path: root/include
2009-03-03Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: don't allow setuid to succeed if the user does not have rt bandwidth sched_rt: don't start timer when rt bandwidth disabled
2009-03-03Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Teach RCU that idle task is not quiscent state at boot
2009-03-02Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: fix warning in io_mapping_map_wc() x86: i915 needs pgprot_writecombine() and is_io_mapping_possible()
2009-03-02fix warning in io_mapping_map_wc()Pallipadi, Venkatesh
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-01net headers: export dcbnl.hChris Leech
The DCB netlink interface is required for building the userspace tools available at e1000.sourceforge.net Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01net headers: cleanup dcbnl.hChris Leech
1) add an include for <linux/types.h> 2) change dcbmsg.dcb_family from unsigned char to __u8 to be more consistent with use of kernel types Signed-off-by: Chris Leech <christopher.leech@intel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-27Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: enable DMAR by default xen: disable interrupts early, as start_kernel expects gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_t gpu/drm, x86, PAT: Handle io_mapping_create_wc() errors in a clean way x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_map x86, doc: fix references to Documentation/x86/i386/boot.txt
2009-02-27Fix recursive lock in free_uid()/free_user_ns()David Howells
free_uid() and free_user_ns() are corecursive when CONFIG_USER_SCHED=n, but free_user_ns() is called from free_uid() by way of uid_hash_remove(), which requires uidhash_lock to be held. free_user_ns() then calls free_uid() to complete the destruction. Fix this by deferring the destruction of the user_namespace. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27sched: don't allow setuid to succeed if the user does not have rt bandwidthDhaval Giani
Impact: fix hung task with certain (non-default) rt-limit settings Corey Hickey reported that on using setuid to change the uid of a rt process, the process would be unkillable and not be running. This is because there was no rt runtime for that user group. Add in a check to see if a user can attach an rt task to its task group. On failure, return EINVAL, which is also returned in CONFIG_CGROUP_SCHED. Reported-by: Corey Hickey <bugfood-ml@fatooh.org> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26block: reduce stack footprint of blk_recount_segments()Jens Axboe
blk_recalc_rq_segments() requires a request structure passed in, which we don't have from blk_recount_segments(). So the latter allocates one on the stack, using > 400 bytes of stack for that. This can cause us to spill over one page of stack from ext4 at least: 0) 4560 400 blk_recount_segments+0x43/0x62 1) 4160 32 bio_phys_segments+0x1c/0x24 2) 4128 32 blk_rq_bio_prep+0x2a/0xf9 3) 4096 32 init_request_from_bio+0xf9/0xfe 4) 4064 112 __make_request+0x33c/0x3f6 5) 3952 144 generic_make_request+0x2d1/0x321 6) 3808 64 submit_bio+0xb9/0xc3 7) 3744 48 submit_bh+0xea/0x10e 8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4] 9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4] 10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4] 11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4] 12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4] 13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4] 14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4] 15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4] 16) 1664 32 do_writepages+0x2d/0x3c 17) 1632 144 __writeback_single_inode+0x162/0x2cd 18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b 19) 1392 16 sync_sb_inodes+0xe/0x10 20) 1376 48 writeback_inodes+0x69/0xb3 21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9 22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4 23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393 24) 720 80 generic_file_aio_write+0x6c/0xc8 25) 640 80 ext4_file_write+0xa9/0x137 [ext4] 26) 560 320 do_sync_write+0xf0/0x137 27) 240 48 vfs_write+0xb3/0x13c 28) 192 64 sys_write+0x4c/0x74 29) 128 128 system_call_fastpath+0x16/0x1b Split the segment counting out into a __blk_recalc_rq_segments() helper to avoid allocating an onstack request just for checking the physical segment count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-26rcu: Teach RCU that idle task is not quiscent state at bootPaul E. McKenney
This patch fixes a bug located by Vegard Nossum with the aid of kmemcheck, updated based on review comments from Nick Piggin, Ingo Molnar, and Andrew Morton. And cleans up the variable-name and function-name language. ;-) The boot CPU runs in the context of its idle thread during boot-up. During this time, idle_cpu(0) will always return nonzero, which will fool Classic and Hierarchical RCU into deciding that a large chunk of the boot-up sequence is a big long quiescent state. This in turn causes RCU to prematurely end grace periods during this time. This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks() function to ignore the idle task as a quiescent state until the system has started up the scheduler in rest_init(), introducing a new non-API function rcu_idle_now_means_idle() to inform RCU of this transition. RCU maintains an internal rcu_idle_cpu_truthful variable to track this state, which is then used by rcu_check_callback() to determine if it should believe idle_cpu(). Because this patch has the effect of disallowing RCU grace periods during long stretches of the boot-up sequence, this patch also introduces Josh Triplett's UP-only optimization that makes synchronize_rcu() be a no-op if num_online_cpus() returns 1. This allows boot-time code that calls synchronize_rcu() to proceed normally. Note, however, that RCU callbacks registered by call_rcu() will likely queue up until later in the boot sequence. Although rcuclassic and rcutree can also use this same optimization after boot completes, rcupreempt must restrict its use of this optimization to the portion of the boot sequence before the scheduler starts up, given that an rcupreempt RCU read-side critical section may be preeempted. In addition, this patch takes Nick Piggin's suggestion to make the system_state global variable be __read_mostly. Changes since v4: o Changes the name of the introduced function and variable to be less emotional. ;-) Changes since v3: o WARN_ON(nr_context_switches() > 0) to verify that RCU switches out of boot-time mode before the first context switch, as suggested by Nick Piggin. Changes since v2: o Created rcu_blocking_is_gp() internal-to-RCU API that determines whether a call to synchronize_rcu() is itself a grace period. o The definition of rcu_blocking_is_gp() for rcuclassic and rcutree checks to see if but a single CPU is online. o The definition of rcu_blocking_is_gp() for rcupreempt checks to see both if but a single CPU is online and if the system is still in early boot. This allows rcupreempt to again work correctly if running on a single CPU after booting is complete. o Added check to rcupreempt's synchronize_sched() for there being but one online CPU. Tested all three variants both SMP and !SMP, booted fine, passed a short rcutorture test on both x86 and Power. Located-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-25ide: fix refcounting in device driversBartlomiej Zolnierkiewicz
During host driver module removal del_gendisk() results in a final put on drive->gendev and freeing the drive by drive_release_dev(). Convert device drivers from using struct kref to use struct device so device driver's object holds reference on ->gendev and prevents drive from prematurely going away. Also fix ->remove methods to not erroneously drop reference on a host driver by using only put_device() instead of ide*_put(). Reported-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: convert DRM_ERROR to DRM_DEBUG in phys object pwrite path drm/i915: make hw page ioremap use ioremap_wc drm: edid revision 0 is valid drm: Correct unbalanced drm_vblank_put() during mode setting. drm: disable encoders before re-routing them drm: Fix ordering of bit fields in EDID structure leading huge vsync values. drm: Fix shifts of EDID vsync offset/width fields. drm/i915: handle bogus VBT panel timing drm/i915: remove PLL debugging messages
2009-02-25Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix endless "Unknown DMAR structure type" loop VT-d: handle Invalidation Queue Error to avoid system hang intel-iommu: fix build error with INTR_REMAP=y and DMAR=n
2009-02-25gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_tVenkatesh Pallipadi
io_mapping_create_wc should take a resource_size_t parameter in place of unsigned long. With unsigned long, there will be no way to map greater than 4GB address in i386/32 bit. On x86, greater than 4GB addresses cannot be mapped on i386 without PAE. Return error for such a case. Patch also adds a structure for io_mapping, that saves the base, size and type on HAVE_ATOMIC_IOMAP archs, that can be used to verify the offset on io_mapping_map calls. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Eric Anholt <eric@anholt.net> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-25drm: disable encoders before re-routing themJesse Barnes
In some cases we may receive a mode config that has a different CRTC<->encoder map that the current configuration. In that case, we need to disable any re-routed encoders before setting the mode, otherwise they may not pick up the new CRTC (if the output types are incompatible for example). Tested-by: Kristian Høgsberg <krh@bitplanet.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-02-25drm: Fix ordering of bit fields in EDID structure leading huge vsync values.Jesse Barnes
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-02-24Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2009-02-24i2c-dev: Clarify the unit of ioctl I2C_TIMEOUTJean Delvare
The unit in which user-space can set the bus timeout value is jiffies for historical reasons (back when HZ was always 100.) This is however not good because user-space doesn't know how long a jiffy lasts. The timeout value should instead be set in a fixed time unit. Given the original value of HZ, this unit should be 10 ms, for compatibility. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2009-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix double free at netns creation veth : add the set_mac_address capability sunlance: Beyond ARRAY_SIZE of ib->btx_ring sungem: another error printed one too early ISDN: fix sc/shmem printk format warning SMSC: timeout reaches -1 smsc9420: handle magic field of ethtool_eeprom sundance: missing parentheses? smsc9420: fix another postfixed timeout wimax/i2400m: driver loads firmware v1.4 instead of v1.3 vlan: Update skb->mac_header in __vlan_put_tag(). cxgb3: Add support for PCI ID 0x35. tcp: remove obsoleted comment about different passes TG3: &&/|| confusion ATM: misplaced parentheses? net/mv643xx: don't disable the mib timer too early and lock properly net/mv643xx: use GFP_ATOMIC while atomic atl1c: Atheros L1C Gigabit Ethernet driver net: Kill skb_truesize_check(), it only catches false-positives. net: forcedeth: Fix wake-on-lan regression
2009-02-22PM: Split up sysdev_[suspend|resume] from device_power_[down|up]Rafael J. Wysocki
Move the sysdev_suspend/resume from the callee to the callers, with no real change in semantics, so that we can rework the disabling of interrupts during suspend/hibernation. This is based on an earlier patch from Linus. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-21Merge branch 'hibernate'Linus Torvalds
* hibernate: PM: Fix suspend_console and resume_console to use only one semaphore PM: Wait for console in resume PM: Fix pm_notifiers during user mode hibernation swsusp: clean up shrink_all_zones() swsusp: dont fiddle with swappiness PM: fix build for CONFIG_PM unset PM/hibernate: fix "swap breaks after hibernation failures" PM/resume: wait for device probing to finish Consolidate driver_probe_done() loops into one place
2009-02-21Consolidate driver_probe_done() loops into one placeArjan van de Ven
there's a few places that currently loop over driver_probe_done(), and I'm about to add another one. This patch abstracts it into a helper to reduce duplication. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Acked-by: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (26 commits) drm/radeon: update sarea copies of last_ variables on resume. drm/i915: Keep refs on the object over the lifetime of vmas for GTT mmap. drm/i915: take struct mutex around fb unref drm: Use spread spectrum when the bios tells us it's ok. drm: Collapse identical i8xx_clock() and i9xx_clock(). drm: Bring PLL limits in sync with DDX values. drm: Add locking around cursor gem operations. drm: Propagate failure from setting crtc base. drm: Check for a NULL encoder when reverting on error path drm/i915: Cleanup the hws on ringbuffer constrution failure. drm/i915: Don't add panel_fixed_mode to the probed modes list at LVDS init. drm: Release user fbs in drm_release drm/i915: Unpin the fb on error during construction. drm/i915: Unpin the hws if we fail to kmap. drm/i915: Unpin the ringbuffer if we fail to ioremap it. drm/i915: unpin for an invalid memory domain. drm/i915: Release and unlock on mmap_gtt error path. drm/i915: Set framebuffer alignment based upon the fence constraints. drm: Do not leak a new reference for flink() on an existing name drm/i915: Fix potential AB-BA deadlock in i915_gem_execbuffer() ...
2009-02-208250: fix boot hang with serial console when using with Serial Over Lan portMauro Carvalho Chehab
Intel 8257x Ethernet boards have a feature called Serial Over Lan. This feature works by emulating a serial port, and it is detected by kernel as a normal 8250 port. However, this emulation is not perfect, as also noticed on changeset 7500b1f602aad75901774a67a687ee985d85893f. Before this patch, the kernel were trying to check if the serial TX is capable of work using IRQ's. This were done with a code similar this: serial_outp(up, UART_IER, UART_IER_THRI); lsr = serial_in(up, UART_LSR); iir = serial_in(up, UART_IIR); serial_outp(up, UART_IER, 0); if (lsr & UART_LSR_TEMT && iir & UART_IIR_NO_INT) up->bugs |= UART_BUG_TXEN; This works fine for other 8250 ports, but, on 8250-emulated SoL port, the chip is a little lazy to down UART_IIR_NO_INT at UART_IIR register. Due to that, UART_BUG_TXEN is sometimes enabled. However, as TX IRQ keeps working, and the TX polling is now enabled, the driver miss-interprets the IRQ received later, hanging up the machine until a key is pressed at the serial console. This is the 6 version of this patch. Previous versions were trying to introduce a large enough delay between serial_outp and serial_in(up, UART_IIR), but not taking forever. However, the needed delay couldn't be safely determined. At the experimental tests, a delay of 1us solves most of the cases, but still hangs sometimes. Increasing the delay to 5us was better, but still doesn't solve. A very high delay of 50 ms seemed to work every time. However, poking around with delays and pray for it to be enough doesn't seem to be a good approach, even for a quirk. So, instead of playing with random large arbitrary delays, let's just disable UART_BUG_TXEN for all SoL ports. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20spi_bitbang: add more lowlevel function documentationMichael Buesch
This adds more documentation of the lowlevel API to avoid future bugs. Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20slab: introduce kzfree()Johannes Weiner
kzfree() is a wrapper for kfree() that additionally zeroes the underlying memory before releasing it to the slab allocator. Currently there is code which memset()s the memory region of an object before releasing it back to the slab allocator to make sure security-sensitive data are really zeroed out after use. These callsites can then just use kzfree() which saves some code, makes users greppable and allows for a stupid destructor that isn't necessarily aware of the actual object size. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20drm/i915: Keep refs on the object over the lifetime of vmas for GTT mmap.Jesse Barnes
This fixes potential fault at fault time if the object was unreferenced while the mapping still existed. Now, while the mmap_offset only lives for the lifetime of the object, the object also stays alive while a vma exists that needs it. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-02-20drm: Propagate failure from setting crtc base.Chris Wilson
Check the error paths within intel_pipe_set_base() to first cleanup and then report back the error. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-02-20drm: Release user fbs in drm_releaseKristian Høgsberg
Avoids leaking fbs and associated buffers on release. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Tested-by: Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-02-18vlan: Update skb->mac_header in __vlan_put_tag().Jarek Poplawski
After moving mac addresses in __vlan_put_tag() skb->mac_header needs to be updated. Reported-by: Karl Hiramoto <karl@hiramoto.org> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: fix deadlock in blk_abort_queue() for drivers that readd to timeout list block: fix booting from partitioned md array block: revert part of 18ce3751ccd488c78d3827e9f6bf54e6322676fb cciss: PCI power management reset for kexec paride/pg.c: xs(): &&/|| confusion fs/bio: bio_alloc_bioset: pass right object ptr to mempool_free block: fix bad definition of BIO_RW_SYNC bsg: Fix sense buffer bug in SG_IO
2009-02-18Bernhard has movedBernhard Walle
Since I don't work for SUSE any more and the bwalle@suse.de address is invalid, correct it in the copyright headers and documentation. Signed-off-by: Bernhard Walle <bernhard.walle@gmx.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18jsm: additional device supportAdam Lackorzynski
I have a Digi Neo 8 PCI card (114f:00b1) Serial controller: Digi International Digi Neo 8 (rev 05) that works with the jsm driver after using the following patch. Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de> Cc: Scott H Kilau <Scott_Kilau@digi.com> Cc: Wendy Xiong <wendyx@us.ibm.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18mm: fix memmap init for handling memory holeKAMEZAWA Hiroyuki
Now, early_pfn_in_nid(PFN, NID) may returns false if PFN is a hole. and memmap initialization was not done. This was a trouble for sparc boot. To fix this, the PFN should be initialized and marked as PG_reserved. This patch changes early_pfn_in_nid() return true if PFN is a hole. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reported-by: David Miller <davem@davemlloft.net> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18mm: clean up for early_pfn_to_nid()KAMEZAWA Hiroyuki
What's happening is that the assertion in mm/page_alloc.c:move_freepages() is triggering: BUG_ON(page_zone(start_page) != page_zone(end_page)); Once I knew this is what was happening, I added some annotations: if (unlikely(page_zone(start_page) != page_zone(end_page))) { printk(KERN_ERR "move_freepages: Bogus zones: " "start_page[%p] end_page[%p] zone[%p]\n", start_page, end_page, zone); printk(KERN_ERR "move_freepages: " "start_zone[%p] end_zone[%p]\n", page_zone(start_page), page_zone(end_page)); printk(KERN_ERR "move_freepages: " "start_pfn[0x%lx] end_pfn[0x%lx]\n", page_to_pfn(start_page), page_to_pfn(end_page)); printk(KERN_ERR "move_freepages: " "start_nid[%d] end_nid[%d]\n", page_to_nid(start_page), page_to_nid(end_page)); ... And here's what I got: move_freepages: Bogus zones: start_page[2207d0000] end_page[2207dffc0] zone[fffff8103effcb00] move_freepages: start_zone[fffff8103effcb00] end_zone[fffff8003fffeb00] move_freepages: start_pfn[0x81f600] end_pfn[0x81f7ff] move_freepages: start_nid[1] end_nid[0] My memory layout on this box is: [ 0.000000] Zone PFN ranges: [ 0.000000] Normal 0x00000000 -> 0x0081ff5d [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[8] active PFN ranges [ 0.000000] 0: 0x00000000 -> 0x00020000 [ 0.000000] 1: 0x00800000 -> 0x0081f7ff [ 0.000000] 1: 0x0081f800 -> 0x0081fe50 [ 0.000000] 1: 0x0081fed1 -> 0x0081fed8 [ 0.000000] 1: 0x0081feda -> 0x0081fedb [ 0.000000] 1: 0x0081fedd -> 0x0081fee5 [ 0.000000] 1: 0x0081fee7 -> 0x0081ff51 [ 0.000000] 1: 0x0081ff59 -> 0x0081ff5d So it's a block move in that 0x81f600-->0x81f7ff region which triggers the problem. This patch: Declaration of early_pfn_to_nid() is scattered over per-arch include files, and it seems it's complicated to know when the declaration is used. I think it makes fix-for-memmap-init not easy. This patch moves all declaration to include/linux/mm.h After this, if !CONFIG_NODES_POPULATES_NODE_MAP && !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID -> Use static definition in include/linux/mm.h else if !CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID -> Use generic definition in mm/page_alloc.c else -> per-arch back end function will be called. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: David Miller <davem@davemlloft.net> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18atmel-mci: fix initialization of dma slave dataDan Williams
The conversion of atmel-mci to dma_request_channel missed the initialization of the channel dma_slave information. The filter_fn passed to dma_request_channel is responsible for initializing the channel's private data. This implementation has the additional benefit of enabling a generic client-channel data passing mechanism. Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18mm: task dirty accounting fixNick Piggin
YAMAMOTO-san noticed that task_dirty_inc doesn't seem to be called properly for cases where set_page_dirty is not used to dirty a page (eg. mark_buffer_dirty). Additionally, there is some inconsistency about when task_dirty_inc is called. It is used for dirty balancing, however it even gets called for __set_page_dirty_no_writeback. So rather than increment it in a set_page_dirty wrapper, move it down to exactly where the dirty page accounting stats are incremented. Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18timerfd: add flags checkDavide Libenzi
As requested by Michael, add a missing check for valid flags in timerfd_settime(), and make it return EINVAL in case some extra bits are set. Michael said: If this is to be any use to userland apps that want to check flag support (perhaps it is too late already), then the sooner we get it into the kernel the better: 2.6.29 would be good; earlier stables as well would be even better. [akpm@linux-foundation.org: remove unused TFD_FLAGS_SET] Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: <stable@kernel.org> [2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18seq_file: properly cope with preadEric Biederman
Currently seq_read assumes that the offset passed to it is always the offset it passed to user space. In the case pread this assumption is broken and we do the wrong thing when presented with pread. To solve this I introduce an offset cache inside of struct seq_file so we know where our logical file position is. Then in seq_read if we try to read from another offset we reset our data structures and attempt to go to the offset user space wanted. [akpm@linux-foundation.org: restore FMODE_PWRITE] [pjt@google.com: seq_open needs its fmode opened up to take advantage of this] Signed-off-by: Eric Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Paul Turner <pjt@google.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18vfs: separate FMODE_PREAD/FMODE_PWRITE into separate flagsPaul Turner
Separate FMODE_PREAD and FMODE_PWRITE into separate flags to reflect the reality that the read and write paths may have independent restrictions. A git grep verifies that these flags are always cleared together so this new behavior will only apply to interfaces that change to clear flags individually. This is required for "seq_file: properly cope with pread", a post-2.6.25 regression fix. [akpm@linux-foundation.org: add comment] Signed-off-by: Paul Turner <pjt@google.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18vmalloc: add __get_vm_area_caller()Benjamin Herrenschmidt
We have get_vm_area_caller() and __get_vm_area() but not __get_vm_area_caller() On powerpc, I use __get_vm_area() to separate the ranges of addresses given to vmalloc vs. ioremap (various good reasons for that) so in order to be able to implement the new caller tracking in /proc/vmallocinfo, I need a "_caller" variant of it. (akpm: needed for ongoing powerpc development, so merge it early) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-18netfilter: nf_conntrack: don't try to deliver events for untracked connectionsPatrick McHardy
The untracked conntrack actually does usually have events marked for delivery as its not special-cased in that part of the code. Skip the actual delivery since it impacts performance noticeably. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-02-18netfilter: nfnetlink_log: fix per-rule qthreshold overrideEric Leblond
In NFLOG the per-rule qthreshold should overrides per-instance only it is set. With current code, the per-rule qthreshold is 1 if not set and it overrides the per-instance qthreshold. This patch modifies the default xt_NFLOG threshold from 1 to 0. Thus a value of 0 means there is no per-rule setting and the instance parameter has to apply. Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-02-18Merge branch 'master' of /repos/git/net-2.6Patrick McHardy
2009-02-18block: fix bad definition of BIO_RW_SYNCJens Axboe
We can't OR shift values, so get rid of BIO_RW_SYNC and use BIO_RW_SYNCIO and BIO_RW_UNPLUG explicitly. This brings back the behaviour from before 213d9417fec62ef4c3675621b9364a667954d4dd. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-17net: Kill skb_truesize_check(), it only catches false-positives.David S. Miller
A long time ago we had bugs, primarily in TCP, where we would modify skb->truesize (for TSO queue collapsing) in ways which would corrupt the socket memory accounting. skb_truesize_check() was added in order to try and catch this error more systematically. However this debugging check has morphed into a Frankenstein of sorts and these days it does nothing other than catch false-positives. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17Add support for VT6415 PCIE PATA IDE Host ControllerZlatko Calusic
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, vm86: fix preemption bug x86, olpc: fix model detection without OFW x86, hpet: fix for LS21 + HPET = boot hang x86: CPA avoid repeated lazy mmu flush x86: warn if arch_flush_lazy_mmu_cpu is called in preemptible context x86/paravirt: make arch_flush_lazy_mmu/cpu disable preemption x86, pat: fix warn_on_once() while mapping 0-1MB range with /dev/mem x86/cpa: make sure cpa is safe to call in lazy mmu mode x86, ptrace, mm: fix double-free on race
