commit c1f43dd9c20d85e66c4d77e284f64ac114abe3f8 upstream.
The count which is used to get_unmap_data maybe not the same as the
count computed in dmaengine_unmap which causes to free data in a
wrong pool.
This patch fixes this issue by keeping the map count with unmap_data
structure and use this count to get the pool.
Signed-off-by: Xuelin Shi <xuelin.shi@freescale.com>
commit 4c88d7f9b0d5fb0588c3386be62115cc2eaa8f9f upstream.
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added
an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct:
Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the
driver can be used with CONFIG_SMP disabled, but the function declaration
is only available for CONFIG_SMP, leading to this build error:
drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration]
irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu));
This patch introduces a dummy helper function for the non-SMP case
that always returns success, to get rid of the build error.
Since the patches causing the problem are marked for stable backports,
this one should be as well.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel
commit 098507ae3ec2331476fb52e85d4040c1cc6d0ef4 upstream.
The replacement of the 'count' variable by two variables 'incs' and
'decs' to resolve some race conditions during module unloading was done
in parallel with some cleanup in the trace subsystem, and was integrated
as a merge.
Unfortunately, the formula for this replacement was wrong in the tracing
code, and the refcount in the traces was not usable as a result.
Use 'count = incs - decs' to compute the user count.
Link: http://lkml.kernel.org/p/1393924179-9147-1-git-send-email-romain.izard.pro@gmail.com
Acked-by: Ingo Molnar <mingo@kernel.org>
Fixes: c1ab9cab7509 "merge conflict resolution"
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
commit f37c013409bb78ebb958821aa10d069e707cabac upstream.
On some newer laptops with a trackpoint the physical buttons for the
trackpoint have been removed to allow for a larger touchpad. On these
laptops the buttonpad has clearly marked areas on the top which are to be
used as trackpad buttons.
Users of the event device-node need to know about this, so that they can
properly interpret BTN_LEFT events as being a left / right / middle click
depending on where on the button pad the clicking finger is.
This commits adds a INPUT_PROP_TOPBUTTONPAD device property which drivers
for such buttonpads will use to signal to the user that this buttonpad not
only has the normal bottom button area, but also a top button area.
commit 0456c66f4e905e1ca839318219c770988b47975c upstream.
serio devices exposed via platform firmware interfaces such as ACPI may
provide additional identifying information of use to userspace.
We don't associate the serio devices with the firmware device (we don't
set it as parent), so there's no way for userspace to make use of this
information.
We cannot change the parent for serio devices instantiated though a
firmware interface as that would break suspend / resume ordering.
Therefore this patch adds a new firmware_id sysfs attribute so that
userspace can get a string from there with any additional identifying
information the firmware interface may provide.
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
commit cbfbbabb89b37f6bad05f478d906a385149f288d upstream.
The version of the drm_tegra_submit structure that was merged all the
way back in 3.10 contains a pad field that was originally intended to
properly pad the following __u64 field. Unfortunately it seems like a
different field was dropped during review that caused this padding to
become unnecessary, but the pad field wasn't removed at that time.
One possible side-effect of this is that since the __u64 following the
pad is now no longer properly aligned, the compiler may (or may not)
introduce padding itself, which results in no predictable ABI.
Rectify this by removing the pad field so that all fields are again
naturally aligned. Technically this is breaking existing userspace ABI,
but given that there aren't any (released) userspace drivers that make
use of this yet, the fallout should be minimal.
Fixes: d43f81cbaf43 ("drm/tegra: Add gr2d device")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 792e6aa7a15ea0fb16f8687e93caede1ea9118c7 upstream.
Add locked-version for cfg80211_sched_scan_stopped.
This is used for some users that might want to
call it when rtnl is already locked.
Fixes: d43c6b6 ("mac80211: reschedule sched scan after HW restart")
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream.
The current implementation of irq_set_affinity() refuses rightfully to
route an interrupt to an offline cpu.
But there is a special case, where this is actually desired. Some of
the ARM SoCs have per cpu timers which require setting the affinity
during cpu startup where the cpu is not yet in the online mask.
If we can't do that, then the local timer interrupt for the about to
become online cpu is routed to some random online cpu.
The developers of the affected machines tried to work around that
issue, but that results in a massive mess in that timer code.
We have a yet unused argument in the set_affinity callbacks of the irq
chips, which I added back then for a similar reason. It was never
required so it got not used. But I'm happy that I never removed it.
That allows us to implement a sane handling of the above scenario. So
the affected SoC drivers can add the required force handling to their
interrupt chip, switch the timer code to irq_force_affinity() and
things just work.
This does not affect any existing user of irq_set_affinity().
Tagged for stable to allow a simple fix of the affected SoC clock
event drivers.
Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>,
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>,
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-arm-kernel@lists.infradead.org,
Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de
commit 9ec36cafe43bf835f8f29273597a5b0cbc8267ef upstream.
Currently we get the following kind of errors if we try to use interrupt
phandles to irqchips that have not yet initialized:
irq: no irq domain found for /ocp/pinmux@48002030 !
WARNING: CPU: 0 PID: 1 at drivers/of/platform.c:171 of_device_alloc+0x144/0x184()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.12.0-00038-g42a9708 #1012
(show_stack+0x14/0x1c)
(dump_stack+0x6c/0xa0)
(warn_slowpath_common+0x64/0x84)
(warn_slowpath_null+0x1c/0x24)
(of_device_alloc+0x144/0x184)
(of_platform_device_create_pdata+0x44/0x9c)
(of_platform_bus_create+0xd0/0x170)
(of_platform_bus_create+0x12c/0x170)
(of_platform_populate+0x60/0x98)
This is because we're wrongly trying to populate resources that are not
yet available. It's perfectly valid to create irqchips dynamically, so
let's fix up the issue by resolving the interrupt resources when
platform_get_irq is called.
And then we also need to accept the fact that some irqdomains do not
exist that early on, and only get initialized later on. So we can
make the current WARN_ON into just into a pr_debug().
We still attempt to populate irq resources when we create the devices.
This allows current drivers which don't use platform_get_irq to continue
to function. Once all drivers are fixed, this code can be removed.
Suggested-by: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Rob Herring <robh@kernel.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit a949ae560a511fe4e3adf48fa44fefded93e5c2b upstream.
A race exists between module loading and enabling of function tracer.
CPU 1 CPU 2
load_module()
module->state = MODULE_STATE_COMING
register_ftrace_function()
mutex_lock(&ftrace_lock);
ftrace_startup()
update_ftrace_function();
ftrace_arch_code_modify_prepare()
set_all_module_text_rw();
<enables-ftrace>
ftrace_arch_code_modify_post_process()
set_all_module_text_ro();
[ here all module text is set to RO,
including the module that is
loading!! ]
blocking_notifier_call_chain(MODULE_STATE_COMING);
ftrace_init_module()
[ tries to modify code, but it's RO, and fails!
ftrace_bug() is called]
When this race happens, ftrace_bug() will produces a nasty warning and
all of the function tracing features will be disabled until reboot.
The simple solution is to treate module load the same way the core
kernel is treated at boot. To hardcode the ftrace function modification
of converting calls to mcount into nops. This is done in init/main.c
there's no reason it could not be done in load_module(). This gives
a better control of the changes and doesn't tie the state of the
module to its notifiers as much. Ftrace is special, it needs to be
treated as such.
The reason this would work, is that the ftrace_module_init() would be
called while the module is in MODULE_STATE_UNFORMED, which is ignored
by the set_all_module_text_ro() call.
Link: http://lkml.kernel.org/r/1395637826-3312-1-git-send-email-indou.takao@jp.fujitsu.com
Reported-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
[ Upstream commit 200b916f3575bdf11609cb447661b8d5957b0bbf ]
commit 50624c934db18ab90 (net: Delay default_device_exit_batch until no
devices are unregistering) introduced rtnl_lock_unregistering() for
default_device_exit_batch(). Same race could happen we when rmmod a driver
which calls rtnl_link_unregister() as we call dev->destructor without rtnl
lock.
For long term, I think we should clean up the mess of netdev_run_todo()
and net namespce exit code.
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit 3d4405226d27b3a215e4d03cfa51f536244e5de7 ]
net_get_random_once depends on the static keys infrastructure to patch up
the branch to the slow path during boot. This was realized by abusing the
static keys api and defining a new initializer to not enable the call
site while still indicating that the branch point should get patched
up. This was needed to have the fast path considered likely by gcc.
The static key initialization during boot up normally walks through all
the registered keys and either patches in ideal nops or enables the jump
site but omitted that step on x86 if ideal nops where already placed at
static_key branch points. Thus net_get_random_once branches not always
became active.
This patch switches net_get_random_once to the ordinary static_key
api and thus places the kernel fast path in the - by gcc considered -
unlikely path. Microbenchmarks on Intel and AMD x86-64 showed that
the unlikely path actually beats the likely path in terms of cycle cost
and that different nop patterns did not make much difference, thus this
switch should not be noticeable.
Fixes: a48e42920ff38b ("net: introduce new macro net_get_random_once")
Reported-by: Tuomas Räsänen <tuomasjjrasanen@tjjr.fi>
[ Upstream commit 2c4a336e0a3e203fab6aa8d8f7bb70a0ad968a6b ]
Right now the core vsock module is the owner of the proto family. This
means there's nothing preventing the transport module from unloading if
there are open sockets, which results in a panic. Fix that by allowing
the transport to be the owner, which will refcount it properly.
Includes version bump to 1.0.1.0-k
Passes checkpatch this time, I swear...
Acked-by: Dmitry Torokhov <dtor@vmware.com>
Signed-off-by: Andy King <acking@vmware.com>
[ Upstream commit 78541c1dc60b65ecfce5a6a096fc260219d6784e ]
The caller needs capabilities on the namespace being queried, not on
their own namespace. This is a security bug, although it likely has
only a minor impact.
Cc: stable@vger.kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit b14878ccb7fac0242db82720b784ab62c467c0dc ]
Currently, it is possible to create an SCTP socket, then switch
auth_enable via sysctl setting to 1 and crash the system on connect:
Oops[#1]:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.14.1-mipsgit-20140415 #1
task: ffffffff8056ce80 ti: ffffffff8055c000 task.ti: ffffffff8055c000
Call Trace:
[<ffffffff8043c4e8>] sctp_auth_asoc_set_default_hmac+0x68/0x80
[<ffffffff8042b300>] sctp_process_init+0x5e0/0x8a4
[<ffffffff8042188c>] sctp_sf_do_5_1B_init+0x234/0x34c
[<ffffffff804228c8>] sctp_do_sm+0xb4/0x1e8
[<ffffffff80425a08>] sctp_endpoint_bh_rcv+0x1c4/0x214
[<ffffffff8043af68>] sctp_rcv+0x588/0x630
[<ffffffff8043e8e8>] sctp6_rcv+0x10/0x24
[<ffffffff803acb50>] ip6_input+0x2c0/0x440
[<ffffffff8030fc00>] __netif_receive_skb_core+0x4a8/0x564
[<ffffffff80310650>] process_backlog+0xb4/0x18c
[<ffffffff80313cbc>] net_rx_action+0x12c/0x210
[<ffffffff80034254>] __do_softirq+0x17c/0x2ac
[<ffffffff800345e0>] irq_exit+0x54/0xb0
[<ffffffff800075a4>] ret_from_irq+0x0/0x4
[<ffffffff800090ec>] rm7k_wait_irqoff+0x24/0x48
[<ffffffff8005e388>] cpu_startup_entry+0xc0/0x148
[<ffffffff805a88b0>] start_kernel+0x37c/0x398
Code: dd0900b8 000330f8 0126302d <dcc60000> 50c0fff1 0047182a a48306a0
03e00008 00000000
---[ end trace b530b0551467f2fd ]---
Kernel panic - not syncing: Fatal exception in interrupt
What happens while auth_enable=0 in that case is, that
ep->auth_hmacs is initialized to NULL in sctp_auth_init_hmacs()
when endpoint is being created.
After that point, if an admin switches over to auth_enable=1,
the machine can crash due to NULL pointer dereference during
reception of an INIT chunk. When we enter sctp_process_init()
via sctp_sf_do_5_1B_init() in order to respond to an INIT chunk,
the INIT verification succeeds and while we walk and process
all INIT params via sctp_process_param() we find that
net->sctp.auth_enable is set, therefore do not fall through,
but invoke sctp_auth_asoc_set_default_hmac() instead, and thus,
dereference what we have set to NULL during endpoint
initialization phase.
The fix is to make auth_enable immutable by caching its value
during endpoint initialization, so that its original value is
being carried along until destruction. The bug seems to originate
from the very first days.
Fix in joint work with Daniel Borkmann.
Reported-by: Joshua Kinard <kumba@gentoo.org>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Joshua Kinard <kumba@gentoo.org>
[ Upstream commit c674ac30c549596295eb0a5af7f4714c0b905b6f ]
Macvlan devices try to avoid stacking, but that's not always
successfull or even desired. As an example, the following
configuration is perefectly legal and valid:
eth0 <--- macvlan0 <---- vlan0.10 <--- macvlan1
However, this configuration produces the following lockdep
trace:
[ 115.620418] ======================================================
[ 115.620477] [ INFO: possible circular locking dependency detected ]
[ 115.620516] 3.15.0-rc1+ #24 Not tainted
[ 115.620540] -------------------------------------------------------
[ 115.620577] ip/1704 is trying to acquire lock:
[ 115.620604] (&vlan_netdev_addr_lock_key/1){+.....}, at: [<ffffffff815df49c>] dev_uc_sync+0x3c/0x80
[ 115.620686]
but task is already holding lock:
[ 115.620723] (&macvlan_netdev_addr_lock_key){+.....}, at: [<ffffffff815da5be>] dev_set_rx_mode+0x1e/0x40
[ 115.620795]
which lock already depends on the new lock.
[ 115.620853]
the existing dependency chain (in reverse order) is:
[ 115.620894]
-> #1 (&macvlan_netdev_addr_lock_key){+.....}:
[ 115.620935] [<ffffffff810d57f2>] lock_acquire+0xa2/0x130
[ 115.620974] [<ffffffff816f62e7>] _raw_spin_lock_nested+0x37/0x50
[ 115.621019] [<ffffffffa07296c3>] vlan_dev_set_rx_mode+0x53/0x110 [8021q]
[ 115.621066] [<ffffffff815da557>] __dev_set_rx_mode+0x57/0xa0
[ 115.621105] [<ffffffff815da5c6>] dev_set_rx_mode+0x26/0x40
[ 115.621143] [<ffffffff815da6be>] __dev_open+0xde/0x140
[ 115.621174] [<ffffffff815da9ad>] __dev_change_flags+0x9d/0x170
[ 115.621174] [<ffffffff815daaa9>] dev_change_flags+0x29/0x60
[ 115.621174] [<ffffffff815e7f11>] do_setlink+0x321/0x9a0
[ 115.621174] [<ffffffff815ea59f>] rtnl_newlink+0x51f/0x730
[ 115.621174] [<ffffffff815e6e75>] rtnetlink_rcv_msg+0x95/0x250
[ 115.621174] [<ffffffff81608b19>] netlink_rcv_skb+0xa9/0xc0
[ 115.621174] [<ffffffff815e6dca>] rtnetlink_rcv+0x2a/0x40
[ 115.621174] [<ffffffff81608150>] netlink_unicast+0xf0/0x1c0
[ 115.621174] [<ffffffff8160851f>] netlink_sendmsg+0x2ff/0x740
[ 115.621174] [<ffffffff815bc9db>] sock_sendmsg+0x8b/0xc0
[ 115.621174] [<ffffffff815bd4b9>] ___sys_sendmsg+0x369/0x380
[ 115.621174] [<ffffffff815bdbb2>] __sys_sendmsg+0x42/0x80
[ 115.621174] [<ffffffff815bdc02>] SyS_sendmsg+0x12/0x20
[ 115.621174] [<ffffffff816ffd69>] system_call_fastpath+0x16/0x1b
[ 115.621174]
-> #0 (&vlan_netdev_addr_lock_key/1){+.....}:
[ 115.621174] [<ffffffff810d4d43>] __lock_acquire+0x1773/0x1a60
[ 115.621174] [<ffffffff810d57f2>] lock_acquire+0xa2/0x130
[ 115.621174] [<ffffffff816f62e7>] _raw_spin_lock_nested+0x37/0x50
[ 115.621174] [<ffffffff815df49c>] dev_uc_sync+0x3c/0x80
[ 115.621174] [<ffffffffa0696d2a>] macvlan_set_mac_lists+0xca/0x110 [macvlan]
[ 115.621174] [<ffffffff815da557>] __dev_set_rx_mode+0x57/0xa0
[ 115.621174] [<ffffffff815da5c6>] dev_set_rx_mode+0x26/0x40
[ 115.621174] [<ffffffff815da6be>] __dev_open+0xde/0x140
[ 115.621174]
[ 115.621174] Possible unsafe locking scenario:
[ 115.621174] CPU0 CPU1
[ 115.621174] ---- ----
[ 115.621174] lock(&macvlan_netdev_addr_lock_key);
[ 115.621174] lock(&vlan_netdev_addr_lock_key/1);
[ 115.621174]
*** DEADLOCK ***
[ 115.621174] 2 locks held by ip/1704:
[ 115.621174] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815e6dbb>] rtnetlink_rcv+0x1b/0x40
[ 115.621174] #1: (&macvlan_netdev_addr_lock_key){+.....}, at: [<ffffffff815da5be>] dev_set_rx_mode+0x1e/0x40
[ 115.621174]
stack backtrace:
[ 115.621174] CPU: 3 PID: 1704 Comm: ip Not tainted 3.15.0-rc1+ #24
[ 115.621174] Hardware name: Hewlett-Packard HP xw8400 Workstation/0A08h, BIOS 786D5 v02.38 10/25/2010
[ 115.621174] ffffffff82339ae0 ffff880465f79568 ffffffff816ee20c ffffffff82339ae0
[ 115.621174] ffff880465f795a8 ffffffff816e9e1b ffff880465f79600 ffff880465b019c8
[ 115.621174] 0000000000000001 0000000000000002 ffff880465b019c8 ffff880465b01230
[ 115.621174] Call Trace:
[ 115.621174] [<ffffffff816ee20c>] dump_stack+0x4d/0x66
[ 115.621174] [<ffffffff816e9e1b>] print_circular_bug+0x200/0x20e
[ 115.621174] [<ffffffff810d3172>] ? trace_hardirqs_on_caller+0xb2/0x1d0
[ 115.621174] [<ffffffff815df49c>] ? dev_uc_sync+0x3c/0x80
[ 115.621174] [<ffffffff811e1db1>] ? mem_cgroup_bad_page_check+0x21/0x30
[ 115.621174] [<ffffffff810d394c>] ? __lock_acquire+0x37c/0x1a60
[ 115.621174] [<ffffffff815ea169>] ? rtnl_newlink+0xe9/0x730
[ 115.621174] [<ffffffff810d329d>] ? trace_hardirqs_on+0xd/0x10
[ 115.621174] [<ffffffff815e6dbb>] ? rtnetlink_rcv+0x1b/0x40
[ 115.621174] [<ffffffff815e6de0>] ? rtnetlink_rcv+0x40/0x40
[ 115.621174] [<ffffffff8119d4af>] ? might_fault+0x5f/0xb0
[ 115.621174] [<ffffffff8119d4f8>] ? might_fault+0xa8/0xb0
[ 115.621174] [<ffffffff815cb51e>] ? verify_iovec+0x5e/0xe0
[ 115.621174] [<ffffffff816faa0d>] ? __do_page_fault+0x11d/0x570
[ 115.621174] [<ffffffff810cfe9f>] ? up_read+0x1f/0x40
[ 115.621174] [<ffffffff816fab04>] ? __do_page_fault+0x214/0x570
[ 115.621174] [<ffffffff8120a10b>] ? mntput_no_expire+0x6b/0x1c0
[ 115.621174] [<ffffffff8120a0b7>] ? mntput_no_expire+0x17/0x1c0
[ 115.621174] [<ffffffff8120a284>] ? mntput+0x24/0x40
Fix this by correctly providing macvlan lockdep class.
[ Upstream commit d38569ab2bba6e6b3233acfc3a84cdbcfbd1f79f ]
This reverts commit dc8eaaa006350d24030502a4521542e74b5cb39f.
vlan: Fix lockdep warning when vlan dev handle notification
Instead we use the new new API to find the lock subclass of
our vlan device. This way we can support configurations where
vlans are interspersed with other devices:
bond -> vlan -> macvlan -> vlan
[ Upstream commit 25175ba5c9bff9aaf0229df34bb5d54c81633ec3 ]
Currently netif_addr_lock_nested assumes that there can be only
a single nesting level between 2 devices. However, if we
have multiple devices of the same type stacked, this fails.
For example:
eth0 <-- vlan0.10 <-- vlan0.10.20
A more complicated configuration may stack more then one type of
device in different order.
Ex:
eth0 <-- vlan0.10 <-- macvlan0 <-- vlan1.10.20 <-- macvlan1
This patch adds an ndo_* function that allows each stackable
device to report its nesting level. If the device doesn't
provide this function default subclass of 1 is used.
[ Upstream commit 4085ebe8c31face855fd01ee40372cb4aab1df3a ]
Multiple devices in the kernel can be stacked/nested and they
need to know their nesting level for the purposes of lockdep.
This patch provides a generic function that determines a nesting
level of a particular device by its type (ex: vlan, macvlan, etc).
We only care about nesting of the same type of devices.
For example:
eth0 <- vlan0.10 <- macvlan0 <- vlan1.20
The nesting level of vlan1.20 would be 1, since there is another vlan
in the stack under it.
receiver's buffer"
[ Upstream commit 362d52040c71f6e8d8158be48c812d7729cb8df1 ]
This reverts commit ef2820a735f7 ("net: sctp: Fix a_rwnd/rwnd management
to reflect real state of the receiver's buffer") as it introduced a
serious performance regression on SCTP over IPv4 and IPv6, though a not
as dramatic on the latter. Measurements are on 10Gbit/s with ixgbe NICs.
Current state:
[root@Lab200slot2 ~]# iperf3 --sctp -4 -c 192.168.241.3 -V -l 1452 -t 60
iperf version 3.0.1 (10 January 2014)
Linux Lab200slot2 3.14.0 #1 SMP Thu Apr 3 23:18:29 EDT 2014 x86_64
Time: Fri, 11 Apr 2014 17:56:21 GMT
Connecting to host 192.168.241.3, port 5201
Cookie: Lab200slot2.1397238981.812898.548918
[ 4] local 192.168.241.2 port 38616 connected to 192.168.241.3 port 5201
Starting Test: protocol: SCTP, 1 streams, 1452 byte blocks, omitting 0 seconds, 60 second test
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.09 sec 20.8 MBytes 161 Mbits/sec
[ 4] 1.09-2.13 sec 10.8 MBytes 86.8 Mbits/sec
[ 4] 2.13-3.15 sec 3.57 MBytes 29.5 Mbits/sec
[ 4] 3.15-4.16 sec 4.33 MBytes 35.7 Mbits/sec
[ 4] 4.16-6.21 sec 10.4 MBytes 42.7 Mbits/sec
[ 4] 6.21-6.21 sec 0.00 Bytes 0.00 bits/sec
[ 4] 6.21-7.35 sec 34.6 MBytes 253 Mbits/sec
[ 4] 7.35-11.45 sec 22.0 MBytes 45.0 Mbits/sec
[ 4] 11.45-11.45 sec 0.00 Bytes 0.00 bits/sec
[ 4] 11.45-12.51 sec 16.0 MBytes 126 Mbits/sec
[ 4] 12.51-13.59 sec 20.3 MBytes 158 Mbits/sec
[ 4] 13.59-14.65 sec 13.4 MBytes 107 Mbits/sec
[ 4] 14.65-16.79 sec 33.3 MBytes 130 Mbits/sec
[ 4] 16.79-16.79 sec 0.00 Bytes 0.00 bits/sec
[ 4] 16.79-17.82 sec 5.94 MBytes 48.7 Mbits/sec
(etc)
[root@Lab200slot2 ~]# iperf3 --sctp -6 -c 2001:db8:0:f101::1 -V -l 1400 -t 60
Time: Fri, 11 Apr 2014 19:08:41 GMT
Connecting to host 2001:db8:0:f101::1, port 5201
Cookie: Lab200slot2.1397243321.714295.2b3f7c
[ 4] local 2001:db8:0:f101::2 port 55804 connected to 2001:db8:0:f101::1 port 5201
Starting Test: protocol: SCTP, 1 streams, 1400 byte blocks, omitting 0 seconds, 60 second test
[ 4] 0.00-1.00 sec 169 MBytes 1.42 Gbits/sec
[ 4] 1.00-2.00 sec 201 MBytes 1.69 Gbits/sec
[ 4] 2.00-3.00 sec 188 MBytes 1.58 Gbits/sec
[ 4] 3.00-4.00 sec 174 MBytes 1.46 Gbits/sec
[ 4] 4.00-5.00 sec 165 MBytes 1.39 Gbits/sec
[ 4] 5.00-6.00 sec 199 MBytes 1.67 Gbits/sec
[ 4] 6.00-7.00 sec 163 MBytes 1.36 Gbits/sec
[ 4] 7.00-8.00 sec 174 MBytes 1.46 Gbits/sec
[ 4] 8.00-9.00 sec 193 MBytes 1.62 Gbits/sec
[ 4] 9.00-10.00 sec 196 MBytes 1.65 Gbits/sec
[ 4] 10.00-11.00 sec 157 MBytes 1.31 Gbits/sec
[ 4] 11.00-12.00 sec 175 MBytes 1.47 Gbits/sec
[ 4] 12.00-13.00 sec 192 MBytes 1.61 Gbits/sec
[ 4] 13.00-14.00 sec 199 MBytes 1.67 Gbits/sec
(etc)
After patch:
[root@Lab200slot2 ~]# iperf3 --sctp -4 -c 192.168.240.3 -V -l 1452 -t 60
Linux Lab200slot2 3.14.0+ #1 SMP Mon Apr 14 12:06:40 EDT 2014 x86_64
Time: Mon, 14 Apr 2014 16:40:48 GMT
Connecting to host 192.168.240.3, port 5201
Cookie: Lab200slot2.1397493648.413274.65e131
[ 4] local 192.168.240.2 port 50548 connected to 192.168.240.3 port 5201
[ 4] 0.00-1.00 sec 240 MBytes 2.02 Gbits/sec
[ 4] 1.00-2.00 sec 239 MBytes 2.01 Gbits/sec
[ 4] 2.00-3.00 sec 240 MBytes 2.01 Gbits/sec
[ 4] 3.00-4.00 sec 239 MBytes 2.00 Gbits/sec
[ 4] 4.00-5.00 sec 245 MBytes 2.05 Gbits/sec
[ 4] 5.00-6.00 sec 240 MBytes 2.01 Gbits/sec
[ 4] 6.00-7.00 sec 240 MBytes 2.02 Gbits/sec
[ 4] 7.00-8.00 sec 239 MBytes 2.01 Gbits/sec
With the reverted patch applied, the SCTP/IPv4 performance is back
to normal on latest upstream for IPv4 and IPv6 and has same throughput
as 3.4.2 test kernel, steady and interval reports are smooth again.
Fixes: ef2820a735f7 ("net: sctp: Fix a_rwnd/rwnd management to reflect real state of the receiver's buffer")
Reported-by: Peter Butler <pbutler@sonusnet.com>
Reported-by: Dongsheng Song <dongsheng.song@gmail.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Peter Butler <pbutler@sonusnet.com>
Cc: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nsn.com>
Cc: Alexander Sverdlin <alexander.sverdlin@nsn.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 30f78d8ebf7f514801e71b88a10c948275168518 ]
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
commit 29c7787075c92ca8af353acd5301481e6f37082f upstream.
David Vrabel identified a regression when using automatic NUMA balancing
under Xen whereby page table entries were getting corrupted due to the
use of native PTE operations. Quoting him
Xen PV guest page tables require that their entries use machine
addresses if the preset bit (_PAGE_PRESENT) is set, and (for
successful migration) non-present PTEs must use pseudo-physical
addresses. This is because on migration MFNs in present PTEs are
translated to PFNs (canonicalised) so they may be translated back
to the new MFN in the destination domain (uncanonicalised).
pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma()
set and clear the _PAGE_PRESENT bit using pte_set_flags(),
pte_clear_flags(), etc.
In a Xen PV guest, these functions must translate MFNs to PFNs
when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting
_PAGE_PRESENT.
His suggested fix converted p[te|md]_[set|clear]_flags to using
paravirt-friendly ops but this is overkill. He suggested an alternative
of using p[te|md]_modify in the NUMA page table operations but this is
does more work than necessary and would require looking up a VMA for
protections.
This patch modifies the NUMA page table operations to use paravirt
friendly operations to set/clear the flags of interest. Unfortunately
this will take a performance hit when updating the PTEs on
CONFIG_PARAVIRT but I do not see a way around it that does not break
Xen.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Many people reported preemption/reschedule problems with i386 kernels
for .13 and .14. After Michele bisected this to a combination of
3e8e42c69bb ("sched: Revert need_resched() to look at TIF_NEED_RESCHED")
ded79754754 ("irq: Force hardirq exit's softirq processing on its own stack")
it finally dawned on me that i386's current_thread_info() was to
blame.
When we are on interrupt/exception stacks, we fail to observe the
right TIF_NEED_RESCHED bit and therefore the PREEMPT_NEED_RESCHED
folding malfunctions.
Current upstream fixes this by making i386 behave the same as x86_64
already did:
2432e1364bbe ("x86: Nuke the supervisor_stack field in i386 thread_info")
b807902a88c4 ("x86: Nuke GET_THREAD_INFO_WITH_ESP() macro for i386")
0788aa6a23cb ("x86: Prepare removal of previous_esp from i386 thread_info structure")
198d208df437 ("x86: Keep thread_info on thread stack in x86_32")
However, that is far too much to stuff into -stable. Therefore I
propose we merge the below patch which uses task_thread_info(current)
for tif_need_resched() instead of the ESP based current_thread_info().
This makes sure we always observe the one true TIF_NEED_RESCHED bit
and things will work as expected again.
Cc: bp@alien8.de
Cc: fweisbec@gmail.com
Cc: david.a.cohen@linux.intel.com
Cc: mingo@kernel.org
Cc: greg@kroah.com
Cc: gregkh@linuxfoundation.org
Cc: pbonzini@redhat.com
Cc: rostedt@goodmis.org
Cc: stefan.bader@canonical.com
Cc: toralf.foerster@gmx.de
Cc: David Cohen <david.a.cohen@linux.intel.com>
Cc: torvalds@linux-foundation.org
Cc: <stable@vger.kernel.org>
Cc: <stable-commits@vger.kernel.org>
Cc: peterz@infradead.org
Cc: barra_cuda@katamail.com
Tested-by: Stefan Bader <stefan.bader@canonical.com>
Tested-by: Toralf F¿rster <toralf.foerster@gmx.de>
Tested-by: Michele Ballabio <barra_cuda@katamail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20140409142447.GD13658@twins.programming.kicks-ass.net
commit af5040da01ef980670b3741b3e10733ee3e33566 upstream.
trace_block_rq_complete does not take into account that request can
be partially completed, so we can get the following incorrect output
of blkparser:
C R 232 + 240 [0]
C R 240 + 232 [0]
C R 248 + 224 [0]
C R 256 + 216 [0]
but should be:
C R 232 + 8 [0]
C R 240 + 8 [0]
C R 248 + 8 [0]
C R 256 + 8 [0]
Also, the whole output summary statistics of completed requests and
final throughput will be incorrect.
This patch takes into account real completion size of the request and
fixes wrong completion accounting.
Signed-off-by: Roman Pen <r.peniaev@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
CC: Frederic Weisbecker <fweisbec@gmail.com>
CC: Ingo Molnar <mingo@redhat.com>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 223b02d923ecd7c84cf9780bb3686f455d279279 upstream.
"len" contains sizeof(nf_ct_ext) and size of extensions. In a worst
case it can contain all extensions. Bellow you can find sizes for all
types of extensions. Their sum is definitely bigger than 256.
nf_ct_ext_types[0]->len = 24
nf_ct_ext_types[1]->len = 32
nf_ct_ext_types[2]->len = 24
nf_ct_ext_types[3]->len = 32
nf_ct_ext_types[4]->len = 152
nf_ct_ext_types[5]->len = 2
nf_ct_ext_types[6]->len = 16
nf_ct_ext_types[7]->len = 8
I have seen "len" up to 280 and my host has crashes w/o this patch.
The right way to fix this problem is reducing the size of the ecache
extension (4) and Florian is going to do this, but these changes will
be quite large to be appropriate for a stable tree.
Fixes: 5b423f6a40a0 (netfilter: nf_conntrack: fix racy timer handling with reliable)
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Signed-off-by: Andrey Vagin <avagin@openvz.org>
commit b855d416dc17061ebb271ea7ef1201d100531770 upstream.
nft_cmp_fast is used for equality comparisions of size <= 4. For
comparisions of size < 4 byte a mask is calculated that is applied to
both the data from userspace (during initialization) and the register
value (during runtime). Both values are stored using (in effect) memcpy
to a memory area that is then interpreted as u32 by nft_cmp_fast.
This works fine on little endian since smaller types have the same base
address, however on big endian this is not true and the smaller types
are interpreted as a big number with trailing zero bytes.
The mask therefore must not include the lower bytes, but the higher bytes
on big endian. Add a helper function that does a cpu_to_le32 to switch
the bytes on big endian. Since we're dealing with a mask of just consequitive
bits, this works out fine.
commit ad36d28293936b03d6b7996e9d6aadfd73c0eb08 upstream.
Added the functions task_ppid_nr_ns() and task_ppid_nr() to abstract the lookup
of the PPID (real_parent's pid_t) of a process, including rcu locking, in the
arbitrary and init_pid_ns.
This provides an alternative to sys_getppid(), which is relative to the child
process' pid namespace.
(informed by ebiederman's 6c621b7e)
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
commit e63ed0d7a98014fdfc2cfeb3f6dada313dcabb59 upstream.
This patch eliminates the reap_ref and replaces it with a proper kref.
On last put of this kref, the target is removed from visibility in
sysfs. The final call to scsi_target_reap() for the device is done from
__scsi_remove_device() and only if the device was made visible. This
ensures that the target disappears as soon as the last device is gone
rather than waiting until final release of the device (which is often
too long).
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 8a4aeec8d2d6a3edeffbdfae451cdf05cbf0fefd upstream.
The AHCI spec allows implementations to issue commands in tag order
rather than FIFO order:
5.3.2.12 P:SelectCmd
HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1)
or HBA selects the command to issue that has had the
PxCI bit set to '1' longer than any other command
pending to be issued.
The result is that commands posted sequentially (time-wise) may play out
of sequence when issued by hardware.
This behavior has likely been hidden by drives that arrange for commands
to complete in issue order. However, it appears recent drives (two from
different vendors that we have found so far) inflict out-of-order
completions as a matter of course. So, we need to take care to maintain
ordered submission, otherwise we risk triggering a drive to fall out of
sequential-io automation and back to random-io processing, which incurs
large latency and degrades throughput.
This issue was found in simple benchmarks where QD=2 seq-write
performance was 30-50% *greater* than QD=32 seq-write performance.
Tagging for -stable and making the change globally since it has a low
risk-to-reward ratio. Also, word is that recent versions of an unnamed
OS also does it this way now. So, drives in the field are already
experienced with this tag ordering scheme.
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Ed Ciechanowski <ed.ciechanowski@intel.com>
Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit 9ef1af9ea28c23d0eaed97f7f5142788b6cf570a upstream.
The Tegra124 clock DT binding currently provides 3 clocks that don't
actually exist; 2 for NAND and one for UART5/UARTE. Delete these. While
this is technically an incompatible DT ABI change, nothing could have
used these clock IDs for anything practical, since the HW doesn't exist.
commit b7aa84d9cb9f26da1a9312c3e39dbd1a3c25a426 upstream.
Commit 4550dd6c6b062 introduced for_each_bvec() which iterates over each
bvec attached to a bio or bip. However, the macro fails to check bi_size
before dereferencing which can lead to crashes while counting/mapping
integrity scatterlist segments.
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
commit f2ebb3a921c1ca1e2ddd9242e95a1989a50c4c68 upstream.
The current mainline has copies propagated to *all* nodes, then
tears down the copies we made for nodes that do not contain
counterparts of the desired mountpoint. That sets the right
propagation graph for the copies (at teardown time we move
the slaves of removed node to a surviving peer or directly
to master), but we end up paying a fairly steep price in
useless allocations. It's fairly easy to create a situation
where N calls of mount(2) create exactly N bindings, with
O(N^2) vfsmounts allocated and freed in process.
Fortunately, it is possible to avoid those allocations/freeings.
The trick is to create copies in the right order and find which
one would've eventually become a master with the current algorithm.
It turns out to be possible in O(nodes getting propagation) time
and with no extra allocations at all.
One part is that we need to make sure that eventual master will be
created before its slaves, so we need to walk the propagation
tree in a different order - by peer groups. And iterate through
the peers before dealing with the next group.
Another thing is finding the (earlier) copy that will be a master
of one we are about to create; to do that we are (temporary) marking
the masters of mountpoints we are attaching the copies to.
Either we are in a peer of the last mountpoint we'd dealt with,
or we have the following situation: we are attaching to mountpoint M,
the last copy S_0 had been attached to M_0 and there are sequences
S_0...S_n, M_0...M_n such that S_{i+1} is a master of S_{i},
S_{i} mounted on M{i} and we need to create a slave of the first S_{k}
such that M is getting propagation from M_{k}. It means that the master
of M_{k} will be among the sequence of masters of M. On the
other hand, the nearest marked node in that sequence will either
be the master of M_{k} or the master of M_{k-1} (the latter -
in the case if M_{k-1} is a slave of something M gets propagation
from, but in a wrong peer group).
So we go through the sequence of masters of M until we find
a marked one (P). Let N be the one before it. Then we go through
the sequence of masters of S_0 until we find one (say, S) mounted
on a node D that has P as master and check if D is a peer of N.
If it is, S will be the master of new copy, if not - the master of S
will be.
That's it for the hard part; the rest is fairly simple. Iterator
is in next_group(), handling of one prospective mountpoint is
propagate_one().
It seems to survive all tests and gives a noticably better performance
than the current mainline for setups that are seriously using shared
subtrees.
commit ea1a8217b06b41b31a2b60b0b83f75c77ef9c873 upstream.
If the glibc xattr.h header is included after the uapi header,
compilation fails due to an enum re-using a #define from the uapi
header.
Protect against this by guarding the define and enum inclusions against
each other.
(See https://lists.debian.org/debian-glibc/2014/03/msg00029.html
and https://sourceware.org/glibc/wiki/Synchronizing_Headers
for more information.)
Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Allan McRae <allan@archlinux.org>
commit aee786acfc0a12bcd37a1c60f3198fb25cf7181a upstream.
bt->width should be (bt)->width, and same for the other fields.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit ec6931b281797b69e6cf109f9cc94d5a2bf994e0 upstream.
The asm-generic, big-endian version of zero_bytemask creates a mask of
bytes preceding the first zero-byte by left shifting ~0ul based on the
position of the first zero byte.
Unfortunately, if the first (top) byte is zero, the output of
prep_zero_mask has only the top bit set, resulting in undefined C
behaviour as we shift left by an amount equal to the width of the type.
As it happens, GCC doesn't manage to spot this through the call to fls(),
but the issue remains if architectures choose to implement their shift
instructions differently.
An example would be arch/arm/ (AArch32), where LSL Rd, Rn, #32 results
in Rd == 0x0, whilst on arch/arm64 (AArch64) LSL Xd, Xn, #64 results in
Xd == Xn.
Rather than check explicitly for the problematic shift, this patch adds
an extra shift by 1, replacing fls with __fls. Since zero_bytemask is
never called with a zero argument (has_zero() is used to check the data
first), we don't need to worry about calling __fls(0), which is
undefined.
Cc: Victor Kamensky <victor.kamensky@linaro.org>
commit 03367ef5ea811475187a0732aada068919e14d61 upstream.
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality
is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the
VMBUS protocol.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit b2853fd6c2d0f383dbdf7427e263eb576a633867 upstream.
The code that resolves the passive side source MAC within the rdma_cm
connection request handler was both redundant and buggy, so remove it.
It was redundant since later, when an RC QP is modified to RTR state,
the resolution will take place in the ib_core module. It was buggy
because this callback also deals with UD SIDR exchange, for which we
incorrectly looked at the REQ member of the CM event and dereferenced
a random value.
Fixes: dd5f03beb4f7 ("IB/core: Ethernet L2 attributes in verbs/cm structures")
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream.
There could be a case, when NFSd file system is mounted in network, different
to socket's one, like below:
"ip netns exec" creates new network and mount namespace, which duplicates NFSd
mount point, created in init_net context. And thus NFS server stop in nested
network context leads to RPCBIND client destruction in init_net.
Then, on NFSd start in nested network context, rpc.nfsd process creates socket
in nested net and passes it into "write_ports", which leads to RPCBIND sockets
creation in init_net context because of the same reason (NFSd monut point was
created in init_net context). An attempt to register passed socket in nested
net leads to panic, because no RPCBIND client present in nexted network
namespace.
This patch add check that passed socket's net matches NFSd superblock's one.
And returns -EINVAL error to user psace otherwise.
v2: Put socket on exit.
Reported-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5acda9d12dcf1ad0d9a5a2a7c646de3472fa7555 upstream.
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Derek Basehore <dbasehore@chromium.org>
commit a9c3f68f3cd8d55f809fbdb0c138ed061ea1bd25 upstream.
The user-settable knob, low_latency, has been the source of
several BUG reports which stem from flush_to_ldisc() running
in interrupt context. Since 3.12, which added several sleeping
locks (termios_rwsem and buf->lock) to the input processing path,
the frequency of these BUG reports has increased.
Note that changes in 3.12 did not introduce this regression;
sleeping locks were first added to the input processing path
with the removal of the BKL from N_TTY in commit
a88a69c91256418c5907c2f1f8a0ec0a36f9e6cc,
'n_tty: Fix loss of echoed characters and remove bkl from n_tty'
and later in commit 38db89799bdf11625a831c5af33938dcb11908b6,
'tty: throttling race fix'. Since those changes, executing
flush_to_ldisc() in interrupt_context (ie, low_latency set), is unsafe.
However, since most devices do not validate if the low_latency
setting is appropriate for the context (process or interrupt) in
which they receive data, some reports are due to misconfiguration.
Further, serial dma devices for which dma fails, resort to
interrupt receiving as a backup without resetting low_latency.
Historically, low_latency was used to force wake-up the reading
process rather than wait for the next scheduler tick. The
effect was to trim multiple milliseconds of latency from
when the process would receive new data.
Recent tests [1] have shown that the reading process now receives
data with only 10's of microseconds latency without low_latency set.
Remove the low_latency rx steering from tty_flip_buffer_push();
however, leave the knob as an optional hint to drivers that can
tune their rx fifos and such like. Cleanup stale code comments
regarding low_latency.
[1] https://lkml.org/lkml/2014/2/20/434
"Yay.. thats an annoying historical pain in the butt gone."
-- Alan Cox
Reported-by: Beat Bolli <bbolli@ewanet.ch>
Reported-by: Pavel Roskin <proski@gnu.org>
Acked-by: David Sterba <dsterba@suse.cz>
Cc: Grant Edwards <grant.b.edwards@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hal Murray <murray+fedora@ip-64-139-1-69.sjc.megapath.net>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream.
If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there
is no runtime check necessary, allow to skip the test within futex_init().
This allows to get rid of some code which would always give the same result,
and also allows the compiler to optimize a couple of if statements away.
Cc: Finn Thain <fthain@telegraphics.com.au>
Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: stable@kernel.org
Some drivers incorrectly assign vlan acceleration features to
vlan_features thus causing issues for Q-in-Q vlan configurations.
Warn the user of such cases.
skb_network_protocol() already accounts for multiple vlan
headers that may be present in the skb. However, skb_mac_gso_segment()
doesn't know anything about it and assumes that skb->mac_len
is set correctly to skip all mac headers. That may not
always be the case. If we are simply forwarding the packet (via
bridge or macvtap), all vlan headers may not be accounted for.
A simple solution is to allow skb_network_protocol to return
the vlan depth it has calculated. This way skb_mac_gso_segment
will correctly skip all mac headers.
addrconf_join_solict and addrconf_join_anycast may cause actions which
need rtnl locked, especially on first address creation.
A new DAD state is introduced which defers processing of the initial
DAD processing into a workqueue.
To get rtnl lock we need to push the code paths which depend on those
calls up to workqueues, specifically addrconf_verify and the DAD
processing.
(v2)
addrconf_dad_failure needs to be queued up to the workqueue, too. This
patch introduces a new DAD state and stop the DAD processing in the
workqueue (this is because of the possible ipv6_del_addr processing
which removes the solicited multicast address from the device).
addrconf_verify_lock is removed, too. After the transition it is not
needed any more.
As we are not processing in bottom half anymore we need to be a bit more
careful about disabling bottom half out when we lock spin_locks which are also
used in bh.
Relevant backtrace:
[ 541.030090] RTNL: assertion failed at net/core/dev.c (4496)
[ 541.031143] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 3.10.33-1-amd64-vyatta #1
[ 541.031145] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 541.031146] ffffffff8148a9f0 000000000000002f ffffffff813c98c1 ffff88007c4451f8
[ 541.031148] 0000000000000000 0000000000000000 ffffffff813d3540 ffff88007fc03d18
[ 541.031150] 0000880000000006 ffff88007c445000 ffffffffa0194160 0000000000000000
[ 541.031152] Call Trace:
[ 541.031153] <IRQ> [<ffffffff8148a9f0>] ? dump_stack+0xd/0x17
[ 541.031180] [<ffffffff813c98c1>] ? __dev_set_promiscuity+0x101/0x180
[ 541.031183] [<ffffffff813d3540>] ? __hw_addr_create_ex+0x60/0xc0
[ 541.031185] [<ffffffff813cfe1a>] ? __dev_set_rx_mode+0xaa/0xc0
[ 541.031189] [<ffffffff813d3a81>] ? __dev_mc_add+0x61/0x90
[ 541.031198] [<ffffffffa01dcf9c>] ? igmp6_group_added+0xfc/0x1a0 [ipv6]
[ 541.031208] [<ffffffff8111237b>] ? kmem_cache_alloc+0xcb/0xd0
[ 541.031212] [<ffffffffa01ddcd7>] ? ipv6_dev_mc_inc+0x267/0x300 [ipv6]
[ 541.031216] [<ffffffffa01c2fae>] ? addrconf_join_solict+0x2e/0x40 [ipv6]
[ 541.031219] [<ffffffffa01ba2e9>] ? ipv6_dev_ac_inc+0x159/0x1f0 [ipv6]
[ 541.031223] [<ffffffffa01c0772>] ? addrconf_join_anycast+0x92/0xa0 [ipv6]
[ 541.031226] [<ffffffffa01c311e>] ? __ipv6_ifa_notify+0x11e/0x1e0 [ipv6]
[ 541.031229] [<ffffffffa01c3213>] ? ipv6_ifa_notify+0x33/0x50 [ipv6]
[ 541.031233] [<ffffffffa01c36c8>] ? addrconf_dad_completed+0x28/0x100 [ipv6]
[ 541.031241] [<ffffffff81075c1d>] ? task_cputime+0x2d/0x50
[ 541.031244] [<ffffffffa01c38d6>] ? addrconf_dad_timer+0x136/0x150 [ipv6]
[ 541.031247] [<ffffffffa01c37a0>] ? addrconf_dad_completed+0x100/0x100 [ipv6]
[ 541.031255] [<ffffffff8105313a>] ? call_timer_fn.isra.22+0x2a/0x90
[ 541.031258] [<ffffffffa01c37a0>] ? addrconf_dad_completed+0x100/0x100 [ipv6]
Hunks and backtrace stolen from a patch by Stephen Hemminger.
Reported-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
skb_zerocopy can copy elements of the frags array between skbs, but it doesn't
orphan them. Also, it doesn't handle errors, so this patch takes care of that
as well, and modify the callers accordingly. skb_tx_error() is also added to
the callers so they will signal the failed delivery towards the creator of the
skb.
Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com>
This fixes a race which happens by freeing an object on the stack.
Quoting Julius:
> The issue is
> that it calls usbnet_terminate_urbs() before that, which temporarily
> installs a waitqueue in dev->wait in order to be able to wait on the
> tasklet to run and finish up some queues. The waiting itself looks
> okay, but the access to 'dev->wait' is totally unprotected and can
> race arbitrarily. I think in this case usbnet_bh() managed to succeed
> it's dev->wait check just before usbnet_terminate_urbs() sets it back
> to NULL. The latter then finishes and the waitqueue_t structure on its
> stack gets overwritten by other functions halfway through the
> wake_up() call in usbnet_bh().
The fix is to just not allocate the data structure on the stack.
As dev->wait is abused as a flag it also takes a runtime PM change
to fix this bug.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Reported-by: Grant Grundler <grundler@google.com>
Tested-by: Grant Grundler <grundler@google.com>
Pull networking fixes from David Miller:
1) OpenVswitch's lookup_datapath() returns error pointers, so don't
check against NULL. From Jiri Pirko.
2) pfkey_compile_policy() code path tries to do a GFP_KERNEL allocation
under RCU locks, fix by using GFP_ATOMIC when necessary. From
Nikolay Aleksandrov.
3) phy_suspend() indirectly passes uninitialized data into the ethtool
get wake-on-land implementations. Fix from Sebastian Hesselbarth.
4) CPSW driver unregisters CPTS twice, fix from Benedikt Spranger.
5) If SKB allocation of reply packet fails, vxlan's arp_reduce() defers
a NULL pointer. Fix from David Stevens.
6) IPV6 neigh handling in vxlan doesn't validate the destination
address properly, and it builds a packet with the src and dst
reversed. Fix also from David Stevens.
7) Fix spinlock recursion during subscription failures in TIPC stack,
from Erik Hugne.
8) Revert buggy conversion of davinci_emac to devm_request_irq, from
Chrstian Riesch.
9) Wrong flags passed into forwarding database netlink notifications,
from Nicolas Dichtel.
10) The netpoll neighbour soliciation handler checks wrong ethertype,
needs to be ETH_P_IPV6 rather than ETH_P_ARP. Fix from Li RongQing.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (34 commits)
tipc: fix spinlock recursion bug for failed subscriptions
vxlan: fix nonfunctional neigh_reduce()
net: davinci_emac: Fix rollback of emac_dev_open()
net: davinci_emac: Replace devm_request_irq with request_irq
netpoll: fix the skb check in pkt_is_ns
net: micrel : ks8851-ml: add vdd-supply support
ip6mr: fix mfc notification flags
ipmr: fix mfc notification flags
rtnetlink: fix fdb notification flags
tcp: syncookies: do not use getnstimeofday()
netlink: fix setsockopt in mmap examples in documentation
openvswitch: Correctly report flow used times for first 5 minutes after boot.
via-rhine: Disable device in error path
ATHEROS-ATL1E: Convert iounmap to pci_iounmap
vxlan: fix potential NULL dereference in arp_reduce()
cnic: Update version to 2.5.20 and copyright year.
cnic,bnx2i,bnx2fc: Fix inconsistent use of page size
cnic: Use proper ulp_ops for per device operations.
net: cdc_ncm: fix control message ordering
ipv6: ip6_append_data_mtu do not handle the mtu of the second fragment properly
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull trace fix from Steven Rostedt:
"Vaibhav Nagarnaik discovered that since 3.10 a clean-up patch made the
array index in the trace event format bogus.
He supplied an elegant solution that uses __stringify() and also
removes the need for the event_storage and event_storage_mutex and
also cuts off a few K of overhead from the trace events"
* tag 'trace-fixes-v3.14-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Fix array size mismatch in format string
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting
little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity:
indicating that remove_migration_ptes() failed to find one of the
migration entries that was temporarily inserted.
The problem comes from remap_file_pages()'s switch from vma_interval_tree
(good for inserting the migration entry) to i_mmap_nonlinear list (no good
for locating it again); but can only be a problem if the remap_file_pages()
range does not cover the whole of the vma (zap_pte() clears the range).
remove_migration_ptes() needs a file_nonlinear method to go down the
i_mmap_nonlinear list, applying linear location to look for migration
entries in those vmas too, just in case there was this race.
The file_nonlinear method does need rmap_walk_control.arg to do this;
but it never needed vma passed in - vma comes from its own iteration.
Reported-and-tested-by: Dave Jones <davej@redhat.com>
Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com>
