commit 50ab8ec74a153eb30db26529088bc57dd700b24c upstream.
See http: //www.infradead.org/rpr.html
X-Evolution-Source: 1451162204.2173.11@leira.trondhjem.org
Content-Transfer-Encoding: 8bit
Mime-Version: 1.0
We support OFFSET_MAX just fine, so don't round down below it. Also
switch to using min_t to make the helper more readable.
Fixes: 433c92379d9c ("NFS: Clean up nfs_size_to_loff_t()")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit aa226ff4a1ce79f229c6b7a4c0a14e17fececd01 upstream.
There are three subsystem callbacks in css shutdown path -
css_offline(), css_released() and css_free(). Except for
css_released(), cgroup core didn't guarantee the order of invocation.
css_offline() or css_free() could be called on a parent css before its
children. This behavior is unexpected and led to bugs in cpu and
memory controller.
This patch updates offline path so that a parent css is never offlined
before its children. Each css keeps online_cnt which reaches zero iff
itself and all its children are offline and offline_css() is invoked
only after online_cnt reaches zero.
This fixes the memory controller bug and allows the fix for cpu
controller.
Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reported-by: Brian Christiansen <brian.o.christiansen@gmail.com>
Link: http://lkml.kernel.org/g/5698A023.9070703@de.ibm.com
Link: http://lkml.kernel.org/g/CAKB58ikDkzc8REt31WBkD99+hxNzjK4+FBmhkgS+NVrC9vjMSg@mail.gmail.com
commit e93ad19d05648397ef3bcb838d26aec06c245dc0 upstream.
If "cpuset.memory_migrate" is set, when a process is moved from one
cpuset to another with a different memory node mask, pages in used by
the process are migrated to the new set of nodes. This was performed
synchronously in the ->attach() callback, which is synchronized
against process management. Recently, the synchronization was changed
from per-process rwsem to global percpu rwsem for simplicity and
optimization.
Combined with the synchronous mm migration, this led to deadlocks
because mm migration could schedule a work item which may in turn try
to create a new worker blocking on the process management lock held
from cgroup process migration path.
This heavy an operation shouldn't be performed synchronously from that
deep inside cgroup migration in the first place. This patch punts the
actual migration to an ordered workqueue and updates cgroup process
migration and cpuset config update paths to flush the workqueue after
all locks are released. This way, the operations still seem
synchronous to userland without entangling mm migration with process
management synchronization. CPU hotplug can also invoke mm migration
but there's no reason for it to wait for mm migrations and thus
doesn't synchronize against their completions.
commit 0f4a943168f31d29a1701908931acaba518b131a upstream.
To address the bug where fabric driver level shutdown
of se_cmd occurs at the same time when TMR CMD_T_ABORTED
is happening resulting in a -1 ->cmd_kref, this patch
adds a CMD_T_FABRIC_STOP bit that is used to determine
when TMR + driver I_T nexus shutdown is happening
concurrently.
It changes target_sess_cmd_list_set_waiting() to obtain
se_cmd->cmd_kref + set CMD_T_FABRIC_STOP, and drop local
reference in target_wait_for_sess_cmds() and invoke extra
target_put_sess_cmd() during Task Aborted Status (TAS)
when necessary.
Also, it adds a new target_wait_free_cmd() wrapper around
transport_wait_for_tasks() for the special case within
transport_generic_free_cmd() to set CMD_T_FABRIC_STOP,
and is now aware of CMD_T_ABORTED + CMD_T_TAS status
bits to know when an extra transport_put_cmd() during
TAS is required.
Note transport_generic_free_cmd() is expected to block on
cmd->cmd_wait_comp in order to follow what iscsi-target
expects during iscsi_conn context se_cmd shutdown.
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Himanshu Madhani <himanshu.madhani@qlogic.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <mchristi@redhat.com>
Signed-off-by: Nicholas Bellinger <nab@daterainc.com>
commit febe562c20dfa8f33bee7d419c6b517986a5aa33 upstream.
This patch fixes a NULL pointer se_cmd->cmd_kref < 0
refcount bug during TMR LUN_RESET with active se_cmd
I/O, that can be triggered during se_cmd descriptor
shutdown + release via core_tmr_drain_state_list() code.
To address this bug, add common __target_check_io_state()
helper for ABORT_TASK + LUN_RESET w/ CMD_T_COMPLETE
checking, and set CMD_T_ABORTED + obtain ->cmd_kref for
both cases ahead of last target_put_sess_cmd() after
TFO->aborted_task() -> transport_cmd_finish_abort()
callback has completed.
It also introduces SCF_ACK_KREF to determine when
transport_cmd_finish_abort() needs to drop the second
extra reference, ahead of calling target_put_sess_cmd()
for the final kref_put(&se_cmd->cmd_kref).
It also updates transport_cmd_check_stop() to avoid
holding se_cmd->t_state_lock while dropping se_cmd
device state via target_remove_from_state_list(), now
that core_tmr_drain_state_list() is holding the
se_device lock while checking se_cmd state from
within TMR logic.
Finally, move transport_put_cmd() release of SGL +
TMR + extended CDB memory into target_free_cmd_mem()
in order to avoid potential resource leaks in TMR
ABORT_TASK + LUN_RESET code-paths. Also update
target_release_cmd_kref() accordingly.
Reviewed-by: Quinn Tran <quinn.tran@qlogic.com>
commit 67645d7619738e51c668ca69f097cb90b5470422 upstream.
There are a number of problems with revoking a "was sending" message:
(1) We never make any attempt to revoke data - only kvecs contibute to
con->out_skip. However, once the header (envelope) is written to the
socket, our peer learns data_len and sets itself to expect at least
data_len bytes to follow front or front+middle. If ceph_msg_revoke()
is called while the messenger is sending message's data portion,
anything we send after that call is counted by the OSD towards the now
revoked message's data portion. The effects vary, the most common one
is the eventual hang - higher layers get stuck waiting for the reply to
the message that was sent out after ceph_msg_revoke() returned and
treated by the OSD as a bunch of data bytes. This is what Matt ran
into.
(2) Flat out zeroing con->out_kvec_bytes worth of bytes to handle kvecs
is wrong. If ceph_msg_revoke() is called before the tag is sent out or
while the messenger is sending the header, we will get a connection
reset, either due to a bad tag (0 is not a valid tag) or a bad header
CRC, which kind of defeats the purpose of revoke. Currently the kernel
client refuses to work with header CRCs disabled, but that will likely
change in the future, making this even worse.
(3) con->out_skip is not reset on connection reset, leading to one or
more spurious connection resets if we happen to get a real one between
con->out_skip is set in ceph_msg_revoke() and before it's cleared in
write_partial_skip().
Fixing (1) and (3) is trivial. The idea behind fixing (2) is to never
zero the tag or the header, i.e. send out tag+header regardless of when
ceph_msg_revoke() is called. That way the header is always correct, no
unnecessary resets are induced and revoke stands ready for disabled
CRCs. Since ceph_msg_revoke() rips out con->out_msg, introduce a new
"message out temp" and copy the header into it before sending.
Reported-by: Matt Conner <matt.conner@keepertech.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Tested-by: Matt Conner <matt.conner@keepertech.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 4511f7166a2deb5f7a578cf87fd2fe1ae83527e3 upstream.
When a new cooling device is registered, we need to update the
thermal zone to set the new registered cooling device to a proper
state.
This fixes a problem that the system is cool, while the fan devices
are left running on full speed after boot, if fan device is registered
after thermal zone device.
Here is the history of why current patch looks like this:
https://patchwork.kernel.org/patch/7273041/
Reference:https://bugzilla.kernel.org/show_bug.cgi?id=92431
Tested-by: Manuel Krause <manuelkrause@netscape.net>
Tested-by: szegad <szegadlo@poczta.onet.pl>
Tested-by: prash <prash.n.rao@gmail.com>
Tested-by: amish <ammdispose-arch@yahoo.com>
Reviewed-by: Javi Merino <javi.merino@arm.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
commit bb431ba26c5cd0a17c941ca6c3a195a3a6d5d461 upstream.
After thermal zone device registered, as we have not read any
temperature before, thus tz->temperature should not be 0,
which actually means 0C, and thermal trend is not available.
In this case, we need specially handling for the first
thermal_zone_device_update().
Both thermal core framework and step_wise governor is
enhanced to handle this. And since the step_wise governor
is the only one that uses trends, so it's the only thermal
governor that needs to be updated.
Tested-by: Matthias <morpheusxyz123@yahoo.de>
commit a9cf8284b45110a4d98aea180a89c857e53bf850 upstream.
Commit 9d99a8dda154 ("nvme: move hardware structures out of the uapi
version of nvme.h") renamed nvme.h to nvme_ioctl.h, but the uapi list
still refers to nvme.h. People trying to install the headers hit a
failure as the header no longer exists.
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 3ed47db34f480df7caf44436e3e63e555351ae9a upstream.
commit 4b0e4e4af6c6dc8354dcb72182d52c1bc55f12fc upstream.
Reviewed-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
commit 5e93b8208d3c419b515fb75e2601931c027e12ab upstream.
Previous implementation does not handle case below: boot up one MST branch
to DP connector of ASIC. After boot up, hot plug 2nd MST branch to DP output
of 1st MST, GUID is not created for 2nd MST branch. When downstream port of
2nd MST branch send upstream request, it fails because 2nd MST branch GUID
is not available.
New Implementation: only create GUID for MST branch and save it within Branch.
Signed-off-by: Hersen Wu <hersenxs.wu@amd.com>
Reviewed-by: Harry Wentland <harry.wentland@amd.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
commit 64566b5e767f9bc3161055ca1b443a51afb52aad upstream.
drm_fixp_from_fraction allows us to create a fixed point directly
from a fraction, rather than creating fixed point values and dividing
later. This avoids overflow of our 64 bit value for large numbers.
drm_fixp2int_ceil allows us to return the ceiling of our fixed point
value.
[airlied: squash Jordan's fix]
32-bit-build-fix: Jordan Lazare <Jordan.Lazare@amd.com>
Signed-off-by: Harry Wentland <harry.wentland@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 1f16ee7fa13649f4e55aa48ad31c3eb0722a62d3 upstream.
We should always send reply for UP request in order
to make downstream device clean-up resources appropriately.
Issue was that reply for UP request was sent only once.
Acked-by: Dave Airlie <airlied@gmail.com>
Signed-off-by: Mykola Lysenko <Mykola.Lysenko@amd.com>
commit 0f26922fe5dc5724b1adbbd54b21bad03590b4f3 upstream.
The datatype __kernel_time_t is u32 on 32bit platform, so its subject to
overflows in the timeval/timespec to cputime conversion.
Currently the following functions are affected:
1. setitimer()
2. timer_create/timer_settime()
3. sys_clock_nanosleep
This can happen on MIPS32 and ARM32 with "Full dynticks CPU time accounting"
enabled, which is required for CONFIG_NO_HZ_FULL.
Enforce u64 conversion to prevent the overflow.
Fixes: 31c1fc818715 ("ARM: Kconfig: allow full nohz CPU accounting")
Signed-off-by: zengtao <prime.zeng@huawei.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/1454384314-154784-1-git-send-email-prime.zeng@huawei.com
commit 8599846d73997cdbccf63f23394d871cfad1e5e6 upstream.
Currently we have two policies for deciding when to signal the host:
One based on the ring buffer state and the other based on what the
VMBUS client driver wants to do. Consider the case when the client
wants to explicitly control when to signal the host. In this case,
if the client were to defer signaling, we will not be able to signal
the host subsequently when the client does want to signal since the
ring buffer state will prevent the signaling. Implement logic to
have only one signaling policy in force for a given channel.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Tested-by: Haiyang Zhang <haiyangz@microsoft.com>
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
commit 8282f5d9c17fe15a9e658c06e3f343efae1a2a2f upstream.
All the variables in this list so far are defined to be in the global
namespace in the UEFI spec, so this just further ensures we're
validating the variables we think we are.
Including the guid for entries will become more important in future
patches when we decide whether or not to allow deletion of variables
based on presence in this list.
commit 73500267c930baadadb0d02284909731baf151f7 upstream.
This adds ucs2_utf8size(), which tells us how big our ucs2 string is in
bytes, and ucs2_as_utf8, which translates from ucs2 to utf8..
[ Upstream commit 7716682cc58e305e22207d5bb315f26af6b1e243 ]
Ilya reported following lockdep splat:
kernel: =========================
kernel: [ BUG: held lock freed! ]
kernel: 4.5.0-rc1-ceph-00026-g5e0a311 #1 Not tainted
kernel: -------------------------
kernel: swapper/5/0 is freeing memory
ffff880035c9d200-ffff880035c9dbff, with a lock still held there!
kernel: (&(&queue->rskq_lock)->rlock){+.-...}, at:
[<ffffffff816f6a88>] inet_csk_reqsk_queue_add+0x28/0xa0
kernel: 4 locks held by swapper/5/0:
kernel: #0: (rcu_read_lock){......}, at: [<ffffffff8169ef6b>]
netif_receive_skb_internal+0x4b/0x1f0
kernel: #1: (rcu_read_lock){......}, at: [<ffffffff816e977f>]
ip_local_deliver_finish+0x3f/0x380
kernel: #2: (slock-AF_INET){+.-...}, at: [<ffffffff81685ffb>]
sk_clone_lock+0x19b/0x440
kernel: #3: (&(&queue->rskq_lock)->rlock){+.-...}, at:
To properly fix this issue, inet_csk_reqsk_queue_add() needs
to return to its callers if the child as been queued
into accept queue.
We also need to make sure listener is still there before
calling sk->sk_data_ready(), by holding a reference on it,
since the reference carried by the child can disappear as
soon as the child is put on accept queue.
Reported-by: Ilya Dryomov <idryomov@gmail.com>
Fixes: ebb516af60e1 ("tcp/dccp: fix race at listener dismantle phase")
[ Upstream commit deed49df7390d5239024199e249190328f1651e7 ]
Since the gc of ipv4 route was removed, the route cached would has
no chance to be removed, and even it has been timeout, it still could
be used, cause no code to check it's expires.
Fix this issue by checking and removing route cache when we get route.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 5f74f82ea34c0da80ea0b49192bb5ea06e063593 ]
Devices may have limits on the number of fragments in an skb they support.
Current codebase uses a constant as maximum for number of fragments one
skb can hold and use.
When enabling scatter/gather and running traffic with many small messages
the codebase uses the maximum number of fragments and may thereby violate
the max for certain devices.
The patch introduces a global variable as max number of fragments.
Signed-off-by: Hans Westgaard Ry <hans.westgaard.ry@oracle.com>
Reviewed-by: Håkon Bugge <haakon.bugge@oracle.com>
[ Upstream commit 9cf7490360bf2c46a16b7525f899e4970c5fc144 ]
Petr Novopashenniy reported that ICMP redirects on SYN_RECV sockets
were leading to RST.
This is of course incorrect.
A specific list of ICMP messages should be able to drop a SYN_RECV.
For instance, a REDIRECT on SYN_RECV shall be ignored, as we do
not hold a dst per SYN_RECV pseudo request.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111751
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
Reported-by: Petr Novopashenniy <pety@rusnet.ru>
[ Upstream commit 415e3d3e90ce9e18727e8843ae343eda5a58fad6 ]
The commit referenced in the Fixes tag incorrectly accounted the number
of in-flight fds over a unix domain socket to the original opener
of the file-descriptor. This allows another process to arbitrary
deplete the original file-openers resource limit for the maximum of
open files. Instead the sending processes and its struct cred should
be credited.
To do so, we add a reference counted struct user_struct pointer to the
scm_fp_list and use it to account for the number of inflight unix fds.
Fixes: 712f4aad406bb1 ("unix: properly account for FDs passed over unix sockets")
Reported-by: David Herrmann <dh.herrmann@gmail.com>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Willy Tarreau <w@1wt.eu>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit 6f21c96a78b835259546d8f3fb4edff0f651d478 ]
The current implementation of ip6_dst_lookup_tail basically
ignore the egress ifindex match: if the saddr is set,
ip6_route_output() purposefully ignores flowi6_oif, due
to the commit d46a9d678e4c ("net: ipv6: Dont add RT6_LOOKUP_F_IFACE
flag if saddr set"), if the saddr is 'any' the first route lookup
in ip6_dst_lookup_tail fails, but upon failure a second lookup will
be performed with saddr set, thus ignoring the ifindex constraint.
This commit adds an output route lookup function variant, which
allows the caller to specify lookup flags, and modify
ip6_dst_lookup_tail() to enforce the ifindex match on the second
lookup via said helper.
ip6_route_output() becames now a static inline function build on
top of ip6_route_output_flags(); as a side effect, out-of-tree
modules need now a GPL license to access the output route lookup
functionality.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit ce87fc6ce3f9f4488546187e3757cf666d9d4a2a ]
GRO is currently not aware of tunnel metadata generated by lightweight
tunnels and stored in the dst. This leads to two possible problems:
* Incorrectly merging two frames that have different metadata.
* Leaking of allocated metadata from merged frames.
This avoids those problems by comparing the tunnel information before
merging, similar to how we handle other metadata (such as vlan tags),
and releasing any state when we are done.
Reported-by: John <john.phillips5@hpe.com>
Fixes: 2e15ea39 ("ip_gre: Add support to collect tunnel metadata.")
Signed-off-by: Jesse Gross <jesse@kernel.org>
Acked-by: Thomas Graf <tgraf@suug.ch>
commit 732042821cfa106b3c20b9780e4c60fee9d68900 upstream.
Helper radix_tree_iter_retry() resets next_index to the current index.
In following radix_tree_next_slot current chunk size becomes zero. This
isn't checked and it tries to dereference null pointer in slot.
Tagged iterator is fine because retry happens only at slot 0 where tag
bitmask in iter->tags is filled with single bit.
Fixes: 46437f9a554f ("radix-tree: fix race in gang lookup")
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Jeremiah Mahler <jmmahler@gmail.com>
commit 46437f9a554fbe3e110580ca08ab703b59f2f95a upstream.
If the indirect_ptr bit is set on a slot, that indicates we need to redo
the lookup. Introduce a new function radix_tree_iter_retry() which
forces the loop to retry the lookup by setting 'slot' to NULL and
turning the iterator back to point at the problematic entry.
This is a pretty rare problem to hit at the moment; the lookup has to
race with a grow of the radix tree from a height of 0. The consequences
of hitting this race are that gang lookup could return a pointer to a
radix_tree_node instead of a pointer to whatever the user had inserted
in the tree.
Fixes: cebbd29e1c2f ("radix-tree: rewrite gang lookup using iterator")
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit 46924008273ed03bd11dbb32136e3da4cfe056e1 upstream.
According to the VT-d specification we need to clear the PPR bit in
the Page Request Status register when handling page requests, or the
hardware won't generate any more interrupts.
This wasn't actually necessary on SKL/KBL (which may well be the
subject of a hardware erratum, although it's harmless enough). But
other implementations do appear to get it right, and we only ever get
one interrupt unless we clear the PPR bit.
Reported-by: CQ Tang <cq.tang@intel.com>
commit 12352d3cae2cebe18805a91fab34b534d7444231 upstream.
Sequence vma_lock_anon_vma() - vma_unlock_anon_vma() isn't safe if
anon_vma appeared between lock and unlock. We have to check anon_vma
first or call anon_vma_prepare() to be sure that it's here. There are
only few users of these legacy helpers. Let's get rid of them.
This patch fixes anon_vma lock imbalance in validate_mm(). Write lock
isn't required here, read lock is enough.
And reorders expand_downwards/expand_upwards: security_mmap_addr() and
wrapping-around check don't have to be under anon vma lock.
Link: https://lkml.kernel.org/r/CACT4Y+Y908EjM2z=706dv4rV6dWtxTLK9nFg9_7DhRMLppBo2g@mail.gmail.com
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit f37755490fe9bf76f6ba1d8c6591745d3574a6a6 upstream.
The tracepoint infrastructure uses RCU sched protection to enable and
disable tracepoints safely. There are some instances where tracepoints are
used in infrastructure code (like kfree()) that get called after a CPU is
going offline, and perhaps when it is coming back online but hasn't been
registered yet.
This can probuce the following warning:
[ INFO: suspicious RCU usage. ]
4.4.0-00006-g0fe53e8-dirty #34 Tainted: G S
include/trace/events/kmem.h:141 suspicious rcu_dereference_check() usage!
RCU used illegally from offline CPU! rcu_scheduler_active = 1, debug_locks = 1
no locks held by swapper/8/0.
stack backtrace:
CPU: 8 PID: 0 Comm: swapper/8 Tainted: G S 4.4.0-00006-g0fe53e8-dirty #34
Call Trace:
[c0000005b76c78d0] [c0000000008b9540] .dump_stack+0x98/0xd4 (unreliable)
[c0000005b76c7950] [c00000000010c898] .lockdep_rcu_suspicious+0x108/0x170
[c0000005b76c79e0] [c00000000029adc0] .kfree+0x390/0x440
[c0000005b76c7a80] [c000000000055f74] .destroy_context+0x44/0x100
[c0000005b76c7b00] [c0000000000934a0] .__mmdrop+0x60/0x150
[c0000005b76c7b90] [c0000000000e3ff0] .idle_task_exit+0x130/0x140
[c0000005b76c7c20] [c000000000075804] .pseries_mach_cpu_die+0x64/0x310
[c0000005b76c7cd0] [c000000000043e7c] .cpu_die+0x3c/0x60
[c0000005b76c7d40] [c0000000000188d8] .arch_cpu_idle_dead+0x28/0x40
[c0000005b76c7db0] [c000000000101e6c] .cpu_startup_entry+0x50c/0x560
[c0000005b76c7ed0] [c000000000043bd8] .start_secondary+0x328/0x360
[c0000005b76c7f90] [c000000000008a6c] start_secondary_prolog+0x10/0x14
This warning is not a false positive either. RCU is not protecting code that
is being executed while the CPU is offline.
Instead of playing "whack-a-mole(TM)" and adding conditional statements to
the tracepoints we find that are used in this instance, simply add a
cpu_online() test to the tracepoint code where the tracepoint will be
ignored if the CPU is offline.
Use of raw_smp_processor_id() is fine, as there should never be a case where
the tracepoint code goes from running on a CPU that is online and suddenly
gets migrated to a CPU that is offline.
Link: http://lkml.kernel.org/r/1455387773-4245-1-git-send-email-kda@linux-powerpc.org
Reported-by: Denis Kirjanov <kda@linux-powerpc.org>
Fixes: 97e1c18e8d17b ("tracing: Kernel Tracepoints")
commit b33c8ff4431a343561e2319f17c14286f2aa52e2 upstream.
In my randconfig tests, I came across a bug that involves several
components:
* gcc-4.9 through at least 5.3
* CONFIG_GCOV_PROFILE_ALL enabling -fprofile-arcs for all files
* CONFIG_PROFILE_ALL_BRANCHES overriding every if()
* The optimized implementation of do_div() that tries to
replace a library call with an division by multiplication
* code in drivers/media/dvb-frontends/zl10353.c doing
u32 adc_clock = 450560; /* 45.056 MHz */
if (state->config.adc_clock)
adc_clock = state->config.adc_clock;
do_div(value, adc_clock);
In this case, gcc fails to determine whether the divisor
in do_div() is __builtin_constant_p(). In particular, it
concludes that __builtin_constant_p(adc_clock) is false, while
__builtin_constant_p(!!adc_clock) is true.
That in turn throws off the logic in do_div() that also uses
__builtin_constant_p(), and instead of picking either the
constant- optimized division, and the code in ilog2() that uses
__builtin_constant_p() to figure out whether it knows the answer at
compile time. The result is a link error from failing to find
multiple symbols that should never have been called based on
the __builtin_constant_p():
dvb-frontends/zl10353.c:138: undefined reference to `____ilog2_NaN'
dvb-frontends/zl10353.c:138: undefined reference to `__aeabi_uldivmod'
ERROR: "____ilog2_NaN" [drivers/media/dvb-frontends/zl10353.ko] undefined!
ERROR: "__aeabi_uldivmod" [drivers/media/dvb-frontends/zl10353.ko] undefined!
This patch avoids the problem by changing __trace_if() to check
whether the condition is known at compile-time to be nonzero, rather
than checking whether it is actually a constant.
I see this one link error in roughly one out of 1600 randconfig builds
on ARM, and the patch fixes all known instances.
Link: http://lkml.kernel.org/r/1455312410-1058841-1-git-send-email-arnd@arndb.de
Acked-by: Nicolas Pitre <nico@linaro.org>
Fixes: ab3c9c686e22 ("branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y")
commit caaee6234d05a58c5b4d05e7bf766131b810a657 upstream.
By checking the effective credentials instead of the real UID / permitted
capabilities, ensure that the calling process actually intended to use its
credentials.
To ensure that all ptrace checks use the correct caller credentials (e.g.
in case out-of-tree code or newly added code omits the PTRACE_MODE_*CREDS
flag), use two new flags and require one of them to be set.
The problem was that when a privileged task had temporarily dropped its
privileges, e.g. by calling setreuid(0, user_uid), with the intent to
perform following syscalls with the credentials of a user, it still passed
ptrace access checks that the user would not be able to pass.
While an attacker should not be able to convince the privileged task to
perform a ptrace() syscall, this is a problem because the ptrace access
check is reused for things in procfs.
In particular, the following somewhat interesting procfs entries only rely
on ptrace access checks:
/proc/$pid/stat - uses the check for determining whether pointers
should be visible, useful for bypassing ASLR
/proc/$pid/maps - also useful for bypassing ASLR
/proc/$pid/cwd - useful for gaining access to restricted
directories that contain files with lax permissions, e.g. in
this scenario:
lrwxrwxrwx root root /proc/13020/cwd -> /root/foobar
drwx------ root root /root
drwxr-xr-x root root /root/foobar
-rw-r--r-- root root /root/foobar/secret
Therefore, on a system where a root-owned mode 6755 binary changes its
effective credentials as described and then dumps a user-specified file,
this could be used by an attacker to reveal the memory layout of root's
processes or reveal the contents of files he is not allowed to access
(through /proc/$pid/cwd).
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: "Serge E. Hallyn" <serge.hallyn@ubuntu.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 1f55c718c290616889c04946864a13ef30f64929 upstream.
Considering current pty code and multiple devpts instances, it's possible
to umount a devpts file system while a program still has /dev/tty opened
pointing to a previosuly closed pty pair in that instance. In the case all
ptmx and pts/N files are closed, umount can be done. If the program closes
/dev/tty after umount is done, devpts_kill_index will use now an invalid
super_block, which was already destroyed in the umount operation after
running ->kill_sb. This is another "use after free" type of issue, but now
related to the allocated super_block instance.
To avoid the problem (warning at ida_remove and potential crashes) for
this specific case, I added two functions in devpts which grabs additional
references to the super_block, which pty code now uses so it makes sure
the super block structure is still valid until pty shutdown is done.
I also moved the additional inode references to the same functions, which
also covered similar case with inode being freed before /dev/tty final
close/shutdown.
Signed-off-by: Herton R. Krzesinski <herton@redhat.com>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream.
This patch allows af_alg_release_parent to be called even for
nokey sockets.
commit a1383cd86a062fc798899ab20f0ec2116cce39cb upstream.
This patch adds a way for skcipher users to determine whether a key
is required by a transform.
commit a5596d6332787fd383b3b5427b41f94254430827 upstream.
This patch adds a way for ahash users to determine whether a key
is required by a crypto_ahash transform.
commit 37766586c965d63758ad542325a96d5384f4a8c9 upstream.
This patch adds a compatibility path to support old applications
that do acept(2) before setkey.
commit c840ac6af3f8713a71b4d2363419145760bd6044 upstream.
Each af_alg parent socket obtained by socket(2) corresponds to a
tfm object once bind(2) has succeeded. An accept(2) call on that
parent socket creates a context which then uses the tfm object.
Therefore as long as any child sockets created by accept(2) exist
the parent socket must not be modified or freed.
This patch guarantees this by using locks and a reference count
on the parent socket. Any attempt to modify the parent socket will
fail with EBUSY.
commit 0bfd464d3fdd5bb322f9cace4cc47f1796545cf7 upstream.
Allow a signal to interrupt the wait for a tty reopen; eg., if
the tty has starting final close and is waiting for the device to
drain.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 06ab30034ed9c200a570ab13c017bde248ddb2a6 upstream.
A kernel WARNING in snd_rawmidi_transmit_ack() is triggered by
syzkaller fuzzer:
WARNING: CPU: 1 PID: 20739 at sound/core/rawmidi.c:1136
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff82999e2d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81352089>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff813522b9>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff84f80bd5>] snd_rawmidi_transmit_ack+0x275/0x400 sound/core/rawmidi.c:1136
[<ffffffff84fdb3c1>] snd_virmidi_output_trigger+0x4b1/0x5a0 sound/core/seq/seq_virmidi.c:163
[< inline >] snd_rawmidi_output_trigger sound/core/rawmidi.c:150
[<ffffffff84f87ed9>] snd_rawmidi_kernel_write1+0x549/0x780 sound/core/rawmidi.c:1223
[<ffffffff84f89fd3>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1273
[<ffffffff817b0323>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817b1db7>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[< inline >] SYSC_write fs/read_write.c:624
[<ffffffff817b50a1>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86336c36>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
Also a similar warning is found but in another path:
Call Trace:
[<ffffffff82be2c0d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81355139>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff81355369>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff8527e69a>] rawmidi_transmit_ack+0x24a/0x3b0 sound/core/rawmidi.c:1133
[<ffffffff8527e851>] snd_rawmidi_transmit_ack+0x51/0x80 sound/core/rawmidi.c:1163
[<ffffffff852d9046>] snd_virmidi_output_trigger+0x2b6/0x570 sound/core/seq/seq_virmidi.c:185
[<ffffffff85285a0b>] snd_rawmidi_kernel_write1+0x4bb/0x760 sound/core/rawmidi.c:1252
[<ffffffff85287b73>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1302
[<ffffffff817ba5f3>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817bc087>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[<ffffffff817bf371>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86660276>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
In the former case, the reason is that virmidi has an open code
calling snd_rawmidi_transmit_ack() with the value calculated outside
the spinlock. We may use snd_rawmidi_transmit() in a loop just for
consuming the input data, but even there, there is a race between
snd_rawmidi_transmit_peek() and snd_rawmidi_tranmit_ack().
Similarly in the latter case, it calls snd_rawmidi_transmit_peek() and
snd_rawmidi_tranmit_ack() separately without protection, so they are
racy as well.
The patch tries to address these issues by the following ways:
- Introduce the unlocked versions of snd_rawmidi_transmit_peek() and
snd_rawmidi_transmit_ack() to be called inside the explicit lock.
- Rewrite snd_rawmidi_transmit() to be race-free (the former case).
- Make the split calls (the latter case) protected in the rawmidi spin
lock.
BugLink: http://lkml.kernel.org/r/CACT4Y+YPq1+cYLkadwjWa5XjzF1_Vki1eHnVn-Lm0hzhSpu5PA@mail.gmail.com
BugLink: http://lkml.kernel.org/r/CACT4Y+acG4iyphdOZx47Nyq_VHGbpJQK-6xNpiqUjaZYqsXOGw@mail.gmail.com
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 203cbf77de59fc8f13502dcfd11350c6d4a5c95f upstream.
If CONFIG_TIME_LOW_RES is enabled we add a jiffie to the relative timeout to
prevent short sleeps, but we do not account for that in interfaces which
retrieve the remaining time.
Helge observed that timerfd can return a remaining time larger than the
relative timeout. That's not expected and breaks userland test programs.
Store the information that the timer was armed relative and provide functions
to adjust the remaining time. To avoid bloating the hrtimer struct make state
a u8, which as a bonus results in better code on x86 at least.
Reported-and-tested-by: Helge Deller <deller@gmx.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: linux-m68k@lists.linux-m68k.org
Cc: dhowells@redhat.com
Link: http://lkml.kernel.org/r/20160114164159.273328486@linutronix.de
commit 8d91f8b15361dfb438ab6eb3b319e2ded43458ff upstream.
@console_may_schedule tracks whether console_sem was acquired through
lock or trylock. If the former, we're inside a sleepable context and
console_conditional_schedule() performs cond_resched(). This allows
console drivers which use console_lock for synchronization to yield
while performing time-consuming operations such as scrolling.
However, the actual console outputting is performed while holding
irq-safe logbuf_lock, so console_unlock() clears @console_may_schedule
before starting outputting lines. Also, only a few drivers call
console_conditional_schedule() to begin with. This means that when a
lot of lines need to be output by console_unlock(), for example on a
console registration, the task doing console_unlock() may not yield for
a long time on a non-preemptible kernel.
If this happens with a slow console devices, for example a serial
console, the outputting task may occupy the cpu for a very long time.
Long enough to trigger softlockup and/or RCU stall warnings, which in
turn pile more messages, sometimes enough to trigger the next cycle of
warnings incapacitating the system.
Fix it by making console_unlock() insert cond_resched() between lines if
@console_may_schedule.
Reported-by: Calvin Owens <calvinowens@fb.com>
Acked-by: Jan Kara <jack@suse.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Kyle McMartin <kyle@kernel.org>
[ Upstream commit 0b6e26ce89391327d955a756a7823272238eb867 ]
With several ConnectX-4 cards installed on a server, one may receive
irqn > 255 from the kernel API, which we mistakenly trim to 8bit.
This causes EQ creation failure with the following stack trace:
[<ffffffff812a11f4>] dump_stack+0x48/0x64
[<ffffffff810ace21>] __setup_irq+0x3a1/0x4f0
[<ffffffff810ad7e0>] request_threaded_irq+0x120/0x180
[<ffffffffa0923660>] ? mlx5_eq_int+0x450/0x450 [mlx5_core]
[<ffffffffa0922f64>] mlx5_create_map_eq+0x1e4/0x2b0 [mlx5_core]
[<ffffffffa091de01>] alloc_comp_eqs+0xb1/0x180 [mlx5_core]
[<ffffffffa091ea99>] mlx5_dev_init+0x5e9/0x6e0 [mlx5_core]
[<ffffffffa091ec29>] init_one+0x99/0x1c0 [mlx5_core]
[<ffffffff812e2afc>] local_pci_probe+0x4c/0xa0
Fixing it by changing of the irqn type from u8 to unsigned int to
support values > 255
Fixes: 61d0e73e0a5a ('net/mlx5_core: Use the the real irqn in eq->irqn')
Reported-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Doron Tsur <doront@mellanox.com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
[ Upstream commit 34ae6a1aa0540f0f781dd265366036355fdc8930 ]
When a tunnel decapsulates the outer header, it has to comply
with RFC 6080 and eventually propagate CE mark into inner header.
It turns out IP6_ECN_set_ce() does not correctly update skb->csum
for CHECKSUM_COMPLETE packets, triggering infamous "hw csum failure"
messages and stack traces.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 9207f9d45b0ad071baa128e846d7e7ed85016df3 ]
Skb_gso_segment() uses skb control block during segmentation.
This patch adds 32-bytes room for previous control block which
will be copied into all resulting segments.
This patch fixes kernel crash during fragmenting forwarded packets.
Fragmentation requires valid IP CB in skb for clearing ip options.
Also patch removes custom save/restore in ovs code, now it's redundant.
Link: http://lkml.kernel.org/r/CALYGNiP-0MZ-FExV2HutTvE9U-QQtkKSoE--KN=JQE5STYsjAA@mail.gmail.com
[ Upstream commit 712f4aad406bb1ed67f3f98d04c044191f0ff593 ]
It is possible for a process to allocate and accumulate far more FDs than
the process' limit by sending them over a unix socket then closing them
to keep the process' fd count low.
This change addresses this problem by keeping track of the number of FDs
in flight per user and preventing non-privileged processes from having
more FDs in flight than their configured FD limit.
Reported-by: socketpair@gmail.com
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Mitigates: CVE-2013-4312 (Linux 2.0+)
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit bf5ce5bf3cc7136fd7fe5e8999a580bc93a9c8f6 upstream.
Commit 655fe4effe0f ("usbcore: add sysfs support to xHCI usb3
hardware LPM") introduced usb3_hardware_lpm sysfs node. This
doesn't show the correct status of USB3 U1 and U2 LPM status.
This patch fixes this by replacing usb3_hardware_lpm with two
nodes, usb3_hardware_lpm_u1 (for U1) and usb3_hardware_lpm_u2
(for U2), and recording the U1/U2 LPM status in right places.
This patch should be back-ported to kernels as old as 4.3,
that contains Commit 655fe4effe0f ("usbcore: add sysfs support
to xHCI usb3 hardware LPM").
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Pull scheduler fixes from Ingo Molnar:
"Misc scheduler fixes"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/core: Reset task's lockless wake-queues on fork()
sched/core: Fix unserialized r-m-w scribbling stuff
sched/core: Check tgid in is_global_init()
sched/fair: Fix multiplication overflow on 32-bit systems
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"A slightly higher volume than a new year's wish, but not too
worrisome: a large LOC is only for HD-audio device-specific quirks, so
fairly safe to apply. The rest ASoC fixes are all trivial and small;
a simple replacement of mutex call with nested lock version, a few
Arizona and Realtek codec fixes, and a regression fix for Skylake
firmware handling"
* tag 'sound-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: Intel: Skylake: Fix the memory leak
ASoC: Intel: Skylake: Revert previous broken fix memory leak fix
ASoC: Use nested lock for snd_soc_dapm_mutex_lock
ASoC: rt5645: add sys clk detection
ALSA: hda - Add keycode map for alc input device
ALSA: hda - Add mic mute hotkey quirk for Lenovo ThinkCentre AIO
ASoC: arizona: Fix bclk for sample rates that are multiple of 4kHz
