path: root/include
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: vmstat show NR_KAISERTABLE as nr_overheadHugh Dickins
The kaiser update made an interesting choice, never to free any shadow page tables. Contention on global spinlock was worrying, particularly with it held across page table scans when freeing. Something had to be done: I was going to add refcounting; but simply never to free them is an appealing choice, minimizing contention without complicating the code (the more a page table is found already, the less the spinlock is used). But leaking pages in this way is also a worry: can we get away with it? At the very least, we need a count to show how bad it actually gets: in principle, one might end up wasting about 1/256 of memory that way (1/512 for when direct-mapped pages have to be user-mapped, plus 1/512 for when they are user-mapped from the vmalloc area on another occasion (but we don't have vmalloc'ed stacks, so only large ldts are vmalloc'ed). Add per-cpu stat NR_KAISERTABLE: including 256 at startup for the shared pgd entries, and 1 for each intermediate page table added thereafter for user-mapping - but leave out the 1 per mm, for its shadow pgd, because that distracts from the monotonic increase. Shown in /proc/vmstat as nr_overhead (0 if kaiser not enabled). In practice, it doesn't look so bad so far: more like 1/12000 after nine hours of gtests below; and movable pageblock segregation should tend to cluster the kaiser tables into a subset of the address space (if not, they will be bad for compaction too). But production may tell a different story: keep an eye on this number, and bring back lighter freeing if it gets out of control (maybe a shrinker). ["nr_overhead" should of course say "nr_kaisertable", if it needs to stay; but for the moment we are being coy, preferring that when Joe Blow notices a new line in his /proc/vmstat, he does not get too curious about what this "kaiser" stuff might be.] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: cleanups while trying for gold linkHugh Dickins
While trying to get our gold link to work, four cleanups: matched the gdt_page declaration to its definition; in fiddling unsuccessfully with PERCPU_INPUT(), lined up backslashes; lined up the backslashes according to convention in percpu-defs.h; deleted the unused irq_stack_pointer addition to irq_stack_union. Sad to report that aligning backslashes does not appear to help gold align to 8192: but while these did not help, they are worth keeping. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: stack map PAGE_SIZE at THREAD_SIZE-PAGE_SIZEHugh Dickins
Kaiser only needs to map one page of the stack; and kernel/fork.c did not build on powerpc (no __PAGE_KERNEL). It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack() and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's kaiser_add_mapping() and kaiser_remove_mapping(). And use linux/kaiser.h in init/main.c to avoid the #ifdefs there. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: merged updateDave Hansen
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02mm/vmstat: Make NR_TLB_REMOTE_FLUSH_RECEIVED available even on UPAndy Lutomirski
commit 5dd0b16cdaff9b94da06074d5888b03235c0bf17 upstream. This fixes CONFIG_SMP=n, CONFIG_DEBUG_TLBFLUSH=y without introducing further #ifdef soup. Caught by a Kbuild bot randconfig build. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: ce4a4e565f52 ("x86/mm: Remove the UP asm/tlbflush.h code, always use the (formerly) SMP code") Link: http://lkml.kernel.org/r/76da9a3cc4415996f2ad2c905b93414add322021.1496673616.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02timers: Reinitialize per cpu bases on hotplugThomas Gleixner
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream. The timer wheel bases are not (re)initialized on CPU hotplug. That leaves them with a potentially stale clk and next_expiry valuem, which can cause trouble then the CPU is plugged. Add a prepare callback which forwards the clock, sets next_expiry to far in the future and reset the control flags to a known state. Set base->must_forward_clk so the first timer which is queued will try to forward the clock to current jiffies. Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel") Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02net/mlx5: Fix rate limit packet pacing naming and structEran Ben Elisha
[ Upstream commit 37e92a9d4fe38dc3e7308913575983a6a088c8d4 ] In mlx5_ifc, struct size was not complete, and thus driver was sending garbage after the last defined field. Fixed it by adding reserved field to complete the struct size. In addition, rename all set_rate_limit to set_pp_rate_limit to be compliant with the Firmware <-> Driver definition. Fixes: 7486216b3a0b ("{net,IB}/mlx5: mlx5_ifc updates") Fixes: 1466cc5b23d1 ("net/mlx5: Rate limit tables support") Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02tcp: invalidate rate samples during SACK renegingYousuk Seung
[ Upstream commit d4761754b4fb2ef8d9a1e9d121c4bec84e1fe292 ] Mark tcp_sock during a SACK reneging event and invalidate rate samples while marked. Such rate samples may overestimate bw by including packets that were SACKed before reneging. < ack 6001 win 10000 sack 7001:38001 < ack 7001 win 0 sack 8001:38001 // Reneg detected > seq 7001:8001 // RTO, SACK cleared. < ack 38001 win 10000 In above example the rate sample taken after the last ack will count 7001-38001 as delivered while the actual delivery rate likely could be much lower i.e. 7001-8001. This patch adds a new field tcp_sock.sack_reneg and marks it when we declare SACK reneging and entering TCP_CA_Loss, and unmarks it after the last rate sample was taken before moving back to TCP_CA_Open. This patch also invalidates rate samples taken while tcp_sock.is_sack_reneg is set. Fixes: b9f64820fb22 ("tcp: track data delivery rate for a TCP connection") Signed-off-by: Yousuk Seung <ysseung@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Soheil Hassas Yeganeh <soheil@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Priyaranjan Jha <priyarjha@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ptr_ring: add barriersMichael S. Tsirkin
[ Upstream commit a8ceb5dbfde1092b466936bca0ff3be127ecf38e ] Users of ptr_ring expect that it's safe to give the data structure a pointer and have it be available to consumers, but that actually requires an smb_wmb or a stronger barrier. In absence of such barriers and on architectures that reorder writes, consumer might read an un=initialized value from an skb pointer stored in the skb array. This was observed causing crashes. To fix, add memory barriers. The barrier we use is a wmb, the assumption being that producers do not need to read the value so we do not need to order these reads. Reported-by: George Cherian <george.cherian@cavium.com> Suggested-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02net: reevalulate autoflowlabel setting after sysctl settingShaohua Li
[ Upstream commit 513674b5a2c9c7a67501506419da5c3c77ac6f08 ] sysctl.ip6.auto_flowlabels is default 1. In our hosts, we set it to 2. If sockopt doesn't set autoflowlabel, outcome packets from the hosts are supposed to not include flowlabel. This is true for normal packet, but not for reset packet. The reason is ipv6_pinfo.autoflowlabel is set in sock creation. Later if we change sysctl.ip6.auto_flowlabels, the ipv6_pinfo.autoflowlabel isn't changed, so the sock will keep the old behavior in terms of auto flowlabel. Reset packet is suffering from this problem, because reset packet is sent from a special control socket, which is created at boot time. Since sysctl.ipv6.auto_flowlabels is 1 by default, the control socket will always have its ipv6_pinfo.autoflowlabel set, even after user set sysctl.ipv6.auto_flowlabels to 1, so reset packset will always have flowlabel. Normal sock created before sysctl setting suffers from the same issue. We can't even turn off autoflowlabel unless we kill all socks in the hosts. To fix this, if IPV6_AUTOFLOWLABEL sockopt is used, we use the autoflowlabel setting from user, otherwise we always call ip6_default_np_autolabel() which has the new settings of sysctl. Note, this changes behavior a little bit. Before commit 42240901f7c4 (ipv6: Implement different admin modes for automatic flow labels), the autoflowlabel behavior of a sock isn't sticky, eg, if sysctl changes, existing connection will change autoflowlabel behavior. After that commit, autoflowlabel behavior is sticky in the whole life of the sock. With this patch, the behavior isn't sticky again. Cc: Martin KaFai Lau <kafai@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tom Herbert <tom@quantonium.net> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ipv4: igmp: guard against silly MTU valuesEric Dumazet
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ] IPv4 stack reacts to changes to small MTU, by disabling itself under RTNL. But there is a window where threads not using RTNL can see a wrong device mtu. This can lead to surprises, in igmp code where it is assumed the mtu is suitable. Fix this by reading device mtu once and checking IPv4 minimal MTU. This patch adds missing IPV4_MIN_MTU define, to not abuse ETH_MIN_MTU anymore. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29crypto: mcryptd - protect the per-CPU queue with a lockSebastian Andrzej Siewior
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream. mcryptd_enqueue_request() grabs the per-CPU queue struct and protects access to it with disabled preemption. Then it schedules a worker on the same CPU. The worker in mcryptd_queue_worker() guards access to the same per-CPU variable with disabled preemption. If we take CPU-hotplug into account then it is possible that between queue_work_on() and the actual invocation of the worker the CPU goes down and the worker will be scheduled on _another_ CPU. And here the preempt_disable() protection does not work anymore. The easiest thing is to add a spin_lock() to guard access to the list. Another detail: mcryptd_queue_worker() is not processing more than MCRYPTD_BATCH invocation in a row. If there are still items left, then it will invoke queue_work() to proceed with more later. *I* would suggest to simply drop that check because it does not use a system workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if preemption is required then the scheduler should do it. However if queue_work() is used then the work item is marked as CPU unbound. That means it will try to run on the local CPU but it may run on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y. Again, the preempt_disable() won't work here but lock which was introduced will help. In order to keep work-item on the local CPU (and avoid RR) I changed it to queue_work_on(). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25bpf: fix branch pruning logicDaniel Borkmann
From: Alexei Starovoitov <ast@fb.com> [ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ] when the verifier detects that register contains a runtime constant and it's compared with another constant it will prune exploration of the branch that is guaranteed not to be taken at runtime. This is all correct, but malicious program may be constructed in such a way that it always has a constant comparison and the other branch is never taken under any conditions. In this case such path through the program will not be explored by the verifier. It won't be taken at run-time either, but since all instructions are JITed the malicious program may cause JITs to complain about using reserved fields, etc. To fix the issue we have to track the instructions explored by the verifier and sanitize instructions that are dead at run time with NOPs. We cannot reject such dead code, since llvm generates it for valid C code, since it doesn't do as much data flow analysis as the verifier does. Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)") Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25vhost-vsock: add pkt cancel capabilityPeng Tao
[ Upstream commit 16320f363ae128d9b9c70e60f00f2a572f57c23d ] To allow canceling all packets of a connection. Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com> Reviewed-by: Jorgen Hansen <jhansen@vmware.com> Signed-off-by: Peng Tao <bergwolf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25vsock: track pkt owner vsockPeng Tao
[ Upstream commit 36d277bac8080202684e67162ebb157f16631581 ] So that we can cancel a queued pkt later if necessary. Signed-off-by: Peng Tao <bergwolf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20IB/core: Fix calculation of maximum RoCE MTUParav Pandit
[ Upstream commit 99260132fde7bddc6e0132ce53da94d1c9ccabcb ] The original code only took into consideration the largest header possible after the IB_BTH_BYTES. This was incorrect, as the largest possible header size is the largest possible combination of headers we might run into. The new code accounts for all possible headers in the largest possible combination and subtracts that from the MTU to make sure that all packets will fit on the wire. Link: https://www.spinics.net/lists/linux-rdma/msg54558.html Fixes: 3c86aa70bf67 ("RDMA/cm: Add RDMA CM support for IBoE devices") Signed-off-by: Parav Pandit <parav@mellanox.com> Reviewed-by: Daniel Jurgens <danielj@mellanox.com> Reported-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20mm: Handle 0 flags in _calc_vm_trans() macroJan Kara
[ Upstream commit 592e254502041f953e84d091eae2c68cba04c10b ] _calc_vm_trans() does not handle the situation when some of the passed flags are 0 (which can happen if these VM flags do not make sense for the architecture). Improve the _calc_vm_trans() macro to return 0 in such situation. Since all passed flags are constant, this does not add any runtime overhead. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20Revert "x86/acpi: Set persistent cpuid <-> nodeid mapping when booting"Dou Liyang
[ Upstream commit c962cff17dfa11f4a8227ac16de2b28aea3312e4 ] Revert: dc6db24d2476 ("x86/acpi: Set persistent cpuid <-> nodeid mapping when booting") The mapping of "cpuid <-> nodeid" is established at boot time via ACPI tables to keep associations of workqueues and other node related items consistent across cpu hotplug. But, ACPI tables are unreliable and failures with that boot time mapping have been reported on machines where the ACPI table and the physical information which is retrieved at actual hotplug is inconsistent. Revert the mapping implementation so it can be replaced with a less error prone approach. Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com> Tested-by: Xiaolong Ye <xiaolong.ye@intel.com> Cc: rjw@rjwysocki.net Cc: linux-acpi@vger.kernel.org Cc: guzheng1@huawei.com Cc: izumi.taku@jp.fujitsu.com Cc: lenb@kernel.org Link: http://lkml.kernel.org/r/1488528147-2279-2-git-send-email-douly.fnst@cn.fujitsu.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20target: fix ALUA transition timeout handlingMike Christie
[ Upstream commit d7175373f2745ed4abe5b388d5aabd06304f801e ] The implicit transition time tells initiators the min time to wait before timing out a transition. We currently schedule the transition to occur in tg_pt_gp_implicit_trans_secs seconds so there is no room for delays. If core_alua_do_transition_tg_pt_work->core_alua_update_tpg_primary_metadata needs to write out info to a remote file, then the initiator can easily time out the operation. Signed-off-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20net/mlx4_core: Avoid delays during VF driver device shutdownJack Morgenstein
[ Upstream commit 4cbe4dac82e423ecc9a0ba46af24a860853259f4 ] Some Hypervisors detach VFs from VMs by instantly causing an FLR event to be generated for a VF. In the mlx4 case, this will cause that VF's comm channel to be disabled before the VM has an opportunity to invoke the VF device's "shutdown" method. For such Hypervisors, there is a race condition between the VF's shutdown method and its internal-error detection/reset thread. The internal-error detection/reset thread (which runs every 5 seconds) also detects a disabled comm channel. If the internal-error detection/reset flow wins the race, we still get delays (while that flow tries repeatedly to detect comm-channel recovery). The cited commit fixed the command timeout problem when the internal-error detection/reset flow loses the race. This commit avoids the unneeded delays when the internal-error detection/reset flow wins. Fixes: d585df1c5ccf ("net/mlx4_core: Avoid command timeouts during VF driver device shutdown") Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Reported-by: Simon Xiao <sixiao@microsoft.com> Signed-off-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20usb: add helper to extract bits 12:11 of wMaxPacketSizeFelipe Balbi
commit 541b6fe63023f3059cf85d47ff2767a3e42a8e44 upstream. According to USB Specification 2.0 table 9-4, wMaxPacketSize is a bitfield. Endpoint's maxpacket is laid out in bits 10:0. For high-speed, high-bandwidth isochronous endpoints, bits 12:11 contain a multiplier to tell us how many transactions we want to try per uframe. This means that if we want an isochronous endpoint to issue 3 transfers of 1024 bytes per uframe, wMaxPacketSize should contain the value: 1024 | (2 << 11) or 5120 (0x1400). In order to make Host and Peripheral controller drivers' life easier, we're adding a helper which returns bits 12:11. Note that no care is made WRT to checking endpoint type and gadget's speed. That's left for drivers to handle. Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20crypto: hmac - require that the underlying hash algorithm is unkeyedEric Biggers
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream. Because the HMAC template didn't check that its underlying hash algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))" through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC being used without having been keyed, resulting in sha3_update() being called without sha3_init(), causing a stack buffer overflow. This is a very old bug, but it seems to have only started causing real problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3) because the innermost hash's state is ->import()ed from a zeroed buffer, and it just so happens that other hash algorithms are fine with that, but SHA-3 is not. However, there could be arch or hardware-dependent hash algorithms also affected; I couldn't test everything. Fix the bug by introducing a function crypto_shash_alg_has_setkey() which tests whether a shash algorithm is keyed. Then update the HMAC template to require that its underlying hash algorithm is unkeyed. Here is a reproducer: #include <linux/if_alg.h> #include <sys/socket.h> int main() { int algfd; struct sockaddr_alg addr = { .salg_type = "hash", .salg_name = "hmac(hmac(sha3-512-generic))", }; char key[4096] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (const struct sockaddr *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key)); } Here was the KASAN report from syzbot: BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline] BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044 CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 print_address_description+0x73/0x250 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x25b/0x340 mm/kasan/report.c:409 check_memory_region_inline mm/kasan/kasan.c:260 [inline] check_memory_region+0x137/0x190 mm/kasan/kasan.c:267 memcpy+0x37/0x50 mm/kasan/kasan.c:303 memcpy include/linux/string.h:341 [inline] sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161 crypto_shash_update+0xcb/0x220 crypto/shash.c:109 shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 hmac_finup+0x182/0x330 crypto/hmac.c:152 crypto_shash_finup+0xc4/0x120 crypto/shash.c:165 shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172 crypto_shash_digest+0xc4/0x120 crypto/shash.c:186 hmac_setkey+0x36a/0x690 crypto/hmac.c:66 crypto_shash_setkey+0xad/0x190 crypto/shash.c:64 shash_async_setkey+0x47/0x60 crypto/shash.c:207 crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200 hash_setkey+0x40/0x90 crypto/algif_hash.c:446 alg_setkey crypto/af_alg.c:221 [inline] alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254 SYSC_setsockopt net/socket.c:1851 [inline] SyS_setsockopt+0x189/0x360 net/socket.c:1830 entry_SYSCALL_64_fastpath+0x1f/0x96 Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16net: remove hlist_nulls_add_tail_rcu()Eric Dumazet
[ Upstream commit d7efc6c11b277d9d80b99b1334a78bfe7d7edf10 ] Alexander Potapenko reported use of uninitialized memory [1] This happens when inserting a request socket into TCP ehash, in __sk_nulls_add_node_rcu(), since sk_reuseport is not initialized. Bug was added by commit d894ba18d4e4 ("soreuseport: fix ordering for mixed v4/v6 sockets") Note that d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6 ordering fix") missed the opportunity to get rid of hlist_nulls_add_tail_rcu() : Both UDP sockets and TCP/DCCP listeners no longer use __sk_nulls_add_node_rcu() for their hash insertion. Since all other sockets have unique 4-tuple, the reuseport status has no special meaning, so we can always use hlist_nulls_add_head_rcu() for them and save few cycles/instructions. [1] ================================================================== BUG: KMSAN: use of uninitialized memory in inet_ehash_insert+0xd40/0x1050 CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.13.0+ #3288 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace:  <IRQ>  __dump_stack lib/dump_stack.c:16  dump_stack+0x185/0x1d0 lib/dump_stack.c:52  kmsan_report+0x13f/0x1c0 mm/kmsan/kmsan.c:1016  __msan_warning_32+0x69/0xb0 mm/kmsan/kmsan_instr.c:766  __sk_nulls_add_node_rcu ./include/net/sock.h:684  inet_ehash_insert+0xd40/0x1050 net/ipv4/inet_hashtables.c:413  reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:754  inet_csk_reqsk_queue_hash_add+0x1cc/0x300 net/ipv4/inet_connection_sock.c:765  tcp_conn_request+0x31e7/0x36f0 net/ipv4/tcp_input.c:6414  tcp_v4_conn_request+0x16d/0x220 net/ipv4/tcp_ipv4.c:1314  tcp_rcv_state_process+0x42a/0x7210 net/ipv4/tcp_input.c:5917  tcp_v4_do_rcv+0xa6a/0xcd0 net/ipv4/tcp_ipv4.c:1483  tcp_v4_rcv+0x3de0/0x4ab0 net/ipv4/tcp_ipv4.c:1763  ip_local_deliver_finish+0x6bb/0xcb0 net/ipv4/ip_input.c:216  NF_HOOK ./include/linux/netfilter.h:248  ip_local_deliver+0x3fa/0x480 net/ipv4/ip_input.c:257  dst_input ./include/net/dst.h:477  ip_rcv_finish+0x6fb/0x1540 net/ipv4/ip_input.c:397  NF_HOOK ./include/linux/netfilter.h:248  ip_rcv+0x10f6/0x15c0 net/ipv4/ip_input.c:488  __netif_receive_skb_core+0x36f6/0x3f60 net/core/dev.c:4298  __netif_receive_skb net/core/dev.c:4336  netif_receive_skb_internal+0x63c/0x19c0 net/core/dev.c:4497  napi_skb_finish net/core/dev.c:4858  napi_gro_receive+0x629/0xa50 net/core/dev.c:4889  e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4018  e1000_clean_rx_irq+0x1492/0x1d30 drivers/net/ethernet/intel/e1000/e1000_main.c:4474  e1000_clean+0x43aa/0x5970 drivers/net/ethernet/intel/e1000/e1000_main.c:3819  napi_poll net/core/dev.c:5500  net_rx_action+0x73c/0x1820 net/core/dev.c:5566  __do_softirq+0x4b4/0x8dd kernel/softirq.c:284  invoke_softirq kernel/softirq.c:364  irq_exit+0x203/0x240 kernel/softirq.c:405  exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:638  do_IRQ+0x15e/0x1a0 arch/x86/kernel/irq.c:263  common_interrupt+0x86/0x86 Fixes: d894ba18d4e4 ("soreuseport: fix ordering for mixed v4/v6 sockets") Fixes: d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6 ordering fix") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Alexander Potapenko <glider@google.com> Acked-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16usbnet: fix alignment for frames with no ethernet headerBjørn Mork
[ Upstream commit a4abd7a80addb4a9547f7dfc7812566b60ec505c ] The qmi_wwan minidriver support a 'raw-ip' mode where frames are received without any ethernet header. This causes alignment issues because the skbs allocated by usbnet are "IP aligned". Fix by allowing minidrivers to disable the additional alignment offset. This is implemented using a per-device flag, since the same minidriver also supports 'ethernet' mode. Fixes: 32f7adf633b9 ("net: qmi_wwan: support "raw IP" mode") Reported-and-tested-by: Jay Foster <jay@systech.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14lib/genalloc.c: make the avail variable an atomic_long_tStephen Bates
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ] If the amount of resources allocated to a gen_pool exceeds 2^32 then the avail atomic overflows and this causes problems when clients try and borrow resources from the pool. This is only expected to be an issue on 64 bit systems. Add the <linux/atomic.h> header to pull in atomic_long* operations. So that 32 bit systems continue to use atomic32_t but 64 bit systems can use atomic64_t. Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com Signed-off-by: Stephen Bates <sbates@raithlin.com> Reviewed-by: Logan Gunthorpe <logang@deltatee.com> Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reviewed-by: Daniel Mentz <danielmentz@google.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14ARM: OMAP2+: gpmc-onenand: propagate error on initialization failureLadislav Michl
[ Upstream commit 7807e086a2d1f69cc1a57958cac04fea79fc2112 ] gpmc_probe_onenand_child returns success even on gpmc_onenand_init failure. Fix that. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14mm: drop unused pmdp_huge_get_and_clear_notify()Kirill A. Shutemov
commit c0c379e2931b05facef538e53bf3b21f283d9a0b upstream. Dave noticed that after fixing MADV_DONTNEED vs numa balancing race the last pmdp_huge_get_and_clear_notify() user is gone. Let's drop the helper. Link: http://lkml.kernel.org/r/20170306112047.24809-1-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [jwang: adjust context for 4.9] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14efi: Move some sysfs files to be read-only by rootGreg Kroah-Hartman
commit af97a77bc01ce49a466f9d4c0125479e2e2230b6 upstream. Thanks to the scripts/leaking_addresses.pl script, it was found that some EFI values should not be readable by non-root users. So make them root-only, and to do that, add a __ATTR_RO_MODE() macro to make this easier, and use it in other places at the same time. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Dave Young <dyoung@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/20171206095010.24170-2-ard.biesheuvel@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14scsi: libsas: align sata_device's rps_resp on a cachelineHuacai Chen
commit c2e8fbf908afd81ad502b567a6639598f92c9b9d upstream. The rps_resp buffer in ata_device is a DMA target, but it isn't explicitly cacheline aligned. Due to this, adjacent fields can be overwritten with stale data from memory on non-coherent architectures. As a result, the kernel is sometimes unable to communicate with an SATA device behind a SAS expander. Fix this by ensuring that the rps_resp buffer is cacheline aligned. This issue is similar to that fixed by Commit 84bda12af31f93 ("libata: align ap->sector_buf") and Commit 4ee34ea3a12396f35b26 ("libata: Align ata_device's id on a cacheline"). Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14scsi: dma-mapping: always provide dma_get_cache_alignmentChristoph Hellwig
commit 860dd4424f344400b491b212ee4acb3a358ba9d9 upstream. Provide the dummy version of dma_get_cache_alignment that always returns 1 even if CONFIG_HAS_DMA is not set, so that drivers and subsystems can use it without ifdefs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09USB: core: Add type-specific length check of BOS descriptorsMasakazu Mokuno
commit 81cf4a45360f70528f1f64ba018d61cb5767249a upstream. As most of BOS descriptors are longer in length than their header 'struct usb_dev_cap_header', comparing solely with it is not sufficient to avoid out-of-bounds access to BOS descriptors. This patch adds descriptor type specific length check in usb_get_bos_descriptor() to fix the issue. Signed-off-by: Masakazu Mokuno <masakazu.mokuno@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09dma-fence: Introduce drm_fence_set_error() helperChris Wilson
commit a009e975da5c7d42a7f5eaadc54946eb5f76c9af upstream. The dma_fence.error field (formerly known as dma_fence.status) is an optional field that may be set by drivers before calling dma_fence_signal(). The field can be used to indicate that the fence was completed in err rather than with success, and is visible to other consumers of the fence and to userspace via sync_file. This patch renames the field from status to error so that its meaning is hopefully more clear (and distinct from dma_fence_get_status() which is a composite between the error state and signal state) and adds a helper that validates the preconditions of when it is suitable to adjust the error field. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org> Link: http://patchwork.freedesktop.org/patch/msgid/20170104141222.6992-3-chris@chris-wilson.co.uk [s/dma_fence/fence/g - gregkh] Cc: Jisheng Zhang <Jisheng.Zhang@synaptics.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09dma-fence: Wrap querying the fence->statusChris Wilson
commit d6c99f4bf093a58d3ab47caaec74b81f18bc4e3f upstream. The fence->status is an optional field that is only valid once the fence has been signaled. (Driver may fill the fence->status with an error code prior to calling dma_fence_signal().) Given the restriction upon its validity, wrap querying of the fence->status into a helper dma_fence_get_status(). Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org> Link: http://patchwork.freedesktop.org/patch/msgid/20170104141222.6992-2-chris@chris-wilson.co.uk [s/dma_fence/fence/g - gregkh] Cc: Jisheng Zhang <Jisheng.Zhang@synaptics.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09dma-buf/dma-fence: Extract __dma_fence_is_later()Chris Wilson
commit 8111477663813caa1a4469cfe6afaae36cd04513 upstream. Often we have the task of comparing two seqno known to be on the same context, so provide a common __dma_fence_is_later(). Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Sumit Semwal <sumit.semwal@linaro.org> Cc: Sean Paul <seanpaul@chromium.org> Cc: Gustavo Padovan <gustavo@padovan.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.com> Link: http://patchwork.freedesktop.org/patch/msgid/20170629125930.821-1-chris@chris-wilson.co.uk [renamed to __fence_is_later() - gregkh] Cc: Jisheng Zhang <Jisheng.Zhang@synaptics.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09mm: avoid returning VM_FAULT_RETRY from ->page_mkwrite handlersJan Kara
[ Upstream commit 0911d0041c22922228ca52a977d7b0b0159fee4b ] Some ->page_mkwrite handlers may return VM_FAULT_RETRY as its return code (GFS2 or Lustre can definitely do this). However VM_FAULT_RETRY from ->page_mkwrite is completely unhandled by the mm code and results in locking and writeably mapping the page which definitely is not what the caller wanted. Fix Lustre and block_page_mkwrite_ret() used by other filesystems (notably GFS2) to return VM_FAULT_NOPAGE instead which results in bailing out from the fault code, the CPU then retries the access, and we fault again effectively doing what the handler wanted. Link: http://lkml.kernel.org/r/20170203150729.15863-1-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Reviewed-by: Jinshan Xiong <jinshan.xiong@intel.com> Cc: Matthew Wilcox <willy@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09perf/x86/intel: Account interrupts for PEBS errorsJiri Olsa
[ Upstream commit 475113d937adfd150eb82b5e2c5507125a68e7af ] It's possible to set up PEBS events to get only errors and not any data, like on SNB-X (model 45) and IVB-EP (model 62) via 2 perf commands running simultaneously: taskset -c 1 ./perf record -c 4 -e branches:pp -j any -C 10 This leads to a soft lock up, because the error path of the intel_pmu_drain_pebs_nhm() does not account event->hw.interrupt for error PEBS interrupts, so in case you're getting ONLY errors you don't have a way to stop the event when it's over the max_samples_per_tick limit: NMI watchdog: BUG: soft lockup - CPU#22 stuck for 22s! [perf_fuzzer:5816] ... RIP: 0010:[<ffffffff81159232>] [<ffffffff81159232>] smp_call_function_single+0xe2/0x140 ... Call Trace: ? trace_hardirqs_on_caller+0xf5/0x1b0 ? perf_cgroup_attach+0x70/0x70 perf_install_in_context+0x199/0x1b0 ? ctx_resched+0x90/0x90 SYSC_perf_event_open+0x641/0xf90 SyS_perf_event_open+0x9/0x10 do_syscall_64+0x6c/0x1f0 entry_SYSCALL64_slow_path+0x25/0x25 Add perf_event_account_interrupt() which does the interrupt and frequency checks and call it from intel_pmu_drain_pebs_nhm()'s error path. We keep the pending_kill and pending_wakeup logic only in the __perf_event_overflow() path, because they make sense only if there's any data to deliver. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vince@deater.net> Cc: Vince Weaver <vincent.weaver@maine.edu> Link: http://lkml.kernel.org/r/1482931866-6018-2-git-send-email-jolsa@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-05bcache: Fix building error on MIPSHuacai Chen
commit cf33c1ee5254c6a430bc1538232b49c3ea13e613 upstream. This patch try to fix the building error on MIPS. The reason is MIPS has already defined the PTR macro, which conflicts with the PTR macro in include/uapi/linux/bcache.h. [fixed by mlyle: corrected a line-length issue] Signed-off-by: Huacai Chen <chenhc@lemote.com> Reviewed-by: Michael Lyle <mlyle@lyle.org> Signed-off-by: Michael Lyle <mlyle@lyle.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-05mm, hugetlbfs: introduce ->split() to vm_operations_structDan Williams
commit 31383c6865a578834dd953d9dbc88e6b19fe3997 upstream. Patch series "device-dax: fix unaligned munmap handling" When device-dax is operating in huge-page mode we want it to behave like hugetlbfs and fail attempts to split vmas into unaligned ranges. It would be messy to teach the munmap path about device-dax alignment constraints in the same (hstate) way that hugetlbfs communicates this constraint. Instead, these patches introduce a new ->split() vm operation. This patch (of 2): The device-dax interface has similar constraints as hugetlbfs in that it requires the munmap path to unmap in huge page aligned units. Rather than add more custom vma handling code in __split_vma() introduce a new vm operation to perform this vma specific check. Link: http://lkml.kernel.org/r/151130418135.4029.6783191281930729710.stgit@dwillia2-desk3.amr.corp.intel.com Fixes: dee410792419 ("/dev/dax, core: file operations and dax-mmap") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-30SUNRPC: Fix tracepoint storage issues with svc_recv and svc_rqst_statusTrond Myklebust
commit e9d4bf219c83d09579bc62512fea2ca10f025d93 upstream. There is no guarantee that either the request or the svc_xprt exist by the time we get round to printing the trace message. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24mm/page_alloc.c: broken deferred calculationPavel Tatashin
commit d135e5750205a21a212a19dbb05aeb339e2cbea7 upstream. In reset_deferred_meminit() we determine number of pages that must not be deferred. We initialize pages for at least 2G of memory, but also pages for reserved memory in this node. The reserved memory is determined in this function: memblock_reserved_memory_within(), which operates over physical addresses, and returns size in bytes. However, reset_deferred_meminit() assumes that that this function operates with pfns, and returns page count. The result is that in the best case machine boots slower than expected due to initializing more pages than needed in single thread, and in the worst case panics because fewer than needed pages are initialized early. Link: http://lkml.kernel.org/r/20171021011707.15191-1-pasha.tatashin@oracle.com Fixes: 864b9a393dcb ("mm: consider memblock reservations for deferred memory initialization sizing") Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24netfilter/ipvs: clear ipvs_property flag when SKB net namespace changedYe Yin
[ Upstream commit 2b5ec1a5f9738ee7bf8f5ec0526e75e00362c48f ] When run ipvs in two different network namespace at the same host, and one ipvs transport network traffic to the other network namespace ipvs. 'ipvs_property' flag will make the second ipvs take no effect. So we should clear 'ipvs_property' when SKB network namespace changed. Fixes: 621e84d6f373 ("dev: introduce skb_scrub_packet()") Signed-off-by: Ye Yin <hustcat@gmail.com> Signed-off-by: Wei Zhou <chouryzhou@gmail.com> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21uapi: fix linux/rds.h userspace compilation errorsDmitry V. Levin
[ Upstream commit feb0869d90e51ce8b6fd8a46588465b1b5a26d09 ] Consistently use types from linux/types.h to fix the following linux/rds.h userspace compilation errors: /usr/include/linux/rds.h:106:2: error: unknown type name 'uint8_t' uint8_t name[32]; /usr/include/linux/rds.h:107:2: error: unknown type name 'uint64_t' uint64_t value; /usr/include/linux/rds.h:117:2: error: unknown type name 'uint64_t' uint64_t next_tx_seq; /usr/include/linux/rds.h:118:2: error: unknown type name 'uint64_t' uint64_t next_rx_seq; /usr/include/linux/rds.h:121:2: error: unknown type name 'uint8_t' uint8_t transport[TRANSNAMSIZ]; /* null term ascii */ /usr/include/linux/rds.h:122:2: error: unknown type name 'uint8_t' uint8_t flags; /usr/include/linux/rds.h:129:2: error: unknown type name 'uint64_t' uint64_t seq; /usr/include/linux/rds.h:130:2: error: unknown type name 'uint32_t' uint32_t len; /usr/include/linux/rds.h:135:2: error: unknown type name 'uint8_t' uint8_t flags; /usr/include/linux/rds.h:139:2: error: unknown type name 'uint32_t' uint32_t sndbuf; /usr/include/linux/rds.h:144:2: error: unknown type name 'uint32_t' uint32_t rcvbuf; /usr/include/linux/rds.h:145:2: error: unknown type name 'uint64_t' uint64_t inum; /usr/include/linux/rds.h:153:2: error: unknown type name 'uint64_t' uint64_t hdr_rem; /usr/include/linux/rds.h:154:2: error: unknown type name 'uint64_t' uint64_t data_rem; /usr/include/linux/rds.h:155:2: error: unknown type name 'uint32_t' uint32_t last_sent_nxt; /usr/include/linux/rds.h:156:2: error: unknown type name 'uint32_t' uint32_t last_expected_una; /usr/include/linux/rds.h:157:2: error: unknown type name 'uint32_t' uint32_t last_seen_una; /usr/include/linux/rds.h:164:2: error: unknown type name 'uint8_t' uint8_t src_gid[RDS_IB_GID_LEN]; /usr/include/linux/rds.h:165:2: error: unknown type name 'uint8_t' uint8_t dst_gid[RDS_IB_GID_LEN]; /usr/include/linux/rds.h:167:2: error: unknown type name 'uint32_t' uint32_t max_send_wr; /usr/include/linux/rds.h:168:2: error: unknown type name 'uint32_t' uint32_t max_recv_wr; /usr/include/linux/rds.h:169:2: error: unknown type name 'uint32_t' uint32_t max_send_sge; /usr/include/linux/rds.h:170:2: error: unknown type name 'uint32_t' uint32_t rdma_mr_max; /usr/include/linux/rds.h:171:2: error: unknown type name 'uint32_t' uint32_t rdma_mr_size; /usr/include/linux/rds.h:212:9: error: unknown type name 'uint64_t' typedef uint64_t rds_rdma_cookie_t; /usr/include/linux/rds.h:215:2: error: unknown type name 'uint64_t' uint64_t addr; /usr/include/linux/rds.h:216:2: error: unknown type name 'uint64_t' uint64_t bytes; /usr/include/linux/rds.h:221:2: error: unknown type name 'uint64_t' uint64_t cookie_addr; /usr/include/linux/rds.h:222:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:228:2: error: unknown type name 'uint64_t' uint64_t cookie_addr; /usr/include/linux/rds.h:229:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:234:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:240:2: error: unknown type name 'uint64_t' uint64_t local_vec_addr; /usr/include/linux/rds.h:241:2: error: unknown type name 'uint64_t' uint64_t nr_local; /usr/include/linux/rds.h:242:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:243:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:248:2: error: unknown type name 'uint64_t' uint64_t local_addr; /usr/include/linux/rds.h:249:2: error: unknown type name 'uint64_t' uint64_t remote_addr; /usr/include/linux/rds.h:252:4: error: unknown type name 'uint64_t' uint64_t compare; /usr/include/linux/rds.h:253:4: error: unknown type name 'uint64_t' uint64_t swap; /usr/include/linux/rds.h:256:4: error: unknown type name 'uint64_t' uint64_t add; /usr/include/linux/rds.h:259:4: error: unknown type name 'uint64_t' uint64_t compare; /usr/include/linux/rds.h:260:4: error: unknown type name 'uint64_t' uint64_t swap; /usr/include/linux/rds.h:261:4: error: unknown type name 'uint64_t' uint64_t compare_mask; /usr/include/linux/rds.h:262:4: error: unknown type name 'uint64_t' uint64_t swap_mask; /usr/include/linux/rds.h:265:4: error: unknown type name 'uint64_t' uint64_t add; /usr/include/linux/rds.h:266:4: error: unknown type name 'uint64_t' uint64_t nocarry_mask; /usr/include/linux/rds.h:269:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:270:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:274:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:275:2: error: unknown type name 'int32_t' int32_t status; Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21uapi: fix linux/rds.h userspace compilation errorDmitry V. Levin
[ Upstream commit 1786dbf3702e33ce3afd2d3dbe630bd04b1d2e58 ] On the kernel side, sockaddr_storage is #define'd to __kernel_sockaddr_storage. Replacing struct sockaddr_storage with struct __kernel_sockaddr_storage defined by <linux/socket.h> fixes the following linux/rds.h userspace compilation error: /usr/include/linux/rds.h:226:26: error: field 'dest_addr' has incomplete type struct sockaddr_storage dest_addr; Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21Revert "uapi: fix linux/rds.h userspace compilation errors"Sasha Levin
This reverts commit ad50561ba7a664bc581826c9d57d137fcf17bfa5. There was a mixup with the commit message for two upstream commit that have the same subject line. This revert will be followed by the two commits with proper commit messages. Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-21ARM: dts: Fix omap3 off mode pull definesTony Lindgren
[ Upstream commit d97556c8012015901a3ce77f46960078139cd79d ] We need to also have OFFPULLUDENABLE bit set to use the off mode pull values. Otherwise the line is pulled down internally if no external pull exists. This is has some documentation at: http://processors.wiki.ti.com/index.php/Optimizing_OMAP35x_and_AM/DM37x_OFF_mode_PAD_configuration Note that the value is still glitchy during off mode transitions as documented in spz319f.pdf "Advisory 1.45". It's best to use external pulls instead of relying on the internal ones for off mode and even then anything pulled up will get driven down momentarily on off mode restore for GPIO banks other than bank1. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18target/iscsi: Fix iSCSI task reassignment handlingBart Van Assche
commit 59b6986dbfcdab96a971f9663221849de79a7556 upstream. Allocate a task management request structure for all task management requests, including task reassignment. This change avoids that the se_tmr->response assignment dereferences an uninitialized se_tmr pointer. Reported-by: Moshe David <mdavid@infinidat.com> Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Moshe David <mdavid@infinidat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18netfilter: nat: Revert "netfilter: nat: convert nat bysrc hash to rhashtable"Florian Westphal
commit e1bf1687740ce1a3598a1c5e452b852ff2190682 upstream. This reverts commit 870190a9ec9075205c0fa795a09fa931694a3ff1. It was not a good idea. The custom hash table was a much better fit for this purpose. A fast lookup is not essential, in fact for most cases there is no lookup at all because original tuple is not taken and can be used as-is. What needs to be fast is insertion and deletion. rhlist removal however requires a rhlist walk. We can have thousands of entries in such a list if source port/addresses are reused for multiple flows, if this happens removal requests are so expensive that deletions of a few thousand flows can take several seconds(!). The advantages that we got from rhashtable are: 1) table auto-sizing 2) multiple locks 1) would be nice to have, but it is not essential as we have at most one lookup per new flow, so even a million flows in the bysource table are not a problem compared to current deletion cost. 2) is easy to add to custom hash table. I tried to add hlist_node to rhlist to speed up rhltable_remove but this isn't doable without changing semantics. rhltable_remove_fast will check that the to-be-deleted object is part of the table and that requires a list walk that we want to avoid. Furthermore, using hlist_node increases size of struct rhlist_head, which in turn increases nf_conn size. Link: https://bugzilla.kernel.org/show_bug.cgi?id=196821 Reported-by: Ivan Babrou <ibobrik@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18tcp/dccp: fix other lockdep splats accessing ireq_optEric Dumazet
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ] In my first attempt to fix the lockdep splat, I forgot we could enter inet_csk_route_req() with a freshly allocated request socket, for which refcount has not yet been elevated, due to complex SLAB_TYPESAFE_BY_RCU rules. We either are in rcu_read_lock() section _or_ we own a refcount on the request. Correct RCU verb to use here is rcu_dereference_check(), although it is not possible to prove we actually own a reference on a shared refcount :/ In v2, I added ireq_opt_deref() helper and use in three places, to fix other possible splats. [ 49.844590] lockdep_rcu_suspicious+0xea/0xf3 [ 49.846487] inet_csk_route_req+0x53/0x14d [ 49.848334] tcp_v4_route_req+0xe/0x10 [ 49.850174] tcp_conn_request+0x31c/0x6a0 [ 49.851992] ? __lock_acquire+0x614/0x822 [ 49.854015] tcp_v4_conn_request+0x5a/0x79 [ 49.855957] ? tcp_v4_conn_request+0x5a/0x79 [ 49.858052] tcp_rcv_state_process+0x98/0xdcc [ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307 [ 49.862085] tcp_v4_do_rcv+0xfc/0x145 [ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145 [ 49.866173] tcp_v4_rcv+0x5ab/0xaf9 [ 49.868029] ip_local_deliver_finish+0x1af/0x2e7 [ 49.870064] ip_local_deliver+0x1b2/0x1c5 [ 49.871775] ? inet_del_offload+0x45/0x45 [ 49.873916] ip_rcv_finish+0x3f7/0x471 [ 49.875476] ip_rcv+0x3f1/0x42f [ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7 [ 49.878791] __netif_receive_skb_core+0x6d3/0x950 [ 49.880701] ? process_backlog+0x7e/0x216 [ 49.882589] __netif_receive_skb+0x1d/0x5e [ 49.884122] process_backlog+0x10c/0x216 [ 49.885812] net_rx_action+0x147/0x3df Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()") Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: kernel test robot <fengguang.wu@intel.com> Reported-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
