[ Upstream commit af9c5d2e3b355854ff0e4acfbfbfadcd5198a349 ]
compiletime_assert() uses __LINE__ to create a unique function name. This
means that if you have more than one BUILD_BUG_ON() in the same source
line (which can happen if they appear e.g. in a macro), then the error
message from the compiler might output the wrong condition.
For this source file:
#include <linux/build_bug.h>
#define macro() \
BUILD_BUG_ON(1); \
BUILD_BUG_ON(0);
void foo()
macro();
gcc would output:
./include/linux/compiler.h:350:38: error: call to `__compiletime_assert_9' declared with attribute error: BUILD_BUG_ON failed: 0
_compiletime_assert(condition, msg, __compiletime_assert_, __LINE__)
However, it was not the BUILD_BUG_ON(0) that failed, so it should say 1
instead of 0. With this patch, we use __COUNTER__ instead of __LINE__, so
each BUILD_BUG_ON() gets a different function name and the correct
condition is printed:
./include/linux/compiler.h:350:38: error: call to `__compiletime_assert_0' declared with attribute error: BUILD_BUG_ON failed: 1
_compiletime_assert(condition, msg, __compiletime_assert_, __COUNTER__)
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: Daniel Santos <daniel.santos@pobox.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: Joe Perches <joe@perches.com>
Link: http://lkml.kernel.org/r/20200331112637.25047-1-vegard.nossum@oracle.com
[ Upstream commit 7e2345200262e4a6056580f0231cccdaffc825f3 ]
"vm_committed_as.count" could be accessed concurrently as reported by
KCSAN,
BUG: KCSAN: data-race in __vm_enough_memory / percpu_counter_add_batch
write to 0xffffffff9451c538 of 8 bytes by task 65879 on cpu 35:
percpu_counter_add_batch+0x83/0xd0
percpu_counter_add_batch at lib/percpu_counter.c:91
__vm_enough_memory+0xb9/0x260
dup_mm+0x3a4/0x8f0
copy_process+0x2458/0x3240
_do_fork+0xaa/0x9f0
__do_sys_clone+0x125/0x160
__x64_sys_clone+0x70/0x90
do_syscall_64+0x91/0xb05
entry_SYSCALL_64_after_hwframe+0x49/0xbe
read to 0xffffffff9451c538 of 8 bytes by task 66773 on cpu 19:
__vm_enough_memory+0x199/0x260
percpu_counter_read_positive at include/linux/percpu_counter.h:81
(inlined by) __vm_enough_memory at mm/util.c:839
mmap_region+0x1b2/0xa10
do_mmap+0x45c/0x700
vm_mmap_pgoff+0xc0/0x130
ksys_mmap_pgoff+0x6e/0x300
__x64_sys_mmap+0x33/0x40
The read is outside percpu_counter::lock critical section which results in
a data race. Fix it by adding a READ_ONCE() in
percpu_counter_read_positive() which could also service as the existing
compiler memory barrier.
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Marco Elver <elver@google.com>
Link: http://lkml.kernel.org/r/1582302724-2804-1-git-send-email-cai@lca.pw
session
[ Upstream commit 57c46e9f33da530a2485fa01aa27b6d18c28c796 ]
A number of hangs have been reported against the target driver; they are
due to the fact that multiple threads may try to destroy the iscsi session
at the same time. This may be reproduced for example when a "targetcli
iscsi/iqn.../tpg1 disable" command is executed while a logout operation is
underway.
When this happens, two or more threads may end up sleeping and waiting for
iscsit_close_connection() to execute "complete(session_wait_comp)". Only
one of the threads will wake up and proceed to destroy the session
structure, the remaining threads will hang forever.
Note that if the blocked threads are somehow forced to wake up with
complete_all(), they will try to free the same iscsi session structure
destroyed by the first thread, causing double frees, memory corruptions
etc...
With this patch, the threads that want to destroy the iscsi session will
increase the session refcount and will set the "session_close" flag to 1;
then they wait for the driver to close the remaining active connections.
When the last connection is closed, iscsit_close_connection() will wake up
all the threads and will wait for the session's refcount to reach zero;
when this happens, iscsit_close_connection() will destroy the session
structure because no one is referencing it anymore.
INFO: task targetcli:5971 blocked for more than 120 seconds.
Tainted: P OE 4.15.0-72-generic #81~16.04.1
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
targetcli D 0 5971 1 0x00000080
Call Trace:
__schedule+0x3d6/0x8b0
? vprintk_func+0x44/0xe0
schedule+0x36/0x80
schedule_timeout+0x1db/0x370
? __dynamic_pr_debug+0x8a/0xb0
wait_for_completion+0xb4/0x140
? wake_up_q+0x70/0x70
iscsit_free_session+0x13d/0x1a0 [iscsi_target_mod]
iscsit_release_sessions_for_tpg+0x16b/0x1e0 [iscsi_target_mod]
iscsit_tpg_disable_portal_group+0xca/0x1c0 [iscsi_target_mod]
lio_target_tpg_enable_store+0x66/0xe0 [iscsi_target_mod]
configfs_write_file+0xb9/0x120
__vfs_write+0x1b/0x40
vfs_write+0xb8/0x1b0
SyS_write+0x5c/0xe0
do_syscall_64+0x73/0x130
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Link: https://lore.kernel.org/r/20200313170656.9716-3-mlombard@redhat.com
Reported-by: Matt Coleman <mcoleman@datto.com>
Tested-by: Matt Coleman <mcoleman@datto.com>
Tested-by: Rahul Kundu <rahul.kundu@chelsio.com>
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
[ Upstream commit 03e2a984b6165621f287fadf5f4b5cd8b58dcaba ]
The behaviour for what is considered an anycast address changed in
commit 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after
encountering pmtu exception"). This now considers the first
address in a subnet where there is a route via a gateway
to be an anycast address.
This breaks path MTU discovery and traceroutes when a host in a
remote network uses the address at the start of a prefix
(eg 2600:: advertised as 2600::/48 in the DFZ) as ICMP errors
will not be sent to anycast addresses.
This patch excludes any routes with a gateway, or via point to
point links, like the behaviour previously from
rt6_is_gw_or_nonexthop in net/ipv6/route.c.
This can be tested with:
ip link add v1 type veth peer name v2
ip netns add test
ip netns exec test ip link set lo up
ip link set v2 netns test
ip link set v1 up
ip netns exec test ip link set v2 up
ip addr add 2001:db8::1/64 dev v1 nodad
ip addr add 2001:db8:100:: dev lo nodad
ip netns exec test ip addr add 2001:db8::2/64 dev v2 nodad
ip netns exec test ip route add unreachable 2001:db8:1::1
ip netns exec test ip route add 2001:db8:100::/64 via 2001:db8::1
ip netns exec test sysctl net.ipv6.conf.all.forwarding=1
ip route add 2001:db8:1::1 via 2001:db8::2
ping -I 2001:db8::1 2001:db8:1::1 -c1
ping -I 2001:db8:100:: 2001:db8:1::1 -c1
ip addr delete 2001:db8:100:: dev lo
ip netns delete test
Currently the first ping will get back a destination unreachable ICMP
error, but the second will never get a response, with "icmp6_send:
acast source" logged. After this patch, both get destination
unreachable ICMP replies.
Fixes: 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after encountering pmtu exception")
Signed-off-by: Tim Stallard <code@timstallard.me.uk>
commit d1e7fd6462ca9fc76650fbe6ca800e35b24267da upstream.
Replace the 32bit exec_id with a 64bit exec_id to make it impossible
to wrap the exec_id counter. With care an attacker can cause exec_id
wrap and send arbitrary signals to a newly exec'd parent. This
bypasses the signal sending checks if the parent changes their
credentials during exec.
The severity of this problem can been seen that in my limited testing
of a 32bit exec_id it can take as little as 19s to exec 65536 times.
Which means that it can take as little as 14 days to wrap a 32bit
exec_id. Adam Zabrocki has succeeded wrapping the self_exe_id in 7
days. Even my slower timing is in the uptime of a typical server.
Which means self_exec_id is simply a speed bump today, and if exec
gets noticably faster self_exec_id won't even be a speed bump.
Extending self_exec_id to 64bits introduces a problem on 32bit
architectures where reading self_exec_id is no longer atomic and can
take two read instructions. Which means that is is possible to hit
a window where the read value of exec_id does not match the written
value. So with very lucky timing after this change this still
remains expoiltable.
I have updated the update of exec_id on exec to use WRITE_ONCE
and the read of exec_id in do_notify_parent to use READ_ONCE
to make it clear that there is no locking between these two
locations.
Link: https://lore.kernel.org/kernel-hardening/20200324215049.GA3710@pi3.com.pl
Fixes: 2.3.23pre2
Cc: stable@vger.kernel.org
commit 3f5b9959041e0db6dacbea80bb833bff5900999f upstream.
When CONFIG_DEVFREQ_THERMAL is disabled all functions except
of_devfreq_cooling_register_power() were already inlined. Also inline
the last function to avoid compile errors when multiple drivers call
of_devfreq_cooling_register_power() when CONFIG_DEVFREQ_THERMAL is not
set. Compilation failed with the following message:
multiple definition of `of_devfreq_cooling_register_power'
(which then lists all usages of of_devfreq_cooling_register_power())
Thomas Zimmermann reported this problem [0] on a kernel config with
CONFIG_DRM_LIMA={m,y}, CONFIG_DRM_PANFROST={m,y} and
CONFIG_DEVFREQ_THERMAL=n after both, the lima and panfrost drivers
gained devfreq cooling support.
[0] https://www.spinics.net/lists/dri-devel/msg252825.html
Fixes: a76caf55e5b356 ("thermal: Add devfreq cooling")
Reported-by: Thomas Zimmermann <tzimmermann@suse.de>
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Tested-by: Thomas Zimmermann <tzimmermann@suse.de>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Link: https://lore.kernel.org/r/20200403205133.1101808-1-martin.blumenstingl@googlemail.com
commit 9b6eaaf3db5e5888df7bca7fed7752a90f7fd871 upstream.
The BIT() macro definition is not available for the UAPI headers
(moreover, it can be defined differently in the user space); replace
its usage with the _BITUL() macro that is defined in <linux/const.h>.
Fixes: 237483aa5cf4 ("coresight: stm: adding driver for CoreSight STM component")
Signed-off-by: Eugene Syromiatnikov <esyr@redhat.com>
Cc: stable <stable@vger.kernel.org>
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: https://lore.kernel.org/r/20200324042213.GA10452@asgard.redhat.com
commit 2c935bc57221cc2edc787c72ea0e2d30cdcd3d5e upstream.
Since we need to change the implementation, stop exposing internals.
Provide kref_read() to read the current reference count; typically
used for debug messages.
Kills two anti-patterns:
atomic_read(&kref->refcount)
kref->refcount.counter
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
[only add kref_read() to kref.h for stable backports - gregkh]
commit f400991bf872debffb01c46da882dc97d7e3248e upstream.
vt_dont_switch is pure boolean, no need for whole char.
Link: https://lore.kernel.org/r/20200219073951.16151-6-jslaby@suse.cz
commit dce05aa6eec977f1472abed95ccd71276b9a3864 upstream.
Avoid global variables (namely sel_cons) by introducing vc_is_sel. It
checks whether the parameter is the current selection console. This will
help putting sel_cons to a struct later.
Link: https://lore.kernel.org/r/20200219073951.16151-1-jslaby@suse.cz
commit 8019ad13ef7f64be44d4f892af9c840179009254 upstream.
As reported by Jann, ihold() does not in fact guarantee inode
persistence. And instead of making it so, replace the usage of inode
pointers with a per boot, machine wide, unique inode identifier.
This sequence number is global, but shared (file backed) futexes are
rare enough that this should not become a performance issue.
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream.
Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in
__purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in
the vunmap() code-path. While this change was necessary to maintain
correctness on x86-32-pae kernels, it also adds additional cycles for
architectures that don't need it.
Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported
severe performance regressions in micro-benchmarks because it now also
calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But
the vmalloc_sync_all() implementation on x86-64 is only needed for newly
created mappings.
To avoid the unnecessary work on x86-64 and to gain the performance
back, split up vmalloc_sync_all() into two functions:
* vmalloc_sync_mappings(), and
* vmalloc_sync_unmappings()
Most call-sites to vmalloc_sync_all() only care about new mappings being
synchronized. The only exception is the new call-site added in the
above mentioned commit.
Shile Zhang directed us to a report of an 80% regression in reaim
throughput.
Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org
Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/
Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com
[ Upstream commit 611d779af7cad2b87487ff58e4931a90c20b113c ]
So far we have the unfortunate situation that mdio_bus_phy_may_suspend()
is called in suspend AND resume path, assuming that function result is
the same. After the original change this is no longer the case,
resulting in broken resume as reported by Geert.
To fix this call mdio_bus_phy_may_suspend() in the suspend path only,
and let the phy_device store the info whether it was suspended by
MDIO bus PM.
Fixes: 503ba7c69610 ("net: phy: Avoid multiple suspends")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 4c16d64ea04056f1b1b324ab6916019f6a064114 ]
Add missing netlink policy entry for FRA_TUN_ID.
Fixes: e7030878fc84 ("fib: Add fib rule match on tunnel id")
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
Reviewed-by: David Ahern <dsahern@gmail.com>
commit 9144d75e22cad3c89e6b2ccab551db9ee28d250a upstream.
net_dim.h has a rather useful extension to BITS_PER_BYTE to compute the
number of bits in a type (BITS_PER_BYTE * sizeof(T)), so promote the macro
to bitops.h, alongside BITS_PER_BYTE, for wider usage.
Link: http://lkml.kernel.org/r/20180706094458.14116-1-chris@chris-wilson.co.uk
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Andy Gospodarek <gospo@broadcom.com>
[only take the bitops.h portion for stable kernels - gregkh]
commit 84a4062632462c4320704fcdf8e99e89e94c0aba upstream.
We have a HID touch device that reports its opens and shorts test
results in HID buffers of size 8184 bytes. The maximum size of the HID
buffer is currently set to 4096 bytes, causing probe of this device to
fail. With this patch we increase the maximum size of the HID buffer to
8192 bytes, making device probe and acquisition of said buffers succeed.
Signed-off-by: Johan Korsnes <jkorsnes@cisco.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Armando Visconti <armando.visconti@st.com>
Cc: Jiri Kosina <jkosina@suse.cz>
commit 1dade3a7048ccfc675650cd2cf13d578b095e5fb upstream.
Sometimes it is useful to find the access_width field value in bytes and
not in bits so add a helper that can be used for this purpose.
Suggested-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: 4.16+ <stable@vger.kernel.org> # 4.16+
[ Upstream commit 8a9093c79863b58cc2f9874d7ae788f0d622a596 ]
tc flower rules that are based on src or dst port blocking are sometimes
ineffective due to uninitialized stack data. __skb_flow_dissect() extracts
ports from the skb for tc flower to match against. However, the port
dissection is not done when when the FLOW_DIS_IS_FRAGMENT bit is set in
key_control->flags. All callers of __skb_flow_dissect(), zero-out the
key_control field except for fl_classify() as used by the flower
classifier. Thus, the FLOW_DIS_IS_FRAGMENT may be set on entry to
__skb_flow_dissect(), since key_control is allocated on the stack
and may not be initialized.
Since key_basic and key_control are present for all flow keys, let's
make sure they are initialized.
Fixes: 62230715fd24 ("flow_dissector: do not dissect l4 ports for fragments")
Co-developed-by: Eric Dumazet <edumazet@google.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: Jason Baron <jbaron@akamai.com>
commit 10a663a1b15134a5a714aa515e11425a44d4fdf7 upstream.
device_shutdown() called from reboot or power_shutdown expect
all devices to be shutdown. Same is true for even ahci pci driver.
As no ahci shutdown function is implemented, the ata subsystem
always remains alive with DMA & interrupt support. File system
related calls should not be honored after device_shutdown().
So defining ahci pci driver shutdown to freeze hardware (mask
interrupt, stop DMA engine and free DMA resources).
Signed-off-by: Prabhakar Kushwaha <pkushwaha@marvell.com>
commit dfa9a5efe8b932a84b3b319250aa3ac60c20f876 upstream.
The rawmidi state flags (opened, append, active_sensing) are stored in
bit fields that can be potentially racy when concurrently accessed
without any locks. Although the current code should be fine, there is
also no any real benefit by keeping the bitfields for this kind of
short number of members.
This patch changes those bit fields flags to the simple bool fields.
There should be no size increase of the snd_rawmidi_substream by this
change.
Reported-by: syzbot+576cc007eb9f2c968200@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20200214111316.26939-4-tiwai@suse.de
a session"
commit 807b9515b7d044cf77df31f1af9d842a76ecd5cb upstream.
Since commit e9d3009cb936 introduced a regression and since the fix for
that regression was not perfect, revert this commit.
Link: https://marc.info/?l=target-devel&m=158157054906195
Cc: Rahul Kundu <rahul.kundu@chelsio.com>
Cc: Mike Marciniszyn <mike.marciniszyn@intel.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Reported-by: Dakshaja Uppalapati <dakshaja@chelsio.com>
Fixes: e9d3009cb936 ("scsi: target: iscsi: Wait for all commands to finish before freeing a session")
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit 860c8802ace14c646864795e057349c9fb2d60ad ]
Eric Dumazet supplied a KCSAN report of a bug that forces use
of hlist_unhashed_lockless() from sk_unhashed():
BUG: KCSAN: data-race in inet_unhash / inet_unhash
write to 0xffff8880a69a0170 of 8 bytes by interrupt on cpu 1:
__hlist_nulls_del include/linux/list_nulls.h:88 [inline]
hlist_nulls_del_init_rcu include/linux/rculist_nulls.h:36 [inline]
__sk_nulls_del_node_init_rcu include/net/sock.h:676 [inline]
inet_unhash+0x38f/0x4a0 net/ipv4/inet_hashtables.c:612
tcp_set_state+0xfa/0x3e0 net/ipv4/tcp.c:2249
tcp_done+0x93/0x1e0 net/ipv4/tcp.c:3854
tcp_write_err+0x7e/0xc0 net/ipv4/tcp_timer.c:56
tcp_retransmit_timer+0x9b8/0x16d0 net/ipv4/tcp_timer.c:479
tcp_write_timer_handler+0x42d/0x510 net/ipv4/tcp_timer.c:599
tcp_write_timer+0xd1/0xf0 net/ipv4/tcp_timer.c:619
call_timer_fn+0x5f/0x2f0 kernel/time/timer.c:1404
expire_timers kernel/time/timer.c:1449 [inline]
__run_timers kernel/time/timer.c:1773 [inline]
__run_timers kernel/time/timer.c:1740 [inline]
run_timer_softirq+0xc0c/0xcd0 kernel/time/timer.c:1786
__do_softirq+0x115/0x33f kernel/softirq.c:292
invoke_softirq kernel/softirq.c:373 [inline]
irq_exit+0xbb/0xe0 kernel/softirq.c:413
exiting_irq arch/x86/include/asm/apic.h:536 [inline]
smp_apic_timer_interrupt+0xe6/0x280 arch/x86/kernel/apic/apic.c:1137
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:830
native_safe_halt+0xe/0x10 arch/x86/kernel/paravirt.c:71
arch_cpu_idle+0x1f/0x30 arch/x86/kernel/process.c:571
default_idle_call+0x1e/0x40 kernel/sched/idle.c:94
cpuidle_idle_call kernel/sched/idle.c:154 [inline]
do_idle+0x1af/0x280 kernel/sched/idle.c:263
cpu_startup_entry+0x1b/0x20 kernel/sched/idle.c:355
start_secondary+0x208/0x260 arch/x86/kernel/smpboot.c:264
secondary_startup_64+0xa4/0xb0 arch/x86/kernel/head_64.S:241
read to 0xffff8880a69a0170 of 8 bytes by interrupt on cpu 0:
sk_unhashed include/net/sock.h:607 [inline]
inet_unhash+0x3d/0x4a0 net/ipv4/inet_hashtables.c:592
rest_init+0xec/0xf6 init/main.c:452
arch_call_rest_init+0x17/0x37
start_kernel+0x838/0x85e init/main.c:786
x86_64_start_reservations+0x29/0x2b arch/x86/kernel/head64.c:490
x86_64_start_kernel+0x72/0x76 arch/x86/kernel/head64.c:471
Reported by Kernel Concurrency Sanitizer on:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.0-rc6+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine,
BIOS Google 01/01/2011
This commit therefore replaces C-language assignments with WRITE_ONCE()
in include/linux/list_nulls.h and include/linux/rculist_nulls.h.
Reported-by: Eric Dumazet <edumazet@google.com> # For KCSAN
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
macros
[ Upstream commit afb34781620274236bd9fc9246e22f6963ef5262 ]
When building with Clang + -Wtautological-constant-compare, several of
the ivtv and cx18 drivers warn along the lines of:
drivers/media/pci/cx18/cx18-driver.c:1005:21: warning: converting the
result of '<<' to a boolean always evaluates to true
[-Wtautological-constant-compare]
cx18_call_hw(cx, CX18_HW_GPIO_RESET_CTRL,
drivers/media/pci/cx18/cx18-cards.h:18:37: note: expanded from macro
'CX18_HW_GPIO_RESET_CTRL'
#define CX18_HW_GPIO_RESET_CTRL (1 << 6)
1 warning generated.
This warning happens because the shift operation is implicitly converted
to a boolean in v4l2_device_mask_call_all before being negated. This can
be solved by just comparing the mask result to 0 explicitly so that
there is no boolean conversion. The ultimate goal is to enable
-Wtautological-compare globally because there are several subwarnings
that would be helpful to have.
For visual consistency and avoidance of these warnings in the future,
all of the implicitly boolean conversions in the v4l2_device macros
are converted to explicit ones as well.
Link: https://github.com/ClangBuiltLinux/linux/issues/752
Reviewed-by: Ezequiel Garcia <ezequiel@collabora.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
commit f51e50db4c20d46930b33be3f208851265694f3e upstream.
boundary->width and boundary->height are sizes relative to
boundary->left and boundary->top coordinates, but they were not being
taken into consideration to adjust r->left and r->top, leading to the
following error:
Consider the follow as initial values for boundary and r:
struct v4l2_rect boundary = {
.left = 100,
.top = 100,
.width = 800,
.height = 600,
struct v4l2_rect r = {
.left = 0,
.top = 0,
.width = 1920,
.height = 960,
calling v4l2_rect_map_inside(&r, &boundary) was modifying r to:
r = {
.left = 0,
.top = 0,
.width = 800,
.height = 600,
Which is wrongly outside the boundary rectangle, because:
v4l2_rect_set_max_size(r, boundary); // r->width = 800, r->height = 600
if (r->left + r->width > boundary->width) // true
r->left = boundary->width - r->width; // r->left = 800 - 800
if (r->top + r->height > boundary->height) // true
r->top = boundary->height - r->height; // r->height = 600 - 600
Fix this by considering top/left coordinates from boundary.
Fixes: ac49de8c49d7 ("[media] v4l2-rect.h: new header with struct v4l2_rect helper functions")
Signed-off-by: Helen Koike <helen.koike@collabora.com>
Cc: <stable@vger.kernel.org> # for v4.7 and up
commit 17a0184ca17e288decdca8b2841531e34d49285f upstream.
Commit e0d795e4f36c ("usb: irda: cleanup on ir-usb module") added a USB
IrDA header with common defines, but mistakingly switched to using the
class-descriptor baud-rate bitmask values for the outbound header.
This broke link-speed handling for rates above 9600 baud, but a device
would also be able to operate at the default 9600 baud until a
link-speed request was issued (e.g. using the TCGETS ioctl).
Fixes: e0d795e4f36c ("usb: irda: cleanup on ir-usb module")
Cc: stable <stable@vger.kernel.org> # 2.6.27
Cc: Felipe Balbi <balbi@kernel.org>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 32c72165dbd0e246e69d16a3ad348a4851afd415 upstream.
The bitmap allocation did not use full unsigned long sizes
when calculating the required size and that was triggered by KASAN
as slab-out-of-bounds read in several places. The patch fixes all
of them.
Reported-by: syzbot+fabca5cbf5e54f3fe2de@syzkaller.appspotmail.com
Reported-by: syzbot+827ced406c9a1d9570ed@syzkaller.appspotmail.com
Reported-by: syzbot+190d63957b22ef673ea5@syzkaller.appspotmail.com
Reported-by: syzbot+dfccdb2bdb4a12ad425e@syzkaller.appspotmail.com
Reported-by: syzbot+df0d0f5895ef1f41a65b@syzkaller.appspotmail.com
Reported-by: syzbot+b08bd19bb37513357fd4@syzkaller.appspotmail.com
Reported-by: syzbot+53cdd0ec0bbabd53370a@syzkaller.appspotmail.com
Signed-off-by: Jozsef Kadlecsik <kadlec@netfilter.org>
commit c42b65e363ce97a828f81b59033c3558f8fa7f70 upstream.
A lot of code become ugly because of open coding allocations for bitmaps.
Introduce three helpers to allow users be more clear of intention
and keep their code neat.
Note, due to multiple circular dependencies we may not provide
the helpers as inliners. For now we keep them exported and, perhaps,
at some point in the future we will sort out header inclusion and
inheritance.
commit d0695e2351102affd8efae83989056bc4b275917 upstream.
Just as commit 0566e40ce7 ("tracing: initcall: Ordered comparison of
function pointers"), this patch fixes another remaining one in xen.h
found by clang-9.
In file included from arch/x86/xen/trace.c:21:
In file included from ./include/trace/events/xen.h:475:
In file included from ./include/trace/define_trace.h:102:
In file included from ./include/trace/trace_events.h:473:
./include/trace/events/xen.h:69:7: warning: ordered comparison of function \
pointers ('xen_mc_callback_fn_t' (aka 'void (*)(void *)') and 'xen_mc_callback_fn_t') [-Wordered-compare-function-pointers]
__field(xen_mc_callback_fn_t, fn)
./include/trace/trace_events.h:421:29: note: expanded from macro '__field'
./include/trace/trace_events.h:407:6: note: expanded from macro '__field_ext'
is_signed_type(type), filter_type); \
./include/linux/trace_events.h:554:44: note: expanded from macro 'is_signed_type'
Fixes: c796f213a6934 ("xen/trace: add multicall tracing")
Signed-off-by: Changbin Du <changbin.du@gmail.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 19cab8872692960535aa6d12e3a295ac51d1a648 upstream.
Commit 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
deprecated the ethtool_cmd::transceiver field, which was fine in
premise, except that the PHY library was actually using it to report the
type of transceiver: internal or external.
Use the first word of the reserved field to put this __u8 transceiver
field back in. It is made read-only, and we don't expect the
ETHTOOL_xLINKSETTINGS API to be doing anything with this anyway, so this
is mostly for the legacy path where we do:
ethtool_get_settings()
-> dev->ethtool_ops->get_link_ksettings()
-> convert_link_ksettings_to_legacy_settings()
to have no information loss compared to the legacy get_settings API.
Fixes: 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit bd73dfabdda280fc5f05bdec79b6721b4b2f035f ]
Illegal memory will be touch if SDMA_SCRIPT_ADDRS_ARRAY_SIZE_V3
(41) exceed the size of structure sdma_script_start_addrs(40),
thus cause memory corrupt such as slob block header so that kernel
trap into while() loop forever in slob_free(). Please refer to below
code piece in imx-sdma.c:
for (i = 0; i < sdma->script_number; i++)
if (addr_arr[i] > 0)
saddr_arr[i] = addr_arr[i]; /* memory corrupt here */
That issue was brought by commit a572460be9cf ("dmaengine: imx-sdma: Add
support for version 3 firmware") because SDMA_SCRIPT_ADDRS_ARRAY_SIZE_V3
(38->41 3 scripts added) not align with script number added in
sdma_script_start_addrs(2 scripts).
Fixes: a572460be9cf ("dmaengine: imx-sdma: Add support for version 3 firmware")
Link: https://www.spinics.net/lists/arm-kernel/msg754895.html
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reported-by: Jurgen Lambrecht <J.Lambrecht@TELEVIC.com>
Link: https://lore.kernel.org/r/1569347584-3478-1-git-send-email-yibin.gong@nxp.com
[vkoul: update the patch title]
Signed-off-by: Vinod Koul <vkoul@kernel.org>
[ Upstream commit 33da8e7c814f77310250bb54a9db36a44c5de784 ]
My recent to change to only use force_sig for a synchronous events
wound up breaking signal reception cifs and drbd. I had overlooked
the fact that by default kthreads start out with all signals set to
SIG_IGN. So a change I thought was safe turned out to have made it
impossible for those kernel thread to catch their signals.
Reverting the work on force_sig is a bad idea because what the code
was doing was very much a misuse of force_sig. As the way force_sig
ultimately allowed the signal to happen was to change the signal
handler to SIG_DFL. Which after the first signal will allow userspace
to send signals to these kernel threads. At least for
wake_ack_receiver in drbd that does not appear actively wrong.
So correct this problem by adding allow_kernel_signal that will allow
signals whose siginfo reports they were sent by the kernel through,
but will not allow userspace generated signals, and update cifs and
drbd to call allow_kernel_signal in an appropriate place so that their
thread can receive this signal.
Fixing things this way ensures that userspace won't be able to send
signals and cause problems, that it is clear which signals the
threads are expecting to receive, and it guarantees that nothing
else in the system will be affected.
This change was partly inspired by similar cifs and drbd patches that
added allow_signal.
Reported-by: ronnie sahlberg <ronniesahlberg@gmail.com>
Reported-by: Christoph Böhmwalder <christoph.boehmwalder@linbit.com>
Tested-by: Christoph Böhmwalder <christoph.boehmwalder@linbit.com>
Cc: Steve French <smfrench@gmail.com>
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Fixes: 247bc9470b1e ("cifs: fix rmmod regression in cifs.ko caused by force_sig changes")
Fixes: 72abe3bcf091 ("signal/cifs: Fix cifs_put_tcp_session to call send_sig instead of force_sig")
Fixes: fee109901f39 ("signal/drbd: Use send_sig not force_sig")
Fixes: 3cf5d076fb4d ("signal: Remove task parameter from force_sig")
[ Upstream commit ea77388b02270b0af8dc57f668f311235ea068f0 ]
Remove the "reserved_at_40" field to match the device specification.
Fixes: 84df61ebc69b ("net/mlx5: Add HW interfaces used by LAG")
Signed-off-by: Mark Zhang <markz@mellanox.com>
Reviewed-by: Yishai Hadas <yishaih@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit 9dea44c91469512d346e638694c22c30a5273992 ]
devm_ioremap_resource() does not currently take 'const' arguments,
which results in a warning from the first driver trying to do it
anyway:
drivers/gpio/gpio-amd-fch.c: In function 'amd_fch_gpio_probe':
drivers/gpio/gpio-amd-fch.c:171:49: error: passing argument 2 of 'devm_ioremap_resource' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
priv->base = devm_ioremap_resource(&pdev->dev, &amd_fch_gpio_iores);
Change the prototype to allow it, as there is no real reason not to.
Fixes: 9bb2e0452508 ("gpio: amd: Make resource struct const")
Link: https://lore.kernel.org/r/20190628150049.1108048-1-arnd@arndb.de
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviwed-By: Enrico Weigelt <info@metux.net>
[ Upstream commit b72845ee5577b227131b1fef23f9d9a296621d7b ]
In vpbe_enum_outputs() we check if (temp_index >= cfg->num_outputs) but
the problem is that "temp_index" can be negative. This patch changes
the types to unsigned to address this array underflow bug.
Fixes: 66715cdc3224 ("[media] davinci vpbe: VPBE display driver")
Acked-by: "Lad, Prabhakar" <prabhakar.csengg@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
commit 458ea3ad033fc86e291712ce50cbe60c3428cf30 upstream.
Those regulators are not actually supported by the AB8500 regulator
driver. There is no ab8500_regulator_info for them and no entry in
ab8505_regulator_match.
As such, they cannot be registered successfully, and looking them
up in ab8505_regulator_match causes an out-of-bounds array read.
Fixes: 547f384f33db ("regulator: ab8500: add support for ab8505")
Cc: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Link: https://lore.kernel.org/r/20191106173125.14496-2-stephan@gerhold.net
Signed-off-by: Mark Brown <broonie@kernel.org>
commit ad6bf88a6c19a39fb3b0045d78ea880325dfcf15 upstream.
Logical block size has type unsigned short. That means that it can be at
most 32768. However, there are architectures that can run with 64k pages
(for example arm64) and on these architectures, it may be possible to
create block devices with 64k block size.
For exmaple (run this on an architecture with 64k pages):
Mount will fail with this error because it tries to read the superblock using 2-sector
access:
device-mapper: writecache: I/O is not aligned, sector 2, size 1024, block size 65536
EXT4-fs (dm-0): unable to read superblock
This patch changes the logical block size from unsigned short to unsigned
int to avoid the overflow.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 4881873f4cc1460f63d85fa81363d56be328ccdc upstream.
According to the public S805 datasheet the RESET2 register uses the
following bits for the PIC_DC, PSC and NAND reset lines:
- PIC_DC is at bit 3 (meaning: RESET_VD_RMEM + 3)
- PSC is at bit 4 (meaning: RESET_VD_RMEM + 4)
- NAND is at bit 5 (meaning: RESET_VD_RMEM + 4)
Update the reset IDs of these three reset lines so they don't conflict
with PIC_DC and map to the actual hardware reset lines.
Fixes: 79795e20a184eb ("dt-bindings: reset: Add bindings for the Meson SoC Reset Controller")
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit 30ca1aa536211f5ac3de0173513a7a99a98a97f3 upstream.
Make ieee80211_send_layer2_update() a common function so other drivers
can re-use it.
Signed-off-by: Dedy Lansky <dlansky@codeaurora.org>
[bwh: Backported to 4.9 as dependency of commit 3e493173b784
"mac80211: Do not send Layer 2 Update frame before authorization":
- Retain type-casting of skb_put() return value
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ad312f95d41c9de19313c51e388c4984451c010f upstream.
The select() implementation is carefully tuned to put a sensible amount
of data on the stack for holding a copy of the user space fd_set, but
not too large to risk overflowing the kernel stack.
When building a 32-bit kernel with clang, we need a little more space
than with gcc, which often triggers a warning:
fs/select.c:619:5: error: stack frame size of 1048 bytes in function 'core_sys_select' [-Werror,-Wframe-larger-than=]
int core_sys_select(int n, fd_set __user *inp, fd_set __user *outp,
I experimentally found that for 32-bit ARM, reducing the maximum stack
usage by 64 bytes keeps us reliably under the warning limit again.
Link: http://lkml.kernel.org/r/20190307090146.1874906-1-arnd@arndb.de
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
CAN sk_buffs
commit e7153bf70c3496bac00e7e4f395bb8d8394ac0ea upstream.
KMSAN sysbot detected a read access to an untinitialized value in the
headroom of an outgoing CAN related sk_buff. When using CAN sockets this
area is filled appropriately - but when using a packet socket this
initialization is missing.
The problematic read access occurs in the CAN receive path which can
only be triggered when the sk_buff is sent through a (virtual) CAN
interface. So we check in the sending path whether we need to perform
the missing initializations.
Fixes: d3b58c47d330d ("can: replace timestamp as unique skb attribute")
Reported-by: syzbot+b02ff0707a97e4e79ebb@syzkaller.appspotmail.com
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: linux-stable <stable@vger.kernel.org> # >= v4.1
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit c70c176ff8c3ff0ac6ef9a831cd591ea9a66bd1a upstream.
Make the function available for outside use and fortify it against NULL
kobject.
CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 96cc4b69581db68efc9749ef32e9cf8e0160c509 ]
Use of eth_hdr() in tx path is error prone.
Many drivers call skb_reset_mac_header() before using it,
but others do not.
Commit 6d1ccff62780 ("net: reset mac header in dev_start_xmit()")
attempted to fix this generically, but commit d346a3fae3ff
("packet: introduce PACKET_QDISC_BYPASS socket option") brought
back the macvlan bug.
Lets add a new helper, so that tx paths no longer have
to call skb_reset_mac_header() only to get a pointer
to skb->data.
Hopefully we will be able to revert 6d1ccff62780
("net: reset mac header in dev_start_xmit()") and save few cycles
in transmit fast path.
BUG: KASAN: use-after-free in __get_unaligned_cpu32 include/linux/unaligned/packed_struct.h:19 [inline]
BUG: KASAN: use-after-free in mc_hash drivers/net/macvlan.c:251 [inline]
BUG: KASAN: use-after-free in macvlan_broadcast+0x547/0x620 drivers/net/macvlan.c:277
Read of size 4 at addr ffff8880a4932401 by task syz-executor947/9579
CPU: 0 PID: 9579 Comm: syz-executor947 Not tainted 5.5.0-rc4-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x197/0x210 lib/dump_stack.c:118
print_address_description.constprop.0.cold+0xd4/0x30b mm/kasan/report.c:374
__kasan_report.cold+0x1b/0x41 mm/kasan/report.c:506
kasan_report+0x12/0x20 mm/kasan/common.c:639
__asan_report_load_n_noabort+0xf/0x20 mm/kasan/generic_report.c:145
macvlan_queue_xmit drivers/net/macvlan.c:520 [inline]
macvlan_start_xmit+0x402/0x77f drivers/net/macvlan.c:559
__netdev_start_xmit include/linux/netdevice.h:4447 [inline]
netdev_start_xmit include/linux/netdevice.h:4461 [inline]
dev_direct_xmit+0x419/0x630 net/core/dev.c:4079
packet_direct_xmit+0x1a9/0x250 net/packet/af_packet.c:240
packet_snd net/packet/af_packet.c:2966 [inline]
packet_sendmsg+0x260d/0x6220 net/packet/af_packet.c:2991
sock_sendmsg_nosec net/socket.c:639 [inline]
sock_sendmsg+0xd7/0x130 net/socket.c:659
__sys_sendto+0x262/0x380 net/socket.c:1985
__do_sys_sendto net/socket.c:1997 [inline]
__se_sys_sendto net/socket.c:1993 [inline]
__x64_sys_sendto+0xe1/0x1a0 net/socket.c:1993
do_syscall_64+0xfa/0x790 arch/x86/entry/common.c:294
RIP: 0033:0x442639
Code: 18 89 d0 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 5b 10 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007ffc13549e08 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000442639
RDX: 000000000000000e RSI: 0000000020000080 RDI: 0000000000000003
RBP: 0000000000000004 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000403bb0 R14: 0000000000000000 R15: 0000000000000000
Allocated by task 9389:
save_stack+0x23/0x90 mm/kasan/common.c:72
set_track mm/kasan/common.c:80 [inline]
__kasan_kmalloc mm/kasan/common.c:513 [inline]
__kasan_kmalloc.constprop.0+0xcf/0xe0 mm/kasan/common.c:486
kasan_kmalloc+0x9/0x10 mm/kasan/common.c:527
__do_kmalloc mm/slab.c:3656 [inline]
__kmalloc+0x163/0x770 mm/slab.c:3665
kmalloc include/linux/slab.h:561 [inline]
tomoyo_realpath_from_path+0xc5/0x660 security/tomoyo/realpath.c:252
tomoyo_get_realpath security/tomoyo/file.c:151 [inline]
tomoyo_path_perm+0x230/0x430 security/tomoyo/file.c:822
tomoyo_inode_getattr+0x1d/0x30 security/tomoyo/tomoyo.c:129
security_inode_getattr+0xf2/0x150 security/security.c:1222
vfs_getattr+0x25/0x70 fs/stat.c:115
vfs_statx_fd+0x71/0xc0 fs/stat.c:145
vfs_fstat include/linux/fs.h:3265 [inline]
__do_sys_newfstat+0x9b/0x120 fs/stat.c:378
__se_sys_newfstat fs/stat.c:375 [inline]
__x64_sys_newfstat+0x54/0x80 fs/stat.c:375
Freed by task 9389:
kasan_set_free_info mm/kasan/common.c:335 [inline]
__kasan_slab_free+0x102/0x150 mm/kasan/common.c:474
kasan_slab_free+0xe/0x10 mm/kasan/common.c:483
__cache_free mm/slab.c:3426 [inline]
kfree+0x10a/0x2c0 mm/slab.c:3757
tomoyo_realpath_from_path+0x1a7/0x660 security/tomoyo/realpath.c:289
The buggy address belongs to the object at ffff8880a4932000
which belongs to the cache kmalloc-4k of size 4096
The buggy address is located 1025 bytes inside of
4096-byte region [ffff8880a4932000, ffff8880a4933000)
The buggy address belongs to the page:
page:ffffea0002924c80 refcount:1 mapcount:0 mapping:ffff8880aa402000 index:0x0 compound_mapcount: 0
raw: 00fffe0000010200 ffffea0002846208 ffffea00028f3888 ffff8880aa402000
raw: 0000000000000000 ffff8880a4932000 0000000100000001 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8880a4932300: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8880a4932380: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8880a4932400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8880a4932480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8880a4932500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: b863ceb7ddce ("[NET]: Add macvlan driver")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 164166558aacea01b99c8c8ffb710d930405ba69 ]
With 'bytes(__u32)' being 32, a left-shift of 31 may happen which is
undefined for the signed 32-bit value 1. Avoid this by declaring 1 as
unsigned.
Signed-off-by: Phil Sutter <phil@nwl.cc>
[ Upstream commit c305c6ae79e2ce20c22660ceda94f0d86d639a82 ]
KCSAN reported a data-race [1]
While we can use READ_ONCE() on the read sides,
we need to make sure hh->hh_len is written last.
[1]
BUG: KCSAN: data-race in eth_header_cache / neigh_resolve_output
write to 0xffff8880b9dedcb8 of 4 bytes by task 29760 on cpu 0:
eth_header_cache+0xa9/0xd0 net/ethernet/eth.c:247
neigh_hh_init net/core/neighbour.c:1463 [inline]
neigh_resolve_output net/core/neighbour.c:1480 [inline]
neigh_resolve_output+0x415/0x470 net/core/neighbour.c:1470
neigh_output include/net/neighbour.h:511 [inline]
ip6_finish_output2+0x7a2/0xec0 net/ipv6/ip6_output.c:116
__ip6_finish_output net/ipv6/ip6_output.c:142 [inline]
__ip6_finish_output+0x2d7/0x330 net/ipv6/ip6_output.c:127
ip6_finish_output+0x41/0x160 net/ipv6/ip6_output.c:152
NF_HOOK_COND include/linux/netfilter.h:294 [inline]
ip6_output+0xf2/0x280 net/ipv6/ip6_output.c:175
dst_output include/net/dst.h:436 [inline]
NF_HOOK include/linux/netfilter.h:305 [inline]
ndisc_send_skb+0x459/0x5f0 net/ipv6/ndisc.c:505
ndisc_send_ns+0x207/0x430 net/ipv6/ndisc.c:647
rt6_probe_deferred+0x98/0xf0 net/ipv6/route.c:615
process_one_work+0x3d4/0x890 kernel/workqueue.c:2269
worker_thread+0xa0/0x800 kernel/workqueue.c:2415
kthread+0x1d4/0x200 drivers/block/aoe/aoecmd.c:1253
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:352
read to 0xffff8880b9dedcb8 of 4 bytes by task 29572 on cpu 1:
neigh_resolve_output net/core/neighbour.c:1479 [inline]
neigh_resolve_output+0x113/0x470 net/core/neighbour.c:1470
CPU: 1 PID: 29572 Comm: kworker/1:4 Not tainted 5.4.0-rc6+ #0
Workqueue: events rt6_probe_deferred
commit 99c4f70df3a6446c56ca817c2d0f9c12d85d4e7c upstream.
The USB regulator was removed for AB8500 in
commit 41a06aa738ad ("regulator: ab8500: Remove USB regulator").
It was then added for AB8505 in
commit 547f384f33db ("regulator: ab8500: add support for ab8505").
However, there was never an entry added for it in
ab8505_regulator_match. This causes all regulators after it
to be initialized with the wrong device tree data, eventually
leading to an out-of-bounds array read.
Given that it is not used anywhere in the kernel, it seems
likely that similar arguments against supporting it exist for
AB8505 (it is controlled by hardware).
Therefore, simply remove it like for AB8500 instead of adding
an entry in ab8505_regulator_match.
Link: https://lore.kernel.org/r/20191106173125.14496-1-stephan@gerhold.net
commit 84b032dbfdf1c139cd2b864e43959510646975f8 upstream.
This reverts commit 6bb86fefa086faba7b60bb452300b76a47cde1a5
("libahci_platform: Staticize ahci_platform_<en/dis>able_phys()") we are
going to need ahci_platform_{enable,disable}_phys() in a subsequent
commit for ahci_brcm.c in order to properly control the PHY
initialization order.
Also make sure the function prototypes are declared in
include/linux/ahci_platform.h as a result.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit 53a256a9b925b47c7e67fc1f16ca41561a7b877c upstream.
dmaengine_desc_set_reuse() allocates a struct dma_slave_caps on the
stack, populates it using dma_get_slave_caps() and then accesses one
of its members.
However dma_get_slave_caps() may fail and this isn't accounted for,
leading to a legitimate warning of gcc-4.9 (but not newer versions):
In file included from drivers/spi/spi-bcm2835.c:19:0:
drivers/spi/spi-bcm2835.c: In function 'dmaengine_desc_set_reuse':
>> include/linux/dmaengine.h:1370:10: warning: 'caps.descriptor_reuse' is used uninitialized in this function [-Wuninitialized]
if (caps.descriptor_reuse) {
Fix it, thereby also silencing the gcc-4.9 warning.
The issue has been present for 4 years but surfaces only now that
the first caller of dmaengine_desc_set_reuse() has been added in
spi-bcm2835.c. Another user of reusable DMA descriptors has existed
for a while in pxa_camera.c, but it sets the DMA_CTRL_REUSE flag
directly instead of calling dmaengine_desc_set_reuse(). Nevertheless,
tag this commit for stable in case there are out-of-tree users.
Fixes: 272420214d26 ("dmaengine: Add DMA_CTRL_REUSE")
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: stable@vger.kernel.org # v4.3+
Link: https://lore.kernel.org/r/ca92998ccc054b4f2bfd60ef3adbab2913171eac.1575546234.git.lukas@wunner.de
commit 8dbd76e79a16b45b2ccb01d2f2e08dbf64e71e40 upstream.
Michal Kubecek and Firo Yang did a very nice analysis of crashes
happening in __inet_lookup_established().
Since a TCP socket can go from TCP_ESTABLISH to TCP_LISTEN
(via a close()/socket()/listen() cycle) without a RCU grace period,
I should not have changed listeners linkage in their hash table.
They must use the nulls protocol (Documentation/RCU/rculist_nulls.txt),
so that a lookup can detect a socket in a hash list was moved in
another one.
Since we added code in commit d296ba60d8e2 ("soreuseport: Resolve
merge conflict for v4/v6 ordering fix"), we have to add
hlist_nulls_add_tail_rcu() helper.
Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood")
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Reported-by: Firo Yang <firo.yang@suse.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
Link: https://lore.kernel.org/netdev/20191120083919.GH27852@unicorn.suse.cz/
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
[stable-4.9: we also need to update code in __inet_lookup_listener() and
inet6_lookup_listener() which has been removed in 5.0-rc1.]
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
commit 56144737e67329c9aaed15f942d46a6302e2e3d8 upstream.
syzbot reported various data-race caused by hrtimer_is_queued() reading
timer->state. A READ_ONCE() is required there to silence the warning.
Also add the corresponding WRITE_ONCE() when timer->state is set.
In remove_hrtimer() the hrtimer_is_queued() helper is open coded to avoid
loading timer->state twice.
KCSAN reported these cases:
BUG: KCSAN: data-race in __remove_hrtimer / tcp_pacing_check
write to 0xffff8880b2a7d388 of 1 bytes by interrupt on cpu 0:
__remove_hrtimer+0x52/0x130 kernel/time/hrtimer.c:991
__run_hrtimer kernel/time/hrtimer.c:1496 [inline]
__hrtimer_run_queues+0x250/0x600 kernel/time/hrtimer.c:1576
hrtimer_run_softirq+0x10e/0x150 kernel/time/hrtimer.c:1593
run_ksoftirqd+0x46/0x60 kernel/softirq.c:603
smpboot_thread_fn+0x37d/0x4a0 kernel/smpboot.c:165
read to 0xffff8880b2a7d388 of 1 bytes by task 24652 on cpu 1:
tcp_pacing_check net/ipv4/tcp_output.c:2235 [inline]
tcp_pacing_check+0xba/0x130 net/ipv4/tcp_output.c:2225
tcp_xmit_retransmit_queue+0x32c/0x5a0 net/ipv4/tcp_output.c:3044
tcp_xmit_recovery+0x7c/0x120 net/ipv4/tcp_input.c:3558
tcp_ack+0x17b6/0x3170 net/ipv4/tcp_input.c:3717
tcp_rcv_established+0x37e/0xf50 net/ipv4/tcp_input.c:5696
tcp_v4_do_rcv+0x381/0x4e0 net/ipv4/tcp_ipv4.c:1561
sk_backlog_rcv include/net/sock.h:945 [inline]
__release_sock+0x135/0x1e0 net/core/sock.c:2435
release_sock+0x61/0x160 net/core/sock.c:2951
sk_stream_wait_memory+0x3d7/0x7c0 net/core/stream.c:145
tcp_sendmsg_locked+0xb47/0x1f30 net/ipv4/tcp.c:1393
tcp_sendmsg+0x39/0x60 net/ipv4/tcp.c:1434
inet_sendmsg+0x6d/0x90 net/ipv4/af_inet.c:807
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg+0x9f/0xc0 net/socket.c:657
BUG: KCSAN: data-race in __remove_hrtimer / __tcp_ack_snd_check
write to 0xffff8880a3a65588 of 1 bytes by interrupt on cpu 0:
read to 0xffff8880a3a65588 of 1 bytes by task 22891 on cpu 1:
__tcp_ack_snd_check+0x415/0x4f0 net/ipv4/tcp_input.c:5265
tcp_ack_snd_check net/ipv4/tcp_input.c:5287 [inline]
tcp_rcv_established+0x750/0xf50 net/ipv4/tcp_input.c:5708
__sys_sendto+0x21f/0x320 net/socket.c:1952
__do_sys_sendto net/socket.c:1964 [inline]
__se_sys_sendto net/socket.c:1960 [inline]
__x64_sys_sendto+0x89/0xb0 net/socket.c:1960
do_syscall_64+0xcc/0x370 arch/x86/entry/common.c:290
CPU: 1 PID: 24652 Comm: syz-executor.3 Not tainted 5.4.0-rc3+ #0
[ tglx: Added comments ]
Link: https://lkml.kernel.org/r/20191106174804.74723-1-edumazet@google.com
[ Upstream commit a8de1304b7df30e3a14f2a8b9709bb4ff31a0385 ]
The DTC v1.5.1 added references to (U)INT32_MAX.
This is no problem for user-space programs since <stdint.h> defines
(U)INT32_MAX along with (u)int32_t.
For the kernel space, libfdt_env.h needs to be adjusted before we
pull in the changes.
In the kernel, we usually use s/u32 instead of (u)int32_t for the
fixed-width types.
Accordingly, we already have S/U32_MAX for their max values.
So, we should not add (U)INT32_MAX to <linux/limits.h> any more.
Instead, add them to the in-kernel libfdt_env.h to compile the
latest libfdt.
Signed-off-by: Rob Herring <robh@kernel.org>
