commit b027e2298bd588d6fa36ed2eda97447fb3eac078 upstream.
There can be a race, if receive_buf call comes before
tty initialization completes in n_tty_open and tty->disc_data
may be NULL.
CPU0 CPU1
000|n_tty_receive_buf_common() n_tty_open()
-001|n_tty_receive_buf2() tty_ldisc_open.isra.3()
-002|tty_ldisc_receive_buf(inline) tty_ldisc_setup()
Using ldisc semaphore lock in tty_init_dev till disc_data
initializes completely.
Signed-off-by: Gaurav Kohli <gkohli@codeaurora.org>
Reviewed-by: Alan Cox <alan@linux.intel.com>
commit 1410a90ae449061b7e1ae19d275148f36948801b upstream.
HW can implement UMR wqe re-transmission in various ways.
Thus, add HCA cap to distinguish the needed fence for UMR to make
sure that the wqe wouldn't fail on mkey checks.
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
Acked-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Cc: Marta Rybczynska <mrybczyn@kalray.eu>
[ upstream commit be95a845cc4402272994ce290e3ad928aff06cb9 ]
In addition to commit b2157399cc98 ("bpf: prevent out-of-bounds
speculation") also change the layout of struct bpf_map such that
false sharing of fast-path members like max_entries is avoided
when the maps reference counter is altered. Therefore enforce
them to be placed into separate cachelines.
pahole dump after change:
struct bpf_map {
const struct bpf_map_ops * ops; /* 0 8 */
struct bpf_map * inner_map_meta; /* 8 8 */
void * security; /* 16 8 */
enum bpf_map_type map_type; /* 24 4 */
u32 key_size; /* 28 4 */
u32 value_size; /* 32 4 */
u32 max_entries; /* 36 4 */
u32 map_flags; /* 40 4 */
u32 pages; /* 44 4 */
u32 id; /* 48 4 */
int numa_node; /* 52 4 */
bool unpriv_array; /* 56 1 */
/* XXX 7 bytes hole, try to pack */
/* --- cacheline 1 boundary (64 bytes) --- */
struct user_struct * user; /* 64 8 */
atomic_t refcnt; /* 72 4 */
atomic_t usercnt; /* 76 4 */
struct work_struct work; /* 80 32 */
char name[16]; /* 112 16 */
/* --- cacheline 2 boundary (128 bytes) --- */
/* size: 128, cachelines: 2, members: 17 */
/* sum members: 121, holes: 1, sum holes: 7 */
Now all entries in the first cacheline are read only throughout
the life time of the map, set up once during map creation. Overall
struct size and number of cachelines doesn't change from the
reordering. struct bpf_map is usually first member and embedded
in map structs in specific map implementations, so also avoid those
members to sit at the end where it could potentially share the
cacheline with first map values e.g. in the array since remote
CPUs could trigger map updates just as well for those (easily
dirtying members like max_entries intentionally as well) while
having subsequent values in cache.
Quoting from Google's Project Zero blog [1]:
Additionally, at least on the Intel machine on which this was
tested, bouncing modified cache lines between cores is slow,
apparently because the MESI protocol is used for cache coherence
[8]. Changing the reference counter of an eBPF array on one
physical CPU core causes the cache line containing the reference
counter to be bounced over to that CPU core, making reads of the
reference counter on all other CPU cores slow until the changed
reference counter has been written back to memory. Because the
length and the reference counter of an eBPF array are stored in
the same cache line, this also means that changing the reference
counter on one physical CPU core causes reads of the eBPF array's
length to be slow on other physical CPU cores (intentional false
sharing).
While this doesn't 'control' the out-of-bounds speculation through
masking the index as in commit b2157399cc98, triggering a manipulation
of the map's reference counter is really trivial, so lets not allow
to easily affect max_entries from it.
Splitting to separate cachelines also generally makes sense from
a performance perspective anyway in that fast-path won't have a
cache miss if the map gets pinned, reused in other progs, etc out
of control path, thus also avoids unintentional false sharing.
[1] https://googleprojectzero.blogspot.ch/2018/01/reading-privileged-memory-with-side.html
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit cd9ff4de0107c65d69d02253bb25d6db93c3dbc1 ]
Map all lookup neigh keys to INADDR_ANY for loopback/point-to-point devices
to avoid making an entry for every remote ip the device needs to talk to.
This used the be the old behavior but became broken in a263b3093641f
(ipv4: Make neigh lookups directly in output packet path) and later removed
in 0bb4087cbec0 (ipv4: Fix neigh lookup keying over loopback/point-to-point
devices) because it was broken.
Signed-off-by: Jim Westfall <jwestfall@surrealistic.net>
[ Upstream commit 4ee806d51176ba7b8ff1efd81f271d7252e03a1d ]
When a tcp socket is closed, if it detects that its net namespace is
exiting, close immediately and do not wait for FIN sequence.
For normal sockets, a reference is taken to their net namespace, so it will
never exit while the socket is open. However, kernel sockets do not take a
reference to their net namespace, so it may begin exiting while the kernel
socket is still open. In this case if the kernel socket is a tcp socket,
it will stay open trying to complete its close sequence. The sock's dst(s)
hold a reference to their interface, which are all transferred to the
namespace's loopback interface when the real interfaces are taken down.
When the namespace tries to take down its loopback interface, it hangs
waiting for all references to the loopback interface to release, which
results in messages like:
unregister_netdevice: waiting for lo to become free. Usage count = 1
These messages continue until the socket finally times out and closes.
Since the net namespace cleanup holds the net_mutex while calling its
registered pernet callbacks, any new net namespace initialization is
blocked until the current net namespace finishes exiting.
After this change, the tcp socket notices the exiting net namespace, and
closes immediately, releasing its dst(s) and their reference to the
loopback interface, which lets the net namespace continue exiting.
Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1711407
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=97811
Signed-off-by: Dan Streetman <ddstreet@canonical.com>
[ Upstream commit e9191ffb65d8e159680ce0ad2224e1acbde6985c ]
Commit 513674b5a2c9 ("net: reevalulate autoflowlabel setting after
sysctl setting") removed the initialisation of
ipv6_pinfo::autoflowlabel and added a second flag to indicate
whether this field or the net namespace default should be used.
The getsockopt() handling for this case was not updated, so it
currently returns 0 for all sockets for which IPV6_AUTOFLOWLABEL is
not explicitly enabled. Fix it to return the effective value, whether
that has been set at the socket or net namespace level.
Fixes: 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 7e040726850a106587485c21bdacc0bfc8a0cbed upstream.
[resend due to me forgetting to cc: linux-api the first time around I
posted these back on Feb 23]
From: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
For some reason these values are not in the uapi header file, so any
libc has to define it themselves. To prevent them from needing to do
this, just have the kernel provide the correct values.
Reported-by: Elliott Hughes <enh@google.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
commit c73322d098e4b6f5f0f0fa1330bf57e218775539 upstream.
Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and
cleanups".
Jia reported a scenario in which the kswapd of a node indefinitely spins
at 100% CPU usage. We have seen similar cases at Facebook.
The kernel's current method of judging its ability to reclaim a node (or
whether to back off and sleep) is based on the amount of scanned pages
in proportion to the amount of reclaimable pages. In Jia's and our
scenarios, there are no reclaimable pages in the node, however, and the
condition for backing off is never met. Kswapd busyloops in an attempt
to restore the watermarks while having nothing to work with.
This series reworks the definition of an unreclaimable node based not on
scanning but on whether kswapd is able to actually reclaim pages in
MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria
the page allocator uses for giving up on direct reclaim and invoking the
OOM killer. If it cannot free any pages, kswapd will go to sleep and
leave further attempts to direct reclaim invocations, which will either
make progress and re-enable kswapd, or invoke the OOM killer.
Patch #1 fixes the immediate problem Jia reported, the remainder are
smaller fixlets, cleanups, and overall phasing out of the old method.
Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(),
and directly related to #5, but in itself not relevant to the series.
If the whole series is too ambitious for 4.11, I would consider the
first three patches fixes, the rest cleanups.
This patch (of 9):
Jia He reports a problem with kswapd spinning at 100% CPU when
requesting more hugepages than memory available in the system:
$ echo 4000 >/proc/sys/vm/nr_hugepages
top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01
Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers
KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3
At that time, there are no reclaimable pages left in the node, but as
kswapd fails to restore the high watermarks it refuses to go to sleep.
Kswapd needs to back away from nodes that fail to balance. Up until
commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of
nodes") kswapd had such a mechanism. It considered zones whose
theoretically reclaimable pages it had reclaimed six times over as
unreclaimable and backed away from them. This guard was erroneously
removed as the patch changed the definition of a balanced node.
However, simply restoring this code wouldn't help in the case reported
here: there *are* no reclaimable pages that could be scanned until the
threshold is met. Kswapd would stay awake anyway.
Introduce a new and much simpler way of backing off. If kswapd runs
through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single
page, make it back off from the node. This is the same number of shots
direct reclaim takes before declaring OOM. Kswapd will go to sleep on
that node until a direct reclaimer manages to reclaim some pages, thus
proving the node reclaimable again.
[hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count]
Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org
[shakeelb@google.com: fix condition for throttle_direct_reclaim]
Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com
Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reported-by: Jia He <hejianet@gmail.com>
Tested-by: Jia He <hejianet@gmail.com>
Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: Dmitry Shmidt <dimitrysh@google.com>
commit 5132ede0fe8092b043dae09a7cc32b8ae7272baa upstream.
This reverts commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12.
Turns out distros do not want to make retpoline as part of their "ABI",
so this patch should not have been merged. Sorry Andi, this was my
fault, I suggested it when your original patch was the "correct" way of
doing this instead.
Reported-by: Jiri Kosina <jikos@kernel.org>
Fixes: 6cfb521ac0d5 ("module: Add retpoline tag to VERMAGIC")
Acked-by: Andi Kleen <ak@linux.intel.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: rusty@rustcorp.com.au
Cc: arjan.van.de.ven@intel.com
Cc: jeyu@kernel.org
commit fac51482577d5e05bbb0efa8d602a3c2111098bf upstream.
With CONFIG_OF enabled on x86, we get the following error on boot:
Failed to find cpu0 device node
Unable to detect cache hierarchy from DT for CPU 0
and the cacheinfo fails to get populated in the corresponding sysfs
entries. This is because cache_setup_of_node looks for of_node for
setting up the shared cpu_map without checking that it's already
populated in the architecture specific callback.
In order to indicate that the shared cpu_map is already populated, this
patch introduces a boolean `cpu_map_populated` in struct cpu_cacheinfo
that can be used by the generic code to skip cache_shared_cpu_map_setup.
This patch also sets that boolean for x86.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com>
commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12 upstream.
Add a marker for retpoline to the module VERMAGIC. This catches the case
when a non RETPOLINE compiled module gets loaded into a retpoline kernel,
making it insecure.
It doesn't handle the case when retpoline has been runtime disabled. Even
in this case the match of the retcompile status will be enforced. This
implies that even with retpoline run time disabled all modules loaded need
to be recompiled.
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: jeyu@kernel.org
Cc: torvalds@linux-foundation.org
Link: https://lkml.kernel.org/r/20180116205228.4890-1-andi@firstfloor.org
commit 745dfa0d8ec26b24f3304459ff6e9eacc5c8351b upstream.
The ioctl SET_FORCE_LOW_DMA has never worked since the initial git
check-in, and the respective setting is nowadays handled correctly. So
disable it entirely.
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
commit e390f9a9689a42f477a6073e2e7df530a4c1b740 upstream.
The '__unreachable' and '__func_stack_frame_non_standard' sections are
only used at compile time. They're discarded for vmlinux but they
should also be discarded for modules.
Since this is a recurring pattern, prefix the section names with
".discard.". It's a nice convention and vmlinux.lds.h already discards
such sections.
Also remove the 'a' (allocatable) flag from the __unreachable section
since it doesn't make sense for a discarded section.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jessica Yu <jeyu@redhat.com>
Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends")
Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble
[dwmw2: Remove the unreachable part in backporting since it's not here yet]
Signed-off-by: David Woodhouse <dwmw@amazon.co.ku>
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream.
As the meltdown/spectre problem affects several CPU architectures, it makes
sense to have common way to express whether a system is affected by a
particular vulnerability or not. If affected the way to express the
mitigation should be common as well.
Create /sys/devices/system/cpu/vulnerabilities folder and files for
meltdown, spectre_v1 and spectre_v2.
Allow architectures to override the show function.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Linus Torvalds <torvalds@linuxfoundation.org>
Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream.
Under speculation, CPUs may mis-predict branches in bounds checks. Thus,
memory accesses under a bounds check may be speculated even if the
bounds check fails, providing a primitive for building a side channel.
To avoid leaking kernel data round up array-based maps and mask the index
after bounds check, so speculated load with out of bounds index will load
either valid value from the array or zero from the padded area.
Unconditionally mask index for all array types even when max_entries
are not rounded to power of 2 for root user.
When map is created by unpriv user generate a sequence of bpf insns
that includes AND operation to make sure that JITed code includes
the same 'index & index_mask' operation.
If prog_array map is created by unpriv user replace
bpf_tail_call(ctx, map, index);
with
if (index >= max_entries) {
index &= map->index_mask;
(along with roundup to power 2) to prevent out-of-bounds speculation.
There is secondary redundant 'if (index >= max_entries)' in the interpreter
and in all JITs, but they can be optimized later if necessary.
Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array)
cannot be used by unpriv, so no changes there.
That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on
all architectures with and without JIT.
v2->v3:
Daniel noticed that attack potentially can be crafted via syscall commands
without loading the program, so add masking to those paths as well.
Acked-by: John Fastabend <john.fastabend@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
[ Backported to 4.9 - gregkh ]
commit 1c21a48055a67ceb693e9c2587824a8de60a217c upstream.
This patch fixes bug where early se_cmd exceptions that occur
before backend execution can result in use-after-free if/when
a subsequent ABORT_TASK occurs for the same tag.
Since an early se_cmd exception will have had se_cmd added to
se_session->sess_cmd_list via target_get_sess_cmd(), it will
not have CMD_T_COMPLETE set by the usual target_complete_cmd()
backend completion path.
This causes a subsequent ABORT_TASK + __target_check_io_state()
to signal ABORT_TASK should proceed. As core_tmr_abort_task()
executes, it will bring the outstanding se_cmd->cmd_kref count
down to zero releasing se_cmd, after se_cmd has already been
queued with error status into fabric driver response path code.
To address this bug, introduce a CMD_T_PRE_EXECUTE bit that is
set at target_get_sess_cmd() time, and cleared immediately before
backend driver dispatch in target_execute_cmd() once CMD_T_ACTIVE
is set.
Then, check CMD_T_PRE_EXECUTE within __target_check_io_state() to
determine when an early exception has occured, and avoid aborting
this se_cmd since it will have already been queued into fabric
Reported-by: Donald White <dew@datera.io>
Cc: Donald White <dew@datera.io>
Cc: Mike Christie <mchristi@redhat.com>
Cc: Hannes Reinecke <hare@suse.com>
[ Upstream commit 879626e3a52630316d817cbda7cec9a5446d1d82 ]
Note in the databook - Section 4.4 - EEE :
" The EEE feature is not supported when the MAC is configured to use the
TBI, RTBI, SMII, RMII or SGMII single PHY interface. Even if the MAC
supports multiple PHY interfaces, you should activate the EEE mode only
when the MAC is operating with GMII, MII, or RGMII interface."
Applying this restriction solves a stability issue observed on Amlogic
gxl platforms operating with RMII interface and the internal PHY.
Fixes: 83bf79b6bb64 ("stmmac: disable at run-time the EEE if not supported")
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org>
[ Upstream commit 5133550296d43236439494aa955bfb765a89f615 ]
Renesas SH7757 has 2 Fast and 2 Gigabit Ether controllers, while the
'sh_eth' driver can only reset and initialize TSU of the first controller
pair. Shimoda-san tried to solve that adding the 'needs_init' member to the
'struct sh_eth_plat_data', however the platform code still never sets this
flag. I think that we can infer this information from the 'devno' variable
(set to 'platform_device::id') and reset/init the Ether controller pair
only for an even 'devno'; therefore 'sh_eth_plat_data::needs_init' can be
removed...
Fixes: 150647fb2c31 ("net: sh_eth: change the condition of initialization")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
Reported by syzkaller:
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit cef0acd4d7d4811d2d19cd0195031bf0dfe41249 upstream.
Add a flag that indicates that the WEP ICV was stripped from an
RX packet, allowing the device to not transfer that if it's
already checked.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 98801506552593c9b8ac11021b0cdad12cab4f6b upstream.
Fix the default for fscache_maybe_release_page() for when the cookie isn't
valid or the page isn't cached. It mustn't return false as that indicates
the page cannot yet be freed.
The problem with the default is that if, say, there's no cache, but a
network filesystem's pages are using up almost all the available memory, a
system can OOM because the filesystem ->releasepage() op will not allow
them to be released as fscache_maybe_release_page() incorrectly prevents
it.
This can be tested by writing a sequence of 512MiB files to an AFS mount.
It does not affect NFS or CIFS because both of those wrap the call in a
check of PG_fscache and it shouldn't bother Ceph as that only has
PG_private set whilst writeback is in progress. This might be an issue for
9P, however.
Note that the pages aren't entirely stuck. Removing a file or unmounting
will clear things because that uses ->invalidatepage() instead.
Fixes: 201a15428bd5 ("FS-Cache: Handle pages pending storage that get evicted under OOM conditions")
Reported-by: Marc Dionne <marc.dionne@auristor.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Marc Dionne <marc.dionne@auristor.com>
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION.
The kaiser update made an interesting choice, never to free any shadow
page tables. Contention on global spinlock was worrying, particularly
with it held across page table scans when freeing. Something had to be
done: I was going to add refcounting; but simply never to free them is
an appealing choice, minimizing contention without complicating the code
(the more a page table is found already, the less the spinlock is used).
But leaking pages in this way is also a worry: can we get away with it?
At the very least, we need a count to show how bad it actually gets:
in principle, one might end up wasting about 1/256 of memory that way
(1/512 for when direct-mapped pages have to be user-mapped, plus 1/512
for when they are user-mapped from the vmalloc area on another occasion
(but we don't have vmalloc'ed stacks, so only large ldts are vmalloc'ed).
Add per-cpu stat NR_KAISERTABLE: including 256 at startup for the
shared pgd entries, and 1 for each intermediate page table added
thereafter for user-mapping - but leave out the 1 per mm, for its
shadow pgd, because that distracts from the monotonic increase.
Shown in /proc/vmstat as nr_overhead (0 if kaiser not enabled).
In practice, it doesn't look so bad so far: more like 1/12000 after
nine hours of gtests below; and movable pageblock segregation should
tend to cluster the kaiser tables into a subset of the address space
(if not, they will be bad for compaction too). But production may
tell a different story: keep an eye on this number, and bring back
lighter freeing if it gets out of control (maybe a shrinker).
["nr_overhead" should of course say "nr_kaisertable", if it needs
to stay; but for the moment we are being coy, preferring that when
Joe Blow notices a new line in his /proc/vmstat, he does not get
too curious about what this "kaiser" stuff might be.]
While trying to get our gold link to work, four cleanups:
matched the gdt_page declaration to its definition;
in fiddling unsuccessfully with PERCPU_INPUT(), lined up backslashes;
lined up the backslashes according to convention in percpu-defs.h;
deleted the unused irq_stack_pointer addition to irq_stack_union.
Sad to report that aligning backslashes does not appear to help gold
align to 8192: but while these did not help, they are worth keeping.
Kaiser only needs to map one page of the stack; and
kernel/fork.c did not build on powerpc (no __PAGE_KERNEL).
It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack()
and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's
kaiser_add_mapping() and kaiser_remove_mapping(). And use
linux/kaiser.h in init/main.c to avoid the #ifdefs there.
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging).
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 5dd0b16cdaff9b94da06074d5888b03235c0bf17 upstream.
This fixes CONFIG_SMP=n, CONFIG_DEBUG_TLBFLUSH=y without introducing
further #ifdef soup. Caught by a Kbuild bot randconfig build.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Fixes: ce4a4e565f52 ("x86/mm: Remove the UP asm/tlbflush.h code, always use the (formerly) SMP code")
Link: http://lkml.kernel.org/r/76da9a3cc4415996f2ad2c905b93414add322021.1496673616.git.luto@kernel.org
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream.
The timer wheel bases are not (re)initialized on CPU hotplug. That leaves
them with a potentially stale clk and next_expiry valuem, which can cause
trouble then the CPU is plugged.
Add a prepare callback which forwards the clock, sets next_expiry to far in
the future and reset the control flags to a known state.
Set base->must_forward_clk so the first timer which is queued will try to
forward the clock to current jiffies.
Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel")
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos
[ Upstream commit 37e92a9d4fe38dc3e7308913575983a6a088c8d4 ]
In mlx5_ifc, struct size was not complete, and thus driver was sending
garbage after the last defined field. Fixed it by adding reserved field
to complete the struct size.
In addition, rename all set_rate_limit to set_pp_rate_limit to be
compliant with the Firmware <-> Driver definition.
Fixes: 7486216b3a0b ("{net,IB}/mlx5: mlx5_ifc updates")
Fixes: 1466cc5b23d1 ("net/mlx5: Rate limit tables support")
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit d4761754b4fb2ef8d9a1e9d121c4bec84e1fe292 ]
Mark tcp_sock during a SACK reneging event and invalidate rate samples
while marked. Such rate samples may overestimate bw by including packets
that were SACKed before reneging.
< ack 6001 win 10000 sack 7001:38001
< ack 7001 win 0 sack 8001:38001 // Reneg detected
> seq 7001:8001 // RTO, SACK cleared.
< ack 38001 win 10000
In above example the rate sample taken after the last ack will count
7001-38001 as delivered while the actual delivery rate likely could
be much lower i.e. 7001-8001.
This patch adds a new field tcp_sock.sack_reneg and marks it when we
declare SACK reneging and entering TCP_CA_Loss, and unmarks it after
the last rate sample was taken before moving back to TCP_CA_Open. This
patch also invalidates rate samples taken while tcp_sock.is_sack_reneg
is set.
Fixes: b9f64820fb22 ("tcp: track data delivery rate for a TCP connection")
Signed-off-by: Yousuk Seung <ysseung@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Priyaranjan Jha <priyarjha@google.com>
[ Upstream commit a8ceb5dbfde1092b466936bca0ff3be127ecf38e ]
Users of ptr_ring expect that it's safe to give the
data structure a pointer and have it be available
to consumers, but that actually requires an smb_wmb
or a stronger barrier.
In absence of such barriers and on architectures that reorder writes,
consumer might read an un=initialized value from an skb pointer stored
in the skb array. This was observed causing crashes.
To fix, add memory barriers. The barrier we use is a wmb, the
assumption being that producers do not need to read the value so we do
not need to order these reads.
Reported-by: George Cherian <george.cherian@cavium.com>
Suggested-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit 513674b5a2c9c7a67501506419da5c3c77ac6f08 ]
sysctl.ip6.auto_flowlabels is default 1. In our hosts, we set it to 2.
If sockopt doesn't set autoflowlabel, outcome packets from the hosts are
supposed to not include flowlabel. This is true for normal packet, but
not for reset packet.
The reason is ipv6_pinfo.autoflowlabel is set in sock creation. Later if
we change sysctl.ip6.auto_flowlabels, the ipv6_pinfo.autoflowlabel isn't
changed, so the sock will keep the old behavior in terms of auto
flowlabel. Reset packet is suffering from this problem, because reset
packet is sent from a special control socket, which is created at boot
time. Since sysctl.ipv6.auto_flowlabels is 1 by default, the control
socket will always have its ipv6_pinfo.autoflowlabel set, even after
user set sysctl.ipv6.auto_flowlabels to 1, so reset packset will always
have flowlabel. Normal sock created before sysctl setting suffers from
the same issue. We can't even turn off autoflowlabel unless we kill all
socks in the hosts.
To fix this, if IPV6_AUTOFLOWLABEL sockopt is used, we use the
autoflowlabel setting from user, otherwise we always call
ip6_default_np_autolabel() which has the new settings of sysctl.
Note, this changes behavior a little bit. Before commit 42240901f7c4
(ipv6: Implement different admin modes for automatic flow labels), the
autoflowlabel behavior of a sock isn't sticky, eg, if sysctl changes,
existing connection will change autoflowlabel behavior. After that
commit, autoflowlabel behavior is sticky in the whole life of the sock.
With this patch, the behavior isn't sticky again.
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tom Herbert <tom@quantonium.net>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ]
IPv4 stack reacts to changes to small MTU, by disabling itself under
RTNL.
But there is a window where threads not using RTNL can see a wrong
device mtu. This can lead to surprises, in igmp code where it is
assumed the mtu is suitable.
Fix this by reading device mtu once and checking IPv4 minimal MTU.
This patch adds missing IPV4_MIN_MTU define, to not abuse
ETH_MIN_MTU anymore.
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream.
mcryptd_enqueue_request() grabs the per-CPU queue struct and protects
access to it with disabled preemption. Then it schedules a worker on the
same CPU. The worker in mcryptd_queue_worker() guards access to the same
per-CPU variable with disabled preemption.
If we take CPU-hotplug into account then it is possible that between
queue_work_on() and the actual invocation of the worker the CPU goes
down and the worker will be scheduled on _another_ CPU. And here the
preempt_disable() protection does not work anymore. The easiest thing is
to add a spin_lock() to guard access to the list.
Another detail: mcryptd_queue_worker() is not processing more than
MCRYPTD_BATCH invocation in a row. If there are still items left, then
it will invoke queue_work() to proceed with more later. *I* would
suggest to simply drop that check because it does not use a system
workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if
preemption is required then the scheduler should do it.
However if queue_work() is used then the work item is marked as CPU
unbound. That means it will try to run on the local CPU but it may run
on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y.
Again, the preempt_disable() won't work here but lock which was
introduced will help.
In order to keep work-item on the local CPU (and avoid RR) I changed it
to queue_work_on().
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ]
when the verifier detects that register contains a runtime constant
and it's compared with another constant it will prune exploration
of the branch that is guaranteed not to be taken at runtime.
This is all correct, but malicious program may be constructed
in such a way that it always has a constant comparison and
the other branch is never taken under any conditions.
In this case such path through the program will not be explored
by the verifier. It won't be taken at run-time either, but since
all instructions are JITed the malicious program may cause JITs
to complain about using reserved fields, etc.
To fix the issue we have to track the instructions explored by
the verifier and sanitize instructions that are dead at run time
with NOPs. We cannot reject such dead code, since llvm generates
it for valid C code, since it doesn't do as much data flow
analysis as the verifier does.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 16320f363ae128d9b9c70e60f00f2a572f57c23d ]
To allow canceling all packets of a connection.
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
Reviewed-by: Jorgen Hansen <jhansen@vmware.com>
Signed-off-by: Peng Tao <bergwolf@gmail.com>
[ Upstream commit 36d277bac8080202684e67162ebb157f16631581 ]
So that we can cancel a queued pkt later if necessary.
[ Upstream commit 99260132fde7bddc6e0132ce53da94d1c9ccabcb ]
The original code only took into consideration the largest header
possible after the IB_BTH_BYTES. This was incorrect, as the largest
possible header size is the largest possible combination of headers we
might run into. The new code accounts for all possible headers in the
largest possible combination and subtracts that from the MTU to make
sure that all packets will fit on the wire.
Link: https://www.spinics.net/lists/linux-rdma/msg54558.html
Fixes: 3c86aa70bf67 ("RDMA/cm: Add RDMA CM support for IBoE devices")
Signed-off-by: Parav Pandit <parav@mellanox.com>
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
Reported-by: Roland Dreier <roland@purestorage.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
[ Upstream commit 592e254502041f953e84d091eae2c68cba04c10b ]
_calc_vm_trans() does not handle the situation when some of the passed
flags are 0 (which can happen if these VM flags do not make sense for
the architecture). Improve the _calc_vm_trans() macro to return 0 in
such situation. Since all passed flags are constant, this does not add
any runtime overhead.
[ Upstream commit c962cff17dfa11f4a8227ac16de2b28aea3312e4 ]
Revert: dc6db24d2476 ("x86/acpi: Set persistent cpuid <-> nodeid mapping when booting")
The mapping of "cpuid <-> nodeid" is established at boot time via ACPI
tables to keep associations of workqueues and other node related items
consistent across cpu hotplug.
But, ACPI tables are unreliable and failures with that boot time mapping
have been reported on machines where the ACPI table and the physical
information which is retrieved at actual hotplug is inconsistent.
Revert the mapping implementation so it can be replaced with a less error
prone approach.
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Tested-by: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: rjw@rjwysocki.net
Cc: linux-acpi@vger.kernel.org
Cc: guzheng1@huawei.com
Cc: izumi.taku@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1488528147-2279-2-git-send-email-douly.fnst@cn.fujitsu.com
[ Upstream commit d7175373f2745ed4abe5b388d5aabd06304f801e ]
The implicit transition time tells initiators the min time
to wait before timing out a transition. We currently schedule
the transition to occur in tg_pt_gp_implicit_trans_secs
seconds so there is no room for delays. If
core_alua_do_transition_tg_pt_work->core_alua_update_tpg_primary_metadata
needs to write out info to a remote file, then the initiator can
easily time out the operation.
Signed-off-by: Mike Christie <mchristi@redhat.com>
[ Upstream commit 4cbe4dac82e423ecc9a0ba46af24a860853259f4 ]
Some Hypervisors detach VFs from VMs by instantly causing an FLR event
to be generated for a VF.
In the mlx4 case, this will cause that VF's comm channel to be disabled
before the VM has an opportunity to invoke the VF device's "shutdown"
method.
For such Hypervisors, there is a race condition between the VF's
shutdown method and its internal-error detection/reset thread.
The internal-error detection/reset thread (which runs every 5 seconds) also
detects a disabled comm channel. If the internal-error detection/reset
flow wins the race, we still get delays (while that flow tries repeatedly
to detect comm-channel recovery).
The cited commit fixed the command timeout problem when the
internal-error detection/reset flow loses the race.
This commit avoids the unneeded delays when the internal-error
detection/reset flow wins.
Fixes: d585df1c5ccf ("net/mlx4_core: Avoid command timeouts during VF driver device shutdown")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reported-by: Simon Xiao <sixiao@microsoft.com>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
commit 541b6fe63023f3059cf85d47ff2767a3e42a8e44 upstream.
According to USB Specification 2.0 table 9-4,
wMaxPacketSize is a bitfield. Endpoint's maxpacket
is laid out in bits 10:0. For high-speed,
high-bandwidth isochronous endpoints, bits 12:11
contain a multiplier to tell us how many
transactions we want to try per uframe.
This means that if we want an isochronous endpoint
to issue 3 transfers of 1024 bytes per uframe,
wMaxPacketSize should contain the value:
1024 | (2 << 11)
or 5120 (0x1400). In order to make Host and
Peripheral controller drivers' life easier, we're
adding a helper which returns bits 12:11. Note that
no care is made WRT to checking endpoint type and
gadget's speed. That's left for drivers to handle.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream.
Because the HMAC template didn't check that its underlying hash
algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))"
through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC
being used without having been keyed, resulting in sha3_update() being
called without sha3_init(), causing a stack buffer overflow.
This is a very old bug, but it seems to have only started causing real
problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3)
because the innermost hash's state is ->import()ed from a zeroed buffer,
and it just so happens that other hash algorithms are fine with that,
but SHA-3 is not. However, there could be arch or hardware-dependent
hash algorithms also affected; I couldn't test everything.
Fix the bug by introducing a function crypto_shash_alg_has_setkey()
which tests whether a shash algorithm is keyed. Then update the HMAC
template to require that its underlying hash algorithm is unkeyed.
Here is a reproducer:
#include <linux/if_alg.h>
#include <sys/socket.h>
int main()
int algfd;
struct sockaddr_alg addr = {
.salg_type = "hash",
.salg_name = "hmac(hmac(sha3-512-generic))",
char key[4096] = { 0 };
algfd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(algfd, (const struct sockaddr *)&addr, sizeof(addr));
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key));
Here was the KASAN report from syzbot:
BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline]
BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161
Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044
CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x137/0x190 mm/kasan/kasan.c:267
memcpy+0x37/0x50 mm/kasan/kasan.c:303
crypto_shash_update+0xcb/0x220 crypto/shash.c:109
shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151
crypto_shash_finup+0xc4/0x120 crypto/shash.c:165
hmac_finup+0x182/0x330 crypto/hmac.c:152
shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172
crypto_shash_digest+0xc4/0x120 crypto/shash.c:186
hmac_setkey+0x36a/0x690 crypto/hmac.c:66
crypto_shash_setkey+0xad/0x190 crypto/shash.c:64
shash_async_setkey+0x47/0x60 crypto/shash.c:207
crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200
hash_setkey+0x40/0x90 crypto/algif_hash.c:446
alg_setkey crypto/af_alg.c:221 [inline]
alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254
SYSC_setsockopt net/socket.c:1851 [inline]
SyS_setsockopt+0x189/0x360 net/socket.c:1830
entry_SYSCALL_64_fastpath+0x1f/0x96
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit d7efc6c11b277d9d80b99b1334a78bfe7d7edf10 ]
Alexander Potapenko reported use of uninitialized memory [1]
This happens when inserting a request socket into TCP ehash,
in __sk_nulls_add_node_rcu(), since sk_reuseport is not initialized.
Bug was added by commit d894ba18d4e4 ("soreuseport: fix ordering for
mixed v4/v6 sockets")
Note that d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6
ordering fix") missed the opportunity to get rid of
hlist_nulls_add_tail_rcu() :
Both UDP sockets and TCP/DCCP listeners no longer use
__sk_nulls_add_node_rcu() for their hash insertion.
Since all other sockets have unique 4-tuple, the reuseport status
has no special meaning, so we can always use hlist_nulls_add_head_rcu()
for them and save few cycles/instructions.
[1]
BUG: KMSAN: use of uninitialized memory in inet_ehash_insert+0xd40/0x1050
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.13.0+ #3288
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x185/0x1d0 lib/dump_stack.c:52
kmsan_report+0x13f/0x1c0 mm/kmsan/kmsan.c:1016
__msan_warning_32+0x69/0xb0 mm/kmsan/kmsan_instr.c:766
__sk_nulls_add_node_rcu ./include/net/sock.h:684
inet_ehash_insert+0xd40/0x1050 net/ipv4/inet_hashtables.c:413
reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:754
inet_csk_reqsk_queue_hash_add+0x1cc/0x300 net/ipv4/inet_connection_sock.c:765
tcp_conn_request+0x31e7/0x36f0 net/ipv4/tcp_input.c:6414
tcp_v4_conn_request+0x16d/0x220 net/ipv4/tcp_ipv4.c:1314
tcp_rcv_state_process+0x42a/0x7210 net/ipv4/tcp_input.c:5917
tcp_v4_do_rcv+0xa6a/0xcd0 net/ipv4/tcp_ipv4.c:1483
tcp_v4_rcv+0x3de0/0x4ab0 net/ipv4/tcp_ipv4.c:1763
ip_local_deliver_finish+0x6bb/0xcb0 net/ipv4/ip_input.c:216
NF_HOOK ./include/linux/netfilter.h:248
ip_local_deliver+0x3fa/0x480 net/ipv4/ip_input.c:257
dst_input ./include/net/dst.h:477
ip_rcv_finish+0x6fb/0x1540 net/ipv4/ip_input.c:397
ip_rcv+0x10f6/0x15c0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x36f6/0x3f60 net/core/dev.c:4298
__netif_receive_skb net/core/dev.c:4336
netif_receive_skb_internal+0x63c/0x19c0 net/core/dev.c:4497
napi_skb_finish net/core/dev.c:4858
napi_gro_receive+0x629/0xa50 net/core/dev.c:4889
e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4018
e1000_clean_rx_irq+0x1492/0x1d30
drivers/net/ethernet/intel/e1000/e1000_main.c:4474
e1000_clean+0x43aa/0x5970 drivers/net/ethernet/intel/e1000/e1000_main.c:3819
napi_poll net/core/dev.c:5500
net_rx_action+0x73c/0x1820 net/core/dev.c:5566
__do_softirq+0x4b4/0x8dd kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364
irq_exit+0x203/0x240 kernel/softirq.c:405
exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:638
do_IRQ+0x15e/0x1a0 arch/x86/kernel/irq.c:263
common_interrupt+0x86/0x86
Fixes: d894ba18d4e4 ("soreuseport: fix ordering for mixed v4/v6 sockets")
Fixes: d296ba60d8e2 ("soreuseport: Resolve merge conflict for v4/v6 ordering fix")
Reported-by: Alexander Potapenko <glider@google.com>
Acked-by: Craig Gallek <kraig@google.com>
[ Upstream commit a4abd7a80addb4a9547f7dfc7812566b60ec505c ]
The qmi_wwan minidriver support a 'raw-ip' mode where frames are
received without any ethernet header. This causes alignment issues
because the skbs allocated by usbnet are "IP aligned".
Fix by allowing minidrivers to disable the additional alignment
offset. This is implemented using a per-device flag, since the same
minidriver also supports 'ethernet' mode.
Fixes: 32f7adf633b9 ("net: qmi_wwan: support "raw IP" mode")
Reported-and-tested-by: Jay Foster <jay@systech.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ]
If the amount of resources allocated to a gen_pool exceeds 2^32 then the
avail atomic overflows and this causes problems when clients try and
borrow resources from the pool. This is only expected to be an issue on
64 bit systems.
Add the <linux/atomic.h> header to pull in atomic_long* operations. So
that 32 bit systems continue to use atomic32_t but 64 bit systems can
use atomic64_t.
Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Daniel Mentz <danielmentz@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
[ Upstream commit 7807e086a2d1f69cc1a57958cac04fea79fc2112 ]
gpmc_probe_onenand_child returns success even on gpmc_onenand_init
failure. Fix that.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Acked-by: Roger Quadros <rogerq@ti.com>
