path: root/include
2008-06-24x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.Jeremy Fitzhardinge
commit ad524d46f36bbc32033bb72ba42958f12bf49b06 upstream When a 64-bit x86 processor runs in 32-bit PAE mode, a pte can potentially have the same number of physical address bits as the 64-bit host ("Enhanced Legacy PAE Paging"). This means, in theory, we could have up to 52 bits of physical address in a pte. The 32-bit kernel uses a 32-bit unsigned long to represent a pfn. This means that it can only represent physical addresses up to 32+12=44 bits wide. Rather than widening pfns everywhere, just set 2^44 as the Linux x86_32-PAE architectural limit for physical address size. This is a bugfix for two cases: 1. running a 32-bit PAE kernel on a machine with more than 64GB RAM. 2. running a 32-bit PAE Xen guest on a host machine with more than 64GB RAM In both cases, a pte could need to have more than 36 bits of physical, and masking it to 36-bits will cause fairly severe havoc. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-24Add return value to reserve_bootmem_node()Bernhard Walle
commit 71c2742f5e6348d76ee62085cf0a13e5eff0f00e upstream This patch changes the function reserve_bootmem_node() from void to int, returning -ENOMEM if the allocation fails. This fixes a build problem on x86 with CONFIG_KEXEC=y and CONFIG_NEED_MULTIPLE_NODES=y Signed-off-by: Bernhard Walle <bwalle@suse.de> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-16bttv: Fix a deadlock in the bttv driverArjan van de Ven
commit 81b2dbcad86732ffc02bad87aa25c4651199fc77 in mainline. vidiocgmbuf() does this: mutex_lock(&fh->cap.vb_lock); retval = videobuf_mmap_setup(&fh->cap, gbuffers, gbufsize, V4L2_MEMORY_MMAP); and videobuf_mmap_setup() then just does mutex_lock(&q->vb_lock); ret = __videobuf_mmap_setup(q, bcount, bsize, memory); mutex_unlock(&q->vb_lock); which is an obvious double-take deadlock. This patch fixes this by having vidiocgmbuf() just call the __videobuf_mmap_setup function instead. Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Reported-by: Koos Vriezen <koos.vriezen@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-16m68k: Add ext2_find_{first,next}_bit() for ext4Aneesh Kumar K.V
commit 69c5ddf58a03da3686691ad2f293bc79fd977c10 upstream Add ext2_find_{first,next}_bit(), which are needed for ext4. They're derived out of the ext2_find_next_zero_bit found in the same file. Compile tested with crosstools [Reworked to preserve all symmetry with ext2_find_{first,next}_zero_bit()] This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10393 Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-16cciss: add new hardware supportMike Miller
commit 24aac480e76c6f5d1391ac05c5e9c0eb9b0cd302 upstream Date: Thu, 12 Jun 2008 15:21:34 -0700 Subject: cciss: add new hardware support Add support for the next generation of HP Smart Array SAS/SATA controllers. Shipping date is late Fall 2008. Bump the driver version to 3.6.20 to reflect the new hardware support from patch 1 of this set. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-16netlink: Fix nla_parse_nested_compat() to call nla_parse() directlyThomas Graf
[ upstream commit: b9a2f2e450b0f770bb4347ae8d48eb2dea701e24 ] The purpose of nla_parse_nested_compat() is to parse attributes which contain a struct followed by a stream of nested attributes. So far, it called nla_parse_nested() to parse the stream of nested attributes which was wrong, as nla_parse_nested() expects a container attribute as data which holds the attribute stream. It needs to call nla_parse() directly while pointing at the next possible alignment point after the struct in the beginning of the attribute. With this patch, I can no longer reproduce the reported leftover warnings. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-06-09capabilities: remain source compatible with 32-bit raw legacy capability ↵Andrew G. Morgan
support. upstream commit: ca05a99a54db1db5bca72eccb5866d2a86f8517f Source code out there hard-codes a notion of what the _LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the raw capability system calls capget() and capset(). Its unfortunate, but true. Since the confusing header file has been in a released kernel, there is software that is erroneously using 64-bit capabilities with the semantics of 32-bit compatibilities. These recently compiled programs may suffer corruption of their memory when sys_getcap() overwrites more memory than they are coded to expect, and the raising of added capabilities when using sys_capset(). As such, this patch does a number of things to clean up the situation for all. It 1. forces the _LINUX_CAPABILITY_VERSION define to always retain its legacy value. 2. adopts a new #define strategy for the kernel's internal implementation of the preferred magic. 3. deprecates v2 capability magic in favor of a new (v3) magic number. The functionality of v3 is entirely equivalent to v2, the only difference being that the v2 magic causes the kernel to log a "deprecated" warning so the admin can find applications that may be using v2 inappropriately. [User space code continues to be encouraged to use the libcap API which protects the application from details like this. libcap-2.10 is the first to support v3 capabilities.] Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518. Thanks to Bojan Smojver for the report. [akpm@linux-foundation.org: s/depreciate/deprecate/g] [akpm@linux-foundation.org: be robust about put_user size] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Bojan Smojver <bojan@rexursive.com> Cc: stable@kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-06-09HID: split Numlock emulation quirk from HID_QUIRK_APPLE_HAS_FN.Diego 'Flameeyes' Petteno
upstream commit: 6e7045990f35ef9250804b3fd85e855b8c2aaeb6. [jkosina@suse.cz: Needed to fix apple aluminium keyboard regression] Since 2.6.25 the HID_QUIRK_APPLE_HAS_FN quirk is enabled even for non-laptop Apple keyboards of the Aluminium series. The USB version of these don't need Numlock emulation, like the laptop (and Aluminium Wireless) do, as they have a proper keypad. This patch splits the Numlock emulation for Apple keyboards in a different quirk flag, so that it can be enabled for all the keyboards but the Aluminium USB ones. If the Numlock emulation is enabled for Aluminium USB keyboards, the JKL and UIO keys become the numeric pad, and the rest of the keyboard is disabled, included the key used to disable Numlock. Additionally, these keyboard should not have a Numlock at all, as the Numlock key is instead replaced by the 'Clear' key as usual for Apple USB keyboards. Signed-off-by: Diego 'Flameeyes' Petteno <flameeyes@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-06-09x86: prevent PGE flush from interruption/preemptionIngo Molnar
upstream commit: b1979a5fda7869a790f4fd83fb06c78498d26ba1 CR4 manipulation is not protected against interrupts and preemption, but KVM uses smp_function_call to manipulate the X86_CR4_VMXE bit either from the CPU hotplug code or from the kvm_init call. We need to protect the CR4 manipulation from both interrupts and preemption. Original bug report: http://lkml.org/lkml/2008/5/7/48 Bugzilla entry: http://bugzilla.kernel.org/show_bug.cgi?id=10642 This is not a regression from 2.6.25, it's a long standing and hard to trigger bug. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-06-09types.h: don't expose struct ustat to userspacemaximilian attems
upstream commit: 6c7c6afbb8c0e60d32a563cae7c6889211e9d9d8 <linux/types.h> can't be used together with <sys/ustat.h> because they both define struct ustat: $ cat test.c #include <sys/ustat.h> #include <linux/types.h> $ gcc -c test.c In file included from test.c:2: /usr/include/linux/types.h:165: error: redefinition of 'struct ustat' has been reported a while ago to debian, but seems to have been lost in cat fighting: http://bugs.debian.org/429064 Signed-off-by: maximilian attems <max@stro.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-05-15sparc: Fix debugger syscall restart interactions.David S. Miller
[ This is a 2.6.25 backport of upstream changeset 28e6103665301ce60634e8a77f0b657c6cc099de with sparc32 build fixes from Robert Reif ] So, forever, we've had this ptrace_signal_deliver implementation which tries to handle all of the nasties that can occur when the debugger looks at a process about to take a signal. It's meant to address all of these issues inside of the kernel so that the debugger need not be mindful of such things. Problem is, this doesn't work. The idea was that we should do the syscall restart business first, so that the debugger captures that state. Otherwise, if the debugger for example saves the child's state, makes the child execute something else, then restores the saved state, we won't handle the syscall restart properly because we lose the "we're in a syscall" state. The code here worked for most cases, but if the debugger actually passes the signal through to the child unaltered, it's possible that we would do a syscall restart when we shouldn't have. In particular this breaks the case of debugging a process under a gdb which is being debugged by yet another gdb. gdb uses sigsuspend to wait for SIGCHLD of the inferior, but if gdb itself is being debugged by a top-level gdb we get a ptrace_stop(). The top-level gdb does a PTRACE_CONT with SIGCHLD to let the inferior gdb see the signal. But ptrace_signal_deliver() assumed the debugger would cancel out the signal and therefore did a syscall restart, because the return error was ERESTARTNOHAND. Fix this by simply making ptrace_signal_deliver() a nop, and providing a way for the debugger to control system call restarting properly: 1) Report a "in syscall" software bit in regs->{tstate,psr}. It is set early on in trap entry to a system call and is fully visible to the debugger via ptrace() and regsets. 2) Test this bit right before doing a syscall restart. We have to do a final recheck right after get_signal_to_deliver() in case the debugger cleared the bit during ptrace_stop(). 3) Clear the bit in trap return so we don't accidently try to set that bit in the real register. As a result we also get a ptrace_{is,clear}_syscall() for sparc32 just like sparc64 has. M68K has this same exact bug, and is now the only other user of the ptrace_signal_deliver hook. It needs to be fixed in the same exact way as sparc. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15sparc: Fix mremap address range validation.David S. Miller
Just like mmap, we need to validate address ranges regardless of MAP_FIXED. sparc{,64}_mmap_check()'s flag argument is unused, remove. Based upon a report and preliminary patch by Jan Lieskovsky <jlieskov@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15sparc: Fix ptrace() detach.David S. Miller
[ Upstream commit: 986bef854fab44012df678a5b51817d5274d3ca1 ] Forever we had a PTRACE_SUNOS_DETACH which was unconditionally recognized, regardless of the personality of the process. Unfortunately, this value is what ended up in the GLIBC sys/ptrace.h header file on sparc as PTRACE_DETACH and PT_DETACH. So continue to recognize this old value. Luckily, it doesn't conflict with anything we actually care about. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15x86: sysfs cpu?/topology is empty in 2.6.25 (32-bit Intel system)Vaidyanathan Srinivasan
commit 5c3a121d52b30a1e53cdaa802fa1965fcd243164 upstream System topology on intel based system needs to be exported for non-numa case as well. All parts of asm-i386/topology.h has come under #ifdef CONFIG_NUMA after the merge to asm-x86/topology.h /sys/devices/system/cpu/cpu?/topology/* is populated based on ENABLE_TOPO_DEFINES The sysfs cpu topology is not being populated on my dual socket dual core xeon 5160 processor based (x86 32 bit) system. CONFIG_NUMA is not set in my case yet the topology is relevant and useful. irqbalance daemon application depends on topology to build the cpus and package list and it fails on Fedora9 beta since the sysfs topology was not being populated in the 2.6.25 kernel. I am not sure if it was intentional to not define ENABLE_TOPO_DEFINES for non-numa systems. This fix has been tested on the above mentioned dual core, dual socket system. Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15nf_conntrack: padding breaks conntrack hash on ARMPhilip Craig
[NETFILTER]: nf_conntrack: padding breaks conntrack hash on ARM Upstream commit 443a70d50: commit 0794935e "[NETFILTER]: nf_conntrack: optimize hash_conntrack()" results in ARM platforms hashing uninitialised padding. This padding doesn't exist on other architectures. Fix this by replacing NF_CT_TUPLE_U_BLANK() with memset() to ensure everything is initialised. There were only 4 bytes that NF_CT_TUPLE_U_BLANK() wasn't clearing anyway (or 12 bytes on ARM). Signed-off-by: Philip Craig <philipc@snapgear.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-15ipvs: fix oops in backup for fwmark conn templatesJulian Anastasov
[ Upstream commit: 2ad17defd596ca7e8ba782d5fc6950ee0e99513c ] Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=10556 where conn templates with protocol=IPPROTO_IP can oops backup box. Result from ip_vs_proto_get() should be checked because protocol value can be invalid or unsupported in backup. But for valid message we should not fail for templates which use IPPROTO_IP. Also, add checks to validate message limits and connection state. Show state NONE for templates using IPPROTO_IP. Fix tested and confirmed by L0op8ack <l0op8ack@hotmail.com> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-09CRYPTO: api: Fix scatterwalk_sg_chainHerbert Xu
[CRYPTO] api: Fix scatterwalk_sg_chain [ Upstream commit: 8ec970d8561abb5645d4602433b772e268c96d05 ] When I backed out of using the generic sg chaining (as it isn't currently portable) and introduced scatterwalk_sg_chain/scatterwalk_sg_next I left out the sg_is_last check in the latter. This causes it to potentially dereference beyond the end of the sg array. As most uses of scatterwalk_sg_next are bound by an overall length, this only affected the chaining code in authenc and eseqiv. Thanks to Patrick McHardy for identifying this problem. This patch also clears the "last" bit on the head of the chained list as it's no longer last. This also went missing in scatterwalk_sg_chain and is present in sg_chain. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-09reiserfs: Unpack tails on quota filesJan Kara
commit d5dee5c395062a55236318ac4eec1f4ebb9de6db upstream Quota files cannot have tails because quota_write and quota_read functions do not support them. So far when quota files did have tail, we just refused to turn quotas on it. Sadly this check has been wrong and so there are now plenty installations where quota files don't have NOTAIL flag set and so now after fixing the check, they suddently fail to turn quotas on. Since it's easy to unpack the tail from kernel, do this from reiserfs_quota_on() which solves the problem and is generally nicer to users anyway. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: <urhausen@urifabi.net> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-01IPSEC: Fix catch-22 with algorithm IDs above 31Herbert Xu
[ Upstream commit: c5d18e984a313adf5a1a4ae69e0b1d93cf410229 ] As it stands it's impossible to use any authentication algorithms with an ID above 31 portably. It just happens to work on x86 but fails miserably on ppc64. The reason is that we're using a bit mask to check the algorithm ID but the mask is only 32 bits wide. After looking at how this is used in the field, I have concluded that in the long term we should phase out state matching by IDs because this is made superfluous by the reqid feature. For current applications, the best solution IMHO is to allow all algorithms when the bit masks are all ~0. The following patch does exactly that. This bug was identified by IBM when testing on the ppc64 platform using the NULL authentication algorithm which has an ID of 251. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-01RTNETLINK: Fix bogus ASSERT_RTNL warningPatrick McHardy
[ Upstream commit: c9c1014b2bd014c7ec037bbb6f58818162fdb265 ] ASSERT_RTNL uses mutex_trylock to test whether the rtnl_mutex is held. This bogus warnings when running in atomic context, which f.e. happens when adding secondary unicast addresses through macvlan or vlan or when synchronizing multicast addresses from wireless devices. Mid-term we might want to consider moving all address updates to process context since the locking seems overly complicated, for now just fix the bogus warning by changing ASSERT_RTNL to use mutex_is_locked(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-01TCP: Increase the max_burst threshold from 3 to tp->reordering.John Heffner
[ Upstream commit: dd9e0dda66ba38a2ddd1405ac279894260dc5c36 ] This change is necessary to allow cwnd to grow during persistent reordering. Cwnd moderation is applied when in the disorder state and an ack that fills the hole comes in. If the hole was greater than 3 packets, but less than tp->reordering, cwnd will shrink when it should not have. Signed-off-by: John Heffner <jheffner@napa.none> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: it821x: do not describe noraid parameter with its value Pb1200/DBAu1200: fix bad IDE resource size Au1200: IDE driver build fix Au1200: kill IDE driver function prototypes avr32 mustn't select HAVE_IDE
2008-04-17Pb1200/DBAu1200: fix bad IDE resource sizeSergei Shtylyov
The header files for the Pb1200/DBAu1200 boards have wrong definition for the IDE interface's decoded range length -- it should be 512 bytes according to what the IDE driver does. In addition, the IDE platform device claims 1 byte too many for its memory resource -- fix the platform code and the IDE driver in accordance. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Au1200: kill IDE driver function prototypesSergei Shtylyov
Fix these warnings emitted when compiling drivers/ide/mips/au1xxx-ide.c: include/asm/mach-au1x00/au1xxx_ide.h:137: warning: 'auide_tune_drive' declared `static' but never defined include/asm/mach-au1x00/au1xxx_ide.h:138: warning: 'auide_tune_chipset' declared `static' but never defined by wiping out the whole "function prototyping" section from the header file <asm-mips/mach-au1x00/au1xxx_ide.h> as it mostly declared functions that are already dead in the IDE driver; move the only useful prototype into the driver. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-16Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: update git url for blktrace io context: increment task attachment count in ioc_task_link()
2008-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [TCP]: Add return value indication to tcp_prune_ofo_queue(). PS3: gelic: fix the oops on the broken IE returned from the hypervisor b43legacy: fix DMA mapping leakage mac80211: remove message on receiving unexpected unencrypted frames Update rt2x00 MAINTAINERS entry Add rfkill to MAINTAINERS file rfkill: Fix device type check when toggling states b43legacy: Fix usage of struct device used for DMAing ssb: Fix usage of struct device used for DMAing MAINTAINERS: move to generic repository for iwlwifi b43legacy: fix initvals loading on bcm4303 rtl8187: Add missing priv->vif assignments netconsole: only set CON_PRINTBUFFER if the user specifies a netconsole [CAN]: Update documentation of struct sockaddr_can MAINTAINERS: isdn4linux@listserv.isdn4linux.de is subscribers-only [TCP]: Fix never pruned tcp out-of-order queue. [NET_SCHED] sch_api: fix qdisc_tree_decrease_qlen() loop
2008-04-15acpi thermal trip points increased to 12Krzysztof Helt
The THERMAL_MAX_TRIPS value is set to 10. It is too few for the Compaq AP550 machine which has 12 trip points. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15spi: spi_s3c24xx must initialize num_chipselectBen Dooks
The SPI core now expects num_chipselect to be set correctly as due to added checks on the chip being selected before an transfer is allowed. This patch adds a num_cs field to the platform data which needs to be set correctly before adding the SPI platform device. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15vfs: fix possible deadlock in ext2, ext3, ext4 when using xattrsJan Kara
mb_cache_entry_alloc() was allocating cache entries with GFP_KERNEL. But filesystems are calling this function while holding xattr_sem so possible recursion into the fs violates locking ordering of xattr_sem and transaction start / i_mutex for ext2-4. Change mb_cache_entry_alloc() so that filesystems can specify desired gfp mask and use GFP_NOFS from all of them. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Dave Jones <davej@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15uml: compile error fixWANG Cong
This patch fixes this error: In file included from /home/wangcong/projects/linux-2.6/arch/um/kernel/smp.c:9: include2/asm/tlb.h: In function `tlb_remove_page': include2/asm/tlb.h:101: error: implicit declaration of function `page_cache_release' And since including <linux/pagemap.h> in <linux/swap.h> will break sparc, we add this #include in uml's own header. Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15ssb: Fix usage of struct device used for DMAingMichael Buesch
This fixes DMA on architectures where DMA is nontrivial, like PPC64. We must use the host-device's (PCI) struct device for any DMA operation instead of the SSB device. For this we add a new struct device pointer to the SSB device structure that will always point to the right device for DMAing. Without this patch b43 and b44 drivers won't work on complex-DMA architectures, that for example need dev->archdata for DMA operations. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15io context: increment task attachment count in ioc_task_link()Jens Axboe
Thanks to Nikanth Karthikesan <knikanth@suse.de> for reporting this. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) [BRIDGE]: Fix crash in __ip_route_output_key with bridge netfilter [NETFILTER]: ipt_CLUSTERIP: fix race between clusterip_config_find_get and _entry_put [IPV6] ADDRCONF: Don't generate temporary address for ip6-ip6 interface. [IPV6] ADDRCONF: Ensure disabling multicast RS even if privacy extensions are disabled. [IPV6]: Use appropriate sock tclass setting for routing lookup. [IPV6]: IPv6 extension header structures need to be packed. [IPV6]: Fix ipv6 address fetching in raw6_icmp_error(). [NET]: Return more appropriate error from eth_validate_addr(). [ISDN]: Do not validate ISDN net device address prior to interface-up [NET]: Fix kernel-doc for skb_segment [SOCK] sk_stamp: should be initialized to ktime_set(-1L, 0) net: check for underlength tap writes net: make struct tun_struct private to tun.c [SCTP]: IPv4 vs IPv6 addresses mess in sctp_inet[6]addr_event. [SCTP]: Fix compiler warning about const qualifiers [SCTP]: Fix protocol violation when receiving an error lenght INIT-ACK [SCTP]: Add check for hmac_algo parameter in sctp_verify_param() [NET_SCHED] cls_u32: refcounting fix for u32_delete() [DCCP]: Fix skb->cb conflicts with IP [AX25]: Potential ax25_uid_assoc-s leaks on module unload. ...
2008-04-13[IPV6]: Use appropriate sock tclass setting for routing lookup.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[IPV6]: IPv6 extension header structures need to be packed.YOSHIFUJI Hideaki
struct ipv6_opt_hdr is the common structure for IPv6 extension headers, and it is common to increment the pointer to get the real content. On the other hand, since the structure consists only of 1-byte next-header field and 1-byte length field, size of that structure depends on architecture; 2 or 4. Add "packed" attribute to get 2. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12net: make struct tun_struct private to tun.cRusty Russell
There's no reason for this to be in the header, and it just hurts recompile time. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Max Krasnyanskiy <maxk@qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[SCTP]: Fix compiler warning about const qualifiersVlad Yasevich
Fix 3 warnings about discarding const qualifiers: net/sctp/ulpevent.c:862: warning: passing argument 1 of 'sctp_event2skb' discards qualifiers from pointer target type net/sctp/sm_statefuns.c:4393: warning: passing argument 1 of 'SCTP_ASOC' discards qualifiers from pointer target type net/sctp/socket.c:5874: warning: passing argument 1 of 'cmsg_nxthdr' discards qualifiers from pointer target type Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[SCTP]: Fix protocol violation when receiving an error lenght INIT-ACKGui Jianfeng
When receiving an error length INIT-ACK during COOKIE-WAIT, a 0-vtag ABORT will be responsed. This action violates the protocol apparently. This patch achieves the following things. 1 If the INIT-ACK contains all the fixed parameters, use init-tag recorded from INIT-ACK as vtag. 2 If the INIT-ACK doesn't contain all the fixed parameters, just reflect its vtag. Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-11Merge branch 'docs' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs' of git://git.lwn.net/linux-2.6: Add additional examples in Documentation/spinlocks.txt Move sched-rt-group.txt to scheduler/ Documentation: move rpc-cache.txt to filesystems/ Documentation: move nfsroot.txt to filesystems/ Spell out behavior of atomic_dec_and_lock() in kerneldoc Fix a typo in highres.txt Fixes to the seq_file document Fill out information on patch tags in SubmittingPatches Add the seq_file documentation
2008-04-11Spell out behavior of atomic_dec_and_lock() in kerneldocJ. Bruce Fields
A little more detail here wouldn't hurt. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-11Fix "$(AS) -traditional" compile breakage caused by asmlinkage_protectHeiko Carstens
git commit 54a015104136974262afa4b8ddd943ea70dec8a2 ("asmlinkage_protect replaces prevent_tail_call") causes this build failure on s390: AS arch/s390/kernel/entry64.o In file included from arch/s390/kernel/entry64.S:14: include/linux/linkage.h:34: error: syntax error in macro parameter list make[1]: *** [arch/s390/kernel/entry64.o] Error 1 make: *** [arch/s390/kernel] Error 2 and some other architectures. The reason is that some architectures add the "-traditional" flag to the invocation of $(AS), which disables variadic macro argument support. So just surround the new define with an #ifndef __ASSEMBLY__ to prevent any side effects on asm code. Cc: Roland McGrath <roland@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [NETNS][IPV6] tcp - assign the netns for timewait sockets [IPV4]: Fix byte value boundary check in do_ip_getsockopt(). BNX2X: Correct bringing chip out of reset [NETFILTER]: nf_nat: autoload IPv4 connection tracking [NETFILTER]: xt_hashlimit: fix mask calculation [XFRM]: xfrm_user: fix selector family initialization rt61pci: rt61pci_beacon_update do not free skb twice ssb-mipscore: Fix interrupt vectors ssb-pcicore: Fix IRQ TPS flag handling mac80211: use short_preamble mode from capability if ERP IE not present [NET]: Undo code bloat in hot paths due to print_mac(). [TCP]: Don't allow FRTO to take place while MTU is being probed [TCP]: tcp_simple_retransmit can cause S+L [TCP]: Fix NewReno's fast rexmit/recovery problems with GSOed skb [TCP]: Restore 2.6.24 mark_head_lost behavior for newreno/fack nl80211: fix STA AID bug b43legacy: fix bcm4303 crash iwlwifi: fix n-band association problem ipw2200: set MAC address on radiotap interface libertas: fix mode initialization problem
2008-04-11pnp: increase number of devices supported per protocolBjorn Helgaas
Increase the PNP "number of devices" limit. We currently use an unsigned char, which limits us to 256 devices per protocol. This patch changes that to an unsigned int. Not all backends can take advantage of this: we limit ISAPNP to 10 devices in isapnp_cfg_begin(), and PNPBIOS is limited to 256 devices because the BIOS interfaces use a one-byte device node number. But there is no limit on the number of PNPACPI devices we may have. Large HP Integrity machines have more than 256, which causes the current "unsigned char number" to wrap around. This causes errors like this: pnp: PnP ACPI init kobject_add failed for 00:00 with -EEXIST, don't try to register things with the same name in the same directory. Call Trace: [<a000000100010720>] show_stack+0x40/0xa0 [<a0000001000107b0>] dump_stack+0x30/0x60 [<a0000001001dbdf0>] kobject_add+0x290/0x2c0 [<a0000001002bfd40>] device_add+0x160/0x860 [<a0000001002c0470>] device_register+0x30/0x60 [<a00000010026ba70>] __pnp_add_device+0x130/0x180 [<a00000010026bb70>] pnp_add_device+0xb0/0xe0 [<a0000001007f2730>] pnpacpi_add_device+0x510/0x5a0 [<a0000001007f2810>] pnpacpi_add_device_handler+0x50/0x80 This patch increases the limit to fix this PNPACPI problem. It should not have any adverse effect on ISAPNP or PNPBIOS because their limits are still enforced in the backends. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10Add commentary about the new "asmlinkage_protect()" macroLinus Torvalds
It's really a pretty ugly thing to need, and some day it will hopefully be obviated by teaching gcc about the magic calling conventions for the low-level system call code, but in the meantime we can at least add big honking comments about why we need these insane and strange macros. I took my comments from my version of the macro, but I ended up deciding to just pick Roland's version of the actual code instead (with his prettier syntax that uses vararg macros). Thus the previous two commits that actually implement it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10asmlinkage_protect replaces prevent_tail_callRoland McGrath
The prevent_tail_call() macro works around the problem of the compiler clobbering argument words on the stack, which for asmlinkage functions is the caller's (user's) struct pt_regs. The tail/sibling-call optimization is not the only way that the compiler can decide to use stack argument words as scratch space, which we have to prevent. Other optimizations can do it too. Until we have new compiler support to make "asmlinkage" binding on the compiler's own use of the stack argument frame, we have work around all the manifestations of this issue that crop up. More cases seem to be prevented by also keeping the incoming argument variables live at the end of the function. This makes their original stack slots attractive places to leave those variables, so the compiler tends not clobber them for something else. It's still no guarantee, but it handles some observed cases that prevent_tail_call() did not. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Don't make smp_{r, w, }mb() interpolate MEMBAR when CONFIG_SMP=n [try #2]David Howells
Don't make smp_{r,w,}mb() interpolate a MEMBAR instruction when CONFIG_SMP=n as SMP memory barries on UP systems should interpolate a compiler barrier only. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Add support for emulation of userspace atomic ops [try #2]David Howells
Use traps 120-126 to emulate atomic cmpxchg32, xchg32, and XOR-, OR-, AND-, SUB- and ADD-to-memory operations for userspace. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Move STACK_TOP_MAX up [try #2]David Howells
Move STACK_TOP_MAX up so that we don't try moving the stack above it as that causes setup_arg_pages() to malfunction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Handle update_mmu_cache() being called when current->mm is NULL [try #2]David Howells
Handle update_mmu_cache() being called when current->mm is NULL. We cache static TLB mappings for the current page table in DAMPR4 and DAMPR5 on the theory that the next data lookup is likely to be in the same general region, and thus is likely to be mapped by the same page table. However, we can't get this information if we can't access the appropriate mm_struct. If current->mm is NULL, we just clear the cache in the knowledge that the TLB miss handlers will load it. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-07[TCP]: tcp_simple_retransmit can cause S+LIlpo Järvinen
This fixes Bugzilla #10384 tcp_simple_retransmit does L increment without any checking whatsoever for overflowing S+L when Reno is in use. The simplest scenario I can currently think of is rather complex in practice (there might be some more straightforward cases though). Ie., if mss is reduced during mtu probing, it may end up marking everything lost and if some duplicate ACKs arrived prior to that sacked_out will be non-zero as well, leading to S+L > packets_out, tcp_clean_rtx_queue on the next cumulative ACK or tcp_fastretrans_alert on the next duplicate ACK will fix the S counter. More straightforward (but questionable) solution would be to just call tcp_reset_reno_sack() in tcp_simple_retransmit but it would negatively impact the probe's retransmission, ie., the retransmissions would not occur if some duplicate ACKs had arrived. So I had to add reno sacked_out reseting to CA_Loss state when the first cumulative ACK arrives (this stale sacked_out might actually be the explanation for the reports of left_out overflows in kernel prior to 2.6.23 and S+L overflow reports of 2.6.24). However, this alone won't be enough to fix kernel before 2.6.24 because it is building on top of the commit 1b6d427bb7e ([TCP]: Reduce sacked_out with reno when purging write_queue) to keep the sacked_out from overflowing. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
