commit 9d8924297cd9c256c23c02abae40202563452453 upstream.
This patch fixes a build error that occurs when CONFIG_PM is enabled
and CONFIG_PM_SLEEP isn't:
>> drivers/usb/host/ohci-pci.c:294:10: error: 'usb_hcd_pci_pm_ops' undeclared here (not in a function)
.pm = &usb_hcd_pci_pm_ops
Since the usb_hcd_pci_pm_ops structure is defined and used when
CONFIG_PM is enabled, its declaration should not be protected by
CONFIG_PM_SLEEP.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Yang Yingliang <yangyingliang@huawei.com>
commit e5b33dc9d16053c2ae4c2c669cf008829530364b upstream.
Add modem-status-change wait queue to struct usb_serial_port that
subdrivers can use to implement TIOCMIWAIT.
Currently subdrivers use a private wait queue which may have been
released when waking up after device disconnected.
Note that we're adding a new wait queue rather than reusing the tty-port
one as we do not want to get woken up at hangup (yet).
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 58569aee5a1a5dcc25c34a0a2ed9a377874e6b05 upstream.
The mv643xx ethernet controller limits the packet size for the TX
checksum offloading. This patch sets this limits for Kirkwood and
Dove which have smaller limits that the default.
As a side note, this patch is an updated version of a patch sent some years
ago: http://lists.infradead.org/pipermail/linux-arm-kernel/2010-June/017320.html
which seems to have been lost.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
[bwh: Backported to 3.2: adjust for the extra two parameters of
orion_ge0{0,1}_init()]
[yangyl: Backported to 3.4: Adjust context]
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
commit d6d7c873529abd622897cad5e36f1fd7d82f5110 upstream.
Commit b6787242f327 ("HID: hidraw: add proper error handling to raw event
reporting") forgot to update the static inline version of
hidraw_report_event() for the case when CONFIG_HIDRAW is unset. Fix that
up.
Cc: Yijing Wang <wangyijing@huawei.com>
commit b6787242f32700377d3da3b8d788ab3928bab849 upstream.
If kmemdup() in hidraw_report_event() fails, we are not propagating
this fact properly.
Let hidraw_report_event() and hid_report_raw_event() return an error
value to the caller.
Reported-by: Oliver Neukum <oneukum@suse.de>
commit 513b032c98b4b9414aa4e9b4a315cb1bf0380101 upstream.
The PPS serial line discipline wants to attach a PPS device to a tty
without changing the tty code to add a struct pps_device * pointer.
Since the number of PPS devices in a typical system is generally very low
(n=1 is by far the most common), it's practical to search the entire list
of allocated pps devices. (We capture the timestamp before the lookup,
so the timing isn't affected.)
It is a bit ugly that this function, which is part of the in-kernel
PPS API, has to be in pps.c as opposed to kapi,c, but that's not
something that affects users.
Signed-off-by: George Spelvin <linux@horizon.com>
Acked-by: Rodolfo Giometti <giometti@enneenne.com>
Cc: Qiang Huang <h.huangqiang@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
commit 9749f30f1a387070e6e8351f35aeb829eacc3ab6 upstream.
Inspired by the list_for_each_entry() macro
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
commit 4e9b45a19241354daec281d7a785739829b52359 upstream.
On 64 bit systems the test for negative message sizes is bogus as the
size, which may be positive when evaluated as a long, will get truncated
to an int when passed to load_msg(). So a long might very well contain a
positive value but when truncated to an int it would become negative.
That in combination with a small negative value of msg_ctlmax (which will
be promoted to an unsigned type for the comparison against msgsz, making
it a big positive value and therefore make it pass the check) will lead to
two problems: 1/ The kmalloc() call in alloc_msg() will allocate a too
small buffer as the addition of alen is effectively a subtraction. 2/ The
copy_from_user() call in load_msg() will first overflow the buffer with
userland data and then, when the userland access generates an access
violation, the fixup handler copy_user_handle_tail() will try to fill the
remainder with zeros -- roughly 4GB. That almost instantly results in a
system crash or reset.
,-[ Reproducer (needs to be run as root) ]--
| #include <sys/stat.h>
| #include <sys/msg.h>
| #include <unistd.h>
| #include <fcntl.h>
| int main(void) {
| long msg = 1;
| int fd;
| fd = open("/proc/sys/kernel/msgmax", O_WRONLY);
| write(fd, "-1", 2);
| close(fd);
| msgsnd(0, &msg, 0xfffffff0, IPC_NOWAIT);
| return 0;
Fix the issue by preventing msgsz from getting truncated by consistently
using size_t for the message length. This way the size checks in
do_msgsnd() could still be passed with a negative value for msg_ctlmax but
we would fail on the buffer allocation in that case and error out.
Also change the type of m_ts from int to size_t to avoid similar nastiness
in other code paths -- it is used in similar constructs, i.e. signed vs.
unsigned checks. It should never become negative under normal
circumstances, though.
Setting msg_ctlmax to a negative value is an odd configuration and should
be prevented. As that might break existing userland, it will be handled
in a separate commit so it could easily be reverted and reworked without
reintroducing the above described bug.
Hardening mechanisms for user copy operations would have catched that bug
early -- e.g. checking slab object sizes on user copy operations as the
usercopy feature of the PaX patch does. Or, for that matter, detect the
long vs. int sign change due to truncation, as the size overflow plugin
of the very same patch does.
[akpm@linux-foundation.org: fix i386 min() warnings]
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Pax Team <pageexec@freemail.hu>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
- Adjust context
- Drop changes to alloc_msg() and copy_msg(), which don't exist]
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
[hq: Backported to 3.4: Adjust context]
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
commit 3f3f8d2f48acfd8ed3b8e6b7377935da57b27b16 upstream.
Throughout compiler*.h, many version checks are made. These can be
simplified by using the macro that gcc's documentation recommends.
However, my primary reason for adding this is that I need bug-check
macros that are enabled at certain gcc versions and it's cleaner to use
this macro than the tradition method:
#if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ => 2)
If you add patch level, it gets this ugly:
#if __GNUC__ > 4 || (__GNUC__ == 4 && (__GNUC_MINOR__ > 2 || \
__GNUC_MINOR__ == 2 __GNUC_PATCHLEVEL__ >= 1))
As opposed to:
#if GCC_VERSION >= 40201
While having separate headers for gcc 3 & 4 eliminates some of this
verbosity, they can still be cleaned up by this.
See also:
http://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Acked-by: Borislav Petkov <bp@alien8.de>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Joe Perches <joe@perches.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 5a581b367b5df0531265311fc681c2abd377e5e6 upstream.
According to the C standard 3.4.3p3, overflow of a signed integer results
in undefined behavior. This commit therefore changes the definitions
of time_after(), time_after_eq(), time_after64(), and time_after_eq64()
to avoid this undefined behavior. The trick is that the subtraction
is done using unsigned arithmetic, which according to 6.2.5p9 cannot
overflow because it is defined as modulo arithmetic. This has the added
(though admittedly quite small) benefit of shortening four lines of code
by four characters each.
Note that the C standard considers the cast from unsigned to
signed to be implementation-defined, see 6.3.1.3p3. However, on a
two's-complement system, an implementation that defines anything other
than a reinterpretation of the bits is free to come to me, and I will be
happy to act as a witness for its being committed to an insane asylum.
(Although I have nothing against saturating arithmetic or signals in some
cases, these things really should not be the default when compiling an
operating-system kernel.)
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kevin Easton <kevin@guarana.org>
[ paulmck: Included time_after64() and time_after_eq64(), as suggested
by Eric Dumazet, also fixed commit message.]
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Ruchi Kandoi <kandoiruchi@google.com>
commit 70044d71d31d6973665ced5be04ef39ac1c09a48 upstream.
PREPARE_[DELAYED_]WORK() are being phased out. They have few users
and a nasty surprise in terms of reentrancy guarantee as workqueue
considers work items to be different if they don't have the same work
function.
firewire core-device and sbp2 have been been multiplexing work items
with multiple work functions. Introduce fw_device_workfn() and
sbp2_lu_workfn() which invoke fw_device->workfn and
sbp2_logical_unit->workfn respectively and always use the two
functions as the work functions and update the users to set the
->workfn fields instead of overriding work functions using
PREPARE_DELAYED_WORK().
This fixes a variety of possible regressions since a2c1c57be8d9
"workqueue: consider work function when searching for busy work items"
due to which fw_workqueue lost its required non-reentrancy property.
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: linux1394-devel@lists.sourceforge.net
commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream.
If a module fails to add its tracepoints due to module tainting, do not
create the module event infrastructure in the debugfs directory. As the events
will not work and worse yet, they will silently fail, making the user wonder
why the events they enable do not display anything.
Having a warning on module load and the events not visible to the users
will make the cause of the problem much clearer.
Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org
Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT"
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
the ring
commit 8d9256906a97c24e97e016482b9be06ea2532b05 upstream.
Backends may need to protect themselves against an insane number of
produced requests stored by a frontend, in case they iterate over
requests until reaching the req_prod value. There can't be more
requests on the ring than the difference between produced requests
and produced (but possibly not yet published) responses.
This is a more strict alternative to a patch previously posted by
Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 2810e5b9a7731ca5fce22bfbe12c96e16ac44b6f upstream.
This patch tries to coalesce tx requests when constructing grant copy
structures. It enables netback to deal with situation when frontend's
MAX_SKB_FRAGS is larger than backend's MAX_SKB_FRAGS.
With the help of coalescing, this patch tries to address two regressions
avoid reopening the security hole in XSA-39.
Regression 1. The reduction of the number of supported ring entries (slots)
per packet (from 18 to 17). This regression has been around for some time but
remains unnoticed until XSA-39 security fix. This is fixed by coalescing
slots.
Regression 2. The XSA-39 security fix turning "too many frags" errors from
just dropping the packet to a fatal error and disabling the VIF. This is fixed
by coalescing slots (handling 18 slots when backend's MAX_SKB_FRAGS is 17)
which rules out false positive (using 18 slots is legit) and dropping packets
using 19 to `max_skb_slots` slots.
To avoid reopening security hole in XSA-39, frontend sending packet using more
than max_skb_slots is considered malicious.
The behavior of netback for packet is thus:
1-18 slots: valid
19-max_skb_slots slots: drop and respond with an error
max_skb_slots+ slots: fatal error
max_skb_slots is configurable by admin, default value is 20.
Also change variable name from "frags" to "slots" in netbk_count_requests.
Please note that RX path still has dependency on MAX_SKB_FRAGS. This will be
fixed with separate patch.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
commit c378f70adbc1bbecd9e6db145019f14b2f688c7c upstream.
Currently, when a disconnect is requested by the user (via NBD_DISCONNECT
ioctl) the return from NBD_DO_IT is undefined (it is usually one of
several error codes). This means that nbd-client does not know if a
manual disconnect was performed or whether a network error occurred.
Because of this, nbd-client's persist mode (which tries to reconnect after
error, but not after manual disconnect) does not always work correctly.
This change fixes this by causing NBD_DO_IT to always return 0 if a user
requests a disconnect. This means that nbd-client can correctly either
persist the connection (if an error occurred) or disconnect (if the user
requested it).
Signed-off-by: Paul Clements <paul.clements@steeleye.com>
Acked-by: Rob Landley <rob@landley.net>
[xr: Backported to 3.4: adjust context]
Signed-off-by: Rui Xiang <rui.xiang@huawei.com>
commit d76a3a77113db020d9bb1e894822869410450bd9 upstream.
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
[bwh: Backported to 3.2: adjust context]
Cc: Rui Xiang <rui.xiang@huawei.com>
commit 14611e51a57df10240817d8ada510842faf0ec51 upstream.
task->cgroups is a RCU pointer pointing to struct css_set. A task
switches to a different css_set on cgroup migration but a css_set
doesn't change once created and its pointers to cgroup_subsys_states
aren't RCU protected.
task_subsys_state[_check]() is the macro to acquire css given a task
and subsys_id pair. It RCU-dereferences task->cgroups->subsys[] not
task->cgroups, so the RCU pointer task->cgroups ends up being
dereferenced without read_barrier_depends() after it. It's broken.
Fix it by introducing task_css_set[_check]() which does
RCU-dereference on task->cgroups. task_subsys_state[_check]() is
reimplemented to directly dereference ->subsys[] of the css_set
returned from task_css_set[_check]().
This removes some of sparse RCU warnings in cgroup.
v2: Fixed unbalanced parenthsis and there's no need to use
rcu_dereference_raw() when !CONFIG_PROVE_RCU. Both spotted by Li.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Li Zefan <lizefan@huawei.com>
- Adjust context
- Remove CONFIG_PROVE_RCU condition
- s/lockdep_is_held(&cgroup_mutex)/cgroup_lock_is_held()/]
css_set
commit 5edee61edeaaebafe584f8fb7074c1ef4658596b upstream.
cgroup core has a bug which violates a basic rule about event
notifications - when a new entity needs to be added, you add that to
the notification list first and then make the new entity conform to
the current state. If done in the reverse order, an event happening
inbetween will be lost.
cgroup_subsys->fork() is invoked way before the new task is added to
the css_set. Currently, cgroup_freezer is the only user of ->fork()
and uses it to make new tasks conform to the current state of the
freezer. If FROZEN state is requested while fork is in progress
between cgroup_fork_callbacks() and cgroup_post_fork(), the child
could escape freezing - the cgroup isn't frozen when ->fork() is
called and the freezer couldn't see the new task on the css_set.
This patch moves cgroup_subsys->fork() invocation to
cgroup_post_fork() after the new task is added to the css_set.
cgroup_fork_callbacks() is removed.
Because now a task may be migrated during cgroup_subsys->fork(),
freezer_fork() is updated so that it adheres to the usual RCU locking
and the rather pointless comment on why locking can be different there
is removed (if it doesn't make anything simpler, why even bother?).
Cc: Rafael J. Wysocki <rjw@sisk.pl>
- Adjust context
- Iterate over first CGROUP_BUILTIN_SUBSYS_COUNT elements of subsys]
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
[ use zero netdev_feature mask to avoid backport of
netif_skb_dev_features function ]
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.4, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
commit 5aaa0b7a2ed5b12692c9ffb5222182bd558d3146 upstream.
Follow up on commit 556061b00 ("sched/nohz: Fix rq->cpu_load[]
calculations") since while that fixed the busy case it regressed the
mostly idle case.
Add a callback from the nohz exit to also age the rq->cpu_load[]
array. This closes the hole where either there was no nohz load
balance pass during the nohz, or there was a 'significant' amount of
idle time between the last nohz balance and the nohz exit.
So we'll update unconditionally from the tick to not insert any
accidental 0 load periods while busy, and we try and catch up from
nohz idle balance and nohz exit. Both these are still prone to missing
a jiffy, but that has always been the case.
Cc: pjt@google.com
Cc: Venkatesh Pallipadi <venki@google.com>
Link: http://lkml.kernel.org/n/tip-kt0trz0apodbf84ucjfdbr1a@git.kernel.org
commit 57d2aa00dcec67afa52478730f2b524521af14fb upstream.
The issue below was found in 2.6.34-rt rather than mainline rt
kernel, but the issue still exists upstream as well.
So please let me describe how it was noticed on 2.6.34-rt:
On this version, each softirq has its own thread, it means there
is at least one RT FIFO task per cpu. The priority of these
tasks is set to 49 by default. If user launches an RT FIFO task
with priority lower than 49 of softirq RT tasks, it's possible
there are two RT FIFO tasks enqueued one cpu runqueue at one
moment. By current strategy of balancing RT tasks, when it comes
to RT tasks, we really need to put them off to a CPU that they
can run on as soon as possible. Even if it means a bit of cache
line flushing, we want RT tasks to be run with the least latency.
When the user RT FIFO task which just launched before is
running, the sched timer tick of the current cpu happens. In this
tick period, the timeout value of the user RT task will be
updated once. Subsequently, we try to wake up one softirq RT
task on its local cpu. As the priority of current user RT task
is lower than the softirq RT task, the current task will be
preempted by the higher priority softirq RT task. Before
preemption, we check to see if current can readily move to a
different cpu. If so, we will reschedule to allow the RT push logic
to try to move current somewhere else. Whenever the woken
softirq RT task runs, it first tries to migrate the user FIFO RT
task over to a cpu that is running a task of lesser priority. If
migration is done, it will send a reschedule request to the found
cpu by IPI interrupt. Once the target cpu responds the IPI
interrupt, it will pick the migrated user RT task to preempt its
current task. When the user RT task is running on the new cpu,
the sched timer tick of the cpu fires. So it will tick the user
RT task again. This also means the RT task timeout value will be
updated again. As the migration may be done in one tick period,
it means the user RT task timeout value will be updated twice
within one tick.
If we set a limit on the amount of cpu time for the user RT task
by setrlimit(RLIMIT_RTTIME), the SIGXCPU signal should be posted
upon reaching the soft limit.
But exactly when the SIGXCPU signal should be sent depends on the
RT task timeout value. In fact the timeout mechanism of sending
the SIGXCPU signal assumes the RT task timeout is increased once
every tick.
However, currently the timeout value may be added twice per
tick. So it results in the SIGXCPU signal being sent earlier
than expected.
To solve this issue, we prevent the timeout value from increasing
twice within one tick time by remembering the jiffies value of
last updating the timeout. As long as the RT task's jiffies is
different with the global jiffies value, we allow its timeout to
be updated.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Fan Du <fan.du@windriver.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1342508623-2887-1-git-send-email-ying.xue@windriver.com
[ lizf: backported to 3.4: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit aad560b7f63b495f48a7232fd086c5913a676e6f upstream.
At IO preparation we calculate the max pages at each device and
allocate a BIO per device of that size. The calculation was wrong
on some unaligned corner cases offset/length combination and would
make prepare return with -ENOMEM. This would be bad for pnfs-objects
that would in that case IO through MDS. And fatal for exofs were it
would fail writes with EIO.
Fix it by doing the proper math, that will work in all cases. (I
ran a test with all possible offset/length combinations this time
round).
Also when reading we do not need to allocate for the parity units
since we jump over them.
Also lower the max_io_length to take into account the parity pages
so not to allocate BIOs bigger than PAGE_SIZE
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit 06bdadd7634551cfe8ce071fe44d0311b3033d9e upstream.
audit_syscall_exit() saves a result of regs_return_value() in intermediate
"int" variable and passes it to __audit_syscall_exit(), which expects its
second argument as a "long" value. This will result in truncating the
value returned by a system call and making a wrong audit record.
I don't know why gcc compiler doesn't complain about this, but anyway it
causes a problem at runtime on arm64 (and probably most 64-bit archs).
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 27c73ae759774e63313c1fbfeb17ba076cea64c5 upstream.
Commit 7cb2ef56e6a8 ("mm: fix aio performance regression for database
caused by THP") can cause dereference of a dangling pointer if
split_huge_page runs during PageHuge() if there are updates to the
tail_page->private field.
Also it is repeating compound_head twice for hugetlbfs and it is running
compound_head+compound_trans_head for THP when a single one is needed in
both cases.
The new code within the PageSlab() check doesn't need to verify that the
THP page size is never bigger than the smallest hugetlbfs page size, to
avoid memory corruption.
A longstanding theoretical race condition was found while fixing the
above (see the change right after the skip_unlock label, that is
relevant for the compound_lock path too).
By re-establishing the _mapcount tail refcounting for all compound
pages, this also fixes the below problem:
echo 0 >/sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages
BUG: Bad page state in process bash pfn:59a01
page:ffffea000139b038 count:0 mapcount:10 mapping: (null) index:0x0
page flags: 0x1c00000000008000(tail)
Modules linked in:
CPU: 6 PID: 2018 Comm: bash Not tainted 3.12.0+ #25
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x55/0x76
bad_page+0xd5/0x130
free_pages_prepare+0x213/0x280
__free_pages+0x36/0x80
update_and_free_page+0xc1/0xd0
free_pool_huge_page+0xc2/0xe0
set_max_huge_pages.part.58+0x14c/0x220
nr_hugepages_store_common.isra.60+0xd0/0xf0
nr_hugepages_store+0x13/0x20
kobj_attr_store+0xf/0x20
sysfs_write_file+0x189/0x1e0
vfs_write+0xc5/0x1f0
SyS_write+0x55/0xb0
system_call_fastpath+0x16/0x1b
Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Guillaume Morin <guillaume@morinfr.org>
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ]
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
[ Upstream commit 12663bfc97c8b3fdb292428105dd92d563164050 ]
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream.
Fixes rendering corruption due to incorrect
gfx configuration.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=63599
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 932e9dec380c67ec15ac3eb073bb55797d8b4801 upstream.
When running a 32bit kernel the hda_intel driver is still reporting
a 64bit dma_mask if the HW supports it.
From sound/pci/hda/hda_intel.c:
/* allow 64bit DMA address if supported by H/W */
if ((gcap & ICH6_GCAP_64OK) && !pci_set_dma_mask(pci, DMA_BIT_MASK(64)))
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(64));
else {
pci_set_dma_mask(pci, DMA_BIT_MASK(32));
pci_set_consistent_dma_mask(pci, DMA_BIT_MASK(32));
which means when there is a call to dma_alloc_coherent from
snd_malloc_dev_pages a machine address bigger than 32bit can be returned.
This can be true in particular if running the 32bit kernel as a pv dom0
under the Xen Hypervisor or PAE on bare metal.
The problem is that when calling setup_bdle to program the BLE the
dma_addr_t returned from the dma_alloc_coherent is wrongly truncated
from snd_sgbuf_get_addr if running a 32bit kernel:
static inline dma_addr_t snd_sgbuf_get_addr(struct snd_dma_buffer *dmab,
size_t offset)
struct snd_sg_buf *sgbuf = dmab->private_data;
dma_addr_t addr = sgbuf->table[offset >> PAGE_SHIFT].addr;
addr &= PAGE_MASK;
return addr + offset % PAGE_SIZE;
where PAGE_MASK in a 32bit kernel is zeroing the upper 32bit af addr.
Without this patch the HW will fetch the 32bit truncated address,
which is not the one obtained from dma_alloc_coherent and will result
to a non working audio but can corrupt host memory at a random location.
The current patch apply to v3.13-rc3-74-g6c843f5
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Reviewed-by: Frediano Ziglio <frediano.ziglio@citrix.com>
commit 389a5390583a18e45bc4abd4439291abec5e7a63 upstream.
Now that scatterwalk_sg_chain sets the chain pointer bit the sg_page
call in scatterwalk_sg_next hits a BUG_ON when CONFIG_DEBUG_SG is
enabled. Use sg_chain_ptr instead of sg_page on a chain entry.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 41da8b5adba77e22584f8b45f9641504fa885308 upstream.
The scatterwalk_crypto_chain function invokes the scatterwalk_sg_chain
function to chain two scatterlists, but the chain pointer indication
bit is not set. When the resulting scatterlist is used, for example,
by sg_nents to count the number of scatterlist entries, a segfault occurs
because sg_nents does not follow the chain pointer to the chained scatterlist.
Update scatterwalk_sg_chain to set the chain pointer indication bit as is
done by the sg_chain function.
commit fd7c092e711ebab55b2688d3859d95dfd0301f73 upstream.
Avoid returning a truncated table or status string instead of setting
the DM_BUFFER_FULL_FLAG when the last target of a table fills the
buffer.
When processing a table or status request, the function retrieve_status
calls ti->type->status. If ti->type->status returns non-zero,
retrieve_status assumes that the buffer overflowed and sets
DM_BUFFER_FULL_FLAG.
However, targets don't return non-zero values from their status method
on overflow. Most targets returns always zero.
If a buffer overflow happens in a target that is not the last in the
table, it gets noticed during the next iteration of the loop in
retrieve_status; but if a buffer overflow happens in the last target, it
goes unnoticed and erroneously truncated data is returned.
In the current code, the targets behave in the following way:
* dm-crypt returns -ENOMEM if there is not enough space to store the
key, but it returns 0 on all other overflows.
* dm-thin returns errors from the status method if a disk error happened.
This is incorrect because retrieve_status doesn't check the error
code, it assumes that all non-zero values mean buffer overflow.
* all the other targets always return 0.
This patch changes the ti->type->status function to return void (because
most targets don't use the return code). Overflow is detected in
retrieve_status: if the status method fills up the remaining space
completely, it is assumed that buffer overflow happened.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
functions
[ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ]
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ]
For properly initialising the Tausworthe generator [1], we have
a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15.
Commit 697f8d0348 ("random32: seeding improvement") introduced
a __seed() function that imposes boundary checks proposed by the
errata paper [2] to properly ensure above conditions.
However, we're off by one, as the function is implemented as:
"return (x < m) ? x + m : x;", and called with __seed(X, 1),
__seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15
would be possible, whereas the lower boundary should actually
be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise
an initialization with an unwanted seed could have the effect
that Tausworthe's PRNG properties cannot not be ensured.
Note that this PRNG is *not* used for cryptography in the kernel.
[1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps
[2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps
Joint work with Hannes Frederic Sowa.
Fixes: 697f8d0348a6 ("random32: seeding improvement")
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
commit 4e58e54754dc1fec21c3a9e824bc108b05fdf46e upstream.
If an TRACE_EVENT() uses __assign_str() or __get_str on a NULL pointer
then the following oops will happen:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<c127a17b>] strlen+0x10/0x1a
*pde = 00000000 ^M
Oops: 0000 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.13.0-rc1-test+ #2
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006^M
task: f5cde9f0 ti: f5e5e000 task.ti: f5e5e000
EIP: 0060:[<c127a17b>] EFLAGS: 00210046 CPU: 1
EIP is at strlen+0x10/0x1a
EAX: 00000000 EBX: c2472da8 ECX: ffffffff EDX: c2472da8
ESI: c1c5e5fc EDI: 00000000 EBP: f5e5fe84 ESP: f5e5fe80
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000000 CR3: 01f32000 CR4: 000007d0
Stack:
f5f18b90 f5e5feb8 c10687a8 0759004f 00000005 00000005 00000005 00200046
00000002 00000000 c1082a93 f56c7e28 c2472da8 c1082a93 f5e5fee4 c106bc61^M
00000000 c1082a93 00000000 00000000 00000001 00200046 00200082 00000000
Call Trace:
[<c10687a8>] ftrace_raw_event_lock+0x39/0xc0
[<c1082a93>] ? ktime_get+0x29/0x69
[<c106bc61>] lock_release+0x57/0x1a5
[<c10824dd>] read_seqcount_begin.constprop.7+0x4d/0x75
[<c1082a93>] ? ktime_get+0x29/0x69^M
[<c1082a93>] ktime_get+0x29/0x69
[<c108a46a>] __tick_nohz_idle_enter+0x1e/0x426
[<c10690e8>] ? lock_release_holdtime.part.19+0x48/0x4d
[<c10bc184>] ? time_hardirqs_off+0xe/0x28
[<c1068c82>] ? trace_hardirqs_off_caller+0x3f/0xaf
[<c108a8cb>] tick_nohz_idle_enter+0x59/0x62
[<c1079242>] cpu_startup_entry+0x64/0x192
[<c102299c>] start_secondary+0x277/0x27c
Code: 90 89 c6 89 d0 88 c4 ac 38 e0 74 09 84 c0 75 f7 be 01 00 00 00 89 f0 48 5e 5d c3 55 89 e5 57 66 66 66 66 90 83 c9 ff 89 c7 31 c0 <f2> ae f7 d1 8d 41 ff 5f 5d c3 55 89 e5 57 66 66 66 66 90 31 ff
EIP: [<c127a17b>] strlen+0x10/0x1a SS:ESP 0068:f5e5fe80
CR2: 0000000000000000
---[ end trace 01bc47bf519ec1b2 ]---
New tracepoints have been added that have allowed for NULL pointers
being assigned to strings. To fix this, change the TRACE_EVENT() code
to check for NULL and if it is, it will assign "(null)" to it instead
(similar to what glibc printf does).
Reported-by: Shuah Khan <shuah.kh@samsung.com>
Reported-by: Jovi Zhangwei <jovi.zhangwei@gmail.com>
Link: http://lkml.kernel.org/r/CAGdX0WFeEuy+DtpsJzyzn0343qEEjLX97+o1VREFkUEhndC+5Q@mail.gmail.com
Link: http://lkml.kernel.org/r/528D6972.9010702@samsung.com
Fixes: 9cbf117662e2 ("tracing/events: provide string with undefined size support")
commit a4d62babf988fe5dfde24437fa135ef147bc7aa0 upstream.
Hardware:
CPU: XLP832,the 64-bit OS
NOR Flash:S29GL128S 128M
Software:
Kernel:2.6.32.41
Filesystem:JFFS2
When writing files, errors appear:
Write len 182 but return retlen 180
Write of 182 bytes at 0x072c815c failed. returned -5, retlen 180
Write len 186 but return retlen 184
Write of 186 bytes at 0x072caff4 failed. returned -5, retlen 184
These errors exist only in 64-bit systems,not in 32-bit systems. After analysis, we
found that the left shift operation is wrong in map_word_load_partial. For instance:
unsigned char buf[3] ={0x9e,0x3a,0xea};
map_bankwidth(map) is 4;
for (i=0; i < 3; i++) {
int bitpos;
bitpos = (map_bankwidth(map)-1-i)*8;
orig.x[0] &= ~(0xff << bitpos);
orig.x[0] |= buf[i] << bitpos;
The value of orig.x[0] is expected to be 0x9e3aeaff, but in this situation(64-bit
System) we'll get the wrong value of 0xffffffff9e3aeaff due to the 64-bit sign
extension:
buf[i] is defined as "unsigned char" and the left-shift operation will convert it
to the type of "signed int", so when left-shift buf[i] by 24 bits, the final result
will get the wrong value: 0xffffffff9e3aeaff.
If the left-shift bits are less than 24, then sign extension will not occur. Whereas
the bankwidth of the nor flash we used is 4, therefore this BUG emerges.
Signed-off-by: Pang Xunlei <pang.xunlei@zte.com.cn>
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Signed-off-by: Lu Zhongjun <lu.zhongjun@zte.com.cn>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit d049f74f2dbe71354d43d393ac3a188947811348 upstream.
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 74e3d1e17b2e11d175970b85acd44f5927000ba2 upstream.
Two rt tasks bind to one CPU core.
The higher priority rt task A preempts a lower priority rt task B which
has already taken the write seq lock, and then the higher priority rt
task A try to acquire read seq lock, it's doomed to lockup.
rt task A with lower priority: call write
i_size_write rt task B with higher priority: call sync, and preempt task A
write_seqcount_begin(&inode->i_size_seqcount); i_size_read
inode->i_size = i_size; read_seqcount_begin <-- lockup here...
So disable preempt when acquiring every i_size_seqcount *write* lock will
cure the problem.
Cc: Zhao Hongjiang <zhaohongjiang@huawei.com>
commit e56fb2874015370e3b7f8d85051f6dce26051df9 upstream.
threadgroup_lock() takes signal->cred_guard_mutex to ensure that
thread_group_leader() is stable. This doesn't look nice, the scope of
this lock in do_execve() is huge.
And as Dave pointed out this can lead to deadlock, we have the
following dependencies:
do_execve: cred_guard_mutex -> i_mutex
cgroup_mount: i_mutex -> cgroup_mutex
attach_task_by_pid: cgroup_mutex -> cred_guard_mutex
Change de_thread() to take threadgroup_change_begin() around the
switch-the-leader code and change threadgroup_lock() to avoid
->cred_guard_mutex.
Note that de_thread() can't sleep with ->group_rwsem held, this can
obviously deadlock with the exiting leader if the writer is active, so it
does threadgroup_change_end() before schedule().
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org>
[ zhj: adjust context ]
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit f2e5ddcc0d12f9c4c7b254358ad245c9dddce13b ]
When CONFIG_NETLABEL is disabled, the cipso_v4_validate() function could loop
forever in the main loop if opt[opt_iter +1] == 0, this will causing a kernel
crash in an SMP system, since the CPU executing this function will
stall /not respond to IPIs.
This problem can be reproduced by running the IP Stack Integrity Checker
(http://isic.sourceforge.net) using the following command on a Linux machine
connected to DUT:
"icmpsic -s rand -d <DUT IP address> -r 123456"
wait (1-2 min)
Signed-off-by: Seif Mazareeb <seif@marvell.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit e87b3998d795123b4139bc3f25490dd236f68212 ]
dst->xfrm is conditionally defined. Provide accessor funtion that
is always available.
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit c52e2421f7368fd36cbe330d2cf41b10452e39a9 ]
TCP stack should make sure it owns skbs before mangling them.
We had various crashes using bnx2x, and it turned out gso_size
was cleared right before bnx2x driver was populating TC descriptor
of the _previous_ packet send. TCP stack can sometime retransmit
packets that are still in Qdisc.
Of course we could make bnx2x driver more robust (using
ACCESS_ONCE(shinfo->gso_size) for example), but the bug is TCP stack.
We have identified two points where skb_unclone() was needed.
This patch adds a WARN_ON_ONCE() to warn us if we missed another
fix of this kind.
Kudos to Neal for finding the root cause of this bug. Its visible
using small MSS.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
commit 4b59e6c4730978679b414a8da61514a2518da512 upstream.
On large systems with a lot of memory, walking all RAM to determine page
types may take a half second or even more.
In non-blockable contexts, the page allocator will emit a page allocation
failure warning unless __GFP_NOWARN is specified. In such contexts, irqs
are typically disabled and such a lengthy delay may even result in NMI
watchdog timeouts.
To fix this, suppress the page walk in such contexts when printing the
page allocation failure warning.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
commit 3f1f33206c16c7b3839d71372bc2ac3f305aa802 upstream.
Stephane thought the perf_cpu_context::active_pmu name confusing and
suggested using 'unique_pmu' instead.
This pointer is a pointer to a 'random' pmu sharing the cpuctx
instance, therefore limiting a for_each_pmu loop to those where
cpuctx->unique_pmu matches the pmu we get a loop over unique cpuctx
instances.
Suggested-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-kxyjqpfj2fn9gt7kwu5ag9ks@git.kernel.org
