commit 0dc6f20b9803f09726bbb682649d35cda8ef5b5d upstream.
When reviewing patch that fixes VGA on BDW Halo Jani noticed that
we also had other ULT IDs that weren't listed there.
So this follow-up patch add these pci-ids as halo and fix comments
on i915_pciids.h
Cc: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit bc4b1f486fe69b86769e07c8edce472327a8462b upstream.
This reverts commit 5083fd7bdfe6760577235a724cf6dccae13652c2.
A bulk-out size smaller than the end-point size is indeed valid. The
offending commit broke the usb-debug driver for EHCI debug devices,
which use 8-byte buffers.
Fixes: 5083fd7bdfe6 ("USB: serial: make bulk_out_size a lower limit")
Reported-by: "Li, Elvin" <elvin.li@intel.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit f161d4b44d7cc1dc66b53365215227db356378b1 upstream.
This patch addresses the original PR_APTPL_BUF_LEN = 8k limitiation
for write-out of PR APTPL metadata that Martin has recently been
running into.
It changes core_scsi3_update_and_write_aptpl() to use vzalloc'ed
memory instead of kzalloc, and increases the default hardcoded
length to 256k.
It also adds logic in core_scsi3_update_and_write_aptpl() to double
the original length upon core_scsi3_update_aptpl_buf() failure, and
retries until the vzalloc'ed buffer is large enough to accommodate
the outgoing APTPL metadata.
Reported-by: Martin Svec <martin.svec@zoner.cz>
commit 99592d598eca62bdbbf62b59941c189176dfc614 upstream.
When studying page stealing, I noticed some weird looking decisions in
try_to_steal_freepages(). The first I assume is a bug (Patch 1), the
following two patches were driven by evaluation.
Testing was done with stress-highalloc of mmtests, using the
mm_page_alloc_extfrag tracepoint and postprocessing to get counts of how
often page stealing occurs for individual migratetypes, and what
migratetypes are used for fallbacks. Arguably, the worst case of page
stealing is when UNMOVABLE allocation steals from MOVABLE pageblock.
RECLAIMABLE allocation stealing from MOVABLE allocation is also not ideal,
so the goal is to minimize these two cases.
The evaluation of v2 wasn't always clear win and Joonsoo questioned the
results. Here I used different baseline which includes RFC compaction
improvements from [1]. I found that the compaction improvements reduce
variability of stress-highalloc, so there's less noise in the data.
First, let's look at stress-highalloc configured to do sync compaction,
and how these patches reduce page stealing events during the test. First
column is after fresh reboot, other two are reiterations of test without
reboot. That was all accumulater over 5 re-iterations (so the benchmark
was run 5x3 times with 5 fresh restarts).
Baseline:
3.19-rc4 3.19-rc4 3.19-rc4
5-nothp-1 5-nothp-2 5-nothp-3
Page alloc extfrag event 10264225 8702233 10244125
Extfrag fragmenting 10263271 8701552 10243473
Extfrag fragmenting for unmovable 13595 17616 15960
Extfrag fragmenting unmovable placed with movable 7989 12193 8447
Extfrag fragmenting for reclaimable 658 1840 1817
Extfrag fragmenting reclaimable placed with movable 558 1677 1679
Extfrag fragmenting for movable 10249018 8682096 10225696
With Patch 1:
6-nothp-1 6-nothp-2 6-nothp-3
Page alloc extfrag event 11834954 9877523 9774860
Extfrag fragmenting 11833993 9876880 9774245
Extfrag fragmenting for unmovable 7342 16129 11712
Extfrag fragmenting unmovable placed with movable 4191 10547 6270
Extfrag fragmenting for reclaimable 373 1130 923
Extfrag fragmenting reclaimable placed with movable 302 906 738
Extfrag fragmenting for movable 11826278 9859621 9761610
With Patch 2:
7-nothp-1 7-nothp-2 7-nothp-3
Page alloc extfrag event 4725990 3668793 3807436
Extfrag fragmenting 4725104 3668252 3806898
Extfrag fragmenting for unmovable 6678 7974 7281
Extfrag fragmenting unmovable placed with movable 2051 3829 4017
Extfrag fragmenting for reclaimable 429 1208 1278
Extfrag fragmenting reclaimable placed with movable 369 976 1034
Extfrag fragmenting for movable 4717997 3659070 3798339
With Patch 3:
8-nothp-1 8-nothp-2 8-nothp-3
Page alloc extfrag event 5016183 4700142 3850633
Extfrag fragmenting 5015325 4699613 3850072
Extfrag fragmenting for unmovable 1312 3154 3088
Extfrag fragmenting unmovable placed with movable 1115 2777 2714
Extfrag fragmenting for reclaimable 437 1193 1097
Extfrag fragmenting reclaimable placed with movable 330 969 879
Extfrag fragmenting for movable 5013576 4695266 3845887
In v2 we've seen apparent regression with Patch 1 for unmovable events,
this is now gone, suggesting it was indeed noise. Here, each patch
improves the situation for unmovable events. Reclaimable is improved by
patch 1 and then either the same modulo noise, or perhaps sligtly worse -
a small price for unmovable improvements, IMHO. The number of movable
allocations falling back to other migratetypes is most noisy, but it's
reduced to half at Patch 2 nevertheless. These are least critical as
compaction can move them around.
If we look at success rates, the patches don't affect them, that didn't change.
Baseline:
Success 1 Min 49.00 ( 0.00%) 42.00 ( 14.29%) 41.00 ( 16.33%)
Success 1 Mean 51.00 ( 0.00%) 45.00 ( 11.76%) 42.60 ( 16.47%)
Success 1 Max 55.00 ( 0.00%) 51.00 ( 7.27%) 46.00 ( 16.36%)
Success 2 Min 53.00 ( 0.00%) 47.00 ( 11.32%) 44.00 ( 16.98%)
Success 2 Mean 59.60 ( 0.00%) 50.80 ( 14.77%) 48.20 ( 19.13%)
Success 2 Max 64.00 ( 0.00%) 56.00 ( 12.50%) 52.00 ( 18.75%)
Success 3 Min 84.00 ( 0.00%) 82.00 ( 2.38%) 78.00 ( 7.14%)
Success 3 Mean 85.60 ( 0.00%) 82.80 ( 3.27%) 79.40 ( 7.24%)
Success 3 Max 86.00 ( 0.00%) 83.00 ( 3.49%) 80.00 ( 6.98%)
Patch 1:
Success 1 Min 49.00 ( 0.00%) 44.00 ( 10.20%) 44.00 ( 10.20%)
Success 1 Mean 51.80 ( 0.00%) 46.00 ( 11.20%) 45.80 ( 11.58%)
Success 1 Max 54.00 ( 0.00%) 49.00 ( 9.26%) 49.00 ( 9.26%)
Success 2 Min 58.00 ( 0.00%) 49.00 ( 15.52%) 48.00 ( 17.24%)
Success 2 Mean 60.40 ( 0.00%) 51.80 ( 14.24%) 50.80 ( 15.89%)
Success 2 Max 63.00 ( 0.00%) 54.00 ( 14.29%) 55.00 ( 12.70%)
Success 3 Min 84.00 ( 0.00%) 81.00 ( 3.57%) 79.00 ( 5.95%)
Success 3 Mean 85.00 ( 0.00%) 81.60 ( 4.00%) 79.80 ( 6.12%)
Success 3 Max 86.00 ( 0.00%) 82.00 ( 4.65%) 82.00 ( 4.65%)
Patch 2:
Success 1 Min 50.00 ( 0.00%) 44.00 ( 12.00%) 39.00 ( 22.00%)
Success 1 Mean 52.80 ( 0.00%) 45.60 ( 13.64%) 42.40 ( 19.70%)
Success 1 Max 55.00 ( 0.00%) 46.00 ( 16.36%) 47.00 ( 14.55%)
Success 2 Min 52.00 ( 0.00%) 48.00 ( 7.69%) 45.00 ( 13.46%)
Success 2 Mean 53.40 ( 0.00%) 49.80 ( 6.74%) 48.80 ( 8.61%)
Success 2 Max 57.00 ( 0.00%) 52.00 ( 8.77%) 52.00 ( 8.77%)
Success 3 Mean 85.00 ( 0.00%) 82.40 ( 3.06%) 79.60 ( 6.35%)
Patch 3:
Success 1 Min 46.00 ( 0.00%) 44.00 ( 4.35%) 42.00 ( 8.70%)
Success 1 Mean 50.20 ( 0.00%) 45.60 ( 9.16%) 44.00 ( 12.35%)
Success 1 Max 52.00 ( 0.00%) 47.00 ( 9.62%) 47.00 ( 9.62%)
Success 2 Min 53.00 ( 0.00%) 49.00 ( 7.55%) 48.00 ( 9.43%)
Success 2 Mean 55.80 ( 0.00%) 50.60 ( 9.32%) 49.00 ( 12.19%)
Success 2 Max 59.00 ( 0.00%) 52.00 ( 11.86%) 51.00 ( 13.56%)
Success 3 Min 84.00 ( 0.00%) 80.00 ( 4.76%) 79.00 ( 5.95%)
Success 3 Mean 85.40 ( 0.00%) 81.60 ( 4.45%) 80.40 ( 5.85%)
Success 3 Max 87.00 ( 0.00%) 83.00 ( 4.60%) 82.00 ( 5.75%)
While there's no improvement here, I consider reduced fragmentation events
to be worth on its own. Patch 2 also seems to reduce scanning for free
pages, and migrations in compaction, suggesting it has somewhat less work
to do:
Patch 1:
Compaction stalls 4153 3959 3978
Compaction success 1523 1441 1446
Compaction failures 2630 2517 2531
Page migrate success 4600827 4943120 5104348
Page migrate failure 19763 16656 17806
Compaction pages isolated 9597640 10305617 10653541
Compaction migrate scanned 77828948 86533283 87137064
Compaction free scanned 517758295 521312840 521462251
Compaction cost 5503 5932 6110
Patch 2:
Compaction stalls 3800 3450 3518
Compaction success 1421 1316 1317
Compaction failures 2379 2134 2201
Page migrate success 4160421 4502708 4752148
Page migrate failure 19705 14340 14911
Compaction pages isolated 8731983 9382374 9910043
Compaction migrate scanned 98362797 96349194 98609686
Compaction free scanned 496512560 469502017 480442545
Compaction cost 5173 5526 5811
As with v2, /proc/pagetypeinfo appears unaffected with respect to numbers
of unmovable and reclaimable pageblocks.
Configuring the benchmark to allocate like THP page fault (i.e. no sync
compaction) gives much noisier results for iterations 2 and 3 after
reboot. This is not so surprising given how [1] offers lower improvements
in this scenario due to less restarts after deferred compaction which
would change compaction pivot.
Baseline:
5-thp-1 5-thp-2 5-thp-3
Page alloc extfrag event 8148965 6227815 6646741
Extfrag fragmenting 8147872 6227130 6646117
Extfrag fragmenting for unmovable 10324 12942 15975
Extfrag fragmenting unmovable placed with movable 5972 8495 10907
Extfrag fragmenting for reclaimable 601 1707 2210
Extfrag fragmenting reclaimable placed with movable 520 1570 2000
Extfrag fragmenting for movable 8136947 6212481 6627932
Patch 1:
6-thp-1 6-thp-2 6-thp-3
Page alloc extfrag event 8345457 7574471 7020419
Extfrag fragmenting 8343546 7573777 7019718
Extfrag fragmenting for unmovable 10256 18535 30716
Extfrag fragmenting unmovable placed with movable 6893 11726 22181
Extfrag fragmenting for reclaimable 465 1208 1023
Extfrag fragmenting reclaimable placed with movable 353 996 843
Extfrag fragmenting for movable 8332825 7554034 6987979
Patch 2:
7-thp-1 7-thp-2 7-thp-3
Page alloc extfrag event 3512847 3020756 2891625
Extfrag fragmenting 3511940 3020185 2891059
Extfrag fragmenting for unmovable 9017 6892 6191
Extfrag fragmenting unmovable placed with movable 1524 3053 2435
Extfrag fragmenting for reclaimable 445 1081 1160
Extfrag fragmenting reclaimable placed with movable 375 918 986
Extfrag fragmenting for movable 3502478 3012212 2883708
Patch 3:
8-thp-1 8-thp-2 8-thp-3
Page alloc extfrag event 3181699 3082881 2674164
Extfrag fragmenting 3180812 3082303 2673611
Extfrag fragmenting for unmovable 1201 4031 4040
Extfrag fragmenting unmovable placed with movable 974 3611 3645
Extfrag fragmenting for reclaimable 478 1165 1294
Extfrag fragmenting reclaimable placed with movable 387 985 1030
Extfrag fragmenting for movable 3179133 3077107 2668277
The improvements for first iteration are clear, the rest is much noisier
and can appear like regression for Patch 1. Anyway, patch 2 rectifies it.
Allocation success rates are again unaffected so there's no point in
making this e-mail any longer.
[1] http://marc.info/?l=linux-mm&m=142166196321125&w=2
This patch (of 3):
When __rmqueue_fallback() is called to allocate a page of order X, it will
find a page of order Y >= X of a fallback migratetype, which is different
from the desired migratetype. With the help of try_to_steal_freepages(),
it may change the migratetype (to the desired one) also of:
1) all currently free pages in the pageblock containing the fallback page
2) the fallback pageblock itself
3) buddy pages created by splitting the fallback page (when Y > X)
These decisions take the order Y into account, as well as the desired
migratetype, with the goal of preventing multiple fallback allocations
that could e.g. distribute UNMOVABLE allocations among multiple
pageblocks.
Originally, decision for 1) has implied the decision for 3). Commit
47118af076f6 ("mm: mmzone: MIGRATE_CMA migration type added") changed that
(probably unintentionally) so that the buddy pages in case 3) are always
changed to the desired migratetype, except for CMA pageblocks.
Commit fef903efcf0c ("mm/page_allo.c: restructure free-page stealing code
and fix a bug") did some refactoring and added a comment that the case of
3) is intended. Commit 0cbef29a7821 ("mm: __rmqueue_fallback() should
respect pageblock type") removed the comment and tried to restore the
original behavior where 1) implies 3), but due to the previous
refactoring, the result is instead that only 2) implies 3) - and the
conditions for 2) are less frequently met than conditions for 1). This
may increase fragmentation in situations where the code decides to steal
all free pages from the pageblock (case 1)), but then gives back the buddy
pages produced by splitting.
This patch restores the original intended logic where 1) implies 3).
During testing with stress-highalloc from mmtests, this has shown to
decrease the number of events where UNMOVABLE and RECLAIMABLE allocations
steal from MOVABLE pageblocks, which can lead to permanent fragmentation.
In some cases it has increased the number of events when MOVABLE
allocations steal from UNMOVABLE or RECLAIMABLE pageblocks, but these are
fixable by sync compaction and thus less harmful.
Note that evaluation has shown that the behavior introduced by
47118af076f6 for buddy pages in case 3) is actually even better than the
original logic, so the following patch will introduce it properly once
again. For stable backports of this patch it makes thus sense to only fix
versions containing 0cbef29a7821.
[iamjoonsoo.kim@lge.com: tracepoint fix]
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
[ Upstream commit 8381eacf5c3b35cf7755f4bc521c4d56d24c1cd9 ]
Make __ipv6_select_ident() static as it isn't used outside
the file.
Fixes: 0508c07f5e0c9 (ipv6: Select fragment id during UFO segmentation if not set.)
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
commit b10a08194c2b615955dfab2300331a90ae9344c7 upstream.
Currently maximum space limit quota format supports is in blocks however
since we store space limits in bytes, this is somewhat confusing. So
store the maximum limit in bytes as well. Also rename the field to match
the new unit and related inode field to match the new naming scheme.
commit dd36929720f40f17685e841ae0d4c581c165ea60 upstream.
The use of READ_ONCE() causes lots of warnings witht he pending paravirt
spinlock fixes, because those ends up having passing a member to a
'const' structure to READ_ONCE().
There should certainly be nothing wrong with using READ_ONCE() with a
const source, but the helper function __read_once_size() would cause
warnings because it would drop the 'const' qualifier, but also because
the destination would be marked 'const' too due to the use of 'typeof'.
Use a union of types in READ_ONCE() to avoid this issue.
Also make sure to use parenthesis around the macro arguments to avoid
possible operator precedence issues.
Tested-by: Ingo Molnar <mingo@kernel.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
commit c5b19946eb76c67566aae6a84bf2b10ad59295ea upstream.
Commit 927609d622a3 ("kernel: tighten rules for ACCESS ONCE") results in
sparse warnings like "Using plain integer as NULL pointer" - Let's add a
type cast to the dummy assignment.
To avoid warnings lik "sparse: warning: cast to restricted __hc32" we also
use __force on that cast.
Fixes: 927609d622a3 ("kernel: tighten rules for ACCESS ONCE")
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 927609d622a3773995f84bc03b4564f873cf0e22 upstream.
Now that all non-scalar users of ACCESS_ONCE have been converted
to READ_ONCE or ASSIGN once, lets tighten ACCESS_ONCE to only
work on scalar types.
This variant was proposed by Alexei Starovoitov.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit f7d4ca8bbfda23b4f1eae9b6757ff64166b093d5 upstream.
Currently when kdb traps printk messages then the raw log level prefix
(consisting of '\001' followed by a numeral) does not get stripped off
before the message is issued to the various I/O handlers supported by
kdb. This causes annoying visual noise as well as causing problems
grepping for ^. It is also a change of behaviour compared to normal usage
of printk() usage. For example <SysRq>-h ends up with different output to
that of kdb's "sr h".
This patch addresses the problem by stripping log levels from messages
before they are issued to the I/O handlers. printk() which can also
act as an i/o handler in some cases is special cased; if the caller
provided a log level then the prefix will be preserved when sent to
printk().
The addition of non-printable characters to the output of kdb commands is a
regression, albeit and extremely elderly one, introduced by commit
04d2c8c83d0e ("printk: convert the format for KERN_<LEVEL> to a 2 byte
pattern"). Note also that this patch does *not* restore the original
behaviour from v3.5. Instead it makes printk() from within a kdb command
display the message without any prefix (i.e. like printk() normally does).
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Joe Perches <joe@perches.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 074f9dd55f9cab1b82690ed7e44bcf38b9616ce0 upstream.
Currently the USB stack assumes that all host controller drivers are
capable of receiving wakeup requests from downstream devices.
However, this isn't true for the isp1760-hcd driver, which means that
it isn't safe to do a runtime suspend of any device attached to a
root-hub port if the device requires wakeup.
This patch adds a "cant_recv_wakeups" flag to the usb_hcd structure
and sets the flag in isp1760-hcd. The core is modified to prevent a
direct child of the root hub from being put into runtime suspend with
wakeup enabled if the flag is set.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Greg Kroah-Hartman <greg@kroah.com>
commit 524134d422316a59d5464ccbc12036bbe90c5563 upstream.
The USB stack provides a mechanism for drivers to request an
asynchronous device reset (usb_queue_reset_device()). The mechanism
uses a work item (reset_ws) embedded in the usb_interface structure
used by the driver, and the reset is carried out by a work queue
routine.
The asynchronous reset can race with driver unbinding. When this
happens, we try to cancel the queued reset before unbinding the
driver, on the theory that the driver won't care about any resets once
it is unbound.
However, thanks to the fact that lockdep now tracks work queue
accesses, this can provoke a lockdep warning in situations where the
device reset causes another interface's driver to be unbound; see
http://marc.info/?l=linux-usb&m=141893165203776&w=2
for an example. The reason is that the work routine for reset_ws in
one interface calls cancel_queued_work() for the reset_ws in another
interface. Lockdep thinks this might lead to a work routine trying to
cancel itself. The simplest solution is not to cancel queued resets
when unbinding drivers.
This means we now need to acquire a reference to the usb_interface
when queuing a reset_ws work item and to drop the reference when the
work routine finishes. We also need to make sure that the
usb_interface structure doesn't outlive its parent usb_device; this
means acquiring and dropping a reference when the interface is created
and destroyed.
In addition, cancelling a queued reset can fail (if the device is in
the middle of an earlier reset), and this can cause usb_reset_device()
to try to rebind an interface that has been deallocated (see
http://marc.info/?l=linux-usb&m=142175717016628&w=2 for details).
Acquiring the extra references prevents this failure.
Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk>
Reported-by: Olivier Sobrie <olivier@sobrie.be>
Tested-by: Olivier Sobrie <olivier@sobrie.be>
commit 5efd2ea8c9f4f12916ffc8ba636792ce052f6911 upstream.
the following error pops up during "testusb -a -t 10"
| musb-hdrc musb-hdrc.1.auto: dma_pool_free buffer-128, f134e000/be842000 (bad dma)
hcd_buffer_create() creates a few buffers, the smallest has 32 bytes of
size. ARCH_KMALLOC_MINALIGN is set to 64 bytes. This combo results in
hcd_buffer_alloc() returning memory which is 32 bytes aligned and it
might by identified by buffer_offset() as another buffer. This means the
buffer which is on a 32 byte boundary will not get freed, instead it
tries to free another buffer with the error message.
This patch fixes the issue by creating the smallest DMA buffer with the
size of ARCH_KMALLOC_MINALIGN (or 32 in case ARCH_KMALLOC_MINALIGN is
smaller). This might be 32, 64 or even 128 bytes. The next three pools
will have the size 128, 512 and 2048.
In case the smallest pool is 128 bytes then we have only three pools
instead of four (and zero the first entry in the array).
The last pool size is always 2048 bytes which is the assumed PAGE_SIZE /
2 of 4096. I doubt it makes sense to continue using PAGE_SIZE / 2 where
we would end up with 8KiB buffer in case we have 16KiB pages.
Instead I think it makes sense to have a common size(s) and extend them
if there is need to.
There is a BUILD_BUG_ON() now in case someone has a minalign of more than
128 bytes.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 04f81f0154e4bf002be6f4d85668ce1257efa4d9 upstream.
Using the IPCB() macro to get the IPv4 options is convenient, but
unfortunately NetLabel often needs to examine the CIPSO option outside
of the scope of the IP layer in the stack. While historically IPCB()
worked above the IP layer, due to the inclusion of the inet_skb_param
struct at the head of the {tcp,udp}_skb_cb structs, recent commit
971f10ec ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
reordered the tcp_skb_cb struct and invalidated this IPCB() trick.
This patch fixes the problem by creating a new function,
cipso_v4_optptr(), which locates the CIPSO option inside the IP header
without calling IPCB(). Unfortunately, this isn't as fast as a simple
lookup so some additional tweaks were made to limit the use of this
new function.
Reported-by: Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
commit 03a9a42a1a7e5b3e7919ddfacc1d1cc81882a955 upstream.
Fix an Oopsable condition when nsm_mon_unmon is called as part of the
namespace cleanup, which now apparently happens after the utsname
has been freed.
Link: http://lkml.kernel.org/r/20150125220604.090121ae@neptune.home
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit f4086a3d789dbe18949862276d83b8f49fce6d2f upstream.
Commit 411a99adffb4f (nfs: clear_request_commit while holding i_lock)
assumes that the nfs_commit_info always points to the inode->i_lock.
For historical reasons, that is not the case for O_DIRECT writes.
Cc: Weston Andros Adamson <dros@primarydata.com>
Fixes: 411a99adffb4f ("nfs: clear_request_commit while holding i_lock")
commit 6ee8e25fc3e916193bce4ebb43d5439e1e2144ab upstream.
Commit e9fd702a58c4 ("audit: convert audit watches to use fsnotify
instead of inotify") broke handling of renames in audit. Audit code
wants to update inode number of an inode corresponding to watched name
in a directory. When something gets renamed into a directory to a
watched name, inotify previously passed moved inode to audit code
however new fsnotify code passes directory inode where the change
happened. That confuses audit and it starts watching parent directory
instead of a file in a directory.
This can be observed for example by doing:
cd /tmp
touch foo bar
auditctl -w /tmp/foo
touch foo
mv bar foo
touch foo
In audit log we see events like:
type=CONFIG_CHANGE msg=audit(1423563584.155:90): auid=1000 ses=2 op="updated rules" path="/tmp/foo" key=(null) list=4 res=1
type=PATH msg=audit(1423563584.155:91): item=2 name="bar" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=3 name="foo" inode=1046842 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=4 name="foo" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=CREATE
and that's it - we see event for the first touch after creating the
audit rule, we see events for rename but we don't see any event for the
last touch. However we start seeing events for unrelated stuff
happening in /tmp.
Fix the problem by passing moved inode as data in the FS_MOVED_FROM and
FS_MOVED_TO events instead of the directory where the change happens.
This doesn't introduce any new problems because noone besides
audit_watch.c cares about the passed value:
fs/notify/fanotify/fanotify.c cares only about FSNOTIFY_EVENT_PATH events.
fs/notify/dnotify/dnotify.c doesn't care about passed 'data' value at all.
fs/notify/inotify/inotify_fsnotify.c uses 'data' only for FSNOTIFY_EVENT_PATH.
kernel/audit_tree.c doesn't care about passed 'data' at all.
kernel/audit_watch.c expects moved inode as 'data'.
Fixes: e9fd702a58c49db ("audit: convert audit watches to use fsnotify instead of inotify")
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull ftrace fixes from Steven Rostedt:
"During testing Sedat Dilek hit a "suspicious RCU usage" splat that
pointed out a real bug. During suspend and resume the tlb_flush
tracepoint is called when the CPU is going offline. As the CPU has
been noted as offline, RCU is ignoring that CPU, which means that it
can not use RCU protected locks. When tracepoints are activated, they
require RCU locking, and if RCU is ignoring a CPU that runs a
tracepoint, there is a chance that the tracepoint could cause
corruption.
The solution was to change the tracepoint into a
TRACE_EVENT_CONDITION() which allows us to check a condition to
determine if the tracepoint should be called or not. If the condition
is not met, the rcu protected code will not be executed. By adding
the condition "cpu_online(smp_processor_id())", this will prevent the
RCU protected code from being executed if the CPU is marked offline.
After adding this, another bug was discovered. As RCU checks rcu
callers, if a rcu call is not done, there is no check (obviously). We
found that tracepoints could be added in RCU ignored locations and not
have lockdep complain until the tracepoint is activated. This missed
places where tracepoints were added in places they should not have
been. To fix this, code was added in 3.18 that if lockdep is enabled,
any tracepoint will still call the rcu checks even if the tracepoint
is not enabled. The bug here, is that the check does not take the
CONDITION into account. As the condition may prevent tracepoints from
being activated in RCU ignored areas (as the one patch does), we get
false positives when we enable lockdep and hit a tracepoint that the
condition prevents it from being called in a RCU ignored location.
The fix for this is to add the CONDITION to the rcu checks, even if
the tracepoint is not enabled"
* tag 'trace-fixes-v3.19-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
x86/tlb/trace: Do not trace on CPU that is offline
tracing: Add condition check to RCU lockdep checks
When taking a CPU down for suspend and resume, a tracepoint may be called
when the CPU has been designated offline. As tracepoints require RCU for
protection, they must not be called if the current CPU is offline.
Unfortunately, trace_tlb_flush() is called in this scenario as was noted
by LOCKDEP:
Disabling non-boot CPUs ...
intel_pstate CPU 1 exiting
smpboot: CPU 1 didn't die...
[ INFO: suspicious RCU usage. ]
3.19.0-rc7-next-20150204.1-iniza-small #1 Not tainted
include/trace/events/tlb.h:35 suspicious rcu_dereference_check() usage!
RCU used illegally from offline CPU!
rcu_scheduler_active = 1, debug_locks = 0
no locks held by swapper/1/0.
stack backtrace:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.19.0-rc7-next-20150204.1-iniza-small #1
Hardware name: SAMSUNG ELECTRONICS CO., LTD. 530U3BI/530U4BI/530U4BH/530U3BI/530U4BI/530U4BH, BIOS 13XK 03/28/2013
0000000000000001 ffff88011a44fe18 ffffffff817e370d 0000000000000011
ffff88011a448290 ffff88011a44fe48 ffffffff810d6847 ffff8800c66b9600
0000000000000001 ffff88011a44c000 ffffffff81cb3900 ffff88011a44fe78
Call Trace:
[<ffffffff817e370d>] dump_stack+0x4c/0x65
[<ffffffff810d6847>] lockdep_rcu_suspicious+0xe7/0x120
[<ffffffff810b71a5>] idle_task_exit+0x205/0x2c0
[<ffffffff81054c4e>] play_dead_common+0xe/0x50
[<ffffffff81054ca5>] native_play_dead+0x15/0x140
[<ffffffff8102963f>] arch_cpu_idle_dead+0xf/0x20
[<ffffffff810cd89e>] cpu_startup_entry+0x37e/0x580
[<ffffffff81053e20>] start_secondary+0x140/0x150
intel_pstate CPU 2 exiting
By converting the tlb_flush tracepoint to a TRACE_EVENT_CONDITION where the
condition is cpu_online(smp_processor_id()), we can avoid calling RCU protected
code when the CPU is offline.
Link: http://lkml.kernel.org/r/CA+icZUUGiGDoL5NU8RuxKzFjoLjEKRtUWx=JB8B9a0EQv-eGzQ@mail.gmail.com
Cc: stable@vger.kernel.org # 3.17+
Fixes: d17d8f9dedb9 "x86/mm: Add tracepoints for TLB flushes"
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Suggested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Dave Hansen <dave@sr71.net>
The trace_tlb_flush() tracepoint can be called when a CPU is going offline.
When a CPU is offline, RCU is no longer watching that CPU and since the
tracepoint is protected by RCU, it must not be called. To prevent the
tlb_flush tracepoint from being called when the CPU is offline, it was
converted to a TRACE_EVENT_CONDITION where the condition checks if the
CPU is online before calling the tracepoint.
Unfortunately, this was not enough to stop lockdep from complaining about
it. Even though the RCU protected code of the tracepoint will never be
called, the condition is hidden within the tracepoint, and even though the
condition prevents RCU code from being called, the lockdep checks are
outside the tracepoint (this is to test tracepoints even when they are not
enabled).
Even though tracepoints should be checked to be RCU safe when they are not
enabled, the condition should still be considered when checking RCU.
Fixes: 3a630178fd5f "tracing: generate RCU warnings even when tracepoints are disabled"
Cc: stable@vger.kernel.org # 3.18+
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull one more infiniband revert from Roland Dreier:
"One more last-second RDMA change for 3.19: Yann realized that the
previous revert of new userspace ABI did not go far enough, and we're
still exposing a change that we don't want. Revert even closer to
3.18 interface to make sure we get things right in the long run"
Yann Droneaud pipes up:
"I hope this could go in v3.19 as, at this stage, we don't want to
expose any bits of this ABI in a released kernel"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
Revert "IB/core: Add support for extended query device caps"
Pull scheduler fixes from Ingo Molnar:
"Misc fixes"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Fix deadline parameter modification handling
sched/wait: Remove might_sleep() from wait_event_cmd()
sched: Fix crash if cpuset_cpumask_can_shrink() is passed an empty cpumask
sched/fair: Avoid using uninitialized variable in preferred_group_nid()
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Hopefully the final pull request for 3.19: this ended up with a
slightly higher volume than wished, but I put them all as they are
either stable or 3.19 regression fixes.
Most of commits are from ASoC, and have been stewed for a while in
linux-next. The only change in the common code is the regression
fixes for ASoC AC97 stuff wrt device registrations. The rest are
device-specific, mostly small fixes in various ASoC drivers and ak411x
on ice1724 boards"
* tag 'sound-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: Intel: fix sst firmware path for cht-bsw-rt5672
ARM: dts: Fix I2S1, I2S2 compatible for exynos4 SoCs
ASoC: sgtl5000: add delay before first I2C access
MAINTAINERS: ASoC: add maintainer for Intel BDW/HSW ASoC driver
ASoC: atmel_ssc_dai: fix the setting for DSP mode
ASoC: sgtl5000: Use shift mask when setting codec mode
ASoC: tlv320aic3x: Fix data delay configuration
ALSA: ak411x: Fix stall in work callback
ASoC: Intel: Used lock version to update shim registers
ASoC: wm8731: init mutex in i2c init path
ASoC: atmel_ssc_dai: fix start event for I2S mode
ASoC: rt5640: Add RT5642 ACPI ID for Intel Baytrail
ASoC: wm97xx: Reset AC'97 device before registering it
ASoC: Add support for allocating AC'97 device before registering it
While commit 7e36ef8205ff ("IB/core: Temporarily disable
ex_query_device uverb") is correct as it makes the extended
QUERY_DEVICE uverb (which came as part of commit 5a77abf9a97a
("IB/core: Add support for extended query device caps") and commit
860f10a799c8 ("IB/core: Add flags for on demand paging support")) not
available to userspace, it doesn't address the initial issue regarding
ib_copy_to_udata() [1][2].
Additionally, further discussions around this new uverb seems to
conclude it would require a different data structure than the one
currently described in <rdma/ib_user_verbs.h> [3].
Both of these issues require a revert of the changes, so this patch
partially reverts commit 8cdd312cfed7 ("IB/mlx5: Implement the ODP
capability query verb") and commit 860f10a799c8 ("IB/core: Add flags
for on demand paging support") and fully reverts commit 5a77abf9a97a
("IB/core: Add support for extended query device caps").
[1] "Re: [PATCH v3 06/17] IB/core: Add support for extended query device caps"
http://mid.gmane.org/1418733236.2779.26.camel@opteya.com
[2] "Re: [PATCH] IB/core: Temporarily disable ex_query_device uverb"
http://mid.gmane.org/1423067503.3030.83.camel@opteya.com
[3] "RE: [PATCH v1 1/5] IB/uverbs: ex_query_device: answer must not depend on request's comp_mask"
http://mid.gmane.org/2807E5FD2F6FDA4886F6618EAC48510E0CC12C30@CRSMSX101.amr.corp.intel.com
Cc: Eli Cohen <eli@mellanox.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Shachar Raindel <raindel@mellanox.com>
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: AC'97 fixes
These are rather too large for this late in the release cycle but
they're clear, well understood and have been tested to fix a regression
which was introduced for v3.19. The details are all in Lars' changelog
and they've been cooking in -next for a while, to a large extent out
of conservatism about the size.
ASoC: Fixes for v3.19
A few last minute fixes for v3.19, all driver specific. None of them
stand out particularly - it's all the standard people who are affected
will care stuff.
The Samsung fix is a DT only fix for the audio controller, it's being
merged via the ASoC tree due to process messups (the submitter sent it
at the end of a tangentally related series rather than separately to the
ARM folks) in order to make sure that it gets to people sooner.
Pull networking fixes from David Miller:
1) Stretch ACKs can kill performance with Reno and CUBIC congestion
control, largely due to LRO and GRO. Fix from Neal Cardwell.
2) Fix userland breakage because we accidently emit zero length netlink
messages from the bridging code. From Roopa Prabhu.
3) Carry handling in generic csum_tcpudp_nofold is broken, fix from
Karl Beldan.
4) Remove bogus dev_set_net() calls from CAIF driver, from Nicolas
Dichtel.
5) Make sure PPP deflation never returns a length greater then the
output buffer, otherwise we overflow and trigger skb_over_panic().
Fix from Florian Westphal.
6) COSA driver needs VIRT_TO_BUS Kconfig dependencies, from Arnd
Bergmann.
7) Don't increase route cached MTU on datagram too big ICMPs. From Li
Wei.
8) Fix error path leaks in nf_tables, from Pablo Neira Ayuso.
9) Fix bitmask handling regression in netlink that broke things like
acpi userland tools. From Pablo Neira Ayuso.
10) Wrong header pointer passed to param_type2af() in SCTP code, from
Saran Maruti Ramanara.
11) Stacked vlans not handled correctly by vlan_get_protocol(), from
Toshiaki Makita.
12) Add missing DMA memory barrier to xgene driver, from Iyappan
Subramanian.
13) Fix crash in rate estimators, from Eric Dumazet.
14) We've been adding various workarounds, one after another, for the
change which added the per-net tcp_sock. It was meant to reduce
socket contention but added lots of problems.
Reduce this instead to a proper per-cpu socket and that rids us of
all the daemons.
From Eric Dumazet.
15) Fix memory corruption and OOPS in mlx4 driver, from Jack
Morgenstein.
16) When we disabled UFO in the virtio_net device, it introduces some
serious performance regressions. The orignal problem was IPV6
fragment ID generation, so fix that properly instead. From Vlad
Yasevich.
17) sr9700 driver build breaks on xtensa because it defines macros with
the same name as those used by the arch code. Use more unique
names. From Chen Gang.
18) Fix endianness in new virio 1.0 mode of the vhost net driver, from
Michael S Tsirkin.
19) Several sysctls were setting the maxlen attribute incorrectly, from
Sasha Levin.
20) Don't accept an FQ scheduler quantum of zero, that leads to crashes.
From Kenneth Klette Jonassen.
21) Fix dumping of non-existing actions in the packet scheduler
classifier. From Ignacy Gawędzki.
22) Return the write work_done value when doing TX work in the qlcnic
driver.
23) ip6gre_err accesses the info field with the wrong endianness, from
Sabrina Dubroca.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits)
sit: fix some __be16/u16 mismatches
ipv6: fix sparse errors in ip6_make_flowlabel()
net: remove some sparse warnings
flow_keys: n_proto type should be __be16
ip6_gre: fix endianness errors in ip6gre_err
qlcnic: Fix NAPI poll routine for Tx completion
amd-xgbe: Set RSS enablement based on hardware features
amd-xgbe: Adjust for zero-based traffic class count
cls_api.c: Fix dumping of non-existing actions' stats.
pkt_sched: fq: avoid hang when quantum 0
net: rds: use correct size for max unacked packets and bytes
vhost/net: fix up num_buffers endian-ness
gianfar: correct the bad expression while writing bit-pattern
net: usb: sr9700: Use 'SR_' prefix for the common register macros
Revert "drivers/net: Disable UFO through virtio"
Revert "drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets"
xen-netback: stop the guest rx thread after a fatal error
net/mlx4_core: Fix kernel Oops (mem corruption) when working with more than 80 VFs
isdn: off by one in connect_res()
include/net/ipv6.h:713:22: warning: incorrect type in assignment (different base types)
include/net/ipv6.h:713:22: expected restricted __be32 [usertype] hash
include/net/ipv6.h:713:22: got unsigned int
include/net/ipv6.h:719:25: warning: restricted __be32 degrades to integer
include/net/ipv6.h:719:22: warning: invalid assignment: ^=
include/net/ipv6.h:719:22: left side has type restricted __be32
include/net/ipv6.h:719:22: right side has type unsigned int
(struct flow_keys)->n_proto is in network order, use
proper type for this.
Fixes following sparse errors :
net/core/flow_dissector.c:139:39: warning: incorrect type in assignment (different base types)
net/core/flow_dissector.c:139:39: expected unsigned short [unsigned] [usertype] n_proto
net/core/flow_dissector.c:139:39: got restricted __be16 [assigned] [usertype] proto
net/core/flow_dissector.c:237:23: warning: incorrect type in assignment (different base types)
net/core/flow_dissector.c:237:23: expected unsigned short [unsigned] [usertype] n_proto
net/core/flow_dissector.c:237:23: got restricted __be16 [assigned] [usertype] proto
Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()")
If the IPv6 fragment id has not been set and we perform
fragmentation due to UFO, select a new fragment id.
We now consider a fragment id of 0 as unset and if id selection
process returns 0 (after all the pertrubations), we set it to
0x80000000, thus giving us ample space not to create collisions
with the next packet we may have to fragment.
When doing UFO integrity checking, we also select the
fragment id if it has not be set yet. This is stored into
the skb_shinfo() thus allowing UFO to function correclty.
This patch also removes duplicate fragment id generation code
and moves ipv6_select_ident() into the header as it may be
used during GSO.
The patch e22b886a8a43 ("sched/wait: Add might_sleep() checks")
introduced a bug in the raid5 subsystem.
The function raid5_quiesce() (and resize_stripes()) uses the 'cmd'
part to release and acquire a spinlock (so we call the sleep
primitives in atomic context), and therefore we cannot do the
might_sleep() check.
Remove it.
Fixes: e22b886a8a43 ("sched/wait: Add might_sleep() checks")
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1502020935580.13510@file01.intranet.prod.int.rdu2.redhat.com
80 VFs
Commit de966c592802 (net/mlx4_core: Support more than 64 VFs) was meant to
allow up to 126 VFs. However, due to leaving MLX4_MFUNC_MAX too low, using
more than 80 VFs resulted in memory corruptions (and Oopses) when more than
80 VFs were requested. In addition, the number of slaves was left too high.
This commit fixes these issues.
Fixes: de966c592802 ("net/mlx4_core: Support more than 64 VFs")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Amir Vadai <amirv@mellanox.com>
Pablo Neira Ayuso says:
Netfilter/IPVS fixes for net
The following patchset contains Netfilter/IPVS fixes for your net tree,
they are:
1) Validate hooks for nf_tables NAT expressions, otherwise users can
crash the kernel when using them from the wrong hook. We already
got one user trapped on this when configuring masquerading.
2) Fix a BUG splat in nf_tables with CONFIG_DEBUG_PREEMPT=y. Reported
by Andreas Schultz.
3) Avoid unnecessary reroute of traffic in the local input path
in IPVS that triggers a crash in in xfrm. Reported by Florian
Wiessner and fixes by Julian Anastasov.
4) Fix memory and module refcount leak from the error path of
nf_tables_newchain().
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
Commit 8eb23b9f35aa ("sched: Debug nested sleeps") added code to report
on nested sleep conditions, which we generally want to avoid because the
inner sleeping operation can re-set the thread state to TASK_RUNNING,
but that will then cause the outer sleep loop not actually sleep when it
calls schedule.
However, that's actually valid traditional behavior, with the inner
sleep being some fairly rare case (like taking a sleeping lock that
normally doesn't actually need to sleep).
And the debug code would actually change the state of the task to
TASK_RUNNING internally, which makes that kind of traditional and
working code not work at all, because now the nested sleep doesn't just
sometimes cause the outer one to not block, but will cause it to happen
every time.
In particular, it will cause the cardbus kernel daemon (pccardd) to
basically busy-loop doing scheduling, converting a laptop into a heater,
as reported by Bruno Prémont. But there may be other legacy uses of
that nested sleep model in other drivers that are also likely to never
get converted to the new model.
This fixes both cases:
- don't set TASK_RUNNING when the nested condition happens (note: even
if WARN_ONCE() only _warns_ once, the return value isn't whether the
warning happened, but whether the condition for the warning was true.
So despite the warning only happening once, the "if (WARN_ON(..))"
would trigger for every nested sleep.
- in the cases where we knowingly disable the warning by using
"sched_annotate_sleep()", don't change the task state (that is used
for all core scheduling decisions), instead use '->task_state_change'
that is used for the debugging decision itself.
(Credit for the second part of the fix goes to Oleg Nesterov: "Can't we
avoid this subtle change in behaviour DEBUG_ATOMIC_SLEEP adds?" with the
suggested change to use 'task_state_change' as part of the test)
Reported-and-bisected-by: Bruno Prémont <bonbons@linux-vserver.org>
Tested-by: Rafael J Wysocki <rjw@rjwysocki.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Thomas Gleixner <tglx@linutronix.de>,
Cc: Ilya Dryomov <ilya.dryomov@inktank.com>,
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: Peter Hurley <peter@hurleysoftware.com>,
Cc: Davidlohr Bueso <dave@stgolabs.net>,
Doing the following commands on a non idle network device
panics the box instantly, because cpu_bstats gets overwritten
by stats.
tc qdisc add dev eth0 root <your_favorite_qdisc>
... some traffic (one packet is enough) ...
tc qdisc replace dev eth0 root est 1sec 4sec <your_favorite_qdisc>
[ 325.355596] BUG: unable to handle kernel paging request at ffff8841dc5a074c
[ 325.362609] IP: [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90
[ 325.369158] PGD 1fa7067 PUD 0
[ 325.372254] Oops: 0000 [#1] SMP
[ 325.375514] Modules linked in: ...
[ 325.398346] CPU: 13 PID: 14313 Comm: tc Not tainted 3.19.0-smp-DEV #1163
[ 325.412042] task: ffff8800793ab5d0 ti: ffff881ff2fa4000 task.ti: ffff881ff2fa4000
[ 325.419518] RIP: 0010:[<ffffffff81541c9e>] [<ffffffff81541c9e>] __gnet_stats_copy_basic+0x3e/0x90
[ 325.428506] RSP: 0018:ffff881ff2fa7928 EFLAGS: 00010286
[ 325.433824] RAX: 000000000000000c RBX: ffff881ff2fa796c RCX: 000000000000000c
[ 325.440988] RDX: ffff8841dc5a0744 RSI: 0000000000000060 RDI: 0000000000000060
[ 325.448120] RBP: ffff881ff2fa7948 R08: ffffffff81cd4f80 R09: 0000000000000000
[ 325.455268] R10: ffff883ff223e400 R11: 0000000000000000 R12: 000000015cba0744
[ 325.462405] R13: ffffffff81cd4f80 R14: ffff883ff223e460 R15: ffff883feea0722c
[ 325.469536] FS: 00007f2ee30fa700(0000) GS:ffff88407fa20000(0000) knlGS:0000000000000000
[ 325.477630] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 325.483380] CR2: ffff8841dc5a074c CR3: 0000003feeae9000 CR4: 00000000001407e0
[ 325.490510] Stack:
[ 325.492524] ffff883feea0722c ffff883fef719dc0 ffff883feea0722c ffff883ff223e4a0
[ 325.499990] ffff881ff2fa79a8 ffffffff815424ee ffff883ff223e49c 000000015cba0744
[ 325.507460] 00000000f2fa7978 0000000000000000 ffff881ff2fa79a8 ffff883ff223e4a0
[ 325.514956] Call Trace:
[ 325.517412] [<ffffffff815424ee>] gen_new_estimator+0x8e/0x230
[ 325.523250] [<ffffffff815427aa>] gen_replace_estimator+0x4a/0x60
[ 325.529349] [<ffffffff815718ab>] tc_modify_qdisc+0x52b/0x590
[ 325.535117] [<ffffffff8155edd0>] rtnetlink_rcv_msg+0xa0/0x240
[ 325.540963] [<ffffffff8155ed30>] ? __rtnl_unlock+0x20/0x20
[ 325.546532] [<ffffffff8157f811>] netlink_rcv_skb+0xb1/0xc0
[ 325.552145] [<ffffffff8155b355>] rtnetlink_rcv+0x25/0x40
[ 325.557558] [<ffffffff8157f0d8>] netlink_unicast+0x168/0x220
[ 325.563317] [<ffffffff8157f47c>] netlink_sendmsg+0x2ec/0x3e0
Lets play safe and not use an union : percpu 'pointers' are mostly read
anyway, and we have typically few qdiscs per host.
Cc: John Fastabend <john.fastabend@gmail.com>
Fixes: 22e0f8b9322c ("net: sched: make bstats per cpu and estimator RCU safe")
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"i2c driver bugfixes (s3c2410, slave-eeprom, sh_mobile), size
regression "bugfix" (i2c slave), documentation bugfix (st).
Also, one documentation update (da9063), so some devicetrees can now
be verified"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: sh_mobile: terminate DMA reads properly
i2c: Only include slave support if selected
i2c: s3c2410: fix ABBA deadlock by keeping clock prepared
i2c: slave-eeprom: fix boundary check when using sysfs
i2c: st: Rename clock reference to something that exists
DT: i2c: Add devices handled by the da9063 MFD driver
vlan_get_protocol() could not get network protocol if a skb has a 802.1ad
vlan tag or multiple vlans, which caused incorrect checksum calculation
in several drivers.
Fix vlan_get_protocol() to retrieve network protocol instead of incorrect
vlan protocol.
As the logic is the same as skb_network_protocol(), create a common helper
function __vlan_get_protocol() and call it from existing functions.
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, but also an event groups fix, two PMU driver
fixes and a CPU model variant addition"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Tighten (and fix) the grouping condition
perf/x86/intel: Add model number for Airmont
perf/rapl: Fix crash in rapl_scale()
perf/x86/intel/uncore: Move uncore_box_init() out of driver initialization
perf probe: Fix probing kretprobes
perf symbols: Introduce 'for' method to iterate over the symbols with a given name
perf probe: Do not rely on map__load() filter to find symbols
perf symbols: Introduce method to iterate symbols ordered by name
perf symbols: Return the first entry with a given name in find_by_name method
perf annotate: Fix memory leaks in LOCK handling
perf annotate: Handle ins parsing failures
perf scripting perl: Force to use stdbool
perf evlist: Remove extraneous 'was' on error message
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota and UDF fix from Jan Kara:
"A fix for UDF to properly free preallocated blocks and a fix for quota
so that Q_GETQUOTA quotactl reports correct numbers for XFS filesystem
(and similarly Q_XGETQUOTA quotactl works properly for other
filesystems)"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
quota: Switch ->get_dqblk() and ->set_dqblk() to use bytes as space units
udf: Release preallocation on last writeable close
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
LRO, GRO, delayed ACKs, and middleboxes can cause "stretch ACKs" that
cover more than the RFC-specified maximum of 2 packets. These stretch
ACKs can cause serious performance shortfalls in common congestion
control algorithms that were designed and tuned years ago with
receiver hosts that were not using LRO or GRO, and were instead
politely ACKing every other packet.
This patch series fixes Reno and CUBIC to handle stretch ACKs.
This patch prepares for the upcoming stretch ACK bug fix patches. It
adds an "acked" parameter to tcp_cong_avoid_ai() to allow for future
fixes to tcp_cong_avoid_ai() to correctly handle stretch ACKs, and
changes all congestion control algorithms to pass in 1 for the ACKed
count. It also changes tcp_slow_start() to return the number of packet
ACK "credits" that were not processed in slow start mode, and can be
processed by the congestion control module in additive increase mode.
In future patches we will fix tcp_cong_avoid_ai() to handle stretch
ACKs, and fix Reno and CUBIC handling of stretch ACKs in slow start
and additive increase mode.
Reported-by: Eyal Perry <eyalpe@mellanox.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
When ak4114 work calls its callback and the callback invokes
ak4114_reinit(), it stalls due to flush_delayed_work(). For avoiding
this, control the reentrance by introducing a refcount. Also
flush_delayed_work() is replaced with cancel_delayed_work_sync().
The exactly same bug is present in ak4113.c and fixed as well.
Reported-by: Pavel Hofman <pavel.hofman@ivitera.com>
Acked-by: Jaroslav Kysela <perex@perex.cz>
Tested-by: Pavel Hofman <pavel.hofman@ivitera.com>
Cc: <stable@vger.kernel.org>
The fix from 9fc81d87420d ("perf: Fix events installation during
moving group") was incomplete in that it failed to recognise that
creating a group with events for different CPUs is semantically
broken -- they cannot be co-scheduled.
Furthermore, it leads to real breakage where, when we create an event
for CPU Y and then migrate it to form a group on CPU X, the code gets
confused where the counter is programmed -- triggered in practice
as well by me via the perf fuzzer.
Fix this by tightening the rules for creating groups. Only allow
grouping of counters that can be co-scheduled in the same context.
This means for the same task and/or the same cpu.
Fixes: 9fc81d87420d ("perf: Fix events installation during moving group")
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20150123125834.090683288@infradead.org
Currently ->get_dqblk() and ->set_dqblk() use struct fs_disk_quota which
tracks space limits and usage in 512-byte blocks. However VFS quotas
track usage in bytes (as some filesystems require that) and we need to
somehow pass this information. Upto now it wasn't a problem because we
didn't do any unit conversion (thus VFS quota routines happily stuck
number of bytes into d_bcount field of struct fd_disk_quota). Only if
you tried to use Q_XGETQUOTA or Q_XSETQLIM for VFS quotas (or Q_GETQUOTA
/ Q_SETQUOTA for XFS quotas), you got bogus results. Hardly anyone
tried this but reportedly some Samba users hit the problem in practice.
So when we want interfaces compatible we need to fix this.
We bite the bullet and define another quota structure used for passing
information from/to ->get_dqblk()/->set_dqblk. It's somewhat sad we have
to have more conversion routines in fs/quota/quota.c and another copying
of quota structure slows down getting of quota information by about 2%
but it seems cleaner than overloading e.g. units of d_bcount to bytes.
CC: stable@vger.kernel.org
1) Don't OOPS on socket AIO, from Christoph Hellwig.
2) Scheduled scans should be aborted upon RFKILL, from Emmanuel
Grumbach.
3) Fix sleep in atomic context in kvaser_usb, from Ahmed S Darwish.
4) Fix RCU locking across copy_to_user() in bpf code, from Alexei
Starovoitov.
5) Lots of crash, memory leak, short TX packet et al bug fixes in
sh_eth from Ben Hutchings.
6) Fix memory corruption in SCTP wrt. INIT collitions, from Daniel
Borkmann.
7) Fix return value logic for poll handlers in netxen, enic, and bnx2x.
From Eric Dumazet and Govindarajulu Varadarajan.
8) Header length calculation fix in mac80211 from Fred Chou.
9) mv643xx_eth doesn't handle highmem correctly in non-TSO code paths.
From Ezequiel Garcia.
10) udp_diag has bogus logic in it's hash chain skipping, copy same fix
tcp diag used. From Herbert Xu.
11) amd-xgbe programs wrong rx flow control register, from Thomas
Lendacky.
12) Fix race leading to use after free in ping receive path, from Subash
Abhinov Kasiviswanathan.
13) Cache redirect routes otherwise we can get a heavy backlog of rcu
jobs liberating DST_NOCACHE entries. From Hannes Frederic Sowa.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (48 commits)
net: don't OOPS on socket aio
stmmac: prevent probe drivers to crash kernel
bnx2x: fix napi poll return value for repoll
ipv6: replacing a rt6_info needs to purge possible propagated rt6_infos too
sh_eth: Fix DMA-API usage for RX buffers
sh_eth: Check for DMA mapping errors on transmit
sh_eth: Ensure DMA engines are stopped before freeing buffers
sh_eth: Remove RX overflow log messages
ping: Fix race in free in receive path
udp_diag: Fix socket skipping within chain
can: kvaser_usb: Fix state handling upon BUS_ERROR events
can: kvaser_usb: Retry the first bulk transfer on -ETIMEDOUT
can: kvaser_usb: Send correct context to URB completion
can: kvaser_usb: Do not sleep in atomic context
ipv4: try to cache dst_entries which would cause a redirect
samples: bpf: relax test_maps check
bpf: rcu lock must not be held when calling copy_to_user()
net: sctp: fix slab corruption from use after free on INIT collisions
net: mv643xx_eth: Fix highmem support in non-TSO egress path
sh_eth: Fix serialisation of interrupt disable with interrupt & NAPI handlers
Not caching dst_entries which cause redirects could be exploited by hosts
on the same subnet, causing a severe DoS attack. This effect aggravated
since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()").
Lookups causing redirects will be allocated with DST_NOCACHE set which
will force dst_release to free them via RCU. Unfortunately waiting for
RCU grace period just takes too long, we can end up with >1M dst_entries
waiting to be released and the system will run OOM. rcuos threads cannot
catch up under high softirq load.
Attaching the flag to emit a redirect later on to the specific skb allows
us to cache those dst_entries thus reducing the pressure on allocation
and deallocation.
This issue was discovered by Marcelo Leitner.
Cc: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Leitner <mleitner@redhat.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Merge misc fixes from Andrew Morton:
"Six fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
drivers/rtc/rtc-s5m.c: terminate s5m_rtc_id array with empty element
printk: add dummy routine for when CONFIG_PRINTK=n
mm/vmscan: fix highidx argument type
memcg: remove extra newlines from memcg oom kill log
x86, build: replace Perl script with Shell script
mm: page_alloc: embed OOM killing naturally into allocation slowpath
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"One correctness fix here for the s2mps11 driver which would have
resulted in some of the regulators being completely broken together
with a fix for locking in regualtor_put() (which is fortunately rarely
called at all in practical systems)"
* tag 'regulator-v3.19-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: s2mps11: Fix wrong calculation of register offset
regulator: core: fix race condition in regulator_put()
There are missing dummy routines for log_buf_addr_get() and
log_buf_len_get() for when CONFIG_PRINTK is not set causing build
failures.
This patch adds these dummy routines at the appropriate location.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
