This patch includes some of the clk enable/disable changes from rev2
Check the version of the HDMI IP to determine whether the fifo
threshold needs to be high. The i.Mx6dl version of the HDMI doesn't
need the workaround. All other parts of the workaround are used
for both parts for code simplicity.
For i.Mxq, set the Threshold of audio fifo as: FIFO depth - 2 (fixed
and independent of the number of channels actually used).
Use unspecified length ahb bursts (using fixed INCRx will make the
audio dma fail).
Additionally and in order to get it working on all conditions it will
be necessary to run the following sw steps at startup of video and audio
(or when video changes or audio changes):
1-Configure AUD_N1 and AUD_CTS1 registers with final value and let the
AUD_N2, AUD_N3, AUD_CTS2 and AUD_CTS3 to 0s.
2-Configure start and end addresses of audio DMA registers.
3-Start DMA operation
4-Configure the AUD_CTS2 and AUD_CTS3 with the final value.
5-Configure the AUD_N2 and AUD_N3 with final value.
Signed-off-by: Alan Tull <r80115@freescale.com>
VPU needs 4K align buffer address for tiled format data output.
Use this macro for IPU/V4L2/Apps to calculate the frame/field size.
Signed-off-by: Wayne Zou <b36644@freescale.com>
Add a platform data to indicate whether the board support ONFI nand
Signed-off-by: Allen Xu <allen.xu@freescale.com>
Basic I2C module integration of AMFM module to ARD platform IMX6Q
and IMX6DL rev A and rev B boards. Supported for kernel 3.0.15.
Signed-off-by: Alejandro Sierra <b18039@freescale.com>
Add tiled format macros: IPU_PIX_FMT_TILED_NV12 and
IPU_PIX_FMT_TILED_NV12F
Delete unused variable busy_lock in mxc_asrc.h.
Signed-off-by: Chen Liangjun <b36089@freescale.com>
1. add amic and dmic support.
2. update wm8962 codec driver
Signed-off-by: Gary Zhang <b13634@freescale.com>
We observed a few commands timeout when using auto cmd23.
The root cause is still unkonwn.
This patch is a workaround to not use auto cmd23 temporarily.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
1 close clock when asrc is not working.
2 enable the asrc core clock when user sucessfully request an
ASRC pair and disable it when the pair is release.So the call
from ESAI using the p2p DMA mode can be support.
Add irq count to CPUFreq as a freq change condition.
Because some devices' working mode is unable to issue
CPUFreq change because of low CPU loading, but the cpu
freq will impact these devices' performace significantly.
Interactive govervor will sample the cpu loading as well
as the irq count which is registered. If the
loading or the irq count exceed the threshold we set,
governor will issue an CPUFreq change request.
These devices' irq threshold and enable/disable can be modified
via /sys/devices/system/cpu/cpufreq/interactive/irq_scaling
echo 0xAABBBC to change the default setting as below
AA : irq number
BBB: threshold
C :enable or disable
Currently only enable USDHC3, USDHC4, GPU, SATA and
USB by default, we can add device to the init struct which is
located in arch/arm/mach-mx6/irq.c.
Signed-off-by: Anson Huang <b20788@freescale.com>
cpufreq: interactive: New 'interactive' governor
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed.
Solve the ASRC noise:
1 change the DMA mode from normal mode to loop mode.
2 use dma_alloc_coherent alloc dma buffer instead of kzalloc.
head file part
Signed-off-by: Tony LIU <junjie.liu@freescale.com>
Since some power rail is differnet between pfuze100 0.1 and pfuze100 1.0,
remove PFUZE100_FIRST_VERSION and change PFUZE100_SW4_VOL6 define.
Signed-off-by: Robin Gong <b38343@freescale.com>
In order to know which wakeup event occurs for usb wakeup
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add discharge vbus flag
the patch is based on a series of patches by Per Forlin
the patch is sdhci host side implementation.
using a toshiba SDHC3.0 card, the performance increases
from 48.5MB/s to 52.4MB/s.
cmd: dd if=/dev/mmcblk0 of=/dev/null bs=1M count=500
the performance results running@1GHz, 200MHz CPU freq are:
52.4MB/s -> 20.7MB/s
Signed-off-by: Tony Lin <tony.lin@freescale.com>
Remove rst_gpio field to mxc_audio_platform_data.
Signed-off-by: Lionel Xu <Lionel.Xu@freescale.com>
Some host controllers will not operate without a hardware
timeout that is limited in value. However large discards
require large timeouts, so there needs to be a way to
specify the maximum discard size.
A host controller driver may now specify the maximum discard
timeout possible so that max_discard_sectors can be calculated.
However, for eMMC when the High Capacity Erase Group Size
is not in use, the timeout calculation depends on clock
rate which may change. For that case Preferred Erase Size
is used instead.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
If the MMC_SEND_STATUS command is not successful, we should not return
a zero status word, but instead allow the caller to know positively
that an error occurred.
Convert the open-coded get_card_status() to use the helper function,
and provide definitions for the card state field.
Tested-by: Pawel Moll <pawel.moll@arm.com>
Previously there has only been one function mmc_wait_for_req()
to start and wait for a request. This patch adds:
* mmc_start_req() - starts a request wihtout waiting
If there is on ongoing request wait for completion
of that request and start the new one and return.
Does not wait for the new command to complete.
This patch also adds new function members in struct mmc_host_ops
only called from core.c:
* pre_req - asks the host driver to prepare for the next job
* post_req - asks the host driver to clean up after a completed job
The intention is to use pre_req() and post_req() to do cache maintenance
while a request is active. pre_req() can be called while a request is
active to minimize latency to start next job. post_req() can be used after
the next job is started to clean up the request. This will minimize the
host driver request end latency. post_req() is typically used before
ending the block request and handing over the buffer to the block layer.
Add a host-private member in mmc_data to be used by pre_req to mark the
data. The host driver will then check this mark to see if the data is
prepared or not.
Signed-off-by: Per Forlin <per.forlin@linaro.org>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Venkatraman S <svenkatr@ti.com>
Tested-by: Sourav Poddar <sourav.poddar@ti.com>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
This was legacy code brought over from the RT tree and
is no longer necessary.
Signed-off-by: Dima Zavin <dima@android.com>
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com
- add hook for post tuning in common code
- add hook for post tuning for platform code to deal with clean up stuff on
finishing tuning.
Signed-off-by: Ryan QIAN <b32804@freescale.com>
In order to reflect the function well, it needs to discharge
both dp and dm, so change the function name.
* Add generic audio codec platform_data to be able to
pass specific settings to audio codecs found in Freescale
target boards.
* cs42888 get this platform data to override specific settings
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Don't show hdmi as an audio playback device if hdmi isn't
configured on the command line.
When use clk_enable and clk_disable function, system may enter
sleep. so these 2 funciton can not used surrounding with spin
lock/unlock. And the clk_enable/disable function already keep
the counter of open and close and it is no need to keep the counter
in driver.
Close ASRC core clock when ASRC device is not used.
Open ASRC core clock when an ASRC device is open. Close ASRC core
clock when an ASRC device is close.
- Added new register definitions for EPDCv2.0
- Added support for 64 LUTs
- Conditionalized code for EPDC versions 1.0, 2.0, and 2.1
- Support for EPDC auto-waveform selection
- Support for collision test mode
- Support for PxP bypassing
- Support for LUT cancellation
- Support for new PxP limitations
- Support for collision minimization EPDC feature
- Added workaround for collision status bug (can't clear
IRQ before reading collision status for LUTs 16-63)
Signed-off-by: Danny Nold <dannynold@freescale.com>
add ePxP v2 DMAENGINE driver
Signed-off-by: Robby Cai <R63905@freescale.com>
add this to support MX6Q_SABRESD board hardware design.
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
This reverts commit cc9616316bf044382ec422da5a6d4ed007235a3d.
head file
Add functionality to parse Audio Data Blocks from EDID data to
find out what modes of LPCM are suppored by the HDMI sink device.
The parsed settings are saved in the hdmi mfd. The HDMI audio driver
will check the settings when the audio stream is opened and will
then apply appropriate constraints.
If we are unable to read from the EDID, then we default to supporting
Basic Audio as defined by the HDMI specification (stereo, 16 bit,
32KHz, 44.1KHz, 48KHz PCM).
Add IOCTRL command V4L2_CID_MXC_SWITCH_CAM for multi camera switch
Signed-off-by: Yuxi Sun <b36102@freescale.com>
fix build error:
incompatible pointer type
- add macros and struct used in new ath6kl.
Add a new field to gpmi_nand_platform_data{}.
Make the BBT support to board specific.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Move the header to a more common place.
The mxs dma engine is not only used in mx23/mx28, but also used
in mx50/mx6q. It will also be used in the future chips.
rename it to mxs-dma.h
Acked-by: Lily Zhang <r58066@freescale.com>
ENGR152547-03 [MX6Q]add SDHC3.0 support on uSDHC controller
add voltage switch function due to SDHC3.0 spec requirement
add tuning function due to SDHC3.0 spec requirement
extend some functions to support SDR50 & SDR104 speed mode
- adjust the sequence of current_limit and bus_speed_mode
- add FSL specific tuning procedure
add the new macro to fix a compiling error.
Encapsulate last MTD partition parser argument into a separate
structure. Currently it holds only 'origin' field for RedBoot parser,
but will be extended in future to contain at least device_node for OF
devices.
Amended commentary to make kerneldoc happy
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
Lots (nearly all) mtd drivers contain nearly the similar code that
calls parse_mtd_partitions, provides some platform-default values, if
parsing fails, and registers mtd device.
This is an aim to provide single implementation of this scenario:
mtd_device_parse_register() which will handle all this parsing and
defaults.
Artem: amended comments
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
It's for migrating to generic clk framework API.
The helper functions help cases clk_enable/clk_disable is used
in non-atomic context.
For example, Call clk_enable in probe and clk_disable in remove.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
As discussed previously, there's the need on some platforms to run some
parts of clk_enable() in contexts which can schedule. The solution
which was agreed upon was to provide clk_prepare() and clk_unprepare()
to contain this parts, while clk_enable() and clk_disable() perform
the atomic part.
This patch provides a common definition for clk_prepare() and
clk_unprepare() in linux/clk.h, and provides an upgrade path for
existing implementation and drivers: drivers can start using
clk_prepare() and clk_unprepare() once this patch is merged without
having to wait for platform support. Platforms can then start to
provide these additional functions.
Eventually, HAVE_CLK_PREPARE will be removed from the kernel, and
everyone will have to provide these new APIs.
Acked-by: Saravana Kannan <skannan@codeaurora.org>
fixup usage of dma direction by introducing dma_transfer_direction,
this patch moves dma/drivers/* to use new enum
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Mika Westerberg <mika.westerberg@iki.fi>
Cc: H Hartley Sweeten <hartleys@visionengravers.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Zhang Wei <zw@zh-kernel.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Shawn Guo <shawn.guo@freescale.com>
Cc: Yong Wang <yong.y.wang@intel.com>
Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com>
Cc: Boojin Kim <boojin.kim@samsung.com>
Cc: Barry Song <Baohua.Song@csr.com>
Acked-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
Before dma_transfer_direction was introduced to replace
dma_data_direction, some dmaengine device uses DMA_NONE of
dma_data_direction for some talk with its client drivers.
The mxs-dma and its clients mxs-mmc and gpmi-nand are such case.
This patch adds DMA_TRANS_NONE to dma_transfer_direction and
migrate the DMA_NONE use in mxs-dma to it.
It also fixes the compile warning below.
CC drivers/dma/mxs-dma.o
drivers/dma/mxs-dma.c: In function ‘mxs_dma_prep_slave_sg’:
drivers/dma/mxs-dma.c:420:16: warning: comparison between ‘enum dma_transfer_direction’ and ‘enum dma_data_direction’
The implicit presence of module.h and all its sub-includes was
masking these implicit header usages:
include/linux/dmaengine.h:684: warning: 'struct page' declared inside parameter list
include/linux/dmaengine.h:684: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/dmaengine.h:687: warning: 'struct page' declared inside parameter list
include/linux/dmaengine.h:736:2: error: implicit declaration of function 'bitmap_zero'
With input from Stephen Rothwell <sfr@canb.auug.org.au>
