commit 3a7da39d165e0c363c294feec119db1427032afd upstream.
This structure was accidentally defined such that its layout can
differ between 32-bit and 64-bit processes. Add compat structure
definitions and an ioctl wrapper function.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
commit 500132a0f26ad7d9916102193cbc6c1b1becb373 upstream.
Use the Mult and bMaxBurst values from the endpoint companion
descriptor to calculate the max length of an isoc transfer.
Add USB_SS_MULT macro to access Mult field of bmAttributes, at
Sarah's suggestion.
This patch should be queued for the 2.6.36 and 2.6.37 stable trees, since
those were the first kernels to have isochronous support for SuperSpeed
devices.
Signed-off-by: Paul Zimmerman <paulz@synopsys.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 9b37596a2e860404503a3f2a6513db60c296bfdc upstream.
The hcd->state variable is a disaster. It's not clearly owned by
either usbcore or the host controller drivers, and they both change it
from time to time, potentially stepping on each other's toes. It's
not protected by any locks. And there's no mechanism to prevent it
from going through an invalid transition.
This patch (as1451) takes a first step toward fixing these problems.
As it turns out, usbcore uses hcd->state for essentially only two
things: checking whether the controller's root hub is running and
checking whether the controller has died. Therefore the patch adds
two new atomic bitflags to the hcd structure, to store these pieces of
information. The new flags are used only by usbcore, and a private
spinlock prevents invalid combinations (a dead controller's root hub
cannot be running).
The patch does not change the places where usbcore sets hcd->state,
since HCDs may depend on them. Furthermore, there is one place in
usb_hcd_irq() where usbcore still must use hcd->state: An HCD's
interrupt handler can implicitly indicate that the controller died by
setting hcd->state to HC_STATE_HALT. Nevertheless, the new code is a
big improvement over the current code.
The patch makes one other change. The hcd_bus_suspend() and
hcd_bus_resume() routines now check first whether the host controller
has died; if it has then they return immediately without calling the
HCD's bus_suspend or bus_resume methods.
This fixes the major problem reported in Bugzilla #29902: The system
fails to suspend after a host controller dies during system resume.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Alex Terekhov <a.terekhov@gmail.com>
commit 969e3033ae7733a0af8f7742ca74cd16c0857e71 upstream.
When a driver doesn't know how much data a device is going to send,
the buffer size should be at least as big as the endpoint's maxpacket
value. The serial drivers don't follow this rule; many of them
request only 256-byte bulk-in buffers. As a result, they suffer
overflow errors if a high-speed device wants to send a lot of data,
because high-speed bulk endpoints are required to have a maxpacket
size of 512.
This patch (as1450) fixes the problem by using the driver's
bulk_in_size value as a minimum, always allocating buffers no smaller
than the endpoint's maxpacket size.
Tested-by: Flynn Marquardt <flynn@flynnux.de>
commit 868baf07b1a259f5f3803c1dc2777b6c358f83cf upstream.
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 8909c9ad8ff03611c9c96c9a92656213e4bb495b upstream.
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with
CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean
that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are
limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't
allow anybody load any module not related to networking.
This patch restricts an ability of autoloading modules to netdev modules
with explicit aliases. This fixes CVE-2011-1019.
Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior
of loading netdev modules by name (without any prefix) for processes
with CAP_SYS_MODULE to maintain the compatibility with network scripts
that use autoloading netdev modules by aliases like "eth0", "wlan0".
Currently there are only three users of the feature in the upstream
kernel: ipip, ip_gre and sit.
root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) --
root@albatros:~# grep Cap /proc/$$/status
CapInh: 0000000000000000
CapPrm: fffffff800001000
CapEff: fffffff800001000
CapBnd: fffffff800001000
root@albatros:~# modprobe xfs
FATAL: Error inserting xfs
(/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted
root@albatros:~# lsmod | grep xfs
root@albatros:~# ifconfig xfs
xfs: error fetching interface information: Device not found
root@albatros:~# lsmod | grep sit
root@albatros:~# ifconfig sit
sit: error fetching interface information: Device not found
root@albatros:~# ifconfig sit0
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
sit 10457 0
tunnel4 2957 1 sit
For CAP_SYS_MODULE module loading is still relaxed:
CapPrm: ffffffffffffffff
CapEff: ffffffffffffffff
CapBnd: ffffffffffffffff
xfs 745319 0
Reference: https://lkml.org/lkml/2011/2/24/203
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Acked-by: Kees Cook <kees.cook@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit f009918a1c1bbf8607b8aab3959876913a30193a upstream.
commit 339412841d7 (RxRPC: Allow key payloads to be passed in XDR form)
broke klog for me. I notice the v1 key struct had a kif_version field
added:
-struct rxkad_key {
- u16 security_index; /* RxRPC header security index */
- u16 ticket_len; /* length of ticket[] */
- u32 expiry; /* time at which expires */
- u32 kvno; /* key version number */
- u8 session_key[8]; /* DES session key */
- u8 ticket[0]; /* the encrypted ticket */
+struct rxrpc_key_data_v1 {
+ u32 kif_version; /* 1 */
+ u16 security_index;
+ u16 ticket_length;
+ u32 expiry; /* time_t */
+ u32 kvno;
+ u8 session_key[8];
+ u8 ticket[0];
However the code in rxrpc_instantiate strips it away:
data += sizeof(kver);
datalen -= sizeof(kver);
Removing kif_version fixes my problem.
commit 1654e7411a1ad4999fe7890ef51d2a2bbb1fcf76 upstream.
__blk_run_queue() automatically either calls q->request_fn() directly
or schedules kblockd depending on whether the function is recursed.
blk-flush implementation needs to be able to explicitly choose
kblockd. Add @force_kblockd.
All the current users are converted to specify %false for the
parameter and this patch doesn't introduce any behavior change.
stable: This is prerequisite for fixing ide oops caused by the new
blk-flush implementation.
Cc: Jan Beulich <JBeulich@novell.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 450adcbe518ab3a3953d8475309525d22de77cba upstream.
o Dominik Klein reported a system hang issue while doing some blkio
throttling testing.
https://lkml.org/lkml/2011/2/24/173
o Some tracing revealed that CFQ was not dispatching any more jobs as
queue unplug was not happening. And queue unplug was not happening
because unplug work was not being called as there was one throttling
work on same cpu which as not finished yet. And throttling work had not
finished as it was tyring to dispatch a bio to CFQ but all the request
descriptors were consume to it was put to sleep.
o So basically it is a cyclic dependecny between CFQ unplug work and
throtl dispatch work. Tejun suggested that use separate workqueue for
such cases.
o This patch uses a separate workqueue for throttle related work and
does not rely on kblockd workqueue anymore.
Reported-by: Dominik Klein <dk@in-telegence.net>
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
thresholds
commit b44129b30652c8771db2265939bb8b463724043d upstream.
reduce_pgdat_percpu_threshold() and restore_pgdat_percpu_threshold() exist
to adjust the per-cpu vmstat thresholds while kswapd is awake to avoid
errors due to counter drift. The functions duplicate some code so this
patch replaces them with a single set_pgdat_percpu_threshold() that takes
a callback function to calculate the desired threshold as a parameter.
[akpm@linux-foundation.org: readability tweak]
[kosaki.motohiro@jp.fujitsu.com: set_pgdat_percpu_threshold(): don't use for_each_online_cpu]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Christoph Lameter <cl@linux.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 1922756124ddd53846877416d92ba4a802bc658f upstream.
This fixes CVE-2011-1013.
Reported-by: Matthiew Herrb (OpenBSD X.org team)
commit 805bdaec1a44155db35f6ee5410d6bbc365324a8 upstream.
Commit 074037e (PM / Wakeup: Introduce wakeup source objects and
event statistics (v3)) caused ACPI wakeup to only work if
CONFIG_PM_SLEEP is set, but it also worked for CONFIG_PM_SLEEP unset
before. This can be fixed by making device_set_wakeup_enable(),
device_init_wakeup() and device_may_wakeup() work in the same way
as before commit 074037e when CONFIG_PM_SLEEP is unset.
Reported-and-tested-by: Justin Maggard <jmaggard10@gmail.com>
commit 93b270f76e7ef3b81001576860c2701931cdc78b upstream.
There are two cases when we call flush_disk.
In one, the device has disappeared (check_disk_change) so any
data will hold becomes irrelevant.
In the oter, the device has changed size (check_disk_size_change)
so data we hold may be irrelevant.
In both cases it makes sense to discard any 'clean' buffers,
so they will be read back from the device if needed.
In the former case it makes sense to discard 'dirty' buffers
as there will never be anywhere safe to write the data. In the
second case it *does*not* make sense to discard dirty buffers
as that will lead to file system corruption when you simply enlarge
the containing devices.
flush_disk calls __invalidate_devices.
__invalidate_device calls both invalidate_inodes and invalidate_bdev.
invalidate_inodes *does* discard I_DIRTY inodes and this does lead
to fs corruption.
invalidate_bev *does*not* discard dirty pages, but I don't really care
about that at present.
So this patch adds a flag to __invalidate_device (calling it
__invalidate_device2) to indicate whether dirty buffers should be
killed, and this is passed to invalidate_inodes which can choose to
skip dirty inodes.
flusk_disk then passes true from check_disk_change and false from
check_disk_size_change.
dm avoids tripping over this problem by calling i_size_write directly
rathher than using check_disk_size_change.
md does use check_disk_size_change and so is affected.
This regression was introduced by commit 608aeef17a which causes
check_disk_size_change to call flush_disk, so it is suitable for any
kernel since 2.6.27.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Andrew Patterson <andrew.patterson@hp.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 2aa15890f3c191326678f1bd68af61ec6b8753ec upstream.
Michael Leun reported that running parallel opens on a fuse filesystem
can trigger a "kernel BUG at mm/truncate.c:475"
Gurudas Pai reported the same bug on NFS.
The reason is, unmap_mapping_range() is not prepared for more than
one concurrent invocation per inode. For example:
thread1: going through a big range, stops in the middle of a vma and
stores the restart address in vm_truncate_count.
thread2: comes in with a small (e.g. single page) unmap request on
the same vma, somewhere before restart_address, finds that the
vma was already unmapped up to the restart address and happily
returns without doing anything.
Another scenario would be two big unmap requests, both having to
restart the unmapping and each one setting vm_truncate_count to its
own value. This could go on forever without any of them being able to
finish.
Truncate and hole punching already serialize with i_mutex. Other
callers of unmap_mapping_range() do not, and it's difficult to get
i_mutex protection for all callers. In particular ->d_revalidate(),
which calls invalidate_inode_pages2_range() in fuse, may be called
with or without i_mutex.
This patch adds a new mutex to 'struct address_space' to prevent
running multiple concurrent unmap_mapping_range() on the same mapping.
[ We'll hopefully get rid of all this with the upcoming mm
preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex
lockbreak" patch in particular. But that is for 2.6.39 ]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reported-by: Michael Leun <lkml20101129@newton.leun.net>
Reported-by: Gurudas Pai <gurudas.pai@oracle.com>
Tested-by: Gurudas Pai <gurudas.pai@oracle.com>
commit 33619f0d3ff715a2a5499520967d526ad931d70d upstream.
Allow drivers to enable Zoomed Video support. Currently, this is only
used by out-of-tree drivers (L64020 DVB driver in particular).
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
commit ca86828ccd3128513f6d4e200b437deac95408db upstream.
This patch adds the PCI northbridge device id for AMD CPU
families 12h and 14h. Both families have implemented the same
PCI northbridge device.
There are some future use cases that use this PCI device and
we would like to clarify its naming.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: xen-devel@lists.xensource.com <xen-devel@lists.xensource.com>
Cc: Keir Fraser <keir@xen.org>
LKML-Reference: <20110106165107.GL4739@erda.amd.com>
commit 6037b715d6fab139742c3df8851db4c823081561 upstream.
Expand security_capable() to include cred, so that it can be usable in a
wider range of call sites.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
commit 0029227f1bc30b6c809ae751f9e7af6cef900997 upstream.
Synchronize the interrupts instead of free them in xhci_suspend(). This will
prevent a double free when the host is suspended and then the card removed.
Set the flag hcd->msix_enabled when using MSI-X, and check the flag in
suspend_common(). MSI-X synchronization will be handled by xhci_suspend(),
and MSI/INTx will be synchronized in suspend_common().
This patch should be queued for the 2.6.37 stable tree.
Reported-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
commit 63a507800c8aca5a1891d598ae13f829346e8e39 upstream.
0x4243 is a PCI bridge, not a GPU.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=33815
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit d14dd7e20d5e526557f5d3cfef4046a642f80924 upstream.
Always allow backtraces when using oprofile on ARM, even if a PMU
isn't present. Restores functionality originally introduced in commit
1b7b56982fdcd9d85effd76f3928cf5d6eb26155 ("oprofile: Always allow
backtraces on ARM") by Richard Purdie.
It is not that obvious, but there is now only one oprofile_arch_init()
function. So the .backtrace callback is available also in timer mode.
Implemented by removing code and using stubs for oprofile_perf_{init,
exit} provided by <linux/oprofile.h>. This allows cleaning of other
architecture specific implementations too.
Signed-off-by: Ari Kauppi <kauppi@papupata.org>
Acked-by: Will Deacon <will.deacon@arm.com>
commit 8d661f1e462d50bd83de87ee628aaf820ce3c66c upstream.
It is defined in include/linux/ieee80211.h. As per IEEE spec.
bit6 to bit15 in block ack parameter represents buffer size.
So the bitmask should be 0xFFC0.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit 1ea1bdf7faa4d0b5293e605f2e1ef1c2c59f6b53 upstream.
The implementations are flagged in Makefile with CONFIG_HW_PERF_EVENTS
instead of CONFIG_PERF_EVENTS.
commit 8c6a98b22b750c9eb52653ba643faa17db8d3881 upstream.
Currently sysrq_enabled and __sysrq_enabled are initialised separately
and inconsistently, leading to sysrq being actually enabled by reported
as not enabled in sysfs. The first change to the sysfs configurable
synchronises these two:
static int __read_mostly sysrq_enabled = 1;
static int __sysrq_enabled;
Add a common define to carry the default for these preventing them becoming
out of sync again. Default this to 1 to mirror previous behaviour.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
commit 925268a06dc2b1ff7bfcc37419a6827a0e739639 upstream.
Now, memory_hotplug_(un)lock() is used for add/remove/offline pages
for avoiding races with hibernation. But this should be held in
online_pages(), too. It seems asymmetric.
There are cases where one has to avoid a race with memory hotplug
notifier and his own local code, and hotplug v.s. hotplug.
This will add a generic solution for avoiding races. In other view,
having lock here has no big impacts. online pages is tend to be
done by udev script at el against each memory section one by one.
Then, it's better to have lock here, too.
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit e159489baa717dbae70f9903770a6a4990865887 upstream.
Currently, the lockdep annotation in flush_work() requires exclusive
access on the workqueue the target work is queued on and triggers
warning if a work is trying to flush another work on the same
workqueue; however, this is no longer true as workqueues can now
execute multiple works concurrently.
This patch adds lock_map_acquire_read() and make process_one_work()
hold read access to the workqueue while executing a work and
start_flush_work() check for write access if concurrnecy level is one
or the workqueue has a rescuer (as only one execution resource - the
rescuer - is guaranteed to be available under memory pressure), and
read access if higher.
This better represents what's going on and removes spurious lockdep
warnings which are triggered by fake dependency chain created through
flush_work().
* Peter pointed out that flushing another work from a WQ_MEM_RECLAIM
wq breaks forward progress guarantee under memory pressure.
Condition check accordingly updated.
Reported-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
commit 6bf4123760a5aece6e4829ce90b70b6ffd751d65 upstream.
wait_for_completion_*_timeout() can return:
0: if the wait timed out
-ve: if the wait was interrupted
+ve: if the completion was completed.
As they currently return an 'unsigned long', the last two cases
are not easily distinguished which can easily result in buggy
code, as is the case for the recently added
wait_for_completion_interruptible_timeout() call in
net/sunrpc/cache.c
So change them both to return 'long'. As MAX_SCHEDULE_TIMEOUT
is LONG_MAX, a large +ve return value should never overflow.
Cc: J. Bruce Fields <bfields@fieldses.org>
LKML-Reference: <20110105125016.64ccab0e@notabene.brown>
commit 795abaf1e4e188c4171e3cd3dbb11a9fcacaf505 upstream.
Commit c0e69a5bbc6f ("klist.c: bit 0 in pointer can't be used as flag")
intended to make sure that all klist objects were at least pointer size
aligned, but used the constant "4" which only works on 32-bit.
Use "sizeof(void *)" which is correct in all cases.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
commit 88f5acf88ae6a9778f6d25d0d5d7ec2d57764a97 upstream.
Commit aa45484 ("calculate a better estimate of NR_FREE_PAGES when memory
is low") noted that watermarks were based on the vmstat NR_FREE_PAGES. To
avoid synchronization overhead, these counters are maintained on a per-cpu
basis and drained both periodically and when a threshold is above a
threshold. On large CPU systems, the difference between the estimate and
real value of NR_FREE_PAGES can be very high. The system can get into a
case where pages are allocated far below the min watermark potentially
causing livelock issues. The commit solved the problem by taking a better
reading of NR_FREE_PAGES when memory was low.
Unfortately, as reported by Shaohua Li this accurate reading can consume a
large amount of CPU time on systems with many sockets due to cache line
bouncing. This patch takes a different approach. For large machines
where counter drift might be unsafe and while kswapd is awake, the per-cpu
thresholds for the target pgdat are reduced to limit the level of drift to
what should be a safe level. This incurs a performance penalty in heavy
memory pressure by a factor that depends on the workload and the machine
but the machine should function correctly without accidentally exhausting
all memory on a node. There is an additional cost when kswapd wakes and
sleeps but the event is not expected to be frequent - in Shaohua's test
case, there was one recorded sleep and wake event at least.
To ensure that kswapd wakes up, a safe version of zone_watermark_ok() is
introduced that takes a more accurate reading of NR_FREE_PAGES when called
from wakeup_kswapd, when deciding whether it is really safe to go back to
sleep in sleeping_prematurely() and when deciding if a zone is really
balanced or not in balance_pgdat(). We are still using an expensive
function but limiting how often it is called.
When the test case is reproduced, the time spent in the watermark
functions is reduced. The following report is on the percentage of time
spent cumulatively spent in the functions zone_nr_free_pages(),
zone_watermark_ok(), __zone_watermark_ok(), zone_watermark_ok_safe(),
zone_page_state_snapshot(), zone_page_state().
vanilla 11.6615%
disable-threshold 0.2584%
David said:
: We had to pull aa454840 "mm: page allocator: calculate a better estimate
: of NR_FREE_PAGES when memory is low and kswapd is awake" from 2.6.36
: internally because tests showed that it would cause the machine to stall
: as the result of heavy kswapd activity. I merged it back with this fix as
: it is pending in the -mm tree and it solves the issue we were seeing, so I
: definitely think this should be pushed to -stable (and I would seriously
: consider it for 2.6.37 inclusion even at this late date).
Reported-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: Nicolas Bareil <nico@chdir.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
[ Upstream commit 3610cda53f247e176bcbb7a7cca64bc53b12acdb ]
unix_release() can asynchornously set socket->sk to NULL, and
it does so without holding the unix_state_lock() on "other"
during stream connects.
However, the reverse mapping, sk->sk_socket, is only transitioned
to NULL under the unix_state_lock().
Therefore make the security hooks follow the reverse mapping instead
of the forward mapping.
Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
tree slot during file page migration
commit 29c1f677d424e8c5683a837fc4f03fc9f19201d7 upstream.
migrate_pages() -> unmap_and_move() only calls rcu_read_lock() for
anonymous pages, as introduced by git commit
989f89c57e6361e7d16fbd9572b5da7d313b073d ("fix rcu_read_lock() in page
migraton"). The point of the RCU protection there is part of getting a
stable reference to anon_vma and is only held for anon pages as file pages
are locked which is sufficient protection against freeing.
However, while a file page's mapping is being migrated, the radix tree is
double checked to ensure it is the expected page. This uses
radix_tree_deref_slot() -> rcu_dereference() without the RCU lock held
triggering the following warning.
[ 173.674290] ===================================================
[ 173.676016] [ INFO: suspicious rcu_dereference_check() usage. ]
[ 173.676016] ---------------------------------------------------
[ 173.676016] include/linux/radix-tree.h:145 invoked rcu_dereference_check() without protection!
[ 173.676016]
[ 173.676016] other info that might help us debug this:
[ 173.676016]
[ 173.676016]
[ 173.676016] rcu_scheduler_active = 1, debug_locks = 0
[ 173.676016] 1 lock held by hugeadm/2899:
[ 173.676016] #0: (&(&inode->i_data.tree_lock)->rlock){..-.-.}, at: [<c10e3d2b>] migrate_page_move_mapping+0x40/0x1ab
[ 173.676016]
[ 173.676016] stack backtrace:
[ 173.676016] Pid: 2899, comm: hugeadm Not tainted 2.6.37-rc5-autobuild
[ 173.676016] Call Trace:
[ 173.676016] [<c128cc01>] ? printk+0x14/0x1b
[ 173.676016] [<c1063502>] lockdep_rcu_dereference+0x7d/0x86
[ 173.676016] [<c10e3db5>] migrate_page_move_mapping+0xca/0x1ab
[ 173.676016] [<c10e41ad>] migrate_page+0x23/0x39
[ 173.676016] [<c10e491b>] buffer_migrate_page+0x22/0x107
[ 173.676016] [<c10e48f9>] ? buffer_migrate_page+0x0/0x107
[ 173.676016] [<c10e425d>] move_to_new_page+0x9a/0x1ae
[ 173.676016] [<c10e47e6>] migrate_pages+0x1e7/0x2fa
This patch introduces radix_tree_deref_slot_protected() which calls
rcu_dereference_protected(). Users of it must pass in the
mapping->tree_lock that is protecting this dereference. Holding the tree
lock protects against parallel updaters of the radix tree meaning that
rcu_dereference_protected is allowable.
[akpm@linux-foundation.org: remove unneeded casts]
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Milton Miller <miltonm@bga.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Wu Fengguang <fengguang.wu@intel.com>
commit 09e099d4bafea3b15be003d548bdf94b4b6e0e17 upstream.
/proc/diskstats would display a strange output as follows.
$ cat /proc/diskstats |grep sda
8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089
8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691
8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390
8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92
8 4 sda4 4 0 8 0 0 0 0 0 0 0 0
8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137
Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is
merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE.
The detailed root cause is as follows.
Assuming that there are two partition, sda1 and sda2.
1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight
is 0 and sda2's one is 1.
sda1 | 0
sda2 | 1
2. A bio belongs to sda1 is issued and is merged into the request mentioned on
step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed
from sda2 region to sda1 region. However the two partition's
hd_struct->in_flight are not changed.
sda1 | 0
sda2 | 1
3. The request is finished and blk_account_io_done() is called. In this case,
sda2's hd_struct->in_flight, not a sda1's one, is decremented.
sda1 | -1
sda2 | 1
The patch fixes the problem by caching the partition lookup
inside the request structure, hence making sure that the increment
and decrement will always happen on the same partition struct. This
also speeds up IO with accounting enabled, since it cuts down on
the number of lookups we have to do.
Also add a refcount to struct hd_struct to keep the partition in
memory as long as users exist. We use kref_test_and_get() to ensure
we don't add a reference to a partition which is going away.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
commit e4a683c899cd5a49f8d684a054c95bd115a0c005 upstream.
Add kref_test_and_get() function, which atomically add a reference only if
refcount is not zero. This prevent to add a reference to an object that is
already being removed.
commit 2d75af2f2a7a6103a6d539a492fe81deacabde44 upstream.
On older gcc (3.3) dynamic debug fails to compile:
include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer':
include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk'
include/net/inet_connection_sock.h:219: error: this is a previous declaration
include/net/inet_connection_sock.h:236: error: duplicate label declaration `out'
include/net/inet_connection_sock.h:236: error: duplicate label `do_printk'
include/net/inet_connection_sock.h:236: error: duplicate label `out'
Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Jason Baron <jbaron@redhat.com>
commit 6650239a4b01077e80d5a4468562756d77afaa59 upstream.
vm_map_ram() is not available on NOMMU platforms, and causes trouble
on incoherrent architectures such as ARM when we access the page data
through both the direct and the virtual mapping.
The alternative is to use the direct mapping to access page data
for the case when we are not crossing a page boundary, but to copy
the data into a linear scratch buffer when we are accessing data
that spans page boundaries.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit ca4ffe8f2848169a8ded0ea8a60b2d81925564c9 upstream.
After a module loads you will have loaded the world roaming regulatory
domain or a custom regulatory domain. Further regulatory hints are
welcomed and should be respected unless the regulatory hint is coming
from a country IE as the IEEE spec allows for a country IE to be a subset
of what is allowed by the local regulatory agencies.
So disable all channels that do not fit a regulatory domain sent
from a unless the hint is from a country IE and the country IE had
no information about the band we are currently processing.
This fixes a few regulatory issues, for example for drivers that depend
on CRDA and had no 5 GHz freqencies allowed were not properly disabling
5 GHz at all, furthermore it also allows users to restrict devices
further as was intended.
If you recieve a country IE upon association we will also disable the
channels that are not allowed if the country IE had at least one
channel on the respective band we are procesing.
This was the original intention behind this design but it was
completely overlooked...
Cc: David Quan <david.quan@atheros.com>
Cc: Jouni Malinen <jouni.malinen@atheros.com>
cc: Easwar Krishnan <easwar.krishnan@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 749b527b21465fb079796c03ffb4302584dc31c1 upstream.
We should be enabling country IE hints for WIPHY_FLAG_STRICT_REGULATORY
even if we haven't yet recieved regulatory domain hint for the driver
if it needed one. Without this Country IEs are not passed on to drivers
that have set WIPHY_FLAG_STRICT_REGULATORY, today this is just all
Atheros chipset drivers: ath5k, ath9k, ar9170, carl9170.
This was part of the original design, however it was completely
overlooked...
Cc: Easwar Krishnan <easwar.krishnan@atheros.com>
commit ac61c46f4f7665ab4548e90430c37b2529e16cff upstream.
If the compiled object doesn't include linux/scatterlist.h before
scsi/scsi.h, it will get an incorrect definition of
SCSI_MAX_SG_CHAIN_SEGMENTS.
Signed-off-by: David Dillow <dillowda@ornl.gov>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit d14fc1a74e846d7851f24fc9519fe87dc12a1231 upstream.
Alan's commit 335f8514f200e63d689113d29cb7253a5c282967 introduced
.carrier_raised function in several drivers. That also means
tty_port_block_til_ready can now suspend the process trying to open the serial
port when Carrier Detect is low and put it into tty_port.open_wait queue. We
need to wake up the process when Carrier Detect goes high and trigger TTY
hangup when CD goes low.
Some of the devices do not report modem status line changes, or at least we
don't understand the status message, so for those we remove .carrier_raised
again.
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] em28xx: radio_fops should also use unlocked_ioctl
[media] wm8775: Revert changeset fcb9757333 to avoid a regression
[media] cx25840: Prevent device probe failure due to volume control ERANGE error
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmaengine: provide dummy functions for DMA_ENGINE=n
mv_xor: fix race in tasklet function
It seems that cx88 and ivtv use wm8775 on some different modes. The
patch that added support for a board with wm8775 broke ivtv boards with
this device. As we're too close to release 2.6.37, let's just revert
it.
Reported-by: Andy Walls <awalls@md.metrocast.net>
Reported-by: Eric Sharkey <eric@lisaneric.org>
Reported-by: Auric <auric@aanet.com.au>
Reported by: David Gesswein <djg@pdp8online.com>
This lets drivers, optionally using the dmaengine, build with DMA_ENGINE
unselected.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
ipv4: dont create routes on down devices
epic100: hamachi: yellowfin: Fix skb allocation size
sundance: Fix oopses with corrupted skb_shared_info
Revert "ipv4: Allow configuring subnets as local addresses"
USB: mcs7830: return negative if auto negotiate fails
irda: prevent integer underflow in IRLMP_ENUMDEVICES
tcp: fix listening_get_next()
atl1c: Do not use legacy PCI power management
mac80211: fix mesh forwarding
MAINTAINERS: email address change
net: Fix range checks in tcf_valid_offset().
net_sched: sch_sfq: fix allot handling
hostap: remove netif_stop_queue from init
mac80211/rt2x00: add ieee80211_tx_status_ni()
typhoon: memory corruption in typhoon_get_drvinfo()
net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant
net_sched: always clone skbs
ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed.
netlink: fix gcc -Wconversion compilation warning
asix: add USB ID for Logitec LAN-GTJ U2A
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: print out alloc information with KERN_DEBUG instead of KERN_INFO
kthread_work: make lockdep happy
This reverts commit 4465b469008bc03b98a1b8df4e9ae501b6c69d4b.
net/ipv4/fib_frontend.c
As reported by Ben Greear, this causes regressions:
> Change 4465b469008bc03b98a1b8df4e9ae501b6c69d4b caused rules
> to stop matching the input device properly because the
> FLOWI_FLAG_MATCH_ANY_IIF is always defined in ip_dev_find().
> This breaks rules such as:
> ip rule add pref 512 lookup local
> ip rule del pref 0 lookup local
> ip link set eth2 up
> ip -4 addr add 172.16.0.102/24 broadcast 172.16.0.255 dev eth2
> ip rule add to 172.16.0.102 iif eth2 lookup local pref 10
> ip rule add iif eth2 lookup 10001 pref 20
> ip route add 172.16.0.0/24 dev eth2 table 10001
> ip route add unreachable 0/0 table 10001
> If you had a second interface 'eth0' that was on a different
> subnet, pinging a system on that interface would fail:
> [root@ct503-60 ~]# ping 192.168.100.1
> connect: Invalid argument
Reported-by: Ben Greear <greearb@candelatech.com>
The taskstats structure is internally aligned on 8 byte boundaries but the
layout of the aggregrate reply, with two NLA headers and the pid (each 4
bytes), actually force the entire structure to be unaligned. This causes
the kernel to issue unaligned access warnings on some architectures like
ia64. Unfortunately, some software out there doesn't properly unroll the
NLA packet and assumes that the start of the taskstats structure will
always be 20 bytes from the start of the netlink payload. Aligning the
start of the taskstats structure breaks this software, which we don't
want. So, for now the alignment only happens on architectures that
require it and those users will have to update to fixed versions of those
packages. Space is reserved in the packet only when needed. This ifdef
should be removed in several years e.g. 2012 once we can be confident
that fixed versions are installed on most systems. We add the padding
before the aggregate since the aggregate is already a defined type.
Commit 85893120 ("delayacct: align to 8 byte boundary on 64-bit systems")
previously addressed the alignment issues by padding out the pid field.
This was supposed to be a compatible change but the circumstances
described above mean that it wasn't. This patch backs out that change,
since it was a hack, and introduces a new NULL attribute type to provide
the padding. Padding the response with 4 bytes avoids allocating an
aligned taskstats structure and copying it back. Since the structure
weighs in at 328 bytes, it's too big to do it on the stack.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Brian Rogers <brian@xyzw.org>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Guillaume Chazarain <guichaz@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
The current packed struct implementation of unaligned access adds the
packed attribute only to the field within the unaligned struct rather than
to the struct as a whole. This is not sufficient to enforce proper
behaviour on architectures with a default struct alignment of more than
one byte.
For example, the current implementation of __get_unaligned_cpu16 when
compiled for arm with gcc -O1 -mstructure-size-boundary=32 assumes the
struct is on a 4 byte boundary so performs the load of the 16bit packed
field as if it were on a 4 byte boundary:
__get_unaligned_cpu16:
ldrh r0, [r0, #0]
bx lr
Moving the packed attribute to the struct rather than the field causes the
proper unaligned access code to be generated:
ldrb r3, [r0, #0] @ zero_extendqisi2
ldrb r0, [r0, #1] @ zero_extendqisi2
orr r0, r3, r0, asl #8
bx lr
Signed-off-by: Will Newton <will.newton@gmail.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6
spinlock in kthread_worker and wait_queue_head in kthread_work both
should be lockdep sensible, so change the interface to make it
suiltable for CONFIG_LOCKDEP.
tj: comment update
Reported-by: Nicolas <nicolas.mailhot@laposte.net>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Cc: Tejun Heo <tj@kernel.org>
This function has three bugs:
1) The offset should be valid most of the time, this is just
a sanity check, therefore we should use "likely" not "unlikely"
2) This is the only place where we can check for arithmetic overflow
of the pointer plus the length.
3) The existing range checks are off by one, the valid range is
skb->head to skb_tail_pointer(), inclusive.
Based almost entirely upon a patch by Ralph Loader.
Reported-by: Ralph Loader <suckfish@ihug.co.nz>
