path: root/include
2013-06-07Merge tag 'trace-fixes-v3.10-rc3-v3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "This contains 4 fixes. The first two fix the case where full RCU debugging is enabled, enabling function tracing causes a live lock of the system. This is due to the added debug checks in rcu_dereference_raw() that is used by the function tracer. These checks are also traced by the function tracer as well as cause enough overhead to the function tracer to slow down the system enough that the time to finish an interrupt can take longer than when the next interrupt is triggered, causing a live lock from the timer interrupt. Talking this over with Paul McKenney, we came up with a fix that adds a new rcu_dereference_raw_notrace() that does not perform these added checks, and let the function tracer use that. The third commit fixes a failed compile when branch tracing is enabled, due to the conversion of the trace_test_buffer() selftest that the branch trace wasn't converted for. The forth patch fixes a bug caught by the RCU lockdep code where a rcu_read_lock() is performed when rcu is disabled (either going to or from idle, or user space). This happened on the irqsoff tracer as it calls task_uid(). The fix here was to use current_uid() when possible that doesn't use rcu locking. Which luckily, is always used when irqsoff calls this code." * tag 'trace-fixes-v3.10-rc3-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Use current_uid() for critical time tracing tracing: Fix bad parameter passed in branch selftest ftrace: Use the rcu _notrace variants for rcu_dereference_raw() and friends rcu: Add _notrace variation of rcu_dereference_raw() and hlist_for_each_entry_rcu()
2013-06-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fix from David Miller: "This is a quick one commit pull request to cure the regression introduced by the MSG_CMSG_COMPAT change." (Background: commit 1be374a0518a completely broke 32-bit COMPAT handling by not only disallowing MSG_CMSG_COMPAT from user APIs, but clearing it in our own internal use too!) * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Unbreak compat_sys_{send,recv}msg
2013-06-06net: Unbreak compat_sys_{send,recv}msgAndy Lutomirski
I broke them in this commit: commit 1be374a0518a288147c6a7398792583200a67261 Author: Andy Lutomirski <luto@amacapital.net> Date: Wed May 22 14:07:44 2013 -0700 net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg This patch adds __sys_sendmsg and __sys_sendmsg as common helpers that accept MSG_CMSG_COMPAT and blocks MSG_CMSG_COMPAT at the syscall entrypoints. It also reverts some unnecessary checks in sys_socketcall. Apparently I was suffering from underscore blindness the first time around. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Tested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-06arch, mm: Remove tlb_fast_mode()Peter Zijlstra
Since the introduction of preemptible mmu_gather TLB fast mode has been broken. TLB fast mode relies on there being absolutely no concurrency; it frees pages first and invalidates TLBs later. However now we can get concurrency and stuff goes *bang*. This patch removes all tlb_fast_mode() code; it was found the better option vs trying to patch the hole by entangling tlb invalidation with the scheduler. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Reported-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix timeouts with direct mode authentication in mac80211, from Stanislaw Gruszka. 2) Aggregation sessions can deadlock in ath9k, from Felix Fietkau. 3) Netfilter's xt_addrtype doesn't work with ipv6 due to route lookups creating undesirable cache entries, from Florian Westphal. 4) Fix netfilter's ipt_ULOG from generating non-NULL terminated strings. 5) Fix netdev transmit queue crashes in mac80211, from Johannes Berg. 6) Fix copy and paste error in 802.11 stack that broke reporting of 64-bit station tx statistics, from Felix Fietkau. 7) When qlge_probe fails, it leaks the netdev. Fix from Wei Yongjun. 8) SKB control block (where we store the IP options information, amongst other things) must be cleared properly otherwise ICMP sending can crash for IP tunnels. Fix from Eric Dumazet. 9) Verification of Energy Efficient Ether support was coded wrongly, the test was inversed. Fix from Giuseppe CAVALLARO. 10) TCP handles redirects improperly because the wrong flow key is used for the route lookup. From Michal Kubecek. 11) Don't interpret MSG_CMSG_COMPAT from userspace, fix from Andy Lutomirski. 12) The new AF_VSOCK was missing from the lockdep string table, fix from Federico Vaga. 13) be2net doesn't handle checksumming of IP fragments properly, from Somnath Kotur. 14) Fix several bugs in the device address list code that lead to crashes and other misbehaviors. From Jay Vosburgh. 15) Fix ipv6 segmentation handling of fragmented GRE tunnel traffic, from Pravin B Shalr. 16) Fix usage of stale policies in IPSEC layer, from Paul Moore. 17) Fix team driver dump of ports when there are a large number of them, from Jiri Pirko. 18) Fix softlockups in UDP ipv4 socket lookup causes by and error in the hlist_nulls_for_each_entry_rcu() macro. From Eric Dumazet. 19) Fix several regressions added by the high rate accuracy changes to the htb packet scheduler. From Eric Dumazet. 20) Fix DMA'ing onto the stack in esd_usb2 and peak_usb CAN drivers, from Olivier Sobrie and Marc Kleine-Budde. 21) Fix unremovable network devices due to missing route pointer installation in the per-device ipv6 address list entries. From Gao feng. 22) Apply the tg3 5719 DMA workaround on 5720 chips as well, otherwise we get stalls. From Nithin Sujir. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits) net_sched: htb: do not mix 1ns and 64ns time units net: fix sk_buff head without data area tg3: Add read dma workaround for 5720 net: ethernet: xilinx_emaclite: set protocol selector bits when writing ANAR bnx2x: Fix bridged GSO for 57710/57711 chips net: fec: add fallback to random MAC address bnx2x: fix TCP offload for tunneling ipv4 over ipv6 ipv6: assign rt6_info to inet6_ifaddr in init_loopback net/mlx4_core: Keep VF assigned MAC in the PF admin table net/mlx4_en: Handle unassigned VF MAC address correctly net/mlx4_core: Return -EPROBE_DEFER when a VF is probed before PF is sufficiently initialized net/mlx4_en: Fix adaptive moderation cq update net: can: peak_usb: Do not do dma on the stack net: can: esd_usb2: Do not do dma on the stack net: can: kvaser_usb: fix reception on "USBcan Pro" and "USBcan R" type hardware. net_sched: restore "overhead xxx" handling net: force a reload of first item in hlist_nulls_for_each_entry_rcu hyperv: Fix vlan_proto setting in netvsc_recv_callback() team: fix port list dump for big number of ports list: introduce list_first_entry_or_null ...
2013-06-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "Recent bug fixes, one of them touches a common code file. It adds two #ifndef/#endif pairs to asm-generic/io.h to be able to override xlate_dev_kmem_ptr and xlate_dev_mem_ptr." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/pgtable: Fix gmap notifier address s390/dasd: fix handling of gone paths s390/pgtable: Fix check for pgste/storage key handling arch: s390: appldata: using strncpy() and strnlen() instead of sprintf() s390/smp: lost IPIs on cpu hotplug kernel: Fix s390 absolute memory access for /dev/mem s390/dma: do not call debug_dma after free
2013-06-03Merge branch 'for-3.10-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: - Fix for yet another xattr bug which may lead to NULL deref. - A subtle bug in for_each_descendant_pre(). This bug requires quite specific conditions to trigger and isn't too likely to actually happen in the wild, but maybe that just makes it that much more nastier. - A warning message added for silly cgroup re-mount (not -o remount, but unmount followed by mount) behavior. * 'for-3.10-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: warn about mismatching options of a new mount of an existing hierarchy cgroup: fix a subtle bug in descendant pre-order walk cgroup: initialize xattr before calling d_instantiate()
2013-06-02net_sched: restore "overhead xxx" handlingEric Dumazet
commit 56b765b79 ("htb: improved accuracy at high rates") broke the "overhead xxx" handling, as well as the "linklayer atm" attribute. tc class add ... htb rate X ceil Y linklayer atm overhead 10 This patch restores the "overhead xxx" handling, for htb, tbf and act_police The "linklayer atm" thing needs a separate fix. Reported-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Vimalkumar <j.vimal@gmail.com> Cc: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-02net: force a reload of first item in hlist_nulls_for_each_entry_rcuEric Dumazet
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading first item in the rcu protected list, in case the loop was restarted. This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37 rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is ptr->field : In some cases, gcc caches the value or ptr->field in a register. Use a barrier() to disallow such caching, as documented in Documentation/atomic_ops.txt line 114 Thanks a lot to Roman for providing analysis and numerous patches. Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru> Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru> Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull scsi target fixes from Nicholas Bellinger: "The highlights include: - Re-instate sess->wait_list in target_wait_for_sess_cmds() for active I/O shutdown handling in fabrics using se_cmd->cmd_kref - Make ib_srpt call target_sess_cmd_list_set_waiting() during session shutdown - Fix FILEIO off-by-one READ_CAPACITY bug for !S_ISBLK export - Fix iscsi-target login error heap buffer overflow (Kees) - Fix iscsi-target active I/O shutdown handling regression in v3.10-rc1 A big thanks to Kees Cook for fixing a long standing login error buffer overflow bug. All patches are CC'ed to stable with the exception of the v3.10-rc1 specific regression + other minor target cleanup." * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: iscsi-target: Fix iscsit_free_cmd() se_cmd->cmd_kref shutdown handling target: Propigate up ->cmd_kref put return via transport_generic_free_cmd iscsi-target: fix heap buffer overflow on error target/file: Fix off-by-one READ_CAPACITY bug for !S_ISBLK export ib_srpt: Call target_sess_cmd_list_set_waiting during shutdown_session target: Re-instate sess_wait_list for target_wait_for_sess_cmds target: Remove unused wait_for_tasks bit in target_wait_for_sess_cmds
2013-06-01Merge tag 'fbdev-for-3.10-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev Pull fbdev fixes from Jean-Christophe PLAGNIOL-VILLARD: "This contains some small fixes - Atmel LCDC: fix blank the backlight on remove - ps3fb: fix compile warning - OMAPDSS: Fix crash with DT boot" * tag 'fbdev-for-3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/plagnioj/linux-fbdev: atmel_lcdfb: blank the backlight on remove trivial: atmel_lcdfb: add missing error message OMAPDSS: Fix crash with DT boot fbdev/ps3fb: fix compile warning
2013-05-31list: introduce list_first_entry_or_nullJiri Pirko
non-rcu variant of list_first_or_null_rcu Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31xfrm: force a garbage collection after deleting a policyPaul Moore
In some cases after deleting a policy from the SPD the policy would remain in the dst/flow/route cache for an extended period of time which caused problems for SELinux as its dynamic network access controls key off of the number of XFRM policy and state entries. This patch corrects this problem by forcing a XFRM garbage collection whenever a policy is sucessfully removed. Reported-by: Ondrej Moris <omoris@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31udp6: Fix udp fragmentation for tunnel traffic.Pravin B Shelar
udp6 over GRE tunnel does not work after to GRE tso changes. GRE tso handler passes inner packet but keeps track of outer header start in SKB_GSO_CB(skb)->mac_offset. udp6 fragment need to take care of outer header, which start at the mac_offset, while adding fragment header. This bug is introduced by commit 68c3316311 (GRE: Add TCP segmentation offload for GRE). Reported-by: Dmitry Kravkov <dkravkov@gmail.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Tested-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-01Merge tag 'please-pull-aertracefix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras Pull aer error logging fix from Tony Luck: "Can't call pci_get_domain_bus_and_slot() from interupt context" * tag 'please-pull-aertracefix' of git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras: aerdrv: Move cper_print_aer() call out of interrupt context
2013-05-31target: Propigate up ->cmd_kref put return via transport_generic_free_cmdNicholas Bellinger
Go ahead and propigate up the ->cmd_kref put return value from target_put_sess_cmd() -> transport_release_cmd() -> transport_put_cmd() -> transport_generic_free_cmd(). This is useful for certain fabrics when determining the active I/O shutdown case with SCF_ACK_KREF where a final target_put_sess_cmd() is still required by the caller. Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-30Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains Netfilter/IPVS fixes for 3.10-rc3, they are: * fix xt_addrtype with IPv6, from Florian Westphal. This required a new hook for IPv6 functions in the netfilter core to avoid hard dependencies with the ipv6 subsystem when this match is only used for IPv4. * fix connection reuse case in IPVS. Currently, if an reused connection are directed to the same server. If that server is down, those connection would fail. Therefore, clear the connection and choose a new server among the available ones. * fix possible non-nul terminated string sent to user-space if ipt_ULOG is used as the default netfilter logging stub, from Chen Gang. * fix mark logging of IPv6 packets in xt_LOG, from Michal Kubecek. This bug has been there since 2.6.26. * Fix breakage ip_vs_sh due to incorrect structure layout for RCU, from Jan Beulich. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31Merge tag 'stable/for-linus-3.10-rc3-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fixes from Konrad Rzeszutek Wilk: - Use proper error paths - Clean up APIC IPI usage (incorrect arguments) - Delay XenBus frontend resume is backend (xenstored) is not running - Fix build error with various combinations of CONFIG_ * tag 'stable/for-linus-3.10-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xenbus_client.c: correct exit path for xenbus_map_ring_valloc_hvm xen-pciback: more uses of cached MSI-X capability offset xen: Clean up apic ipi interface xenbus: save xenstore local status for later use xenbus: delay xenbus frontend resume if xenstored is not running xmem/tmem: fix 'undefined variable' build error.
2013-05-30aerdrv: Move cper_print_aer() call out of interrupt contextLance Ortiz
The following warning was seen on 3.9 when a corrected PCIe error was being handled by the AER subsystem. WARNING: at .../drivers/pci/search.c:214 pci_get_dev_by_id+0x8a/0x90() This occurred because a call to pci_get_domain_bus_and_slot() was added to cper_print_pcie() to setup for the call to cper_print_aer(). The warning showed up because cper_print_pcie() is called in an interrupt context and pci_get* functions are not supposed to be called in that context. The solution is to move the cper_print_aer() call out of the interrupt context and into aer_recover_work_func() to avoid any warnings when calling pci_get* functions. Signed-off-by: Lance Ortiz <lance.ortiz@hp.com> Acked-by: Borislav Petkov <bp@suse.de> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-05-29target: Re-instate sess_wait_list for target_wait_for_sess_cmdsNicholas Bellinger
Switch back to pre commit 1c7b13fe652 list splicing logic for active I/O shutdown with tcm_qla2xxx + ib_srpt fabrics. The original commit was done under the incorrect assumption that it's safe to walk se_sess->sess_cmd_list unprotected in target_wait_for_sess_cmds() after sess->sess_tearing_down = 1 has been set by target_sess_cmd_list_set_waiting() during session shutdown. So instead of adding sess->sess_cmd_lock protection around sess->sess_cmd_list during target_wait_for_sess_cmds(), switch back to sess->sess_wait_list to allow wait_for_completion() + TFO->release_cmd() to occur without having to walk ->sess_cmd_list after the list_splice. Also add a check to exit if target_sess_cmd_list_set_waiting() has already been called, and add a WARN_ON to check for any fabric bug where new se_cmds are added to sess->sess_cmd_list after sess->sess_tearing_down = 1 has already been set. Cc: Joern Engel <joern@logfs.org> Cc: Roland Dreier <roland@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-29xenbus: delay xenbus frontend resume if xenstored is not runningAurelien Chartier
If the xenbus frontend is located in a domain running xenstored, the device resume is hanging because it is happening before the process resume. This patch adds extra logic to the resume code to check if we are the domain running xenstored and delay the resume if needed. Signed-off-by: Aurelien Chartier <aurelien.chartier@citrix.com> [Changes in v2: - Instead of bypassing the resume, process it in a workqueue] [Changes in v3: - Add a struct work in xenbus_device to avoid dynamic allocation - Several small code fixes] [Changes in v4: - Use a dedicated workqueue] [Changes in v5: - Move create_workqueue error handling to xenbus_frontend_dev_resume] Acked-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-05-29Merge branch 'fbdev-3.10-fixes' of git://gitorious.org/linux-omap-dss2/linux ↵Jean-Christophe PLAGNIOL-VILLARD
into linux-fbdev/for-3.10-fixes Pull Tomi fixes for ps3fb and omap2 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2013-05-28rcu: Add _notrace variation of rcu_dereference_raw() and ↵Steven Rostedt
hlist_for_each_entry_rcu() As rcu_dereference_raw() under RCU debug config options can add quite a bit of checks, and that tracing uses rcu_dereference_raw(), these checks happen with the function tracer. The function tracer also happens to trace these debug checks too. This added overhead can livelock the system. Add a new interface to RCU for both rcu_dereference_raw_notrace() as well as hlist_for_each_entry_rcu_notrace() as the hlist iterator uses the rcu_dereference_raw() as well, and is used a bit with the function tracer. Link: http://lkml.kernel.org/r/20130528184209.304356745@goodmis.org Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-05-25Merge tag 'pm+acpi-3.10-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: - Additional CPU ID for the intel_pstate driver from Dirk Brandewie. - More cpufreq fixes related to ARM big.LITTLE support and locking from Viresh Kumar. - VIA C7 cpufreq build fix from Rafał Bilski. - ACPI power management fix making it possible to use device power states regardless of the CONFIG_PM setting from Rafael J Wysocki. - New ACPI video blacklist item from Bastian Triller. * tag 'pm+acpi-3.10-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: Add "Asus UL30A" to ACPI video detect blacklist cpufreq: arm_big_little_dt: Instantiate as platform_driver cpufreq: arm_big_little_dt: Register driver only if DT has valid data cpufreq / e_powersaver: Fix linker error when ACPI processor is a module cpufreq / intel_pstate: Add additional supported CPU ID cpufreq: Drop rwsem lock around CPUFREQ_GOV_POLICY_EXIT ACPI / PM: Allow device power states to be used for CONFIG_PM unset
2013-05-25Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma fixes from Vinod Koul: "We have two patches from Andy & Rafael fixing the Lynxpoint dma" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: ACPI / LPSS: register clock device for Lynxpoint DMA properly dma: acpi-dma: parse CSRT to extract additional resources
2013-05-24Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge fixes from Andrew Morton: "A bunch of fixes and one simple fbdev driver which missed the merge window because people will still talking about it (to no great effect)." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (30 commits) aio: fix kioctx not being freed after cancellation at exit time mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas drivers/rtc/rtc-max8998.c: check for pdata presence before dereferencing ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap() random: fix accounting race condition with lockless irq entropy_count update drivers/char/random.c: fix priming of last_data mm/memory_hotplug.c: fix printk format warnings nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary drivers/block/brd.c: fix brd_lookup_page() race fbdev: FB_GOLDFISH should depend on HAS_DMA drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq() auditfilter.c: fix kernel-doc warnings aio: fix io_getevents documentation revert "selftest: add simple test for soft-dirty bit" drivers/leds/leds-ot200.c: fix error caused by shifted mask mm/THP: use pmd_populate() to update the pmd with pgtable_t pointer linux/kernel.h: fix kernel-doc warning mm compaction: fix of improper cache flush in migration code rapidio/tsi721: fix bug in MSI interrupt handling hfs: avoid crash in hfs_bnode_create ...
2013-05-24Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "We didn't have any fixes sent up for -rc2, so this is a slightly larger batch. A bit all over the place platform-wise; OMAP, at91, marvell, renesas, sunxi, ux500, etc. I tried to summarize highlights but there isn't a whole lot to point out. Lots of little things fixed all over. A couple of defconfig updates due to new/changing options." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits) ARM: at91/sama5: fix incorrect PMC pcr div definition ARM: at91/dt: fix macb pinctrl_macb_rmii_mii_alt definition ARM: at91: at91sam9n12: move external irq declatation to DT ARM: shmobile: marzen: Use error values in usb_power_* ARM: tegra: defconfig fixes ARM: nomadik: fix IRQ assignment for SMC ethernet ARM: vt8500: Add missing NULL terminator in dt_compat clk: tegra: add ac97 controller clock clk: tegra: remove USB from clk init table ARM: dts: mvebu: Fix wrong the address reg value for the L2-cache node ARM: plat-orion: Fix num_resources and id for ge10 and ge11 ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis SERIAL: OMAP: Remove the slave idle handling from the driver ARM: OMAP2+: serial: Remove the un-used slave idle hooks ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc() arm: mvebu: fix the 'ranges' property to handle PCIe ARM: mvebu: select ARCH_REQUIRE_GPIOLIB for mvebu platform ARM: AM33XX: Add missing .clkdm_name to clkdiv32k_ick clock ...
2013-05-24linux/kernel.h: fix kernel-doc warningRandy Dunlap
Fix kernel-doc warning in <linux/kernel.h>: Warning(include/linux/kernel.h:590): No description found for parameter 'ip' scripts/kernel-doc cannot handle macros, functions, or function prototypes between the function or macro that is being documented and its definition, so move these prototypes above the function that is being documented. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24wait: fix false timeouts when using wait_event_timeout()Imre Deak
Many callers of the wait_event_timeout() and wait_event_interruptible_timeout() expect that the return value will be positive if the specified condition becomes true before the timeout elapses. However, at the moment this isn't guaranteed. If the wake-up handler is delayed enough, the time remaining until timeout will be calculated as 0 - and passed back as a return value - even if the condition became true before the timeout has passed. Fix this by returning at least 1 if the condition becomes true. This semantic is in line with what wait_for_condition_timeout() does; see commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious failure under heavy load"). Daniel said "We have 3 instances of this bug in drm/i915. One case even where we switch between the interruptible and not interruptible wait_event_timeout variants, foolishly presuming they have the same semantics. I very much like this." One such bug is reported at https://bugs.freedesktop.org/show_bug.cgi?id=64133 Signed-off-by: Imre Deak <imre.deak@intel.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Lukas Czerner <lczerner@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24rapidio: add enumeration/discovery start from user spaceAlexandre Bounine
Add RapidIO enumeration/discovery start from user space. User space start allows to defer RapidIO fabric scan until the moment when all participating endpoints are initialized avoiding mandatory synchronized start of all endpoints (which may be challenging in systems with large number of RapidIO endpoints). Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24rapidio: make enumeration/discovery configurableAlexandre Bounine
Systems that use RapidIO fabric may need to implement their own enumeration and discovery methods which are better suitable for needs of a target application. The following set of patches is intended to simplify process of introduction of new RapidIO fabric enumeration/discovery methods. The first patch offers ability to add new RapidIO enumeration/discovery methods using kernel configuration options. This new configuration option mechanism allows to select statically linked or modular enumeration/discovery method(s) from the list of existing methods or use external module(s). This patch also updates the currently existing enumeration/discovery code to be used as a statically linked or modular method. The corresponding configuration option is named "Basic enumeration/discovery" method. This is the only one configuration option available today but new methods are expected to be introduced after adoption of provided patches. The second patch address a long time complaint of RapidIO subsystem users regarding fabric enumeration/discovery start sequence. Existing implementation offers only a boot-time enumeration/discovery start which requires synchronized boot of all endpoints in RapidIO network. While it works for small closed configurations with limited number of endpoints, using this approach in systems with large number of endpoints is quite challenging. To eliminate requirement for synchronized start the second patch introduces RapidIO enumeration/discovery start from user space. For compatibility with the existing RapidIO subsystem implementation, automatic boot time enumeration/discovery start can be configured in by specifying "rio-scan.scan=1" command line parameter if statically linked basic enumeration method is selected. This patch: Rework to implement RapidIO enumeration/discovery method selection combined with ability to use enumeration/discovery as a kernel module. This patch adds ability to introduce new RapidIO enumeration/discovery methods using kernel configuration options. Configuration option mechanism allows to select statically linked or modular enumeration/discovery method from the list of existing methods or use external modules. If a modular enumeration/discovery is selected each RapidIO mport device can have its own method attached to it. The existing enumeration/discovery code was updated to be used as statically linked or modular method. This configuration option is named "Basic enumeration/discovery" method. Several common routines have been moved from rio-scan.c to make them available to other enumeration methods and reduce number of exported symbols. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "It's been a while since my last pull request so quite a few fixes have piled up." Indeed. 1) Fix nf_{log,queue} compilation with PROC_FS disabled, from Pablo Neira Ayuso. 2) Fix data corruption on some tg3 chips with TSO enabled, from Michael Chan. 3) Fix double insertion of VLAN tags in be2net driver, from Sarveshwar Bandi. 4) Don't have TCP's MD5 support pass > PAGE_SIZE page offsets in scatter-gather entries into the crypto layer, the crypto layer can't handle that. From Eric Dumazet. 5) Fix lockdep splat in 802.1Q MRP code, also from Eric Dumazet. 6) Fix OOPS in netfilter log module when called from conntrack, from Hans Schillstrom. 7) FEC driver needs to use netif_tx_{lock,unlock}_bh() rather than the non-BH disabling variants. From Fabio Estevam. 8) TCP GSO can generate out-of-order packets, fix from Eric Dumazet. 9) vxlan driver doesn't update 'used' field of fdb entries when it should, from Sridhar Samudrala. 10) ipv6 should use kzalloc() to allocate inet6 socket cork options, otherwise we can OOPS in ip6_cork_release(). From Eric Dumazet. 11) Fix races in bonding set mode, from Nikolay Aleksandrov. 12) Fix checksum generation regression added by "r8169: fix 8168evl frame padding.", from Francois Romieu. 13) ip_gre can look at stale SKB data pointer, fix from Eric Dumazet. 14) Fix checksum handling when GSO is enabled in bnx2x driver with certain chips, from Yuval Mintz. 15) Fix double free in batman-adv, from Martin Hundebøll. 16) Fix device startup synchronization with firmware in tg3 driver, from Nithin Sujit. 17) perf networking dropmonitor doesn't work at all due to mixed up trace parameter ordering, from Ben Hutchings. 18) Fix proportional rate reduction handling in tcp_ack(), from Nandita Dukkipati. 19) IPSEC layer doesn't return an error when a valid state is detected, causing an OOPS. Fix from Timo Teräs. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) be2net: bug fix on returning an invalid nic descriptor tcp: xps: fix reordering issues net: Revert unused variable changes. xfrm: properly handle invalid states as an error virtio_net: enable napi for all possible queues during open tcp: bug fix in proportional rate reduction. net: ethernet: sun: drop unused variable net: ethernet: korina: drop unused variable net: ethernet: apple: drop unused variable qmi_wwan: Added support for Cinterion's PLxx WWAN Interface perf: net_dropmonitor: Remove progress indicator perf: net_dropmonitor: Use bisection in symbol lookup perf: net_dropmonitor: Do not assume ordering of dictionaries perf: net_dropmonitor: Fix symbol-relative addresses perf: net_dropmonitor: Fix trace parameter order net: fec: use a more proper compatible string for MVF type device qlcnic: Fix updating netdev->features qlcnic: remove netdev->trans_start updates within the driver qlcnic: Return proper error codes from probe failure paths tg3: Update version to 3.132 ...
2013-05-24cgroup: fix a subtle bug in descendant pre-order walkTejun Heo
When cgroup_next_descendant_pre() initiates a walk, it checks whether the subtree root doesn't have any children and if not returns NULL. Later code assumes that the subtree isn't empty. This is broken because the subtree may become empty inbetween, which can lead to the traversal escaping the subtree by walking to the sibling of the subtree root. There's no reason to have the early exit path. Remove it along with the later assumption that the subtree isn't empty. This simplifies the code a bit and fixes the subtle bug. While at it, fix the comment of cgroup_for_each_descendant_pre() which was incorrectly referring to ->css_offline() instead of ->css_online(). Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: stable@vger.kernel.org
2013-05-23Merge tag 'pci-v3.10-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Here are some more fixes for v3.10. The Moorestown update broke Intel Medfield devices, so I reverted it. The acpiphp change fixes a regression: we broke hotplug notifications to host bridges when we split acpiphp into the host-bridge related part and the endpoint-related part. Moorestown Revert "x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0" Hotplug PCI: acpiphp: Re-enumerate devices when host bridge receives Bus Check" * tag 'pci-v3.10-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: Revert "x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0" PCI: acpiphp: Re-enumerate devices when host bridge receives Bus Check
2013-05-23Merge tag 'tty-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are some tty / serial driver fixes for 3.10-rc2. Nothing huge, although the rocket driver fix looks large, it's just moving the code around to fix the reported build issues in it. Other than that, this has the fix for the of-reported lockdep warning from the vt layer, as well as some other needed bugfixes. All of these have been in linux-next for a while" * tag 'tty-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: mxser: Fix build warning introduced by dfc7b837c7f9 (Re: linux-next: build warning after merge of the tty.current tree) tty: mxser: fix usage of opmode_ioaddr serial: 8250_dw: add ACPI ID for Intel BayTrail TTY: Fix tty miss restart after we turn off flow-control tty/vt: Fix vc_deallocate() lock order TTY: ehv_bytechan: add missing platform_driver_unregister() when module exit TTY: rocket, fix more no-PCI warnings serial: mcf: missing uart_unregister_driver() on error in mcf_init() tty: serial: mpc5xxx: fix error handing in mpc52xx_uart_init() serial: samsung: add missing platform_driver_unregister() when module exit serial: pl011: protect attribute read from NULL platform data struct tty: nwpserial: Pass correct pointer to free_irq() serial: 8250_dw: Add valid clk pointer check
2013-05-23Merge tag 'usb-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg Kroah-Hartman: "Here are a number of tiny USB bugfixes / new device ids for 3.10-rc2 The majority of these are USB gadget fixes, but they are all small. Other than that, some USB host controller fixes, and USB serial driver fixes for problems reported with them. Also hopefully a fixed up USB_OTG Kconfig dependancy, that one seems to be almost impossible to get right for all of the different platforms these days." * tag 'usb-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (56 commits) USB: cxacru: potential underflow in cxacru_cm_get_array() USB: ftdi_sio: Add support for Newport CONEX motor drivers USB: option: add device IDs for Dell 5804 (Novatel E371) WWAN card usb: ohci: fix goto wrong tag in err case usb: isp1760-if: fix memleak when platform_get_resource fail usb: ehci-s5p: fix memleak when fallback to pdata USB: serial: clean up chars_in_buffer USB: ti_usb_3410_5052: fix chars_in_buffer overhead USB: io_ti: fix chars_in_buffer overhead USB: ftdi_sio: fix chars_in_buffer overhead USB: ftdi_sio: clean up get_modem_status USB: serial: add generic wait_until_sent implementation USB: serial: add wait_until_sent operation USB: set device dma_mask without reference to global data USB: Blacklisted Cinterion's PLxx WWAN Interface usb: option: Add Telewell TW-LTE 4G USB: EHCI: remove bogus #error USB: reset resume quirk needed by a hub USB: usb-stor: realtek_cr: Fix compile error usb, chipidea: fix link error when USB_EHCI_HCD is a module ...
2013-05-23netfilter: add nf_ipv6_ops hook to fix xt_addrtype with IPv6Florian Westphal
Quoting https://bugzilla.netfilter.org/show_bug.cgi?id=812: [ ip6tables -m addrtype ] When I tried to use in the nat/PREROUTING it messes up the routing cache even if the rule didn't matched at all. [..] If I remove the --limit-iface-in from the non-working scenario, so just use the -m addrtype --dst-type LOCAL it works! This happens when LOCAL type matching is requested with --limit-iface-in, and the default ipv6 route is via the interface the packet we test arrived on. Because xt_addrtype uses ip6_route_output, the ipv6 routing implementation creates an unwanted cached entry, and the packet won't make it to the real/expected destination. Silently ignoring --limit-iface-in makes the routing work but it breaks rule matching (--dst-type LOCAL with limit-iface-in is supposed to only match if the dst address is configured on the incoming interface; without --limit-iface-in it will match if the address is reachable via lo). The test should call ipv6_chk_addr() instead. However, this would add a link-time dependency on ipv6. There are two possible solutions: 1) Revert the commit that moved ipt_addrtype to xt_addrtype, and put ipv6 specific code into ip6t_addrtype. 2) add new "nf_ipv6_ops" struct to register pointers to ipv6 functions. While the former might seem preferable, Pablo pointed out that there are more xt modules with link-time dependeny issues regarding ipv6, so lets go for 2). Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-23OMAPDSS: Fix crash with DT bootTomi Valkeinen
When booting with DT, there's a crash when omapfb is probed. This is caused by the fact that omapdss+DT is not yet supported, and thus omapdss is not probed at all. On the other hand, omapfb is always probed. When omapfb tries to use omapdss, there's a NULL pointer dereference crash. The same error should most likely happen with omapdrm and omap_vout also. To fix this, add an "initialized" state to omapdss. When omapdss has been probed, it's marked as initialized. omapfb, omapdrm and omap_vout check this state when they are probed to see that omapdss is actually there. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2013-05-22Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS update from Ralf Baechle: - Fix a build error if <linux/printk.h> is included without <linux/linkage.h> having been included before. - Cleanup and fix the damage done by the generic idle loop patch. - A kprobes fix that brings the MIPS code in line with what other architectures are for quite a while already. - Wire up the native getdents64(2) syscall for 64 bit - for some reason it was only for the compat ABIs. This has been reported to cause an application issue. This turned out bigger than I meant but the wait instruction support code was driving me nuts. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: N64: Wire getdents64(2) kprobes/mips: Fix to check double free of insn slot MIPS: Idle: Break r4k_wait into two functions and fix it. MIPS: Idle: Do address fiddlery in helper functions. MIPS: Idle: Consolidate all declarations in <asm/idle.h>. MIPS: Idle: Don't call local_irq_disable() in cpu_wait() implementations. MIPS: Idle: Re-enable irqs at the end of r3081, au1k and loongson2 cpu_wait. MIPS: Idle: Make call of function pointer readable. MIPS: Idle: Consistently reformat inline assembler. MIPS: Idle: cleaup SMTC idle hook as per Linux coding style. MIPS: Consolidate idle loop / WAIT instruction support in a single file. MIPS: clock.h: Remove declaration of cpu_wait. Add include dependencies to <linux/printk.h>. MIPS: Rewrite pfn_valid to work in modules, too.
2013-05-22Merge tag 'omap-fixes-a-for-3.10-rc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into fixes From Paul Walmsley: Fix the OMAP serial driver to work correctly on OMAP4 when booting with DT. * tag 'omap-fixes-a-for-3.10-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending: ARM: OMAP2+: hwmod: Remove sysc slave idle and auto idle apis SERIAL: OMAP: Remove the slave idle handling from the driver ARM: OMAP2+: serial: Remove the un-used slave idle hooks ARM: OMAP2+: hwmod-data: UART IP needs software control to manage sidle modes ARM: OMAP2+: hwmod: Add a new flag to handle SIDLE in SWSUP only in active ARM: OMAP2+: hwmod: Fix sidle programming in _enable_sysc()/_idle_sysc() Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-22Merge tag 'mfd-fixes-3.10-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes Pull mfd fixes from Samuel Ortiz: "This is the first batch of MFD fixes for 3.10. It's bigger than I would like, most of it is due to the big ab/db8500 merge that went through during the 3.10 merge window. So we have: - Some build fixes for the tps65912 and ab8500 drivers. - A couple of build fixes for the the si476x driver with pre 4.3 gcc compilers. - A few runtime breakage fixes (probe failures or oopses) for the ab8500 and db8500 drivers. - Some sparse or regular gcc warning fixes for the si476x, ab8500 and cros_ec drivers." * tag 'mfd-fixes-3.10-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes: mfd: ab8500-sysctrl: Let sysctrl driver work without pdata mfd: db8500-prcmu: Update stored DSI PLL divider value mfd: ab8500-sysctrl: Always enable pm_power_off handler mfd: ab8500-core: Pass GPADC compatible string to MFD core mfd: db8500-prcmu: Supply the pdata_size attribute for db8500-thermal mfd: ab8500-core: Use the correct driver name when enabling gpio/pinctrl mfd: ab8500: Pass AB8500 IRQ to debugfs code by resource mfd: ab8500-gpadc: Suppress 'ignoring regulator_enable() return value' warning mfd: ab8500-sysctrl: Set sysctrl_dev during probe mfd: ab8500-sysctrl: Fix sparse warning mfd: abx500-core: Fix sparse warning mfd: ab8500: Debugfs code depends on gpadc mfd: si476x: Use get_unaligned_be16() for unaligned be16 loads mfd: cros_ec_spi: Use %z to format pointer differences mfd: si476x: Do not use binary constants mfd: tps65912: Select MFD_CORE
2013-05-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio fixes from Rusty Russell: "A build fix and a uapi exposure fix. The build fix is later than I liked, but my first version broke linux-next due to overzealous header clean." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio_console: fix uapi header Hoist memcpy_fromiovec/memcpy_toiovec into lib/
2013-05-22kernel: Fix s390 absolute memory access for /dev/memMichael Holzheu
On s390 the prefix page and absolute zero pages are not correctly returned when reading /dev/mem. The reason is that the s390 asm/io.h file includes the asm-generic/io.h file which then defines xlate_dev_mem_ptr() and therefore overwrites the s390 specific version that does the correct swap operation for prefix and absolute zero pages. The problem is a regression that was introduced with git commit cd248341 (s390/pci: base support). To fix the problem add "#ifndef xlate_dev_mem_ptr" in asm-generic/io.h and "#define xlate_dev_mem_ptr" in asm/io.h. This ensures that the s390 version is used. For completeness also add the "#ifndef" construct for xlate_dev_kmem_ptr(). Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-05-22Add include dependencies to <linux/printk.h>.Ralf Baechle
If <linux/linkage.h> has not been included before <linux/printk.h>, a build error like the below one will result: CC arch/mips/kernel/idle.o In file included from arch/mips/kernel/idle.c:17:0: include/linux/printk.h:109:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:109:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:110:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:110:1: error: expected ‘,’ or ‘;’ before ‘int’ include/linux/printk.h:114:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:114:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:115:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:115:1: error: expected ‘,’ or ‘;’ before ‘int’ include/linux/printk.h:117:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:117:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:118:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:118:1: error: ‘__cold__’ attribute ignored [-Werror=attributes] include/linux/printk.h:118:1: error: expected ‘,’ or ‘;’ before ‘asmlinkage’ include/linux/printk.h:122:1: error: data definition has no type or storage class [-Werror] include/linux/printk.h:122:1: error: type defaults to ‘int’ in declaration of ‘asmlinkage’ [-Werror=implicit-int] include/linux/printk.h:123:1: error: ‘format’ attribute only applies to function types [-Werror=attributes] include/linux/printk.h:123:1: error: ‘__cold__’ attribute ignored [-Werror=attributes] include/linux/printk.h:123:1: error: expected ‘,’ or ‘;’ before ‘int’ In file included from include/linux/kernel.h:14:0, from include/linux/sched.h:15, from arch/mips/kernel/idle.c:18: include/linux/dynamic_debug.h: In function ‘ddebug_dyndbg_module_param_cb’: include/linux/dynamic_debug.h:124:3: error: implicit declaration of function ‘printk’ [-Werror=implicit-function-declaration] Fixed by including <linux/linkage.h>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-22ACPI / PM: Allow device power states to be used for CONFIG_PM unsetRafael J. Wysocki
Currently, drivers/acpi/device_pm.c depends on CONFIG_PM and all of the functions defined in there are replaced with static inline stubs if that option is unset. However, CONFIG_PM means, roughly, "runtime PM or suspend/hibernation support" and some of those functions are useful regardless of that. For example, they are used by the ACPI fan driver for controlling fans and acpi_device_set_power() is called during device removal. Moreover, device initialization may depend on setting device power states properly. For these reasons, make the routines manipulating ACPI device power states defined in drivers/acpi/device_pm.c available for CONFIG_PM unset too. Reported-by: Zhang Rui <rui.zhang@intel.com> Reported-and-tested-by: Michel Lespinasse <walken@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: 3.9+ <stable@vger.kernel.org>
2013-05-21Merge branch 'drm-radeon-sun-hainan' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull radeon sun/hainan support from Dave Airlie: "Since I know its outside the merge window, but since this is new hw I thought I'd try and provoke the new hw exception, it just fills in the blanks in the driver for the new AMD sun and hainan chipsets." * 'drm-radeon-sun-hainan' of git://people.freedesktop.org/~airlied/linux: drm/radeon: add Hainan pci ids drm/radeon: add golden register settings for Hainan (v2) drm/radeon: sun/hainan chips do not have UVD (v2) drm/radeon: track which asics have UVD drm/radeon: radeon-asic updates for Hainan drm/radeon: fill in ucode loading support for Hainan drm/radeon: don't touch DCE or VGA regs on Hainan (v3) drm/radeon: fill in GPU init for Hainan (v2) drm/radeon: add chip family for Hainan
2013-05-20target: Remove unused wait_for_tasks bit in target_wait_for_sess_cmdsJoern Engel
Drop unused transport_wait_for_tasks() check in target_wait_for_sess_cmds shutdown code, and convert tcm_qla2xxx + ib_srpt fabric drivers. Cc: Joern Engel <joern@logfs.org> Cc: Roland Dreier <roland@kernel.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2013-05-20Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-05-20tty/vt: Fix vc_deallocate() lock orderPeter Hurley
Now that the tty port owns the flip buffers and i/o is allowed from the driver even when no tty is attached, the destruction of the tty port (and the flip buffers) must ensure that no outstanding work is pending. Unfortunately, this creates a lock order problem with the console_lock (see attached lockdep report [1] below). For single console deallocation, drop the console_lock prior to port destruction. When multiple console deallocation, defer port destruction until the consoles have been deallocated. tty_port_destroy() is not required if the port has not been used; remove from vc_allocate() failure path. [1] lockdep report from Dave Jones <davej@redhat.com> ====================================================== [ INFO: possible circular locking dependency detected ] 3.9.0+ #16 Not tainted ------------------------------------------------------- (agetty)/26163 is trying to acquire lock: blocked: ((&buf->work)){+.+...}, instance: ffff88011c8b0020, at: [<ffffffff81062065>] flush_work+0x5/0x2e0 but task is already holding lock: blocked: (console_lock){+.+.+.}, instance: ffffffff81c2fde0, at: [<ffffffff813bc201>] vt_ioctl+0xb61/0x1230 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (console_lock){+.+.+.}: [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff810416c7>] console_lock+0x77/0x80 [<ffffffff813c3dcd>] con_flush_chars+0x2d/0x50 [<ffffffff813b32b2>] n_tty_receive_buf+0x122/0x14d0 [<ffffffff813b7709>] flush_to_ldisc+0x119/0x170 [<ffffffff81064381>] process_one_work+0x211/0x700 [<ffffffff8106498b>] worker_thread+0x11b/0x3a0 [<ffffffff8106ce5d>] kthread+0xed/0x100 [<ffffffff81601cac>] ret_from_fork+0x7c/0xb0 -> #0 ((&buf->work)){+.+...}: [<ffffffff810b349a>] __lock_acquire+0x193a/0x1c00 [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff810620ae>] flush_work+0x4e/0x2e0 [<ffffffff81065305>] __cancel_work_timer+0x95/0x130 [<ffffffff810653b0>] cancel_work_sync+0x10/0x20 [<ffffffff813b8212>] tty_port_destroy+0x12/0x20 [<ffffffff813c65e8>] vc_deallocate+0xf8/0x110 [<ffffffff813bc20c>] vt_ioctl+0xb6c/0x1230 [<ffffffff813b01a5>] tty_ioctl+0x285/0xd50 [<ffffffff811ba825>] do_vfs_ioctl+0x305/0x530 [<ffffffff811baad1>] sys_ioctl+0x81/0xa0 [<ffffffff81601d59>] system_call_fastpath+0x16/0x1b other info that might help us debug this: [ 6760.076175] Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(console_lock); lock((&buf->work)); lock(console_lock); lock((&buf->work)); *** DEADLOCK *** 1 lock on stack by (agetty)/26163: #0: blocked: (console_lock){+.+.+.}, instance: ffffffff81c2fde0, at: [<ffffffff813bc201>] vt_ioctl+0xb61/0x1230 stack backtrace: Pid: 26163, comm: (agetty) Not tainted 3.9.0+ #16 Call Trace: [<ffffffff815edb14>] print_circular_bug+0x200/0x20e [<ffffffff810b349a>] __lock_acquire+0x193a/0x1c00 [<ffffffff8100a269>] ? sched_clock+0x9/0x10 [<ffffffff8100a269>] ? sched_clock+0x9/0x10 [<ffffffff8100a200>] ? native_sched_clock+0x20/0x80 [<ffffffff810b3f74>] lock_acquire+0xa4/0x210 [<ffffffff81062065>] ? flush_work+0x5/0x2e0 [<ffffffff810620ae>] flush_work+0x4e/0x2e0 [<ffffffff81062065>] ? flush_work+0x5/0x2e0 [<ffffffff810b15db>] ? mark_held_locks+0xbb/0x140 [<ffffffff8113c8a3>] ? __free_pages_ok.part.57+0x93/0xc0 [<ffffffff810b15db>] ? mark_held_locks+0xbb/0x140 [<ffffffff810652f2>] ? __cancel_work_timer+0x82/0x130 [<ffffffff81065305>] __cancel_work_timer+0x95/0x130 [<ffffffff810653b0>] cancel_work_sync+0x10/0x20 [<ffffffff813b8212>] tty_port_destroy+0x12/0x20 [<ffffffff813c65e8>] vc_deallocate+0xf8/0x110 [<ffffffff813bc20c>] vt_ioctl+0xb6c/0x1230 [<ffffffff810aec41>] ? lock_release_holdtime.part.30+0xa1/0x170 [<ffffffff813b01a5>] tty_ioctl+0x285/0xd50 [<ffffffff812b00f6>] ? inode_has_perm.isra.46.constprop.61+0x56/0x80 [<ffffffff811ba825>] do_vfs_ioctl+0x305/0x530 [<ffffffff812b04db>] ? selinux_file_ioctl+0x5b/0x110 [<ffffffff811baad1>] sys_ioctl+0x81/0xa0 [<ffffffff81601d59>] system_call_fastpath+0x16/0x1b Cc: Dave Jones <davej@redhat.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20drm/radeon: add Hainan pci idsAlex Deucher
Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com>
