commit 81cf4a45360f70528f1f64ba018d61cb5767249a upstream.
As most of BOS descriptors are longer in length than their header
'struct usb_dev_cap_header', comparing solely with it is not sufficient
to avoid out-of-bounds access to BOS descriptors.
This patch adds descriptor type specific length check in
usb_get_bos_descriptor() to fix the issue.
Signed-off-by: Masakazu Mokuno <masakazu.mokuno@gmail.com>
commit 446fa3a95df1e8b78f25e1babc41e46edd200821 upstream.
The SuperspeedPlus Device Capability Descriptor has a variable size
depending on the number of sublink speed attributes.
This patch adds a macro to calculate that size. The macro takes one
argument, the Sublink Speed Attribute Count (SSAC) as reported by the
descriptor in bmAttributes[4:0].
See USB 3.1 9.6.2.5, Table 9-19.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit faee822c5a7ab99de25cd34fcde3f8d37b6b9923 upstream.
USB 3.1 devices that support precision time measurement have an
additional PTM cabaility descriptor as part of the full BOS descriptor
Look for this descriptor while parsing the BOS descriptor, and store it in
struct usb_hub_bos if it exists.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
[ Upstream commit 0911d0041c22922228ca52a977d7b0b0159fee4b ]
Some ->page_mkwrite handlers may return VM_FAULT_RETRY as its return
code (GFS2 or Lustre can definitely do this). However VM_FAULT_RETRY
from ->page_mkwrite is completely unhandled by the mm code and results
in locking and writeably mapping the page which definitely is not what
the caller wanted.
Fix Lustre and block_page_mkwrite_ret() used by other filesystems
(notably GFS2) to return VM_FAULT_NOPAGE instead which results in
bailing out from the fault code, the CPU then retries the access, and we
fault again effectively doing what the handler wanted.
Link: http://lkml.kernel.org/r/20170203150729.15863-1-jack@suse.cz
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Jinshan Xiong <jinshan.xiong@intel.com>
Cc: Matthew Wilcox <willy@infradead.org>
commit cf33c1ee5254c6a430bc1538232b49c3ea13e613 upstream.
This patch try to fix the building error on MIPS. The reason is MIPS
has already defined the PTR macro, which conflicts with the PTR macro
in include/uapi/linux/bcache.h.
[fixed by mlyle: corrected a line-length issue]
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Reviewed-by: Michael Lyle <mlyle@lyle.org>
Signed-off-by: Michael Lyle <mlyle@lyle.org>
commit fc9e50f5a5a4e1fa9ba2756f745a13e693cf6a06 upstream.
The start callback allows the caller to set up a context for the
dump callbacks. Presumably, the context can then be destroyed in
the done callback.
Signed-off-by: Tom Herbert <tom@herbertland.com>
commit e9d4bf219c83d09579bc62512fea2ca10f025d93 upstream.
There is no guarantee that either the request or the svc_xprt exist
by the time we get round to printing the trace message.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit f86e4271978bd93db466d6a95dad4b0fdcdb04f6 upstream.
Per the discussion with Joonsoo Kim [1], we need check the return value
of lookup_page_ext() for all call sites since it might return NULL in
some cases, although it is unlikely, i.e. memory hotplug.
Tested with ltp with "page_owner=0".
[1] http://lkml.kernel.org/r/20160519002809.GA10245@js1304-P5Q-DELUXE
[akpm@linux-foundation.org: fix build-breaking typos]
[arnd@arndb.de: fix build problems from lookup_page_ext]
Link: http://lkml.kernel.org/r/6285269.2CksypHdYp@wuerfel
Link: http://lkml.kernel.org/r/1464023768-31025-1-git-send-email-yang.shi@linaro.org
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Signed-off-by: Michal Hocko <mhocko@suse.com>
commit d135e5750205a21a212a19dbb05aeb339e2cbea7 upstream.
In reset_deferred_meminit() we determine number of pages that must not
be deferred. We initialize pages for at least 2G of memory, but also
pages for reserved memory in this node.
The reserved memory is determined in this function:
memblock_reserved_memory_within(), which operates over physical
addresses, and returns size in bytes. However, reset_deferred_meminit()
assumes that that this function operates with pfns, and returns page
count.
The result is that in the best case machine boots slower than expected
due to initializing more pages than needed in single thread, and in the
worst case panics because fewer than needed pages are initialized early.
Link: http://lkml.kernel.org/r/20171021011707.15191-1-pasha.tatashin@oracle.com
Fixes: 864b9a393dcb ("mm: consider memblock reservations for deferred memory initialization sizing")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
[ Upstream commit 2b5ec1a5f9738ee7bf8f5ec0526e75e00362c48f ]
When run ipvs in two different network namespace at the same host, and one
ipvs transport network traffic to the other network namespace ipvs.
'ipvs_property' flag will make the second ipvs take no effect. So we should
clear 'ipvs_property' when SKB network namespace changed.
Fixes: 621e84d6f373 ("dev: introduce skb_scrub_packet()")
Signed-off-by: Ye Yin <hustcat@gmail.com>
Signed-off-by: Wei Zhou <chouryzhou@gmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit feb0869d90e51ce8b6fd8a46588465b1b5a26d09 ]
Consistently use types from linux/types.h to fix the following
linux/rds.h userspace compilation errors:
/usr/include/linux/rds.h:106:2: error: unknown type name 'uint8_t'
uint8_t name[32];
/usr/include/linux/rds.h:107:2: error: unknown type name 'uint64_t'
uint64_t value;
/usr/include/linux/rds.h:117:2: error: unknown type name 'uint64_t'
uint64_t next_tx_seq;
/usr/include/linux/rds.h:118:2: error: unknown type name 'uint64_t'
uint64_t next_rx_seq;
/usr/include/linux/rds.h:121:2: error: unknown type name 'uint8_t'
uint8_t transport[TRANSNAMSIZ]; /* null term ascii */
/usr/include/linux/rds.h:122:2: error: unknown type name 'uint8_t'
uint8_t flags;
/usr/include/linux/rds.h:129:2: error: unknown type name 'uint64_t'
uint64_t seq;
/usr/include/linux/rds.h:130:2: error: unknown type name 'uint32_t'
uint32_t len;
/usr/include/linux/rds.h:135:2: error: unknown type name 'uint8_t'
uint8_t flags;
/usr/include/linux/rds.h:139:2: error: unknown type name 'uint32_t'
uint32_t sndbuf;
/usr/include/linux/rds.h:144:2: error: unknown type name 'uint32_t'
uint32_t rcvbuf;
/usr/include/linux/rds.h:145:2: error: unknown type name 'uint64_t'
uint64_t inum;
/usr/include/linux/rds.h:153:2: error: unknown type name 'uint64_t'
uint64_t hdr_rem;
/usr/include/linux/rds.h:154:2: error: unknown type name 'uint64_t'
uint64_t data_rem;
/usr/include/linux/rds.h:155:2: error: unknown type name 'uint32_t'
uint32_t last_sent_nxt;
/usr/include/linux/rds.h:156:2: error: unknown type name 'uint32_t'
uint32_t last_expected_una;
/usr/include/linux/rds.h:157:2: error: unknown type name 'uint32_t'
uint32_t last_seen_una;
/usr/include/linux/rds.h:164:2: error: unknown type name 'uint8_t'
uint8_t src_gid[RDS_IB_GID_LEN];
/usr/include/linux/rds.h:165:2: error: unknown type name 'uint8_t'
uint8_t dst_gid[RDS_IB_GID_LEN];
/usr/include/linux/rds.h:167:2: error: unknown type name 'uint32_t'
uint32_t max_send_wr;
/usr/include/linux/rds.h:168:2: error: unknown type name 'uint32_t'
uint32_t max_recv_wr;
/usr/include/linux/rds.h:169:2: error: unknown type name 'uint32_t'
uint32_t max_send_sge;
/usr/include/linux/rds.h:170:2: error: unknown type name 'uint32_t'
uint32_t rdma_mr_max;
/usr/include/linux/rds.h:171:2: error: unknown type name 'uint32_t'
uint32_t rdma_mr_size;
/usr/include/linux/rds.h:212:9: error: unknown type name 'uint64_t'
typedef uint64_t rds_rdma_cookie_t;
/usr/include/linux/rds.h:215:2: error: unknown type name 'uint64_t'
uint64_t addr;
/usr/include/linux/rds.h:216:2: error: unknown type name 'uint64_t'
uint64_t bytes;
/usr/include/linux/rds.h:221:2: error: unknown type name 'uint64_t'
uint64_t cookie_addr;
/usr/include/linux/rds.h:222:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:228:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:229:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:234:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:240:2: error: unknown type name 'uint64_t'
uint64_t local_vec_addr;
/usr/include/linux/rds.h:241:2: error: unknown type name 'uint64_t'
uint64_t nr_local;
/usr/include/linux/rds.h:242:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:243:2: error: unknown type name 'uint64_t'
uint64_t user_token;
/usr/include/linux/rds.h:248:2: error: unknown type name 'uint64_t'
uint64_t local_addr;
/usr/include/linux/rds.h:249:2: error: unknown type name 'uint64_t'
uint64_t remote_addr;
/usr/include/linux/rds.h:252:4: error: unknown type name 'uint64_t'
uint64_t compare;
/usr/include/linux/rds.h:253:4: error: unknown type name 'uint64_t'
uint64_t swap;
/usr/include/linux/rds.h:256:4: error: unknown type name 'uint64_t'
uint64_t add;
/usr/include/linux/rds.h:259:4: error: unknown type name 'uint64_t'
uint64_t compare;
/usr/include/linux/rds.h:260:4: error: unknown type name 'uint64_t'
uint64_t swap;
/usr/include/linux/rds.h:261:4: error: unknown type name 'uint64_t'
uint64_t compare_mask;
/usr/include/linux/rds.h:262:4: error: unknown type name 'uint64_t'
uint64_t swap_mask;
/usr/include/linux/rds.h:265:4: error: unknown type name 'uint64_t'
uint64_t add;
/usr/include/linux/rds.h:266:4: error: unknown type name 'uint64_t'
uint64_t nocarry_mask;
/usr/include/linux/rds.h:269:2: error: unknown type name 'uint64_t'
uint64_t flags;
/usr/include/linux/rds.h:270:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:274:2: error: unknown type name 'uint64_t'
/usr/include/linux/rds.h:275:2: error: unknown type name 'int32_t'
int32_t status;
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
[ Upstream commit 1786dbf3702e33ce3afd2d3dbe630bd04b1d2e58 ]
On the kernel side, sockaddr_storage is #define'd to
__kernel_sockaddr_storage. Replacing struct sockaddr_storage with
struct __kernel_sockaddr_storage defined by <linux/socket.h> fixes
the following linux/rds.h userspace compilation error:
/usr/include/linux/rds.h:226:26: error: field 'dest_addr' has incomplete type
struct sockaddr_storage dest_addr;
This reverts commit ad50561ba7a664bc581826c9d57d137fcf17bfa5.
There was a mixup with the commit message for two upstream commit
that have the same subject line.
This revert will be followed by the two commits with proper commit
messages.
commit 8f235d1a3eb7198affe7cadf676a10afb8a46a1a upstream.
__phys_to_pfn and __pfn_to_phys are symmetric, PHYS_PFN and PFN_PHYS are
semmetric:
- y = (phys_addr_t)x << PAGE_SHIFT
- y >> PAGE_SHIFT = (phys_add_t)x
- (unsigned long)(y >> PAGE_SHIFT) = x
[akpm@linux-foundation.org: use macro arg name `x']
[arnd@arndb.de: include linux/pfn.h for PHYS_PFN definition]
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Cc: Marcin Nowakowski <marcin.nowakowski@mips.com>
[ Upstream commit d97556c8012015901a3ce77f46960078139cd79d ]
We need to also have OFFPULLUDENABLE bit set to use the off mode pull values.
Otherwise the line is pulled down internally if no external pull exists.
This is has some documentation at:
http://processors.wiki.ti.com/index.php/Optimizing_OMAP35x_and_AM/DM37x_OFF_mode_PAD_configuration
Note that the value is still glitchy during off mode transitions as documented
in spz319f.pdf "Advisory 1.45". It's best to use external pulls instead of
relying on the internal ones for off mode and even then anything pulled up
will get driven down momentarily on off mode restore for GPIO banks other
than bank1.
commit 59b6986dbfcdab96a971f9663221849de79a7556 upstream.
Allocate a task management request structure for all task management
requests, including task reassignment. This change avoids that the
se_tmr->response assignment dereferences an uninitialized se_tmr
pointer.
Reported-by: Moshe David <mdavid@infinidat.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Cc: Moshe David <mdavid@infinidat.com>
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ]
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
Reported-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit c92e8c02fe664155ac4234516e32544bec0f113d ]
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
[ Upstream commit 0ad646c81b2182f7fa67ec0c8c825e0ee165696d ]
register_netdevice() could fail early when we have an invalid
dev name, in which case ->ndo_uninit() is not called. For tun
device, this is a problem because a timer etc. are already
initialized and it expects ->ndo_uninit() to clean them up.
We could move these initializations into a ->ndo_init() so
that register_netdevice() knows better, however this is still
complicated due to the logic in tun_detach().
Therefore, I choose to just call dev_get_valid_name() before
register_netdevice(), which is quicker and much easier to audit.
And for this specific case, it is already enough.
Fixes: 96442e42429e ("tuntap: choose the txq based on rxq")
Reported-by: Dmitry Alexeev <avekceeb@gmail.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
[ Upstream commit 2b7cda9c35d3b940eb9ce74b30bbd5eb30db493d ]
Based on SNMP values provided by Roman, Yuchung made the observation
that some crashes in tcp_sacktag_walk() might be caused by MTU probing.
Looking at tcp_mtu_probe(), I found that when a new skb was placed
in front of the write queue, we were not updating tcp highest sack.
If one skb is freed because all its content was copied to the new skb
(for MTU probing), then tp->highest_sack could point to a now freed skb.
Bad things would then happen, including infinite loops.
This patch renames tcp_highest_sack_combine() and uses it
from tcp_mtu_probe() to fix the bug.
Note that I also removed one test against tp->sacked_out,
since we want to replace tp->highest_sack regardless of whatever
condition, since keeping a stale pointer to freed skb is a recipe
for disaster.
Fixes: a47e5a988a57 ("[TCP]: Convert highest_sack to sk_buff to allow direct access")
Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reported-by: Roman Gushchin <guro@fb.com>
Reported-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
commit 3510c7aa069aa83a2de6dab2b41401a198317bdc upstream.
The recent fix for adding rwsem nesting annotation was using the given
"hop" argument as the lock subclass key. Although the idea itself
works, it may trigger a kernel warning like:
BUG: looking up invalid subclass: 8
since the lockdep has a smaller number of subclasses (8) than we
currently allow for the hops there (10).
The current definition is merely a sanity check for avoiding the too
deep delivery paths, and the 8 hops are already enough. So, as a
quick fix, just follow the max hops as same as the max lockdep
subclasses.
Fixes: 1f20f9ff57ca ("ALSA: seq: Fix nested rwsem annotation for lockdep splat")
Reported-by: syzbot <syzkaller@googlegroups.com>
commit 7c4788950ba5922fde976d80b72baf46f14dee8d upstream.
I recently encountered wreckage because access_ok() was used where it
should not be, add an explicit WARN when access_ok() is used wrongly.
[add include/preempt.h to fix build error - gregkh]
commit 2b02c20ce0c28974b44e69a2e2f5ddc6a470ad6f upstream.
Some firmwares in Huawei E3372H devices have been observed to switch back
to NTB 32-bit format after altsetting switch.
This patch implements a driver flag to check for the device settings and
set NTB format to 16-bit again if needed.
The flag has been activated for devices controlled by the huawei_cdc_ncm.c
driver.
V1->V2:
- fixed broken error checks
- some corrections to the commit message
V2->V3:
- variable name changes, to clarify what's happening
- check (and possibly set) the NTB format later in the common bind code path
Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com>
Reported-and-tested-by: Christian Panton <christian@panton.org>
Reviewed-by: Bjørn Mork <bjorn@mork.no>
CC: Bjørn Mork <bjorn@mork.no>
CC: Christian Panton <christian@panton.org>
CC: linux-usb@vger.kernel.org
CC: netdev@vger.kernel.org
CC: Oliver Neukum <oliver@neukum.org>
Cc: Porto Rio <porto.rio@gmx.net>
[ Upstream commit 4567d686f5c6d955e57a3afa1741944c1e7f4033 ]
Some bus names are pretty long and do not fit into
17 chars. Increase therefore MII_BUS_ID_SIZE and
phy_fixup.bus_id to larger number. Now mii_bus.id
can host larger name.
Signed-off-by: Volodymyr Bendiuga <volodymyr.bendiuga@gmail.com>
Signed-off-by: Magnus Öberg <magnus.oberg@westermo.se>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
commit a2b4a79b88b24c49d98d45a06a014ffd22ada1a4 upstream.
The SPI_IOC_MESSAGE() macro references _IOC_SIZEBITS. Add linux/ioctl.h
to make sure this macro is defined. This fixes the following build
failure of lcdproc with the musl libc:
In file included from .../sysroot/usr/include/sys/ioctl.h:7:0,
from hd44780-spi.c:31:
hd44780-spi.c: In function 'spi_transfer':
hd44780-spi.c:89:24: error: '_IOC_SIZEBITS' undeclared (first use in this function)
status = ioctl(p->fd, SPI_IOC_MESSAGE(1), &xfer);
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
commit 2bbbd96357ce76cc45ec722c00f654aa7b189112 upstream.
At least the Armada XP SoC supports 4GB on a single DRAM window. Because
the size register values contain the actual size - 1, the MSB is set in
that case. For example, the SDRAM window's control register's value is
0xffffffe1 for 4GB (bits 31 to 24 contain the size).
The MBUS driver reads back each window's size from registers and
calculates the actual size as (control_reg | ~DDR_SIZE_MASK) + 1, which
overflows for 32 bit values, resulting in other miscalculations further
on (a bad RAM window for the CESA crypto engine calculated by
mvebu_mbus_setup_cpu_target_nooverlap() in my case).
This patch changes the type in 'struct mbus_dram_window' from u32 to
u64, which allows us to keep using the same register calculation code in
most MBUS-using drivers (which calculate ->size - 1 again).
Fixes: fddddb52a6c4 ("bus: introduce an Marvell EBU MBus driver")
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
[ Upstream commit 72aa107df6a275cf03359934ca5799a2be7a1bf7 ]
Include <linux/in6.h> to fix the following linux/mroute6.h userspace
compilation errors:
/usr/include/linux/mroute6.h:80:22: error: field 'mf6cc_origin' has incomplete type
struct sockaddr_in6 mf6cc_origin; /* Origin of mcast */
/usr/include/linux/mroute6.h:81:22: error: field 'mf6cc_mcastgrp' has incomplete type
struct sockaddr_in6 mf6cc_mcastgrp; /* Group in question */
/usr/include/linux/mroute6.h:91:22: error: field 'src' has incomplete type
struct sockaddr_in6 src;
/usr/include/linux/mroute6.h:92:22: error: field 'grp' has incomplete type
struct sockaddr_in6 grp;
/usr/include/linux/mroute6.h:132:18: error: field 'im6_src' has incomplete type
struct in6_addr im6_src, im6_dst;
/usr/include/linux/mroute6.h:132:27: error: field 'im6_dst' has incomplete type
uint8_t name[32];
uint64_t value;
uint8_t flags;
uint64_t seq;
uint32_t len;
uint8_t flags;
uint32_t sndbuf;
uint32_t rcvbuf;
uint64_t inum;
uint64_t hdr_rem;
uint64_t data_rem;
uint64_t addr;
uint64_t bytes;
uint64_t flags;
uint64_t flags;
uint64_t flags;
uint64_t nr_local;
uint64_t flags;
uint64_t compare;
uint64_t swap;
uint64_t add;
uint64_t compare;
uint64_t swap;
uint64_t swap_mask;
uint64_t add;
uint64_t flags;
int32_t status;
[ Upstream commit ec9dd352d591f0c90402ec67a317c1ed4fb2e638 ]
This patch fixes a bug exhibited by the following scenario:
1. fd1 = perf_event_open with attr.config = ID1
2. attach bpf program prog1 to fd1
3. fd2 = perf_event_open with attr.config = ID1
<this will be successful>
4. user program closes fd2 and prog1 is detached from the tracepoint.
5. user program with fd1 does not work properly as tracepoint
no output any more.
The issue happens at step 4. Multiple perf_event_open can be called
successfully, but only one bpf prog pointer in the tp_event. In the
current logic, any fd release for the same tp_event will free
the tp_event->prog.
The fix is to free tp_event->prog only when the closing fd
corresponds to the one which registered the program.
Signed-off-by: Yonghong Song <yhs@fb.com>
[ Upstream commit fa5f7b51fc3080c2b195fa87c7eca7c05e56f673 ]
This code causes a static checker warning because Smatch doesn't trust
anything that comes from skb->data. I've reviewed this code and I do
think skb->data can be controlled by the user here.
The sctp_event_subscribe struct has 13 __u8 fields and we want to see
if ours is non-zero. sn_type can be any value in the 0-USHRT_MAX range.
We're subtracting SCTP_SN_TYPE_BASE which is 1 << 15 so we could read
either before the start of the struct or after the end.
This is a very old bug and it's surprising that it would go undetected
for so long but my theory is that it just doesn't have a big impact so
it would be hard to notice.
commit e88d62cd4b2f0b1ae55e9008e79c2794b1fc914d upstream.
As raw_cpu_generic_read() is a plain read from a raw_cpu_ptr() address,
it's possible (albeit unlikely) that the compiler will split the access
across multiple instructions.
In this_cpu_generic_read() we disable preemption but not interrupts
before calling raw_cpu_generic_read(). Thus, an interrupt could be taken
in the middle of the split load instructions. If a this_cpu_write() or
RMW this_cpu_*() op is made to the same variable in the interrupt
handling path, this_cpu_read() will return a torn value.
For native word types, we can avoid tearing using READ_ONCE(), but this
won't work in all cases (e.g. 64-bit types on most 32-bit platforms).
This patch reworks this_cpu_generic_read() to use READ_ONCE() where
possible, otherwise falling back to disabling interrupts.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
[Mark: backport to v4.4.y]
commit 5803b023881857db32ffefa0d269c90280a67ee0 upstream.
The event handler in the virmidi sequencer code takes a read-lock for
the linked list traverse, while it's calling snd_seq_dump_var_event()
in the loop. The latter function may expand the user-space data
depending on the event type. It eventually invokes copy_from_user(),
which might be a potential dead-lock.
The sequencer core guarantees that the user-space data is passed only
with atomic=0 argument, but snd_virmidi_dev_receive_event() ignores it
and always takes read-lock(). For avoiding the problem above, this
patch introduces rwsem for non-atomic case, while keeping rwlock for
atomic case.
Also while we're at it: the superfluous irq flags is dropped in
snd_virmidi_input_open().
Reported-by: Jia-Ju Bai <baijiaju1990@163.com>
commit 50e76632339d4655859523a39249dd95ee5e93e7 upstream.
Cpusets vs. suspend-resume is _completely_ broken. And it got noticed
because it now resulted in non-cpuset usage breaking too.
On suspend cpuset_cpu_inactive() doesn't call into
cpuset_update_active_cpus() because it doesn't want to move tasks about,
there is no need, all tasks are frozen and won't run again until after
we've resumed everything.
But this means that when we finally do call into
cpuset_update_active_cpus() after resuming the last frozen cpu in
cpuset_cpu_active(), the top_cpuset will not have any difference with
the cpu_active_mask and this it will not in fact do _anything_.
So the cpuset configuration will not be restored. This was largely
hidden because we would unconditionally create identity domains and
mobile users would not in fact use cpusets much. And servers what do use
cpusets tend to not suspend-resume much.
An addition problem is that we'd not in fact wait for the cpuset work to
finish before resuming the tasks, allowing spurious migrations outside
of the specified domains.
Fix the rebuild by introducing cpuset_force_rebuild() and fix the
ordering with cpuset_wait_for_hotplug().
Reported-by: Andy Lutomirski <luto@kernel.org>
Cc: <stable@vger.kernel.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Fixes: deb7aa308ea2 ("cpuset: reorganize CPU / memory hotplug handling")
Link: http://lkml.kernel.org/r/20170907091338.orwxrqkbfkki3c24@hirez.programming.kicks-ass.net
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 7fc10de8d49a748c476532c9d8e8fe19e548dd67 upstream.
Since most of the SD ADCs have the option of reseting the serial
interface by sending a number of SCLKs with CS = 0 and DIN = 1,
a dedicated function that can do this is usefull.
Needed for the patch: iio: ad7793: Fix the serial interface reset
Signed-off-by: Dragos Bogdan <dragos.bogdan@analog.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit bd7a3fe770ebd8391d1c7d072ff88e9e76d063eb upstream.
Andrey Konovalov reported a possible out-of-bounds problem for a USB interface
association descriptor. He writes:
It seems there's no proper size check of a USB_DT_INTERFACE_ASSOCIATION
descriptor. It's only checked that the size is >= 2 in
usb_parse_configuration(), so find_iad() might do out-of-bounds access
to intf_assoc->bInterfaceCount.
And he's right, we don't check for crazy descriptors of this type very well, so
resolve this problem. Yet another issue found by syzkaller...
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Tested-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 5ef1ecf060f28ecef313b5723f1fd39bf5a35f56 ]
Certain 64-bit systems (e.g. Amlogic Meson GX) require buffers to be
used for DMA to be 8-byte-aligned. struct sdio_func has an embedded
small DMA buffer not meeting this requirement.
When testing switching to descriptor chain mode in meson-gx driver
SDIO is broken therefore. Fix this by allocating the small DMA buffer
separately as kmalloc ensures that the returned memory area is
properly aligned for every basic data type.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Tested-by: Helmut Klein <hgkr.klein@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 62bc306e2083436675e33b5bdeb6a77907d35971 ]
32-bit socketcalls were not being logged by audit on x86_64 systems.
Log them. This is basically a duplicate of the call from
net/socket.c:sys_socketcall(), but it addresses the impedance mismatch
between 32-bit userspace process and 64-bit kernel audit.
See: https://github.com/linux-audit/audit-kernel/issues/14
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit af913418261d6d3e7a29f06cf35f04610ead667c ]
We need to define DRM_FORMAT_MOD_VENDOR_NONE for the fourcc_mod_code()
macro to work correctly.
Signed-off-by: Kristian H. Kristensen <hoegsberg@google.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1481657272-25975-1-git-send-email-hoegsberg@google.com
xen_swiotlb_dma_mmap was backported from v4.10, but older
kernels before commit 00085f1efa38 ("dma-mapping: use unsigned long
for dma_attrs") use a different signature:
arm/xen/mm.c:202:10: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
.mmap = xen_swiotlb_dma_mmap,
arm/xen/mm.c:202:10: note: (near initialization for 'xen_swiotlb_dma_ops.mmap')
This adapts the patch to the old calling conventions.
Fixes: "swiotlb-xen: implement xen_swiotlb_dma_mmap callback"
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
commit 7e91c7df29b5e196de3dc6f086c8937973bd0b88 upstream.
This function creates userspace mapping for the DMA-coherent memory.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@globallogic.com>
Signed-off-by: Andrii Anisov <andrii_anisov@epam.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
commit c283e41ef32442f41e7180f9bb1c5aedf9255bfe upstream.
The DMA chip has a fixed number of requestor lines used for flow
control. This number is platform dependent. The pxa_dma dma driver will
use this value to activate or not the flow control.
There won't be any impact on mmp_pdma driver.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream.
It was possible for an unprivileged user to create the user and user
session keyrings for another user. For example:
sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u
keyctl add keyring _uid_ses.4000 "" @u
sleep 15' &
sleep 1
sudo -u '#4000' keyctl describe @u
sudo -u '#4000' keyctl describe @us
This is problematic because these "fake" keyrings won't have the right
permissions. In particular, the user who created them first will own
them and will have full access to them via the possessor permissions,
which can be used to compromise the security of a user's keys:
-4: alswrv-----v------------ 3000 0 keyring: _uid.4000
-5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000
Fix it by marking user and user session keyrings with a flag
KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session
keyring by name, skip all keyrings that don't have the flag set.
Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed")
commit 979990c6284814617d8f2179d197f72ff62b5d85 upstream.
kernelci.org reports a crazy stack usage for the VT code when CONFIG_KASAN
is enabled:
drivers/tty/vt/keyboard.c: In function 'kbd_keycode':
drivers/tty/vt/keyboard.c:1452:1: error: the frame size of 2240 bytes is larger than 2048 bytes [-Werror=frame-larger-than=]
The problem is that tty_insert_flip_char() gets inlined many times into
kbd_keycode(), and also into other functions, and each copy requires 128
bytes for stack redzone to check for a possible out-of-bounds access on
the 'ch' and 'flags' arguments that are passed into
tty_insert_flip_string_flags as a variable-length string.
This introduces a new __tty_insert_flip_char() function for the slow
path, which receives the two arguments by value. This completely avoids
the problem and the stack usage goes back down to around 100 bytes.
Without KASAN, this is also slightly better, as we don't have to
spill the arguments to the stack but can simply pass 'ch' and 'flag'
in registers, saving a few bytes in .text for each call site.
This should be backported to linux-4.0 or later, which first introduced
the stack sanitizer in the kernel.
Fixes: c420f167db8c ("kasan: enable stack instrumentation")
[ Upstream commit 5a63643e583b6a9789d7a225ae076fb4e603991c ]
This reverts commit 1d6119baf0610f813eb9d9580eb4fd16de5b4ceb.
After reverting commit 6d7b857d541e ("net: use lib/percpu_counter API
for fragmentation mem accounting") then here is no need for this
fix-up patch. As percpu_counter is no longer used, it cannot
memory leak it any-longer.
Fixes: 6d7b857d541e ("net: use lib/percpu_counter API for fragmentation mem accounting")
Fixes: 1d6119baf061 ("net: fix percpu memory leaks")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit fb452a1aa3fd4034d7999e309c5466ff2d7005aa ]
This reverts commit 6d7b857d541ecd1d9bd997c97242d4ef94b19de2.
There is a bug in fragmentation codes use of the percpu_counter API,
that can cause issues on systems with many CPUs.
The frag_mem_limit() just reads the global counter (fbc->count),
without considering other CPUs can have upto batch size (130K) that
haven't been subtracted yet. Due to the 3MBytes lower thresh limit,
this become dangerous at >=24 CPUs (3*1024*1024/130000=24).
The correct API usage would be to use __percpu_counter_compare() which
does the right thing, and takes into account the number of (online)
CPUs and batch size, to account for this and call __percpu_counter_sum()
when needed.
We choose to revert the use of the lib/percpu_counter API for frag
memory accounting for several reasons:
1) On systems with CPUs > 24, the heavier fully locked
__percpu_counter_sum() is always invoked, which will be more
expensive than the atomic_t that is reverted to.
Given systems with more than 24 CPUs are becoming common this doesn't
seem like a good option. To mitigate this, the batch size could be
decreased and thresh be increased.
2) The add_frag_mem_limit+sub_frag_mem_limit pairs happen on the RX
CPU, before SKBs are pushed into sockets on remote CPUs. Given
NICs can only hash on L2 part of the IP-header, the NIC-RXq's will
likely be limited. Thus, a fair chance that atomic add+dec happen
on the same CPU.
Revert note that commit 1d6119baf061 ("net: fix percpu memory leaks")
removed init_frag_mem_limit() and instead use inet_frags_init_net().
After this revert, inet_frags_uninit_net() becomes empty.
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 4e587ea71bf924f7dac621f1351653bd41e446cb ]
Commit c5cff8561d2d adds rcu grace period before freeing fib6_node. This
generates a new sparse warning on rt->rt6i_node related code:
net/ipv6/route.c:1394:30: error: incompatible types in comparison
expression (different address spaces)
./include/net/ip6_fib.h:187:14: error: incompatible types in comparison
This commit adds "__rcu" tag for rt6i_node and makes sure corresponding
rcu API is used for it.
After this fix, sparse no longer generates the above warning.
Fixes: c5cff8561d2d ("ipv6: add rcu grace period before freeing fib6_node")
Signed-off-by: Wei Wang <weiwan@google.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit c5cff8561d2d0006e972bd114afd51f082fee77c ]
We currently keep rt->rt6i_node pointing to the fib6_node for the route.
And some functions make use of this pointer to dereference the fib6_node
from rt structure, e.g. rt6_check(). However, as there is neither
refcount nor rcu taken when dereferencing rt->rt6i_node, it could
potentially cause crashes as rt->rt6i_node could be set to NULL by other
CPUs when doing a route deletion.
This patch introduces an rcu grace period before freeing fib6_node and
makes sure the functions that dereference it takes rcu_read_lock().
Note: there is no "Fixes" tag because this bug was there in a very
early stage.
commit 591b6bb605785c12a21e8b07a08a277065b655a5 upstream.
Several legacy devices such as Geode-based Cisco ASA appliances
and DB800 development board do possess CS5536 IDE controller
with different PCI id than existing one. Using pata_generic is
not always feasible as at least DB800 requires MSR quirk from
pata_cs5536 to be used with vendor firmware.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
commit fbf1c41fc0f4d3574ac2377245efd666c1fa3075 upstream.
Commit 0a94efb5acbb ("workqueue: implicit ordered attribute should be
overridable") introduced a __WQ_ORDERED_EXPLICIT flag but gave it the
same value as __WQ_LEGACY. I don't believe these were intended to
mean the same thing, so renumber __WQ_ORDERED_EXPLICIT.
Fixes: 0a94efb5acbb ("workqueue: implicit ordered attribute should be ...")
