Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
[ Upstream commit 89d328f637b9904b6d4c9af73c8a608b8dd4d6f8 ]
The actual number of bytes stored in a PRZ is smaller than the
bytes requested by platform data, since there is a header on each
PRZ. Additionally, if ECC is enabled, there are trailing bytes used
as well. Normally this mismatch doesn't matter since PRZs are circular
buffers and the leading "overflow" bytes are just thrown away. However, in
the case of a compressed record, this rather badly corrupts the results.
This corruption was visible with "ramoops.mem_size=204800 ramoops.ecc=1".
Any stored crashes would not be uncompressable (producing a pstorefs
"dmesg-*.enc.z" file), and triggering errors at boot:
[ 2.790759] pstore: crypto_comp_decompress failed, ret = -22!
Backporting this depends on commit 70ad35db3321 ("pstore: Convert console
write to use ->write_buf")
Reported-by: Joel Fernandes <joel@joelfernandes.org>
Fixes: b0aad7a99c1d ("pstore: Add compression support to pstore")
Reviewed-by: Joel Fernandes (Google) <joel@joelfernandes.org>
[ Upstream commit 123664101aa2156d05251704fc63f9bcbf77741a ]
This reverts commit b3cf8528bb21febb650a7ecbf080d0647be40b9f.
That commit unintentionally broke Xen balloon memory hotplug with
"hotplug_unpopulated" set to 1. As long as "System RAM" resource
got assigned under a new "Unusable memory" resource in IO/Mem tree
any attempt to online this memory would fail due to general kernel
restrictions on having "System RAM" resources as 1st level only.
The original issue that commit has tried to workaround fa564ad96366
("x86/PCI: Enable a 64bit BAR on AMD Family 15h (Models 00-1f, 30-3f,
60-7f)") also got amended by the following 03a551734 ("x86/PCI: Move
and shrink AMD 64-bit window to avoid conflict") which made the
original fix to Xen ballooning unnecessary.
Signed-off-by: Igor Druzhinin <igor.druzhinin@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit 3f2b7b9035107d6096ea438ea3d97dcf0481b6d2 ]
The code in fscache_retrieval_complete is using atomic_sub followed by an
atomic_read:
atomic_sub(n_pages, &op->n_pages);
if (atomic_read(&op->n_pages) <= 0)
fscache_op_complete(&op->op, true);
This causes two threads doing a decrement of n_pages to race with each
other seeing the op->refcount 0 at same time - and they end up calling
fscache_op_complete() in both the threads leading to an assertion failure.
Fix this by using atomic_sub_return_relaxed() instead of two calls. Note
that I'm using 'relaxed' rather than, say, 'release' as there aren't
multiple variables that appear to need ordering across the release.
The oops looks something like:
FS-Cache: Assertion failed
FS-Cache: 0 > 0 is false
kernel BUG at /usr/src/linux-4.4.0/fs/fscache/operation.c:449!
Workqueue: fscache_operation fscache_op_work_func [fscache]
RIP: 0010:[<ffffffffc037eacd>] fscache_op_complete+0x10d/0x180 [fscache]
Call Trace:
[<ffffffffc1464cf9>] cachefiles_read_copier+0x3a9/0x410 [cachefiles]
[<ffffffffc037e272>] fscache_op_work_func+0x22/0x50 [fscache]
[<ffffffff81096da0>] process_one_work+0x150/0x3f0
[<ffffffff8109751a>] worker_thread+0x11a/0x470
[<ffffffff81808e59>] ? __schedule+0x359/0x980
[<ffffffff81097400>] ? rescuer_thread+0x310/0x310
[<ffffffff8109cdd6>] kthread+0xd6/0xf0
[<ffffffff8109cd00>] ? kthread_park+0x60/0x60
[<ffffffff8180d0cf>] ret_from_fork+0x3f/0x70
This seen this in 4.4.x kernels and the same bug affects fscache in latest
upstreams kernels.
Fixes: 1bb4b7f98f36 ("FS-Cache: The retrieval remaining-pages counter needs to be atomic_t")
Signed-off-by: Kiran Kumar Modukuri <kiran.modukuri@gmail.com>
[ Upstream commit 584eab291c67894cb17cc87544b9d086228ea70f ]
register_{netdevice/inetaddr/inet6addr}_notifier may return an error
value, this patch adds the code to handle these error paths.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
[ Upstream commit fb6df5a6234c38a9c551559506a49a677ac6f07a ]
In sctp_hash_transport/sctp_epaddr_lookup_transport, it dereferences
a transport's asoc under rcu_read_lock while asoc is freed not after
a grace period, which leads to a use-after-free panic.
This patch fixes it by calling kfree_rcu to make asoc be freed after
a grace period.
Note that only the asoc's memory is delayed to free in the patch, it
won't cause sk to linger longer.
Thanks Neil and Marcelo to make this clear.
Fixes: 7fda702f9315 ("sctp: use new rhlist interface on sctp transport rhashtable")
Fixes: cd2b70875058 ("sctp: check duplicate node before inserting a new transport")
Reported-by: syzbot+0b05d8aa7cb185107483@syzkaller.appspotmail.com
Reported-by: syzbot+aad231d51b1923158444@syzkaller.appspotmail.com
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 22f6bbb7bcfcef0b373b0502a7ff390275c575dd ]
list_del() leaves the skb->next pointer poisoned, which can then lead to
a crash in e.g. OVS forwarding. For example, setting up an OVS VXLAN
forwarding bridge on sfc as per:
$ ovs-vsctl show
5dfd9c47-f04b-4aaa-aa96-4fbb0a522a30
Bridge "br0"
Port "br0"
Interface "br0"
type: internal
Port "enp6s0f0"
Interface "enp6s0f0"
Port "vxlan0"
Interface "vxlan0"
type: vxlan
options: {key="1", local_ip="10.0.0.5", remote_ip="10.0.0.4"}
ovs_version: "2.5.0"
(where 10.0.0.5 is an address on enp6s0f1)
and sending traffic across it will lead to the following panic:
general protection fault: 0000 [#1] SMP PTI
CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.20.0-rc3-ehc+ #701
Hardware name: Dell Inc. PowerEdge R710/0M233H, BIOS 6.4.0 07/23/2013
RIP: 0010:dev_hard_start_xmit+0x38/0x200
Code: 53 48 89 fb 48 83 ec 20 48 85 ff 48 89 54 24 08 48 89 4c 24 18 0f 84 ab 01 00 00 48 8d 86 90 00 00 00 48 89 f5 48 89 44 24 10 <4c> 8b 33 48 c7 03 00 00 00 00 48 8b 05 c7 d1 b3 00 4d 85 f6 0f 95
RSP: 0018:ffff888627b437e0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: dead000000000100 RCX: ffff88862279c000
RDX: ffff888614a342c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff888618a88000 R08: 0000000000000001 R09: 00000000000003e8
R10: 0000000000000000 R11: ffff888614a34140 R12: 0000000000000000
R13: 0000000000000062 R14: dead000000000100 R15: ffff888616430000
FS: 0000000000000000(0000) GS:ffff888627b40000(0000) knlGS:0000000000000000
CR2: 00007f6d2bc6d000 CR3: 000000000200a000 CR4: 00000000000006e0
Call Trace:
<IRQ>
__dev_queue_xmit+0x623/0x870
? masked_flow_lookup+0xf7/0x220 [openvswitch]
? ep_poll_callback+0x101/0x310
do_execute_actions+0xaba/0xaf0 [openvswitch]
? __wake_up_common+0x8a/0x150
? __wake_up_common_lock+0x87/0xc0
? queue_userspace_packet+0x31c/0x5b0 [openvswitch]
ovs_execute_actions+0x47/0x120 [openvswitch]
ovs_dp_process_packet+0x7d/0x110 [openvswitch]
ovs_vport_receive+0x6e/0xd0 [openvswitch]
? dst_alloc+0x64/0x90
? rt_dst_alloc+0x50/0xd0
? ip_route_input_slow+0x19a/0x9a0
? __udp_enqueue_schedule_skb+0x198/0x1b0
? __udp4_lib_rcv+0x856/0xa30
? cpumask_next_and+0x19/0x20
? find_busiest_group+0x12d/0xcd0
netdev_frame_hook+0xce/0x150 [openvswitch]
__netif_receive_skb_core+0x205/0xae0
__netif_receive_skb_list_core+0x11e/0x220
netif_receive_skb_list+0x203/0x460
? __efx_rx_packet+0x335/0x5e0 [sfc]
efx_poll+0x182/0x320 [sfc]
net_rx_action+0x294/0x3c0
__do_softirq+0xca/0x297
irq_exit+0xa6/0xb0
do_IRQ+0x54/0xd0
common_interrupt+0xf/0xf
</IRQ>
So, in all listified-receive handling, instead pull skbs off the lists with
skb_list_del_init().
Fixes: 9af86f933894 ("net: core: fix use-after-free in __netif_receive_skb_list_core")
Fixes: 7da517a3bc52 ("net: core: Another step of skb receive list processing")
Fixes: a4ca8b7df73c ("net: ipv4: fix drop handling in ip_list_rcv() and ip_list_rcv_finish()")
Fixes: d8269e2cbf90 ("net: ipv6: listify ipv6_rcv() and ip6_rcv_finish()")
Signed-off-by: Edward Cree <ecree@solarflare.com>
[ Upstream commit e6ac64d4c4d095085d7dd71cbd05704ac99829b2 ]
While skb_push() makes the kernel panic if the skb headroom is less than
the unaligned hardware header size, it will proceed normally in case we
copy more than that because of alignment, and we'll silently corrupt
adjacent slabs.
In the case fixed by the previous patch,
"ipv6: Check available headroom in ip6_xmit() even without options", we
end up in neigh_hh_output() with 14 bytes headroom, 14 bytes hardware
header and write 16 bytes, starting 2 bytes before the allocated buffer.
Always check we're not writing before skb->head and, if the headroom is
not enough, warn and drop the packet.
v2:
- instead of panicking with BUG_ON(), WARN_ON_ONCE() and drop the packet
(Eric Dumazet)
- if we avoid the panic, though, we need to explicitly check the headroom
before the memcpy(), otherwise we'll have corrupted slabs on a running
kernel, after we warn
- use __skb_push() instead of skb_push(), as the headroom check is
already implemented here explicitly (Eric Dumazet)
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
commit 37c2578c0c40e286bc0d30bdc05290b2058cf66e upstream.
vmbus_process_offer() mustn't call channel->sc_creation_callback()
directly for sub-channels, because sc_creation_callback() ->
vmbus_open() may never get the host's response to the
OPEN_CHANNEL message (the host may rescind a channel at any time,
e.g. in the case of hot removing a NIC), and vmbus_onoffer_rescind()
may not wake up the vmbus_open() as it's blocked due to a non-zero
vmbus_connection.offer_in_progress, and finally we have a deadlock.
The above is also true for primary channels, if the related device
drivers use sync probing mode by default.
And, usually the handling of primary channels and sub-channels can
depend on each other, so we should offload them to different
workqueues to avoid possible deadlock, e.g. in sync-probing mode,
NIC1's netvsc_subchan_work() can race with NIC2's netvsc_probe() ->
rtnl_lock(), and causes deadlock: the former gets the rtnl_lock
and waits for all the sub-channels to appear, but the latter
can't get the rtnl_lock and this blocks the handling of sub-channels.
The patch can fix the multiple-NIC deadlock described above for
v3.x kernels (e.g. RHEL 7.x) which don't support async-probing
of devices, and v4.4, v4.9, v4.14 and v4.18 which support async-probing
but don't enable async-probing for Hyper-V drivers (yet).
The patch can also fix the hang issue in sub-channel's handling described
above for all versions of kernels, including v4.19 and v4.20-rc4.
So actually the patch should be applied to all the existing kernels,
not only the kernels that have 8195b1396ec8.
Fixes: 8195b1396ec8 ("hv_netvsc: fix deadlock on hotplug")
Cc: stable@vger.kernel.org
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 5363857b916c1f48027e9b96ee8be8376bf20811 upstream.
As addressed in alsa-lib (commit b420056604f0), we need to fix the
case where the evaluation of PCM interval "(x x+1]" leading to
-EINVAL. After applying rules, such an interval may be translated as
"(x x+1)".
Fixes: ff2d6acdf6f1 ("ALSA: pcm: Fix snd_interval_refine first/last with open min/max")
Cc: <stable@vger.kernel.org>
commit f51ccf46217c28758b1f3b5bc0ccfc00eca658b2 upstream.
The USB-serial console implementation has never reported the actual
terminal settings used. Despite storing the corresponding cflags in its
struct console, these were never honoured on later tty open() where the
tty termios would be left initialised to the driver defaults.
Unlike the serial console implementation, the USB-serial code calls
subdriver open() already at console setup. While calling set_termios()
and write() before open() looks like it could work for some USB-serial
drivers, others definitely do not expect this, so modelling this after
serial core is going to be intrusive, if at all possible.
Instead, use a (renamed) tty helper to save the termios data used at
console setup so that the tty termios reflects the actual terminal
settings after a subsequent tty open().
Note that the calls to tty_init_termios() (tty_driver_install()) and
tty_save_termios() are serialised using the disconnect mutex.
This specifically fixes a regression that was triggered by a recent
change adding software flow control to the pl2303 driver: a getty trying
to disable flow control while leaving the baud rate unchanged would now
also set the baud rate to the driver default (prior to the flow-control
change this had been a noop).
Fixes: 7041d9c3f01b ("USB: serial: pl2303: add support for tx xon/xoff flow control")
Cc: stable <stable@vger.kernel.org> # 4.18
Cc: Florian Zumbiehl <florz@florz.de>
Reported-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 704620afc70cf47abb9d6a1a57f3825d2bca49cf upstream.
When reading an extra descriptor, we need to properly check the minimum
and maximum size allowed, to prevent from invalid data being sent by a
device.
Reported-by: Hui Peng <benquike@gmail.com>
Reported-by: Mathias Payer <mathias.payer@nebelwelt.net>
Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Hui Peng <benquike@gmail.com>
Signed-off-by: Mathias Payer <mathias.payer@nebelwelt.net>
Cc: stable <stable@kernel.org>
commit 0c7a52e4d4b5c4d35b31f3c3ad32af814f1bf491 upstream.
After enabling KVM event tracing, almost all of trace_kvm_exit()'s
printk shows
"kvm_exit: IRQ: ..."
even if the actual exception_type is NOT IRQ. More specifically,
trace_kvm_exit() is defined in virt/kvm/arm/trace.h by TRACE_EVENT.
This slight problem may have existed after commit e6753f23d961
("tracepoint: Make rcuidle tracepoint callers use SRCU"). There are
two variables in trace_kvm_exit() and __DO_TRACE() which have the
same name, *idx*. Thus the actual value of *idx* will be overwritten
when tracing. Fix it by adding a simple prefix.
Cc: Joel Fernandes <joel@joelfernandes.org>
Cc: Wang Haibin <wanghaibin.wang@huawei.com>
Cc: linux-trace-devel@vger.kernel.org
Fixes: e6753f23d961 ("tracepoint: Make rcuidle tracepoint callers use SRCU")
Signed-off-by: Zenghui Yu <yuzenghui@huawei.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 3054426dc68e5d63aa6a6e9b91ac4ec78e3f3805 upstream.
commit 3f5fe9fef5b2 ("sched/debug: Fix task state recording/printout")
tried to fix the problem introduced by a previous commit efb40f588b43
("sched/tracing: Fix trace_sched_switch task-state printing"). However
the prev_state output in sched_switch is still broken.
task_state_index() uses fls() which considers the LSB as 1. Left
shifting 1 by this value gives an incorrect mapping to the task state.
Fix this by decrementing the value returned by __get_task_state()
before shifting.
Link: http://lkml.kernel.org/r/1540882473-1103-1-git-send-email-pkondeti@codeaurora.org
Fixes: 3f5fe9fef5b2 ("sched/debug: Fix task state recording/printout")
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
commit 0145b50566e7de5637e80ecba96c7f0e6fff1aad upstream.
Before this commit sensor_hub_input_attr_get_raw_value() failed to take
the signedness of 16 and 8 bit values into account, returning e.g.
65436 instead of -100 for the z-axis reading of an accelerometer.
This commit adds a new is_signed parameter to the function and makes all
callers pass the appropriate value for this.
While at it, this commit also fixes up some neighboring lines where
statements were needlessly split over 2 lines to improve readability.
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit 39eb456dacb543de90d3bc6a8e0ac5cf51ac475e upstream.
Currently, the depth of the ret_stack is determined by curr_ret_stack index.
The issue is that there's a race between setting of the curr_ret_stack and
calling of the callback attached to the return of the function.
Commit 03274a3ffb44 ("tracing/fgraph: Adjust fgraph depth before calling
trace return callback") moved the calling of the callback to after the
setting of the curr_ret_stack, even stating that it was safe to do so, when
in fact, it was the reason there was a barrier() there (yes, I should have
commented that barrier()).
Not only does the curr_ret_stack keep track of the current call graph depth,
it also keeps the ret_stack content from being overwritten by new data.
The function profiler, uses the "subtime" variable of ret_stack structure
and by moving the curr_ret_stack, it allows for interrupts to use the same
structure it was using, corrupting the data, and breaking the profiler.
To fix this, there needs to be two variables to handle the call stack depth
and the pointer to where the ret_stack is being used, as they need to change
at two different locations.
Cc: stable@kernel.org
Fixes: 03274a3ffb449 ("tracing/fgraph: Adjust fgraph depth before calling trace return callback")
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
commit d125f3f866df88da5a85df00291f88f0baa89f7c upstream.
As all architectures now call function_graph_enter() to do the entry work,
no architecture should ever call ftrace_push_return_trace(). Make it static.
This is needed to prepare for a fix of a design bug on how the curr_ret_stack
is used.
commit 8114865ff82e200b383e46821c25cb0625b842b5 upstream.
Currently all the architectures do basically the same thing in preparing the
function graph tracer on entry to a function. This code can be pulled into a
generic location and then this will allow the function graph tracer to be
fixed, as well as extended.
Create a new function graph helper function_graph_enter() that will call the
hook function (ftrace_graph_entry) and the shadow stack operation
(ftrace_push_return_trace), and remove the need of the architecture code to
manage the shadow stack.
is used.
commit 9137bb27e60e554dab694eafa4cca241fa3a694f upstream
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
commit 46f7ecb1e7359f183f5bbd1e08b90e10e52164f9 upstream
The IBPB control code in x86 removed the usage. Remove the functionality
which was introduced for this.
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.559149393@linutronix.de
commit a74cfffb03b73d41e08f84c2e5c87dec0ce3db9f upstream
arch_smt_update() is only called when the sysfs SMT control knob is
changed. This means that when SMT is enabled in the sysfs control knob the
system is considered to have SMT active even if all siblings are offline.
To allow finegrained control of the speculation mitigations, the actual SMT
state is more interesting than the fact that siblings could be enabled.
Rework the code, so arch_smt_update() is invoked from each individual CPU
hotplug function, and simplify the update function while at it.
Link: https://lkml.kernel.org/r/20181125185004.521974984@linutronix.de
commit 321a874a7ef85655e93b3206d0f36b4a6097f948 upstream
Make the scheduler's 'sched_smt_present' static key globaly available, so
it can be used in the x86 speculation control code.
Provide a query function and a stub for the CONFIG_SMP=n case.
Link: https://lkml.kernel.org/r/20181125185004.430168326@linutronix.de
commit dbfe2953f63c640463c630746cd5d9de8b2f63ae upstream
Currently, IBPB is only issued in cases when switching into a non-dumpable
process, the rationale being to protect such 'important and security
sensitive' processess (such as GPG) from data leaking into a different
userspace process via spectre v2.
This is however completely insufficient to provide proper userspace-to-userpace
spectrev2 protection, as any process can poison branch buffers before being
scheduled out, and the newly scheduled process immediately becomes spectrev2
victim.
In order to minimize the performance impact (for usecases that do require
spectrev2 protection), issue the barrier only in cases when switching between
processess where the victim can't be ptraced by the potential attacker (as in
such cases, the attacker doesn't have to bother with branch buffers at all).
[ tglx: Split up PTRACE_MODE_NOACCESS_CHK into PTRACE_MODE_SCHED and
PTRACE_MODE_IBPB to be able to do ptrace() context tracking reasonably
fine-grained ]
Fixes: 18bf3c3ea8 ("x86/speculation: Use Indirect Branch Prediction Barrier in context switch")
Originally-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: "WoodhouseDavid" <dwmw@amazon.co.uk>
Cc: "SchauflerCasey" <casey.schaufler@intel.com>
Link: https://lkml.kernel.org/r/nycvar.YFH.7.76.1809251437340.15880@cbobk.fhfr.pm
[ Upstream commit 86de5921a3d5dd246df661e09bdd0a6131b39ae3 ]
Jean-Louis reported a TCP regression and bisected to recent SACK
compression.
After a loss episode (receiver not able to keep up and dropping
packets because its backlog is full), linux TCP stack is sending
a single SACK (DUPACK).
Sender waits a full RTO timer before recovering losses.
While RFC 6675 says in section 5, "Algorithm Details",
(2) If DupAcks < DupThresh but IsLost (HighACK + 1) returns true --
indicating at least three segments have arrived above the current
cumulative acknowledgment point, which is taken to indicate loss
-- go to step (4).
(4) Invoke fast retransmit and enter loss recovery as follows:
there are old TCP stacks not implementing this strategy, and
still counting the dupacks before starting fast retransmit.
While these stacks probably perform poorly when receivers implement
LRO/GRO, we should be a little more gentle to them.
This patch makes sure we do not enable SACK compression unless
3 dupacks have been sent since last rcv_nxt update.
Ideally we should even rearm the timer to send one or two
more DUPACK if no more packets are coming, but that will
be work aiming for linux-4.21.
Many thanks to Jean-Louis for bisecting the issue, providing
packet captures and testing this patch.
Fixes: 5d9f4262b7ea ("tcp: add SACK compression")
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 0211dda68a4f6531923a2f72d8e8959207f59fba ]
On every iteration of net_dim, the algorithm may choose to
check for the system state by comparing current data sample
with previous data sample. After each of these comparison,
regardless of the action taken, the sample used as baseline
is needed to be updated.
This patch fixes a bug that causes DIM to take wrong decisions,
due to never updating the baseline sample for comparison between
iterations. This way, DIM always compares current sample with
zeros.
Although this is a functional fix, it also improves and stabilizes
performance as the algorithm works properly now.
Performance:
Tested single UDP TX stream with pktgen:
samples/pktgen/pktgen_sample03_burst_single_flow.sh -i p4p2 -d 1.1.1.1
-m 24:8a:07:88:26:8b -f 3 -b 128
ConnectX-5 100GbE packet rate improved from 15-19Mpps to 19-20Mpps.
Also, toggling between profiles is less frequent with the fix.
Fixes: 8115b750dbcb ("net/dim: use struct net_dim_sample as arg to net_dim")
Signed-off-by: Tal Gilboa <talgi@mellanox.com>
Reviewed-by: Tariq Toukan <tariqt@mellanox.com>
[ Upstream commit 5cd8d46ea1562be80063f53c7c6a5f40224de623 ]
tpacket_snd sends packets with user pages linked into skb frags. It
notifies that pages can be reused when the skb is released by setting
skb->destructor to tpacket_destruct_skb.
This can cause data corruption if the skb is orphaned (e.g., on
transmit through veth) or cloned (e.g., on mirror to another psock).
Create a kernel-private copy of data in these cases, same as tun/tap
zerocopy transmission. Reuse that infrastructure: mark the skb as
SKBTX_ZEROCOPY_FRAG, which will trigger copy in skb_orphan_frags(_rx).
Unlike other zerocopy packets, do not set shinfo destructor_arg to
struct ubuf_info. tpacket_destruct_skb already uses that ptr to notify
when the original skb is released and a timestamp is recorded. Do not
change this timestamp behavior. The ubuf_info->callback is not needed
anyway, as no zerocopy notification is expected.
Mark destructor_arg as not-a-uarg by setting the lower bit to 1. The
resulting value is not a valid ubuf_info pointer, nor a valid
tpacket_snd frame address. Add skb_zcopy_.._nouarg helpers for this.
The fix relies on features introduced in commit 52267790ef52 ("sock:
add MSG_ZEROCOPY"), so can be backported as is only to 4.14.
Tested with from `./in_netns.sh ./txring_overwrite` from
http://github.com/wdebruij/kerneltools/tests
Fixes: 69e3c75f4d54 ("net: TX_RING and packet mmap")
Reported-by: Anand H. Krishnan <anandhkrishnan@gmail.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
commit 4d54954a197175c0dcb3c82af0c0740d0c5f827a upstream.
Tracing the event "fs_dax:dax_pmd_insert_mapping" with perf produces this
warning:
[fs_dax:dax_pmd_insert_mapping] unknown op '~'
It is printed in process_op (tools/lib/traceevent/event-parse.c) because
'~' is parsed as a binary operator.
perf reads the format of fs_dax:dax_pmd_insert_mapping ("print fmt") from
/sys/kernel/debug/tracing/events/fs_dax/dax_pmd_insert_mapping/format .
The format contains:
~(((u64) ~(~(((1UL) << 12)-1)))
\ interpreted as a binary operator by process_op().
This part is generated in the declaration of the event class
dax_pmd_insert_mapping_class in include/trace/events/fs_dax.h :
__print_flags_u64(__entry->pfn_val & PFN_FLAGS_MASK, "|",
PFN_FLAGS_TRACE),
This patch adds a pair of parentheses in the declaration of PFN_FLAGS_MASK
to make sure that '~' is parsed as a unary operator by perf.
The part of the format that was problematic is now:
~(((u64) (~(~(((1UL) << 12)-1))))
Now, all the '~' are parsed as unary operators.
Link: http://lkml.kernel.org/r/20181021145939.8760-1-sebhtml@videotron.qc.ca
Signed-off-by: Sebastien Boisvert <sebhtml@videotron.qc.ca>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: "Tzvetomir Stoyanov (VMware)" <tz.stoyanov@gmail.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Ross Zwisler <zwisler@kernel.org>
Cc: Elenie Godzaridis <arangradient@gmail.com>
Cc: <stable@vger.kerenl.org>
commit 007d1e8395eaa59b0e7ad9eb2b53a40859446a88 upstream.
FS_EVENT_ON_CHILD gets a special treatment in fsnotify() because it is
not a flag specifying an event type, but rather an extra flags that may
be reported along with another event and control the handling of the
event by the backend.
FS_ISDIR is also an "extra flag" and not an "event type" and therefore
desrves the same treatment. With inotify/dnotify backends it was never
possible to set FS_ISDIR in mark masks, so it did not matter.
With fanotify backend, mark adding code jumps through hoops to avoid
setting the FS_ISDIR in the commulative object mask.
Separate the constant ALL_FSNOTIFY_EVENTS to ALL_FSNOTIFY_FLAGS and
ALL_FSNOTIFY_EVENTS, so the latter can be used to test for specific
event types.
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
can_rx_offload_queue_tail()
commit 4530ec36bb1e0d24f41c33229694adacda3d5d89 upstream.
This function has nothing todo with error.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Cc: linux-stable <stable@vger.kernel.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
can_rx_offload_queue_sorted() functions
commit 55059f2b7f868cd43b3ad30e28e18347e1b46ace upstream.
Current CAN framework can't guarantee proper/chronological order
of RX and TX-ECHO messages. To make this possible, drivers should use
this functions instead of can_get_echo_skb().
__can_get_echo_skb()
commit a4310fa2f24687888ce80fdb0e88583561a23700 upstream.
This patch factors out all non sending parts of can_get_echo_skb() into
a seperate function __can_get_echo_skb(), so that it can be re-used in
an upcoming patch.
commit 8873c064d1de579ea23412a6d3eee972593f142b upstream.
syzkaller was able to hit the WARN_ON(sock_owned_by_user(sk));
in tcp_close()
While a socket is being closed, it is very possible other
threads find it in rtnetlink dump.
tcp_get_info() will acquire the socket lock for a short amount
of time (slow = lock_sock_fast(sk)/unlock_sock_fast(sk, slow);),
enough to trigger the warning.
Fixes: 67db3e4bfbc9 ("tcp: no longer hold ehash lock while calling tcp_get_info()")
Reported-by: syzbot <syzkaller@googlegroups.com>
commit 781f0766cc41a9dd2e5d118ef4b1d5d89430257b upstream.
Devices connected under Terminus Technology Inc. Hub (1a40:0101) may
fail to work after the system resumes from suspend:
[ 206.063325] usb 3-2.4: reset full-speed USB device number 4 using xhci_hcd
[ 206.143691] usb 3-2.4: device descriptor read/64, error -32
[ 206.351671] usb 3-2.4: device descriptor read/64, error -32
Info for this hub:
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1a40 ProdID=0101 Rev=01.11
S: Product=USB 2.0 Hub
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
Some expirements indicate that the USB devices connected to the hub are
innocent, it's the hub itself is to blame. The hub needs extra delay
time after it resets its port.
Hence wait for extra delay, if the device is connected to this quirky
hub.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 98ee3fc7ef8395f8b7a379e6608aee91efc66d48 ]
Function name is wrong in the kernel-doc header.
Fixes: 9c3736a3de21 ("mtd: nand: Add core infrastructure to deal with NAND devices")
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
[ Upstream commit 17b8b74c0f8dbf9b9e3301f9ca5b65dd1c079951 ]
The function is called when rcu_read_lock() is held and not
when rcu_read_lock_bh() is held.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
replace
[ Upstream commit 439cd39ea136d2c026805264d58a91f36b6b64ca ]
Commit 45040978c899 ("netfilter: ipset: Fix set:list type crash
when flush/dump set in parallel") postponed decreasing set
reference counters to the RCU callback.
An 'ipset del' command can terminate before the RCU grace period
is elapsed, and if sets are listed before then, the reference
counter shown in userspace will be wrong:
# ipset create h hash:ip; ipset create l list:set; ipset add l
# ipset del l h; ipset list h
Type: hash:ip
Revision: 4
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 88
References: 1
Number of entries: 0
Members:
# sleep 1; ipset list h
Type: hash:ip
Revision: 4
Size in memory: 88
References: 0
Members:
Fix this by making the reference count update synchronous again.
As a result, when sets are listed, ip_set_name_byindex() might
now fetch a set whose reference count is already zero. Instead
of relying on the reference count to protect against concurrent
set renaming, grab ip_set_ref_lock as reader and copy the name,
while holding the same lock in ip_set_rename() as writer
instead.
Reported-by: Li Shuang <shuali@redhat.com>
Fixes: 45040978c899 ("netfilter: ipset: Fix set:list type crash when flush/dump set in parallel")
[ Upstream commit 4269fea768a11a447d8de620ce420f2214d4685c ]
Laura found a better way to do this from userspace without requiring
kernel infrastructure, revert this.
Fixes: 978d8f9055c3 ("netfilter: nft_numgen: add map lookups for numgen random operations")
Signed-off-by: Laura Garcia Liebana <nevola@gmail.com>
[ Upstream commit 5a8de47b3c250521dd632cdedaac6db88367defa ]
With 4.19, programs like ebtables fail to build when they include
"linux/netfilter_bridge.h". It is caused by commit 94276fa8a2a4 which
added a use of INT_MIN and INT_MAX to the header:
: In file included from /usr/include/linux/netfilter_bridge/ebtables.h:18,
: from include/ebtables_u.h:28,
: from communication.c:23:
: /usr/include/linux/netfilter_bridge.h:30:20: error: 'INT_MIN' undeclared here (not in a function)
: NF_BR_PRI_FIRST = INT_MIN,
Define these constants by including "limits.h" when !__KERNEL__ (the
same way as for other netfilter_* headers).
Fixes: 94276fa8a2a4 ("netfilter: bridge: Expose nf_tables bridge hook priorities through uapi")
Acked-by: Máté Eckl <ecklm94@gmail.com>
This is the 4.19.4 stable release
[ Upstream commit fd82d61ba142f0b83463e47064bf5460aac57b6e ]
As defined in rfc6525#section-6.1.3, SCTP_STREAM_CHANGE_DENIED
and SCTP_STREAM_CHANGE_FAILED should be used instead of
SCTP_ASSOC_CHANGE_DENIED and SCTP_ASSOC_CHANGE_FAILED.
To keep the compatibility, fix it by adding two macros.
Fixes: b444153fb5a6 ("sctp: add support for generating add stream change event notification")
Reported-by: Jianwen Ji <jiji@redhat.com>
[ Upstream commit 12480e3b16982c4026de10dd8155823219cd6391 ]
According to rfc8260#section-4.3.2, SCTP_SS_DEFAULT is required to
defined as SCTP_SS_FCFS or SCTP_SS_RR.
SCTP_SS_FCFS is used for SCTP_SS_DEFAULT's value in this patch.
Fixes: 5bbbbe32a431 ("sctp: introduce stream scheduler foundations")
[ Upstream commit 69fec325a64383667b8a35df5d48d6ce52fb2782 ]
This reverts commit 22d7be267eaa8114dcc28d66c1c347f667d7878a.
The dst's mtu in transport can be updated by a non sctp place like
in xfrm where the MTU information didn't get synced between asoc,
transport and dst, so it is still needed to do the pmtu check
in sctp_packet_config.
This is the 4.19.3 stable release
commit f9005571701920551bcf54a500973fb61f2e1eda upstream.
xen_create_contiguous_region has now only an implementation if
CONFIG_XEN_PV is defined. However, on ARM we never set CONFIG_XEN_PV but
we do have an implementation of xen_create_contiguous_region which is
required for swiotlb-xen to work correctly (although it just sets
*dma_handle).
[backport: remove change to xen_remap_pfn]
Cc: <stable@vger.kernel.org> # 4.12
Fixes: 16624390816c ("xen: create xen_create/destroy_contiguous_region() stubs for PVHVM only builds")
Signed-off-by: Stefano Stabellini <stefanos@xilinx.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
CC: Jeff.Kubascik@dornerworks.com
CC: Jarvis.Roach@dornerworks.com
CC: Nathan.Studer@dornerworks.com
CC: vkuznets@redhat.com
CC: boris.ostrovsky@oracle.com
CC: jgross@suse.com
CC: julien.grall@arm.com
commit aba118389a6fb2ad7958de0f37b5869852bd38cf upstream.
Consistently use types provided by <linux/types.h> via <drm/drm.h>
to fix the following linux/kfd_ioctl.h userspace compilation errors:
/usr/include/linux/kfd_ioctl.h:250:2: error: unknown type name 'uint32_t'
uint32_t reset_type;
/usr/include/linux/kfd_ioctl.h:251:2: error: unknown type name 'uint32_t'
uint32_t reset_cause;
/usr/include/linux/kfd_ioctl.h:252:2: error: unknown type name 'uint32_t'
uint32_t memory_lost;
/usr/include/linux/kfd_ioctl.h:253:2: error: unknown type name 'uint32_t'
uint32_t gpu_id;
Fixes: 0c119abad7f0d ("drm/amd: Add kfd ioctl defines for hw_exception event")
Cc: <stable@vger.kernel.org> # v4.19
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Reviewed-by: Felix Kuehling <Felix.Kuehling@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 35b69a420bfb56b7b74cb635ea903db05e357bec upstream.
Add support for platforms where pit_shutdown() doesn't work because of a
quirk in the PIT emulation. On these platforms setting the counter register
to zero causes the PIT to start running again, negating the shutdown.
Provide a global variable that controls whether the counter register is
zero'ed, which platform specific code can override.
Signed-off-by: Michael Kelley <mikelley@microsoft.com>
Cc: "gregkh@linuxfoundation.org" <gregkh@linuxfoundation.org>
Cc: "devel@linuxdriverproject.org" <devel@linuxdriverproject.org>
Cc: "daniel.lezcano@linaro.org" <daniel.lezcano@linaro.org>
Cc: "virtualization@lists.linux-foundation.org" <virtualization@lists.linux-foundation.org>
Cc: "jgross@suse.com" <jgross@suse.com>
Cc: "akataria@vmware.com" <akataria@vmware.com>
Cc: "olaf@aepfle.de" <olaf@aepfle.de>
Cc: "apw@canonical.com" <apw@canonical.com>
Cc: vkuznets <vkuznets@redhat.com>
Cc: "jasowang@redhat.com" <jasowang@redhat.com>
Cc: "marcelo.cerri@canonical.com" <marcelo.cerri@canonical.com>
Cc: KY Srinivasan <kys@microsoft.com>
Link: https://lkml.kernel.org/r/1541303219-11142-2-git-send-email-mikelley@microsoft.com
