commit 9ecd1a75d977e2e8c48139c7d3efed183f898d94 upstream.
The maximum packet including header that can be handled by netfront / netback
wire format is 65535. Reduce gso_max_size accordingly.
Drop skb and print warning when skb->len > 65535. This can 1) save the effort
to send malformed packet to netback, 2) help spotting misconfiguration of
netfront in the future.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
commit 2810e5b9a7731ca5fce22bfbe12c96e16ac44b6f upstream.
This patch tries to coalesce tx requests when constructing grant copy
structures. It enables netback to deal with situation when frontend's
MAX_SKB_FRAGS is larger than backend's MAX_SKB_FRAGS.
With the help of coalescing, this patch tries to address two regressions
avoid reopening the security hole in XSA-39.
Regression 1. The reduction of the number of supported ring entries (slots)
per packet (from 18 to 17). This regression has been around for some time but
remains unnoticed until XSA-39 security fix. This is fixed by coalescing
slots.
Regression 2. The XSA-39 security fix turning "too many frags" errors from
just dropping the packet to a fatal error and disabling the VIF. This is fixed
by coalescing slots (handling 18 slots when backend's MAX_SKB_FRAGS is 17)
which rules out false positive (using 18 slots is legit) and dropping packets
using 19 to `max_skb_slots` slots.
To avoid reopening security hole in XSA-39, frontend sending packet using more
than max_skb_slots is considered malicious.
The behavior of netback for packet is thus:
1-18 slots: valid
19-max_skb_slots slots: drop and respond with an error
max_skb_slots+ slots: fatal error
max_skb_slots is configurable by admin, default value is 20.
Also change variable name from "frags" to "slots" in netbk_count_requests.
Please note that RX path still has dependency on MAX_SKB_FRAGS. This will be
fixed with separate patch.
commit 9b31a328e344e62e7cc98ae574edcb7b674719bb upstream.
Switch back to pre commit 1c7b13fe652 list splicing logic for active I/O
shutdown with tcm_qla2xxx + ib_srpt fabrics.
The original commit was done under the incorrect assumption that it's safe to
walk se_sess->sess_cmd_list unprotected in target_wait_for_sess_cmds() after
sess->sess_tearing_down = 1 has been set by target_sess_cmd_list_set_waiting()
during session shutdown.
So instead of adding sess->sess_cmd_lock protection around sess->sess_cmd_list
during target_wait_for_sess_cmds(), switch back to sess->sess_wait_list to
allow wait_for_completion() + TFO->release_cmd() to occur without having to
walk ->sess_cmd_list after the list_splice.
Also add a check to exit if target_sess_cmd_list_set_waiting() has already
been called, and add a WARN_ON to check for any fabric bug where new se_cmds
are added to sess->sess_cmd_list after sess->sess_tearing_down = 1 has already
been set.
Cc: Joern Engel <joern@logfs.org>
Cc: Roland Dreier <roland@kernel.org>
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
commit ec4602a9588a196fa1a9af46bfdd37cbf5792db4 upstream.
Currently, drivers/acpi/device_pm.c depends on CONFIG_PM and all of
the functions defined in there are replaced with static inline stubs
if that option is unset. However, CONFIG_PM means, roughly, "runtime
PM or suspend/hibernation support" and some of those functions are
useful regardless of that. For example, they are used by the ACPI
fan driver for controlling fans and acpi_device_set_power() is called
during device removal. Moreover, device initialization may depend on
setting device power states properly.
For these reasons, make the routines manipulating ACPI device power
states defined in drivers/acpi/device_pm.c available for CONFIG_PM
unset too.
Reported-by: Zhang Rui <rui.zhang@intel.com>
Reported-and-tested-by: Michel Lespinasse <walken@google.com>
commit 7805d000db30a3787a4c969bab6ae4d8a5fd8ce6 upstream.
When cgroup_next_descendant_pre() initiates a walk, it checks whether
the subtree root doesn't have any children and if not returns NULL.
Later code assumes that the subtree isn't empty. This is broken
because the subtree may become empty inbetween, which can lead to the
traversal escaping the subtree by walking to the sibling of the
subtree root.
There's no reason to have the early exit path. Remove it along with
the later assumption that the subtree isn't empty. This simplifies
the code a bit and fixes the subtle bug.
While at it, fix the comment of cgroup_for_each_descendant_pre() which
was incorrectly referring to ->css_offline() instead of
->css_online().
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream.
Many callers of the wait_event_timeout() and
wait_event_interruptible_timeout() expect that the return value will be
positive if the specified condition becomes true before the timeout
elapses. However, at the moment this isn't guaranteed. If the wake-up
handler is delayed enough, the time remaining until timeout will be
calculated as 0 - and passed back as a return value - even if the
condition became true before the timeout has passed.
Fix this by returning at least 1 if the condition becomes true. This
semantic is in line with what wait_for_condition_timeout() does; see
commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious
failure under heavy load").
Daniel said "We have 3 instances of this bug in drm/i915. One case even
where we switch between the interruptible and not interruptible
wait_event_timeout variants, foolishly presuming they have the same
semantics. I very much like this."
One such bug is reported at
https://bugs.freedesktop.org/show_bug.cgi?id=64133
Signed-off-by: Imre Deak <imre.deak@intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Lukas Czerner <lczerner@redhat.com>
commit 6407d75afd08545f2252bb39806ffd3f10c7faac upstream.
uapi should use __u32 not u32.
Fix a macro in virtio_console.h which uses u32.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 780a7654cee8d61819512385e778e4827db4bfbc upstream.
audit rule additions containing "-F auid!=4294967295" were failing
with EINVAL because of a regression caused by e1760bd.
Apparently some userland audit rule sets want to know if loginuid uid
has been set and are using a test for auid != 4294967295 to determine
that.
In practice that is a horrible way to ask if a value has been set,
because it relies on subtle implementation details and will break
every time the uid implementation in the kernel changes.
So add a clean way to test if the audit loginuid has been set, and
silently convert the old idiom to the cleaner and more comprehensible
new idiom.
RGB notes: In upstream, audit_rule_to_entry has been refactored out.
This is patch is already upstream in functionally the same form in
commit 780a7654cee8d61819512385e778e4827db4bfbc . The decimal constant
was cast to unsigned to quiet GCC 4.6 32-bit architecture warnings.
Reported-By: Steve Grubb <sgrubb@redhat.com>
Tested-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Backported-by: Richard Guy Briggs <rgb@redhat.com>
commit ccf5ae83a6cf3d9cfe9a7038bfe7cd38ab03d5e1 upstream.
It is possible for one thread to to take se_sess->sess_cmd_lock in
core_tmr_abort_task() before taking a reference count on
se_cmd->cmd_kref, while another thread in target_put_sess_cmd() drops
se_cmd->cmd_kref before taking se_sess->sess_cmd_lock.
This introduces kref_put_spinlock_irqsave() and uses it in
target_put_sess_cmd() to close the race window.
Signed-off-by: Joern Engel <joern@logfs.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ]
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ]
Protect the SIOCGCM* ioctl macros with parenthesis.
Reported-by: Paul Wouters <pwouters@redhat.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ Upstream commit b56141ab34e2c3e2d7960cea12c20c99530c0c76 ]
This patch fixes race between inet_frag_lru_move() and inet_frag_lru_add()
which was introduced in commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206
("net: frag, move LRU list maintenance outside of rwlock")
One cpu already added new fragment queue into hash but not into LRU.
Other cpu found it in hash and tries to move it to the end of LRU.
This leads to NULL pointer dereference inside of list_move_tail().
Another possible race condition is between inet_frag_lru_move() and
inet_frag_lru_del(): move can happens after deletion.
This patch initializes LRU list head before adding fragment into hash and
inet_frag_lru_move() doesn't touches it if it's empty.
I saw this kernel oops two times in a couple of days.
[119482.128853] BUG: unable to handle kernel NULL pointer dereference at (null)
[119482.132693] IP: [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.136456] PGD 2148f6067 PUD 215ab9067 PMD 0
[119482.140221] Oops: 0000 [#1] SMP
[119482.144008] Modules linked in: vfat msdos fat 8021q fuse nfsd auth_rpcgss nfs_acl nfs lockd sunrpc ppp_async ppp_generic bridge slhc stp llc w83627ehf hwmon_vid snd_hda_codec_hdmi snd_hda_codec_realtek kvm_amd k10temp kvm snd_hda_intel snd_hda_codec edac_core radeon snd_hwdep ath9k snd_pcm ath9k_common snd_page_alloc ath9k_hw snd_timer snd soundcore drm_kms_helper ath ttm r8169 mii
[119482.152692] CPU 3
[119482.152721] Pid: 20, comm: ksoftirqd/3 Not tainted 3.9.0-zurg-00001-g9f95269 #132 To Be Filled By O.E.M. To Be Filled By O.E.M./RS880D
[119482.161478] RIP: 0010:[<ffffffff812ede89>] [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.166004] RSP: 0018:ffff880216d5db58 EFLAGS: 00010207
[119482.170568] RAX: 0000000000000000 RBX: ffff88020882b9c0 RCX: dead000000200200
[119482.175189] RDX: 0000000000000000 RSI: 0000000000000880 RDI: ffff88020882ba00
[119482.179860] RBP: ffff880216d5db58 R08: ffffffff8155c7f0 R09: 0000000000000014
[119482.184570] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88020882ba00
[119482.189337] R13: ffffffff81c8d780 R14: ffff880204357f00 R15: 00000000000005a0
[119482.194140] FS: 00007f58124dc700(0000) GS:ffff88021fcc0000(0000) knlGS:0000000000000000
[119482.198928] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[119482.203711] CR2: 0000000000000000 CR3: 00000002155f0000 CR4: 00000000000007e0
[119482.208533] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[119482.213371] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[119482.218221] Process ksoftirqd/3 (pid: 20, threadinfo ffff880216d5c000, task ffff880216d3a9a0)
[119482.223113] Stack:
[119482.228004] ffff880216d5dbd8 ffffffff8155dcda 0000000000000000 ffff000200000001
[119482.233038] ffff8802153c1f00 ffff880000289440 ffff880200000014 ffff88007bc72000
[119482.238083] 00000000000079d5 ffff88007bc72f44 ffffffff00000002 ffff880204357f00
[119482.243090] Call Trace:
[119482.248009] [<ffffffff8155dcda>] ip_defrag+0x8fa/0xd10
[119482.252921] [<ffffffff815a8013>] ipv4_conntrack_defrag+0x83/0xe0
[119482.257803] [<ffffffff8154485b>] nf_iterate+0x8b/0xa0
[119482.262658] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.267527] [<ffffffff815448e4>] nf_hook_slow+0x74/0x130
[119482.272412] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40
[119482.277302] [<ffffffff8155d068>] ip_rcv+0x268/0x320
[119482.282147] [<ffffffff81519992>] __netif_receive_skb_core+0x612/0x7e0
[119482.286998] [<ffffffff81519b78>] __netif_receive_skb+0x18/0x60
[119482.291826] [<ffffffff8151a650>] process_backlog+0xa0/0x160
[119482.296648] [<ffffffff81519f29>] net_rx_action+0x139/0x220
[119482.301403] [<ffffffff81053707>] __do_softirq+0xe7/0x220
[119482.306103] [<ffffffff81053868>] run_ksoftirqd+0x28/0x40
[119482.310809] [<ffffffff81074f5f>] smpboot_thread_fn+0xff/0x1a0
[119482.315515] [<ffffffff81074e60>] ? lg_local_lock_cpu+0x40/0x40
[119482.320219] [<ffffffff8106d870>] kthread+0xc0/0xd0
[119482.324858] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.329460] [<ffffffff816c32dc>] ret_from_fork+0x7c/0xb0
[119482.334057] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40
[119482.338661] Code: 00 00 55 48 8b 17 48 b9 00 01 10 00 00 00 ad de 48 8b 47 08 48 89 e5 48 39 ca 74 29 48 b9 00 02 20 00 00 00 ad de 48 39 c8 74 7a <4c> 8b 00 4c 39 c7 75 53 4c 8b 42 08 4c 39 c7 75 2b 48 89 42 08
[119482.343787] RIP [<ffffffff812ede89>] __list_del_entry+0x29/0xd0
[119482.348675] RSP <ffff880216d5db58>
[119482.353493] CR2: 0000000000000000
Oops happened on this path:
ip_defrag() -> ip_frag_queue() -> inet_frag_lru_move() -> list_move_tail() -> __list_del_entry()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Eric Dumazet <edumazet@google.com>
Acked-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 77d21f23a1e4db8639e3916547c903a3b3c7a07c ]
Programs using virtio headers outside of kernel will no longer
build because u16 type does not exist in userspace. All user ABI
must use __u16 typedef instead.
Bug introduce by:
commit 986a4f4d452dec004697f667439d27c3fda9c928
Author: Jason Wang <jasowang@redhat.com>
Date: Fri Dec 7 07:04:56 2012 +0000
virtio_net: multiqueue support
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ]
Before escaping RCU protected section and adding packet into
prequeue, make sure the dst is refcounted.
Reported-by: Mike Galbraith <bitbucket@online.de>
commit b4f711ee03d28f776fd2324fd0bd999cc428e4d2 upstream.
Kay Sievers noted that the ALWAYS_USE_PERSISTENT_CLOCK config,
which enables some minor compile time optimization to avoid
uncessary code in mostly the suspend/resume path could cause
problems for userland.
In particular, the dependency for RTC_HCTOSYS on
!ALWAYS_USE_PERSISTENT_CLOCK, which avoids setting the time
twice and simplifies suspend/resume, has the side effect
of causing the /sys/class/rtc/rtcN/hctosys flag to always be
zero, and this flag is commonly used by udev to setup the
/dev/rtc symlink to /dev/rtcN, which can cause pain for
older applications.
While the udev rules could use some work to be less fragile,
breaking userland should strongly be avoided. Additionally
the compile time optimizations are fairly minor, and the code
being optimized is likely to be reworked in the future, so
lets revert this change.
Reported-by: Kay Sievers <kay@vrfy.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Feng Tang <feng.tang@intel.com>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Link: http://lkml.kernel.org/r/1366828376-18124-1-git-send-email-john.stultz@linaro.org
commit cdee3904b4ce7c03d1013ed6dd704b43ae7fc2e9 upstream.
Commit b05d8447e782 (audit: inline audit_syscall_entry to reduce
burden on archs) changed audit_syscall_entry to check for a dummy
context before calling __audit_syscall_entry. Unfortunately the dummy
context state is maintained in __audit_syscall_entry so once set it
never gets cleared, even if the audit rules change.
As a result, if there are no auditing rules when a process starts
then it will never be subject to any rules added later. x86 doesn't
see this because it has an assembly fast path that calls directly into
I noticed this issue when working on audit performance optimisations.
I wrote a set of simple test cases available at:
http://ozlabs.org/~anton/junkcode/audit_tests.tar.gz
02_new_rule.py fails without the patch and passes with it. The
test case clears all rules, starts a process, adds a rule then
verifies the process produces a syscall audit record.
commit f3002134158092178be81339ec5a22ff80e6c308 upstream.
This reverts commit f792685006274a850e6cc0ea9ade275ccdfc90bc.
The cputime scaling code was changed/fixed and does not need the
div64_u64_rem() primitive anymore. It has no other users, so let's
remove them.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: rostedt@goodmis.org
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/1367314507-9728-4-git-send-email-sgruszka@redhat.com
commit f792685006274a850e6cc0ea9ade275ccdfc90bc upstream.
Provide an extended version of div64_u64() that
also returns the remainder of the division.
We are going to need this to refine the cputime
scaling code.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 18932a28419596bc9403770f5d8a108c5433fe59 upstream.
commit 219b47339ced80ca580bb6ce7d1636166984afa7 upstream.
Currently we have a problem with this:
1. i915: create gem object
2. i915: export gem object to prime
3. radeon: import gem object
4. close prime fd
5. radeon: unref object
6. i915: unref object
i915 has an imported object reference in its file priv, that isn't
cleaned up properly until fd close. The reference gets added at step 2,
but at step 6 we don't have enough info to clean it up.
The solution is to take a reference on the dma-buf when we export it,
and drop the reference when the gem handle goes away.
So when we export a dma_buf from a gem object, we keep track of it
with the handle, we take a reference to the dma_buf. When we close
the handle (i.e. userspace is finished with the buffer), we drop
the reference to the dma_buf, and it gets collected.
This patch isn't meant to fix any other problem or bikesheds, and it doesn't
fix any races with other scenarios.
v1.1: move export symbol line back up.
v2: okay I had to do a bit more, as the first patch showed a leak
on one of my tests, that I found using the dma-buf debugfs support,
the problem case is exporting a buffer twice with the same handle,
we'd add another export handle for it unnecessarily, however
we now fail if we try to export the same object with a different gem handle,
however I'm not sure if that is a case I want to support, and I've
gotten the code to WARN_ON if we hit something like that.
v2.1: rebase this patch, write better commit msg.
v3: cleanup error handling, track import vs export in linked list,
these two patches were separate previously, but seem to work better
like this.
v4: danvet is correct, this code is no longer useful, since the buffer
better exist, so remove it.
v5: always take a reference to the dma buf object, import or export.
(Imre Deak contributed this originally)
v6: square the circle, remove import vs export tracking now
that there is no difference
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 871dd9286e25330c8a581e5dacfa8b1dfe1dd641 upstream.
linux-v3.8-rc1 and later support for plug for blkdev_issue_discard with
commit 0cfbcafcae8b7364b5fa96c2b26ccde7a3a296a9
(block: add plug for blkdev_issue_discard )
For example,
1) DISCARD rq-1 with size size 4GB
2) DISCARD rq-2 with size size 1GB
If these 2 discard requests get merged, final request size will be 5GB.
In this case, request's __data_len field may overflow as it can store
max 4GB(unsigned int).
This issue was observed while doing mkfs.f2fs on 5GB SD card:
https://lkml.org/lkml/2013/4/1/292
Info: sector size = 512
Info: total sectors = 11370496 (in 512bytes)
Info: zone aligned segment0 blkaddr: 512
[ 257.789764] blk_update_request: bio idx 0 >= vcnt 0
mkfs process gets stuck in D state and I see the following in the dmesg:
[ 257.789733] __end_that: dev mmcblk0: type=1, flags=122c8081
[ 257.789764] sector 4194304, nr/cnr 2981888/4294959104
[ 257.789764] bio df3840c0, biotail df3848c0, buffer (null), len
1526726656
[ 257.794921] request botched: dev mmcblk0: type=1, flags=122c8081
[ 257.794921] sector 4194304, nr/cnr 2981888/4294959104
[ 257.794921] bio df3840c0, biotail df3848c0, buffer (null), len
1526726656
This patch fixes this issue.
Reported-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Tested-by: Max Filippov <jcmvbkbc@gmail.com>
commit af73e4d9506d3b797509f3c030e7dcd554f7d9c4 upstream.
The current kernel returns -EINVAL unless a given mmap length is
"almost" hugepage aligned. This is because in sys_mmap_pgoff() the
given length is passed to vm_mmap_pgoff() as it is without being aligned
with hugepage boundary.
This is a regression introduced in commit 40716e29243d ("hugetlbfs: fix
alignment of huge page requests"), where alignment code is pushed into
hugetlb_file_setup() and the variable len in caller side is not changed.
To fix this, this patch partially reverts that commit, and adds
alignment code in caller side. And it also introduces hstate_sizelog()
in order to get proper hstate to specified hugepage size.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=56881
[akpm@linux-foundation.org: fix warning when CONFIG_HUGETLB_PAGE=n]
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: <iceman_dvd@yahoo.com>
Cc: Steven Truelove <steven.truelove@utoronto.ca>
Cc: Jianguo Wu <wujianguo@huawei.com>
commit 794446c6946513c684d448205fbd76fa35f38b72 upstream.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit d76a3a77113db020d9bb1e894822869410450bd9 upstream.
In the case where an inode has a very stale transaction id (tid) in
i_datasync_tid or i_sync_tid, it's possible that after a very large
(2**31) number of transactions, that the tid number space might wrap,
causing tid_geq()'s calculations to fail.
Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified
by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily",
attempted to fix this problem, but it only avoided kjournald spinning
forever by fixing the logic in jbd2_log_start_commit().
Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c
that might call jbd2_log_start_commit() with a stale tid, those
functions will subsequently call jbd2_log_wait_commit() with the same
stale tid, and then wait for a very long time. To fix this, we
replace the calls to jbd2_log_start_commit() and
jbd2_log_wait_commit() with a call to a new function,
jbd2_complete_transaction(), which will correctly handle stale tid's.
As a bonus, jbd2_complete_transaction() will avoid locking
j_state_lock for writing unless a commit needs to be started. This
should have a small (but probably not measurable) improvement for
ext4's scalability.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reported-by: George Barnett <gbarnett@atlassian.com>
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream.
Trying to run an application which was trying to put data into half of
memory using shmget(), we found that having a shmall value below 8EiB-8TiB
would prevent us from using anything more than 8TiB. By setting
kernel.shmall greater than 8EiB-8TiB would make the job work.
In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX.
ipc/shm.c:
458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params)
459 {
465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT;
474 if (ns->shm_tot + numpages > ns->shm_ctlall)
475 return -ENOSPC;
[akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int]
Signed-off-by: Robin Holt <holt@sgi.com>
Reported-by: Alex Thorlton <athorlton@sgi.com>
commit e56fb2874015370e3b7f8d85051f6dce26051df9 upstream.
threadgroup_lock() takes signal->cred_guard_mutex to ensure that
thread_group_leader() is stable. This doesn't look nice, the scope of
this lock in do_execve() is huge.
And as Dave pointed out this can lead to deadlock, we have the
following dependencies:
do_execve: cred_guard_mutex -> i_mutex
cgroup_mount: i_mutex -> cgroup_mutex
attach_task_by_pid: cgroup_mutex -> cred_guard_mutex
Change de_thread() to take threadgroup_change_begin() around the
switch-the-leader code and change threadgroup_lock() to avoid
->cred_guard_mutex.
Note that de_thread() can't sleep with ->group_rwsem held, this can
obviously deadlock with the exiting leader if the writer is active, so it
does threadgroup_change_end() before schedule().
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Li Zefan <lizefan@huawei.com>
commit 712317ad97f41e738e1a19aa0a6392a78a84094e upstream.
We should store file xattrs in struct cfent instead of struct cftype,
because cftype is a type while cfent is object instance of cftype.
For example each cgroup has a tasks file, and each tasks file is
associated with a uniq cfent, but all those files share the same
struct cftype.
Alexey Kodanev reported a crash, which can be reproduced:
# mount -t cgroup -o xattr /sys/fs/cgroup
# mkdir /sys/fs/cgroup/test
# setfattr -n trusted.value -v test_value /sys/fs/cgroup/tasks
# rmdir /sys/fs/cgroup/test
# umount /sys/fs/cgroup
oops!
In this case, simple_xattrs_free() will free the same struct simple_xattrs
twice.
tj: Dropped unused local variable @cft from cgroup_diput().
Reported-by: Alexey Kodanev <alexey.kodanev@oracle.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit e08b34e86dfdb72a62196ce0f03d33f48958d8b9 upstream.
The commit [b209c4df: ALSA: emu10k1: cache emu1010 firmware] broke the
firmware loading of the dock, just (mistakenly) ignoring a different
firmware for docks on some models. This patch revives them again.
Bugzilla: https://bugs.archlinux.org/task/34865
Reported-and-tested-by: Tobias Powalowski <tobias.powalowski@googlemail.com>
commit 6ee8630e02be6dd89926ca0fbc21af68b23dc087 upstream.
On architectures where a pgd entry may be shared between user and kernel
(e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0.
This patch introduces a generic USER_PGTABLES_CEILING that arch code can
override. It is the responsibility of the arch code setting the ceiling
to ensure the complete freeing of the page tables (usually in
pgd_free()).
[catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes]
Pull kdump fixes from Peter Anvin:
"The kexec/kdump people have found several problems with the support
for loading over 4 GiB that was introduced in this merge cycle. This
is partly due to a number of design problems inherent in the way the
various pieces of kdump fit together (it is pretty horrifically manual
in many places.)
After a *lot* of iterations this is the patchset that was agreed upon,
but of course it is now very late in the cycle. However, because it
changes both the syntax and semantics of the crashkernel option, it
would be desirable to avoid a stable release with the broken
interfaces."
I'm not happy with the timing, since originally the plan was to release
the final 3.9 tomorrow. But apparently I'm doing an -rc8 instead...
* 'x86-kdump-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kexec: use Crash kernel for Crash kernel low
x86, kdump: Change crashkernel_high/low= to crashkernel=,high/low
x86, kdump: Retore crashkernel= to allocate under 896M
x86, kdump: Set crashkernel_low automatically
Pull x86 fixes from Peter Anvin:
"Three groups of fixes:
1. Make sure we don't execute the early microcode patching if family
< 6, since it would touch MSRs which don't exist on those
families, causing crashes.
2. The Xen partial emulation of HyperV can be dealt with more
gracefully than just disabling the driver.
3. More EFI variable space magic. In particular, variables hidden
from runtime code need to be taken into account too."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode: Verify the family before dispatching microcode patching
x86, hyperv: Handle Xen emulation of Hyper-V more gracefully
x86,efi: Implement efi_no_storage_paranoia parameter
efi: Export efi_query_variable_store() for efivars.ko
x86/Kconfig: Make EFI select UCS2_STRING
efi: Distinguish between "remaining space" and actually used space
efi: Pass boot services variable info to runtime code
Move utf16 functions to kernel core and rename
x86,efi: Check max_size only if it is non-zero.
x86, efivars: firmware bug workarounds should be in platform code
Pull networking updates from David Miller:
1) ax88796 does 64-bit divides which causes link errors on ARM, fix
from Arnd Bergmann.
2) Once an improper offload setting is detected on an SKB we don't rate
limit the log message so we can very easily live lock. From Ben
Greear.
3) Openvswitch cannot report vport configuration changes reliably
because it didn't preallocate the netlink notification message
before changing state. From Jesse Gross.
4) The effective UID/GID SCM credentials fix, from Linus.
5) When a user explicitly asks for wireless authentication, cfg80211
isn't told about the AP detachment leaving inconsistent state. Fix
from Johannes Berg.
6) Fix self-MAC checks in batman-adv on multi-mesh nodes, from Antonio
Quartulli.
7) Revert build_skb() change sin IGB driver, can result in memory
corruption. From Alexander Duyck.
8) Fix setting VLANs on virtual functions in IXGBE, from Greg Rose.
9) Fix TSO races in qlcnic driver, from Sritej Velaga.
10) In bnx2x the kernel driver and UNDI firmware can try to program the
chip at the same time, resulting in corruption. Add proper
synchronization. From Dmitry Kravkov.
11) Fix corruption of status block in firmware ram in bxn2x, from Ariel
Elior.
12) Fix load balancing hash regression of bonding driver in forwarding
configurations, from Eric Dumazet.
13) Fix TS ECR regression in TCP by calling tcp_replace_ts_recent() in
all the right spots, from Eric Dumazet.
14) Fix several bonding bugs having to do with address manintainence,
including not removing address when configuration operations
encounter errors, missed locking on the address lists, missing
refcounting on VLAN objects, etc. All from Nikolay Aleksandrov.
15) Add workarounds for firmware bugs in LTE qmi_wwan devices, wherein
the devices fail to add a proper ethernet header while on LTE
networks but otherwise properly do so on 2G and 3G ones. From Bjørn
Mork.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits)
net: fix incorrect credentials passing
net: rate-limit warn-bad-offload splats.
net: ax88796: avoid 64 bit arithmetic
qlge: Update version to 1.00.00.32.
qlge: Fix ethtool autoneg advertising.
qlge: Fix receive path to drop error frames
net: qmi_wwan: prevent duplicate mac address on link (firmware bug workaround)
net: qmi_wwan: fixup destination address (firmware bug workaround)
net: qmi_wwan: fixup missing ethernet header (firmware bug workaround)
bonding: in bond_mc_swap() bond's mc addr list is walked without lock
bonding: disable netpoll on enslave failure
bonding: primary_slave & curr_active_slave are not cleaned on enslave failure
bonding: vlans don't get deleted on enslave failure
bonding: mc addresses don't get deleted on enslave failure
pkt_sched: fix error return code in fw_change_attrs()
irda: small read past the end of array in debug code
tcp: call tcp_replace_ts_recent() from tcp_ack()
netfilter: xt_rpfilter: skip locally generated broadcast/multicast, too
netfilter: ipset: bitmap:ip,mac: fix listing with timeout
bonding: fix l23 and l34 load balancing in forwarding path
Commit 257b5358b32f ("scm: Capture the full credentials of the scm
sender") changed the credentials passing code to pass in the effective
uid/gid instead of the real uid/gid.
Obviously this doesn't matter most of the time (since normally they are
the same), but it results in differences for suid binaries when the wrong
uid/gid ends up being used.
This just undoes that (presumably unintentional) part of the commit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Cc: stable@vger.kernel.org
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Matt Fleming (1):
code
Matthew Garrett (3):
space
Richard Weinberger (2):
Sergey Vlasov (2):
The "reason" can come from skb->data[] and it hasn't been capped so it
can be from 0-255 instead of just 0-6. For example in irlmp_state_dtr()
the code does:
reason = skb->data[3];
irlmp_disconnect_indication(self, reason, skb);
Also LMREASON has a couple other values which don't have entries in the
irlmp_reasons[] array. And 0xff is a valid reason as well which means
"unknown".
So far as I can see we don't actually care about "reason" except for in
the debug code.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse build fix from Miklos Szeredi:
"This fixes android builds. The patch appears large, but is just
search & replace."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: fix type definitions in uapi header
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
This reverts commit 3a366e614d0837d9fc23f78cdb1a1186ebc3387f.
Wanlong Gao reports that it causes a kernel panic on his machine several
minutes after boot. Reverting it removes the panic.
Jens says:
"It's not quite clear why that is yet, so I think we should just revert
the commit for 3.9 final (which I'm assuming is pretty close).
The wifi is crap at the LSF hotel, so sending this email instead of
queueing up a revert and pull request."
Reported-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Requested-by: Jens Axboe <axboe@kernel.dk>
Cc: Tejun Heo <tj@kernel.org>
Vivek found old kexec-tools does not work new kernel anymore.
So change back crashkernel= back to old behavoir, and add crashkernel_high=
to let user decide if buffer could be above 4G, and also new kexec-tools will
be needed.
-v2: let crashkernel=X override crashkernel_high=
update description about _high will be ignored by crashkernel=X
-v3: update description about kernel-parameters.txt according to Vivek.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1366089828-19692-4-git-send-email-yinghai@kernel.org
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Chao said that kdump does does work well on his system on 3.8
without extra parameter, even iommu does not work with kdump.
And now have to append crashkernel_low=Y in first kernel to make
kdump work.
We have now modified crashkernel=X to allocate memory beyong 4G (if
available) and do not allocate low range for crashkernel if the user
does not specify that with crashkernel_low=Y. This causes regression
if iommu is not enabled. Without iommu, swiotlb needs to be setup in
first 4G and there is no low memory available to second kernel.
Set crashkernel_low automatically if the user does not specify that.
For system that does support IOMMU with kdump properly, user could
specify crashkernel_low=0 to save that 72M low ram.
-v3: add swiotlb_size() according to Konrad.
-v4: add comments what 8M is for according to hpa.
also update more crashkernel_low= in kernel-parameters.txt
-v5: update changelog according to Vivek.
-v6: Change description about swiotlb referring according to HATAYAMA.
Reported-by: WANG Chao <chaowang@redhat.com>
Tested-by: WANG Chao <chaowang@redhat.com>
Link: http://lkml.kernel.org/r/1366089828-19692-2-git-send-email-yinghai@kernel.org
Pull networking fixes from David Miller:
1) Fix erroneous netfilter drop of SIP packets generated by some Cisco
phones, from Patrick McHardy.
2) Fix netfilter IPSET refcounting in list_set_add(), from Jozsef
Kadlecsik.
3) Fix TCP syncookies route lookup key, we don't use the same values we
would use for the usual SYN receive processing, from Dmitry Popov.
4) Fix NULL deref in bond_slave_netdev_event(), from Nikolay
Aleksandrov.
5) When bonding enslave fails, we can forget to clear the IFF_BONDING
bit, fix also from Nikolay Aleksandrov.
6) skb->csum_start is 16-bits, which is almost always just fine. But
if we reallocate the headroom of an SKB this can push the
skb->csum_start value outside of it's valid range. This can easily
happen when collapsing multiple SKBs from the retransmit queue
together.
Fix from Thomas Graf.
7) Fix NULL deref in be2net driver due to missing check of
__vlan_put_tag() return value, from Ivan Vecera.
8) tun_set_iff() returns zero instead of error code on failure, fix
from Wei Yongjun.
9) Like GARP, 802 MRP needs to hold the app->lock when adding MAD
events and queueing PDUs. Fix from David Ward.
10) Build fix, MVMDIO needs PHYLIB, from Thomas Petazzoni..
11) Fix mac80211 static with ipv6 modular build, from Cong Wang.
12) If userland specifies a path cost explicitly, do not override it
when the carrier state changes. From Stephen Hemminger.
13) mvnets calculates the TX queue to use incorrectly resulting in
garbage pointer derefs and crashes, fix from Willy Tarreau.
14) cdc_mbim does erroneous sizeof(ETH_HLEN). Fix from Bjorn Mork.
15) IP fragmentation can leak a refcount-less route out from an RCU
protected section. This results in crashes and all sorts of hard to
diagnose behavior. Fix from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (24 commits)
qlcnic: fix beaconing test for 82xx adapter
net: drop dst before queueing fragments
net: fec: fix regression in link change accounting
net: cdc_mbim: remove bogus sizeof()
drivers: net: ethernet: cpsw: get slave VLAN id from slave node instead of cpsw node
net: mvneta: fix improper tx queue usage in mvneta_tx()
esp4: fix error return code in esp_output()
bridge: make user modified path cost sticky
ipv6: statically link register_inet6addr_notifier()
net: mvmdio: add select PHYLIB
net/802/mrp: fix possible race condition when calling mrp_pdu_queue()
tuntap: fix error return code in tun_set_iff()
be2net: take care of __vlan_put_tag return value
can: sja1000: fix handling on dt properties on little endian systems
can: mcp251x: add missing IRQF_ONESHOT to request_threaded_irq
netfilter: nf_nat: fix race when unloading protocol modules
tcp: Reallocate headroom if it would overflow csum_start
stmmac: prevent interrupt loop with MMC RX IPC Counter
bonding: IFF_BONDING is not stripped on enslave failure
bonding: fix netdev event NULL pointer dereference
Commit 7e98d53086d18c877cb44e9065219335184024de (Synchronize fuse header with
one used in library) added #ifdef __linux__ around defines if it is not set.
The kernel build is self-contained and can be built on non-Linux toolchains.
After the mentioned commit builds on non-Linux toolchains will try to include
stdint.h and fail due to -nostdinc, and then fail with a bunch of undefined type
errors.
Fix by checking for __KERNEL__ instead of __linux__ and using the standard int
types instead of the linux specific ones.
Reported-by: Arve Hjønnevåg <arve@android.com>
Reported-by: Colin Cross <ccross@android.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
We want to be able to use the utf16 functions that are currently present
in the EFI variables code in platform-specific code as well. Move them to
the kernel core, and in the process rename them to accurately describe what
they do - they don't handle UTF16, only UCS2.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull {timer,irq,core} fixes from Thomas Gleixner:
- timer: bug fix for a cpu hotplug race.
- irq: single bugfix for a wrong return value, which prevents the
calling function to invoke the software fallback.
- core: bugfix which plugs two race confitions which can cause hotplug
per cpu threads to end up on the wrong cpu.
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
hrtimer: Don't reinitialize a cpu_base lock on CPU_UP
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: gic: fix irq_trigger return
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kthread: Prevent unpark race which puts threads on the wrong cpu
Tomas reported the following build error:
net/built-in.o: In function `ieee80211_unregister_hw':
(.text+0x10f0e1): undefined reference to `unregister_inet6addr_notifier'
net/built-in.o: In function `ieee80211_register_hw':
(.text+0x10f610): undefined reference to `register_inet6addr_notifier'
make: *** [vmlinux] Error 1
when built IPv6 as a module.
So we have to statically link these symbols.
Reported-by: Tomas Melin <tomas.melin@iki.fi>
Cc: Tomas Melin <tomas.melin@iki.fi>
Cc: YOSHIFUJI Hidaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Cong Wang <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull ftrace fixes from Steven Rostedt:
"Namhyung Kim found and fixed a bug that can crash the kernel by simply
doing: echo 1234 | tee -a /sys/kernel/debug/tracing/set_ftrace_pid
Luckily, this can only be done by root, but still is a nasty bug."
* tag 'trace-fixes-v3.9-rc-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE section
tracing: Fix possible NULL pointer dereferences
Nothing is using it yet, but this will allow us to delay the open-time
checks to use time, without breaking the normal UNIX permission
semantics where permissions are determined by the opener (and the file
descriptor can then be passed to a different process, or the process can
drop capabilities).
This patch attempts to fix:
https://bugzilla.kernel.org/show_bug.cgi?id=56461
The symptom is a crash and messages like this:
chrome: Corrupted page table at address 34a03000
*pdpt = 0000000000000000 *pde = 0000000000000000
Bad pagetable: 000f [#1] PREEMPT SMP
Ingo guesses this got introduced by commit 611ae8e3f520 ("x86/tlb:
enable tlb flush range support for x86") since that code started to free
unused pagetables.
On x86-32 PAE kernels, that new code has the potential to free an entire
PMD page and will clear one of the four page-directory-pointer-table
(aka pgd_t entries).
The hardware aggressively "caches" these top-level entries and invlpg
does not actually affect the CPU's copy. If we clear one we *HAVE* to
do a full TLB flush, otherwise we might continue using a freed pmd page.
(note, we do this properly on the population side in pud_populate()).
This patch tracks whenever we clear one of these entries in the 'struct
mmu_gather', and ensures that we follow up with a full tlb flush.
BTW, I disassembled and checked that:
if (tlb->fullmm == 0)
and
if (!tlb->fullmm && !tlb->need_flush_all)
generate essentially the same code, so there should be zero impact there
to the !PAE case.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Artem S Tashkinov <t.artem@mailcity.com>
