[ Upstream commit f42f7c283078ce3c1e8368b140e270755b1ae313 ]
Fix up the priority queue to not batch by owner, but by queue, so that
we allow '1 << priority' elements to be dequeued before switching to
the next priority queue.
The owner field is still used to wake up requests in round robin order
by owner to avoid single processes hogging the RPC layer by loading the
queues.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
commit 3b8720e63f4a1fc6f422a49ecbaa3b59c86d5aaf upstream.
It's dead code ever since
commit 34280340b1dc74c521e636f45cd728f9abf56ee2
Author: Geert Uytterhoeven <geert+renesas@glider.be>
Date: Fri Dec 4 17:01:43 2015 +0100
fbdev: Remove unused SH-Mobile HDMI driver
Also with this gone we can remove the cea_modes db. This entire thing
is massively incomplete anyway, compared to the CEA parsing that
drm_edid.c does.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Tavis Ormandy <taviso@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190721201956.941-1-daniel.vetter@ffwll.ch
[ Upstream commit 6b58859419554fb824e09cfdd73151a195473cbc ]
We observe an oops in the skx_edac module during boot:
EDAC MC0: Giving out device to module skx_edac controller Skylake Socket#0 IMC#0
EDAC MC1: Giving out device to module skx_edac controller Skylake Socket#0 IMC#1
EDAC MC2: Giving out device to module skx_edac controller Skylake Socket#1 IMC#0
EDAC MC13: Giving out device to module skx_edac controller Skylake Socket#0 IMC#1
EDAC MC14: Giving out device to module skx_edac controller Skylake Socket#1 IMC#0
EDAC MC15: Giving out device to module skx_edac controller Skylake Socket#1 IMC#1
Too many memory controllers: 16
EDAC MC: Removed device 0 for skx_edac Skylake Socket#0 IMC#0
We observe there are two memory controllers per socket, with a limit
of 16. Raise the maximum number of memory controllers from 16 to 2 *
MAX_NUMNODES (1024).
[ bp: This is just a band-aid fix until we've sorted out the whole issue
with the bus_type association and handling in EDAC and can get rid of
this arbitrary limit. ]
Signed-off-by: Justin Ernst <justin.ernst@hpe.com>
Acked-by: Russ Anderson <russ.anderson@hpe.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: linux-edac@vger.kernel.org
Link: https://lkml.kernel.org/r/20180925143449.284634-1-justin.ernst@hpe.com
[ Upstream commit c785896b21dd8e156326ff660050b0074d3431df ]
The table id (second) argument to MODULE_DEVICE_TABLE is often
referenced otherwise. This is not the case for CPU features. This
leads to warnings when building the kernel with Clang:
arch/arm/crypto/aes-ce-glue.c:450:1: warning: variable
'cpu_feature_match_AES' is not needed and will not be emitted
[-Wunneeded-internal-declaration]
module_cpu_feature_match(AES, aes_init);
Avoid warnings by using __maybe_unused, similar to commit 1f318a8bafcf
("modules: mark __inittest/__exittest as __maybe_unused").
Fixes: 67bad2fdb754 ("cpu: add generic support for CPU feature based module autoloading")
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Upstream commit 53dd9dce6979bc54d64a3a09a2fb20187a025be7 ]
The next update of libfdt has a new dependency on INT_MAX. Update the
instances of libfdt_env.h in the kernel to either include the necessary
header with the definition or define it locally.
Cc: Russell King <linux@armlinux.org.uk>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Rob Herring <robh@kernel.org>
[ Upstream commit 9708d2b5b7c648e8e0a40d11e8cea12f6277f33c ]
llc_sap_close() is called by llc_sap_put() which
could be called in BH context in llc_rcv(). We can't
block in BH.
There is no reason to block it here, kfree_rcu() should
be sufficient.
[ Upstream commit ff28915fd31ccafc0d38e6f84b66df280ed9e86a ]
include/trace/events/sched.h includes <linux/sched.h> (via
<linux/sched/numa_balancing.h>) and so knows about the TASK_* constants
used to interpret .prev_state. So instead of duplicating the magic
numbers make use of the defined macros to ease understanding the
mapping from state bits to letters which isn't completely intuitive for
an outsider.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: kernel@pengutronix.de
Link: http://lkml.kernel.org/r/20180905093636.24068-1-u.kleine-koenig@pengutronix.de
commit 4e7120d79edb31e4ee68e6f8421448e4603be1e9 upstream.
For both PASID-based-Device-TLB Invalidate Descriptor and
Device-TLB Invalidate Descriptor, the Physical Function Source-ID
value is split according to this layout:
PFSID[3:0] is set at offset 12 and PFSID[15:4] is put at offset 52.
Fix the part laid out at offset 52.
Fixes: 0f725561e1684 ("iommu/vt-d: Add definitions for PFSID")
Signed-off-by: Eric Auger <eric.auger@redhat.com>
Acked-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: stable@vger.kernel.org # v4.19+
Acked-by: Lu Baolu <baolu.lu@linux.intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit c57c80467f90e5504c8df9ad3555d2c78800bf94 upstream.
Add a function to create a kernel thread associated with a given VM. In
particular, it ensures that the worker thread inherits the priority and
cgroups of the calling thread.
Signed-off-by: Junaid Shahid <junaids@google.com>
commit 0d9ce162cf46c99628cc5da9510b959c7976735b upstream.
It doesn't seem as if there is any particular need for kvm_lock to be a
spinlock, so convert the lock to a mutex so that sleepable functions (in
particular cond_resched()) can be called while holding it.
commit 833b45de69a6016c4b0cebe6765d526a31a81580 upstream.
The largepages debugfs entry is incremented/decremented as shadow
pages are created or destroyed. Clearing it will result in an
underflow, which is harmless to KVM but ugly (and could be
misinterpreted by tools that use debugfs information), so make
this particular statistic read-only.
Cc: kvm-ppc@vger.kernel.org
commit 731dc9df975a5da21237a18c3384f811a7a41cc6 upstream.
A kernel module may need to check the value of the "mitigations=" kernel
command line parameter as part of its setup when the module needs
to perform software mitigations for a CPU flaw.
Uninline and export the helper functions surrounding the cpu_mitigations
enum to allow for their usage from a module.
Lastly, privatize the enum and cpu_mitigations variable since the value of
cpu_mitigations can be checked with the exported helper functions.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit db4d30fbb71b47e4ecb11c4efa5d8aad4b03dfae upstream.
Some processors may incur a machine check error possibly resulting in an
unrecoverable CPU lockup when an instruction fetch encounters a TLB
multi-hit in the instruction TLB. This can occur when the page size is
changed along with either the physical address or cache type. The relevant
erratum can be found here:
https://bugzilla.kernel.org/show_bug.cgi?id=205195
There are other processors affected for which the erratum does not fully
disclose the impact.
This issue affects both bare-metal x86 page tables and EPT.
It can be mitigated by either eliminating the use of large pages or by
using careful TLB invalidations when changing the page size in the page
tables.
Just like Spectre, Meltdown, L1TF and MDS, a new bit has been allocated in
MSR_IA32_ARCH_CAPABILITIES (PSCHANGE_MC_NO) and will be set on CPUs which
are mitigated against this issue.
Signed-off-by: Vineela Tummalapalli <vineela.tummalapalli@intel.com>
Co-developed-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
commit 6608b45ac5ecb56f9e171252229c39580cc85f0f upstream.
Add the sysfs reporting file for TSX Async Abort. It exposes the
vulnerability and the mitigation state similar to the existing files for
the other hardware vulnerabilities.
Sysfs file path is:
/sys/devices/system/cpu/vulnerabilities/tsx_async_abort
Tested-by: Neelima Krishnan <neelima.krishnan@intel.com>
Reviewed-by: Mark Gross <mgross@linux.intel.com>
Reviewed-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 3e977ac6179b39faa3c0eda5fce4f00663ae298d upstream.
If the user has created a read-only object, they should not be allowed
to circumvent the write protection by using a GGTT mmapping. Deny it.
Also most machines do not support read-only GGTT PTEs, so again we have
to reject attempted writes. Fortunately, this is known a priori, so we
can at least reject in the call to create the mmap (with a sanity check
in the fault handler).
v2: Check the vma->vm_flags during mmap() to allow readonly access.
v3: Remove VM_MAYWRITE to curtail mprotect()
Testcase: igt/gem_userptr_blits/readonly_mmap*
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Jon Bloomfield <jon.bloomfield@intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Matthew Auld <matthew.william.auld@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Reviewed-by: Matthew Auld <matthew.william.auld@gmail.com> #v1
Reviewed-by: Jon Bloomfield <jon.bloomfield@intel.com>
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180712185315.3288-4-chris@chris-wilson.co.uk
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
[ Upstream commit f75359f3ac855940c5718af10ba089b8977bf339 ]
Add a couple of READ_ONCE() and WRITE_ONCE() to prevent
load-tearing and store-tearing in sock_read_timestamp()
and sock_write_timestamp()
This might prevent another KCSAN report.
Fixes: 3a0ed3e96197 ("sock: Make sock->sk_stamp thread-safe")
Cc: Deepa Dinamani <deepa.kernel@gmail.com>
Acked-by: Deepa Dinamani <deepa.kernel@gmail.com>
[ Upstream commit c24b75e0f9239e78105f81c5f03a751641eb07ef ]
syzbot reported the following issue :
BUG: KCSAN: data-race in update_defense_level / update_defense_level
read to 0xffffffff861a6260 of 4 bytes by task 3006 on cpu 1:
update_defense_level+0x621/0xb30 net/netfilter/ipvs/ip_vs_ctl.c:177
defense_work_handler+0x3d/0xd0 net/netfilter/ipvs/ip_vs_ctl.c:225
process_one_work+0x3d4/0x890 kernel/workqueue.c:2269
worker_thread+0xa0/0x800 kernel/workqueue.c:2415
kthread+0x1d4/0x200 drivers/block/aoe/aoecmd.c:1253
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:352
write to 0xffffffff861a6260 of 4 bytes by task 7333 on cpu 0:
update_defense_level+0xa62/0xb30 net/netfilter/ipvs/ip_vs_ctl.c:205
Reported by Kernel Concurrency Sanitizer on:
CPU: 0 PID: 7333 Comm: kworker/0:5 Not tainted 5.4.0-rc3+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Workqueue: events defense_work_handler
Indeed, old_secure_tcp is currently a static variable, while it
needs to be a per netns variable.
Fixes: a0840e2e165a ("IPVS: netns, ip_vs_ctl local vars moved to ipvs struct.")
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit a9018adfde809d44e71189b984fa61cc89682b5e ]
The issue is in drivers/infiniband/core/uverbs_std_types_cq.c in the
UVERBS_HANDLER(UVERBS_METHOD_CQ_CREATE) function. We check that:
if (attr.comp_vector >= attrs->ufile->device->num_comp_vectors) {
But we don't check if "attr.comp_vector" is negative. It could
potentially lead to an array underflow. My concern would be where
cq->vector is used in the create_cq() function from the cxgb4 driver.
And really "attr.comp_vector" is appears as a u32 to user space so that's
the right type to use.
Fixes: 9ee79fce3642 ("IB/core: Add completion queue (cq) object actions")
Link: https://lore.kernel.org/r/20191011133419.GA22905@mwanda
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit e80a0af4759a164214f02da157a3800753ce135f upstream.
Many kernel drivers contain code that allocates and frees both a
scatterlist and the pages that populate that scatterlist.
Introduce functions in lib/scatterlist.c that perform these tasks
instead of duplicating this functionality in multiple drivers.
Only include these functions in the build if CONFIG_SGL_ALLOC=y
to avoid that the kernel size increases if this functionality is
not used.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 572ff4d560be3784205b224cd67d6715620092d7 upstream
The powerhold mask for TPS65917 is different when comapred to
the other palmas versions. Hence assign the right mask that enables
power off of tps65917 pmic correctly.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
commit 250367c59e6ba0d79d702a059712d66edacd4a1a upstream.
Invoking the following commands on a 32-bit architecture with strict
alignment requirements (such as an ARMv7-based Raspberry Pi) results
in an alignment exception:
# nft add table ip test-ip4
# nft add chain ip test-ip4 output { type filter hook output priority 0; }
# nft add rule ip test-ip4 output quota 1025 bytes
Alignment trap: not handling instruction e1b26f9f at [<7f4473f8>]
Unhandled fault: alignment exception (0x001) at 0xb832e824
Internal error: : 1 [#1] PREEMPT SMP ARM
Hardware name: BCM2835
[<7f4473fc>] (nft_quota_do_init [nft_quota])
[<7f447448>] (nft_quota_init [nft_quota])
[<7f4260d0>] (nf_tables_newrule [nf_tables])
[<7f4168dc>] (nfnetlink_rcv_batch [nfnetlink])
[<7f416bd0>] (nfnetlink_rcv [nfnetlink])
[<8078b334>] (netlink_unicast)
[<8078b664>] (netlink_sendmsg)
[<8071b47c>] (sock_sendmsg)
[<8071bd18>] (___sys_sendmsg)
[<8071ce3c>] (__sys_sendmsg)
[<8071ce94>] (sys_sendmsg)
The reason is that nft_quota_do_init() calls atomic64_set() on an
atomic64_t which is only aligned to 32-bit, not 64-bit, because it
succeeds struct nft_expr in memory which only contains a 32-bit pointer.
Fix by aligning the nft_expr private data to 64-bit.
Fixes: 96518518cc41 ("netfilter: add nftables")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: stable@vger.kernel.org # v3.13+
commit 169226f7e0d275c1879551f37484ef6683579a5c upstream.
We have a usecase to use tmpfs as QEMU memory backend and we would like
to take the advantage of THP as well. But, our test shows the EPT is
not PMD mapped even though the underlying THP are PMD mapped on host.
The number showed by /sys/kernel/debug/kvm/largepage is much less than
the number of PMD mapped shmem pages as the below:
7f2778200000-7f2878200000 rw-s 00000000 00:14 262232 /dev/shm/qemu_back_mem.mem.Hz2hSf (deleted)
[snip]
AnonHugePages: 0 kB
ShmemPmdMapped: 579584 kB
[snip]
Locked: 0 kB
cat /sys/kernel/debug/kvm/largepages
12
And some benchmarks do worse than with anonymous THPs.
By digging into the code we figured out that commit 127393fbe597 ("mm:
thp: kvm: fix memory corruption in KVM with THP enabled") checks if
there is a single PTE mapping on the page for anonymous THP when setting
up EPT map. But the _mapcount < 0 check doesn't work for page cache THP
since every subpage of page cache THP would get _mapcount inc'ed once it
is PMD mapped, so PageTransCompoundMap() always returns false for page
cache THP. This would prevent KVM from setting up PMD mapped EPT entry.
So we need handle page cache THP correctly. However, when page cache
THP's PMD gets split, kernel just remove the map instead of setting up
PTE map like what anonymous THP does. Before KVM calls get_user_pages()
the subpages may get PTE mapped even though it is still a THP since the
page cache THP may be mapped by other processes at the mean time.
Checking its _mapcount and whether the THP has PTE mapped or not.
Although this may report some false negative cases (PTE mapped by other
processes), it looks not trivial to make this accurate.
With this fix /sys/kernel/debug/kvm/largepage would show reasonable
pages are PMD mapped by EPT as the below:
7fbeaee00000-7fbfaee00000 rw-s 00000000 00:14 275464 /dev/shm/qemu_back_mem.mem.SKUvat (deleted)
[snip]
AnonHugePages: 0 kB
ShmemPmdMapped: 557056 kB
[snip]
Locked: 0 kB
271
And the benchmarks are as same as anonymous THPs.
[yang.shi@linux.alibaba.com: v4]
Link: http://lkml.kernel.org/r/1571865575-42913-1-git-send-email-yang.shi@linux.alibaba.com
Link: http://lkml.kernel.org/r/1571769577-89735-1-git-send-email-yang.shi@linux.alibaba.com
Fixes: dd78fedde4b9 ("rmap: support file thp")
Signed-off-by: Yang Shi <yang.shi@linux.alibaba.com>
Reported-by: Gang Deng <gavin.dg@linux.alibaba.com>
Tested-by: Gang Deng <gavin.dg@linux.alibaba.com>
Suggested-by: Hugh Dickins <hughd@google.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: <stable@vger.kernel.org> [4.8+]
[ Upstream commit 1b53d64435d56902fc234ff2507142d971a09687 ]
KCSAN reported the following data-race [1]
The fix will also prevent the compiler from optimizing out
the condition.
[1]
BUG: KCSAN: data-race in neigh_resolve_output / neigh_resolve_output
write to 0xffff8880a41dba78 of 8 bytes by interrupt on cpu 1:
neigh_event_send include/net/neighbour.h:443 [inline]
neigh_resolve_output+0x78/0x480 net/core/neighbour.c:1474
neigh_output include/net/neighbour.h:511 [inline]
ip_finish_output2+0x4af/0xe40 net/ipv4/ip_output.c:228
__ip_finish_output net/ipv4/ip_output.c:308 [inline]
__ip_finish_output+0x23a/0x490 net/ipv4/ip_output.c:290
ip_finish_output+0x41/0x160 net/ipv4/ip_output.c:318
NF_HOOK_COND include/linux/netfilter.h:294 [inline]
ip_output+0xdf/0x210 net/ipv4/ip_output.c:432
dst_output include/net/dst.h:436 [inline]
ip_local_out+0x74/0x90 net/ipv4/ip_output.c:125
__ip_queue_xmit+0x3a8/0xa40 net/ipv4/ip_output.c:532
ip_queue_xmit+0x45/0x60 include/net/ip.h:237
__tcp_transmit_skb+0xe81/0x1d60 net/ipv4/tcp_output.c:1169
tcp_transmit_skb net/ipv4/tcp_output.c:1185 [inline]
__tcp_retransmit_skb+0x4bd/0x15f0 net/ipv4/tcp_output.c:2976
tcp_retransmit_skb+0x36/0x1a0 net/ipv4/tcp_output.c:2999
tcp_retransmit_timer+0x719/0x16d0 net/ipv4/tcp_timer.c:515
tcp_write_timer_handler+0x42d/0x510 net/ipv4/tcp_timer.c:598
tcp_write_timer+0xd1/0xf0 net/ipv4/tcp_timer.c:618
read to 0xffff8880a41dba78 of 8 bytes by interrupt on cpu 0:
neigh_event_send include/net/neighbour.h:442 [inline]
neigh_resolve_output+0x57/0x480 net/core/neighbour.c:1474
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.0-rc3+ #0
[ Upstream commit 1899bb325149e481de31a4f32b59ea6f24e176ea ]
Since de77ecd4ef02 ("bonding: improve link-status update in
mii-monitoring"), the bonding driver has utilized two separate variables
to indicate the next link state a particular slave should transition to.
Each is used to communicate to a different portion of the link state
change commit logic; one to the bond_miimon_commit function itself, and
another to the state transition logic.
Unfortunately, the two variables can become unsynchronized,
resulting in incorrect link state transitions within bonding. This can
cause slaves to become stuck in an incorrect link state until a
subsequent carrier state transition.
The issue occurs when a special case in bond_slave_netdev_event
sets slave->link directly to BOND_LINK_FAIL. On the next pass through
bond_miimon_inspect after the slave goes carrier up, the BOND_LINK_FAIL
case will set the proposed next state (link_new_state) to BOND_LINK_UP,
but the new_link to BOND_LINK_DOWN. The setting of the final link state
from new_link comes after that from link_new_state, and so the slave
will end up incorrectly in _DOWN state.
Resolve this by combining the two variables into one.
Reported-by: Aleksei Zakharov <zakharov.a.g@yandex.ru>
Reported-by: Sha Zhang <zhangsha.zhang@huawei.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Fixes: de77ecd4ef02 ("bonding: improve link-status update in mii-monitoring")
Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com>
commit 55667441c84fa5e0911a0aac44fb059c15ba6da2 upstream.
UDP IPv6 packets auto flowlabels are using a 32bit secret
(static u32 hashrnd in net/core/flow_dissector.c) and
apply jhash() over fields known by the receivers.
Attackers can easily infer the 32bit secret and use this information
to identify a device and/or user, since this 32bit secret is only
set at boot time.
Really, using jhash() to generate cookies sent on the wire
is a serious security concern.
Trying to change the rol32(hash, 16) in ip6_make_flowlabel() would be
a dead end. Trying to periodically change the secret (like in sch_sfq.c)
could change paths taken in the network for long lived flows.
Let's switch to siphash, as we did in commit df453700e8d8
("inet: switch IP ID generator to siphash")
Using a cryptographically strong pseudo random function will solve this
privacy issue and more generally remove other weak points in the stack.
Packet schedulers using skb_get_hash_perturb() benefit from this change.
Fixes: b56774163f99 ("ipv6: Enable auto flow labels by default")
Fixes: 42240901f7c4 ("ipv6: Implement different admin modes for automatic flow labels")
Fixes: 67800f9b1f4e ("ipv6: Call skb_get_hash_flowi6 to get skb->hash in ip6_make_flowlabel")
Fixes: cb1ce2ef387b ("ipv6: Implement automatic flow label generation on transmit")
Reported-by: Jonathan Berger <jonathann1@walla.com>
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
Cc: Tom Herbert <tom@herbertland.com>
[ Upstream commit d7d16a89350ab263484c0aa2b523dd3a234e4a80 ]
Some paths call skb_queue_empty() without holding
the queue lock. We must use a barrier in order
to not let the compiler do strange things, and avoid
KCSAN splats.
Adding a barrier in skb_queue_empty() might be overkill,
I prefer adding a new helper to clearly identify
points where the callers might be lockless. This might
help us finding real bugs.
The corresponding WRITE_ONCE() should add zero cost
for current compilers.
[ Upstream commit 20eb4f29b60286e0d6dc01d9c260b4bd383c58fb ]
sk_page_frag() optimizes skb_frag allocations by using per-task
skb_frag cache when it knows it's the only user. The condition is
determined by seeing whether the socket allocation mask allows
blocking - if the allocation may block, it obviously owns the task's
context and ergo exclusively owns current->task_frag.
Unfortunately, this misses recursion through memory reclaim path.
Please take a look at the following backtrace.
[2] RIP: 0010:tcp_sendmsg_locked+0xccf/0xe10
tcp_sendmsg+0x27/0x40
sock_sendmsg+0x30/0x40
sock_xmit.isra.24+0xa1/0x170 [nbd]
nbd_send_cmd+0x1d2/0x690 [nbd]
nbd_queue_rq+0x1b5/0x3b0 [nbd]
__blk_mq_try_issue_directly+0x108/0x1b0
blk_mq_request_issue_directly+0xbd/0xe0
blk_mq_try_issue_list_directly+0x41/0xb0
blk_mq_sched_insert_requests+0xa2/0xe0
blk_mq_flush_plug_list+0x205/0x2a0
blk_flush_plug_list+0xc3/0xf0
[1] blk_finish_plug+0x21/0x2e
_xfs_buf_ioapply+0x313/0x460
__xfs_buf_submit+0x67/0x220
xfs_buf_read_map+0x113/0x1a0
xfs_trans_read_buf_map+0xbf/0x330
xfs_btree_read_buf_block.constprop.42+0x95/0xd0
xfs_btree_lookup_get_block+0x95/0x170
xfs_btree_lookup+0xcc/0x470
xfs_bmap_del_extent_real+0x254/0x9a0
__xfs_bunmapi+0x45c/0xab0
xfs_bunmapi+0x15/0x30
xfs_itruncate_extents_flags+0xca/0x250
xfs_free_eofblocks+0x181/0x1e0
xfs_fs_destroy_inode+0xa8/0x1b0
destroy_inode+0x38/0x70
dispose_list+0x35/0x50
prune_icache_sb+0x52/0x70
super_cache_scan+0x120/0x1a0
do_shrink_slab+0x120/0x290
shrink_slab+0x216/0x2b0
shrink_node+0x1b6/0x4a0
do_try_to_free_pages+0xc6/0x370
try_to_free_mem_cgroup_pages+0xe3/0x1e0
try_charge+0x29e/0x790
mem_cgroup_charge_skmem+0x6a/0x100
__sk_mem_raise_allocated+0x18e/0x390
__sk_mem_schedule+0x2a/0x40
[0] tcp_sendmsg_locked+0x8eb/0xe10
___sys_sendmsg+0x26d/0x2b0
__sys_sendmsg+0x57/0xa0
do_syscall_64+0x42/0x100
entry_SYSCALL_64_after_hwframe+0x44/0xa9
In [0], tcp_send_msg_locked() was using current->page_frag when it
called sk_wmem_schedule(). It already calculated how many bytes can
be fit into current->page_frag. Due to memory pressure,
sk_wmem_schedule() called into memory reclaim path which called into
xfs and then IO issue path. Because the filesystem in question is
backed by nbd, the control goes back into the tcp layer - back into
tcp_sendmsg_locked().
nbd sets sk_allocation to (GFP_NOIO | __GFP_MEMALLOC) which makes
sense - it's in the process of freeing memory and wants to be able to,
e.g., drop clean pages to make forward progress. However, this
confused sk_page_frag() called from [2]. Because it only tests
whether the allocation allows blocking which it does, it now thinks
current->page_frag can be used again although it already was being
used in [0].
After [2] used current->page_frag, the offset would be increased by
the used amount. When the control returns to [0],
current->page_frag's offset is increased and the previously calculated
number of bytes now may overrun the end of allocated memory leading to
silent memory corruptions.
Fix it by adding gfpflags_normal_context() which tests sleepable &&
!reclaim and use it to determine whether to use current->task_frag.
v2: Eric didn't like gfp flags being tested twice. Introduce a new
helper gfpflags_normal_context() and combine the two tests.
Cc: Josef Bacik <josef@toxicpanda.com>
[ Upstream commit ee8d153d46a3b98c064ee15c0c0a3bbf1450e5a1 ]
We already annotated most accesses to sk->sk_napi_id
We missed sk_mark_napi_id() and sk_mark_napi_id_once()
which might be called without socket lock held in UDP stack.
KCSAN reported :
BUG: KCSAN: data-race in udpv6_queue_rcv_one_skb / udpv6_queue_rcv_one_skb
write to 0xffff888121c6d108 of 4 bytes by interrupt on cpu 0:
sk_mark_napi_id include/net/busy_poll.h:125 [inline]
__udpv6_queue_rcv_skb net/ipv6/udp.c:571 [inline]
udpv6_queue_rcv_one_skb+0x70c/0xb40 net/ipv6/udp.c:672
udpv6_queue_rcv_skb+0xb5/0x400 net/ipv6/udp.c:689
udp6_unicast_rcv_skb.isra.0+0xd7/0x180 net/ipv6/udp.c:832
__udp6_lib_rcv+0x69c/0x1770 net/ipv6/udp.c:913
udpv6_rcv+0x2b/0x40 net/ipv6/udp.c:1015
ip6_protocol_deliver_rcu+0x22a/0xbe0 net/ipv6/ip6_input.c:409
ip6_input_finish+0x30/0x50 net/ipv6/ip6_input.c:450
NF_HOOK include/linux/netfilter.h:305 [inline]
NF_HOOK include/linux/netfilter.h:299 [inline]
ip6_input+0x177/0x190 net/ipv6/ip6_input.c:459
dst_input include/net/dst.h:442 [inline]
ip6_rcv_finish+0x110/0x140 net/ipv6/ip6_input.c:76
ipv6_rcv+0x1a1/0x1b0 net/ipv6/ip6_input.c:284
__netif_receive_skb_one_core+0xa7/0xe0 net/core/dev.c:5010
__netif_receive_skb+0x37/0xf0 net/core/dev.c:5124
process_backlog+0x1d3/0x420 net/core/dev.c:5955
napi_poll net/core/dev.c:6392 [inline]
net_rx_action+0x3ae/0xa90 net/core/dev.c:6460
write to 0xffff888121c6d108 of 4 bytes by interrupt on cpu 1:
CPU: 1 PID: 10890 Comm: syz-executor.0 Not tainted 5.4.0-rc3+ #0
Fixes: e68b6e50fa35 ("udp: enable busy polling for all sockets")
[ Upstream commit 7170a977743b72cf3eb46ef6ef89885dc7ad3621 ]
This socket field can be read and written by concurrent cpus.
Use READ_ONCE() and WRITE_ONCE() annotations to document this,
and avoid some compiler 'optimizations'.
KCSAN reported :
BUG: KCSAN: data-race in tcp_v4_rcv / tcp_v4_rcv
write to 0xffff88812220763c of 4 bytes by interrupt on cpu 0:
sk_incoming_cpu_update include/net/sock.h:953 [inline]
tcp_v4_rcv+0x1b3c/0x1bb0 net/ipv4/tcp_ipv4.c:1934
ip_protocol_deliver_rcu+0x4d/0x420 net/ipv4/ip_input.c:204
ip_local_deliver_finish+0x110/0x140 net/ipv4/ip_input.c:231
ip_local_deliver+0x133/0x210 net/ipv4/ip_input.c:252
ip_rcv_finish+0x121/0x160 net/ipv4/ip_input.c:413
ip_rcv+0x18f/0x1a0 net/ipv4/ip_input.c:523
__do_softirq+0x115/0x33f kernel/softirq.c:292
do_softirq_own_stack+0x2a/0x40 arch/x86/entry/entry_64.S:1082
do_softirq.part.0+0x6b/0x80 kernel/softirq.c:337
do_softirq kernel/softirq.c:329 [inline]
__local_bh_enable_ip+0x76/0x80 kernel/softirq.c:189
read to 0xffff88812220763c of 4 bytes by interrupt on cpu 1:
sk_incoming_cpu_update include/net/sock.h:952 [inline]
tcp_v4_rcv+0x181a/0x1bb0 net/ipv4/tcp_ipv4.c:1934
run_ksoftirqd+0x46/0x60 kernel/softirq.c:603
smpboot_thread_fn+0x37d/0x4a0 kernel/smpboot.c:165
CPU: 1 PID: 16 Comm: ksoftirqd/1 Not tainted 5.4.0-rc3+ #0
commit 644fbdeacf1d3edd366e44b8ba214de9d1dd66a9 upstream.
Now sctp uses inet_dgram_connect as its proto_ops .connect, and the flags
param can't be passed into its proto .connect where this flags is really
needed.
sctp works around it by getting flags from socket file in __sctp_connect.
It works for connecting from userspace, as inherently the user sock has
socket file and it passes f_flags as the flags param into the proto_ops
.connect.
However, the sock created by sock_create_kern doesn't have a socket file,
and it passes the flags (like O_NONBLOCK) by using the flags param in
kernel_connect, which calls proto_ops .connect later.
So to fix it, this patch defines a new proto_ops .connect for sctp,
sctp_inet_connect, which calls __sctp_connect() directly with this
flags param. After this, the sctp's proto .connect can be removed.
Note that sctp_inet_connect doesn't need to do some checks that are not
needed for sctp, which makes thing better than with inet_dgram_connect.
Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
commit 159d2c7d8106177bd9a986fd005a311fe0d11285 upstream.
qdisc_root() use from netem_enqueue() triggers a lockdep warning.
__dev_queue_xmit() uses rcu_read_lock_bh() which is
not equivalent to rcu_read_lock() + local_bh_disable_bh as far
as lockdep is concerned.
WARNING: suspicious RCU usage
5.3.0-rc7+ #0 Not tainted
include/net/sch_generic.h:492 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 2, debug_locks = 1
3 locks held by syz-executor427/8855:
#0: 00000000b5525c01 (rcu_read_lock_bh){....}, at: lwtunnel_xmit_redirect include/net/lwtunnel.h:92 [inline]
#0: 00000000b5525c01 (rcu_read_lock_bh){....}, at: ip_finish_output2+0x2dc/0x2570 net/ipv4/ip_output.c:214
#1: 00000000b5525c01 (rcu_read_lock_bh){....}, at: __dev_queue_xmit+0x20a/0x3650 net/core/dev.c:3804
#2: 00000000364bae92 (&(&sch->q.lock)->rlock){+.-.}, at: spin_lock include/linux/spinlock.h:338 [inline]
#2: 00000000364bae92 (&(&sch->q.lock)->rlock){+.-.}, at: __dev_xmit_skb net/core/dev.c:3502 [inline]
#2: 00000000364bae92 (&(&sch->q.lock)->rlock){+.-.}, at: __dev_queue_xmit+0x14b8/0x3650 net/core/dev.c:3838
stack backtrace:
CPU: 0 PID: 8855 Comm: syz-executor427 Not tainted 5.3.0-rc7+ #0
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
lockdep_rcu_suspicious+0x153/0x15d kernel/locking/lockdep.c:5357
qdisc_root include/net/sch_generic.h:492 [inline]
netem_enqueue+0x1cfb/0x2d80 net/sched/sch_netem.c:479
__dev_xmit_skb net/core/dev.c:3527 [inline]
__dev_queue_xmit+0x15d2/0x3650 net/core/dev.c:3838
dev_queue_xmit+0x18/0x20 net/core/dev.c:3902
neigh_hh_output include/net/neighbour.h:500 [inline]
neigh_output include/net/neighbour.h:509 [inline]
ip_finish_output2+0x1726/0x2570 net/ipv4/ip_output.c:228
__ip_finish_output+0x5fc/0xb90 net/ipv4/ip_output.c:290
ip_finish_output+0x38/0x1f0 net/ipv4/ip_output.c:318
ip_mc_output+0x292/0xf40 net/ipv4/ip_output.c:417
ip_local_out+0xbb/0x190 net/ipv4/ip_output.c:125
ip_send_skb+0x42/0xf0 net/ipv4/ip_output.c:1555
udp_send_skb.isra.0+0x6b2/0x1160 net/ipv4/udp.c:887
udp_sendmsg+0x1e96/0x2820 net/ipv4/udp.c:1174
inet_sendmsg+0x9e/0xe0 net/ipv4/af_inet.c:807
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg+0xd7/0x130 net/socket.c:657
___sys_sendmsg+0x3e2/0x920 net/socket.c:2311
__sys_sendmmsg+0x1bf/0x4d0 net/socket.c:2413
__do_sys_sendmmsg net/socket.c:2442 [inline]
__se_sys_sendmmsg net/socket.c:2439 [inline]
__x64_sys_sendmmsg+0x9d/0x100 net/socket.c:2439
do_syscall_64+0xfd/0x6a0 arch/x86/entry/common.c:296
entry_SYSCALL_64_after_hwframe+0x49/0xbe
commit b74555de21acd791f12c4a1aeaf653dd7ac21133 upstream.
syzbot reported:
BUG: memory leak
unreferenced object 0xffff88811eb3de00 (size 224):
comm "syz-executor559", pid 7315, jiffies 4294943019 (age 10.300s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00 a0 38 24 81 88 ff ff 00 c0 f2 15 81 88 ff ff ..8$............
backtrace:
[<000000008d1c66a1>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<000000008d1c66a1>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<000000008d1c66a1>] slab_alloc_node mm/slab.c:3269 [inline]
[<000000008d1c66a1>] kmem_cache_alloc_node+0x153/0x2a0 mm/slab.c:3579
[<00000000447d9496>] __alloc_skb+0x6e/0x210 net/core/skbuff.c:198
[<000000000cdbf82f>] alloc_skb include/linux/skbuff.h:1058 [inline]
[<000000000cdbf82f>] llc_alloc_frame+0x66/0x110 net/llc/llc_sap.c:54
[<000000002418b52e>] llc_conn_ac_send_sabme_cmd_p_set_x+0x2f/0x140 net/llc/llc_c_ac.c:777
[<000000001372ae17>] llc_exec_conn_trans_actions net/llc/llc_conn.c:475 [inline]
[<000000001372ae17>] llc_conn_service net/llc/llc_conn.c:400 [inline]
[<000000001372ae17>] llc_conn_state_process+0x1ac/0x640 net/llc/llc_conn.c:75
[<00000000f27e53c1>] llc_establish_connection+0x110/0x170 net/llc/llc_if.c:109
[<00000000291b2ca0>] llc_ui_connect+0x10e/0x370 net/llc/af_llc.c:477
[<000000000f9c740b>] __sys_connect+0x11d/0x170 net/socket.c:1840
The bug is that most callers of llc_conn_send_pdu() assume it consumes a
reference to the skb, when actually due to commit b85ab56c3f81 ("llc:
properly handle dev_queue_xmit() return value") it doesn't.
Revert most of that commit, and instead make the few places that need
llc_conn_send_pdu() to *not* consume a reference call skb_get() before.
Fixes: b85ab56c3f81 ("llc: properly handle dev_queue_xmit() return value")
Reported-by: syzbot+6b825a6494a04cc0e3f7@syzkaller.appspotmail.com
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
commit 8f8fed0cdbbd6cdbf28d9ebe662f45765d2f7d39 upstream.
When a non-passthrough command is terminated with CHECK CONDITION, request
sense is executed by hijacking the command descriptor. Since
scsi_eh_prep_cmnd() and scsi_eh_restore_cmnd() do not save/restore the
original command resid, the value returned on failure of the original
command is lost and replaced with the value set by the execution of the
request sense command. This value may in many instances be unaligned to the
device sector size, causing sd_done() to print a warning message about the
incorrect unaligned resid before the command is retried.
Fix this problem by saving the original command residual in struct
scsi_eh_save using scsi_eh_prep_cmnd() and restoring it in
scsi_eh_restore_cmnd(). In addition, to make sure that the request sense
command is executed with a correctly initialized command structure, also
reset the residual to 0 in scsi_eh_prep_cmnd() after saving the original
command value in struct scsi_eh_save.
Link: https://lore.kernel.org/r/20191001074839.1994-1-damien.lemoal@wdc.com
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
commit 7388afe09143210f555bdd6c75035e9acc1fab96 upstream.
Enforce the first argument to be a correct type of a pointer to struct
element and avoid unnecessary typecasts from const to non-const pointers
(the change in validate_ie_attr() is needed to make this part work). In
addition, avoid signed/unsigned comparison within for_each_element() and
mark struct element packed just in case.
Signed-off-by: Jouni Malinen <j@w1.fi>
commit 0f3b07f027f87a38ebe5c436490095df762819be upstream.
Rather than always iterating elements from frames with pure
u8 pointers, add a type "struct element" that encapsulates
the id/datalen/data format of them.
Then, add the element iteration macros
* for_each_element
* for_each_element_id
* for_each_element_extid
which take, as their first 'argument', such a structure and
iterate through a given u8 array interpreting it as elements.
While at it and since we'll need it, also add
* for_each_subelement
* for_each_subelement_id
* for_each_subelement_extid
which instead of taking data/length just take an outer element
and use its data/datalen.
Also add for_each_element_completed() to determine if any of
the loops above completed, i.e. it was able to parse all of
the elements successfully and no data remained.
Use for_each_element_id() in cfg80211_find_ie_match() as the
first user of this.
commit cfc8f568aada98f9608a0a62511ca18d647613e2 upstream.
Prepare to use SND_SOC_DAPM_PRE_POST_PMU definition to
reduce coming code size and make it more readable.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Link: https://lore.kernel.org/r/20190719100524.23300-2-oleksandr.suvorov@toradex.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit dccc96abfb21dc19d69e707c38c8ba439bba7160 ]
The data structure used for log messages is so large that it can cause a
boot failure. Since allocations from that data structure can fail anyway,
use kmalloc() / kfree() instead of that data structure.
See also https://bugzilla.kernel.org/show_bug.cgi?id=204119.
See also commit ded85c193a39 ("scsi: Implement per-cpu logging buffer") # v4.0.
Reported-by: Jan Palus <jpalus@fastmail.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Jan Palus <jpalus@fastmail.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit 6565c182094f69e4ffdece337d395eb7ec760efc upstream.
Quoted from
commit 3da40c7b0898 ("ext4: only call ext4_truncate when size <= isize")
" At LSF we decided that if we truncate up from isize we shouldn't trim
fallocated blocks that were fallocated with KEEP_SIZE and are past the
new i_size. This patch fixes ext4 to do this. "
And generic/092 of fstest have covered this case for long time, however
is_quota_modification() didn't adjust based on that rule, so that in
below condition, we will lose to quota block change:
- fallocate blocks beyond EOF
- remount
- truncate(file_path, file_size)
Fix it.
Link: https://lore.kernel.org/r/20190911093650.35329-1-yuchao0@huawei.com
Fixes: 3da40c7b0898 ("ext4: only call ext4_truncate when size <= isize")
CC: stable@vger.kernel.org
Signed-off-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit e336b4027775cb458dc713745e526fa1a1996b2a ]
Since BUG() and WARN() may use a trap (e.g. UD2 on x86) to
get the address where the BUG() has occurred, kprobes can not
do single-step out-of-line that instruction. So prohibit
probing on such address.
Without this fix, if someone put a kprobe on WARN(), the
kernel will crash with invalid opcode error instead of
outputing warning message, because kernel can not find
correct bug address.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Naveen N . Rao <naveen.n.rao@linux.ibm.com>
Link: https://lkml.kernel.org/r/156750890133.19112.3393666300746167111.stgit@devnote2
commit f794809a7259dfaa3d47d90ef5a86007cf48b1ce upstream.
The upstream kernel commit cited below modified the workqueue in the
new CQ API to be bound to a specific CPU (instead of being unbound).
This caused ALL users of the new CQ API to use the same bound WQ.
Specifically, MAD handling was severely delayed when the CPU bound
to the WQ was busy handling (higher priority) interrupts.
This caused a delay in the MAD "heartbeat" response handling,
which resulted in ports being incorrectly classified as "down".
To fix this, add a new "unbound" WQ type to the new CQ API, so that users
have the option to choose either a bound WQ or an unbound WQ.
For MADs, choose the new "unbound" WQ.
Fixes: b7363e67b23e ("IB/device: Convert ib-comp-wq to be CPU-bound")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.m>
[ Upstream commit 89a26cd4b501e9511d3cd3d22327fc76a75a38b3 ]
When running a 64-bit kernel with a 32-bit iptables binary, the size of
the xt_nfacct_match_info struct diverges.
kernel: sizeof(struct xt_nfacct_match_info) : 40
iptables: sizeof(struct xt_nfacct_match_info)) : 36
Trying to append nfacct related rules results in an unhelpful message.
Although it is suggested to look for more information in dmesg, nothing
can be found there.
# iptables -A <chain> -m nfacct --nfacct-name <acct-object>
iptables: Invalid argument. Run `dmesg' for more information.
This patch fixes the memory misalignment by enforcing 8-byte alignment
within the struct's first revision. This solution is often used in many
other uapi netfilter headers.
Signed-off-by: Juliana Rodrigueiro <juliana.rodrigueiro@intra2net.com>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit fe163e534e5eecdfd7b5920b0dfd24c458ee85d6 ]
syzbot reported:
BUG: KMSAN: uninit-value in capi_write+0x791/0xa90 drivers/isdn/capi/capi.c:700
CPU: 0 PID: 10025 Comm: syz-executor379 Not tainted 4.20.0-rc7+ #2
Call Trace:
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:313
do_loop_readv_writev fs/read_write.c:703 [inline]
do_iter_write+0x83e/0xd80 fs/read_write.c:961
vfs_writev fs/read_write.c:1004 [inline]
do_writev+0x397/0x840 fs/read_write.c:1039
__do_sys_writev fs/read_write.c:1112 [inline]
__se_sys_writev+0x9b/0xb0 fs/read_write.c:1109
__x64_sys_writev+0x4a/0x70 fs/read_write.c:1109
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
The problem is that capi_write() is reading past the end of the message.
Fix it by checking the message's length in the needed places.
Reported-and-tested-by: syzbot+0849c524d9c634f5ae66@syzkaller.appspotmail.com
commit 47d3d7fdb10a21c223036b58bd70ffdc24a472c4 upstream.
Since ip6frag_expire_frag_queue() now pulls the head skb
from frag queue, we should no longer use skb_get(), since
this leads to an skb leak.
Stefan Bader initially reported a problem in 4.4.stable [1] caused
by the skb_get(), so this patch should also fix this issue.
296583.091021] kernel BUG at /build/linux-6VmqmP/linux-4.4.0/net/core/skbuff.c:1207!
[296583.091734] Call Trace:
[296583.091749] [<ffffffff81740e50>] __pskb_pull_tail+0x50/0x350
[296583.091764] [<ffffffff8183939a>] _decode_session6+0x26a/0x400
[296583.091779] [<ffffffff817ec719>] __xfrm_decode_session+0x39/0x50
[296583.091795] [<ffffffff818239d0>] icmpv6_route_lookup+0xf0/0x1c0
[296583.091809] [<ffffffff81824421>] icmp6_send+0x5e1/0x940
[296583.091823] [<ffffffff81753238>] ? __netif_receive_skb+0x18/0x60
[296583.091838] [<ffffffff817532b2>] ? netif_receive_skb_internal+0x32/0xa0
[296583.091858] [<ffffffffc0199f74>] ? ixgbe_clean_rx_irq+0x594/0xac0 [ixgbe]
[296583.091876] [<ffffffffc04eb260>] ? nf_ct_net_exit+0x50/0x50 [nf_defrag_ipv6]
[296583.091893] [<ffffffff8183d431>] icmpv6_send+0x21/0x30
[296583.091906] [<ffffffff8182b500>] ip6_expire_frag_queue+0xe0/0x120
[296583.091921] [<ffffffffc04eb27f>] nf_ct_frag6_expire+0x1f/0x30 [nf_defrag_ipv6]
[296583.091938] [<ffffffff810f3b57>] call_timer_fn+0x37/0x140
[296583.091951] [<ffffffffc04eb260>] ? nf_ct_net_exit+0x50/0x50 [nf_defrag_ipv6]
[296583.091968] [<ffffffff810f5464>] run_timer_softirq+0x234/0x330
[296583.091982] [<ffffffff8108a339>] __do_softirq+0x109/0x2b0
Fixes: d4289fcc9b16 ("net: IP6 defrag: use rbtrees for IPv6 defrag")
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Cc: Peter Oskolkov <posk@google.com>
Cc: Florian Westphal <fw@strlen.de>
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
commit dbb2483b2a46fbaf833cfb5deb5ed9cace9c7399 upstream.
In commit 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
I introduced a check for xfrm protocol, but according to Herbert
IPSEC_PROTO_ANY should only be used as a wildcard for lookup, so
it should be removed from validate_tmpl().
And, IPSEC_PROTO_ANY is expected to only match 3 IPSec-specific
protocols, this is why xfrm_state_flush() could still miss
IPPROTO_ROUTING, which leads that those entries are left in
net->xfrm.state_all before exit net. Fix this by replacing
IPSEC_PROTO_ANY with zero.
This patch also extracts the check from validate_tmpl() to
xfrm_id_proto_valid() and uses it in parse_ipsecrequest().
With this, no other protocols should be added into xfrm.
Fixes: 6a53b7593233 ("xfrm: check id proto in validate_tmpl()")
Reported-by: syzbot+0bf0519d6e0de15914fe@syzkaller.appspotmail.com
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit dbf47a2a094edf58983265e323ca4bdcdb58b5ee ]
Action sample doesn't properly handle psample_group pointer in overwrite
case. Following issues need to be fixed:
- In tcf_sample_init() function RCU_INIT_POINTER() is used to set
s->psample_group, even though we neither setting the pointer to NULL, nor
preventing concurrent readers from accessing the pointer in some way.
Use rcu_swap_protected() instead to safely reset the pointer.
- Old value of s->psample_group is not released or deallocated in any way,
which results resource leak. Use psample_group_put() on non-NULL value
obtained with rcu_swap_protected().
- The function psample_group_put() that released reference to struct
psample_group pointed by rcu-pointer s->psample_group doesn't respect rcu
grace period when deallocating it. Extend struct psample_group with rcu
head and use kfree_rcu when freeing it.
Fixes: 5c5670fae430 ("net/sched: Introduce sample tc action")
Signed-off-by: Vlad Buslov <vladbu@mellanox.com>
[ Upstream commit 981471bd3abf4d572097645d765391533aac327d ]
The net pointer in struct xt_tgdtor_param is not explicitly
initialized therefore is still NULL when dereferencing it.
So we have to find a way to pass the correct net pointer to
ipt_destroy_target().
The best way I find is just saving the net pointer inside the per
netns struct tcf_idrinfo, which could make this patch smaller.
Fixes: 0c66dc1ea3f0 ("netfilter: conntrack: register hooks in netns when needed by ruleset")
Reported-and-tested-by: itugrok@yahoo.com
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 5c498950f730aa17c5f8a2cdcb903524e4002ed2 ]
Signed-off-by: Luis Henriques <lhenriques@suse.com>
Reviewed-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[ Upstream commit 68e03b85474a51ec1921b4d13204782594ef7223 ]
when do randbuilding, I got this error:
In file included from drivers/hwmon/pmbus/ucd9000.c:19:0:
./include/linux/gpio/driver.h:576:1: error: redefinition of gpiochip_add_pin_range
gpiochip_add_pin_range(struct gpio_chip *chip, const char *pinctl_name,
In file included from drivers/hwmon/pmbus/ucd9000.c:18:0:
./include/linux/gpio.h:245:1: note: previous definition of gpiochip_add_pin_range was here
Fixes: 964cb341882f ("gpio: move pincontrol calls to <linux/gpio/driver.h>")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20190731123814.46624-1-yuehaibing@huawei.com
[ Upstream commit df3accb849607a86278a37c35e6b313635ccc48b ]
Allow the caller to pass error information when cleaning up a failed
I/O request so that we can conditionally take action to cancel the
request altogether if the error turned out to be fatal.
[ Upstream commit 078b5fd92c4913dd367361db6c28568386077c89 ]
In several places we're just moving the struct nfs_page from one list to
another by first removing from the existing list, then adding to the new
one.
