path: root/include
2008-05-30[S390] s390 types: make dma_addr_t 64 bit capableChristian Borntraeger
virtio tests with guests larger than 4 GB revealed that the dma_addr_t definition for s390 did not make it into the 64bit world. This patch changes the definition on s390 to have an u64 on 64bit and u32 on 32bit systems. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6tip-timers-nohz-2008-05-30_12.28_FriLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: driver-core: prepare for 2.6.27 api change by adding dev_set_name
2008-05-29driver-core: prepare for 2.6.27 api change by adding dev_set_nameStephen Rothwell
Create the dev_set_name function now so that various subsystems can start changing over to it before other changes in 2.6.27 will make it compulsory. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: re-tune NUMA topologies sched: stop wake_affine from causing serious imbalance sched: fix sched_clock_cpu() revert ("sched: fair-group: SMP-nice for group scheduling") sched: cleanup show_schedstat(): fix memleak sched: unite unlikely pairs in rt_policy() and schedule_debug() revert ("sched: fair: weight calculations")
2008-05-29Merge commit 'linus/master' into sched-fixes-for-linusIngo Molnar
2008-05-29sched: re-tune NUMA topologiesIngo Molnar
improve the sysbench ramp-up phase and its peak throughput on a 16way NUMA box, by turning on WAKE_AFFINE: tip/sched tip/sched+wake-affine ------------------------------------------------- 1: 700 830 +15.65% 2: 1465 1391 -5.28% 4: 3017 3105 +2.81% 8: 5100 6021 +15.30% 16: 10725 10745 +0.19% 32: 10135 10150 +0.16% 64: 9338 9240 -1.06% 128: 8599 8252 -4.21% 256: 8475 8144 -4.07% ------------------------------------------------- SUM: 57558 57882 +0.56% this change also improves lat_ctx from 6.69 usecs to 1.11 usec: $ ./lat_ctx -s 0 2 "size=0k ovr=1.19 2 1.11 $ ./lat_ctx -s 0 2 "size=0k ovr=1.22 2 6.69 in sysbench it's an overall win with some weakness at the lots-of-clients side. That happens because we now under-balance this workload a bit. To counter that effect, turn on NEWIDLE: wake-idle wake-idle+newidle ------------------------------------------------- 1: 830 834 +0.43% 2: 1391 1401 +0.65% 4: 3105 3091 -0.43% 8: 6021 6046 +0.42% 16: 10745 10736 -0.08% 32: 10150 10206 +0.55% 64: 9240 9533 +3.08% 128: 8252 8355 +1.24% 256: 8144 8384 +2.87% ------------------------------------------------- SUM: 57882 58591 +1.21% as a bonus this not only improves the many-clients case but also improves the (more important) rampup phase. sysbench is a workload that quickly breaks down if the scheduler over-balances, so since it showed an improvement under NEWIDLE this change is definitely good.
2008-05-29revert ("sched: fair-group: SMP-nice for group scheduling")Ingo Molnar
Yanmin Zhang reported: Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1. It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito. With bisect, I located the following patch: | 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit | commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair-group: SMP-nice for group scheduling Revert it so that we get v2.6.25 behavior. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Workaround for RSE issue
2008-05-28Fix FRV minimum slab/kmalloc alignmentDavid Howells
> +#define ARCH_KMALLOC_MINALIGN (sizeof(long) * 2) > +#define ARCH_SLAB_MINALIGN (sizeof(long) * 2) This doesn't work if SLAB is selected and slab debugging is enabled as these are passed to the preprocessor, and the preprocessor doesn't understand sizeof. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: fix RCU problem in cfq_cic_lookup() block: make blktrace use per-cpu buffers for message notes Added in elevator switch message to blktrace stream Added in MESSAGE notes for blktraces block: reorder cfq_queue to save space on 64bit builds block: Move the second call to get_request to the end of the loop splice: handle try_to_release_page() failure splice: fix sendfile() issue with relay
2008-05-28FRV: Specify the minimum slab/kmalloc alignmentDavid Howells
Specify the minimum slab/kmalloc alignment to be 8 bytes. This fixes a crash when SLOB is selected as the memory allocator. The FRV arch needs this so that it can use the load- and store-double instructions without faulting. By default SLOB sets the minimum to be 4 bytes. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28MN10300: Fix typo in header guardVegard Nossum
Fix a typo in the header guard of asm/ipc.h. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28block: make blktrace use per-cpu buffers for message notesJens Axboe
Currently it uses a single static char array, but that risks being corrupted when multiple users issue message notes at the same time. Make the buffers dynamically allocated when the trace is setup and make them per-cpu instead. The default max message size of 1k is also very large, the interface is mainly for small text notes. So shrink it to 128 bytes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-28Added in MESSAGE notes for blktracesAlan D. Brunelle
Allows messages to be inserted into blktrace streams. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-27[IA64] Workaround for RSE issueTony Luck
Problem: An application violating the architectural rules regarding operation dependencies and having specific Register Stack Engine (RSE) state at the time of the violation, may result in an illegal operation fault and invalid RSE state. Such faults may initiate a cascade of repeated illegal operation faults within OS interruption handlers. The specific behavior is OS dependent. Implication: An application causing an illegal operation fault with specific RSE state may result in a series of illegal operation faults and an eventual OS stack overflow condition. Workaround: OS interruption handlers that switch to kernel backing store implement a check for invalid RSE state to avoid the series of illegal operation faults. The core of the workaround is the RSE_WORKAROUND code sequence inserted into each invocation of the SAVE_MIN_WITH_COVER and SAVE_MIN_WITH_COVER_R19 macros. This sequence includes hard-coded constants that depend on the number of stacked physical registers being 96. The rest of this patch consists of code to disable this workaround should this not be the case (with the presumption that if a future Itanium processor increases the number of registers, it would also remove the need for this patch). Move the start of the RBS up to a mod32 boundary to avoid some corner cases. The dispatch_illegal_op_fault code outgrew the spot it was squatting in when built with this patch and CONFIG_VIRT_CPU_ACCOUNTING=y Move it out to the end of the ivt. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-26posix timers: discard SI_TIMER signals on execOleg Nesterov
Based on Roland's patch. This approach was suggested by Austin Clements from the very beginning, and then by Linus. As Austin pointed out, the execing task can be killed by SI_TIMER signal because exec flushes the signal handlers, but doesn't discard the pending signals generated by posix timers. Perhaps not a bug, but people find this surprising. See http://bugzilla.kernel.org/show_bug.cgi?id=10460 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Align i2c_device_id tuner: Do not alter i2c_client.name
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: global_reg_snapshot is not for userspace
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) vlan: Use bitmask of feature flags instead of seperate feature bits fmvj18x_cs: add NextCom NC5310 rev B support xirc2ps_cs: re-initialize the multicast address in do_reset 3C509: rx_bytes should not be increased when alloc_skb failed NETFRONT: Use __skb_queue_purge() VIRTIO: Use __skb_queue_purge() phylib: do EXPORT_SYMBOL on get_phy_id netlink: Fix nla_parse_nested_compat() to call nla_parse() directly WAN: protect HDLC proto list while insmod/rmmod drivers/net/fs_enet: remove null pointer dereference S2io: Version update for napi and MSI-X patches S2io: Added napi support when MSIX is enabled. S2io: Move all the transmit completions to a single msi-x (alarm) vector drivers/net/ehea - remove unnecessary memset after kzalloc au1000_eth: remove useless check Blackfin EMAC Driver: Removed duplicated include <linux/ethtool.h> cpmac bugfixes and enhancements e1000e: use resource_size_t, not unsigned long, for phys addrs net/usb: add support for Apple USB Ethernet Adapter uli526x: add support for netpoll ...
2008-05-26i2c: Align i2c_device_idJiri Slaby
Align i2c_device_id.driver_data to 8 bytes to not fail on crossbuilds. (Added in d2653e92732bd3911feff6bee5e23dbf959381db.) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-25sparc64: global_reg_snapshot is not for userspaceAdrian Bunk
global_reg_snapshot shouldn't be visible in our userspace headers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-24Merge branch 'x86-fixes-for-linus' of ↵tip-auto-x86-next-base-2008-05-26_08_52_Montip-auto-sched-next-base-2008-05-26_08_52_Montip-auto-latest-base-2008-05-26_08_52_Montip-auto-ftrace-next-base-2008-05-26_08_52_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: prevent PGE flush from interruption/preemption x86: use explicit copy in vdso_gettimeofday() namespacecheck: automated fixes x86/xen: fix arbitrary_virt_to_machine() x86: don't read maxlvt before checking if APIC is mapped x86: disable TSC for sched_clock() when calibration failed x86: distangle user disabled TSC from unstable x86: fix setup of cyc2ns in tsc_64.c
2008-05-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] integrator: fix build warnings and errors [ARM] fix OMAP include loops Revert "[ARM] pxa: spitz wants PXA27x UDC definitions" [ARM] 5053/1: define before use of processor_id [ARM] 5052/1: export clock functions for the at91x40 [ARM] 5051/1: define pgtable_t for the !CONFIG_MMU case too [ARM] omap: fix omap clk support build errors [ARM] 5039/1: S3C244X: Rename SDI device if running on S3C244X. [ARM] 5043/1: pxafb: remove unused mode variable in pxafb_init_fbinfo [ARM] 5041/1: VR1000: Fix DM9000 IRQ flags initialisation [ARM] 5040/1: BAST: Fix DM9000 IRQ flags initialisation [ARM] 5038/1: ARM: OMAP: Remove tsc2102 references from board-palmte.c [ARM] 5025/2: fix collie cpu initialisation
2008-05-24for_each_online_pgdat(): kerneldoc fixFernando Luis Vazquez Cao
for_each_pgdat() was renamed to for_each_online_pgdat() and kerneldoc comments should be updated accordingly. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: build fixesDavid Brownell
This fixes various gpio-related build errors (mostly potential) reported in part by Russell King and Uwe Kleine-König. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24SM501: reverse FPEN/VBIASEN flags behaviourBen Dooks
To keep backwards compatibility, reverse the meanings of these flags so that when they are not set, the driver uses the original behvaiour. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: restart recovery cleanly after device failure.NeilBrown
When we get any IO error during a recovery (rebuilding a spare), we abort the recovery and restart it. For RAID6 (and multi-drive RAID1) it may not be best to restart at the beginning: when multiple failures can be tolerated, the recovery may be able to continue and re-doing all that has already been done doesn't make sense. We already have the infrastructure to record where a recovery is up to and restart from there, but it is not being used properly. This is because: - We sometimes abort with MD_RECOVERY_ERR rather than just MD_RECOVERY_INTR, which causes the recovery not be be checkpointed. - We remove spares and then re-added them which loses important state information. The distinction between MD_RECOVERY_ERR and MD_RECOVERY_INTR really isn't needed. If there is an error, the relevant drive will be marked as Faulty, and that is enough to ensure correct handling of the error. So we first remove MD_RECOVERY_ERR, changing some of the uses of it to MD_RECOVERY_INTR. Then we cause the attempt to remove a non-faulty device from an array to fail (unless recovery is impossible as the array is too degraded). Then when remove_and_add_spares attempts to remove the devices on which recovery can continue, it will fail, they will remain in place, and recovery will continue on them as desired. Issue: If we are halfway through rebuilding a spare and another drive fails, and a new spare is immediately available, do we want to: 1/ complete the current rebuild, then go back and rebuild the new spare or 2/ restart the rebuild from the start and rebuild both devices in parallel. Both options can be argued for. The code currently takes option 2 as a/ this requires least code change b/ this results in a minimally-degraded array in minimal time. Cc: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: allow parallel resync of md-devices.Bernd Schubert
In some configurations, a raid6 resync can be limited by CPU speed (Calculating P and Q and moving data) rather than by device speed. In these cases there is nothing to be gained byt serialising resync of arrays that share a device, and doing the resync in parallel can provide benefit. So add a sysfs tunable to flag an array as being allowed to resync in parallel with other arrays that use (a different part of) the same device. Signed-off-by: Bernd Schubert <bs@q-leap.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: kill file_path wrapperChristoph Hellwig
Kill the trivial and rather pointless file_path wrapper around d_path. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: proper extern for mdp_majorAdrian Bunk
This patch adds a proper extern for mdp_major in include/linux/raid/md.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: fix atomic_t overflow in vmAlan Cox
The atomic_t type is 32bit but a 64bit system can have more than 2^32 pages of virtual address space available. Without this we overflow on ludicrously large mappings Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24types.h: don't expose struct ustat to userspacemaximilian attems
<linux/types.h> can't be used together with <sys/ustat.h> because they both define struct ustat: $ cat test.c #include <sys/ustat.h> #include <linux/types.h> $ gcc -c test.c In file included from test.c:2: /usr/include/linux/types.h:165: error: redefinition of 'struct ustat' has been reported a while ago to debian, but seems to have been lost in cat fighting: http://bugs.debian.org/429064 Signed-off-by: maximilian attems <max@stro.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: support for InstaShield IS-400 four port RS-232 PCI cardIgnacio García Pérez
Add support for the InstaShield IS-400 four port RS-232 PCI card. Signed-off-by: Ignacio García Pérez <iggarpe@t2i.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fix parenthesis in include/asm-mips/mach-au1x00/au1000.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/mach-au1x00/au1000.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fix parenthesis in include/asm-mips/gic.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/gic.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24i5k_amb: support Intel 5400 chipsetDarrick J. Wong
Minor rework to support the Intel 5400 chipset. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23x86: prevent PGE flush from interruption/preemptionIngo Molnar
CR4 manipulation is not protected against interrupts and preemption, but KVM uses smp_function_call to manipulate the X86_CR4_VMXE bit either from the CPU hotplug code or from the kvm_init call. We need to protect the CR4 manipulation from both interrupts and preemption. Original bug report: http://lkml.org/lkml/2008/5/7/48 Bugzilla entry: http://bugzilla.kernel.org/show_bug.cgi?id=10642 This is not a regression from 2.6.25, it's a long standing and hard to trigger bug. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23[ARM] fix OMAP include loopsRussell King
OMAP has two include loops in its header files: asm-arm/hardware.h <- asm-arm/arch-omap/io.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h asm-arm/arch-omap/board-palmte.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <- asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve these by removing the offending includes, and add additional includes where necessary. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] 5053/1: define before use of processor_idGreg Ungerer
For the simple read_cpuid() macro case the variable processor_id has no definition on use of the macro. Add an extern for it. Move all the processor ID macros into the #ifndef __ASSEMBLEY__ block. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23[ARM] 5051/1: define pgtable_t for the !CONFIG_MMU case tooGreg Ungerer
The non-MMU case also needs the type definition of pgtable_t. So move it out of a CONFIG_MMU conditional section. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23vlan: Use bitmask of feature flags instead of seperate feature bitsPatrick McHardy
Herbert Xu points out that the use of seperate feature bits for features to be propagated to VLAN devices is going to get messy real soon. Replace the VLAN feature bits by a bitmask of feature flags to be propagated and restore the old GSO_SHIFT/MASK values. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-23[POWERPC] mpic: Fix use of uninitialized variableStephen Rothwell
Compiling ppc64_defconfig with gcc 4.3 gives thes warnings: arch/powerpc/sysdev/mpic.c: In function 'mpic_irq_get_priority': arch/powerpc/sysdev/mpic.c:1351: warning: 'is_ipi' may be used uninitialized in this function arch/powerpc/sysdev/mpic.c: In function 'mpic_irq_set_priority': arch/powerpc/sysdev/mpic.c:1328: warning: 'is_ipi' may be used uninitialized in this function It turns out that in the cases where is_ipi is uninitialized, another variable (mpic) will be NULL and it is dereferenced. Protect against this by returning if mpic is NULL in mpic_irq_set_priority, and removing mpic_irq_get_priority completely as it has no in tree callers. This has the nice side effect of making the warning go away. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-22netlink: Fix nla_parse_nested_compat() to call nla_parse() directlyThomas Graf
The purpose of nla_parse_nested_compat() is to parse attributes which contain a struct followed by a stream of nested attributes. So far, it called nla_parse_nested() to parse the stream of nested attributes which was wrong, as nla_parse_nested() expects a container attribute as data which holds the attribute stream. It needs to call nla_parse() directly while pointing at the next possible alignment point after the struct in the beginning of the attribute. With this patch, I can no longer reproduce the reported leftover warnings. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22[ARM] omap: fix omap clk support build errorsRussell King
arch/arm/plat-omap/clock.c:397: warning: "struct cpufreq_frequency_table" declared inside parameter list arch/arm/plat-omap/clock.c:397: warning: its scope is only this definition or declaration, which is probably not what you want arch/arm/plat-omap/clock.c: In function `clk_init_cpufreq_table': arch/arm/plat-omap/clock.c:402: error: structure has no member named `clk_init_cpufreq_table' arch/arm/plat-omap/clock.c:403: error: structure has no member named `clk_init_cpufreq_table' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] 5025/2: fix collie cpu initialisationThomas Kunze
collie.h: * add some meaningfull names to some gpios collie.c: * initialize cpu registers correctly Signed-off-by: Thomas Kunze <thommycheck@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: The world is not perfect patch. tcp: Make prior_ssthresh a u32 xfrm_user: Remove zero length key checks. net/ipv4/arp.c: Use common hex_asc helpers cassini: Only use chip checksum for ipv4 packets. tcp: TCP connection times out if ICMP frag needed is delayed netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__ af_key: Fix selector family initialization. libertas: Fix ethtool statistics mac80211: fix NULL pointer dereference in ieee80211_compatible_rates mac80211: don't claim iwspy support orinoco_cs: add ID for SpeedStream wireless adapters hostap_cs: add ID for Conceptronic CON11CPro rtl8187: resource leak in error case ath5k: Fix loop variable initializations
2008-05-21tcp: Make prior_ssthresh a u32Ilpo Järvinen
If previous window was above representable values of u16, strange things will happen if undo with the truncated value is called for. Alternatively, this could be fixed by some max trickery but that would limit undoing high-speed undos. Adds 16-bit hole but there isn't anything to fill it with. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21netfilter: Move linux/types.h inclusions outside of #ifdef __KERNEL__Patrick McHardy
Greg Steuck <greg@nest.cx> points out that some of the netfilter headers can't be used in userspace without including linux/types.h first. The headers include their own linux/types.h include statements, these are stripped by make headers-install because they are inside #ifdef __KERNEL__ however. Move them out to fix this. Reported and Tested by Greg Steuck. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20Merge branch 'for-2.6.26' of git://linux-nfs.org/~bfields/linuxtip-x86-xsave-2008-05-26_08_54_Montip-x86-cpu-2008-05-26_08_53_MonLinus Torvalds
* 'for-2.6.26' of git://linux-nfs.org/~bfields/linux: (25 commits) svcrdma: Verify read-list fits within RPCSVC_MAXPAGES svcrdma: Change svc_rdma_send_error return type to void svcrdma: Copy transport address and arm CQ before calling rdma_accept svcrdma: Set rqstp transport address in rdma_read_complete function svcrdma: Use ib verbs version of dma_unmap svcrdma: Cleanup queued, but unprocessed I/O in svc_rdma_free svcrdma: Move the QP and cm_id destruction to svc_rdma_free svcrdma: Add reference for each SQ/RQ WR svcrdma: Move destroy to kernel thread svcrdma: Shrink scope of spinlock on RQ CQ svcrdma: Use standard Linux lists for context cache svcrdma: Simplify RDMA_READ deferral buffer management svcrdma: Remove unused READ_DONE context flags bit svcrdma: Return error from rdma_read_xdr so caller knows to free context svcrdma: Fix error handling during listening endpoint creation svcrdma: Free context on post_recv error in send_reply svcrdma: Free context on ib_post_recv error svcrdma: Add put of connection ESTABLISHED reference in rdma_cma_handler svcrdma: Fix return value in svc_rdma_send svcrdma: Fix race with dto_tasklet in svc_rdma_send ...
2008-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) pktgen: make sure that pktgen_thread_worker has been executed [VLAN]: Propagate selected feature bits to VLAN devices drivers/atm/: remove CVS keywords vlan: Correctly handle device notifications for layered VLAN devices net: Fix call to ->change_rx_flags(dev, IFF_MULTICAST) in dev_change_flags() net_sched: cls_api: fix return value for non-existant classifiers ipsec: Use the correct ip_local_out function ipv6 addrconf: Allow infinite prefix lifetime. ipv6 route: Fix lifetime in netlink. ipv6 addrconf: Fix route lifetime setting in corner case. ndisc: Add missing strategies for per-device retrans timer/reachable time settings. ipv6: Move <linux/in6.h> from header-y to unifdef-y. l2tp: avoid skb truesize bug if headroom is increased wireless: Create 'device' symlink in sysfs wireless, airo: waitbusy() won't delay libertas: fix command timeout after firmware failure mac80211: Add RTNL version of ieee80211_iterate_active_interfaces mac80211 : Association with 11n hidden ssid ap. hostap: fix "registers" registration in procfs isdn/capi: Return proper errnos on module init. ...
