The mach-mx51 folder has been replaced by mach-mx5 to enable the addition
of more platforms.
Signed-off-by: Alejandro Gonzalez <alex.gonzalez@digi.com>
iMX23 evk RevC using gpio as usb id.
usb_id pin is conflict with mmcsd detection pin
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add USB 100mA limitation feature for mx28 to mach usb 2.0 current requirment
Signed-off-by: Frank Li <Frank.li@freescale.com>
add usb support for mx28
include usb host and usb device
Signed-off-by: Albert Chen <r65187@freescale.com>
FEC driver support for i.MX28
Signed-off-by:Jason Liu <r64343@freescale.com>
Add the MSL codes(New Framework) for MX28,
including clock, gpio, pinctrl, interrupt, timer, DMA, etc.
Signed-off-by: Fred Fan <r01011@freescale.com>
Signed-off-by: Robby Cai <R63905@freescale.com>
To preview with V4L2 overlay and capture at the same time may fail.
This patch implements workaround for this issue by enabling CSI after
PRP channels are setup.
Signed-off-by: Liu Ying <b17645@freescale.com>
Add IPU_CSC_UPDATE case for ipu ioctl.
Signed-off-by: Sammy He <r62914@freescale.com>
Add iram allocation functions using GENERIC_ALLOCATOR. The
allocation size is 4KB multiples to guarantee alignment.
Signed-off-by: Rob Herring <r.herring@freescale.com>
blank/unblank fb during v4l2 playback, unblank will cause current buffer
of display channel to be 1. This patch make the sequence of select
display buffer correct.
Signed-off-by: Jason Chen <b02280@freescale.com>
1. Blank BG during video play on FG:
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 1024 -oh 768 -d 3 qvga.yuv
echo 1 > /sys/class/graphics/fb0/blank
echo 0 > /sys/class/graphics/fb0/blank
2. The same input and output (ic_bypass):
./mxc_v4l2_output.out -iw 320 -ih 240 -ow 320 -oh 240 -d 3 qvga.yuv
This commit adds support for the second etherent mac.
This driver should be sync with the mainline driver in future.
Signed-off-by: Pedro Perez de Heredia <pedro.perez@digi.com>
Register the mma7455l accelerometer chip with the I2C2 bus and add a
client driver for the mma7455l device. The chip is probed and I2C R/W
transactions are working. No other test on the mma7455l driver has been
performed at this stage.
Modify MXCFB_SET_LOC_ALPHA ioctrl to support DP local alpha with
alpha value contained in pixel.
To support 720p output for ipu lib.
If there is no usb devices connectted or all connectted usb
devices are in suspend state, usb host can suspend its whole bus,
then put the PHY into low power mode and close all usb clocks.
(The patch is splitted 2 patches, this is common code part.)
Signed-off-by: Li Jun <r65092@freescale.com>
Changed bit definition from 0x8000 to 0x4000
Signed-off-by: Anish Trivedi <anish@freescale.com>
Support DP gamma by setting piecewise linear approximation,
application need set coefficient const[k] and slope[k]. The algorithm to
calculate these coefficient pls refer to unit test.
Added the device identification and timing database. Adjusted the GPMI
NAND Flash driver to use this information.
Signed-off-by: Patrick Turley <patrick.turley@freescale.com>
Follow the approach suggested by Russell King and implemented by him in
the clkdev API and allow consumer device supply mapings to be set up
using the dev_name() for the consumer instead of the struct device.
In order to avoid making existing machines instabuggy and creating merge
issues the use of struct device is still supported for the time being.
This resolves problems working with buses such as I2C which make the
struct device available late providing that the final device name is
known, which is the case for most embedded systems with fixed setups.
Consumers must still use the struct device when calling regulator_get().
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add i.MX specific files into include/linux/Kbuild
Signed-off-by: Lily Zhang <r58066@freescale.com>
-Added kernel error message to handle hang due to SCC HW failure.
-Eliminated unwanted sleeps.
-Kernel error message to handle the case when SCC key fuses are not blown.
Signed-off-by: Raj Rajasekaran <b10872@freescale.com>
A new feature is added to support to upsizing by horizontal stripes
via IC PP channels double using.
Signed-off-by: Mark Gutman <r58412@freescale.com>
MX233: Restructure the STMP378xxx USB Host and Gadget device structures
to be similar to MXC structures. Enable fsl_otg_arc driver to work on
MX233 platform. Remove FSL_USB2_DONT_REMAP requirement.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
arch/arm/mach-stmp3xxx/Kconfig
arch/arm/mach-stmp3xxx/Makefile
arch/arm/mach-stmp3xxx/devices.c
arch/arm/mach-stmp3xxx/include/mach/stmp3xxx.h
arch/arm/mach-stmp3xxx/stmp378x_devb.c
USB will enter low power mode if no vbus power supply.
Only finished this feature in Mx37.
1. When enter low power mode, driver will close usb related clocks
as possible as could.
set usb IP to stop.
Set PHY to low power suspend by setting PHCD bit of portsc.
2. This patch doesn't support low power mode in OTG mode yet.
This is i.MX BSP 5.0.0 release ported to 2.6.31
Signed-off-by: Alan Tull <r80115@freescale.com>
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
and oob sizes
Linux driver for /dev/crypto (aka CryptoDev)
See http://www.logix.cz/michal/devel/cryptodev for details.
Signed-off-by: Michal Ludvig <mludvig@suse.cz>
JFFS2 community fix with not use OOB at MLC NAND, this patch
is coming from the MTD community
Signed-off-by: Jason Liu <r64343@freescale.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
tc: Fix unitialized kernel memory leak
pkt_sched: Revert tasklet_hrtimer changes.
net: sk_free() should be allowed right after sk_alloc()
gianfar: gfar_remove needs to call unregister_netdev()
ipw2200: firmware DMA loading rework
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL test
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm snapshot: fix on disk chunk size validation
dm exception store: split set_chunk_size
dm snapshot: fix header corruption race on invalidation
dm snapshot: refactor zero_disk_area to use chunk_io
dm log: userspace add luid to distinguish between concurrent log instances
dm raid1: do not allow log_failure variable to unset after being set
dm log: remove incorrect field from userspace table output
dm log: fix userspace status output
dm stripe: expose correct io hints
dm table: add more context to terse warning messages
dm table: fix queue_limit checking device iterator
dm snapshot: implement iterate devices
dm multipath: fix oops when request based io fails when no paths
Tom Horsley reports that his debugger hangs when it tries to read
/proc/pid_of_tracee/maps, this happens since
"mm_for_maps: take ->cred_guard_mutex to fix the race with exec"
04b836cbf19e885f8366bccb2e4b0474346c02d
commit in 2.6.31.
But the root of the problem lies in the fact that do_execve() path calls
tracehook_report_exec() which can stop if the tracer sets PT_TRACE_EXEC.
The tracee must not sleep in TASK_TRACED holding this mutex. Even if we
remove ->cred_guard_mutex from mm_for_maps() and proc_pid_attr_write(),
another task doing PTRACE_ATTACH should not hang until it is killed or the
tracee resumes.
With this patch do_execve() does not use ->cred_guard_mutex directly and
we do not hold it throughout, instead:
- introduce prepare_bprm_creds() helper, it locks the mutex
and calls prepare_exec_creds() to initialize bprm->cred.
- install_exec_creds() drops the mutex after commit_creds(),
and thus before tracehook_report_exec()->ptrace_stop().
or, if exec fails,
free_bprm() drops this mutex when bprm->cred != NULL which
indicates install_exec_creds() was not called.
Reported-by: Tom Horsley <tom.horsley@att.net>
Cc: Roland McGrath <roland@redhat.com>
cancel_delayed_work() has to use del_timer_sync() to guarantee the timer
function is not running after return. But most users doesn't actually
need this, and del_timer_sync() has problems: it is not useable from
interrupt, and it depends on every lock which could be taken from irq.
Introduce __cancel_delayed_work() which calls del_timer() instead.
The immediate reason for this patch is
http://bugzilla.kernel.org/show_bug.cgi?id=13757
but hopefully this helper makes sense anyway.
As for 13757 bug, actually we need requeue_delayed_work(), but its
semantics are not yet clear.
Merge this patch early to resolves cross-tree interdependencies between
input and infiniband.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Stefan Richter <stefanr@s5r6.in-berlin.de>
Device-mapper userspace logs (like the clustered log) are
identified by a universally unique identifier (UUID). This
identifier is used to associate requests from the kernel to
a specific log in userspace. The UUID must be unique everywhere,
since multiple machines may use this identifier when communicating
about a particular log, as is the case for cluster logs.
Sometimes, device-mapper/LVM may re-use a UUID. This is the
case during pvmoves, when moving from one segment of an LV
to another, or when resizing a mirror, etc. In these cases,
a new log is created with the same UUID and loaded in the
"inactive" slot. When a device-mapper "resume" is issued,
the "live" table is deactivated and the new "inactive" table
becomes "live". (The "inactive" table can also be removed
via a device-mapper 'clear' command.)
The above two issues were colliding. More than one log was being
created with the same UUID, and there was no way to distinguish
between them. So, sometimes the wrong log would be swapped
out during the exchange.
The solution is to create a locally unique identifier,
'luid', to go along with the UUID. This new identifier is used
to determine exactly which log is being referenced by the kernel
when the log exchange is made. The identifier is not
universally safe, but it does not need to be, since
create/destroy/suspend/resume operations are bound to a specific
machine; and these are the operations that make up the exchange.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Set sensible I/O hints for striped DM devices in the topology
infrastructure added for 2.6.31 for userspace tools to
obtain via sysfs.
Add .io_hints to 'struct target_type' to allow the I/O hints portion
(io_min and io_opt) of the 'struct queue_limits' to be set by each
target and implement this for dm-stripe.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
These are full of unresolved problems, mainly that conversions don't
work 1-1 from hrtimers to tasklet_hrtimers because unlike hrtimers
tasklets can't be killed from softirq context.
And when a qdisc gets reset, that's exactly what we need to do here.
We'll work this out in the net-next-2.6 tree and if warranted we'll
backport that work to -stable.
This reverts the following 3 changesets:
a2cb6a4dd470d7a64255a10b843b0d188416b78f
("pkt_sched: Fix bogon in tasklet_hrtimer changes.")
38acce2d7983632100a9ff3fd20295f6e34074a8
("pkt_sched: Convert CBQ to tasklet_hrtimer.")
ee5f9757ea17759e1ce5503bdae2b07e48e32af9
("pkt_sched: Convert qdisc_watchdog to tasklet_hrtimer")
My previous patch (commit 4f8ee2c9cc: "lmb: Remove __init from
lmb_end_of_DRAM()") removed __init in lmb.c but missed the fact that it
was also marked as such in the .h
As struct skcipher_givcrypt_request includes struct crypto_request
at a non-zero offset, testing for NULL after converting the pointer
returned by crypto_dequeue_request does not work. This can result
in IPsec crashes when the queue is depleted.
This patch fixes it by doing the pointer conversion only when the
return value is non-NULL. In particular, we create a new function
__crypto_dequeue_request that does the pointer conversion.
Reported-by: Brad Bosch <bradbosch@comcast.net>
If the BIOS reports an invalid throttling state (which seems to be
fairly common after system boot), a reset is done to state T0.
Because of a check in acpi_processor_get_throttling_ptc(), the reset
never actually gets executed, which results in the error reoccurring
on every access of for example /proc/acpi/processor/CPU0/throttling.
Add a 'force' option to acpi_processor_set_throttling() to ensure
the reset really takes effect.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13389
This patch, together with the next one, fixes a regression introduced in
2.6.30, listed on the regression list. They have been available for 2.5
months now in bugzilla, but have not been picked up, despite various
reminders and without any reason given.
Google shows that numerous people are hitting this issue. The issue is in
itself relatively minor, but the bug in the code is clear.
The patches have been in all my kernels and today testing has shown that
throttling works correctly with the patches applied when the system
overheats (http://bugzilla.kernel.org/show_bug.cgi?id=13918#c14).
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
It's problematic to allow signed element_nr's or total's to be passed as
part of the flex array API.
flex_array_alloc() allows total_nr_elements to be set to a negative
quantity, which is obviously erroneous.
flex_array_get() and flex_array_put() allows negative array indices in
dereferencing an array part, which could address memory mapped before
struct flex_array.
The fix is to convert all existing element_nr formals to be qualified as
unsigned. Existing checks to compare it to total_nr_elements or the max
array size based on element_size need not be changed.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
The `parts' member of struct flex_array should evaluate to an incomplete
type so that sizeof() cannot be used and C99 does not require the
zero-length specification.
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed
user_shm_lock() calls in hugetlb_file_setup() but left the
user_shm_unlock call in shm_destroy().
In detail:
Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock()
is not called in hugetlb_file_setup(). However, user_shm_unlock() is
called in any case in shm_destroy() and in the following
atomic_dec_and_lock(&up->__count) in free_uid() is executed and if
up->__count gets zero, also cleanup_user_struct() is scheduled.
Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set.
However, the ref counter up->__count gets unexpectedly non-positive and
the corresponding structs are freed even though there are live
references to them, resulting in a kernel oops after a lots of
shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set.
Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the
time of shm_destroy() may give a different answer from at the time
of hugetlb_file_setup(). And fixed newseg()'s no_id error path,
which has missed user_shm_unlock() ever since it came in 2.6.9.
Reported-by: Stefan Huber <shuber2@gmail.com>
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Tested-by: Stefan Huber <shuber2@gmail.com>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: ucb1400_ts - enable interrupt unconditionally
Input: ucb1400_ts - enable ADC Filter
Input: wacom - don't use on-stack memory for report buffers
Input: iforce - support new revision of ACT LABS Force RS
Input: joydev - decouple axis and button map ioctls from input constants
smc91x: let smc91x work well under netpoll
pxaficp-ir: remove incorrect net_device_ops
NET: llc, zero sockaddr_llc struct
drivers/net: fixed drivers that support netpoll use ndo_start_xmit()
netpoll: warning for ndo_start_xmit returns with interrupts enabled
net: Fix Micrel KSZ8842 Kconfig description
netfilter: xt_quota: fix wrong return value (error case)
ipv6: Fix commit 63d9950b08184e6531adceb65f64b429909cc101 (ipv6: Make v4-mapped bindings consistent with IPv4)
E100: fix interaction with swiotlb on X86.
rtl8187: always set MSR_LINK_ENEDCA flag with RTL8187B
ibm_newemac: emac_close() needs to call netif_carrier_off()
net: fix ks8851 build errors
net: Rename MAC platform driver for w90p910 platform
yellowfin: Fix buffer underrun after dev_alloc_skb() failure
orinoco: correct key bounds check in orinoco_hw_get_tkip_iv
mac80211: fix todo lock
vfs_read() offset is defined as loff_t, but kernel_read()
offset is only defined as unsigned long. Redefine
kernel_read() offset as loff_t.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
None of this stuff should execute in hw IRQ context, therefore
use a tasklet_hrtimer so that it runs in softirq context.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon: add GET_PARAM/INFO support for Z pipes
drm/radeon/kms: add r100/r200 OQ support.
drm: Fix sysfs device confusion.
drm/radeon/kms: implement the bo busy ioctl properly.
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some
cases want to know whether the result is the empty set or not. In
particular, the TLB IPI sending code wants to do cpumask operations and
determine if there are any CPU's left in the final set.
So this just makes the bitmask (and cpumask) functions return a boolean
for whether the result has any bits set.
Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix)
Needed for occlusion queries on rv530 chips.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
