path: root/include
2013-09-21iio: Add iio_push_buffers_with_timestamp() helperLars-Peter Clausen
Drivers using software buffers often store the timestamp in their data buffer before calling iio_push_to_buffers() with that data buffer. Storing the timestamp in the buffer usually involves some ugly pointer arithmetic. This patch adds a new helper function called iio_push_buffers_with_timestamp() which is similar to iio_push_to_buffers but takes an additional timestamp parameter. The function will help to hide to uglyness in one central place instead of exposing it in every driver. If timestamps are enabled for the IIO device iio_push_buffers_with_timestamp() will store the timestamp as the last element in buffer, before passing the buffer on to iio_push_buffers(). The buffer needs large enough to hold the timestamp in this case. If timestamps are disabled iio_push_buffers_with_timestamp() will behave just like iio_push_buffers(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Denis Ciocca <denis.ciocca@gmail.com> Cc: Manuel Stahl <manuel.stahl@iis.fraunhofer.de> Cc: Ge Gao <ggao@invensense.com> Cc: Peter Meerwald <pmeerw@pmeerw.net> Cc: Jacek Anaszewski <j.anaszewski@samsung.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-21iio: ti_am335x_adc: Add continuous sampling supportZubair Lutfullah
Previously the driver had only one-shot reading functionality. This patch adds continuous sampling support to the driver. Continuous sampling starts when buffer is enabled. HW IRQ wakes worker thread that pushes samples to userspace. Sampling stops when buffer is disabled by userspace. Patil Rachna (TI) laid the ground work for ADC HW register access. Russ Dill (TI) fixed bugs in the driver relevant to FIFOs and IRQs. I fixed channel scanning so multiple ADC channels can be read simultaneously and pushed to userspace. Restructured the driver to fit IIO ABI. And added INDIO_BUFFER_HARDWARE mode. Signed-off-by: Zubair Lutfullah <zubair.lutfullah@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Russ Dill <Russ.Dill@ti.com> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-15iio: iio_push_to_buffers(): Change type of 'data' to const void *Lars-Peter Clausen
Change the type of the 'data' parameter for iio_push_to_buffers() from 'u8 *' to 'const void *'. Drivers typically use the correct type (e.g. __be16 *) for their data buffer. When passing the buffer to iio_push_to_buffers() it needs to be cast to 'u8 *' for the compiler to not complain (and also having to add __force if we want to keep sparse happy as well). Since the buffer implementation should not care about the data layout (except the size of one sample) using a void pointer is the correct thing to do. Also make it const as the buffer implementations are not supposed to modify it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-15iio: add info_mask_[shared_by_dir/shared_by_all]Jonathan Cameron
These two additional info_mask bitmaps should allow all 'standard' numeric attributes to be handled using the read_raw and write_raw callbacks. Whilst this should reduce code, the more important element is that this makes these values easily accessible to in kernel users of IIO devices. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
2013-09-15iio: refactor info mask and ext_info attribute creation.Jonathan Cameron
Introduce an enum to specify whether the attribute is separate or shared. Factor out the bitmap handling for loop into a separate function. Tidy up error handling and add a NULL assignment to squish a false positive warning from GCC. Change ext_info shared type from boolean to enum and update in all drivers. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
2013-09-15iio: drop info_mask from struct iio_devJonathan Cameron
Somehow this got missed when dropping all the code that used it prior to the split. Remove it now, there are no users. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
2013-09-14iio: pressure-core: st: Allow for number of channels to varyLee Jones
At the moment the number of channels specified is dictated by the first sensor supported by the driver. As we add support for more sensors this is likely to vary. Instead of using the ARRAY_SIZE() of the LPS331AP's channel specifier we'll use a new adaptable 'struct st_sensors' element instead. Signed-off-by: Lee Jones <lee.jones@linaro.org> Acked-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-09-14iio: Add INT_TIME (integration time) channel info attributePeter Meerwald
Integration time is in seconds; it controls the measurement time and influences the gain of a sensor. There are two typical ways that scaling is implemented in a device: 1) input amplifier, 2) reference to the ADC is changed. These both result in the accuracy of the ADC varying (by applying its sampling over a more relevant range). Integration time is a way of dealing with noise inherent in the analog sensor itself. In the case of a light sensor, a mixture of photon noise and device specific noise. Photon noise is dealt with by either improving the efficiency of the sensor, (more photons actually captured) which is not easily varied dynamically, or by integrating the measurement over a longer time period. Note that this can also be thought of as an averaging of a number of individual samples and is infact sometimes implemented this way. Altering integration time implies that the duration of a measurement changes, a fact the device's user may be interested in. Hence it makes sense to distinguish between integration time and simple scale. In some devices both types of control are present and whilst they will have similar effects on the amplitude of the reading, their effect on the noise of the measurements will differ considerably. Used by adjd_s311, tsl4531, tcs3472 The following drivers have similar controls (and could be adapted): * tsl2563 (integration time is controlled via CALIBSCALE among other things) * tsl2583 (has integration_time device_attr, but driver doesn't use channels yet) * tsl2x7x (has integration_time attr) Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Cc: Jon Brenner <jon.brenner@ams.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-31iio: Remove trailing ; from function definitionsPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-29iio: at91: Use different prescal, startup mask in MR for different IPiio-for-3.12cJosh Wu
For at91 boards, there are different IPs for adc. Different IPs has different STARTUP & PRESCAL mask in ADC_MR. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-17iio: trigger: implement devm_iio_trigger_alloc/devm_iio_triger_freeJacek Anaszewski
Add a resource managed devm_iio_trigger_alloc()/devm_iio_triger_free() to automatically clean up triggers allocated by IIO drivers, thus leading to simplified IIO drivers code. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Kyunmin Park <kyungmin.park@samsung.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-15Staging: olpc_dcon: replace some magic numbersJens Frederich
This patch replace some magic numbers. I believe it makes the driver more readable. The magic number 0x26 is the XO system embedded controller (EC) command 'DCON power enable/disable'. Number 0x41, and 0x42 are special memory controller settings register. The 0x41 initialize bit sequence 0x101 means: enable memory power down function and special SDRAM clock delay for synchronize SDRAM output and clock signal. The 0x42 initialize squence 0x101 is wrong. According to the specification Bit 8 is reserved, thus not in use. I removed it. Signed-off-by: Jens Frederich <jfrederich@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-12Merge 3.11-rc5 into staging-nextGreg Kroah-Hartman
We want the staging fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-10Merge tag 'nfs-for-3.11-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Stable patch for lockd to fix Oopses due to inappropriate calls to utsname()->nodename - Stable patches for sunrpc to fix Oopses on shutdown when using AF_LOCAL sockets with rpcbind - Fix memory leak and error checking issues in nfs4_proc_lookup_mountpoint - Fix a regression with the sync mount option failing to work for nfs4 mounts - Fix a writeback performance issue when doing cache invalidation - Remove an incorrect call to nfs_setsecurity in nfs_fhget * tag 'nfs-for-3.11-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFSv4: Fix up nfs4_proc_lookup_mountpoint NFS: Remove unnecessary call to nfs_setsecurity in nfs_fhget() NFSv4: Fix the sync mount option for nfs4 mounts NFS: Fix writeback performance issue on cache invalidation SUNRPC: If the rpcbind channel is disconnected, fail the call to unregister SUNRPC: Don't auto-disconnect from the local rpcbind socket LOCKD: Don't call utsname()->nodename from nlmclnt_setlockargs
2013-08-10Merge tag 'staging-3.11-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver fixes from Greg KH: "Here are 3 small fixes for staging/IIO drivers for 3.11-rc5. Nothing huge, two IIO driver fixes, and a zcache fix. All of these have been in linux-next for a while" * tag 'staging-3.11-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: zcache: fix "zcache=" kernel parameter iio: ti_am335x_adc: Fix wrong samples received on 1st read iio:trigger: Fix use_count race condition
2013-08-09Merge tag 'pm+acpi-3.11-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - ACPI-based memory hotplug stopped working after a recent change, because it's not possible to associate sufficiently many "physical" devices with one ACPI device object due to an artificial limit. Fix from Rafael J Wysocki removes that limit and makes memory hotplug work again. - A change made in 3.9 uncovered a bug in the ACPI processor driver preventing NUMA nodes from being put offline due to an ordering issue. Fix from Yasuaki Ishimatsu changes the ordering to make things work again. - One of the recent ACPI video commits (that hasn't been reverted so far) uncovered a bug in the code handling quirky BIOSes that caused some Asus machines to boot with backlight completely off which made it quite difficult to use them afterward. Fix from Felipe Contreras improves the quirk to cover this particular case correctly. - A cpufreq user space interface change made in 3.10 inadvertently renamed the ignore_nice_load sysfs attribute to ignore_nice which resulted in some confusion. Fix from Viresh Kumar changes the name back to ignore_nice_load. - An initialization ordering change made in 3.9 broke cpufreq on loongson2 boards. Fix from Aaro Koskinen restores the correct initialization ordering there. - Fix breakage resulting from a mistake made in 3.9 and causing the detection of some graphics adapters (that were detected correctly before) to fail. There are two objects representing the same PCIe port in the affected systems' ACPI tables and both appear as "enabled" and we are expected to guess which one to use. We used to choose the right one before by pure luck, but when we tried to address another similar corner case, the luck went away. This time we try to make our guessing a bit more educated which is reported to work on those systems. - The /proc/acpi/wakeup interface code is missing some locking which may lead to breakage if that file is written or read during hotplug of wakeup devices. That should be rare but still possible, so it's better to start using the appropriate locking there. * tag 'pm+acpi-3.11-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI: Try harder to resolve _ADR collisions for bridges cpufreq: rename ignore_nice as ignore_nice_load cpufreq: loongson2: fix regression related to clock management ACPI / processor: move try_offline_node() after acpi_unmap_lsapic() ACPI: Drop physical_node_id_bitmap from struct acpi_device ACPI / PM: Walk physical_node_list under physical_node_lock ACPI / video: improve quirk check in acpi_video_bqc_quirk()
2013-08-09Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Some driver fixes (em28xx, coda, usbtv, s5p, hdpvr and ml86v7667) and a fix for media DocBook" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] em28xx: fix assignment of the eeprom data [media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe() [media] usbtv: fix dependency [media] usbtv: Throw corrupted frames away [media] usbtv: Fix deinterlacing [media] v4l2: added missing mutex.h include to v4l2-ctrls.h [media] DocBook: upgrade media_api DocBook version to 4.2 [media] ml86v7667: fix compile warning: 'ret' set but not used [media] s5p-g2d: Fix registration failure [media] media: coda: Fix DT driver data pointer for i.MX27 [media] s5p-mfc: Fix input/output format reporting
2013-08-08userns: limit the maximum depth of user_namespace->parent chainOleg Nesterov
Ensure that user_namespace->parent chain can't grow too much. Currently we use the hardroded 32 as limit. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-08Merge tag 'regmap-v3.11-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap fixes from Mark Brown: "Two things here, one is a fix for a nasty issue where we were failing to sync the last register in a block when using raw writes and the other fixes a missing header for the !REGMAP stubs so that we don't rely on implicit includes in that case" * tag 'regmap-v3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: Add missing header for !CONFIG_REGMAP stubs regmap: cache: Make sure to sync the last register in a block
2013-08-07SUNRPC: If the rpcbind channel is disconnected, fail the call to unregisterTrond Myklebust
If rpcbind causes our connection to the AF_LOCAL socket to close after we've registered a service, then we want to be careful about reconnecting since the mount namespace may have changed. By simply refusing to reconnect the AF_LOCAL socket in the case of unregister, we avoid the need to somehow save the mount namespace. While this may lead to some services not unregistering properly, it should be safe. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Nix <nix@esperi.org.uk> Cc: Jeff Layton <jlayton@redhat.com> Cc: stable@vger.kernel.org # 3.9.x
2013-08-07ACPI: Try harder to resolve _ADR collisions for bridgesRafael J. Wysocki
In theory, under a given ACPI namespace node there should be only one child device object with _ADR whose value matches a given bus address exactly. In practice, however, there are systems in which multiple child device objects under a given parent have _ADR matching exactly the same address. In those cases we use _STA to determine which of the multiple matching devices is enabled, since some systems are known to indicate which ACPI device object to associate with the given physical (usually PCI) device this way. Unfortunately, as it turns out, there are systems in which many device objects under the same parent have _ADR matching exactly the same bus address and none of them has _STA, in which case they all should be regarded as enabled according to the spec. Still, if those device objects are supposed to represent bridges (e.g. this is the case for device objects corresponding to PCIe ports), we can try harder and skip the ones that have no child device objects in the ACPI namespace. With luck, we can avoid using device objects that we are not expected to use this way. Although this only works for bridges whose children also have ACPI namespace representation, it is sufficient to address graphics adapter detection issues on some systems, so rework the code finding a matching device ACPI handle for a given bus address to implement this idea. Introduce a new function, acpi_find_child(), taking three arguments: the ACPI handle of the device's parent, a bus address suitable for the device's bus type and a bool indicating if the device is a bridge and make it work as outlined above. Reimplement the function currently used for this purpose, acpi_get_child(), as a call to acpi_find_child() with the last argument set to 'false' and make the PCI subsystem use acpi_find_child() with the bridge information passed as the last argument to it. [Lan Tianyu notices that it is not sufficient to use pci_is_bridge() for that, because the device's subordinate pointer hasn't been set yet at this point, so use hdr_type instead.] This change fixes a regression introduced inadvertently by commit 33f767d (ACPI: Rework acpi_get_child() to be more efficient) which overlooked the fact that for acpi_walk_namespace() "post-order" means "after all children have been visited" rather than "on the way back", so for device objects without children and for namespace walks of depth 1, as in the acpi_get_child() case, the "post-order" callbacks ordering is actually the same as the ordering of "pre-order" ones. Since that commit changed the namespace walk in acpi_get_child() to terminate after finding the first matching object instead of going through all of them and returning the last one, it effectively changed the result returned by that function in some rare cases and that led to problems (the switch from a "pre-order" to a "post-order" callback was supposed to prevent that from happening, but it was ineffective). As it turns out, the systems where the change made by commit 33f767d actually matters are those where there are multiple ACPI device objects representing the same PCIe port (which effectively is a bridge). Moreover, only one of them, and the one we are expected to use, has child device objects in the ACPI namespace, so the regression can be addressed as described above. References: https://bugzilla.kernel.org/show_bug.cgi?id=60561 Reported-by: Peter Wu <lekensteyn@gmail.com> Tested-by: Vladimir Lalov <mail@vlalov.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
2013-08-07Merge tag 'trace-fixes-3.11-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "Oleg Nesterov has been working hard in closing all the holes that can lead to race conditions between deleting an event and accessing an event debugfs file. This included a fix to the debugfs system (acked by Greg Kroah-Hartman). We think that all the holes have been patched and hopefully we don't find more. I haven't marked all of them for stable because I need to examine them more to figure out how far back some of the changes need to go. Along the way, some other fixes have been made. Alexander Z Lam fixed some logic where the wrong buffer was being modifed. Andrew Vagin found a possible corruption for machines that actually allocate cpumask, as a reference to one was being zeroed out by mistake. Dhaval Giani found a bad prototype when tracing is not configured. And I not only had some changes to help Oleg, but also finally fixed a long standing bug that Dave Jones and others have been hitting, where a module unload and reload can cause the function tracing accounting to get screwed up" * tag 'trace-fixes-3.11-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix reset of time stamps during trace_clock changes tracing: Make TRACE_ITER_STOP_ON_FREE stop the correct buffer tracing: Fix trace_dump_stack() proto when CONFIG_TRACING is not set tracing: Fix fields of struct trace_iterator that are zeroed by mistake tracing/uprobes: Fail to unregister if probe event files are in use tracing/kprobes: Fail to unregister if probe event files are in use tracing: Add comment to describe special break case in probe_remove_event_call() tracing: trace_remove_event_call() should fail if call/file is in use debugfs: debugfs_remove_recursive() must not rely on list_empty(d_subdirs) ftrace: Check module functions being traced on reload ftrace: Consolidate some duplicate code for updating ftrace ops tracing: Change remove_event_file_dir() to clear "d_subdirs"->i_private tracing: Introduce remove_event_file_dir() tracing: Change f_start() to take event_mutex and verify i_private != NULL tracing: Change event_filter_read/write to verify i_private != NULL tracing: Change event_enable/disable_read() to verify i_private != NULL tracing: Turn event/id->i_private into call->event.type
2013-08-06regmap: Add missing header for !CONFIG_REGMAP stubsMateusz Krawczuk
regmap.h requires linux/err.h if CONFIG_REGMAP is not defined. Without it I get error. CC drivers/media/platform/exynos4-is/fimc-reg.o In file included from drivers/media/platform/exynos4-is/fimc-reg.c:14:0: include/linux/regmap.h: In function ‘regmap_write’: include/linux/regmap.h:525:10: error: ‘EINVAL’ undeclared (first use in this function) include/linux/regmap.h:525:10: note: each undeclared identifier is reported only once for each function it appears in Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@kernel.org
2013-08-06ACPI: Drop physical_node_id_bitmap from struct acpi_deviceRafael J. Wysocki
The physical_node_id_bitmap in struct acpi_device is only used for looking up the first currently unused dependent phyiscal node ID by acpi_bind_one(). It is not really necessary, however, because acpi_bind_one() walks the entire physical_node_list of the given device object for sanity checking anyway and if that list is always sorted by node_id, it is straightforward to find the first gap between the currently used node IDs and use that number as the ID of the new list node. This also removes the artificial limit of the maximum number of dependent physical devices per ACPI device object, which now depends only on the capacity of unsigend int. As a result, it fixes a regression introduced by commit e2ff394 (ACPI / memhotplug: Bind removable memory blocks to ACPI device nodes) that caused acpi_memory_enable_device() to fail when the number of 128 MB blocks within one removable memory module was greater than 32. Reported-and-tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
2013-08-05Merge tag 'iio-fixes-for-3.11b' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Second round of IIO fixes for the 3.11 cycle. 1) Fix a long term race in the IIO trigger handling. This only effects cases where a single trigger is in use by multiple devices. 2) ti_am335x fix an issue with incorrect data due to reading before the sequencer is finished.
2013-08-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't ignore user initiated wireless regulatory settings on cards with custom regulatory domains, from Arik Nemtsov. 2) Fix length check of bluetooth information responses, from Jaganath Kanakkassery. 3) Fix misuse of PTR_ERR in btusb, from Adam Lee. 4) Handle rfkill properly while iwlwifi devices are offline, from Emmanuel Grumbach. 5) Fix r815x devices DMA'ing to stack buffers, from Hayes Wang. 6) Kernel info leak in ATM packet scheduler, from Dan Carpenter. 7) 8139cp doesn't check for DMA mapping errors, from Neil Horman. 8) Fix bridge multicast code to not snoop when no querier exists, otherwise mutlicast traffic is lost. From Linus Lüssing. 9) Avoid soft lockups in fib6_run_gc(), from Michal Kubecek. 10) Fix races in automatic address asignment on ipv6, which can result in incorrect lifetime assignments. From Jiri Benc. 11) Cure build bustage when CONFIG_NET_LL_RX_POLL is not set and rename it CONFIG_NET_RX_BUSY_POLL to eliminate the last reference to the original naming of this feature. From Cong Wang. 12) Fix crash in TIPC when server socket creation fails, from Ying Xue. 13) macvlan_changelink() silently succeeds when it shouldn't, from Michael S Tsirkin. 14) HTB packet scheduler can crash due to sign extension, fix from Stephen Hemminger. 15) With the cable unplugged, r8169 prints out a message every 10 seconds, make it netif_dbg() instead of netif_warn(). From Peter Wu. 16) Fix memory leak in rtm_to_ifaddr(), from Daniel Borkmann. 17) sis900 gets spurious TX queue timeouts due to mismanagement of link carrier state, from Denis Kirjanov. 18) Validate somaxconn sysctl to make sure it fits inside of a u16. From Roman Gushchin. 19) Fix MAC address filtering on qlcnic, from Shahed Shaikh. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits) qlcnic: Fix for flash update failure on 83xx adapter qlcnic: Fix link speed and duplex display for 83xx adapter qlcnic: Fix link speed display for 82xx adapter qlcnic: Fix external loopback test. qlcnic: Removed adapter series name from warning messages. qlcnic: Free up memory in error path. qlcnic: Fix ingress MAC learning qlcnic: Fix MAC address filter issue on 82xx adapter net: ethernet: davinci_emac: drop IRQF_DISABLED netlabel: use domain based selectors when address based selectors are not available net: check net.core.somaxconn sysctl values sis900: Fix the tx queue timeout issue net: rtm_to_ifaddr: free ifa if ifa_cacheinfo processing fails r8169: remove "PHY reset until link up" log spam net: ethernet: cpsw: drop IRQF_DISABLED htb: fix sign extension bug macvlan: handle set_promiscuity failures macvlan: better mode validation tipc: fix oops when creating server socket fails net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLL ...
2013-08-03iio: Fix documentation of devm_iio_device_free()Peter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-03iio: core: implement devm_iio_device_alloc/devm_iio_device_freeGrygorii Strashko
Add a resource managed devm_iio_device_alloc()/devm_iio_device_free() to automatically clean up any allocations made by IIO drivers, thus leading to simplified IIO drivers code. In addition, this will allow IIO drivers to use other devm_*() API (like devm_request_irq) and don't care about the race between iio_device_free() and the release of resources by Device core during driver removing. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Tested-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-03iio: Remove IIO_DEV_ATTR_RESET macroLars-Peter Clausen
There are no users of this macro left and we have come to the conclusion that it is not a good idea to expose the raw chip reset to userspace so the macro is very unlikely to be used in new drivers. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-03iio: Added ST-sensors platform data to select the DRDY interrupt pinDenis CIOCCA
This patch add support to redirect the DRDY interrupt on INT1 or INT2 on accelerometer and pressure sensors. Signed-off-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-08-02tracing: Fix trace_dump_stack() proto when CONFIG_TRACING is not setDhaval Giani
When CONFIG_TRACING is not enabled, the stub prototype for trace_dump_stack() is incorrect. It has (void) when it should be (int). Link: http://lkml.kernel.org/r/CAPhKKr_H=ukFnBL4WgDOVT5ay2xeF-Ho+CA0DWZX0E2JW-=vSQ@mail.gmail.com Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-08-02tracing: Fix fields of struct trace_iterator that are zeroed by mistakeAndrew Vagin
tracing_read_pipe zeros all fields bellow "seq". The declaration contains a comment about that, but it doesn't help. The first field is "snapshot", it's true when current open file is snapshot. Looks obvious, that it should not be zeroed. The second field is "started". It was converted from cpumask_t to cpumask_var_t (v2.6.28-4983-g4462344), in other words it was converted from cpumask to pointer on cpumask. Currently the reference on "started" memory is lost after the first read from tracing_read_pipe and a proper object will never be freed. The "started" is never dereferenced for trace_pipe, because trace_pipe can't have the TRACE_FILE_ANNOTATE options. Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org Cc: stable@vger.kernel.org # 2.6.30 Signed-off-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-08-02Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/rdma fixes from Roland Dreier: - Fixes for the newly merged mlx5 hardware driver - Stack info leak fixes from Dan Carpenter - Fixes for pkey table handling with SR-IOV - A few other small things * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IPoIB: Fix pkey change flow for virtualization environments IPoIB: Make sure child devices use valid/proper pkeys IB/core: Create QP1 using the pkey index which contains the default pkey mlx5_core: Variable may be used uninitialized mlx5_core: Implement new initialization sequence mlx5_core: Fix use after free in mlx5_cmd_comp_handler() IB/mlx5: Fix stack info leak in mlx5_ib_alloc_ucontext() IB/mlx5: Fix error return code in init_one() IB/mlx4: Use default pkey when creating tunnel QPs RDMA/cma: Only call cma_save_ib_info() for CM REQs RDMA/cma: Fix accessing invalid private data for UD RDMA/cma: Fix gcc warning Revert "RDMA/nes: Fix compilation error when nes_debug is enabled" IB/qib: Add err_decode() call for ring dump RDMA/cxgb3: Fix stack info leak in iwch_create_cq() RDMA/nes: Fix info leaks in nes_create_qp() and nes_create_cq() RDMA/ocrdma: Fix several stack info leaks RDMA/cxgb4: Fix stack info leak in c4iw_create_qp() RDMA/ocrdma: Remove unused include
2013-08-02Merge tag 'pm+acpi-3.11-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - Revert two cpuidle commits added during the 3.8 development cycle that turn out to have introduced a significant performance regression as requested by Jeremy Eder. - The recent patches that made the freezer less heavy-weight introduced a regression causing user-space-driven hibernation using the ioctl() interface to block indefinitely when the hibernate process executes try_to_freeze(). Fix from Colin Cross addresses this by adding a process flag to mark the hibernate/suspend process to inform the freezer that that process should be ignored. - One of the recent cpufreq reverts uncovered a problem in the core causing the cpufreq driver module refcount to become negative after a system suspend-resume cycle. Fix from Rafael J Wysocki. - The evaluation of the ACPI battery _BIX method has never worked correctly, because the commit that added support for it forgot to take the "Revision" field in the return package into account. As a result, the reading of battery info doesn't work at all on some systems, which is addressed by a fix from Lan Tianyu. * tag 'pm+acpi-3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: freezer: set PF_SUSPEND_TASK flag on tasks that call freeze_processes ACPI / battery: Fix parsing _BIX return value cpufreq: Fix cpufreq driver module refcount balance after suspend/resume Revert "cpuidle: Quickly notice prediction failure for repeat mode" Revert "cpuidle: Quickly notice prediction failure in general case"
2013-08-01net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLLCong Wang
Eliezer renames several *ll_poll to *busy_poll, but forgets CONFIG_NET_LL_RX_POLL, so in case of confusion, rename it too. Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01net: fix a compile error when CONFIG_NET_LL_RX_POLL is not setCong Wang
When CONFIG_NET_LL_RX_POLL is not set, I got: net/socket.c: In function ‘sock_poll’: net/socket.c:1165:4: error: implicit declaration of function ‘sk_busy_loop’ [-Werror=implicit-function-declaration] Fix this by adding a nop when !CONFIG_NET_LL_RX_POLL. Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01ipv6: prevent fib6_run_gc() contentionMichal Kubeček
On a high-traffic router with many processors and many IPv6 dst entries, soft lockup in fib6_run_gc() can occur when number of entries reaches gc_thresh. This happens because fib6_run_gc() uses fib6_gc_lock to allow only one thread to run the garbage collector but ip6_dst_gc() doesn't update net->ipv6.ip6_rt_last_gc until fib6_run_gc() returns. On a system with many entries, this can take some time so that in the meantime, other threads pass the tests in ip6_dst_gc() (ip6_rt_last_gc is still not updated) and wait for the lock. They then have to run the garbage collector one after another which blocks them for quite long. Resolve this by replacing special value ~0UL of expire parameter to fib6_run_gc() by explicit "force" parameter to choose between spin_lock_bh() and spin_trylock_bh() and call fib6_run_gc() with force=false if gc_thresh is reached but not max_size. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-07-31Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Radeon, nouveau, exynos, intel, mgag200.. Not all strictly regressions but there was probably only one patch I'd have really left out and it didn't seem worth respinning exynos to avoid it, the line change count is quite low. radeon: regressions + more dynamic powermanagement fixes, since DPM is a new feature, and off by default I'd prefer to keep merging fixes since it has a large userbase already and I'd like to keep them on mainline nouveau: is mostly regression fixes i915: is a regression fix since Daniel is on holidays I've merged it. mgag200: I've picked a bunch of targetted fixes from a big bunch of distro patches, exynos: build fixes mostly, one regression fix I expect things will slow right down now, I may send on the intel early quirk from Jesse separatly, since I think the x86 maintainers acked it" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (37 commits) drm/i915: fix missed hunk after GT access breakage drm/radeon/dpm: re-enable cac control on SI drm/radeon/dpm: fix calculations in si_calculate_leakage_for_v_and_t_formula drm: fix 64 bit drm fixed point helpers drm/radeon/atom: initialize more atom interpretor elements to 0 drm/nouveau: fix semaphore dmabuf obj drm/nouveau/vm: make vm refcount into a kref drm/nv31/mpeg: don't recognize nv3x cards as having nv44 graph class drm/nv40/mpeg: write magic value to channel object to make it work drm/nouveau: fix size check for cards without vm drm/nv50-/disp: remove dcb_outp_match call, and related variables drm/nva3-/disp: fix hda eld writing, needs to be padded drm/nv31/mpeg: fix mpeg engine initialization drm/nv50/mc: include vp in the fb error reporting mask drm/nouveau: fix null pointer dereference in poll_changed drm/nv50/gpio: post-nv92 cards have 32 interrupt lines drm/nvc0/fb: take lock in nvc0_ram_put() drm/nouveau/core: xtensa firmware size needs to be 0x40000 no matter what drm/mgag200: Fix LUT programming for 16bpp drm/mgag200: Fix framebuffer pitch calculation ...
2013-07-31Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge more patches from Andrew Morton: "A bunch of fixes. Plus Joe's printk move and rework. It's not a -rc3 thing but now would be a nice time to offload it, while things are quiet. I've been sitting on it all for a couple of weeks, no issues" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: vmpressure: make sure there are no events queued after memcg is offlined vmpressure: do not check for pending work to prevent from new work vmpressure: change vmpressure::sr_lock to spinlock printk: rename struct log to struct printk_log printk: use pointer for console_cmdline indexing printk: move braille console support into separate braille.[ch] files printk: add console_cmdline.h printk: move to separate directory for easier modification drivers/rtc/rtc-twl.c: fix: rtcX/wakealarm attribute isn't created mm: zbud: fix condition check on allocation size thp, mm: avoid PageUnevictable on active/inactive lru lists mm/swap.c: clear PageActive before adding pages onto unevictable list arch/x86/platform/ce4100/ce4100.c: include reboot.h mm: sched: numa: fix NUMA balancing when !SCHED_DEBUG rapidio: fix use after free in rio_unregister_scan() .gitignore: ignore *.lz4 files MAINTAINERS: dynamic debug: Jason's not there... dmi_scan: add comments on dmi_present() and the loop in dmi_scan_machine() ocfs2/refcounttree: add the missing NULL check of the return value of find_or_create_page() mm: mempolicy: fix mbind_range() && vma_adjust() interaction
2013-07-31ndisc: Add missing inline to ndisc_addr_option_padJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-31vmpressure: make sure there are no events queued after memcg is offlinedMichal Hocko
vmpressure is called synchronously from reclaim where the target_memcg is guaranteed to be alive but the eventfd is signaled from the work queue context. This means that memcg (along with vmpressure structure which is embedded into it) might go away while the work item is pending which would result in use-after-release bug. We have two possible ways how to fix this. Either vmpressure pins memcg before it schedules vmpr->work and unpin it in vmpressure_work_fn or explicitely flush the work item from the css_offline context (as suggested by Tejun). This patch implements the later one and it introduces vmpressure_cleanup which flushes the vmpressure work queue item item. It hooks into mem_cgroup_css_offline after the memcg itself is cleaned up. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michal Hocko <mhocko@suse.cz> Reported-by: Tejun Heo <tj@kernel.org> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Li Zefan <lizefan@huawei.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31vmpressure: change vmpressure::sr_lock to spinlockMichal Hocko
There is nothing that can sleep inside critical sections protected by this lock and those sections are really small so there doesn't make much sense to use mutex for them. Change the log to a spinlock Signed-off-by: Michal Hocko <mhocko@suse.cz> Reported-by: Tejun Heo <tj@kernel.org> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Li Zefan <lizefan@huawei.com> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31mlx5_core: Implement new initialization sequenceEli Cohen
Introduce enbale_hca and disable_hca commands to signify when the driver starts or ceases to operate on the device. In addition the driver will use boot and init pages count; boot pages is required to allow firmware to complete boot commands and the other to complete init hca. Command interface revision is bumped to 4 to enforce using supported firmware. This patch breaks compatibility with old versions of firmware (< 4); however, the first GA firmware we will publish will support version 4 so this should not be a problem. Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix association failures not triggering a connect-failure event in cfg80211, from Johannes Berg. 2) Eliminate a potential NULL deref with older iptables tools when configuring xt_socket rules, from Eric Dumazet. 3) Missing RTNL locking in wireless regulatory code, from Johannes Berg. 4) Fix OOPS caused by firmware loading races in ath9k_htc, from Alexey Khoroshilov. 5) Fix usb URB leak in usb_8dev CAN driver, also from Alexey Khoroshilov. 6) VXLAN namespace teardown fails to unregister devices, from Stephen Hemminger. 7) Fix multicast settings getting dropped by firmware in qlcnic driver, from Sucheta Chakraborty. 8) Add sysctl range enforcement for tcp_syn_retries, from Michal Tesar. 9) Fix a nasty bug in bridging where an active timer would get reinitialized with a setup_timer() call. From Eric Dumazet. 10) Fix use after free in new mlx5 driver, from Dan Carpenter. 11) Fix freed pointer reference in ipv6 multicast routing on namespace cleanup, from Hannes Frederic Sowa. 12) Some usbnet drivers report TSO and SG in their feature set, but the usbnet layer doesn't really support them. From Eric Dumazet. 13) Fix crash on EEH errors in tg3 driver, from Gavin Shan. 14) Drop cb_lock when requesting modules in genetlink, from Stanislaw Gruszka. 15) Kernel stack leaks in cbq scheduler and af_key pfkey messages, from Dan Carpenter. 16) FEC driver erroneously signals NETDEV_TX_BUSY on transmit leading to endless loops, from Uwe Kleine-König. 17) Fix hangs from loading mvneta driver, from Arnaud Patard. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (84 commits) mlx5: fix error return code in mlx5_alloc_uuars() mvneta: Try to fix mvneta when compiled as module mvneta: Fix hang when loading the mvneta driver atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring genetlink: fix usage of NLM_F_EXCL or NLM_F_REPLACE af_key: more info leaks in pfkey messages net/fec: Don't let ndo_start_xmit return NETDEV_TX_BUSY without link net_sched: Fix stack info leak in cbq_dump_wrr(). igb: fix vlan filtering in promisc mode when not in VT mode ixgbe: Fix Tx Hang issue with lldpad on 82598EB genetlink: release cb_lock before requesting additional module net: fec: workaround stop tx during errata ERR006358 qlcnic: Fix diagnostic interrupt test for 83xx adapters. qlcnic: Fix setting Guest VLAN qlcnic: Fix operation type and command type. qlcnic: Fix initialization of work function. Revert "atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring" atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring net/tg3: Fix warning from pci_disable_device() net/tg3: Fix kernel crash ...
2013-07-31tracing: trace_remove_event_call() should fail if call/file is in useOleg Nesterov
Change trace_remove_event_call(call) to return the error if this call is active. This is what the callers assume but can't verify outside of the tracing locks. Both trace_kprobe.c/trace_uprobe.c need the additional changes, unregister_trace_probe() should abort if trace_remove_event_call() fails. The caller is going to free this call/file so we must ensure that nobody can use them after trace_remove_event_call() succeeds. debugfs should be fine after the previous changes and event_remove() does TRACE_REG_UNREGISTER, but still there are 2 reasons why we need the additional checks: - There could be a perf_event(s) attached to this tp_event, so the patch checks ->perf_refcount. - TRACE_REG_UNREGISTER can be suppressed by FTRACE_EVENT_FL_SOFT_MODE, so we simply check FTRACE_EVENT_FL_ENABLED protected by event_mutex. Link: http://lkml.kernel.org/r/20130729175033.GB26284@redhat.com Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-07-31NFC: netlink: Rename CMD_FW_UPLOAD to CMD_FW_DOWNLOADSamuel Ortiz
Loading a firmware into a target is typically called firmware download, not firmware upload. So we rename the netlink API to NFC_CMD_FW_DOWNLOAD in order to avoid any terminology confusion from userspace. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-07-31Merge branch 'drm-fixes-3.11' of git://people.freedesktop.org/~agd5f/linuxDave Airlie
Alex writes: - more fixes for SI dpm - fix DP on some rv6xx boards * 'drm-fixes-3.11' of git://people.freedesktop.org/~agd5f/linux: drm/radeon/dpm: re-enable cac control on SI drm/radeon/dpm: fix calculations in si_calculate_leakage_for_v_and_t_formula drm: fix 64 bit drm fixed point helpers drm/radeon/atom: initialize more atom interpretor elements to 0
2013-07-30drm: fix 64 bit drm fixed point helpersAlex Deucher
Sign bit wasn't handled properly and a small typo. Thanks to Christian for helping me sort this out. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-07-30freezer: set PF_SUSPEND_TASK flag on tasks that call freeze_processesColin Cross
Calling freeze_processes sets a global flag that will cause any process that calls try_to_freeze to enter the refrigerator. It skips sending a signal to the current task, but if the current task ever hits try_to_freeze, all threads will be frozen and the system will deadlock. Set a new flag, PF_SUSPEND_TASK, on the task that calls freeze_processes. The flag notifies the freezer that the thread is involved in suspend and should not be frozen. Also add a WARN_ON in thaw_processes if the caller does not have the PF_SUSPEND_TASK flag set to catch if a different task calls thaw_processes than the one that called freeze_processes, leaving a task with PF_SUSPEND_TASK permanently set on it. Threads that spawn off a task with PF_SUSPEND_TASK set (which swsusp does) will also have PF_SUSPEND_TASK set, preventing them from freezing while they are helping with suspend, but they need to be dead by the time suspend is triggered, otherwise they may run when userspace is expected to be frozen. Add a WARN_ON in thaw_processes if more than one thread has the PF_SUSPEND_TASK flag set. Reported-and-tested-by: Michael Leun <lkml20130126@newton.leun.net> Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
