path: root/include
2007-08-28[PATCH] Revert "Keep rfcomm_dev on the list until it is freed"Willy Tarreau
Randy Dunlap and Boris B. Zhmurov reported build failure of rfcomm/tty.c since 2.6.20.17. Marcel Holtmann confirmed that the following patch was inappropriate for this kernel. Remove it. This reverts commit 8c25e9c9cd1fed0d5f57075b584c39a4b9af9830. Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Willy Tarreau <w@1wt.eu>
2007-08-25[PATCH] Keep rfcomm_dev on the list until it is freedVille Tervo
This patch changes the RFCOMM TTY release process so that the TTY is kept on the list until it is really freed. A new device flag is used to keep track of released TTYs. Signed-off-by: Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Willy Tarreau <w@1wt.eu>
2007-08-25[PATCH] Include serial_reg.h with userspace headersHerton Ronaldo Krzesinski
As reported by Gustavo de Nardin <gustavodn@mandriva.com.br>, while trying to compile xosview (http://xosview.sourceforge.net/) with upstream kernel headers being used you get the following errors: serialmeter.cc:48:30: error: linux/serial_reg.h: No such file or directory serialmeter.cc: In member function 'virtual void SerialMeter::checkResources()': serialmeter.cc:71: error: 'UART_LSR' was not declared in this scope serialmeter.cc:71: error: 'UART_MSR' was not declared in this scope ... Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: Gustavo de Nardin <gustavodn@mandriva.com.br> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Willy Tarreau <w@1wt.eu>
2007-08-25[PATCH] Missing header include in ipt_iprange.hAdrian Bunk
[NETFILTER]: ipt_iprange.h must #include <linux/types.h> ipt_iprange.h must #include <linux/types.h> since it uses __be32. This patch fixes kernel Bugzilla #7604. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Willy Tarreau <w@1wt.eu>
2007-08-25[PATCH] Fix IPCOMP crashes.Patrick McHardy
[XFRM]: Fix crash introduced by struct dst_entry reordering XFRM expects xfrm_dst->u.next to be same pointer as dst->next, which was broken by the dst_entry reordering in commit 1e19e02c~, causing an oops in xfrm_bundle_ok when walking the bundle upwards. Kill xfrm_dst->u.next and change the only user to use dst->next instead. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Willy Tarreau <w@1wt.eu>
2007-08-15[PATCH] pi-futex: Fix exit races and locking problemsAlexey Kuznetsov
1. New entries can be added to tsk->pi_state_list after task completed exit_pi_state_list(). The result is memory leakage and deadlocks. 2. handle_mm_fault() is called under spinlock. The result is obvious. 3. results in self-inflicted deadlock inside glibc. Sometimes futex_lock_pi returns -ESRCH, when it is not expected and glibc enters to for(;;) sleep() to simulate deadlock. This problem is quite obvious and I think the patch is right. Though it looks like each "if" in futex_lock_pi() got some stupid special case "else if". :-) 4. sometimes futex_lock_pi() returns -EDEADLK, when nobody has the lock. The reason is also obvious (see comment in the patch), but correct fix is far beyond my comprehension. I guess someone already saw this, the chunk: if (rt_mutex_trylock(&q.pi_state->pi_mutex)) ret = 0; is obviously from the same opera. But it does not work, because the rtmutex is really taken at this point: wake_futex_pi() of previous owner reassigned it to us. My fix works. But it looks very stupid. I would think about removal of shift of ownership in wake_futex_pi() and making all the work in context of process taking lock. From: Thomas Gleixner <tglx@linutronix.de> Fix 1) Avoid the tasklist lock variant of the exit race fix by adding an additional state transition to the exit code. This fixes also the issue, when a task with recursive segfaults is not able to release the futexes. Fix 2) Cleanup the lookup_pi_state() failure path and solve the -ESRCH problem finally. Fix 3) Solve the fixup_pi_state_owner() problem which needs to do the fixup in the lock protected section by using the in_atomic userspace access functions. This removes also the ugly lock drop / unqueue inside of fixup_pi_state() Fix 4) Fix a stale lock in the error path of futex_wake_pi() Added some error checks for verification. The -EDEADLK problem is solved by the rtmutex fixups. Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-15[PATCH] x86_64: allocate sparsemem memmap above 4GZou Nan hai
On systems with huge amount of physical memory, VFS cache and memory memmap may eat all available system memory under 4G, then the system may fail to allocate swiotlb bounce buffer. There was a fix for this issue in arch/x86_64/mm/numa.c, but that fix dose not cover sparsemem model. This patch add fix to sparsemem model by first try to allocate memmap above 4G. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [chrisw: trivial backport] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-15[PATCH] pci_ids: update patch for Intel ICH9MJason Gaston
This patch updates the Intel ICH9M LPC Controller DID's, due to a specification change. Signed-off-by: Jason Gaston <jason.d.gaston@intel.com> Cc: <stable@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-15[PATCH] make freezeable workqueues singlethreadOleg Nesterov
It is a known fact that freezeable multithreaded workqueues doesn't like CPU_DEAD. We keep them only for the incoming CPU-hotplug rework. Sadly, we can't just kill create_freezeable_workqueue() right now, make them singlethread. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-15[PATCH] md: Don't write more than is required of the last page of a bitmapNeilBrown
It is possible that real data or metadata follows the bitmap without full page alignment. So limit the last write to be only the required number of bytes, rounded up to the hard sector size of the device. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-11[PATCH] Fix AF_UNIX OOPSDavid Miller
This combines two upstream commits to fix an OOPS with AF_UNIX and SELINUX. basically, sk->sk_socket can become null because we access a peer socket without any locking, so it can be shut down and released in another thread. Commit: d410b81b4eef2e4409f9c38ef201253fbbcc7d94 [AF_UNIX]: Make socket locking much less confusing. The unix_state_*() locking macros imply that there is some rwlock kind of thing going on, but the implementation is actually a spinlock which makes the code more confusing than it needs to be. So use plain unix_state_lock and unix_state_unlock. Signed-off-by: David S. Miller <davem@davemloft.net> Commit: 19fec3e807a487415e77113cb9dbdaa2da739836 [AF_UNIX]: Fix datagram connect race causing an OOPS. Based upon an excellent bug report and initial patch by Frederik Deweerdt. The UNIX datagram connect code blindly dereferences other->sk_socket via the call down to the security_unix_may_send() function. Without locking 'other' that pointer can go NULL via unix_release_sock() which does sock_orphan() which also marks the socket SOCK_DEAD. So we have to lock both 'sk' and 'other' yet avoid all kinds of potential deadlocks (connect to self is OK for datagram sockets and it is possible for two datagram sockets to perform a simultaneous connect to each other). So what we do is have a "double lock" function similar to how we handle this situation in other areas of the kernel. We take the lock of the socket pointer with the smallest address first in order to avoid ABBA style deadlocks. Once we have them both locked, we check to see if SOCK_DEAD is set for 'other' and if so, drop everything and retry the lookup. Signed-off-by: David S. Miller <davem@davemloft.net> [chrisw: backport to 2.6.20] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] SPARC64: Fix two bugs wrt. kernel 4MB TSB.David Miller
1) The TSB lookup was not using the correct hash mask. 2) It was not aligned on a boundary equal to it's size, which is required by the sun4v Hypervisor. wasn't having it's return value checked, and that bug will be fixed up as well in a subsequent changeset. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] NET: Fix BMSR_100{HALF,FULL}2 defines in linux/mii.hDavid Miller
Noticed by Matvejchikov Ilya. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] s390: Fix TCP/UDP pseudo header checksum computation.Heiko Carstens
git commit f994aae1bd8e4813d59a2ed64d17585fe42d03fc changed the function declaration of csum_tcpudp_nofold. Argument types were changed from unsigned long to __be32 (unsigned int). Therefore we lost the implicit type conversion that zeroed the upper half of the registers that are used to pass parameters. Since the inline assembly relied on this we ended up adding random values and wrong checksums were created. Showed only up on machines with more than 4GB since gcc produced code where the registers that are used to pass 'saddr' and 'daddr' previously contained addresses before calling this function. Fix this by using 32 bit arithmetics and convert code to C, since gcc produces better code than these hand-optimized versions. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] {ip, nf}_nat_proto_gre: do not modify/corrupt GREv0 packets through NATJorge Boncompte
While porting some changes of the 2.6.21-rc7 pptp/proto_gre conntrack and nat modules to a 2.4.32 kernel I noticed that the gre_key function returns a wrong pointer to the GRE key of a version 0 packet thus corrupting the packet payload. The intended behaviour for GREv0 packets is to act like nf_conntrack_proto_generic/nf_nat_proto_unknown so I have ripped the offending functions (not used anymore) and modified the nf_nat_proto_gre modules to not touch version 0 (non PPTP) packets. Signed-off-by: Jorge Boncompte <jorge@dti2.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-11[PATCH] iop13xx: fix i/o address translationDan Williams
PCI devices were being programmed with an incorrect base address value. This patch moves I/O space into a 16-bit addressable region and corrects the i/o offset. Much thanks to Martin Michlmayr for tracking this issue and testing debug patches. Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01Taskstats fix the structure members alignment issueBalbir Singh
We broke the the alignment of members of taskstats to the 8 byte boundary with the CSA patches. In the current kernel, the taskstats structure is not suitable for use by 32 bit applications in a 64 bit kernel. On x86_64 Offsets of taskstats' members (64 bit kernel, 64 bit application) @taskstats'offsetof[@taskstats'indices] = ( 0, # version 4, # ac_exitcode 8, # ac_flag 9, # ac_nice 16, # cpu_count 24, # cpu_delay_total 32, # blkio_count 40, # blkio_delay_total 48, # swapin_count 56, # swapin_delay_total 64, # cpu_run_real_total 72, # cpu_run_virtual_total 80, # ac_comm 112, # ac_sched 113, # ac_pad 116, # ac_uid 120, # ac_gid 124, # ac_pid 128, # ac_ppid 132, # ac_btime 136, # ac_etime 144, # ac_utime 152, # ac_stime 160, # ac_minflt 168, # ac_majflt 176, # coremem 184, # virtmem 192, # hiwater_rss 200, # hiwater_vm 208, # read_char 216, # write_char 224, # read_syscalls 232, # write_syscalls 240, # read_bytes 248, # write_bytes 256, # cancelled_write_bytes ); Offsets of taskstats' members (64 bit kernel, 32 bit application) @taskstats'offsetof[@taskstats'indices] = ( 0, # version 4, # ac_exitcode 8, # ac_flag 9, # ac_nice 12, # cpu_count 20, # cpu_delay_total 28, # blkio_count 36, # blkio_delay_total 44, # swapin_count 52, # swapin_delay_total 60, # cpu_run_real_total 68, # cpu_run_virtual_total 76, # ac_comm 108, # ac_sched 109, # ac_pad 112, # ac_uid 116, # ac_gid 120, # ac_pid 124, # ac_ppid 128, # ac_btime 132, # ac_etime 140, # ac_utime 148, # ac_stime 156, # ac_minflt 164, # ac_majflt 172, # coremem 180, # virtmem 188, # hiwater_rss 196, # hiwater_vm 204, # read_char 212, # write_char 220, # read_syscalls 228, # write_syscalls 236, # read_bytes 244, # write_bytes 252, # cancelled_write_bytes ); This is one way to solve the problem without re-arranging structure members is to pack the structure. The patch adds an __attribute__((aligned(8))) to the taskstats structure members so that 32 bit applications using taskstats can work with a 64 bit kernel. Using __attribute__((packed)) would break the 64 bit alignment of members. The fix was tested on x86_64. After the fix, we got Offsets of taskstats' members (64 bit kernel, 64 bit application) @taskstats'offsetof[@taskstats'indices] = ( 0, # version 4, # ac_exitcode 8, # ac_flag 9, # ac_nice 16, # cpu_count 24, # cpu_delay_total 32, # blkio_count 40, # blkio_delay_total 48, # swapin_count 56, # swapin_delay_total 64, # cpu_run_real_total 72, # cpu_run_virtual_total 80, # ac_comm 112, # ac_sched 113, # ac_pad 120, # ac_uid 124, # ac_gid 128, # ac_pid 132, # ac_ppid 136, # ac_btime 144, # ac_etime 152, # ac_utime 160, # ac_stime 168, # ac_minflt 176, # ac_majflt 184, # coremem 192, # virtmem 200, # hiwater_rss 208, # hiwater_vm 216, # read_char 224, # write_char 232, # read_syscalls 240, # write_syscalls 248, # read_bytes 256, # write_bytes 264, # cancelled_write_bytes ); Offsets of taskstats' members (64 bit kernel, 32 bit application) @taskstats'offsetof[@taskstats'indices] = ( 0, # version 4, # ac_exitcode 8, # ac_flag 9, # ac_nice 16, # cpu_count 24, # cpu_delay_total 32, # blkio_count 40, # blkio_delay_total 48, # swapin_count 56, # swapin_delay_total 64, # cpu_run_real_total 72, # cpu_run_virtual_total 80, # ac_comm 112, # ac_sched 113, # ac_pad 120, # ac_uid 124, # ac_gid 128, # ac_pid 132, # ac_ppid 136, # ac_btime 144, # ac_etime 152, # ac_utime 160, # ac_stime 168, # ac_minflt 176, # ac_majflt 184, # coremem 192, # virtmem 200, # hiwater_rss 208, # hiwater_vm 216, # read_char 224, # write_char 232, # read_syscalls 240, # write_syscalls 248, # read_bytes 256, # write_bytes 264, # cancelled_write_bytes ); Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-25[PATCH] IPV6: Disallow RH0 by default.YOSHIFUJI Hideaki
[IPV6]: Disallow RH0 by default. A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. Note: We allow RH2 by default because it is harmless. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-13ide: use correct IDE error recoverySuleiman Souhlal
ide: use correct IDE error recovery IDE error recovery is using IDLE IMMEDIATE if the drive is busy or has DRQ set. This violates the ATA spec (can only send IDLE IMMEDIATE when drive is not busy) and really hoses up some drives (modern drives will not be able to recover using this error handling). The correct thing to do is issue a SRST followed by a SET FEATURES command. This is what Western Digital recommends for error recovery and what Western Digital says Windows does.  It also does not violate the ATA spec as far as I can tell. Bart: * port the patch over the current tree * undo the recalibration code removal * send SET FEATURES command after checking for good drive status * don't check whether the current request is of REQ_TYPE_ATA_{CMD,TASK} type because we need to send SET FEATURES before handling any requests * some pre-ATA4 drives require INITIALIZE DEVICE PARAMETERS command before other commands (except IDENTIFY) so send SET FEATURES only if there are no pending drive->special requests * update comments and patch description * any bugs introduced by this patch are mine and not Suleiman's :-) Signed-off-by: Suleiman Souhlal <suleiman@google.com> Acked-by: Alan Cox <alan@redhat.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-13Fix IFB net driver input device crashesPatrick McHardy
[IFB]: Fix crash on input device removal The input_device pointer is not refcounted, which means the device may disappear while packets are queued, causing a crash when ifb passes packets with a stale skb->dev pointer to netif_rx(). Fix by storing the interface index instead and do a lookup where neccessary. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06[PATCH] uml: fix static linking for realPaolo 'Blaisorblade' Giarrusso
There was a typo in commit b40b478e9972ec14cf144f1a03f88918789cbfe0, preventing it from working - 32bit binaries crashed hopelessly before the below fix and work perfectly now. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [chrisw: update changelog to reflect -stable commit id] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-04-06V4L: saa7146: Fix allocation of clipping memoryOliver Endriss
V4L: saa7146: Fix allocation of clipping memory Olaf Hering pointed out that SAA7146_CLIPPING_MEM would become very large for PAGE_SIZE > 4K. In fact, the number of clipping windows is limited to 16, and calculate_clipping_registers_rect() does not use more than 256 bytes. SAA7146_CLIPPING_MEM adjusted accordingly. (cherry picked from commit 7a7cd1920969dd9da4e0d99aab573b3eba24c799) Thanks-to: Olaf Hering <olaf@aepfle.de> Acked-by: Michael Hunold <hunold@linuxtv.org> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06NET: Fix FIB rules compatabilityThomas Graf
[NET]: Fix fib_rules compatibility breakage Based upon a patch from Patrick McHardy. The fib_rules netlink attribute policy introduced in 2.6.19 broke userspace compatibilty. When specifying a rule with "from all" or "to all", iproute adds a zero byte long netlink attribute, but the policy requires all addresses to have a size equal to sizeof(struct in_addr)/sizeof(struct in6_addr), resulting in a validation error. Check attribute length of FRA_SRC/FRA_DST in the generic framework by letting the family specific rules implementation provide the length of an address. Report an error if address length is non zero but no address attribute is provided. Fix actual bug by checking address length for non-zero instead of relying on availability of attribute. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06SPARC: Fix sparc builds with gcc-4.2.xMikael Pettersson
[SPARC]: sparc64 gcc-4.2.0 20070317 -Werror failure Compiling 2.6.21-rc5 with gcc-4.2.0 20070317 (prerelease) for sparc64 fails as follows: gcc -Wp,-MD,arch/sparc64/kernel/.time.o.d -nostdinc -isystem /home/mikpe/pkgs/linux-sparc64/gcc-4.2.0/lib/gcc/sparc64-unknown-linux-gnu/4.2.0/include -D__KERNEL__ -Iinclude -include include/linux/autoconf.h -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -m64 -pipe -mno-fpu -mcpu=ultrasparc -mcmodel=medlow -ffixed-g4 -ffixed-g5 -fcall-used-g7 -Wno-sign-compare -Wa,--undeclared-regs -fomit-frame-pointer -fno-stack-protector -Wdeclaration-after-statement -Wno-pointer-sign -Werror -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(time)" -D"KBUILD_MODNAME=KBUILD_STR(time)" -c -o arch/sparc64/kernel/time.o arch/sparc64/kernel/time.c cc1: warnings being treated as errors arch/sparc64/kernel/time.c: In function 'kick_start_clock': arch/sparc64/kernel/time.c:559: warning: overflow in implicit constant conversion make[1]: *** [arch/sparc64/kernel/time.o] Error 1 make: *** [arch/sparc64/kernel] Error 2 gcc gets unhappy when the MSTK_SET macro's u8 __val variable is updated with &= ~0xff (MSTK_YEAR_MASK). Making the constant unsigned fixes the problem. [ I fixed up the sparc32 side as well -DaveM ] Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06IPV6: Fix ipv6 round-robin locking.David Miller
[IPV6]: Fix routing round-robin locking. As per RFC2461, section 6.3.6, item #2, when no routers on the matching list are known to be reachable or probably reachable we do round robin on those available routes so that we make sure to probe as many of them as possible to detect when one becomes reachable faster. Each routing table has a rwlock protecting the tree and the linked list of routes at each leaf. The round robin code executes during lookup and thus with the rwlock taken as a reader. A small local spinlock tries to provide protection but this does not work at all for two reasons: 1) The round-robin list manipulation, as coded, goes like this (with read lock held): walk routes finding head and tail spin_lock(); rotate list using head and tail spin_unlock(); While one thread is rotating the list, another thread can end up with stale values of head and tail and then proceed to corrupt the list when it gets the lock. This ends up causing the OOPS in fib6_add() later onthat many people have been hitting. 2) All the other code paths that run with the rwlock held as a reader do not expect the list to change on them, they expect it to remain completely fixed while they hold the lock in that way. So, simply stated, it is impossible to implement this correctly using a manipulation of the list without violating the rwlock locking semantics. Reimplement using a per-fib6_node round-robin pointer. This way we don't need to manipulate the list at all, and since the round-robin pointer can only ever point to real existing entries we don't need to perform any locking on the changing of the round-robin pointer itself. We only need to reset the round-robin pointer to NULL when the entry it is pointing to is removed. The idea is from Thomas Graf and it is very similar to how this was implemented before the advanced router selection code when in. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-06uml: fix unreasonably long udelayPaolo 'Blaisorblade' Giarrusso
Currently we have a confused udelay implementation. * __const_udelay does not accept usecs but xloops in i386 and x86_64 * our implementation requires usecs as arg * it gets a xloops count when called by asm/arch/delay.h Bugs related to this (extremely long shutdown times) where reported by some x86_64 users, especially using Device Mapper. To hit this bug, a compile-time constant time parameter must be passed - that's why UML seems to work most times. Fix this with a simple udelay implementation. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06UML - Fix static linkingJeff Dike
During a static link, ld has started putting a .note section in the .uml.setup.init section. This has the result that the UML setups begin with 32 bytes of garbage and UML crashes immediately on boot. This patch creates a specific .note section for ld to drop this stuff into. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06UML - fix epollJeff Dike
UML/x86_64 needs the same packing of struct epoll_event as x86_64. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06ide: remove clearing bmdma status from cdrom_decode_status() (rev #4)Albert Lee
ide: remove clearing bmdma status from cdrom_decode_status() (rev #4) patch 2/2: Remove clearing bmdma status from cdrom_decode_status() since ATA devices might need it as well. (http://lkml.org/lkml/2006/12/4/201 and http://lkml.org/lkml/2006/11/15/94) Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: "Adam W. Hawks" <awhawks@us.ibm.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06ide: clear bmdma status in ide_intr() for ICHx controllers (revised #4)Albert Lee
ide: clear bmdma status in ide_intr() for ICHx controllers (revised #4) patch 1/2 (revised): - Fix drive->waiting_for_dma to work with CDB-intr devices. - Do the dma status clearing in ide_intr() and add a new hwif->ide_dma_clear_irq for Intel ICHx controllers. Revised per Alan, Sergei and Bart's advice. Patch against 2.6.20-rc6. Tested ok on my ICH4 and pdc20275 adapters. Please review/apply, thanks. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Adam Hawks <awhawks@us.ibm.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23UML - arch_prctl should set thread fsJeff Dike
x86_64 needs some TLS fixes. What was missing was remembering the child thread id during clone and stuffing it into the child during each context switch. The %fs value is stored separately in the thread structure since the host controls what effect it has on the actual register file. The host also needs to store it in its own thread struct, so we need the value kept outside the register file. arch_prctl_skas was fixed to call PTRACE_ARCH_PRCTL appropriately. There is some saving and restoring of registers in the ARCH_SET_* cases so that the correct set of registers are changed on the host and restored to the process when it runs again. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23Fix page allocation debugging on sparc64David Miller
[SPARC64]: Get DEBUG_PAGEALLOC working again. We have to make sure to use base-pagesize TLB entries even during the early transition period where we need TLB miss handling but don't have the kernel page tables setup yet for the linear region. Also, it is necessary therefore to not use the 4MB TSB for these translations, and instead use the normal kernel TSB. This allows us to also get rid of the 4MB tsb for debug builds which shrinks the kernel a little bit. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23fix MTIME_SEC_MAX on 32-bitThomas Gleixner
The maximum seconds value we can handle on 32bit is LONG_MAX. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-13Fix timewait jiffiesEric Dumazet
[INET]: twcal_jiffie should be unsigned long, not int Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-13conntrack: fix {nf, ip}_ct_iterate_cleanup endless loopsPatrick McHardy
[NETFILTER]: conntrack: fix {nf,ip}_ct_iterate_cleanup endless loops Fix {nf,ip}_ct_iterate_cleanup unconfirmed list handling: - unconfirmed entries can not be killed manually, they are removed on confirmation or final destruction of the conntrack entry, which means we might iterate forever without making forward progress. This can happen in combination with the conntrack event cache, which holds a reference to the conntrack entry, which is only released when the packet makes it all the way through the stack or a different packet is handled. - taking references to an unconfirmed entry and using it outside the locked section doesn't work, the list entries are not refcounted and another CPU might already be waiting to destroy the entry What the code really wants to do is make sure the references of the hash table to the selected conntrack entries are released, so they will be destroyed once all references from skbs and the event cache are dropped. Since unconfirmed entries haven't even entered the hash yet, simply mark them as dying and skip confirmation based on that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09ATA: convert GSI to irq on ia64Zhang, Yanmin
If an ATA drive uses legacy mode, ata driver will choose 14 and 15 as the fixed irq number. On ia64 platform, such numbers are GSI and should be converted to irq vector. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09throttle_vm_writeout(): don't loop on GFP_NOFS and GFP_NOIO allocationsAndrew Morton
throttle_vm_writeout() is designed to wait for the dirty levels to subside. But if the caller holds IO or FS locks, we might be holding up that writeout. So change it to take a single nap to give other devices a chance to clean some memory, then return. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09lockdep: forward declare struct task_structHeiko Carstens
3117df0453828bd045c16244e6f50e5714667a8a causes this: In file included from arch/s390/kernel/early.c:13: include/linux/lockdep.h:300: warning: "struct task_struct" declared inside parameter list include/linux/lockdep.h:300: warning: its scope is only this definition or declaration, which is probably not what you want Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09ufs: restore back support of openstepEvgeniy Dushistov
This is a fix of regression, which triggered by ~2.6.16. Patch with name ufs-directory-and-page-cache-from-blocks-to-pages.patch: in additional to conversation from block to page cache mechanism added new checks of directory integrity, one of them that directory entry do not across directory chunks. But some kinds of UFS: OpenStep UFS and Apple UFS (looks like these are the same filesystems) have different directory chunk size, then common UFSes(BSD and Solaris UFS). So this patch adds ability to works with variable size of directory chunks, and set it for ufstype=openstep to right size. Tested on darwin ufs. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Revert "[PATCH] LOG2: Alter get_order() so that it can make use of ilog2() ↵Linus Torvalds
on a constant" Revert "[PATCH] LOG2: Alter get_order() so that it can make use of ilog2() on a constant" This reverts commit 39d61db0edb34d60b83c5e0d62d0e906578cc707. The commit was buggy in multiple ways: - the conversion to ilog2() was incorrect to begin with - it tested the wrong #defines, so on all architectures but FRV you'd never see the bug except for constant arguments. - the new "get_order()" macro used its arguments multiple times, and didn't even parenthesize them properly - despite the comments, it was not true that you could use it for constant initializers, since not all architectures even use the generic page.h header file. All of the problems are individually fixable, but it all boils down to: better just revert it, and re-do it from scratch. Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Andrew Morton <akpm@osdl.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09mmc: Power quirk for ENE controllersDarren Salt
mmc: Power quirk for ENE controllers Support for these devices was broken for 2.6.18-rc1 and later by commit 146ad66eac836c0b976c98f428d73e1f6a75270d, which added voltage level support. This restores the previous behaviour for these devices by ensuring that when the voltage is changed, only one write to set the voltage is performed. It may be that both writes are needed if the voltage is being changed between two non-zero values or that it's safe to ensure that only one write is done if the hardware only supports one voltage; I don't know whether either is the case nor can I test since I have only the one SD reader (1524:0550), and it supports just the one voltage. Signed-off-by: Darren Salt <linux@youmustbejoking.demon.co.uk> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09x86: Don't require the vDSO for handling a.out signalsAndi Kleen
x86: Don't require the vDSO for handling a.out signals and in other strange binfmts. vDSO is not necessarily mapped there. This fixes signals in a.out programs Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09x86_64: Fix wrong gcc check in bitops.hAndi Kleen
gcc 5.0 will likely not have the constraint problem Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Fix atmarp.h for userspaceDavid Miller
[ATM]: atmarp.h needs to always include linux/types.h To provide the __be* types, even for userspace includes. Reported by Andrew Walrond. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Fix recently introduced problem with shutting down a busy NFS server.NeilBrown
When the last thread of nfsd exits, it shuts down all related sockets. It currently uses svc_close_socket to do this, but that only is immediately effective if the socket is not SK_BUSY. If the socket is busy - i.e. if a request has arrived that has not yet been processes - svc_close_socket is not effective and the shutdown process spins. So create a new svc_force_close_socket which removes the SK_BUSY flag is set and then calls svc_close_socket. Also change some open-codes loops in svc_destroy to use list_for_each_entry_safe. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09md: Avoid possible BUG_ON in md bitmap handling.Neil Brown
md/bitmap tracks how many active write requests are pending on blocks associated with each bit in the bitmap, so that it knows when it can clear the bit (when count hits zero). The counter has 14 bits of space, so if there are ever more than 16383, we cannot cope. Currently the code just calles BUG_ON as "all" drivers have request queue limits much smaller than this. However is seems that some don't. Apparently some multipath configurations can allow more than 16383 concurrent write requests. So, in this unlikely situation, instead of calling BUG_ON we now wait for the count to drop down a bit. This requires a new wait_queue_head, some waiting code, and a wakeup call. Tested by limiting the counter to 20 instead of 16383 (writes go a lot slower in that case...). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff .prev/drivers/md/bitmap.c ./drivers/md/bitmap.c
2007-03-09knfsd: Fix a race in closing NFSd connections.NeilBrown
If you lose this race, it can iput a socket inode twice and you get a BUG in fs/inode.c When I added the option for user-space to close a socket, I added some cruft to svc_delete_socket so that I could call that function when closing a socket per user-space request. This was the wrong thing to do. I should have just set SK_CLOSE and let normal mechanisms do the work. Not only wrong, but buggy. The locking is all wrong and it openned up a race where-by a socket could be closed twice. So this patch: Introduces svc_close_socket which sets SK_CLOSE then either leave the close up to a thread, or calls svc_delete_socket if it can get SK_BUSY. Adds a bias to sk_busy which is removed when SK_DEAD is set, This avoid races around shutting down the socket. Changes several 'spin_lock' to 'spin_lock_bh' where the _bh was missing. Bugzilla-url: http://bugzilla.kernel.org/show_bug.cgi?id=7916 Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-03[PATCH] x86-64: define dma noncoherent API functionsJeff Garzik
x86-64 is missing these: Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[PATCH] alpha: fix epoll syscall enumerationsMike Frysinger
We went and named them __NR_sys_foo instead of __NR_foo. It may be too late to change this, but we can at least add the proper names now. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: Initialize nbytes for internal sg commands libata: Fix ata_busy_wait() kernel docs pata_via: Correct missing comments pata_atiixp: propogate cable detection hack from drivers/ide to the new driver ahci/pata_jmicron: fix JMicron quirk
