commit 9c0a835a9d9aed41bcf9c287f5069133a6e2a87b upstream.
The usb/ch9.h will be installed to /usr/include/linux,
and be used from user space.
But le16_to_cpu() is only defined for kernel code.
Without this patch, user space compile will be broken.
Special thanks to Stefan Becker
Reported-by: Stefan Becker <chemobejk@gmail.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit d020283dc694c9ec31b410f522252f7a8397e67d upstream.
Looks like change "PM QoS: Move and rename the implementation files"
merged during the 3.2 development cycle made PM QoS depend on
CONFIG_PM which depends on (PM_SLEEP || PM_RUNTIME).
That breaks CPU C-states with kernels not having these CONFIGs, causing CPUs
to spend time in Polling loop idle instead of going into deep C-states,
consuming way way more power. This is with either acpi idle or intel idle
enabled.
Either CONFIG_PM should be enabled with any pm_qos users or
the !CONFIG_PM pm_qos_request() should return sane defaults not to break
the existing users. Here's is the patch for the latter option.
[rjw: Modified the changelog slightly.]
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
commit 181e9bdef37bfcaa41f3ab6c948a2a0d60a268b5 upstream.
Commit 2aede851ddf08666f68ffc17be446420e9d2a056
PM / Hibernate: Freeze kernel threads after preallocating memory
introduced a mechanism by which kernel threads were frozen after
the preallocation of hibernate image memory to avoid problems with
frozen kernel threads not responding to memory freeing requests.
However, it overlooked the s2disk code path in which the
SNAPSHOT_CREATE_IMAGE ioctl was run directly after SNAPSHOT_FREE,
which caused freeze_workqueues_begin() to BUG(), because it saw
that worqueues had been already frozen.
Although in principle this issue might be addressed by removing
the relevant BUG_ON() from freeze_workqueues_begin(), that would
reintroduce the very problem that commit 2aede851ddf08666f68ffc17be4
attempted to avoid into that particular code path. For this reason,
to fix the issue at hand, introduce thaw_kernel_threads() and make
the SNAPSHOT_FREE ioctl execute it.
Special thanks to Srivatsa S. Bhat for detailed analysis of the
problem.
Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz>
Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 3c076351c4027a56d5005a39a0b518a4ba393ce2 upstream.
Right now we forcibly clear ASPM state on all devices if the BIOS indicates
that the feature isn't supported. Based on the Microsoft presentation
"PCI Express In Depth for Windows Vista and Beyond", I'm starting to think
that this may be an error. The implication is that unless the platform
grants full control via _OSC, Windows will not touch any PCIe features -
including ASPM. In that case clearing ASPM state would be an error unless
the platform has granted us that control.
This patch reworks the ASPM disabling code such that the actual clearing
of state is triggered by a successful handoff of PCIe control to the OS.
The general ASPM code undergoes some changes in order to ensure that the
ability to clear the bits isn't overridden by ASPM having already been
disabled. Further, this theoretically now allows for situations where
only a subset of PCIe roots hand over control, leaving the others in the
BIOS state.
It's difficult to know for sure that this is the right thing to do -
there's zero public documentation on the interaction between all of these
components. But enough vendors enable ASPM on platforms and then set this
bit that it seems likely that they're expecting the OS to leave them alone.
Measured to save around 5W on an idle Thinkpad X220.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
[ Upstream commit 5ee4433efe99b9f39f6eff5052a177bbcfe72cea ]
By definition net_generic should never be called when it can return
NULL. Fail conspicously with a BUG_ON to make it clear when people mess
up that a NULL return should never happen.
Recently there was a bug in the CAIF subsystem where it was registered
with register_pernet_device instead of register_pernet_subsys. It was
erroneously concluded that net_generic could validly return NULL and
that net_assign_generic was buggy (when it was just inefficient).
Hopefully this BUG_ON will prevent people to coming to similar erroneous
conclusions in the futrue.
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream.
If the master tries to authenticate a client using drm_authmagic and
that client has already closed its drm file descriptor,
either wilfully or because it was terminated, the
call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory
and corrupt it.
Typically this results in a hard system hang.
This patch fixes that problem by removing any authentication tokens
(struct drm_magic_entry) open for a file descriptor when that file
descriptor is closed.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 245132643e1cfcd145bbc86a716c1818371fcb93 upstream.
Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in
find_get_pages") correctly fixed an infinite loop; but left a problem
that find_get_pages() on shmem would return 0 (appearing to callers to
mean end of tree) when it meets a run of nr_pages swap entries.
The only uses of find_get_pages() on shmem are via pagevec_lookup(),
called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's
scan_mapping_unevictable_pages(). The first is already commented, and
not worth worrying about; but the second can leave pages on the
Unevictable list after an unusual sequence of swapping and locking.
Fix that by using shmem_find_get_pages_and_swap() (then ignoring the
swap) instead of pagevec_lookup().
But I don't want to contaminate vmscan.c with shmem internals, nor
shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into
shmem.c, renaming it shmem_unlock_mapping(); and rename
check_move_unevictable_page() to check_move_unevictable_pages(), looping
down an array of pages, oftentimes under the same lock.
Leave out the "rotate unevictable list" block: that's a leftover from
when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed
handling involved looking at pages at tail of LRU.
Was there significance to the sequence first ClearPageUnevictable, then
test page_evictable, then SetPageUnevictable here? I think not, we're
under LRU lock, and have no barriers between those.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Michel Lespinasse <walken@google.com>
commit cd4ca7afc61d3b18fcd635002459fb6b1d701099 upstream.
Update xc4000 tuner definition, number 81 is already in use by
TUNER_PARTSNIC_PTI_5NF05.
Signed-off-by: Miroslav Slugen <thunder.mmm@gmail.com>
commit 895f3022523361e9b383cf48f51feb1f7d5e7e53 upstream.
The target code was not setting the additional sense length field in the
sense data it returned, which meant that at least the Linux stack
ignored the ASC/ASCQ fields. For example, without this patch, on a
tcm_loop device:
# sg_raw -v /dev/sda 2 0 0 0 0 0
gives
cdb to send: 02 00 00 00 00 00
SCSI Status: Check Condition
Sense Information:
Fixed format, current; Sense key: Illegal Request
Raw sense data (in hex):
70 00 05 00 00 00 00 00
while after the patch we correctly get the following (which matches what
a regular disk returns):
Sense Information:
Additional sense: Invalid command operation code
70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00
00 00
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 8df0eb7c9d96f9e82f233ee8b74e0f0c8471f868 upstream.
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides
32bits for these. The new fields were reserved before.
According to the ACPI spec, the OS must disregrard reserved fields.
In order to know whether or not, we must know what version the SRAT
table has.
This patch stores the SRAT table revision for later consumption
by arch specific __init functions.
Signed-off-by: Kurt Garloff <kurt@garloff.de>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 0bfc96cb77224736dfa35c3c555d37b3646ef35e upstream.
[ Changes with respect to 3.3: return -ENOTTY from scsi_verify_blk_ioctl
and -ENOIOCTLCMD from sd_compat_ioctl. ]
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and
will pass the command to the underlying block device. This is
well-known, but it is also a large security problem when (via Unix
permissions, ACLs, SELinux or a combination thereof) a program or user
needs to be granted access only to part of the disk.
This patch lets partitions forward a small set of harmless ioctls;
others are logged with printk so that we can see which ioctls are
actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred.
Of course it was being sent to a (partition on a) hard disk, so it would
have failed with ENOTTY and the patch isn't changing anything in
practice. Still, I'm treating it specially to avoid spamming the logs.
In principle, this restriction should include programs running with
CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and
/dev/sdb, it still should not be able to read/write outside the
boundaries of /dev/sda2 independent of the capabilities. However, for
now programs with CAP_SYS_RAWIO will still be allowed to send the
ioctls. Their actions will still be logged.
This patch does not affect the non-libata IDE driver. That driver
however already tests for bd != bd->bd_contains before issuing some
ioctl; it could be restricted further to forbid these ioctls even for
programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO.
Cc: linux-scsi@vger.kernel.org
Cc: James Bottomley <JBottomley@parallels.com>
[ Make it also print the command name when warning - Linus ]
commit 577ebb374c78314ac4617242f509e2f5e7156649 upstream.
Introduce a wrapper around scsi_cmd_ioctl that takes a block device.
The function will then be enhanced to detect partition block devices
and, in that case, subject the ioctls to whitelisting.
commit eaf5f9073533cde21c7121c136f1c3f072d9cf59 upstream.
Two (or more) concurrent calls of shrink_dcache_parent() on the same dentry may
cause shrink_dcache_parent() to loop forever.
Here's what appears to happen:
1 - CPU0: select_parent(P) finds C and puts it on dispose list, returns 1
2 - CPU1: select_parent(P) locks P->d_lock
3 - CPU0: shrink_dentry_list() locks C->d_lock
dentry_kill(C) tries to lock P->d_lock but fails, unlocks C->d_lock
4 - CPU1: select_parent(P) locks C->d_lock,
moves C from dispose list being processed on CPU0 to the new
5 - CPU0: shrink_dentry_list() finds dispose list empty, returns
6 - Goto 2 with CPU0 and CPU1 switched
Basically select_parent() steals the dentry from shrink_dentry_list() and thinks
it found a new one, causing shrink_dentry_list() to think it's making progress
and loop over and over.
One way to trigger this is to make udev calls stat() on the sysfs file while it
is going away.
Having a file in /lib/udev/rules.d/ with only this one rule seems to the trick:
ATTR{vendor}=="0x8086", ATTR{device}=="0x10ca", ENV{PCI_SLOT_NAME}="%k", ENV{MATCHADDR}="$attr{address}", RUN+="/bin/true"
Then execute the following loop:
while true; do
echo -bond0 > /sys/class/net/bonding_masters
echo +bond0 > /sys/class/net/bonding_masters
echo -bond1 > /sys/class/net/bonding_masters
echo +bond1 > /sys/class/net/bonding_masters
done
One fix would be to check all callers and prevent concurrent calls to
shrink_dcache_parent(). But I think a better solution is to stop the
stealing behavior.
This patch adds a new dentry flag that is set when the dentry is added to the
dispose list. The flag is cleared in dentry_lru_del() in case the dentry gets a
new reference just before being pruned.
If the dentry has this flag, select_parent() will skip it and let
shrink_dentry_list() retry pruning it. With select_parent() skipping those
dentries there will not be the appearance of progress (new dentries found) when
there is none, hence shrink_dcache_parent() will not loop forever.
Set the flag is also set in prune_dcache_sb() for consistency as suggested by
Linus.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 2fefb8a09e7ed251ae8996e0c69066e74c5aa560 upstream.
There's no reason I can see that we need to call sv_shutdown between
closing the two lists of sockets.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 6c06108be53ca5e94d8b0e93883d534dd9079646 upstream.
If ctrls->count is too high the multiplication could overflow and
array_size would be lower than expected. Mauro and Hans Verkuil
suggested that we cap it at 1024. That comes from the maximum
number of controls with lots of room for expantion.
$ grep V4L2_CID include/linux/videodev2.h | wc -l
211
commit ab936cbcd02072a34b60d268f94440fd5cf1970b upstream.
Commit ef6a3c6311 ("mm: add replace_page_cache_page() function") added a
function replace_page_cache_page(). This function replaces a page in the
radix-tree with a new page. WHen doing this, memory cgroup needs to fix
up the accounting information. memcg need to check PCG_USED bit etc.
In some(many?) cases, 'newpage' is on LRU before calling
replace_page_cache(). So, memcg's LRU accounting information should be
fixed, too.
This patch adds mem_cgroup_replace_page_cache() and removes the old hooks.
In that function, old pages will be unaccounted without touching
res_counter and new page will be accounted to the memcg (of old page).
WHen overwriting pc->mem_cgroup of newpage, take zone->lru_lock and avoid
races with LRU handling.
Background:
replace_page_cache_page() is called by FUSE code in its splice() handling.
Here, 'newpage' is replacing oldpage but this newpage is not a newly allocated
page and may be on LRU. LRU mis-accounting will be critical for memory cgroup
because rmdir() checks the whole LRU is empty and there is no account leak.
If a page is on the other LRU than it should be, rmdir() will fail.
This bug was added in March 2011, but no bug report yet. I guess there
are not many people who use memcg and FUSE at the same time with upstream
kernels.
The result of this bug is that admin cannot destroy a memcg because of
account leak. So, no panic, no deadlock. And, even if an active cgroup
exist, umount can succseed. So no problem at shutdown.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Miklos Szeredi <mszeredi@suse.cz>
commit 1f536b9e9f85456df93614b3c2f6a1a2b7d7cb9b upstream.
Building an ARM target we get the following warnings:
CC arch/arm/kernel/setup.o
In file included from arch/arm/kernel/setup.c:39:
arch/arm/include/asm/elf.h:102:1: warning: "vmcore_elf64_check_arch" redefined
In file included from arch/arm/kernel/setup.c:24:
include/linux/crash_dump.h:30:1: warning: this is the location of the previous definition
Quoting Russell King:
"linux/crash_dump.h makes no attempt to include asm/elf.h, but it depends
on stuff in asm/elf.h to determine how stuff inside this file is defined
at parse time.
So, if asm/elf.h is included after linux/crash_dump.h or not at all, you
get a different result from the situation where asm/elf.h is included
before."
So add elf.h header to crash_dump.h to avoid this problem.
The original discussion about this can be found at:
http://www.spinics.net/lists/arm-kernel/msg154113.html
commit 9e7860cee18241633eddb36a4c34c7b61d8cecbc upstream.
Haogang Chen found out that:
There is a potential integer overflow in process_msg() that could result
in cross-domain attack.
body = kmalloc(msg->hdr.len + 1, GFP_NOIO | __GFP_HIGH);
When a malicious guest passes 0xffffffff in msg->hdr.len, the subsequent
call to xb_read() would write to a zero-length buffer.
The other end of this connection is always the xenstore backend daemon
so there is no guest (malicious or otherwise) which can do this. The
xenstore daemon is a trusted component in the system.
However this seem like a reasonable robustness improvement so we should
have it.
And Ian when read the API docs found that:
The payload length (len field of the header) is limited to 4096
(XENSTORE_PAYLOAD_MAX) in both directions. If a client exceeds the
limit, its xenstored connection will be immediately killed by
xenstored, which is usually catastrophic from the client's point of
view. Clients (particularly domains, which cannot just reconnect)
should avoid this.
so this patch checks against that instead.
This also avoids a potential integer overflow pointed out by Haogang Chen.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Haogang Chen <haogangchen@gmail.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 1830ea91c20b06608f7cdb2455ce05ba834b3214 upstream.
Spec shows this as 1010b = 0xa
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 18b7ede5f7ee2092aedcb578d3ac30bd5d4fc23c upstream.
[ removed the dwc3 portion of the patch as it didn't apply to
older kernels - gregkh]
According to USB 3.0 Specification Table 9-22, if
bmAttributes [4:0] are set to zero, it means "no
streams supported", but the way this helper was
defined on Linux, we will *always* have one stream
which might cause several problems.
For example on DWC3, we would tell the controller
endpoint has streams enabled and yet start transfers
with Stream ID set to 0, which would goof up the host
side.
While doing that, convert the macro to an inline
function due to the different checks we now need.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit bc677d5b64644c399cd3db6a905453e611f402ab upstream.
Add a new field num_mapped_sgs to struct urb so that we have a place to
store the number of mapped entries and can also retain the original
value of entries in num_sgs. Previously, usb_hcd_map_urb_for_dma()
would overwrite this with the number of mapped entries, which would
break dma_unmap_sg() because it requires the original number of entries.
This fixes warnings like the following when using USB storage devices:
WARNING: at lib/dma-debug.c:902 check_unmap+0x4e4/0x695()
ehci_hcd 0000:00:12.2: DMA-API: device driver frees DMA sg list with different entry count [map count=4] [unmap count=1]
Modules linked in: ohci_hcd ehci_hcd
Pid: 0, comm: kworker/0:1 Not tainted 3.2.0-rc2+ #319
Call Trace:
<IRQ> [<ffffffff81036d3b>] warn_slowpath_common+0x80/0x98
[<ffffffff81036de7>] warn_slowpath_fmt+0x41/0x43
[<ffffffff811fa5ae>] check_unmap+0x4e4/0x695
[<ffffffff8105e92c>] ? trace_hardirqs_off+0xd/0xf
[<ffffffff8147208b>] ? _raw_spin_unlock_irqrestore+0x33/0x50
[<ffffffff811fa84a>] debug_dma_unmap_sg+0xeb/0x117
[<ffffffff8137b02f>] usb_hcd_unmap_urb_for_dma+0x71/0x188
[<ffffffff8137b166>] unmap_urb_for_dma+0x20/0x22
[<ffffffff8137b1c5>] usb_hcd_giveback_urb+0x5d/0xc0
[<ffffffffa0000d02>] ehci_urb_done+0xf7/0x10c [ehci_hcd]
[<ffffffffa0001140>] qh_completions+0x429/0x4bd [ehci_hcd]
[<ffffffffa000340a>] ehci_work+0x95/0x9c0 [ehci_hcd]
---[ end trace f29ac88a5a48c580 ]---
Mapped at:
[<ffffffff811faac4>] debug_dma_map_sg+0x45/0x139
[<ffffffff8137bc0b>] usb_hcd_map_urb_for_dma+0x22e/0x478
[<ffffffff8137c494>] usb_hcd_submit_urb+0x63f/0x6fa
[<ffffffff8137d01c>] usb_submit_urb+0x2c7/0x2de
[<ffffffff8137dcd4>] usb_sg_wait+0x55/0x161
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Commit 1e39f384bb01 ("evm: fix build problems") makes the stub version
of security_old_inode_init_security() return 0 when CONFIG_SECURITY is
not set.
But that makes callers such as reiserfs_security_init() assume that
security_old_inode_init_security() has set name, value, and len
arguments properly - but security_old_inode_init_security() left them
uninitialized which then results in interesting failures.
Revert security_old_inode_init_security() to the old behavior of
returning EOPNOTSUPP since both callers (reiserfs and ocfs2) handle this
just fine.
[ Also fixed the S_PRIVATE(inode) case of the actual non-stub
security_old_inode_init_security() function to return EOPNOTSUPP
for the same reason, as pointed out by Mimi Zohar.
It got incorrectly changed to match the new function in commit
fb88c2b6cbb1: "evm: fix security/security_old_init_security return
code". - Linus ]
Reported-by: Jorge Bastos <mysql.jorge@decimal.pt>
Acked-by: James Morris <jmorris@namei.org>
Acked-by: Mimi Zohar <zohar@us.ibm.com>
We should not forget to try for real server with port 0
in the backup server when processing the sync message. We should
do it in all cases because the backup server can use different
forwarding method.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
Commit 2a95ea6c0d129b4 ("procfs: do not overflow get_{idle,iowait}_time
for nohz") did not take into account that one some architectures jiffies
and cputime use different units.
This causes get_idle_time() to return numbers in the wrong units, making
the idle time fields in /proc/stat wrong.
Instead of converting the usec value returned by
get_cpu_{idle,iowait}_time_us to units of jiffies, use the new function
usecs_to_cputime64 to convert it to the correct unit of cputime64_t.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Cc: "Artem S. Tashkinov" <t.artem@mailcity.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Unlike all of the other cpuid bits, the TSC deadline timer bit is set
unconditionally, regardless of what userspace wants.
This is broken in several ways:
- if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC
deadline timer feature, a guest that uses the feature will break
- live migration to older host kernels that don't support the TSC deadline
timer will cause the feature to be pulled from under the guest's feet;
breaking it
- guests that are broken wrt the feature will fail.
Fix by not enabling the feature automatically; instead report it to userspace.
Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee
will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not
KVM_GET_SUPPORTED_CPUID.
Fixes the Illumos guest kernel, which uses the TSC deadline timer feature.
[avi: add the KVM_CAP + documentation]
Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Fix race between CPU hotplug and lglocks
for linus: writeback reason binary tracing format fix
* tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: show writeback reason with __print_symbolic
skb->truesize might be big even for a small packet.
Its even bigger after commit 87fb4b7b533 (net: more accurate skb
truesize) and big MTU.
We should allow queueing at least one packet per receiver, even with a
low RCVBUF setting.
Reported-by: Michal Simek <monstr@monstr.eu>
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Currently, the *_global_[un]lock_online() routines are not at all synchronized
with CPU hotplug. Soft-lockups detected as a consequence of this race was
reported earlier at https://lkml.org/lkml/2011/8/24/185. (Thanks to Cong Meng
for finding out that the root-cause of this issue is the race condition
between br_write_[un]lock() and CPU hotplug, which results in the lock states
getting messed up).
Fixing this race by just adding {get,put}_online_cpus() at appropriate places
in *_global_[un]lock_online() is not a good option, because, then suddenly
br_write_[un]lock() would become blocking, whereas they have been kept as
non-blocking all this time, and we would want to keep them that way.
So, overall, we want to ensure 3 things:
1. br_write_lock() and br_write_unlock() must remain as non-blocking.
2. The corresponding lock and unlock of the per-cpu spinlocks must not happen
for different sets of CPUs.
3. Either prevent any new CPU online operation in between this lock-unlock, or
ensure that the newly onlined CPU does not proceed with its corresponding
per-cpu spinlock unlocked.
To achieve all this:
(a) We introduce a new spinlock that is taken by the *_global_lock_online()
routine and released by the *_global_unlock_online() routine.
(b) We register a callback for CPU hotplug notifications, and this callback
takes the same spinlock as above.
(c) We maintain a bitmap which is close to the cpu_online_mask, and once it is
initialized in the lock_init() code, all future updates to it are done in
the callback, under the above spinlock.
(d) The above bitmap is used (instead of cpu_online_mask) while locking and
unlocking the per-cpu locks.
The callback takes the spinlock upon the CPU_UP_PREPARE event. So, if the
br_write_lock-unlock sequence is in progress, the callback keeps spinning,
thus preventing the CPU online operation till the lock-unlock sequence is
complete. This takes care of requirement (3).
The bitmap that we maintain remains unmodified throughout the lock-unlock
sequence, since all updates to it are managed by the callback, which takes
the same spinlock as the one taken by the lock code and released only by the
unlock routine. Combining this with (d) above, satisfies requirement (2).
Overall, since we use a spinlock (mentioned in (a)) to prevent CPU hotplug
operations from racing with br_write_lock-unlock, requirement (1) is also
taken care of.
By the way, it is to be noted that a CPU offline operation can actually run
in parallel with our lock-unlock sequence, because our callback doesn't react
to notifications earlier than CPU_DEAD (in order to maintain our bitmap
properly). And this means, since we use our own bitmap (which is stale, on
purpose) during the lock-unlock sequence, we could end up unlocking the
per-cpu lock of an offline CPU (because we had locked it earlier, when the
CPU was online), in order to satisfy requirement (2). But this is harmless,
though it looks a bit awkward.
Debugged-by: Cong Meng <mc@linux.vnet.ibm.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Add a flow_cache_flush_deferred function
ipv4: reintroduce route cache garbage collector
net: have ipconfig not wait if no dev is available
sctp: Do not account for sizeof(struct sk_buff) in estimated rwnd
asix: new device id
davinci-cpdma: fix locking issue in cpdma_chan_stop
sctp: fix incorrect overflow check on autoclose
r8169: fix Config2 MSIEnable bit setting.
llc: llc_cmsg_rcv was getting called after sk_eat_skb.
net: bpf_jit: fix an off-one bug in x86_64 cond jump target
iwlwifi: update SCD BC table for all SCD queues
Revert "Bluetooth: Revert: Fix L2CAP connection establishment"
Bluetooth: Clear RFCOMM session timer when disconnecting last channel
Bluetooth: Prevent uninitialized data access in L2CAP configuration
iwlwifi: allow to switch to HT40 if not associated
iwlwifi: tx_sync only on PAN context
mwifiex: avoid double list_del in command cancel path
ath9k: fix max phy rate at rate control init
nfc: signedness bug in __nci_request()
iwlwifi: do not set the sequence control bit is not needed
flow_cach_flush() might sleep but can be called from
atomic context via the xfrm garbage collector. So add
a flow_cache_flush_deferred() function and use this if
the xfrm garbage colector is invoked from within the
packet path.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Timo Teräs <timo.teras@iki.fi>
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
time/clocksource: Fix kernel-doc warnings
rtc: m41t80: Workaround broken alarm functionality
rtc: Expire alarms after the time is set.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
Revert "xen/pv-on-hvm kexec: add xs_reset_watches to shutdown watches from old kernel"
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (31 commits)
Revert "[media] af9015: limit I2C access to keep FW happy"
[media] s5p-fimc: Fix camera input configuration in subdev operations
[media] m5mols: Fix logic in sanity check
[media] ati_remote: switch to single-byte scancodes
[media] V4L: mt9m111: fix uninitialised mutex
[media] V4L: omap1_camera: fix missing <linux/module.h> include
[media] V4L: mt9t112: use after free in mt9t112_probe()
[media] V4L: soc-camera: fix compiler warnings on 64-bit platforms
[media] s5p_mfc_enc: fix s/H264/H263/ typo
[media] omap_vout: Fix compile error in 3.1
[media] au0828: add missing models 72101, 72201 & 72261 to the model matrix
[media] au0828: add missing USB ID 2040:7213
[media] au0828: add missing USB ID 2040:7260
[media] [trivial] omap24xxcam-dma: Fix logical test
[media] omap_vout: fix crash if no driver for a display
[media] media: video: s5p-tv: fix build break
[media] omap3isp: fix compilation of ispvideo.c
[media] m5mols: Fix set_fmt to return proper pixel format code
[media] s5p-fimc: Use correct fourcc for RGB565 colour format
[media] s5p-fimc: Fail driver probing when sensor configuration is wrong
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
old kernel"
This reverts commit ddacf5ef684a655abe2bb50c4b2a5b72ae0d5e05.
As when booting the kernel under Amazon EC2 as an HVM guest it ends up
hanging during startup. Reverting this we loose the fix for kexec
booting to the crash kernels.
Fixes Canonical BZ #901305 (http://bugs.launchpad.net/bugs/901305)
Tested-by: Alessandro Salvatori <sandr8@gmail.com>
Reported-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Ian Campbell <Ian.Campbell@citrix.com>
Fix various KernelDoc build warnings.
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Cc: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20111219091320.0D5AF6FC03D@msa105.auone-net.jp
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (22 commits)
[SCSI] fcoe: fix fcoe in a DCB environment by adding DCB notifiers to set skb priority
[SCSI] bnx2i: Fixed kernel panic caused by unprotected task->sc->request deref
[SCSI] qla4xxx: check for failed conn setup
[SCSI] qla4xxx: a small loop fix
[SCSI] qla4xxx: fix flash/ddb support
[SCSI] zfcp: return early from slave_destroy if slave_alloc returned early
[SCSI] fcoe: Fix preempt count leak in fcoe_filter_frames()
[SCSI] qla2xxx: Update version number to 8.03.07.12-k.
[SCSI] qla2xxx: Submit all chained IOCBs for passthrough commands on request queue 0.
[SCSI] qla2xxx: Correct fc_host port_state display.
[SCSI] qla2xxx: Disable generating pause frames when firmware hang detected for ISP82xx.
[SCSI] qla2xxx: Clear mailbox busy flag during premature mailbox completion for ISP82xx.
[SCSI] qla2xxx: Encapsulate prematurely completing mailbox commands during ISP82xx firmware hang.
[SCSI] qla2xxx: Display IPE error message for ISP82xx.
[SCSI] qla2xxx: Return the correct value for a mailbox command if 82xx is in reset recovery.
[SCSI] qla2xxx: Enable Minidump by default with default capture mask 0x1f.
[SCSI] qla2xxx: Stop unconditional completion of mailbox commands issued in interrupt mode during firmware hang.
[SCSI] qla2xxx: Revert back the request queue mapping to request queue 0.
[SCSI] qla2xxx: Don't call alloc_fw_dump for ISP82XX.
[SCSI] qla2xxx: Check for SCSI status on underruns.
This makes the binary trace understandable by trace-cmd.
CC: Dave Chinner <david@fromorbit.com>
CC: Curt Wohlgemuth <curtw@google.com>
CC: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
* 'drm-intel-fixes' of git://people.freedesktop.org/~keithp/linux:
drm/i915/dp: Dither down to 6bpc if it makes the mode fit
drm/i915: enable semaphores on per-device defaults
drm/i915: don't set unpin_work if vblank_get fails
drm/i915: By default, enable RC6 on IVB and SNB when reasonable
iommu: Export intel_iommu_enabled to signal when iommu is in use
drm/i915/sdvo: Include LVDS panels for the IS_DIGITAL check
drm/i915: prevent division by zero when asking for chipset power
drm/i915: add PCH info to i915_capabilities
drm/i915: set the right SDVO transcoder for CPT
drm/i915: no-lvds quirk for ASUS AT5NM10T-I
drm/i915: Treat pre-gen4 backlight duty cycle value consistently
drm/i915: Hook up Ivybridge eDP
drm/i915: add multi-threaded forcewake support
* 'for-linus' of git://git.kernel.dk/linux-block:
block: don't kick empty queue in blk_drain_queue()
block/swim3: Locking fixes
loop: Fix discard_alignment default setting
cfq-iosched: fix cfq_cic_link() race confition
cfq-iosched: free cic_index if blkio_alloc_blkg_stats fails
cciss: fix flush cache transfer length
cciss: Add IRQF_SHARED back in for the non-MSI(X) interrupt handler
loop: fix loop block driver discard and encryption comment
block: initialize request_queue's numa node during
In i915 driver, we do not enable either rc6 or semaphores on SNB when dmar
is enabled. The new 'intel_iommu_enabled' variable signals when the
iommu code is in operation.
Cc: Ted Phelps <phelps@gnusto.com>
Cc: Peter <pab1612@gmail.com>
Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz>
Cc: Andrew Lutomirski <luto@mit.edu>
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-off-by: Keith Packard <keithp@keithp.com>
skb priority
Use DCB notifiers to set the skb priority to allow packets
to be steered and tagged correctly over DCB enabled drivers
that setup traffic classes.
This allows queue_mapping() routines to be removed in these
drivers that were previously inspecting the ethertype of
every skb to mark FCoE/FIP frames.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=43739
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@kernel.org
Exactly like roundup_pow_of_two(1), the rounddown version was buggy for
the case of a compile-time constant '1' argument. Probably because it
originated from the same code, sharing history with the roundup version
from before the bugfix (for that one, see commit 1a06a52ee1b0: "Fix
roundup_pow_of_two(1)").
However, unlike the roundup version, the fix for rounddown is to just
remove the broken special case entirely. It's simply not needed - the
generic code
1UL << ilog2(n)
does the right thing for the constant '1' argment too. The only reason
roundup needed that special case was because rounding up does so by
subtracting one from the argument (and then adding one to the result)
causing the obvious problems with "ilog2(0)".
But rounddown doesn't do any of that, since ilog2() naturally truncates
(ie "rounds down") to the right rounded down value. And without the
ilog2(0) case, there's no reason for the special case that had the wrong
value.
tl;dr: rounddown_pow_of_two(1) should be 1, not 0.
Acked-by: Dmitry Torokhov <dtor@vmware.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: core: Fix deadlock when the CONFIG_MMC_UNSAFE_RESUME is not defined
mmc: sdhci-s3c: Remove old and misprototyped suspend operations
mmc: tmio: fix clock gating on platforms with a .set_pwr() method
mmc: sh_mmcif: fix clock gating on platforms with a .down_pwr() method
mmc: core: Fix typo at mmc_card_sleep
mmc: core: Fix power_off_notify during suspend
mmc: core: Fix setting power notify state variable for non-eMMC
mmc: core: Add quirk for long data read time
mmc: Add module.h include to sdhci-cns3xxx.c
mmc: mxcmmc: fix falling back to PIO
mmc: omap_hsmmc: DMA unmap only once in case of MMC error
On 64-bit platforms assigning a pointer to a 32-bit variable causes a
compiler warning and cannot actually work. Soc-camera currently doesn't
support any 64-bit systems, but such platforms can be added in the
and in any case compiler warnings should be avoided.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Adds a quirk that sets the data read timeout to a fixed value instead
of relying on the information in the CSD. The timeout value chosen
is 300ms since that has proven enough for the problematic cards found,
but could be increased if other cards require this.
This patch also enables this quirk for certain Micron cards known to
have this problem.
Signed-off-by: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com>
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Cc: <stable@kernel.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
