path: root/include
2014-10-30ima: pass 'opened' flag to identify newly created filesDmitry Kasatkin
commit 3034a146820c26fe6da66a45f6340fe87fe0983a upstream. Empty files and missing xattrs do not guarantee that a file was just created. This patch passes FILE_CREATED flag to IMA to reliably identify new files. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30mm/balloon_compaction: redesign ballooned pages managementKonstantin Khlebnikov
commit d6d86c0a7f8ddc5b38cf089222cb1d9540762dc2 upstream. Sasha Levin reported KASAN splash inside isolate_migratepages_range(). Problem is in the function __is_movable_balloon_page() which tests AS_BALLOON_MAP in page->mapping->flags. This function has no protection against anonymous pages. As result it tried to check address space flags inside struct anon_vma. Further investigation shows more problems in current implementation: * Special branch in __unmap_and_move() never works: balloon_page_movable() checks page flags and page_count. In __unmap_and_move() page is locked, reference counter is elevated, thus balloon_page_movable() always fails. As a result execution goes to the normal migration path. virtballoon_migratepage() returns MIGRATEPAGE_BALLOON_SUCCESS instead of MIGRATEPAGE_SUCCESS, move_to_new_page() thinks this is an error code and assigns newpage->mapping to NULL. Newly migrated page lose connectivity with balloon an all ability for further migration. * lru_lock erroneously required in isolate_migratepages_range() for isolation ballooned page. This function releases lru_lock periodically, this makes migration mostly impossible for some pages. * balloon_page_dequeue have a tight race with balloon_page_isolate: balloon_page_isolate could be executed in parallel with dequeue between picking page from list and locking page_lock. Race is rare because they use trylock_page() for locking. This patch fixes all of them. Instead of fake mapping with special flag this patch uses special state of page->_mapcount: PAGE_BALLOON_MAPCOUNT_VALUE = -256. Buddy allocator uses PAGE_BUDDY_MAPCOUNT_VALUE = -128 for similar purpose. Storing mark directly in struct page makes everything safer and easier. PagePrivate is used to mark pages present in page list (i.e. not isolated, like PageLRU for normal pages). It replaces special rules for reference counter and makes balloon migration similar to migration of normal pages. This flag is protected by page_lock together with link to the balloon device. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Link: http://lkml.kernel.org/p/53E6CEAA.9020105@oracle.com Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30kernel: add support for gcc 5Sasha Levin
commit 71458cfc782eafe4b27656e078d379a34e472adf upstream. We're missing include/linux/compiler-gcc5.h which is required now because gcc branched off to v5 in trunk. Just copy the relevant bits out of include/linux/compiler-gcc4.h, no new code is added as of now. This fixes a build error when using gcc 5. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30mm: clear __GFP_FS when PF_MEMALLOC_NOIO is setJunxiao Bi
commit 934f3072c17cc8886f4c043b47eeeb1b12f8de33 upstream. commit 21caf2fc1931 ("mm: teach mm by current context info to not do I/O during memory allocation") introduces PF_MEMALLOC_NOIO flag to avoid doing I/O inside memory allocation, __GFP_IO is cleared when this flag is set, but __GFP_FS implies __GFP_IO, it should also be cleared. Or it may still run into I/O, like in superblock shrinker. And this will make the kernel run into the deadlock case described in that commit. See Dave Chinner's comment about io in superblock shrinker: Filesystem shrinkers do indeed perform IO from the superblock shrinker and have for years. Even clean inodes can require IO before they can be freed - e.g. on an orphan list, need truncation of post-eof blocks, need to wait for ordered operations to complete before it can be freed, etc. IOWs, Ext4, btrfs and XFS all can issue and/or block on arbitrary amounts of IO in the superblock shrinker context. XFS, in particular, has been doing transactions and IO from the VFS inode cache shrinker since it was first introduced.... Fix this by clearing __GFP_FS in memalloc_noio_flags(), this function has masked all the gfp_mask that will be passed into fs for the processes setting PF_MEMALLOC_NOIO in the direct reclaim path. v1 thread at: https://lkml.org/lkml/2014/9/3/32 Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Dave Chinner <david@fromorbit.com> Cc: joyce.xue <xuejiufei@huawei.com> Cc: Ming Lei <ming.lei@canonical.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30Drivers: hv: util: Properly pack the data for file copy functionalityK. Y. Srinivasan
commit bc5a5b02331a3175a5fca20a4beba249e573b672 upstream. Properly pack the data for file copy functionality. Patch based on investigation done by Matej Muzila <mmuzila@redhat.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reported-by: <qge@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30pci_ids: Add support for Intel Quark ILBJosef Ahmad
commit bb048713bba3ead39f6112910906d9fe3f88ede7 upstream. This patch adds the PCI id for Intel Quark ILB. It will be used for GPIO and Multifunction device driver. Signed-off-by: Josef Ahmad <josef.ahmad@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Chang Rebecca Swee Fun <rebecca.swee.fun.chang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15USB: Add device quirk for ASUS T100 Base Station keyboardLu Baolu
commit ddbe1fca0bcb87ca8c199ea873a456ca8a948567 upstream. This full-speed USB device generates spurious remote wakeup event as soon as USB_DEVICE_REMOTE_WAKEUP feature is set. As the result, Linux can't enter system suspend and S0ix power saving modes once this keyboard is used. This patch tries to introduce USB_QUIRK_IGNORE_REMOTE_WAKEUP quirk. With this quirk set, wakeup capability will be ignored during device configure. This patch could be back-ported to kernels as old as 2.6.39. Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15uas: Add no-report-opcodes quirkHans de Goede
commit 734016b00b50a3c6a0e1fc1b7b217e783f5123a1 upstream. Besides the ASM1051 (*) needing sdev->no_report_opcodes = 1, it turns out that the JMicron JMS567 also needs it to work properly with uas (usb-storage always sets it). Since some of the scsi devs were not to keen on the idea to outrightly set sdev->no_report_opcodes = 1 for all uas devices, so add a quirk for this, and set it for the JMS567. *) Which has become a non-issue since we've completely blacklisted uas on the ASM1051 for other reasons Reported-and-tested-by: Claudio Bizzarri <claudio.bizzarri@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15uas: Add a quirk for rejecting ATA_12 and ATA_16 commandsHans de Goede
commit 593078525c8b234a35a36ff551b8716464e86481 upstream. And set this quirk for the Seagate Expansion Desk (0bc2:2312), as that one seems to hang upon receiving an ATA_12 or ATA_16 command. https://bugzilla.kernel.org/show_bug.cgi?id=79511 https://bbs.archlinux.org/viewtopic.php?id=183190 While at it also add missing documentation for the u value for usb-storage quirks. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15irq_work: Force raised irq work to run on irq work interruptFrederic Weisbecker
commit 76a33061b9323b7fdb220ae5fa116c10833ec22e upstream. The nohz full kick, which restarts the tick when any resource depend on it, can't be executed anywhere given the operation it does on timers. If it is called from the scheduler or timers code, chances are that we run into a deadlock. This is why we run the nohz full kick from an irq work. That way we make sure that the kick runs on a virgin context. However if that's the case when irq work runs in its own dedicated self-ipi, things are different for the big bunch of archs that don't support the self triggered way. In order to support them, irq works are also handled by the timer interrupt as fallback. Now when irq works run on the timer interrupt, the context isn't blank. More precisely, they can run in the context of the hrtimer that runs the tick. But the nohz kick cancels and restarts this hrtimer and cancelling an hrtimer from itself isn't allowed. This is why we run in an endless loop: Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 2 CPU: 2 PID: 7538 Comm: kworker/u8:8 Not tainted 3.16.0+ #34 Workqueue: btrfs-endio-write normal_work_helper [btrfs] ffff880244c06c88 000000001b486fe1 ffff880244c06bf0 ffffffff8a7f1e37 ffffffff8ac52a18 ffff880244c06c78 ffffffff8a7ef928 0000000000000010 ffff880244c06c88 ffff880244c06c20 000000001b486fe1 0000000000000000 Call Trace: <NMI[<ffffffff8a7f1e37>] dump_stack+0x4e/0x7a [<ffffffff8a7ef928>] panic+0xd4/0x207 [<ffffffff8a1450e8>] watchdog_overflow_callback+0x118/0x120 [<ffffffff8a186b0e>] __perf_event_overflow+0xae/0x350 [<ffffffff8a184f80>] ? perf_event_task_disable+0xa0/0xa0 [<ffffffff8a01a4cf>] ? x86_perf_event_set_period+0xbf/0x150 [<ffffffff8a187934>] perf_event_overflow+0x14/0x20 [<ffffffff8a020386>] intel_pmu_handle_irq+0x206/0x410 [<ffffffff8a01937b>] perf_event_nmi_handler+0x2b/0x50 [<ffffffff8a007b72>] nmi_handle+0xd2/0x390 [<ffffffff8a007aa5>] ? nmi_handle+0x5/0x390 [<ffffffff8a0cb7f8>] ? match_held_lock+0x8/0x1b0 [<ffffffff8a008062>] default_do_nmi+0x72/0x1c0 [<ffffffff8a008268>] do_nmi+0xb8/0x100 [<ffffffff8a7ff66a>] end_repeat_nmi+0x1e/0x2e [<ffffffff8a0cb7f8>] ? match_held_lock+0x8/0x1b0 [<ffffffff8a0cb7f8>] ? match_held_lock+0x8/0x1b0 [<ffffffff8a0cb7f8>] ? match_held_lock+0x8/0x1b0 <<EOE><IRQ[<ffffffff8a0ccd2f>] lock_acquired+0xaf/0x450 [<ffffffff8a0f74c5>] ? lock_hrtimer_base.isra.20+0x25/0x50 [<ffffffff8a7fc678>] _raw_spin_lock_irqsave+0x78/0x90 [<ffffffff8a0f74c5>] ? lock_hrtimer_base.isra.20+0x25/0x50 [<ffffffff8a0f74c5>] lock_hrtimer_base.isra.20+0x25/0x50 [<ffffffff8a0f7723>] hrtimer_try_to_cancel+0x33/0x1e0 [<ffffffff8a0f78ea>] hrtimer_cancel+0x1a/0x30 [<ffffffff8a109237>] tick_nohz_restart+0x17/0x90 [<ffffffff8a10a213>] __tick_nohz_full_check+0xc3/0x100 [<ffffffff8a10a25e>] nohz_full_kick_work_func+0xe/0x10 [<ffffffff8a17c884>] irq_work_run_list+0x44/0x70 [<ffffffff8a17c8da>] irq_work_run+0x2a/0x50 [<ffffffff8a0f700b>] update_process_times+0x5b/0x70 [<ffffffff8a109005>] tick_sched_handle.isra.21+0x25/0x60 [<ffffffff8a109b81>] tick_sched_timer+0x41/0x60 [<ffffffff8a0f7aa2>] __run_hrtimer+0x72/0x470 [<ffffffff8a109b40>] ? tick_sched_do_timer+0xb0/0xb0 [<ffffffff8a0f8707>] hrtimer_interrupt+0x117/0x270 [<ffffffff8a034357>] local_apic_timer_interrupt+0x37/0x60 [<ffffffff8a80010f>] smp_apic_timer_interrupt+0x3f/0x50 [<ffffffff8a7fe52f>] apic_timer_interrupt+0x6f/0x80 To fix this we force non-lazy irq works to run on irq work self-IPIs when available. That ability of the arch to trigger irq work self IPIs is available with arch_irq_work_has_interrupt(). Reported-by: Catalin Iacob <iacobcatalin@gmail.com> Reported-by: Dave Jones <davej@redhat.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15irq_work: Introduce arch_irq_work_has_interrupt()Peter Zijlstra
commit c5c38ef3d70377dc504a6a3f611a3ec814bc757b upstream. The nohz full code needs irq work to trigger its own interrupt so that the subsystem can work even when the tick is stopped. Lets introduce arch_irq_work_has_interrupt() that archs can override to tell about their support for this ability. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-15sctp: handle association restarts when the socket is closed.Vlad Yasevich
[ Upstream commit bdf6fa52f01b941d4a80372d56de465bdbbd1d23 ] Currently association restarts do not take into consideration the state of the socket. When a restart happens, the current assocation simply transitions into established state. This creates a condition where a remote system, through a the restart procedure, may create a local association that is no way reachable by user. The conditions to trigger this are as follows: 1) Remote does not acknoledge some data causing data to remain outstanding. 2) Local application calls close() on the socket. Since data is still outstanding, the association is placed in SHUTDOWN_PENDING state. However, the socket is closed. 3) The remote tries to create a new association, triggering a restart on the local system. The association moves from SHUTDOWN_PENDING to ESTABLISHED. At this point, it is no longer reachable by any socket on the local system. This patch addresses the above situation by moving the newly ESTABLISHED association into SHUTDOWN-SENT state and bundling a SHUTDOWN after the COOKIE-ACK chunk. This way, the restarted associate immidiately enters the shutdown procedure and forces the termination of the unreachable association. Reported-by: David Laight <David.Laight@aculab.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't halt the firmware in r8152 driver, from Hayes Wang. 2) Handle full sized 802.1ad frames in bnx2 and tg3 drivers properly, from Vlad Yasevich. 3) Don't sleep while holding tx_clean_lock in netxen driver, fix from Manish Chopra. 4) Certain kinds of ipv6 routes can end up endlessly failing the route validation test, causing it to be re-looked up over and over again. This particularly kills input route caching in TCP sockets. Fix from Hannes Frederic Sowa. 5) netvsc_start_xmit() has a use-after-free access to skb->len, fix from K Y Srinivasan. 6) Fix matching of inverted containers in ematch module, from Ignacy Gawędzki. 7) Aggregation of GRO frames via SKB ->frag_list for linear skbs isn't handled properly, regression fix from Eric Dumazet. 8) Don't test return value of ipv4_neigh_lookup(), which returns an error pointer, against NULL. From WANG Cong. 9) Fix an old regression where we mistakenly allow a double add of the same tunnel. Fixes from Steffen Klassert. 10) macvtap device delete and open can run in parallel and corrupt lists etc., fix from Vlad Yasevich. 11) Fix build error with IPV6=m NETFILTER_XT_TARGET_TPROXY=y, from Pablo Neira Ayuso. 12) rhashtable_destroy() triggers lockdep splats, fix also from Pablo. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) bna: Update Maintainer Email r8152: disable power cut for RTL8153 r8152: remove clearing bp bnx2: Correctly receive full sized 802.1ad fragmes tg3: Allow for recieve of full-size 8021AD frames r8152: fix setting RTL8152_UNPLUG netxen: Fix bug in Tx completion path. netxen: Fix BUG "sleeping function called from invalid context" ipv6: remove rt6i_genid hyperv: Fix a bug in netvsc_start_xmit() net: stmmac: fix stmmac_pci_probe failed when CONFIG_HAVE_CLK is selected ematch: Fix matching of inverted containers. gro: fix aggregation for skb using frag_list neigh: check error pointer instead of NULL for ipv4_neigh_lookup() ip6_gre: Return an error when adding an existing tunnel. ip6_vti: Return an error when adding an existing tunnel. ip6_tunnel: Return an error when adding an existing tunnel. ip6gre: add a rtnl link alias for ip6gretap net/mlx4_core: Allow not to specify probe_vf in SRIOV IB mode r8152: fix the carrier off when autoresuming ...
2014-09-30ipv6: remove rt6i_genidHannes Frederic Sowa
Eric Dumazet noticed that all no-nonexthop or no-gateway routes which are already marked DST_HOST (e.g. input routes routes) will always be invalidated during sk_dst_check. Thus per-socket dst caching absolutely had no effect and early demuxing had no effect. Thus this patch removes rt6i_genid: fn_sernum already gets modified during add operations, so we only must ensure we mutate fn_sernum during ipv6 address remove operations. This is a fairly cost extensive operations, but address removal should not happen that often. Also our mtu update functions do the same and we heard no complains so far. xfrm policy changes also cause a call into fib6_flush_trees. Also plug a hole in rt6_info (no cacheline changes). I verified via tracing that this change has effect. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: YOSHIFUJI Hideaki <hideaki@yoshifuji.org> Cc: Vlad Yasevich <vyasevich@gmail.com> Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com> Cc: Martin Lau <kafai@fb.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Assorted fixes + unifying __d_move() and __d_materialise_dentry() + minimal regression fix for d_path() of victims of overwriting rename() ported on top of that" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Don't exchange "short" filenames unconditionally. fold swapping ->d_name.hash into switch_names() fold unlocking the children into dentry_unlock_parents_for_move() kill __d_materialise_dentry() __d_materialise_dentry(): flip the order of arguments __d_move(): fold manipulations with ->d_child/->d_subdirs don't open-code d_rehash() in d_materialise_unique() pull rehashing and unlocking the target dentry into __d_materialise_dentry() ufs: deal with nfsd/iget races fuse: honour max_read and max_write in direct_io mode shmem: fix nlink for rename overwrite directory
2014-09-27Merge branch 'for-3.17-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "This is quite late but these need to be backported anyway. This is the fix for a long-standing cpuset bug which existed from 2009. cpuset makes use of PF_SPREAD_{PAGE|SLAB} flags to modify the task's memory allocation behavior according to the settings of the cpuset it belongs to; unfortunately, when those flags have to be changed, cpuset did so directly even whlie the target task is running, which is obviously racy as task->flags may be modified by the task itself at any time. This obscure bug manifested as corrupt PF_USED_MATH flag leading to a weird crash. The bug is fixed by moving the flag to task->atomic_flags. The first two are prepatory ones to help defining atomic_flags accessors and the third one is the actual fix" * 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cpuset: PF_SPREAD_PAGE and PF_SPREAD_SLAB should be atomic flags sched: add macros to define bitops for task atomic flags sched: fix confusing PFA_NO_NEW_PRIVS constant
2014-09-26fuse: honour max_read and max_write in direct_io modeMiklos Szeredi
The third argument of fuse_get_user_pages() "nbytesp" refers to the number of bytes a caller asked to pack into fuse request. This value may be lesser than capacity of fuse request or iov_iter. So fuse_get_user_pages() must ensure that *nbytesp won't grow. Now, when helper iov_iter_get_pages() performs all hard work of extracting pages from iov_iter, it can be done by passing properly calculated "maxsize" to the helper. The other caller of iov_iter_get_pages() (dio_refill_pages()) doesn't need this capability, so pass LONG_MAX as the maxsize argument here. Fixes: c9c37e2e6378 ("fuse: switch to iov_iter_get_pages()") Reported-by: Werner Baumann <werner.baumann@onlinehome.de> Tested-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "A CONFIG_STACK_GROWSUP=y fix, and a hotplug llc CPU mask fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix unreleased llc_shared_mask bit during CPU hotplug sched: Fix end_of_stack() and location of stack canary for architectures using CONFIG_STACK_GROWSUP
2014-09-25Merge tag 'pm+acpi-3.17-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are regression fixes (ACPI hotplug, cpufreq, hibernation, ACPI LPSS driver), fixes for stuff that never worked correctly (ACPI GPIO support in some cases and a wrong sign of an error code in the ACPI core in one place), and one blacklist item for ACPI backlight handling. Specifics: - Revert of a recent hibernation core commit that introduced a NULL pointer dereference during resume for at least one user (Rafael J Wysocki). - Fix for the ACPI LPSS (Low-Power Subsystem) driver to disable asynchronous PM callback execution for LPSS devices during system suspend/resume (introduced in 3.16) which turns out to break ordering expectations on some systems. From Fu Zhonghui. - cpufreq core fix related to the handling of sysfs nodes during system suspend/resume that has been broken for intel_pstate since 3.15 from Lan Tianyu. - Restore the generation of "online" uevents for ACPI container devices that was removed in 3.14, but some user space utilities turn out to need them (Rafael J Wysocki). - The cpufreq core fails to release a lock in an error code path after changes made in 3.14. Fix from Prarit Bhargava. - ACPICA and ACPI/GPIO fixes to make the handling of ACPI GPIO operation regions (which means AML using GPIOs) work correctly in all cases from Bob Moore and Srinivas Pandruvada. - Fix for a wrong sign of the ACPI core's create_modalias() return value in case of an error from Mika Westerberg. - ACPI backlight blacklist entry for ThinkPad X201s from Aaron Lu" * tag 'pm+acpi-3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: Revert "PM / Hibernate: Iterate over set bits instead of PFNs in swsusp_free()" gpio / ACPI: Use pin index and bit length ACPICA: Update to GPIO region handler interface. ACPI / platform / LPSS: disable async suspend/resume of LPSS devices cpufreq: release policy->rwsem on error cpufreq: fix cpufreq suspend/resume for intel_pstate ACPI / scan: Correct error return value of create_modalias() ACPI / video: disable native backlight for ThinkPad X201s ACPI / hotplug: Generate online uevents for ACPI containers
2014-09-25Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "This is probably not the kind of pull request you want to see that late in the cycle. Yet, the ACPI refactorization was problematic again and caused another two issues which need fixing. My holidays with limited internet (plus travelling) and the developer's illness didn't help either :( The details: - ACPI code was refactored out into a seperate file and as a side-effect, the i2c-core module got renamed. Jean Delvare rightfully complained about the rename being problematic for distributions. So, Mika and I thought the least problematic way to deal with it is to move all the code back into the main i2c core source file. This is mainly a huge code move with some #ifdeffery applied. No functional code changes. Our personal tests and the testbots did not find problems. (I was thinking about reverting, too, yet that would also have ~800 lines changed) - The new ACPI code also had a NULL pointer exception, thanks to Peter for finding and fixing it. - Mikko fixed a locking problem by decoupling clock_prepare and clock_enable. - Addy learnt that the datasheet was wrong and reimplemented the frequency setup according to the new algorithm. - Fan fixed an off-by-one error when copying data - Janusz fixed a copy'n'paste bug which gave a wrong error message - Sergei made sure that "don't touch" bits are not accessed" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: acpi: Fix NULL Pointer dereference i2c: move acpi code back into the core i2c: rk3x: fix divisor calculation for SCL frequency i2c: mxs: fix error message in pio transfer i2c: ismt: use correct length when copy buffer i2c: rcar: fix RCAR_IRQ_ACK_{RECV|SEND} i2c: tegra: Move clk_prepare/clk_set_rate to probe
2014-09-25Merge branches 'acpi-hotplug', 'acpi-scan', 'acpi-lpss', 'acpi-gpio' and ↵Rafael J. Wysocki
'acpi-video' * acpi-hotplug: ACPI / hotplug: Generate online uevents for ACPI containers * acpi-scan: ACPI / scan: Correct error return value of create_modalias() * acpi-lpss: ACPI / platform / LPSS: disable async suspend/resume of LPSS devices * acpi-gpio: gpio / ACPI: Use pin index and bit length ACPICA: Update to GPIO region handler interface. * acpi-video: ACPI / video: disable native backlight for ThinkPad X201s
2014-09-25i2c: move acpi code back into the coreWolfram Sang
Commit 5d98e61d337c ("I2C/ACPI: Add i2c ACPI operation region support") renamed the i2c-core module. This may cause regressions for distributions, so put the ACPI code back into the core. Reported-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Tested-by: Lan Tianyu <tianyu.lan@intel.com> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
2014-09-24cpuset: PF_SPREAD_PAGE and PF_SPREAD_SLAB should be atomic flagsZefan Li
When we change cpuset.memory_spread_{page,slab}, cpuset will flip PF_SPREAD_{PAGE,SLAB} bit of tsk->flags for each task in that cpuset. This should be done using atomic bitops, but currently we don't, which is broken. Tetsuo reported a hard-to-reproduce kernel crash on RHEL6, which happened when one thread tried to clear PF_USED_MATH while at the same time another thread tried to flip PF_SPREAD_PAGE/PF_SPREAD_SLAB. They both operate on the same task. Here's the full report: https://lkml.org/lkml/2014/9/19/230 To fix this, we make PF_SPREAD_PAGE and PF_SPREAD_SLAB atomic flags. v4: - updated mm/slab.c. (Fengguang Wu) - updated Documentation. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Kees Cook <keescook@chromium.org> Fixes: 950592f7b991 ("cpusets: update tasks' page/slab spread flags in time") Cc: <stable@vger.kernel.org> # 2.6.31+ Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-09-24sched: add macros to define bitops for task atomic flagsZefan Li
This will simplify code when we add new flags. v3: - Kees pointed out that no_new_privs should never be cleared, so we shouldn't define task_clear_no_new_privs(). we define 3 macros instead of a single one. v2: - updated scripts/tags.sh, suggested by Peter Cc: Ingo Molnar <mingo@kernel.org> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-09-24sched: fix confusing PFA_NO_NEW_PRIVS constantZefan Li
Commit 1d4457f99928 ("sched: move no_new_privs into new atomic flags") defined PFA_NO_NEW_PRIVS as hexadecimal value, but it is confusing because it is used as bit number. Redefine it as decimal bit number. Note this changes the bit position of PFA_NOW_NEW_PRIVS from 1 to 0. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Kees Cook <keescook@chromium.org> [ lizf: slightly modified subject and changelog ] Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-09-24Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull one last block fix from Jens Axboe: "We've had an issue with scsi-mq where probing takes forever. This was bisected down to the percpu changes for blk_mq_queue_enter(), and the fact we now suffer an RCU grace period when killing a queue. SCSI creates and destroys tons of queues, so this let to 10s of seconds of stalls at boot for some. Tejun has a real fix for this, but it's too involved for 3.17. So this is a temporary workaround to expedite the queue killing until we can fold in the real fix for 3.18 when that merge window opens" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe
2014-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes three issues: - if ccp is loaded on a machine without ccp, it will incorrectly activate causing all requests to fail. Fixed by preventing ccp from loading if hardware isn't available. - not all IRQs were enabled for the qat driver, leading to potential stalls when it is used - disabled buggy AVX CTR implementation in aesni" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: aesni - disable "by8" AVX CTR optimization crypto: ccp - Check for CCP before registering crypto algs crypto: qat - Enable all 32 IRQs
2014-09-24Merge tag 'media/v3.17-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "For some last time fixes: - a regression detected on Kernel 3.16 related to VBI Teletext application breakage on drivers using videobuf2 (see https://bugzilla.kernel.org/show_bug.cgi?id=84401). The bug was noticed on saa7134 (migrated to VB2 on 3.16), but also affects em28xx (migrated on 3.9 to VB2); - two additional sanity checks at videobuf2; - two fixups to restore proper VBI support at the em28xx driver; - two Kernel oops fixups (at cx24123 and cx2341x drivers); - a bug at adv7604 where an if was doing just the opposite as it would be expected; - some documentation fixups to match the behavior defined at the Kernel" * tag 'media/v3.17-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] em28xx-v4l: get rid of field "users" in struct em28xx_v4l2" [media] em28xx: fix VBI handling logic [media] DocBook media: improve the poll() documentation [media] DocBook media: fix the poll() 'no QBUF' documentation [media] vb2: fix VBI/poll regression [media] cx2341x: fix kernel oops [media] cx24123: fix kernel oops due to missing parent pointer [media] adv7604: fix inverted condition [media] media/radio: fix radio-miropcm20.c build with io.h header file [media] vb2: fix plane index sanity check in vb2_plane_cookie() [media] DocBook media: update version number and V4L2 changes [media] DocBook media: fix fieldname in struct v4l2_subdev_selection [media] vb2: fix vb2 state check when start_streaming fails [media] videobuf2-core.h: fix comment [media] videobuf2-core: add comments before the WARN_ON [media] videobuf2-dma-sg: fix for wrong GFP mask to sg_alloc_table_from_pages
2014-09-24blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probeTejun Heo
blk-mq uses percpu_ref for its usage counter which tracks the number of in-flight commands and used to synchronously drain the queue on freeze. percpu_ref shutdown takes measureable wallclock time as it involves a sched RCU grace period. This means that draining a blk-mq takes measureable wallclock time. One would think that this shouldn't matter as queue shutdown should be a rare event which takes place asynchronously w.r.t. userland. Unfortunately, SCSI probing involves synchronously setting up and then tearing down a lot of request_queues back-to-back for non-existent LUNs. This means that SCSI probing may take more than ten seconds when scsi-mq is used. This will be properly fixed by implementing a mechanism to keep q->mq_usage_counter in atomic mode till genhd registration; however, that involves rather big updates to percpu_ref which is difficult to apply late in the devel cycle (v3.17-rc6 at the moment). As a stop-gap measure till the proper fix can be implemented in the next cycle, this patch introduces __percpu_ref_kill_expedited() and makes blk_mq_freeze_queue() use it. This is heavy-handed but should work for testing the experimental SCSI blk-mq implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Christoph Hellwig <hch@infradead.org> Link: http://lkml.kernel.org/g/20140919113815.GA10791@lst.de Fixes: add703fda981 ("blk-mq: use percpu_ref for mq usage count") Cc: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-24crypto: ccp - Check for CCP before registering crypto algsTom Lendacky
If the ccp is built as a built-in module, then ccp-crypto (whether built as a module or a built-in module) will be able to load and it will register its crypto algorithms. If the system does not have a CCP this will result in -ENODEV being returned whenever a command is attempted to be queued by the registered crypto algorithms. Add an API, ccp_present(), that checks for the presence of a CCP on the system. The ccp-crypto module can use this to determine if it should register it's crypto alogorithms. Cc: stable@vger.kernel.org Reported-by: Scot Doyle <lkml14@scotdoyle.com> Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Tested-by: Scot Doyle <lkml14@scotdoyle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-09-23Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/rdma fixes from Roland Dreier: "Last late set of InfiniBand/RDMA fixes for 3.17: - fixes for the new memory region re-registration support - iSER initiator error path fixes - grab bag of small fixes for the qib and ocrdma hardware drivers - larger set of fixes for mlx4, especially in RoCE mode" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits) IB/mlx4: Fix VF mac handling in RoCE IB/mlx4: Do not allow APM under RoCE IB/mlx4: Don't update QP1 in native mode IB/mlx4: Avoid accessing netdevice when building RoCE qp1 header mlx4: Fix mlx4 reg/unreg mac to work properly with 0-mac addresses IB/core: When marshaling uverbs path, clear unused fields IB/mlx4: Avoid executing gid task when device is being removed IB/mlx4: Fix lockdep splat for the iboe lock IB/mlx4: Get upper dev addresses as RoCE GIDs when port comes up IB/mlx4: Reorder steps in RoCE GID table initialization IB/mlx4: Don't duplicate the default RoCE GID IB/mlx4: Avoid null pointer dereference in mlx4_ib_scan_netdevs() IB/iser: Bump version to 1.4.1 IB/iser: Allow bind only when connection state is UP IB/iser: Fix RX/TX CQ resource leak on error flow RDMA/ocrdma: Use right macro in query AH RDMA/ocrdma: Resolve L2 address when creating user AH mlx4: Correct error flows in rereg_mr IB/qib: Correct reference counting in debugfs qp_stats IPoIB: Remove unnecessary port query ...
2014-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If the user gives us a msg_namelen of 0, don't try to interpret anything pointed to by msg_name. From Ani Sinha. 2) Fix some bnx2i/bnx2fc randconfig compilation errors. The gist of the issue is that we firstly have drivers that span both SCSI and networking. And at the top of that chain of dependencies we have things like SCSI_FC_ATTRS and SCSI_NETLINK which are selected. But since select is a sledgehammer and ignores dependencies, everything to select's SCSI_FC_ATTRS and/or SCSI_NETLINK has to also explicitly select their dependencies and so on and so forth. Generally speaking 'select' is supposed to only be used for child nodes, those which have no dependencies of their own. And this whole chain of dependencies in the scsi layer violates that rather strongly. So just make SCSI_NETLINK depend upon it's dependencies, and so on and so forth for the things selecting it (either directly or indirectly). From Anish Bhatt and Randy Dunlap. 3) Fix generation of blackhole routes in IPSEC, from Steffen Klassert. 4) Actually notice netdev feature changes in rtl_open() code, from Hayes Wang. 5) Fix divide by zero in bond enslaving, from Nikolay Aleksandrov. 6) Missing memory barrier in sunvnet driver, from David Stevens. 7) Don't leave anycast addresses around when ipv6 interface is destroyed, from Sabrina Dubroca. 8) Don't call efx_{arch}_filter_sync_rx_mode before addr_list_lock is initialized in SFC driver, from Edward Cree. 9) Fix missing DMA error checking in 3c59x, from Neal Horman. 10) Openvswitch doesn't emit OVS_FLOW_CMD_NEW notifications accidently, fix from Samuel Gauthier. 11) pch_gbe needs to select NET_PTP_CLASSIFY otherwise we can get a build error. 12) Fix macvlan regression wherein we stopped emitting broadcast/multicast frames over software devices. From Nicolas Dichtel. 13) Fix infiniband bug due to unintended overflow of skb->cb[], from Eric Dumazet. And add an assertion so this doesn't happen again. 14) dm9000_parse_dt() should return error pointers, not NULL. From Tobias Klauser. 15) IP tunneling code uses this_cpu_ptr() in preemptible contexts, fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits) net: bcmgenet: call bcmgenet_dma_teardown in bcmgenet_fini_dma net: bcmgenet: fix TX reclaim accounting for fragments ipv4: do not use this_cpu_ptr() in preemptible context dm9000: Return an ERR_PTR() in all error conditions of dm9000_parse_dt() r8169: fix an if condition r8152: disable ALDPS ipoib: validate struct ipoib_cb size net: sched: shrink struct qdisc_skb_cb to 28 bytes tg3: Work around HW/FW limitations with vlan encapsulated frames macvlan: allow to enqueue broadcast pkt on virtual device pch_gbe: 'select' NET_PTP_CLASSIFY. scsi: Use 'depends' with LIBFC instead of 'select'. openvswitch: restore OVS_FLOW_CMD_NEW notifications genetlink: add function genl_has_listeners() lib: rhashtable: remove second linux/log2.h inclusion net: allow macvlans to move to net namespace 3c59x: Fix bad offset spec in skb_frag_dma_map 3c59x: Add dma error checking and recovery sparc: bpf_jit: fix support for ldx/stx mem and SKF_AD_VLAN_TAG can: at91_can: add missing prepare and unprepare of the clock ...
2014-09-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== pull request (net): ipsec 2014-09-22 We generate a blackhole or queueing route if a packet matches an IPsec policy but a state can't be resolved. Here we assume that dst_output() is called to kill these packets. Unfortunately this assumption is not true in all cases, so it is possible that these packets leave the system without the necessary transformations. This pull request contains two patches to fix this issue: 1) Fix for blackhole routed packets. 2) Fix for queue routed packets. Both patches are serious stable candidates. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-22net: sched: shrink struct qdisc_skb_cb to 28 bytesEric Dumazet
We cannot make struct qdisc_skb_cb bigger without impacting IPoIB, or increasing skb->cb[] size. Commit e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()") broke IPoIB. Only current offender is sch_choke, and this one do not need an absolutely precise flow key. If we store 17 bytes of flow key, its more than enough. (Its the actual size of flow_keys if it was a packed structure, but we might add new fields at the end of it later) Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: e0f31d849867 ("flow_keys: Record IP layer protocol in skb_flow_dissect()") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-22Merge branch 'for-3.17-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue fix from Tejun Heo: "create_singlethread_workqueue() is the old interface which is kept around for backward compatibility - each should be reviewed to determine whether singlethread usage was to save worker threads or for ordering guarantee and whether it's depended upon by memory reclaim path. While adding NUMA support for unbound workqueues during v3.10, I forgot to update it breaking the singlethread and ordering properties on NUMA setups. The breakage was unfortunately rather subtle and went without being reported until now. The only missing piece is __WQ_ORDERED flag which makes the unbounded workqueue use a single backend queue across different NUMA nodes. It's fixed by making create_singlethread_workqueue() wrap alloc_ordered_workqueue() so that possible future updates are inherited automatically" * 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: apply __WQ_ORDERED to create_singlethread_workqueue()
2014-09-21[media] vb2: fix VBI/poll regressionHans Verkuil
The recent conversion of saa7134 to vb2 unconvered a poll() bug that broke the teletext applications alevt and mtt. These applications expect that calling poll() without having called VIDIOC_STREAMON will cause poll() to return POLLERR. That did not happen in vb2. This patch fixes that behavior. It also fixes what should happen when poll() is called when STREAMON is called but no buffers have been queued. In that case poll() will also return POLLERR, but only for capture queues since output queues will always return POLLOUT anyway in that situation. This brings the vb2 behavior in line with the old videobuf behavior. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-09-21[media] videobuf2-core.h: fix commentHans Verkuil
The comment for start_streaming that tells the developer with which vb2 state buffers should be returned to vb2 gave the wrong state. Very confusing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-09-21ACPI / hotplug: Generate online uevents for ACPI containersRafael J. Wysocki
Commit 46394fd01 (ACPI / hotplug: Move container-specific code out of the core) removed the generation of "online" uevents for containers, because "add" uevents are now generated for them automatically when container system devices are registered. However, there are user space tools that need to be notified when the container and all of its children have been enumerated, which doesn't happen any more. For this reason, add a mechanism allowing "online" uevents to be generated for ACPI containers after enumerating the container along with all of its children. Fixes: 46394fd01 (ACPI / hotplug: Move container-specific code out of the core) Reported-and-tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: 3.14+ <stable@vger.kernel.org> # 3.14+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-09-20sched: Fix end_of_stack() and location of stack canary for architectures ↵Chuck Ebbert
using CONFIG_STACK_GROWSUP Aaron Tomlin recently posted patches [1] to enable checking the stack canary on every task switch. Looking at the canary code, I realized that every arch (except ia64, which adds some space for register spill above the stack) shares a definition of end_of_stack() that makes it the first long after the threadinfo. For stacks that grow down, this low address is correct because the stack starts at the end of the thread area and grows toward lower addresses. However, for stacks that grow up, toward higher addresses, this is wrong. (The stack actually grows away from the canary.) On these archs end_of_stack() should return the address of the last long, at the highest possible address for the stack. [1] http://lkml.org/lkml/2014/9/12/293 Signed-off-by: Chuck Ebbert <cebbert.lkml@gmail.com> Link: http://lkml.kernel.org/r/20140920101751.6c5166b6@as Signed-off-by: Ingo Molnar <mingo@kernel.org> Tested-by: James Hogan <james.hogan@imgtec.com> [metag] Acked-by: James Hogan <james.hogan@imgtec.com> Acked-by: Aaron Tomlin <atomlin@redhat.com>
2014-09-20Merge tag 'staging-3.17-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging / IIO fixes from Greg KH: "Here are some IIO and Staging driver fixes for 3.17-rc6. They are all pretty simple, and resolve reported issues" * tag 'staging-3.17-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: vt6655: buffer overflow in ioctl iio:magnetometer: bugfix magnetometers gain values iio: adc: at91: don't use the last converted data register iio: adc: xilinx-xadc: assign auxiliary channels address correctly iio: meter: ade7758: Fix indio_dev->trig assignment iio: inv_mpu6050: Fix indio_dev->trig assignment iio: gyro: itg3200: Fix indio_dev->trig assignment iio: st_sensors: Fix indio_dev->trig assignment iio: hid_sensor_hub: Fix indio_dev->trig assignment iio: adc: ad_sigma_delta: Fix indio_dev->trig assignment iio: accel: bma180: Fix indio_dev->trig assignment iio:trigger: modify return value for iio_trigger_get iio:inkern: fix overwritten -EPROBE_DEFER in of_iio_channel_get_by_name
2014-09-20Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "A bunch of radeon fixes for oops on module unload, and problems with resetting the dma engine, one nouveau fix for black boxes in rendering on my mbp retina, one sti fix, and a couple of intel fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/nouveau: ltc/gf100-: fix cbc issues on certain boards drm/bochs: add missing drm_connector_register call drm/cirrus: add missing drm_connector_register call drm/radeon: Fix typo 'addr' -> 'entry' in rs400_gart_set_page drm/nouveau/runpm: fix module unload drm/radeon/px: fix module unload vgaswitcheroo: add vga_switcheroo_fini_domain_pm_ops drm/radeon: don't reset dma on r6xx-evergreen init drm/radeon: don't reset sdma on CIK init drm/radeon: don't reset dma on NI/SI init drm/radeon/dpm: fix resume on mullins drm/radeon: Disable HDP flush before every CS again for < r600 drm/radeon: delete unused PTE_* defines drm/i915: Add limited color range readout for HDMI/DP ports on g4x/vlv/chv drm: sti: do not iterate over the info frame array drm/i915: Fix SRC_COPY width on 830/845g
2014-09-19Merge tag 'iio-fixes-3.17a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: First round of IIO fixes for the 3.17 cycle. * Fix an overwritten error return that can prevent deferred probing when using of_iio_channel_get_by_name * A series that deals with an incorrect reference count when the default trigger is set within the main probe routine for a driver. Can result in a double free if the trigger is changed. * Fix a buglet with xilinx-xadc concerning setup of the address for an aux channel. * At91 adc driver could sometimes get a touchscreen reading rather than the intended adc channel. This is fixed by using the channel data register instead. * Fix some ST magnetometer gain values that differ in production parts from the prerelease ones used for driver development.
2014-09-19genetlink: add function genl_has_listeners()Nicolas Dichtel
This function is the counterpart of the function netlink_has_listeners(). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-19Merge tag 'pci-v3.17-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "These fix: - Boot video device detection on dual-GPU Apple systems - Hotplug fiascos on VGA switcheroo with radeon & nouveau drivers - Boot hang on Freescale i.MX6 systems - Excessive "no hotplug settings from platform" warnings In particular: Enumeration - Don't default exclusively to first video device (Bruno Prémont) PCI device hotplug - Remove "no hotplug settings from platform" warning (Bjorn Helgaas) - Add pci_ignore_hotplug() for VGA switcheroo (Bjorn Helgaas) Freescale i.MX6 - Put LTSSM in "Detect" state before disabling (Lucas Stach)" * tag 'pci-v3.17-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: vgaarb: Drop obsolete #ifndef vgaarb: Don't default exclusively to first video device with mem+io ACPIPHP / radeon / nouveau: Remove acpi_bus_no_hotplug() PCI: Remove "no hotplug settings from platform" warning PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device PCI: imx6: Put LTSSM in "Detect" state before disabling it MAINTAINERS: Add Lucas Stach as co-maintainer for i.MX6 PCI driver
2014-09-19IB: ib_umem_release() should decrement mm->pinned_vm from ib_umem_getShawn Bohrer
In debugging an application that receives -ENOMEM from ib_reg_mr(), I found that ib_umem_get() can fail because the pinned_vm count has wrapped causing it to always be larger than the lock limit even with RLIMIT_MEMLOCK set to RLIM_INFINITY. The wrapping of pinned_vm occurs because the process that calls ib_reg_mr() will have its mm->pinned_vm count incremented. Later a different process with a different mm_struct than the one that allocated the ib_umem struct ends up releasing it which results in decrementing the new processes mm->pinned_vm count past zero and wrapping. I'm not entirely sure what circumstances cause a different process to release the ib_umem than the one that allocated it but the kernel stack trace of the freeing process from my situation looks like the following: Call Trace: [<ffffffff814d64b1>] dump_stack+0x19/0x1b [<ffffffffa0b522a5>] ib_umem_release+0x1f5/0x200 [ib_core] [<ffffffffa0b90681>] mlx4_ib_destroy_qp+0x241/0x440 [mlx4_ib] [<ffffffffa0b4d93c>] ib_destroy_qp+0x12c/0x170 [ib_core] [<ffffffffa0cc7129>] ib_uverbs_close+0x259/0x4e0 [ib_uverbs] [<ffffffff81141cba>] __fput+0xba/0x240 [<ffffffff81141e4e>] ____fput+0xe/0x10 [<ffffffff81060894>] task_work_run+0xc4/0xe0 [<ffffffff810029e5>] do_notify_resume+0x95/0xa0 [<ffffffff814e3dd0>] int_signal+0x12/0x17 The following patch fixes the issue by storing the pid struct of the process that calls ib_umem_get() so that ib_umem_release and/or ib_umem_account() can properly decrement the pinned_vm count of the correct mm_struct. Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Reviewed-by: Shachar Raindel <raindel@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2014-09-19[SCSI] fix regression that accidentally disabled block-based tcqChristoph Hellwig
The scsi blk-mq support accidentally flipped a conditional, which lead to never enabling block based tcq when using the legacy request path. Fixes: d285203cf647d7c9 scsi: add support for a blk-mq based I/O path. Reported-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-09-18Merge branch 'pci/vga'; commit '6a73336bde29' into for-linusBjorn Helgaas
* pci/vga: vgaarb: Drop obsolete #ifndef vgaarb: Don't default exclusively to first video device with mem+io * commit '6a73336bde29': PCI: Remove "no hotplug settings from platform" warning
2014-09-19Merge branch 'drm-fixes-3.17' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes - fix a resume hang on mullins - fix an oops on module unload with vgaswitcheroo (radeon and nouveau) - fix possible hangs DMA engine hangs due to hw bugs * 'drm-fixes-3.17' of git://people.freedesktop.org/~agd5f/linux: drm/nouveau/runpm: fix module unload drm/radeon/px: fix module unload vgaswitcheroo: add vga_switcheroo_fini_domain_pm_ops drm/radeon: don't reset dma on r6xx-evergreen init drm/radeon: don't reset sdma on CIK init drm/radeon: don't reset dma on NI/SI init drm/radeon/dpm: fix resume on mullins drm/radeon: Disable HDP flush before every CS again for < r600 drm/radeon: delete unused PTE_* defines
2014-09-18vgaswitcheroo: add vga_switcheroo_fini_domain_pm_opsAlex Deucher
Drivers should call this on unload to unregister pmops. Bug: https://bugzilla.kernel.org/show_bug.cgi?id=84431 Reviewed-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com>
2014-09-16vgaarb: Drop obsolete #ifndefBruno Prémont
Commit 20cde694027e ("x86, ia64: Move EFI_FB vga_default_device() initialization to pci_vga_fixup()") moved boot video device detection from efifb to x86 and ia64 pci/fixup.c. Remove the left-over #ifndef check that will always match since the corresponding arch-specific define is gone with above patch. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Matthew Garrett <matthew.garrett@nebula.com>
