[ Upstream commit 61e76b178dbe7145e8d6afa84bb4ccea71918994 ]
RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination
unreachable) messages:
5 - Source address failed ingress/egress policy
6 - Reject route to destination
Now they are treated as protocol error and icmpv6_err_convert() converts them
to EPROTO.
RFC 4443 says:
"Codes 5 and 6 are more informative subsets of code 1."
Treat codes 5 and 6 as code 1 (EACCES)
Btw, connect() returning -EPROTO confuses firefox, so that fallback to
other/IPv4 addresses does not work:
https://bugzilla.mozilla.org/show_bug.cgi?id=910773
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit f46078cfcd77fa5165bf849f5e568a7ac5fa569c ]
It is not allowed for an ipv6 packet to contain multiple fragmentation
headers. So discard packets which were already reassembled by
fragmentation logic and send back a parameter problem icmp.
The updates for RFC 6980 will come in later, I have to do a bit more
research here.
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream.
This patch adds wait_event_interruptible_lock_irq_timeout(), which is a
straight-forward descendant of wait_event_interruptible_timeout() and
wait_event_interruptible_lock_irq().
The zfcp driver used to call wait_event_interruptible_timeout()
in combination with some intricate and error-prone locking. Using
wait_event_interruptible_lock_irq_timeout() as a replacement
nicely cleans up that locking.
This rework removes a situation that resulted in a locking imbalance
in zfcp_qdio_sbal_get():
BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10
last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp]
It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194
"[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new
code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit
without a required lock being held. The problem occured when a
special, non-SCSI I/O request was being submitted in process context,
when the adapter's queues had been torn down. In this case the bug
surfaced when the Fibre Channel port connection for a well-known address
was closed during a concurrent adapter shut-down procedure, which is a
rare constellation.
This patch also fixes these warnings from the sparse tool (make C=1):
drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in
'zfcp_qdio_sbal_check' - wrong count at exit
drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in
'zfcp_qdio_sbal_get' - unexpected unlock
Last but not least, we get rid of that crappy lock-unlock-lock
sequence at the beginning of the critical section.
It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
Cc: Mike Galbraith <mgalbraith@suse.de>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit cc229884d3f77ec3b1240e467e0236c3e0647c0c upstream.
This adds a way to check ring empty state after enable_cb outside any
locks. Will be used by virtio_net.
Note: there's room for more optimization: caller is likely to have a
memory barrier already, which means we might be able to get rid of a
barrier here. Deferring this optimization until we do some
benchmarking.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[wg: Backported to 3.2]
Signed-off-by: Wolfram Gloger <wmglo@dent.med.uni-muenchen.de>
pending data
[ Upstream commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1 ]
We accidentally call down to ip6_push_pending_frames when uncorking
pending AF_INET data on a ipv6 socket. This results in the following
splat (from Dave Jones):
skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:126!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth
+netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c
CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37
task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000
RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282
RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006
RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520
RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800
R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800
FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000
CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
Stack:
ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4
ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6
ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0
Call Trace:
[<ffffffff8159a9aa>] skb_push+0x3a/0x40
[<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0
[<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140
[<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0
[<ffffffff81694660>] ? udplite_getfrag+0x20/0x20
[<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0
[<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0
[<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40
[<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20
[<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0
[<ffffffff816f5d54>] tracesys+0xdd/0xe2
Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55
RIP [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP <ffff8801e6431de8>
This patch adds a check if the pending data is of address family AF_INET
and directly calls udp_push_ending_frames from udp_v6_push_pending_frames
if that is the case.
This bug was found by Dave Jones with trinity.
(Also move the initialization of fl6 below the AF_INET check, even if
not strictly necessary.)
Cc: Dave Jones <davej@redhat.com>
[ Upstream commit 8965779d2c0e6ab246c82a405236b1fb2adae6b2, with
some bits from commit b7b1bfce0bb68bd8f6e62a28295922785cc63781
("ipv6: split duplicate address detection and router solicitation timer")
to get the __ipv6_get_lladdr() used by this patch. ]
dingtianhong reported the following deadlock detected by lockdep:
[ INFO: possible circular locking dependency detected ]
3.4.24.05-0.1-default #1 Not tainted
ksoftirqd/0/3 is trying to acquire lock:
(&ndev->lock){+.+...}, at: [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120
but task is already holding lock:
(&mc->mca_lock){+.+...}, at: [<ffffffff8149d130>] mld_send_report+0x40/0x150
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&mc->mca_lock){+.+...}:
[<ffffffff810a8027>] validate_chain+0x637/0x730
[<ffffffff810a8417>] __lock_acquire+0x2f7/0x500
[<ffffffff810a8734>] lock_acquire+0x114/0x150
[<ffffffff814f691a>] rt_spin_lock+0x4a/0x60
[<ffffffff8149e4bb>] igmp6_group_added+0x3b/0x120
[<ffffffff8149e5d8>] ipv6_mc_up+0x38/0x60
[<ffffffff81480a4d>] ipv6_find_idev+0x3d/0x80
[<ffffffff81483175>] addrconf_notify+0x3d5/0x4b0
[<ffffffff814fae3f>] notifier_call_chain+0x3f/0x80
[<ffffffff81073471>] raw_notifier_call_chain+0x11/0x20
[<ffffffff813d8722>] call_netdevice_notifiers+0x32/0x60
[<ffffffff813d92d4>] __dev_notify_flags+0x34/0x80
[<ffffffff813d9360>] dev_change_flags+0x40/0x70
[<ffffffff813ea627>] do_setlink+0x237/0x8a0
[<ffffffff813ebb6c>] rtnl_newlink+0x3ec/0x600
[<ffffffff813eb4d0>] rtnetlink_rcv_msg+0x160/0x310
[<ffffffff814040b9>] netlink_rcv_skb+0x89/0xb0
[<ffffffff813eb357>] rtnetlink_rcv+0x27/0x40
[<ffffffff81403e20>] netlink_unicast+0x140/0x180
[<ffffffff81404a9e>] netlink_sendmsg+0x33e/0x380
[<ffffffff813c4252>] sock_sendmsg+0x112/0x130
[<ffffffff813c537e>] __sys_sendmsg+0x44e/0x460
[<ffffffff813c5544>] sys_sendmsg+0x44/0x70
[<ffffffff814feab9>] system_call_fastpath+0x16/0x1b
-> #0 (&ndev->lock){+.+...}:
[<ffffffff810a798e>] check_prev_add+0x3de/0x440
[<ffffffff814f6c82>] rt_read_lock+0x42/0x60
[<ffffffff8149b036>] mld_newpack+0xb6/0x160
[<ffffffff8149b18b>] add_grhead+0xab/0xc0
[<ffffffff8149d03b>] add_grec+0x3ab/0x460
[<ffffffff8149d14a>] mld_send_report+0x5a/0x150
[<ffffffff8149f99e>] igmp6_timer_handler+0x4e/0xb0
[<ffffffff8105705a>] call_timer_fn+0xca/0x1d0
[<ffffffff81057b9f>] run_timer_softirq+0x1df/0x2e0
[<ffffffff8104e8c7>] handle_pending_softirqs+0xf7/0x1f0
[<ffffffff8104ea3b>] __do_softirq_common+0x7b/0xf0
[<ffffffff8104f07f>] __thread_do_softirq+0x1af/0x210
[<ffffffff8104f1c1>] run_ksoftirqd+0xe1/0x1f0
[<ffffffff8106c7de>] kthread+0xae/0xc0
[<ffffffff814fff74>] kernel_thread_helper+0x4/0x10
actually we can just hold idev->lock before taking pmc->mca_lock,
and avoid taking idev->lock again when iterating idev->addr_list,
since the upper callers of mld_newpack() already take
read_lock_bh(&idev->lock).
Reported-by: dingtianhong <dingtianhong@huawei.com>
Cc: dingtianhong <dingtianhong@huawei.com>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Tested-by: Ding Tianhong <dingtianhong@huawei.com>
Tested-by: Chen Weilong <chenweilong@huawei.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit b1a5a34bd0b8767ea689e68f8ea513e9710b671e ]
Ver and type in pppoe_hdr should be swapped as defined by RFC2516
section-4.
[ Upstream commit c87a124a5d5e8cf8e21c4363c3372bcaf53ea190 ]
Roman Gushchin discovered that udp4_lib_lookup2() was not reloading
first item in the rcu protected list, in case the loop was restarted.
This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37
rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is
ptr->field :
In some cases, gcc caches the value or ptr->field in a register.
Use a barrier() to disallow such caching, as documented in
Documentation/atomic_ops.txt line 114
Thanks a lot to Roman for providing analysis and numerous patches.
Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru>
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream.
When we have a page fault for the address which is backed by a hugepage
under migration, the kernel can't wait correctly and do busy looping on
hugepage fault until the migration finishes. As a result, users who try
to kick hugepage migration (via soft offlining, for example) occasionally
experience long delay or soft lockup.
This is because pte_offset_map_lock() can't get a correct migration entry
or a correct page table lock for hugepage. This patch introduces
migration_entry_wait_huge() to solve this.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream.
Many callers of the wait_event_timeout() and
wait_event_interruptible_timeout() expect that the return value will be
positive if the specified condition becomes true before the timeout
elapses. However, at the moment this isn't guaranteed. If the wake-up
handler is delayed enough, the time remaining until timeout will be
calculated as 0 - and passed back as a return value - even if the
condition became true before the timeout has passed.
Fix this by returning at least 1 if the condition becomes true. This
semantic is in line with what wait_for_condition_timeout() does; see
commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious
failure under heavy load").
Daniel said "We have 3 instances of this bug in drm/i915. One case even
where we switch between the interruptible and not interruptible
wait_event_timeout variants, foolishly presuming they have the same
semantics. I very much like this."
One such bug is reported at
https://bugs.freedesktop.org/show_bug.cgi?id=64133
Signed-off-by: Imre Deak <imre.deak@intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Lukas Czerner <lczerner@redhat.com>
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ]
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c, note
that I had to add list_first_or_null_rcu to rculist.h in order
to accomodate this fix. ]
Currently, if macvlan in passthru mode is created and data are rxed and
you remove this device, following panic happens:
NULL pointer dereference at 0000000000000198
IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan]
I'm using following script to trigger this:
<script>
while [ 1 ]
do
ip link add link e1 name macvtap0 type macvtap mode passthru
ip link set e1 up
ip link set macvtap0 up
IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'`
cat /dev/tap$IFINDEX >/dev/null &
ip link del dev macvtap0
done
</script>
I run this script while "ping -f" is running on another machine to send
packets to e1 rx.
Reason of the panic is that list_first_entry() is blindly called in
macvlan_handle_frame() even if the list was empty. vlan is set to
incorrect pointer which leads to the crash.
I'm fixing this by protecting port->vlans list by rcu and by preventing
from getting incorrect pointer in case the list is empty.
Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device"
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ]
Protect the SIOCGCM* ioctl macros with parenthesis.
Reported-by: Paul Wouters <pwouters@redhat.com>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ]
Before escaping RCU protected section and adding packet into
prequeue, make sure the dst is refcounted.
Reported-by: Mike Galbraith <bitbucket@online.de>
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream.
Trying to run an application which was trying to put data into half of
memory using shmget(), we found that having a shmall value below 8EiB-8TiB
would prevent us from using anything more than 8TiB. By setting
kernel.shmall greater than 8EiB-8TiB would make the job work.
In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX.
ipc/shm.c:
458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params)
459 {
465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT;
474 if (ns->shm_tot + numpages > ns->shm_ctlall)
475 return -ENOSPC;
[akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int]
Signed-off-by: Robin Holt <holt@sgi.com>
Reported-by: Alex Thorlton <athorlton@sgi.com>
[ Upstream commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 ]
Commit 257b5358b32f ("scm: Capture the full credentials of the scm
sender") changed the credentials passing code to pass in the effective
uid/gid instead of the real uid/gid.
Obviously this doesn't matter most of the time (since normally they are
the same), but it results in differences for suid binaries when the wrong
uid/gid ends up being used.
This just undoes that (presumably unintentional) part of the commit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Cc: stable@vger.kernel.org
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ]
Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code
to reset nf_trace in nf_reset(). This is wrong and unnecessary.
nf_reset() is used in the following cases:
- when passing packets up the the socket layer, at which point we want to
release all netfilter references that might keep modules pinned while
the packet is queued. nf_trace doesn't matter anymore at this point.
- when encapsulating or decapsulating IPsec packets. We want to continue
tracing these packets after IPsec processing.
- when passing packets through virtual network devices. Only devices on
that encapsulate in IPv4/v6 matter since otherwise nf_trace is not
used anymore. Its not entirely clear whether those packets should
be traced after that, however we've always done that.
- when passing packets through virtual network devices that make the
packet cross network namespace boundaries. This is the only cases
where we clearly want to reset nf_trace and is also what the
original patch intended to fix.
Add a new function nf_reset_trace() and use it in dev_forward_skb() to
fix this properly.
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ]
A few drivers use dev_uc_sync/unsync to synchronize the
address lists from master down to slave/lower devices. In
some cases (bond/team) a single address list is synched down
to multiple devices. At the time of unsync, we have a leak
in these lower devices, because "synced" is treated as a
boolean and the address will not be unsynced for anything after
the first device/call.
Treat "synced" as a count (same as refcount) and allow all
unsync calls to work.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream.
Various drivers end up replicating the code to mmap() their memory
buffers into user space, and our core memory remapping function may be
very flexible but it is unnecessarily complicated for the common cases
to use.
Our internal VM uses pfn's ("page frame numbers") which simplifies
things for the VM, and allows us to pass physical addresses around in a
denser and more efficient format than passing a "phys_addr_t" around,
and having to shift it up and down by the page size. But it just means
that drivers end up doing that shifting instead at the interface level.
It also means that drivers end up mucking around with internal VM things
like the vma details (vm_pgoff, vm_start/end) way more than they really
need to.
So this just exports a function to map a certain physical memory range
into user space (using a phys_addr_t based interface that is much more
natural for a driver) and hides all the complexity from the driver.
Some drivers will still end up tweaking the vm_page_prot details for
things like prefetching or cacheability etc, but that's actually
relevant to the driver, rather than caring about what the page offset of
the mapping is into the particular IO memory region.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream.
This patch adds support for kvm_gfn_to_hva_cache_init functions for
reads and writes that will cross a page. If the range falls within
the same memslot, then this will be a fast operation. If the range
is split between two memslots, then the slower kvm_read_guest and
kvm_write_guest are used.
Tested: Test against kvm_clock unit tests.
Signed-off-by: Andrew Honig <ahonig@google.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream.
In UP and non-preempt respectively, the spinlocks and preemption
disable/enable points are stubbed out entirely, because there is no
regular code that can ever hit the kind of concurrency they are meant to
protect against.
However, while there is no regular code that can cause scheduling, we
_do_ end up having some exceptional (literally!) code that can do so,
and that we need to make sure does not ever get moved into the critical
region by the compiler.
In particular, get_user() and put_user() is generally implemented as
inline asm statements (even if the inline asm may then make a call
instruction to call out-of-line), and can obviously cause a page fault
and IO as a result. If that inline asm has been scheduled into the
middle of a preemption-safe (or spinlock-protected) code region, we
obviously lose.
Now, admittedly this is *very* unlikely to actually ever happen, and
we've not seen examples of actual bugs related to this. But partly
exactly because it's so hard to trigger and the resulting bug is so
subtle, we should be extra careful to get this right.
So make sure that even when preemption is disabled, and we don't have to
generate any actual *code* to explicitly tell the system that we are in
a preemption-disabled region, we need to at least tell the compiler not
to move things around the critical region.
This patch grew out of the same discussion that caused commits
79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq*
functions") and 3e2e0d2c222b ("tile: comment assumption about
__insn_mtspr for <asm/irqflags.h>") to come about.
Note for stable: use discretion when/if applying this. As mentioned,
this bug may never have actually bitten anybody, and gcc may never have
done the required code motion for it to possibly ever trigger in
practice.
Cc: Steven Rostedt <srostedt@redhat.com>
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream.
The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than
65535, and the blow backtrace is observed on locking up:
INFO: task flush-8:32:1130 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000
ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000
ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000
ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000
Call Trace:
[<ffffffff8168fc2d>] schedule+0x5d/0x70
[<ffffffff8168fccc>] io_schedule+0x8c/0xd0
[<ffffffff81324461>] get_request+0x731/0x7d0
[<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90
[<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40
[<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110
[<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0
[<ffffffff81322176>] generic_make_request+0xc6/0x120
[<ffffffff81322308>] submit_bio+0x138/0x160
[<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120
[<ffffffff811d1f61>] submit_bh+0x1f1/0x220
[<ffffffff811d48b8>] __block_write_full_page+0x228/0x340
[<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0
[<ffffffff811d8960>] ? I_BDEV+0x10/0x10
[<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100
[<ffffffff811d4ae5>] block_write_full_page+0x15/0x20
[<ffffffff811d9268>] blkdev_writepage+0x18/0x20
[<ffffffff81142527>] __writepage+0x17/0x40
[<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0
[<ffffffff81142510>] ? set_page_dirty+0x70/0x70
[<ffffffff81143a61>] generic_writepages+0x51/0x80
[<ffffffff81143ab0>] do_writepages+0x20/0x50
[<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0
[<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0
[<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0
[<ffffffff811cad43>] wb_writeback+0x1a3/0x330
[<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50
[<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70
[<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260
[<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240
[<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0
[<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260
[<ffffffff81083550>] kthread+0xc0/0xd0
[<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0
[<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0
The above trace was triggered by
"dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768"
It was previously working by accident, since another bug introduced
by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused
all drives to use maxsect=65535.
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit d8668fcb0b257d9fdcfbe5c172a99b8d85e1cd82 upstream.
The function returns type of ATAPI drives so it should return integer value.
The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since
v2.6.39 changed the type of return value from int to bool, the change would
cause all of the ATAPI class drives to be treated as TYPE_TAPE and the
max_sectors of the drives to be set to 65535 because of the commit
f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the
function would return true for all ATAPI class drives and the TYPE_TAPE is
defined as 0x01.
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d
and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter
adds an assertion to genetlink to prevent this from happening
again in the future. ]
The original name is too long.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e upstream.
If some vcpus are created before KVM_CREATE_IRQCHIP, then
irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading
to potential NULL pointer dereferences.
Fix by:
- ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called
- ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP
This is somewhat long winded because vcpu->arch.apic is created without
kvm->lock held.
Based on earlier patch by Michael Ellerman.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 331818f1c468a24e581aedcbe52af799366a9dfe upstream.
Commit bf118a342f10dafe44b14451a1392c3254629a1f (NFSv4: include bitmap
in nfsv4 get acl data) introduces the 'acl_scratch' page for the case
where we may need to decode multi-page data. However it fails to take
into account the fact that the variable may be NULL (for the case where
we're not doing multi-page decode), and it also attaches it to the
encoding xdr_stream rather than the decoding one.
The immediate result is an Oops in nfs4_xdr_enc_getacl due to the
call to page_address() with a NULL page pointer.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Andy Adamson <andros@netapp.com>
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit d740269867021faf4ce38a449353d2b986c34a67 upstream.
To avoid an explosion of request_module calls on a chain of abusive
scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon
as maximum recursion depth is hit, the error will fail all the way back
up the chain, aborting immediately.
This also has the side-effect of stopping the user's shell from attempting
to reexecute the top-level file as a shell script. As seen in the
dash source:
if (cmd != path_bshell && errno == ENOEXEC) {
*argv-- = cmd;
*argv = cmd = path_bshell;
goto repeat;
The above logic was designed for running scripts automatically that lacked
the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC,
things continue to behave as the shell expects.
Additionally, when tracking recursion, the binfmt handlers should not be
involved. The recursion being tracked is the depth of calls through
search_binary_handler(), so that function should be exclusively responsible
for tracking the depth.
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ]
This patch introduces a constant limit of the fragment queue hash
table bucket list lengths. Currently the limit 128 is choosen somewhat
arbitrary and just ensures that we can fill up the fragment cache with
empty packets up to the default ip_frag_high_thresh limits. It should
just protect from list iteration eating considerable amounts of cpu.
If we reach the maximum length in one hash bucket a warning is printed.
This is implemented on the caller side of inet_frag_find to distinguish
between the different users of inet_fragment.c.
I dropped the out of memory warning in the ipv4 fragment lookup path,
because we already get a warning by the slab allocator.
Cc: Jesper Dangaard Brouer <jbrouer@redhat.com>
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ]
a long time ago by the commit
commit 93456b6d7753def8760b423ac6b986eb9d5a4a95
Author: Denis V. Lunev <den@openvz.org>
Date: Thu Jan 10 03:23:38 2008 -0800
[IPV4]: Unify access to the routing tables.
the defenition of FIB_HASH_TABLE size has obtained wrong dependency:
it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original
code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH
This patch returns the situation to the original state.
The problem was spotted by Tingwei Liu.
Signed-off-by: Denis V. Lunev <den@openvz.org>
CC: Tingwei Liu <tingw.liu@gmail.com>
CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream.
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") introduces a link failure since
perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL:
arch/x86/power/built-in.o: In function `restore_processor_state':
(.text+0x45c): undefined reference to `perf_restore_debug_store'
Fix it by defining the dummy function appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream.
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream.
automount-support is broken on the parisc architecture, because the existing
#if list does not include a check for defined(__hppa__). The HPPA (parisc)
architecture is similiar to other 64bit Linux targets where we have to define
autofs_wqt_t (which is passed back and forth to user space) as int type which
has a size of 32bit across 32 and 64bit kernels.
During the discussion on the mailing list, H. Peter Anvin suggested to invert
the #if list since only specific platforms (specifically those who do not have
a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned
long type.
This suggestion is probably the best way to go, since Arm64 (and maybe others?)
seems to have a non-working automounter. So in the long run even for other new
upcoming architectures this inverted check seem to be the best solution, since
it will not require them to change this #if again (unless they are 64bit only).
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
CC: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
Upstream commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream.
Otherwise, ext4 file systems with the quota featured enable will get a
very confusing "No such process" error message if the quota code is
built as a module and the quota_v2 module has not been loaded.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
Acked-by: Jan Kara <jack@suse.cz>
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream.
I've still got lockdep warnings even after Alan's patch, and it seems that
yet more band aids are required to paper over similar paths for
unbind_con_driver() and unregister_con_driver(). After this hack, lockdep
warnings are finally gone.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Jiri Kosina <jkosina@suse.cz>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream.
Adjust the console layer to allow a take over call where the caller
already holds the locks. Make the fb layer lock in order.
This is partly a band aid, the fb layer is terminally confused about the
locking rules it uses for its notifiers it seems.
[akpm@linux-foundation.org: remove stray non-ascii char, tidy comment]
[akpm@linux-foundation.org: export do_take_over_console()]
[airlied: cleanup another non-ascii char]
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream.
The utf8s_to_utf16s conversion routine needs to be improved. Unlike
its utf16s_to_utf8s sibling, it doesn't accept arguments specifying
the maximum length of the output buffer or the endianness of its
16-bit output.
This patch (as1501) adds the two missing arguments, and adjusts the
only two places in the kernel where the function is called. A
follow-on patch will add a third caller that does utilize the new
capabilities.
The two conversion routines are still annoyingly inconsistent in the
way they handle invalid byte combinations. But that's a subject for a
different patch.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Clemens Ladisch <clemens@ladisch.de>
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream.
Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer:
parse descriptors with structs" introduced a set of useful parsers
for descriptors. Unfortunately the parses for the Processing Unit
Descriptor came with a very subtle bug...
Functions uac_processing_unit_iProcessing() and
uac_processing_unit_specific() were indexing the baSourceID array
forgetting the fields before the iProcessing and process-specific
descriptors.
The problem was observed with Sound Blaster Extigy mixer,
where nNrModes in Up/Down-mix Processing Unit Descriptor
was accessed at offset 10 of the descriptor (value 0)
instead of offset 15 (value 7). In result the resulting
control had interesting limit values:
Simple mixer control 'Channel Routing Mode Select',0
Capabilities: volume volume-joined penum
Playback channels: Mono
Capture channels: Mono
Limits: 0 - -1
Mono: -1 [100%]
Fixed by starting from the bmControls, which was calculated
correctly, instead of baSourceID.
Now the mentioned control is fine:
Limits: 0 - 6
Mono: 0 [0%]
Signed-off-by: Pawel Moll <mail@pawelmoll.com>
schedule
commit 21a92735f660eaecf69a6f2e777f18463760ec32 upstream.
With an RCU based mmu_notifier implementation, any callout to
mmu_notifier_invalidate_range_{start,end}() or
mmu_notifier_invalidate_page() would not be allowed to call schedule()
as that could potentially allow a modification to the mmu_notifier
structure while it is currently being used.
Since srcu allocs 4 machine words per instance per cpu, we may end up
with memory exhaustion if we use srcu per mm. So all mms share a global
srcu. Note that during large mmu_notifier activity exit & unregister
paths might hang for longer periods, but it is tolerable for current
mmu_notifier clients.
Signed-off-by: Sagi Grimberg <sagig@mellanox.co.il>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Haggai Eran <haggaie@mellanox.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
call_console_drivers
This patch corrects a buffer overflow in kernels from 3.0 to 3.4 when calling
log_prefix() function from call_console_drivers().
This bug existed in previous releases but has been revealed with commit
162a7e7500f9664636e649ba59defe541b7c2c60 (2.6.39 => 3.0) that made changes
about how to allocate memory for early printk buffer (use of memblock_alloc).
It disappears with commit 7ff9554bb578ba02166071d2d487b7fc7d860d62 (3.4 => 3.5)
that does a refactoring of printk buffer management.
In log_prefix(), the access to "p[0]", "p[1]", "p[2]" or
"simple_strtoul(&p[1], &endp, 10)" may cause a buffer overflow as this
function is called from call_console_drivers by passing "&LOG_BUF(cur_index)"
where the index must be masked to do not exceed the buffer's boundary.
The trick is to prepare in call_console_drivers() a buffer with the necessary
data (PRI field of syslog message) to be safely evaluated in log_prefix().
This patch can be applied to stable kernel branches 3.0.y, 3.2.y and 3.4.y.
Without this patch, one can freeze a server running this loop from shell :
$ export DUMMY=`cat /dev/urandom | tr -dc '12345AZERTYUIOPQSDFGHJKLMWXCVBNazertyuiopqsdfghjklmwxcvbn' | head -c255`
$ while true do ; echo $DUMMY > /dev/kmsg ; done
The "server freeze" depends on where memblock_alloc does allocate printk buffer :
if the buffer overflow is inside another kernel allocation the problem may not
be revealed, else the server may hangs up.
Signed-off-by: Alexandre SIMON <Alexandre.Simon@univ-lorraine.fr>
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream.
They don't always appear as AHCI class devices but instead as IDE class.
Based on an initial patch by Hiroaki Nito
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit 115c9b81928360d769a76c632bae62d15206a94a upstream.
Implement a new netlink attribute type IFLA_EXT_MASK. The mask
is a 32 bit value that can be used to indicate to the kernel that
certain extended ifinfo values are requested by the user application.
At this time the only mask value defined is RTEXT_FILTER_VF to
indicate that the user wants the ifinfo dump to send information
about the VFs belonging to the interface.
This patch fixes a bug in which certain applications do not have
large enough buffers to accommodate the extra information returned
by the kernel with large numbers of SR-IOV virtual functions.
Those applications will not send the new netlink attribute with
the interface info dump request netlink messages so they will
not get unexpectedly large request buffers returned by the kernel.
Modifies the rtnl_calcit function to traverse the list of net
devices and compute the minimum buffer size that can hold the
info dumps of all matching devices based upon the filter passed
in via the new netlink attribute filter mask. If no filter
mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE.
With this change it is possible to add yet to be defined netlink
attributes to the dump request which should make it fairly extensible
in the future.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Acked-by: Greg Rose <gregory.v.rose@intel.com>
[bwh: Backported to 3.0:
- Adjust context
- Drop the change in do_setlink() that reverts commit f18da1456581
('net: RTNETLINK adjusting values of min_ifinfo_dump_size'), which
was never applied here]
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream.
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
Cc: Ben Hutchings <bhutchings@solarflare.com>
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
