commit d049f74f2dbe71354d43d393ac3a188947811348 upstream.
The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit ea8117478918a4734586d35ff530721b682425be upstream.
Mike reported that commit 7d1a9417 ("x86: Use generic idle loop")
regressed several workloads and caused excessive reschedule
interrupts.
The patch in question failed to notice that the x86 code had an
inverted sense of the polling state versus the new generic code (x86:
default polling, generic: default !polling).
Fix the two prominent x86 mwait based idle drivers and introduce a few
new generic polling helpers (fixing the wrong smp_mb__after_clear_bit
usage).
Also switch the idle routines to using tif_need_resched() which is an
immediate TIF_NEED_RESCHED test as opposed to need_resched which will
end up being slightly different.
Reported-by: Mike Galbraith <bitbucket@online.de>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: lenb@kernel.org
Cc: tglx@linutronix.de
Link: http://lkml.kernel.org/n/tip-nc03imb0etuefmzybzj7sprf@git.kernel.org
commit bf378d341e4873ed928dc3c636252e6895a21f50 upstream.
The PPC64 people noticed a missing memory barrier and crufty old
comments in the perf ring buffer code. So update all the comments and
add the missing barrier.
When the architecture implements local_t using atomic_long_t there
will be double barriers issued; but short of introducing more
conditional barrier primitives this is the best we can do.
Reported-by: Victor Kaplansky <victork@il.ibm.com>
Tested-by: Victor Kaplansky <victork@il.ibm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: michael@ellerman.id.au
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: benh@kernel.crashing.org
Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan
[ Upstream commit 01ba16d6ec85a1ec4669c75513a76b61ec53ee50 ]
On receiving a packet too big icmp error we update the expire value by
calling rt6_update_expires. This function uses dst_set_expires which is
implemented that it can only reduce the expiration value of the dst entry.
If we insert new routing non-expiry information into the ipv6 fib where
we already have a matching rt6_info we only clear the RTF_EXPIRES flag
in rt6i_flags and leave the dst.expires value as is.
When new mtu information arrives for that cached dst_entry we again
call dst_set_expires. This time it won't update the dst.expire value
because we left the dst.expire value intact from the last update. So
dst_set_expires won't touch dst.expires.
Fix this by resetting dst.expires when clearing the RTF_EXPIRE flag.
dst_set_expires checks for a zero expiration and updates the
dst.expires.
In the past this (not updating dst.expires) was necessary because
dst.expire was placed in a union with the dst_entry *from reference
and rt6_clean_expires did assign NULL to it. This split happend in
ecd9883724b78cc72ed92c98bcb1a46c764fff21 ("ipv6: fix race condition
regarding dst->expires and dst->from").
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
Reported-by: Valentijn Sessink <valentyn@blub.net>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Tested-by: Valentijn Sessink <valentyn@blub.net>
commit bc5bd37ce48c66e9192ad2e7231e9678880f6f8e upstream.
Pavel Roskin reported that DRM_IOCTL_MODE_GETCONNECTOR was overwritting
the 4 bytes beyond the end of its structure with a 32-bit userspace
running on a 64-bit kernel. This is due to the padding gcc inserts as
the drm_mode_get_connector struct includes a u64 and its size is not a
natural multiple of u64s.
64-bit kernel:
sizeof(drm_mode_get_connector)=80, alignof=8
sizeof(drm_mode_get_encoder)=20, alignof=4
sizeof(drm_mode_modeinfo)=68, alignof=4
32-bit userspace:
sizeof(drm_mode_get_connector)=76, alignof=4
Fortuituously we can insert explicit padding to the tail of our
structures without breaking ABI.
Reported-by: Pavel Roskin <proski@gnu.org>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Dave Airlie <airlied@redhat.com>
Cc: dri-devel@lists.freedesktop.org
commit 2053a1db41193c2b5e1f47a91aaba0fd63ba7102 upstream.
The unpacked_lun field in the SCSI target tracepoints should be
initialized with cmd->orig_fe_lun rather than cmd->se_lun->unpacked_lun
for two reasons:
- most importantly, if we are in the cmd_complete tracepoint
returning a check condition due to no LUN found, cmd->se_lun will
be NULL and we'll crash trying to dereference it.
- also, in any case, cmd->se_lun->unpacked_lun is an internal index
into the target's internal set of LUNs; cmd->orig_fe_lun is much
more useful and interesting, since it's the value the initiator
actually sent.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 32c37fc30c52508711ea6a108cfd5855b8a07176 upstream.
Some USB drive enclosures do not correctly report an
overflow condition if they hold a drive with a capacity
over 2TB and are confronted with a READ_CAPACITY_10.
They answer with their capacity modulo 2TB.
The generic layer cannot cope with that. It must be told
to use READ_CAPACITY_16 from the beginning.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
[ Upstream commit 550bab42f83308c9d6ab04a980cc4333cef1c8fa ]
Make sure rt6i_gateway contains nexthop information in
all routes returned from lookup or when routes are directly
attached to skb for generated ICMP packets.
The effect of this patch should be a faster version of
rt6_nexthop() and the consideration of local addresses as
nexthop.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 96dc809514fb2328605198a0602b67554d8cce7b ]
In v3.9 6fd6ce2056de2709 ("ipv6: Do not depend on rt->n in
ip6_finish_output2()." changed the behaviour of ip6_finish_output2()
such that the recently introduced rt6_nexthop() is used
instead of an assigned neighbor.
As rt6_nexthop() prefers rt6i_gateway only for gatewayed
routes this causes a problem for users like IPVS, xt_TEE and
RAW(hdrincl) if they want to use different address for routing
compared to the destination address.
Another case is when redirect can create RTF_DYNAMIC
route without RTF_GATEWAY flag, we ignore the rt6i_gateway
in rt6_nexthop().
Fix the above problems by considering the rt6i_gateway if
present, so that traffic routed to address on local subnet is
not wrongly diverted to the destination address.
Thanks to Simon Horman and Phil Oester for spotting the
problematic commit.
Thanks to Hannes Frederic Sowa for his review and help in testing.
Reported-by: Phil Oester <kernel@linuxace.com>
Reported-by: Mark Brooks <mark@loadbalancer.org>
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit f2e5ddcc0d12f9c4c7b254358ad245c9dddce13b ]
When CONFIG_NETLABEL is disabled, the cipso_v4_validate() function could loop
forever in the main loop if opt[opt_iter +1] == 0, this will causing a kernel
crash in an SMP system, since the CPU executing this function will
stall /not respond to IPIs.
This problem can be reproduced by running the IP Stack Integrity Checker
(http://isic.sourceforge.net) using the following command on a Linux machine
connected to DUT:
"icmpsic -s rand -d <DUT IP address> -r 123456"
wait (1-2 min)
Signed-off-by: Seif Mazareeb <seif@marvell.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit e87b3998d795123b4139bc3f25490dd236f68212 ]
dst->xfrm is conditionally defined. Provide accessor funtion that
is always available.
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commits 6d36824e730f247b602c90e8715a792003e3c5a7,
02cf4ebd82ff0ac7254b88e466820a290ed8289a, and parts of
7eec4174ff29cd42f2acfae8112f51c228545d40 ]
After hearing many people over past years complaining against TSO being
bursty or even buggy, we are proud to present automatic sizing of TSO
packets.
One part of the problem is that tcp_tso_should_defer() uses an heuristic
relying on upcoming ACKS instead of a timer, but more generally, having
big TSO packets makes little sense for low rates, as it tends to create
micro bursts on the network, and general consensus is to reduce the
buffering amount.
This patch introduces a per socket sk_pacing_rate, that approximates
the current sending rate, and allows us to size the TSO packets so
that we try to send one packet every ms.
This field could be set by other transports.
Patch has no impact for high speed flows, where having large TSO packets
makes sense to reach line rate.
For other flows, this helps better packet scheduling and ACK clocking.
This patch increases performance of TCP flows in lossy environments.
A new sysctl (tcp_min_tso_segs) is added, to specify the
minimal size of a TSO packet (default being 2).
A follow-up patch will provide a new packet scheduler (FQ), using
sk_pacing_rate as an input to perform optional per flow pacing.
This explains why we chose to set sk_pacing_rate to twice the current
rate, allowing 'slow start' ramp up.
sk_pacing_rate = 2 * cwnd * mss / srtt
v2: Neal Cardwell reported a suspect deferring of last two segments on
initial write of 10 MSS, I had to change tcp_tso_should_defer() to take
into account tp->xmit_size_goal_segs
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Van Jacobson <vanj@google.com>
Cc: Tom Herbert <therbert@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
commit d9a605e40b1376eb02b067d7690580255a0df68f upstream.
Since in some situations the lock can be shared for readers, we shouldn't
be calling it a mutex, rename it to rwsem.
Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 19872d20c890073c5207d9e02bb8f14d451a11eb upstream.
udev has this nice feature of creating "dead" /dev/<node> device-nodes if
it finds a devnode:<node> modalias. Once the node is accessed, the kernel
automatically loads the module that provides the node. However, this
requires udev to know the major:minor code to use for the node. This
feature was introduced by:
commit 578454ff7eab61d13a26b568f99a89a2c9edc881
Author: Kay Sievers <kay.sievers@vrfy.org>
Date: Thu May 20 18:07:20 2010 +0200
driver core: add devname module aliases to allow module on-demand auto-loading
However, uhid uses dynamic minor numbers so this doesn't actually work. We
need to load uhid to know which minor it's going to use.
Hence, allocate a static minor (just like uinput does) and we're good
to go.
Reported-by: Tom Gundersen <teg@jklm.no>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
commit 117aad1e9e4d97448d1df3f84b08bd65811e6d6a upstream.
Isolated balloon pages can wrongly end up in LRU lists when
migrate_pages() finishes its round without draining all the isolated
page list.
The same issue can happen when reclaim_clean_pages_from_list() tries to
reclaim pages from an isolated page list, before migration, in the CMA
path. Such balloon page leak opens a race window against LRU lists
shrinkers that leads us to the following kernel panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
IP: [<ffffffff810c2625>] shrink_page_list+0x24e/0x897
PGD 3cda2067 PUD 3d713067 PMD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 340 Comm: kswapd0 Not tainted 3.12.0-rc1-22626-g4367597 #87
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
RIP: shrink_page_list+0x24e/0x897
RSP: 0000:ffff88003da499b8 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88003e82bd60 RCX: 00000000000657d5
RDX: 0000000000000000 RSI: 000000000000031f RDI: ffff88003e82bd40
RBP: ffff88003da49ab0 R08: 0000000000000001 R09: 0000000081121a45
R10: ffffffff81121a45 R11: ffff88003c4a9a28 R12: ffff88003e82bd40
R13: ffff88003da0e800 R14: 0000000000000001 R15: ffff88003da49d58
FS: 0000000000000000(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000
CR2: 00000000067d9000 CR3: 000000003ace5000 CR4: 00000000000407b0
Call Trace:
shrink_inactive_list+0x240/0x3de
shrink_lruvec+0x3e0/0x566
__shrink_zone+0x94/0x178
shrink_zone+0x3a/0x82
balance_pgdat+0x32a/0x4c2
kswapd+0x2f0/0x372
kthread+0xa2/0xaa
ret_from_fork+0x7c/0xb0
Code: 80 7d 8f 01 48 83 95 68 ff ff ff 00 4c 89 e7 e8 5a 7b 00 00 48 85 c0 49 89 c5 75 08 80 7d 8f 00 74 3e eb 31 48 8b 80 18 01 00 00 <48> 8b 74 0d 48 8b 78 30 be 02 00 00 00 ff d2 eb
RIP [<ffffffff810c2625>] shrink_page_list+0x24e/0x897
RSP <ffff88003da499b8>
CR2: 0000000000000028
---[ end trace 703d2451af6ffbfd ]---
Kernel panic - not syncing: Fatal exception
This patch fixes the issue, by assuring the proper tests are made at
putback_movable_pages() & reclaim_clean_pages_from_list() to avoid
isolated balloon pages being wrongly reinserted in LRU lists.
[akpm@linux-foundation.org: clarify awkward comment text]
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Reported-by: Luiz Capitulino <lcapitulino@redhat.com>
Tested-by: Luiz Capitulino <lcapitulino@redhat.com>
[ Upstream commit 26794942461f438a6bc725ec7294b08a6bd782c4 ]
The include/asm-generic/hugetlb.h stubs that just vector huge_pte_*()
calls to the pte_*() implementations won't work in certain situations.
x86 and sparc, for example, return "unsigned long" from the bit
checks, and just go "return pte_val(pte) & PTE_BIT_FOO;"
But since huge_pte_*() returns 'int', if any high bits on 64-bit are
relevant, they get chopped off.
The net effect is that we can loop forever trying to COW a huge page,
because the huge_pte_write() check signals false all the time.
Reported-by: Gurudas Pai <gurudas.pai@oracle.com>
Tested-by: Gurudas Pai <gurudas.pai@oracle.com>
Acked-by: David Rientjes <rientjes@google.com>
commit 5e130367d43ff22836bbae380d197d600fe8ddbb upstream.
This makes it more convenient to check for rfkill (no need to check for
dev->rfkill before calling rfkill_blocked()) and also avoids potential
races if the RFKILL state needs to be checked from within the rfkill
callback.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
[ Upstream commit 9a3bab6b05383f1e4c3716b3615500c51285959e ]
A host might need net_secret[] and never open a single socket.
Problem added in commit aebda156a570782
("net: defer net_secret[] initialization")
Based on prior patch from Hannes Frederic Sowa.
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@strressinduktion.org>
[ Upstream commit 7df37ff33dc122f7bd0614d707939fe84322d264 ]
When a router is doing DNAT for 6to4/6rd packets the latest
anti-spoofing commit 218774dc ("ipv6: add anti-spoofing checks for
6to4 and 6rd") will drop them because the IPv6 address embedded does
not match the IPv4 destination. This patch will allow them to pass by
testing if we have an address that matches on 6to4/6rd interface. I
have been hit by this problem using Fedora and IPV6TO4_IPV4ADDR.
Also, log the dropped packets (with rate limit).
Signed-off-by: Catalin(ux) M. BOIE <catab@embedromix.ro>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
commit 27ce405039bfe6d3f4143415c638f56a3df77dca upstream.
implement() is setting bytes in LE data stream. In case the data is not
aligned to 64bits, it reads past the allocated buffer. It doesn't really
change any value there (it's properly bitmasked), but in case that this
read past the boundary hits a page boundary, pagefault happens when
accessing 64bits of 'x' in implement(), and kernel oopses.
This happens much more often when numbered reports are in use, as the
initial 8bit skip in the buffer makes the whole process work on values
which are not aligned to 64bits.
This problem dates back to attempts in 2005 and 2006 to make implement()
and extract() as generic as possible, and even back then the problem
was realized by Adam Kroperlin, but falsely assumed to be impossible
to cause any harm:
http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg47690.html
I have made several attempts at fixing it "on the spot" directly in
implement(), but the results were horrible; the special casing for processing
last 64bit chunk and switching to different math makes it unreadable mess.
I therefore took a path to allocate a few bytes more which will never make
it into final report, but are there as a cushion for all the 64bit math
operations happening in implement() and extract().
All callers of hid_output_report() are converted at the same time to allocate
the buffer by newly introduced hid_alloc_report_buf() helper.
Bruno noticed that the whole raw_size test can be dropped as well, as
hid_alloc_report_buf() makes sure that the buffer is always of a proper
size.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit f84cb8a46a771f36a04a02c61ea635c968ed5f6a upstream.
Workaround the SCSI layer's problematic WRITE SAME heuristics by
disabling WRITE SAME in the DM multipath device's queue_limits if an
underlying device disabled it.
The WRITE SAME heuristics, with both the original commit 5db44863b6eb
("[SCSI] sd: Implement support for WRITE SAME") and the updated commit
66c28f971 ("[SCSI] sd: Update WRITE SAME heuristics"), default to enabling
WRITE SAME(10) even without successfully determining it is supported.
After the first failed WRITE SAME the SCSI layer will disable WRITE SAME
for the device (by setting sdkp->device->no_write_same which results in
'max_write_same_sectors' in device's queue_limits to be set to 0).
When a device is stacked ontop of such a SCSI device any changes to that
SCSI device's queue_limits do not automatically propagate up the stack.
As such, a DM multipath device will not have its WRITE SAME support
disabled. This causes the block layer to continue to issue WRITE SAME
requests to the mpath device which causes paths to fail and (if mpath IO
isn't configured to queue when no paths are available) it will result in
actual IO errors to the upper layers.
This fix doesn't help configurations that have additional devices
stacked ontop of the mpath device (e.g. LVM created linear DM devices
ontop). A proper fix that restacks all the queue_limits from the bottom
of the device stack up will need to be explored if SCSI will continue to
use this model of optimistically allowing op codes and then disabling
them after they fail for the first time.
Before this patch:
EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
device-mapper: multipath: XXX snitm debugging: got -EREMOTEIO (-121)
device-mapper: multipath: XXX snitm debugging: failing WRITE SAME IO with error=-121
end_request: critical target error, dev dm-6, sector 528
dm-6: WRITE SAME failed. Manually zeroing.
device-mapper: multipath: Failing path 8:112.
end_request: I/O error, dev dm-6, sector 4616
end_request: I/O error, dev dm-6, sector 5640
end_request: I/O error, dev dm-6, sector 6664
end_request: I/O error, dev dm-6, sector 7688
end_request: I/O error, dev dm-6, sector 524288
Buffer I/O error on device dm-6, logical block 65536
lost page write due to I/O error on dm-6
JBD2: Error -5 detected when updating journal superblock for dm-6-8.
end_request: I/O error, dev dm-6, sector 524296
Aborting journal on device dm-6-8.
# cat /sys/block/sdh/queue/write_same_max_bytes
0
# cat /sys/block/dm-6/queue/write_same_max_bytes
33553920
After this patch:
device-mapper: multipath: XXX snitm debugging: WRITE SAME I/O failed with error=-121
0
0
It should be noted that WRITE SAME support wasn't enabled in DM
multipath until v3.10.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Hannes Reinecke <hare@suse.de>
commit 9a71677874d200865433647e9282fcf9fa6b05dd upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit e5b9e7503eb1f4884efa3b321d3cc47806779202 upstream.
Also add a new RADEON_INFO query to check that CP DMA packets are
supported on the compute ring.
CP DMA has been supported since the 3.8 kernel, but due to an oversight
we forgot to teach the CS checker that the CP DMA packet was legal for
the compute ring on Southern Islands GPUs.
This patch fixes a bug where the radeon driver will incorrectly reject a legal
CP DMA packet from user space. I would like to have the patch
backported to stable so that we don't have to require Mesa users to use a
bleeding edge kernel in order to take advantage of this feature which
is already present in the stable kernels (3.8 and newer).
v2:
- Don't bump kms version, so this patch can be backported to stable
kernels.
Signed-off-by: Tom Stellard <thomas.stellard@amd.com>
commit 0431b2742f8e7755f3bbf5924900d12973412e94 upstream.
This adds the pci ids for the berlin GPU core.
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream.
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
commit 7bd36014460f793c19e7d6c94dab67b0afcfcb7f upstream.
Gerlando Falauto reported that when HRTICK is enabled, it is
possible to trigger system deadlocks. These were hard to
reproduce, as HRTICK has been broken in the past, but seemed
to be connected to the timekeeping_seq lock.
Since seqlock/seqcount's aren't supported w/ lockdep, I added
some extra spinlock based locking and triggered the following
lockdep output:
[ 15.849182] ntpd/4062 is trying to acquire lock:
[ 15.849765] (&(&pool->lock)->rlock){..-...}, at: [<ffffffff810aa9b5>] __queue_work+0x145/0x480
[ 15.850051]
[ 15.850051] but task is already holding lock:
[ 15.850051] (timekeeper_lock){-.-.-.}, at: [<ffffffff810df6df>] do_adjtimex+0x7f/0x100
<snip>
[ 15.850051] Chain exists of: &(&pool->lock)->rlock --> &p->pi_lock --> timekeeper_lock
[ 15.850051] Possible unsafe locking scenario:
[ 15.850051]
[ 15.850051] CPU0 CPU1
[ 15.850051] ---- ----
[ 15.850051] lock(timekeeper_lock);
[ 15.850051] lock(&p->pi_lock);
[ 15.850051] lock(&(&pool->lock)->rlock);
[ 15.850051]
[ 15.850051] *** DEADLOCK ***
The deadlock was introduced by 06c017fdd4dc48451a ("timekeeping:
Hold timekeepering locks in do_adjtimex and hardpps") in 3.10
This patch avoids this deadlock, by moving the call to
schedule_delayed_work() outside of the timekeeper lock
critical section.
Reported-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Tested-by: Lin Ming <minggr@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/1378943457-27314-1-git-send-email-john.stultz@linaro.org
commit 43622021d2e2b82ea03d883926605bdd0525e1d1 upstream.
The "Report ID" field of a HID report is used to build indexes of
reports. The kernel's index of these is limited to 256 entries, so any
malicious device that sets a Report ID greater than 255 will trigger
memory corruption on the host:
[ 1347.156239] BUG: unable to handle kernel paging request at ffff88094958a878
[ 1347.156261] IP: [<ffffffff813e4da0>] hid_register_report+0x2a/0x8b
CVE-2013-2888
commit 6bdaa63c2957ac04e8d596880f732b79f9c06c3c upstream.
Add PCI device IDs for AMD F15h, model 30h. They will be used in
amd_nb.c and amd64_edac.c
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
commit bd1c149aa9915b9abb6d83d0f01dfd2ace0680b5 upstream.
For performance reasons, when SMAP is in use, SMAP is left open for an
entire put_user_try { ... } put_user_catch(); block, however, calling
__put_user() in the middle of that block will close SMAP as the
STAC..CLAC constructs intentionally do not nest.
Furthermore, using __put_user() rather than put_user_ex() here is bad
for performance.
Thus, introduce new [compat_]save_altstack_ex() helpers that replace
__[compat_]save_altstack() for x86, being currently the only
architecture which supports put_user_try { ... } put_user_catch().
Reported-by: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-es5p6y64if71k8p5u08agv9n@git.kernel.org
commit c34ac00caefbe49d40058ae7200bd58725cebb45 upstream.
list_first_or_null() should test whether the list is empty and return
pointer to the first entry if not in a RCU safe manner. It's broken
in several ways.
* It compares __kernel @__ptr with __rcu @__next triggering the
following sparse warning.
net/core/dev.c:4331:17: error: incompatible types in comparison expression (different address spaces)
* It doesn't perform rcu_dereference*() and computes the entry address
using container_of() directly from the __rcu pointer which is
inconsitent with other rculist interface. As a result, all three
in-kernel users - net/core/dev.c, macvlan, cgroup - are buggy. They
dereference the pointer w/o going through read barrier.
* While ->next dereference passes through list_next_rcu(), the
compiler is still free to fetch ->next more than once and thus
nullify the "__ptr != __next" condition check.
Fix it by making list_first_or_null_rcu() dereference ->next directly
using ACCESS_ONCE() and then use list_entry_rcu() on it like other
rculist accessors.
v2: Paul pointed out that the compiler may fetch the pointer more than
once nullifying the condition check. ACCESS_ONCE() added on
->next dereference.
v3: Restored () around macro param which was accidentally removed.
Spotted by Paul.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 9d8924297cd9c256c23c02abae40202563452453 upstream.
This patch fixes a build error that occurs when CONFIG_PM is enabled
and CONFIG_PM_SLEEP isn't:
>> drivers/usb/host/ohci-pci.c:294:10: error: 'usb_hcd_pci_pm_ops' undeclared here (not in a function)
.pm = &usb_hcd_pci_pm_ops
Since the usb_hcd_pci_pm_ops structure is defined and used when
CONFIG_PM is enabled, its declaration should not be protected by
CONFIG_PM_SLEEP.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Pull networking fixes from David Miller:
1) There was a simplification in the ipv6 ndisc packet sending
attempted here, which avoided using memory accounting on the
per-netns ndisc socket for sending NDISC packets. It did fix some
important issues, but it causes regressions so it gets reverted here
too. Specifically, the problem with this change is that the IPV6
output path really depends upon there being a valid skb->sk
attached.
The reason we want to do this change in some form when we figure out
how to do it right, is that if a device goes down the ndisc_sk
socket send queue will fill up and block NDISC packets that we want
to send to other devices too. That's really bad behavior.
Hopefully Thomas can come up with a better version of this change.
2) Fix a severe TCP performance regression by reverting a change made
to dev_pick_tx() quite some time ago. From Eric Dumazet.
3) TIPC returns wrongly signed error codes, fix from Erik Hugne.
4) Fix OOPS when doing IPSEC over ipv4 tunnels due to orphaning the
skb->sk too early. Fix from Li Hongjun.
5) RAW ipv4 sockets can use the wrong routing key during lookup, from
Chris Clark.
6) Similar to #1 revert an older change that tried to use plain
alloc_skb() for SYN/ACK TCP packets, this broke the netfilter owner
mark which needs to see the skb->sk for such frames. From Phil
Oester.
7) BNX2x driver bug fixes from Ariel Elior and Yuval Mintz,
specifically in the handling of virtual functions.
8) IPSEC path error propagations to sockets is not done properly when
we have v4 in v6, and v6 in v4 type rules. Fix from Hannes Frederic
Sowa.
9) Fix missing channel context release in mac80211, from Johannes Berg.
10) Fix network namespace handing wrt. SCM_RIGHTS, from Andy
Lutomirski.
11) Fix usage of bogus NAPI weight in jme, netxen, and ps3_gelic
drivers. From Michal Schmidt.
12) Hopefully a complete and correct fix for the genetlink dump locking
and module reference counting. From Pravin B Shelar.
13) sk_busy_loop() must do a cpu_relax(), from Eliezer Tamir.
14) Fix handling of timestamp offset when restoring a snapshotted TCP
socket. From Andrew Vagin.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits)
net: fec: fix time stamping logic after napi conversion
net: bridge: convert MLDv2 Query MRC into msecs_to_jiffies for max_delay
mISDN: return -EINVAL on error in dsp_control_req()
net: revert 8728c544a9c ("net: dev_pick_tx() fix")
Revert "ipv6: Don't depend on per socket memory for neighbour discovery messages"
ipv4 tunnels: fix an oops when using ipip/sit with IPsec
tipc: set sk_err correctly when connection fails
tcp: tcp_make_synack() should use sock_wmalloc
bridge: separate querier and query timer into IGMP/IPv4 and MLD/IPv6 ones
ipv4: sendto/hdrincl: don't use destination address found in header
tcp: don't apply tsoffset if rcv_tsecr is zero
tcp: initialize rcv_tstamp for restored sockets
net: xilinx: fix memleak
net: usb: Add HP hs2434 device to ZLP exception table
net: add cpu_relax to busy poll loop
net: stmmac: fixed the pbl setting with DT
genl: Hold reference on correct module while netlink-dump.
genl: Fix genl dumpit() locking.
xfrm: Fix potential null pointer dereference in xdst_queue_output
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec
Steffen Klassert says:
This pull request fixes some issues that arise when 6in4 or 4in6 tunnels
are used in combination with IPsec, all from Hannes Frederic Sowa and a
null pointer dereference when queueing packets to the policy hold queue.
1) We might access the local error handler of the wrong address family if
6in4 or 4in6 tunnel is protected by ipsec. Fix this by addind a pointer
to the correct local_error to xfrm_state_afinet.
2) Add a helper function to always refer to the correct interpretation
of skb->sk.
3) Call skb_reset_inner_headers to record the position of the inner headers
when adding a new one in various ipv6 tunnels. This is needed to identify
the addresses where to send back errors in the xfrm layer.
4) Dereference inner ipv6 header if encapsulated to always call the
right error handler.
5) Choose protocol family by skb protocol to not call the wrong
xfrm{4,6}_local_error handler in case an ipv6 sockets is used
in ipv4 mode.
6) Partly revert "xfrm: introduce helper for safe determination of mtu"
because this introduced pmtu discovery problems.
7) Set skb->protocol on tcp, raw and ip6_append_data genereated skbs.
We need this to get the correct mtu informations in xfrm.
8) Fix null pointer dereference in xdst_queue_output.
Merge fixes from Andrew Morton:
"Five fixes.
err, make that six. let me try again"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
fs/ocfs2/super.c: Use bigger nodestr to accomodate 32-bit node numbers
memcg: check that kmem_cache has memcg_params before accessing it
drivers/base/memory.c: fix show_mem_removable() to handle missing sections
IPC: bugfix for msgrcv with msgtyp < 0
Omnikey Cardman 4000: pull in ioctl.h in user header
timer_list: correct the iterator for timer_list
This file uses the ioctl helpers (_IOR/_IOW/etc...), so include ioctl.h
for the definitions.
Cc: Harald Welte <laforge@gnumonks.org>
This just replaces the dentry count/lock combination with the lockref
structure that contains both a count and a spinlock, and does the
mechanical conversion to use the lockref infrastructure.
There are no semantic changes here, it's purely syntactic. The
reference lockref implementation uses the spinlock exactly the same way
that the old dcache code did, and the bulk of this patch is just
expanding the internal "d_count" use in the dcache code to use
"d_lockref.count" instead.
This is purely preparation for the real change to make the reference
count updates be lockless during the 3.12 merge window.
[ As with the previous commit, this is a rewritten version of a concept
originally from Waiman, so credit goes to him, blame for any errors
goes to me.
Waiman's patch had some semantic differences for taking advantage of
the lockless update in dget_parent(), while this patch is
intentionally a pure search-and-replace change with no semantic
changes. - Linus ]
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
This introduces a new "lockref" structure that supports the concept of
lockless updates of reference counts that still honor an attached
spinlock.
NOTE! This reference implementation is not the optimized lockless
version, rather it is the fallback implementation using standard
spinlocks. The actual optimized versions will be merged into 3.12, but
I wanted to get the infrastructure in place and document the new
interfaces.
[ Also note that this particular commit is drastically cut-down minimal
version of the original patch by Waiman. In order to properly credit
the original author I'm marking Waiman as the author here, but in the
end this patch bears little resemblance to the patch by Waiman. So
blame any errors on me editing things down to the point where I can
introduce the infrastructure before the merge window for 3.12 actually
opens. - Linus ]
Add a cpu_relaxt to sk_busy_loop.
Julie Cummings reported performance issues when hyperthreading is on.
Arjan van de Ven observed that we should have a cpu_relax() in the
busy poll loop.
Reported-by: Julie Cummings <julie.a.cummings@intel.com>
Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com>
netlink dump operations take module as parameter to hold
reference for entire netlink dump duration.
Currently it holds ref only on genl module which is not correct
when we use ops registered to genl from another module.
Following patch adds module pointer to genl_ops so that netlink
can hold ref count on it.
CC: Jesse Gross <jesse@nicira.com>
CC: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
This is one more set of fixes intended for the 3.11 stream...
For the mac80211 bits, Johannes says:
"I have three more patches for the 3.11 stream: Felix's fix for the
fairly visible brcmsmac crash, a fix from Simon for an IBSS join bug I
found and a fix for a channel context bug in IBSS I'd introduced."
Along with those...
Sujith Manoharan makes a minor change to not use a PLL hang workaroun
for AR9550. This one-liner fixes a couple of bugs reported in the Red Hat
bugzilla.
Helmut Schaa addresses an ath9k_htc bug that mangles frame headers
during Tx. This fix is small, tested by the bug reported and isolated
to ath9k_htc.
Stanislaw Gruszka reverts a recent iwl4965 change that broke rfkill
notification to user space.
Please let me know if there are problems!
nsproxy.pid_ns is *not* the task's pid namespace. The name should clarify
that.
This makes it more obvious that setns on a pid namespace is weird --
it won't change the pid namespace shown in procfs.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fixes from Mark Brown:
"Two changes here:
- Fix a bug in the rbtree code which could cause it to create two
different cache entries for the same register by adding a single
register at a time to the cache. This isn't awesome for
performance but it's non-invasive which we need for this late in
the release cycle and the I/O costs we're trying to avoid are high.
- Add another header used in the !CONFIG_REGMAP stubs where we had
been relying on implicit inclusion"
* tag 'regmap-v3.11-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: rbtree: Fix overlapping rbnodes.
regmap: Add another missing header for !CONFIG_REGMAP stubs
In commit 0ea9d5e3e0e03a63b11392f5613378977dae7eca ("xfrm: introduce
helper for safe determination of mtu") I switched the determination of
ipv4 mtus from dst_mtu to ip_skb_dst_mtu. This was an error because in
case of IP_PMTUDISC_PROBE we fall back to the interface mtu, which is
never correct for ipv4 ipsec.
This patch partly reverts 0ea9d5e3e0e03a63b11392f5613378977dae7eca
("xfrm: introduce helper for safe determination of mtu").
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Pull vfs fixes from Al Viro:
"Assorted fixes from the last week or so"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: collect_mounts() should return an ERR_PTR
bfs: iget_locked() doesn't return an ERR_PTR
efs: iget_locked() doesn't return an ERR_PTR()
proc: kill the extra proc_readfd_common()->dir_emit_dots()
cope with potentially long ->d_dname() output for shmem/hugetlb
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of small bug fixes for lpfc and zfcp and a fix for a
fairly nasty bug in sg where a process which cancels I/O completes in
a kernel thread which would then try to write back to the now gone
userspace and end up writing to a random kernel address instead"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] zfcp: remove access control tables interface (keep sysfs files)
[SCSI] zfcp: fix schedule-inside-lock in scsi_device list loops
[SCSI] zfcp: fix lock imbalance by reworking request queue locking
[SCSI] sg: Fix user memory corruption when SG_IO is interrupted by a signal
[SCSI] lpfc: Don't force CONFIG_GENERIC_CSUM on
dynamic_dname() is both too much and too little for those - the
output may be well in excess of 64 bytes dynamic_dname() assumes
to be enough (thanks to ashmem feeding really long names to
shmem_file_setup()) and vsnprintf() is an overkill for those
guys.
