commit 63a507800c8aca5a1891d598ae13f829346e8e39 upstream.
0x4243 is a PCI bridge, not a GPU.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=33815
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 8d661f1e462d50bd83de87ee628aaf820ce3c66c upstream.
It is defined in include/linux/ieee80211.h. As per IEEE spec.
bit6 to bit15 in block ack parameter represents buffer size.
So the bitmask should be 0xFFC0.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit 795abaf1e4e188c4171e3cd3dbb11a9fcacaf505 upstream.
Commit c0e69a5bbc6f ("klist.c: bit 0 in pointer can't be used as flag")
intended to make sure that all klist objects were at least pointer size
aligned, but used the constant "4" which only works on 32-bit.
Use "sizeof(void *)" which is correct in all cases.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
commit d14fc1a74e846d7851f24fc9519fe87dc12a1231 upstream.
Alan's commit 335f8514f200e63d689113d29cb7253a5c282967 introduced
.carrier_raised function in several drivers. That also means
tty_port_block_til_ready can now suspend the process trying to open the serial
port when Carrier Detect is low and put it into tty_port.open_wait queue. We
need to wake up the process when Carrier Detect goes high and trigger TTY
hangup when CD goes low.
Some of the devices do not report modem status line changes, or at least we
don't understand the status message, so for those we remove .carrier_raised
again.
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
commit 50b5d6ad63821cea324a5a7a19854d4de1a0a819 upstream.
ICMP protocol unreachable handling completely disregarded
the fact that the user may have locked the socket. It proceeded
to destroy the association, even though the user may have
held the lock and had a ref on the association. This resulted
in the following:
Attempt to release alive inet socket f6afcc00
[ BUG: held lock freed! ]
somenu/2672 is freeing memory f6afcc00-f6afcfff, with a lock still held
there!
(sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
1 lock held by somenu/2672:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<c122098a>] sctp_connect+0x13/0x4c
stack backtrace:
Pid: 2672, comm: somenu Not tainted 2.6.32-telco #55
Call Trace:
[<c1232266>] ? printk+0xf/0x11
[<c1038553>] debug_check_no_locks_freed+0xce/0xff
[<c10620b4>] kmem_cache_free+0x21/0x66
[<c1185f25>] __sk_free+0x9d/0xab
[<c1185f9c>] sk_free+0x1c/0x1e
[<c1216e38>] sctp_association_put+0x32/0x89
[<c1220865>] __sctp_connect+0x36d/0x3f4
[<c122098a>] ? sctp_connect+0x13/0x4c
[<c102d073>] ? autoremove_wake_function+0x0/0x33
[<c12209a8>] sctp_connect+0x31/0x4c
[<c11d1e80>] inet_dgram_connect+0x4b/0x55
[<c11834fa>] sys_connect+0x54/0x71
[<c103a3a2>] ? lock_release_non_nested+0x88/0x239
[<c1054026>] ? might_fault+0x42/0x7c
[<c11847ab>] sys_socketcall+0x6d/0x178
[<c10da994>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c1002959>] syscall_call+0x7/0xb
This was because the sctp_wait_for_connect() would aqcure the socket
lock and then proceed to release the last reference count on the
association, thus cause the fully destruction path to finish freeing
the socket.
The simplest solution is to start a very short timer in case the socket
is owned by user. When the timer expires, we can do some verification
and be able to do the release properly.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit e692cb668fdd5a712c6ed2a2d6f2a36ee83997b4 upstream.
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream.
If vfs_getattr in fill_post_wcc returns an error, we don't
set fh_post_change.
For NFSv4, this can result in set_change_info triggering a BUG_ON.
i.e. fh_post_saved being zero isn't really a bug.
So:
- instead of BUGging when fh_post_saved is zero, just clear ->atomic.
- if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway.
This will be used i seg_change_info, but not overly trusted.
- While we are there, remove the pointless 'if' statements in set_change_info.
There is no harm setting all the values.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 8acfe468b0384e834a303f08ebc4953d72fb690a upstream.
This helps protect us from overflow issues down in the
individual protocol sendmsg/recvmsg handlers. Once
we hit INT_MAX we truncate out the rest of the iovec
by setting the iov_len members to zero.
This works because:
1) For SOCK_STREAM and SOCK_SEQPACKET sockets, partial
writes are allowed and the application will just continue
with another write to send the rest of the data.
2) For datagram oriented sockets, where there must be a
one-to-one correspondance between write() calls and
packets on the wire, INT_MAX is going to be far larger
than the packet size limit the protocol is going to
check for and signal with -EMSGSIZE.
Based upon a patch by Linus Torvalds.
commit f5eb917b861828da18dc28854308068c66d1449a upstream.
Here is a patch to stop X.25 examining fields beyond the end of the packet.
For example, when a simple CALL ACCEPTED was received:
10 10 0f
x25_parse_facilities was attempting to decode the FACILITIES field, but this
packet contains no facilities field.
Signed-off-by: John Hughes <john@calva.com>
commit 1d8638d4038eb8709edc80e37a0bbb77253d86e9 upstream.
Add new vendor for Broadcom 4318.
Signed-off-by: Daniel Klaffenbach <danielklaffenbach@gmail.com>
commit c6353b4520788e34098bbf61c73fb9618ca7fdd6 upstream.
For yet unknown reason, MCP89 on MBP 7,1 doesn't work w/ ahci under
linux but the controller doesn't require explicit mode setting and
works fine with ata_generic. Make ahci ignore the controller on MBP
7,1 and let ata_generic take it for now.
Reported in bko#15923.
https://bugzilla.kernel.org/show_bug.cgi?id=15923
NVIDIA is investigating why ahci mode doesn't work.
Cc: Peer Chen <pchen@nvidia.com>
Reported-by: Anders Østhus <grapz666@gmail.com>
Reported-by: Andreas Graf <andreas_graf@csgraf.de>
Reported-by: Benoit Gschwind <gschwind@gnu-log.net>
Reported-by: Damien Cassou <damien.cassou@gmail.com>
Reported-by: tixetsal@juno.com
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
commit 892b6f90db81cccb723d5d92f4fddc2d68b206e1 upstream.
Physical block size was declared unsigned int to accomodate the maximum
size reported by READ CAPACITY(16). Make sure we use the right type in
the related functions.
commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream.
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
[ Upstream commit 01db403cf99f739f86903314a489fb420e0e254f ]
Fixes kernel bugzilla #16603
tcp_sendmsg() truncates iov_len to an 'int' which a 4GB write to write
zero bytes, for example.
There is also the problem higher up of how verify_iovec() works. It
wants to prevent the total length from looking like an error return
value.
However it does this using 'int', but syscalls return 'long' (and
thus signed 64-bit on 64-bit machines). So it could trigger
false-positives on 64-bit as written. So fix it to use 'long'.
Reported-by: Olaf Bonorden <bono@onlinehome.de>
Reported-by: Daniel Büse <dbuese@gmx.de>
Reported-by: Andrew Morton <akpm@linux-foundation.org>
commit f459ffbdfd04edb4a8ce6eea33170eb057a5e695 upstream.
fixes https://bugzilla.kernel.org/show_bug.cgi?id=19012
commit 4c894f47bb49284008073d351c0ddaac8860864e upstream.
This patch adds a workaround for an IOMMU BIOS problem to
the AMD IOMMU driver. The result of the bug is that the
IOMMU does not execute commands anymore when the system
comes out of the S3 state resulting in system failure. The
bug in the BIOS is that is does not restore certain hardware
specific registers correctly. This workaround reads out the
contents of these registers at boot time and restores them
on resume from S3. The workaround is limited to the specific
IOMMU chipset where this problem occurs.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 8ca3eb08097f6839b2206e2242db4179aee3cfb3 upstream.
pa-risc and ia64 have stacks that grow upwards. Check that
they do not run into other mappings. By making VM_GROWSUP
0x0 on architectures that do not ever use it, we can avoid
some unpleasant #ifdefs in check_stack_guard_page().
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: dann frazier <dannf@debian.org>
is low and kswapd is awake
commit aa45484031ddee09b06350ab8528bfe5b2c76d1c upstream.
Ordinarily watermark checks are based on the vmstat NR_FREE_PAGES as it is
cheaper than scanning a number of lists. To avoid synchronization
overhead, counter deltas are maintained on a per-cpu basis and drained
both periodically and when the delta is above a threshold. On large CPU
systems, the difference between the estimated and real value of
NR_FREE_PAGES can be very high. If NR_FREE_PAGES is much higher than
number of real free page in buddy, the VM can allocate pages below min
watermark, at worst reducing the real number of pages to zero. Even if
the OOM killer kills some victim for freeing memory, it may not free
memory if the exit path requires a new page resulting in livelock.
This patch introduces a zone_page_state_snapshot() function (courtesy of
Christoph) that takes a slightly more accurate view of an arbitrary vmstat
counter. It is used to read NR_FREE_PAGES while kswapd is awake to avoid
the watermark being accidentally broken. The estimate is not perfect and
may result in cache line bounces but is expected to be lighter than the
IPI calls necessary to continually drain the per-cpu counters while kswapd
is awake.
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
[ Upstream commit 01f83d69844d307be2aa6fea88b0e8fe5cbdb2f4 ]
If peer uses tiny MSS (say, 75 bytes) and similarly tiny advertised
window, the SWS logic will packetize to half the MSS unnecessarily.
This causes problems with some embedded devices.
However for large MSS devices we do want to half-MSS packetize
otherwise we never get enough packets into the pipe for things
like fast retransmit and recovery to work.
Be careful also to handle the case where MSS > window, otherwise
we'll never send until the probe timer.
Reported-by: ツ Leandro Melo de Sales <leandroal@gmail.com>
[ Upstream commit ad1af0fedba14f82b240a03fe20eb9b2fdbd0357 ]
As reported by Anton Blanchard when we use
percpu_counter_read_positive() to make our orphan socket limit checks,
the check can be off by up to num_cpus_online() * batch (which is 32
by default) which on a 128 cpu machine can be as large as the default
orphan limit itself.
Fix this by doing the full expensive sum check if the optimized check
triggers.
Reported-by: Anton Blanchard <anton@samba.org>
commit 669c55e9f99b90e46eaa0f98a67ec53d46dc969a upstream
Dave reported that his large SPARC machines spend lots of time in
hweight64(), try and optimize some of those needless cpumask_weight()
invocations (esp. with the large offstack cpumasks these are very
expensive indeed).
Reported-by: David Miller <davem@davemloft.net>
LKML-Reference: <new-submission>
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 50b926e439620c469565e8be0f28be78f5fca1ce upstream
SD_PREFER_SIBLING is set at the CPU domain level if power saving isn't
enabled, leading to many cache misses on large machines as we traverse
looking for an idle shared cache to wake to. Change the enabler of
select_idle_sibling() to SD_SHARE_PKG_RESOURCES, and enable same at the
sibling domain level.
Reported-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <1262612696.15495.15.camel@marge.simson.net>
commit 0017d735092844118bef006696a750a0e4ef6ebd upstream
Oleg noticed a few races with the TASK_WAKING usage on fork.
- since TASK_WAKING is basically a spinlock, it should be IRQ safe
- since we set TASK_WAKING (*) without holding rq->lock it could
be there still is a rq->lock holder, thereby not actually
providing full serialization.
(*) in fact we clear PF_STARTING, which in effect enables TASK_WAKING.
Cure the second issue by not setting TASK_WAKING in sched_fork(), but
only temporarily in wake_up_new_task() while calling select_task_rq().
Cure the first by holding rq->lock around the select_task_rq() call,
this will disable IRQs, this however requires that we push down the
rq->lock release into select_task_rq_fair()'s cgroup stuff.
Because select_task_rq_fair() still needs to drop the rq->lock we
cannot fully get rid of TASK_WAKING.
Reported-by: Oleg Nesterov <oleg@redhat.com>
commit 9084bb8246ea935b98320554229e2f371f7f52fa upstream
Introduce cpuset_cpus_allowed_fallback() helper to fix the cpuset problems
with select_fallback_rq(). It can be called from any context and can't use
any cpuset locks including task_lock(). It is called when the task doesn't
have online cpus in ->cpus_allowed but ttwu/etc must be able to find a
suitable cpu.
I am not proud of this patch. Everything which needs such a fat comment
can't be good even if correct. But I'd prefer to not change the locking
rules in the code I hardly understand, and in any case I believe this
simple change make the code much more correct compared to deadlocks we
currently have.
LKML-Reference: <20100315091027.GA9155@redhat.com>
commit 6a1bdc1b577ebcb65f6603c57f8347309bc4ab13 upstream
_cpu_down() changes the current task's affinity and then recovers it at
the end. The problems are well known: we can't restore old_allowed if it
was bound to the now-dead-cpu, and we can race with the userspace which
can change cpu-affinity during unplug.
_cpu_down() should not play with current->cpus_allowed at all. Instead,
take_cpu_down() can migrate the caller of _cpu_down() after __cpu_disable()
removes the dying cpu from cpu_online_mask.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
LKML-Reference: <20100315091023.GA9148@redhat.com>
cpuset_lock/cpuset_cpus_allowed_locked code
commit 897f0b3c3ff40b443c84e271bef19bd6ae885195 upstream
This patch just states the fact the cpusets/cpuhotplug interaction is
broken and removes the deadlockable code which only pretends to work.
- cpuset_lock() doesn't really work. It is needed for
cpuset_cpus_allowed_locked() but we can't take this lock in
try_to_wake_up()->select_fallback_rq() path.
- cpuset_lock() is deadlockable. Suppose that a task T bound to CPU takes
callback_mutex. If cpu_down(CPU) happens before T drops callback_mutex
stop_machine() preempts T, then migration_call(CPU_DEAD) tries to take
cpuset_lock() and hangs forever because CPU is already dead and thus
T can't be scheduled.
- cpuset_cpus_allowed_locked() is deadlockable too. It takes task_lock()
which is not irq-safe, but try_to_wake_up() can be called from irq.
Kill them, and change select_fallback_rq() to use cpu_possible_mask, like
we currently do without CONFIG_CPUSETS.
Also, with or without this patch, with or without CONFIG_CPUSETS, the
callers of select_fallback_rq() can race with each other or with
set_cpus_allowed() pathes.
The subsequent patches try to to fix these problems.
LKML-Reference: <20100315091003.GA9123@redhat.com>
commit ea87bb7853168434f4a82426dd1ea8421f9e604d upstream
The ability of enqueueing a task to the head of a SCHED_FIFO priority
list is required to fix some violations of POSIX scheduling policy.
Extend the related functions with a "head" argument.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Carsten Emde <cbe@osadl.org>
Tested-by: Mathias Weber <mathias.weber.mw1@roche.com>
LKML-Reference: <20100120171629.734886007@linutronix.de>
commit 88ec22d3edb72b261f8628226cd543589a6d5e1b upstream
In order to remove the cfs_rq dependency from set_task_cpu() we
need to ensure the task is cfs_rq invariant for all callsites.
The simple approach is to substract cfs_rq->min_vruntime from
se->vruntime on dequeue, and add cfs_rq->min_vruntime on
enqueue.
However, this has the downside of breaking FAIR_SLEEPERS since
we loose the old vruntime as we only maintain the relative
position.
To solve this, we observe that we only migrate runnable tasks,
we do this using deactivate_task(.sleep=0) and
activate_task(.wakeup=0), therefore we can restrain the
min_vruntime invariance to that state.
The only other case is wakeup balancing, since we want to
maintain the old vruntime we cannot make it relative on dequeue,
but since we don't migrate inactive tasks, we can do so right
before we activate it again.
This is where we need the new pre-wakeup hook, we need to call
this while still holding the old rq->lock. We could fold it into
->select_task_rq(), but since that has multiple callsites and
would obfuscate the locking requirements, that seems like a
fudge.
This leaves the fork() case, simply make sure that ->task_fork()
leaves the ->vruntime in a relative state.
This covers all cases where set_task_cpu() gets called, and
ensures it sees a relative vruntime.
LKML-Reference: <20091216170518.191697025@chello.nl>
commit efbbd05a595343a413964ad85a2ad359b7b7efbd upstream
As will be apparent in the next patch, we need a pre wakeup hook
for sched_fair task migration, hence rename the post wakeup hook
and one pre wakeup.
LKML-Reference: <20091216170518.114746117@chello.nl>
commit b9889ed1ddeca5a3f3569c8de7354e9e97d803ae upstream
This build warning:
kernel/sched.c: In function 'set_task_cpu':
kernel/sched.c:2070: warning: unused variable 'old_rq'
Made me realize that the forced2_migrations stat looks pretty
pointless (and a misnomer) - remove it.
commit cd29fe6f2637cc2ccbda5ac65f5332d6bf5fa3c6 upstream
Currently we try to do task placement in wake_up_new_task() after we do
the load-balance pass in sched_fork(). This yields complicated semantics
in that we have to deal with tasks on different RQs and the
set_task_cpu() calls in copy_process() and sched_fork()
Rename ->task_new() to ->task_fork() and call it from sched_fork()
before the balancing, this gives the policy a clear point to place the
task.
commit 9824a2b728b63e7ff586b9fd9293c819be79f0f3 upstream
cpu_nr_migrations() is not used, remove it.
Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
LKML-Reference: <4AF12A66.6020609@ct.jp.nec.com>
commit dba091b9e3522b9d32fc9975e48d3b69633b45f0 upstream
sched_rr_get_param calls
task->sched_class->get_rr_interval(task) without protection
against a concurrent sched_setscheduler() call which modifies
task->sched_class.
Serialize the access with task_rq_lock(task) and hand the rq
pointer into get_rr_interval() as it's needed at least in the
sched_fair implementation.
LKML-Reference: <alpine.LFD.2.00.0912090930120.3089@localhost.localdomain>
commit c41d68a513c71e35a14f66d71782d27a79a81ea6 upstream.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
commit e2f3d75fc0e4a0d03c61872bad39ffa2e74a04ff upstream.
For some mysterious reason, certain hardware reacts badly to usual EH
actions while the system is going for suspend. As the devices won't
be needed until the system is resumed, ask EH to skip usual autopsy
and recovery and proceed directly to suspend.
Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com>
commit 30da55242818a8ca08583188ebcbaccd283ad4d9 upstream.
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove
unsafe and unnecessary hardware access" changed read_msi_msg_desc() to
return the last MSI message written instead of reading it from the
device, since it may be called while the device is in a reduced
power state.
However, the pSeries platform code really does need to read messages
from the device, since they are initially written by firmware.
Therefore:
- Restore the previous behaviour of read_msi_msg_desc()
- Add new functions get_cached_msi_msg{,_desc}() which return the
- Use the new functions where appropriate
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream.
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream.
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 6cb4aff0a77cc0e6bae9475d62205319e3ebbf3f upstream.
Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes
during inode creation") contains a bug that will cause it to oops when
mounting a file system that didn't previously contain extended attributes
on a system using security.* xattrs.
The issue is that while creating the privroot during mount
reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which
dereferences the xattr root. The xattr root doesn't exist, so we get an
oops.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 upstream.
This is a real fix for problem of utime/stime values decreasing
described in the thread:
http://lkml.org/lkml/2009/11/3/522
Now cputime is accounted in the following way:
- {u,s}time in task_struct are increased every time when the thread
is interrupted by a tick (timer interrupt).
- When a thread exits, its {u,s}time are added to signal->{u,s}time,
after adjusted by task_times().
- When all threads in a thread_group exits, accumulated {u,s}time
(and also c{u,s}time) in signal struct are added to c{u,s}time
in signal struct of the group's parent.
So {u,s}time in task struct are "raw" tick count, while
{u,s}time and c{u,s}time in signal struct are "adjusted" values.
And accounted values are used by:
- task_times(), to get cputime of a thread:
This function returns adjusted values that originates from raw
{u,s}time and scaled by sum_exec_runtime that accounted by CFS.
- thread_group_cputime(), to get cputime of a thread group:
This function returns sum of all {u,s}time of living threads in
the group, plus {u,s}time in the signal struct that is sum of
adjusted cputimes of all exited threads belonged to the group.
The problem is the return value of thread_group_cputime(),
because it is mixed sum of "raw" value and "adjusted" value:
group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time)
This misbehavior can break {u,s}time monotonicity.
Assume that if there is a thread that have raw values greater
than adjusted values (e.g. interrupted by 1000Hz ticks 50 times
but only runs 45ms) and if it exits, cputime will decrease (e.g.
-5ms).
To fix this, we could do:
group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time)
But task_times() contains hard divisions, so applying it for
every thread should be avoided.
This patch fixes the above problem in the following way:
- Modify thread's exit (= __exit_signal()) not to use task_times().
It means {u,s}time in signal struct accumulates raw values instead
of adjusted values. As the result it makes thread_group_cputime()
to return pure sum of "raw" values.
- Introduce a new function thread_group_times(*task, *utime, *stime)
that converts "raw" values of thread_group_cputime() to "adjusted"
values, in same calculation procedure as task_times().
- Modify group's exit (= wait_task_zombie()) to use this introduced
thread_group_times(). It make c{u,s}time in signal struct to
have adjusted values like before this patch.
- Replace some thread_group_cputime() by thread_group_times().
This replacements are only applied where conveys the "adjusted"
cputime to users, and where already uses task_times() near by it.
(i.e. sys_times(), getrusage(), and /proc/<PID>/stat.)
This patch have a positive side effect:
- Before this patch, if a group contains many short-life threads
(e.g. runs 0.9ms and not interrupted by ticks), the group's
cputime could be invisible since thread's cputime was accumulated
after adjusted: imagine adjustment function as adj(ticks, runtime),
{adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0.
After this patch it will not happen because the adjustment is
applied after accumulated.
v2:
- remove if()s, put new variables into signal_struct.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Spencer Candland <spencer@bluehost.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <4B162517.8040909@jp.fujitsu.com>
commit 0696b711e4be45fa104c12329f617beb29c03f78 upstream.
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier
to struct timekeeper" the clock multiplier of vsyscall is updated with
the unmodified clock multiplier of the clock source and not with the
NTP adjusted multiplier of the timekeeper.
This causes user space observerable time warps:
new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf
Add a new argument "mult" to update_vsyscall() and hand in the
timekeeping internal NTP adjusted multiplier.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com>
LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com>
Signed-off-by: Kurt Garloff <garloff@suse.de>
commit 3c5d92a0cfb5103c0d5ab74d4ae6373d3af38148 upstream.
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
Acked-by: John Jolly <jjolly@suse.de>
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 38117d1495e587fbb10d6e55733139a27893cef5 upstream.
commit 06c4648d46d1b757d6b9591a86810be79818b60c upstream.
Currently such notifications are only generated when the device comes up or the
address changes. However one use case for these notifications is to enable
faster network recovery after a virtual machine migration (by causing switches
to relearn their MAC tables). A migration appears to the network stack as a
temporary loss of carrier and therefore does not trigger either of the current
conditions. Rather than adding carrier up as a trigger (which can cause issues
when interfaces a flapping) simply add an interface which the driver can use
to explicitly trigger the notification.
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
BIO_RW_* bits
commit aca27ba9618276dd2f777bcd5a1419589ccf1ca8 upstream.
Commit a82afdf (block: use the same failfast bits for bio and request)
moved BIO_RW_* bits around such that they match up with REQ_* bits.
Unfortunately, fs.h hard coded RW_MASK, RWA_MASK, READ, WRITE, READA
and SWRITE as 0, 1, 2 and 3, and expected them to match with BIO_RW_*
bits. READ/WRITE didn't change but BIO_RW_AHEAD was moved to bit 4
instead of bit 1, breaking RWA_MASK, READA and SWRITE.
This patch updates RWA_MASK, READA and SWRITE such that they match the
BIO_RW_* bits again. A follow up patch will update the definitions to
directly use BIO_RW_* bits so that this kind of breakage won't happen
again.
Neil also spotted missing RWA_MASK conversion.
Stable: The offending commit a82afdf was released with v2.6.32, so
this patch should be applied to all kernels since then but it must
_NOT_ be applied to kernels earlier than that.
Reported-and-bisected-by: Vladislav Bolkhovitin <vst@vlnb.net>
Root-caused-by: Neil Brown <neilb@suse.de>
commit ea2db495f92ad2cf3301623e60cb95b4062bc484 upstream.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit d53cdbb94a52a920d5420ed64d986c3523a56743 upstream.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
Cc: Michael Buesch <mb@bu3sch.de>
Turns out this isn't the best way to resolve this issue. The
individual patches will be applied instead.
