commit 5955102c9984fa081b2d570cfac75c97eecf8f3b upstream
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
[only the fs.h change included to make backports easier - gregkh]
commit 98f368e9e2630a3ce3e80fb10fb2e02038cf9578 upstream.
When checking the current cred for a capability in a specific user
namespace, it isn't always desirable to have the LSMs audit the check.
This patch adds a noaudit variant of ns_capable() for when those
situations arise.
The common logic between ns_capable() and the new ns_capable_noaudit()
is moved into a single, shared function to keep duplicated code to a
minimum and ease maintainability.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
[ Upstream commit d5e26bb1d812ba74f29b6bcbc88c3dbfb3eed824 ]
Applications which use virtual LUN's that are backed by a physical LUN
over both adapter ports may experience an I/O failure in the event of a
link loss (e.g. cable pull).
Virtual LUNs may be accessed through one or both ports of the adapter.
This access is encoded in the translation entries that comprise the
virtual LUN and used by the AFU for load-balancing I/O and handling
failover scenarios. In a link loss scenario, even though the AFU is able
to maintain connectivity to the LUN, it is up to the application to
retry the failed I/O. When applications are unaware of the virtual LUN's
underlying topology, they are unable to make a sound decision of when to
retry an I/O and therefore are forced to make their reaction to a failed
I/O absolute. The result is either a failure to retry I/O or increased
latency for scenarios where a retry is pointless.
To remedy this scenario, provide feedback back to the application on
virtual LUN creation as to which ports the LUN may be accessed. LUN's
spanning both ports are candidates for a retry in a presence of an I/O
failure.
Signed-off-by: Matthew R. Ochs <mrochs@linux.vnet.ibm.com>
Acked-by: Manoj Kumar <manoj@linux.vnet.ibm.com>
Reviewed-by: Uma Krishnan <ukrishn@linux.vnet.ibm.com>
[ Upstream commit f21018427cb007a0894c36ad702990ab639cbbb4 ]
Driver private request types should not get the artifical cap for the
FS requests. This is important to use the full device capabilities
for internal command or NVMe pass through commands.
Reported-by: Jeff Lien <Jeff.Lien@hgst.com>
Tested-by: Jeff Lien <Jeff.Lien@hgst.com>
Reviewed-by: Keith Busch <keith.busch@intel.com>
Updated by me to use an explicit check for the one command type that
does support extended checking, instead of relying on the ordering
of the enum command values - as suggested by Keith.
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 37cf4dc3370fbca0344e23bb96446eb2c3548ba7 ]
For adjtimex()'s ADJ_SETOFFSET, make sure the tv_usec value is
sane. We might multiply them later which can cause an overflow
and undefined behavior.
This patch introduces new helper functions to simplify the
checking code and adds comments to clarify
Orginally this patch was by Sasha Levin, but I've basically
rewritten it, so he should get credit for finding the issue
and I should get the blame for any mistakes made since.
Also, credit to Richard Cochran for the phrasing used in the
comment for what is considered valid here.
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit a223c1c7ab4cc64537dc4b911f760d851683768a ]
Currently CQM (cache quality of service monitoring) is grouping all
events belonging to same PID to use one RMID. However its not counting
all of these different events. Hence we end up with a count of zero
for all events other than the group leader.
The patch tries to address the issue by keeping a flag in the
perf_event.hw which has other CQM related fields. The field is updated
at event creation and during grouping.
Signed-off-by: Vikas Shivappa <vikas.shivappa@linux.intel.com>
[peterz: Changed hw_perf_event::is_group_event to an int]
Reviewed-by: Tony Luck <tony.luck@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: fenghua.yu@intel.com
Cc: h.peter.anvin@intel.com
Cc: ravi.v.shankar@intel.com
Cc: vikas.shivappa@intel.com
Link: http://lkml.kernel.org/r/1457652732-4499-2-git-send-email-vikas.shivappa@linux.intel.com
[ Upstream commit 65376df582174ffcec9e6471bf5b0dd79ba05e4a ]
Commit b76437579d13 ("procfs: mark thread stack correctly in
proc/<pid>/maps") added [stack:TID] annotation to /proc/<pid>/maps.
Finding the task of a stack VMA requires walking the entire thread list,
turning this into quadratic behavior: a thousand threads means a
thousand stacks, so the rendering of /proc/<pid>/maps needs to look at a
million combinations.
The cost is not in proportion to the usefulness as described in the
patch.
Drop the [stack:TID] annotation to make /proc/<pid>/maps (and
/proc/<pid>/numa_maps) usable again for higher thread counts.
The [stack] annotation inside /proc/<pid>/task/<tid>/maps is retained, as
identifying the stack VMA there is an O(1) operation.
Siddesh said:
"The end users needed a way to identify thread stacks programmatically and
there wasn't a way to do that. I'm afraid I no longer remember (or have
access to the resources that would aid my memory since I changed
employers) the details of their requirement. However, I did do this on my
own time because I thought it was an interesting project for me and nobody
really gave any feedback then as to its utility, so as far as I am
concerned you could roll back the main thread maps information since the
information is available in the thread-specific files"
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com>
Cc: Shaohua Li <shli@fb.com>
[ Upstream commit 5d8d8db851ef81337e7026b32a9d5a9cfb2271d5 ]
Add support for Intel R200 depth camera in uvc driver.
This includes adding new uvc GUIDs for the new pixel formats,
adding new V4L pixel format definition to user api headers,
and updating the uvc driver GUID-to-4cc tables with the new formats.
Tested-by: Greenberg, Aviv D <aviv.d.greenberg@intel.com>
Signed-off-by: Aviv Greenberg <aviv.d.greenberg@intel.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
[ Upstream commit 7157bb27e79875db5603aa1e30f56e873a8300f9 ]
Used by production devices:
Intel(R) Iris Graphics 540 (Skylake GT3e)
Intel(R) Iris Graphics 550 (Skylake GT3e)
v2: More ids
v3: Less ids (GT1 got duplicated)
Cc: Mika Kuoppala <mika.kuoppala@intel.com>
Signed-off-by: Michał Winiarski <michal.winiarski@intel.com>
Reviewed-by: Mika Kuoppala <mika.kuoppala@intel.com>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1454674902-26207-1-git-send-email-michal.winiarski@intel.com
[ Upstream commit 985dd4360fdf2533fe48a33a4a2094f2e4718dc0 ]
Add PCIIDs for new versions of the SOC, based on BSpec. Also add the
name of the versions as code comment where this is available. The new
versions don't have any changes visible to the kernel driver.
Signed-off-by: Imre Deak <imre.deak@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1453989852-13569-1-git-send-email-imre.deak@intel.com
[ Upstream commit b4ed5d1682c6613988c2eb1de55df5ac9988afcc ]
Currently some "Unspecified error 0x80004005" is reported on the Windows
side if something fails. Handle the ENOSPC case and return
ERROR_DISK_FULL, which allows at least Copy-VMFile to report a meaning
full error.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit b5d4acd4cbf5029a2616084d9e9f392046d53a37 ]
The get/set bad block interface defines good block, factory bad block,
grown bad block, device reserved block, and host reserved block.
Unfortunately the grown bad block was missing, leaving the offsets wrong
for device and host side reserved blocks.
This patch adds the missing type and corrects the offsets.
Signed-off-by: Matias Bjørling <m@bjorling.me>
commit 3feab13c919f99b0a17d0ca22ae00cf90f5d3fd1 upstream.
When the ACPI_DECLARE_PROBE_ENTRY macro was added in
commit e647b532275b ("ACPI: Add early device probing infrastructure"),
a stub macro adding an unused entry was added for the !CONFIG_ACPI
Kconfig option case to make sure kernel code making use of the
macro did not require to be guarded within CONFIG_ACPI in order to
be compiled.
The stub macro was never used since all kernel code that defines
ACPI_DECLARE_PROBE_ENTRY entries is currently guarded within
CONFIG_ACPI; it contains a typo that should be nonetheless fixed.
Fix the typo in the stub (ie !CONFIG_ACPI) ACPI_DECLARE_PROBE_ENTRY()
macro so that it can actually be used if needed.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Fixes: e647b532275b (ACPI: Add early device probing infrastructure)
commit 4097461897df91041382ff6fcd2bfa7ee6b2448c upstream.
As explained in 1407814240-4275-1-git-send-email-decui@microsoft.com we
have a hard load dependency between i8042 and atkbd which prevents
keyboard from working on Gen2 Hyper-V VMs.
> hyperv_keyboard invokes serio_interrupt(), which needs a valid serio
> driver like atkbd.c. atkbd.c depends on libps2.c because it invokes
> ps2_command(). libps2.c depends on i8042.c because it invokes
> i8042_check_port_owner(). As a result, hyperv_keyboard actually
> depends on i8042.c.
> For a Generation 2 Hyper-V VM (meaning no i8042 device emulated), if a
> Linux VM (like Arch Linux) happens to configure CONFIG_SERIO_I8042=m
> rather than =y, atkbd.ko can't load because i8042.ko can't load(due to
> no i8042 device emulated) and finally hyperv_keyboard can't work and
> the user can't input: https://bugs.archlinux.org/task/39820
> (Ubuntu/RHEL/SUSE aren't affected since they use CONFIG_SERIO_I8042=y)
To break the dependency we move away from using i8042_check_port_owner()
and instead allow serio port owner specify a mutex that clients should use
to serialize PS/2 command stream.
Reported-by: Mark Laws <mdl@60hz.org>
Tested-by: Mark Laws <mdl@60hz.org>
commit 9798ac6d32c1a32d6d92d853ff507d2d39c4300c upstream.
So that callers of cros_ec_cmd_xfer() don't have to repeat boilerplate
code when checking for errors from the EC side.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Reviewed-by: Benson Leung <bleung@chromium.org>
Signed-off-by: Brian Norris <briannorris@chromium.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
commit 8a1b2725a60d3267135c15e80984b4406054f650 upstream.
Add a new USB_SPEED_SUPER_PLUS device speed, and make sure usb core can
handle the new speed.
In most cases the behaviour is the same as with USB_SPEED_SUPER SuperSpeed
devices. In a few places we add a "Plus" string to inform the user of the
new speed.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit f3b0946d629c8bfbd3e5f038e30cb9c711a35f10 upstream.
Bharat Kumar Gogada reported issues with the generic MSI code, where the
end-point ended up with garbage in its MSI configuration (both for the vector
and the message).
It turns out that the two MSI paths in the kernel are doing slightly different
things:
generic MSI: disable MSI -> allocate MSI -> enable MSI -> setup EP
PCI MSI: disable MSI -> allocate MSI -> setup EP -> enable MSI
And it turns out that end-points are allowed to latch the content of the MSI
configuration registers as soon as MSIs are enabled. In Bharat's case, the
end-point ends up using whatever was there already, which is not what you
want.
In order to make things converge, we introduce a new MSI domain flag
(MSI_FLAG_ACTIVATE_EARLY) that is unconditionally set for PCI/MSI. When set,
this flag forces the programming of the end-point as soon as the MSIs are
allocated.
A consequence of this is that we have an extra activate in irq_startup, but
that should be without much consequence.
tglx:
- Several people reported a VMWare regression with PCI/MSI-X passthrough. It
turns out that the patch also cures that issue.
- We need to have a look at the MSI disable interrupt path, where we write
the msg to all zeros without disabling MSI in the PCI device. Is that
correct?
Fixes: 52f518a3a7c2 "x86/MSI: Use hierarchical irqdomains to manage MSI interrupts"
Reported-and-tested-by: Bharat Kumar Gogada <bharat.kumar.gogada@xilinx.com>
Reported-and-tested-by: Foster Snowhill <forst@forstwoof.ru>
Reported-by: Matthias Prager <linux@matthiasprager.de>
Reported-by: Jason Taylor <jason.taylor@simplivity.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: linux-pci@vger.kernel.org
Link: http://lkml.kernel.org/r/1468426713-31431-1-git-send-email-marc.zyngier@arm.com
commit b6140914fd079e43ea75a53429b47128584f033a upstream.
No user and we definitely don't want to grow one.
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: linux-block@vger.kernel.org
Cc: linux-nvme@lists.infradead.org
Cc: axboe@fb.com
Cc: agordeev@redhat.com
Link: http://lkml.kernel.org/r/1467621574-8277-2-git-send-email-hch@lst.de
commit 69874ec233871a62e1bc8c89e643993af93a8630 upstream.
Add the device ID for the PF of the NFP4000. The device ID for the VF,
0x6003, is already present as PCI_DEVICE_ID_NETRONOME_NFP6000_VF.
Signed-off-by: Simon Horman <simon.horman@netronome.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit a755e169031dac9ebaed03302c4921687c271d62 upstream.
Device IDs for the Netronome NFP3200, NFP3240, NFP6000, and NFP6000 SR-IOV
devices.
Signed-off-by: Jason S. McMullan <jason.mcmullan@netronome.com>
[simon: edited changelog]
commit db1bb44c4c7e8d49ed674dc59e5222d99c698088 upstream.
We're always tracing IPv4 or IPv6 addresses, so we can save a lot
of space on the ringbuffer by allocating the correct sockaddr size.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Fixes: 83a712e0afef "sunrpc: add some tracepoints around ..."
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 410c29dfbfdf73d0d0b5d14a21868ab038eca703 upstream.
If a Simple command is sent with a failure, target_setup_cmd_from_cdb
returns with TCM_UNSUPPORTED_SCSI_OPCODE or TCM_INVALID_CDB_FIELD.
So in the cases where target_setup_cmd_from_cdb returns an error, we
never get far enough to call target_execute_cmd to increment simple_cmds.
Since simple_cmds isn't incremented, the result of the failure from
target_setup_cmd_from_cdb causes transport_generic_request_failure to
decrement simple_cmds, due to call to transport_complete_task_attr.
With this dev->simple_cmds or dev->dev_ordered_sync is now -1, not 0.
So when a subsequent command with an Ordered Task is sent, it causes
a hang, since dev->simple_cmds is at -1.
Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Tested-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Signed-off-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
commit ea263c7fada4af8ec7fe5fcfd6e7d7705a89351b upstream.
max_discard_sectors only 32bits, and some non scsi backend
devices will set this to the max 0xffffffff, so we can end up
overflowing during the max_unmap_lba_count calculation.
This fixes a regression caused by my patch:
commit 8a9ebe717a133ba7bc90b06047f43cc6b8bcb8b3
Author: Mike Christie <mchristi@redhat.com>
Date: Mon Jan 18 14:09:27 2016 -0600
target: Fix WRITE_SAME/DISCARD conversion to linux 512b sectors
which can result in extra discards being sent to due the overflow
causing max_unmap_lba_count to be smaller than what the backing
device can actually support.
Signed-off-by: Mike Christie <mchristi@redhat.com>
commit dff0ca9ea7dc8be2181a62df4a722c32ce68ff4a upstream.
If a command with a Simple task attribute is failed due to a Unit
Attention, then a subsequent command with an Ordered task attribute
will hang forever. The reason for this is that the Unit Attention
status is checked for in target_setup_cmd_from_cdb, before the call
to target_execute_cmd, which calls target_handle_task_attr, which
in turn increments dev->simple_cmds.
However, transport_generic_request_failure still calls
transport_complete_task_attr, which will decrement dev->simple_cmds.
In this case, simple_cmds is now -1. So when a command with the
Ordered task attribute is sent, target_handle_task_attr sees that
dev->simple_cmds is not 0, so it decides it can't execute the
command until all the (nonexistent) Simple commands have completed.
Reported-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
commit c9b254955b9f8814966f5dabd34c39d0e0a2b437 upstream.
If the caller specified IB_SEND_FENCE in the send flags of the work
request and no previous work request stated that the successive one
should be fenced, the work request would be executed without a fence.
This could result in RDMA read or atomic operations failure due to a MR
being invalidated. Fix this by adding the mlx5 enumeration for fencing
RDMA/atomic operations and fix the logic to apply this.
Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB adapters')
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit e3353c268b06236d6c40fa1714c114f21f44451c upstream.
Make MODIFY_QP command input structure compliant to specification
Signed-off-by: Artemy Kovalyov <artemyko@mellanox.com>
commit df08c32ce3be5be138c1dbfcba203314a3a7cd6f upstream.
The name for a bdi of a gendisk is derived from the gendisk's devt.
However, since the gendisk is destroyed before the bdi it leaves a
window where a new gendisk could dynamically reuse the same devt while a
bdi with the same name is still live. Arrange for the bdi to hold a
reference against its "owner" disk device while it is registered.
Otherwise we can hit sysfs duplicate name collisions like the following:
WARNING: CPU: 10 PID: 2078 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x64/0x80
sysfs: cannot create duplicate filename '/devices/virtual/bdi/259:1'
Hardware name: HP ProLiant DL580 Gen8, BIOS P79 05/06/2015
0000000000000286 0000000002c04ad5 ffff88006f24f970 ffffffff8134caec
ffff88006f24f9c0 0000000000000000 ffff88006f24f9b0 ffffffff8108c351
0000001f0000000c ffff88105d236000 ffff88105d1031e0 ffff8800357427f8
Call Trace:
[<ffffffff8134caec>] dump_stack+0x63/0x87
[<ffffffff8108c351>] __warn+0xd1/0xf0
[<ffffffff8108c3cf>] warn_slowpath_fmt+0x5f/0x80
[<ffffffff812a0d34>] sysfs_warn_dup+0x64/0x80
[<ffffffff812a0e1e>] sysfs_create_dir_ns+0x7e/0x90
[<ffffffff8134faaa>] kobject_add_internal+0xaa/0x320
[<ffffffff81358d4e>] ? vsnprintf+0x34e/0x4d0
[<ffffffff8134ff55>] kobject_add+0x75/0xd0
[<ffffffff816e66b2>] ? mutex_lock+0x12/0x2f
[<ffffffff8148b0a5>] device_add+0x125/0x610
[<ffffffff8148b788>] device_create_groups_vargs+0xd8/0x100
[<ffffffff8148b7cc>] device_create_vargs+0x1c/0x20
[<ffffffff811b775c>] bdi_register+0x8c/0x180
[<ffffffff811b7877>] bdi_register_dev+0x27/0x30
[<ffffffff813317f5>] add_disk+0x175/0x4a0
Reported-by: Yi Zhang <yizhan@redhat.com>
Tested-by: Yi Zhang <yizhan@redhat.com>
Fixed up missing 0 return in bdi_register_owner().
commit 20bd723ec6a3261df5e02250cd3a1fbb09a343f2 upstream.
When a bio is cloned, the newly created bio must be associated with
the same blkcg as the original bio (if BLK_CGROUP is enabled). If
this operation is not performed, then the new bio is not associated
with any group, and the group of the current task is returned when
the group of the bio is requested.
Depending on the cloning frequency, this may cause a large
percentage of the bios belonging to a given group to be treated
as if belonging to other groups (in most cases as if belonging to
the root group). The expected group isolation may thereby be broken.
This commit adds the missing association in bio-cloning functions.
Fixes: da2f0f74cf7d ("Btrfs: add support for blkio controllers")
Signed-off-by: Paolo Valente <paolo.valente@linaro.org>
Reviewed-by: Nikolay Borisov <kernel@kyup.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit 73f576c04b9410ed19660f74f97521bee6e1c546 upstream.
The memory controller has quite a bit of state that usually outlives the
cgroup and pins its CSS until said state disappears. At the same time
it imposes a 16-bit limit on the CSS ID space to economically store IDs
in the wild. Consequently, when we use cgroups to contain frequent but
small and short-lived jobs that leave behind some page cache, we quickly
run into the 64k limitations of outstanding CSSs. Creating a new cgroup
fails with -ENOSPC while there are only a few, or even no user-visible
cgroups in existence.
Although pinning CSSs past cgroup removal is common, there are only two
instances that actually need an ID after a cgroup is deleted: cache
shadow entries and swapout records.
Cache shadow entries reference the ID weakly and can deal with the CSS
having disappeared when it's looked up later. They pose no hurdle.
Swap-out records do need to pin the css to hierarchically attribute
swapins after the cgroup has been deleted; though the only pages that
remain swapped out after offlining are tmpfs/shmem pages. And those
references are under the user's control, so they are manageable.
This patch introduces a private 16-bit memcg ID and switches swap and
cache shadow entries over to using that. This ID can then be recycled
after offlining when the CSS remains pinned only by objects that don't
specifically need it.
This script demonstrates the problem by faulting one cache page in a new
cgroup and deleting it again:
set -e
mkdir -p pages
for x in `seq 128000`; do
[ $((x % 1000)) -eq 0 ] && echo $x
mkdir /cgroup/foo
echo $$ >/cgroup/foo/cgroup.procs
echo trex >pages/$x
echo $$ >/cgroup/cgroup.procs
rmdir /cgroup/foo
done
When run on an unpatched kernel, we eventually run out of possible IDs
even though there are no visible cgroups:
[root@ham ~]# ./cssidstress.sh
65000
mkdir: cannot create directory '/cgroup/foo': No space left on device
After this patch, the IDs get released upon cgroup destruction and the
cache and css objects get released once memory reclaim kicks in.
[hannes@cmpxchg.org: init the IDR]
Link: http://lkml.kernel.org/r/20160621154601.GA22431@cmpxchg.org
Fixes: b2052564e66d ("mm: memcontrol: continue cache reclaim from offlined groups")
Link: http://lkml.kernel.org/r/20160617162516.GD19084@cmpxchg.org
Reported-by: John Garcia <john.garcia@mesosphere.io>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Nikolay Borisov <kernel@kyup.com>
Signed-off-by: Michal Hocko <mhocko@suse.com>
commit 67245ff332064c01b760afa7a384ccda024bfd24 upstream.
This gets rid of the horrible notion of having that
struct inode *ptmx_inode
be the linchpin of the interface between the pty code and devpts.
By de-emphasizing the ptmx inode, a lot of things actually get cleaner,
and we will have a much saner way forward. In particular, this will
allow us to associate with any particular devpts instance at open-time,
and not be artificially tied to one particular ptmx inode.
The patch itself is actually fairly straightforward, and apart from some
locking and return path cleanups it's pretty mechanical:
- the interfaces that devpts exposes all take "struct pts_fs_info *"
instead of "struct inode *ptmx_inode" now.
NOTE! The "struct pts_fs_info" thing is a completely opaque structure
as far as the pty driver is concerned: it's still declared entirely
internally to devpts. So the pty code can't actually access it in any
way, just pass it as a "cookie" to the devpts code.
- the "look up the pts fs info" is now a single clear operation, that
also does the reference count increment on the pts superblock.
So "devpts_add/del_ref()" is gone, and replaced by a "lookup and get
ref" operation (devpts_get_ref(inode)), along with a "put ref" op
(devpts_put_ref()).
- the pty master "tty->driver_data" field now contains the pts_fs_info,
not the ptmx inode.
- because we don't care about the ptmx inode any more as some kind of
base index, the ref counting can now drop the inode games - it just
gets the ref on the superblock.
- the pts_fs_info now has a back-pointer to the super_block. That's so
that we can easily look up the information we actually need. Although
quite often, the pts fs info was actually all we wanted, and not having
to look it up based on some magical inode makes things more
straightforward.
In particular, now that "devpts_get_ref(inode)" operation should really
be the *only* place we need to look up what devpts instance we're
associated with, and we do it exactly once, at ptmx_open() time.
The other side of this is that one ptmx node could now be associated
with multiple different devpts instances - you could have a single
/dev/ptmx node, and then have multiple mount namespaces with their own
instances of devpts mounted on /dev/pts/. And that's all perfectly sane
in a model where we just look up the pts instance at open time.
This will eventually allow us to get rid of our odd single-vs-multiple
pts instance model, but this patch in itself changes no semantics, only
an internal binding model.
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Jann Horn <jann@thejh.net>
Cc: Greg KH <greg@kroah.com>
Cc: Jiri Slaby <jslaby@suse.com>
Cc: Florian Weimer <fw@deneb.enyo.de>
Cc: Francesco Ruggeri <fruggeri@arista.com>
Cc: "Herton R. Krzesinski" <herton@redhat.com>
commit e41f501d391265ff568f3e49d6128cc30856a36f upstream.
If CONFIG_KASAN is enabled and gcc is configured with
--disable-initfini-array and/or gold linker is used, gcc emits
.ctors/.dtors and .text.startup/.text.exit sections instead of
.init_array/.fini_array. .dtors section is not explicitly accounted in
the linker script and messes vvar/percpu layout.
We want:
ffffffff822bfd80 D _edata
ffffffff822c0000 D __vvar_beginning_hack
ffffffff822c0000 A __vvar_page
ffffffff822c0080 0000000000000098 D vsyscall_gtod_data
ffffffff822c1000 A __init_begin
ffffffff822c1000 D init_per_cpu__irq_stack_union
ffffffff822c1000 A __per_cpu_load
ffffffff822d3000 D init_per_cpu__gdt_page
We got:
ffffffff8279a600 D _edata
ffffffff8279b000 A __vvar_page
ffffffff8279c000 A __init_begin
ffffffff8279c000 D init_per_cpu__irq_stack_union
ffffffff8279c000 A __per_cpu_load
ffffffff8279e000 D __vvar_beginning_hack
ffffffff8279e080 0000000000000098 D vsyscall_gtod_data
ffffffff827ae000 D init_per_cpu__gdt_page
This happens because __vvar_page and .vvar get different addresses in
arch/x86/kernel/vmlinux.lds.S:
. = ALIGN(PAGE_SIZE);
__vvar_page = .;
.vvar : AT(ADDR(.vvar) - LOAD_OFFSET) {
/* work around gold bug 13023 */
__vvar_beginning_hack = .;
Discard .dtors/.fini_array/.text.exit, since we don't call dtors.
Merge .text.startup into init text.
Link: http://lkml.kernel.org/r/1467386363-120030-1-git-send-email-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reviewed-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
commit abb2bafd295fe962bbadc329dbfb2146457283ac upstream.
The EFI firmware on Macs contains a full-fledged network stack for
downloading OS X images from osrecovery.apple.com. Unfortunately
on Macs introduced 2011 and 2012, EFI brings up the Broadcom 4331
wireless card on every boot and leaves it enabled even after
ExitBootServices has been called. The card continues to assert its IRQ
line, causing spurious interrupts if the IRQ is shared. It also corrupts
memory by DMAing received packets, allowing for remote code execution
over the air. This only stops when a driver is loaded for the wireless
card, which may be never if the driver is not installed or blacklisted.
The issue seems to be constrained to the Broadcom 4331. Chris Milsted
has verified that the newer Broadcom 4360 built into the MacBookPro11,3
(2013/2014) does not exhibit this behaviour. The chances that Apple will
ever supply a firmware fix for the older machines appear to be zero.
The solution is to reset the card on boot by writing to a reset bit in
its mmio space. This must be done as an early quirk and not as a plain
vanilla PCI quirk to successfully combat memory corruption by DMAed
packets: Matthew Garrett found out in 2012 that the packets are written
to EfiBootServicesData memory (http://mjg59.dreamwidth.org/11235.html).
This type of memory is made available to the page allocator by
efi_free_boot_services(). Plain vanilla PCI quirks run much later, in
subsys initcall level. In-between a time window would be open for memory
corruption. Random crashes occurring in this time window and attributed
to DMAed packets have indeed been observed in the wild by Chris
Bainbridge.
When Matthew Garrett analyzed the memory corruption issue in 2012, he
sought to fix it with a grub quirk which transitions the card to D3hot:
http://git.savannah.gnu.org/cgit/grub.git/commit/?id=9d34bb85da56
This approach does not help users with other bootloaders and while it
may prevent DMAed packets, it does not cure the spurious interrupts
emanating from the card. Unfortunately the card's mmio space is
inaccessible in D3hot, so to reset it, we have to undo the effect of
Matthew's grub patch and transition the card back to D0.
Note that the quirk takes a few shortcuts to reduce the amount of code:
The size of BAR 0 and the location of the PM capability is identical
on all affected machines and therefore hardcoded. Only the address of
BAR 0 differs between models. Also, it is assumed that the BCMA core
currently mapped is the 802.11 core. The EFI driver seems to always take
care of this.
Michael Büsch, Bjorn Helgaas and Matt Fleming contributed feedback
towards finding the best solution to this problem.
The following should be a comprehensive list of affected models:
iMac13,1 2012 21.5" [Root Port 00:1c.3 = 8086:1e16]
iMac13,2 2012 27" [Root Port 00:1c.3 = 8086:1e16]
Macmini5,1 2011 i5 2.3 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,2 2011 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,3 2011 i7 2.0 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini6,1 2012 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1e12]
Macmini6,2 2012 i7 2.3 GHz [Root Port 00:1c.1 = 8086:1e12]
MacBookPro8,1 2011 13" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,2 2011 15" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,3 2011 17" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro9,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro9,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
For posterity, spurious interrupts caused by the Broadcom 4331 wireless
card resulted in splats like this (stacktrace omitted):
irq 17: nobody cared (try booting with the "irqpoll" option)
handlers:
[<ffffffff81374370>] pcie_isr
[<ffffffffc0704550>] sdhci_irq [sdhci] threaded [<ffffffffc07013c0>] sdhci_thread_irq [sdhci]
[<ffffffffc0a0b960>] azx_interrupt [snd_hda_codec]
Disabling IRQ #17
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79301
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111781
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=728916
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=895951#c16
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1009819
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1098621
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1149632#c5
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1279130
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1332732
Tested-by: Konstantin Simanov <k.simanov@stlk.ru> # [MacBookPro8,1]
Tested-by: Lukas Wunner <lukas@wunner.de> # [MacBookPro9,1]
Tested-by: Bryan Paradis <bryan.paradis@gmail.com> # [MacBookPro9,2]
Tested-by: Andrew Worsley <amworsley@gmail.com> # [MacBookPro10,1]
Tested-by: Chris Bainbridge <chris.bainbridge@gmail.com> # [MacBookPro10,2]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Chris Milsted <cmilsted@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Michael Buesch <m@bues.ch>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: b43-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Link: http://lkml.kernel.org/r/48d0972ac82a53d460e5fce77a07b2560db95203.1465690253.git.lukas@wunner.de
[ Did minor readability edits. ]
commit 94477bff390aa4612d2332c8abafaae0a13d6923 upstream.
There are cases where it is desired to see if a proposed placement
is compatible with a buffer object before calling ttm_bo_validate().
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
commit a118084432d642eeccb961c7c8cc61525a941fcb upstream.
Needed by the following fix.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
[ Upstream commit 82a31b9231f02d9c1b7b290a46999d517b0d312a ]
Similar to commit 9b368814b336 ("net: fix bridge multicast packet checksum validation")
we need to fixup the checksum for CHECKSUM_COMPLETE when
pushing skb on RX path. Otherwise we get similar splats.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Tom Herbert <tom@herbertland.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit eb70db8756717b90c01ccc765fdefc4dd969fc74 ]
People who use PACKET_FANOUT_HASH want a symmetric hash, meaning that
they want packets going in both directions on a flow to hash to the
same bucket.
The core kernel SKB hash became non-symmetric when the ipv6 flow label
and other entities were incorporated into the standard flow hash order
to increase entropy.
But there are no users of PACKET_FANOUT_HASH who want an assymetric
hash, they all want a symmetric one.
Therefore, use the flow dissector to compute a flat symmetric hash
over only the protocol, addresses and ports. This hash does not get
installed into and override the normal skb hash, so this change has
no effect whatsoever on the rest of the stack.
Reported-by: Eric Leblond <eric@regit.org>
Tested-by: Eric Leblond <eric@regit.org>
commit d50039ea5ee63c589b0434baa5ecf6e5075bb6f9 upstream.
Also simplify the logic a bit.
Acked-by: Trond Myklebust <trondmy@primarydata.com>
commit 4c5ea0a9cd02d6aa8adc86e100b2a4cff8d614ff upstream.
The following scenario is possible:
CPU 1 CPU 2
static_key_slow_inc()
atomic_inc_not_zero()
-> key.enabled == 0, no increment
jump_label_lock()
atomic_inc_return()
-> key.enabled == 1 now
-> key.enabled == 1, inc to 2
return
** static key is wrong!
jump_label_update()
jump_label_unlock()
Testing the static key at the point marked by (**) will follow the
wrong path for jumps that have not been patched yet. This can
actually happen when creating many KVM virtual machines with userspace
LAPIC emulation; just run several copies of the following program:
#include <fcntl.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <linux/kvm.h>
int main(void)
for (;;) {
int kvmfd = open("/dev/kvm", O_RDONLY);
int vmfd = ioctl(kvmfd, KVM_CREATE_VM, 0);
close(ioctl(vmfd, KVM_CREATE_VCPU, 1));
close(vmfd);
close(kvmfd);
return 0;
Every KVM_CREATE_VCPU ioctl will attempt a static_key_slow_inc() call.
The static key's purpose is to skip NULL pointer checks and indeed one
of the processes eventually dereferences NULL.
As explained in the commit that introduced the bug:
706249c222f6 ("locking/static_keys: Rework update logic")
jump_label_update() needs key.enabled to be true. The solution adopted
here is to temporarily make key.enabled == -1, and use go down the
slow path when key.enabled <= 0.
Fixes: 706249c222f6 ("locking/static_keys: Rework update logic")
Link: http://lkml.kernel.org/r/1466527937-69798-1-git-send-email-pbonzini@redhat.com
[ Small stylistic edits to the changelog and the code. ]
commit 2c610022711675ee908b903d242f0b90e1db661f upstream.
While this prior commit:
54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()")
... fixes spin_is_locked() and spin_unlock_wait() for the usage
in ipc/sem and netfilter, it does not in fact work right for the
usage in task_work and futex.
So while the 2 locks crossed problem:
spin_lock(A) spin_lock(B)
if (!spin_is_locked(B)) spin_unlock_wait(A)
foo() foo();
... works with the smp_mb() injected by both spin_is_locked() and
spin_unlock_wait(), this is not sufficient for:
flag = 1;
smp_mb(); spin_lock()
spin_unlock_wait() if (!flag)
// add to lockless list
// iterate lockless list
... because in this scenario, the store from spin_lock() can be delayed
past the load of flag, uncrossing the variables and loosing the
guarantee.
This patch reworks spin_is_locked() and spin_unlock_wait() to work in
both cases by exploiting the observation that while the lock byte
store can be delayed, the contender must have registered itself
visibly in other state contained in the word.
It also allows for architectures to override both functions, as PPC
and ARM64 have an additional issue for which we currently have no
generic solution.
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Giovanni Gherdovich <ggherdovich@suse.com>
Cc: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Waiman Long <waiman.long@hpe.com>
Fixes: 54cf809b9512 ("locking,qspinlock: Fix spin_is_locked() and spin_unlock_wait()")
commit 7e8b3dfef16375dbfeb1f36a83eb9f27117c51fd upstream.
The HOSTPC extension registers found in some EHCI implementations form
a variable-length array, with one element for each port. Therefore
the hostpc field in struct ehci_regs should be declared as a
zero-length array, not a single-element array.
This fixes a problem reported by UBSAN.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Wilfried Klaebe <linux-kernel@lebenslange-mailadresse.de>
Tested-by: Wilfried Klaebe <linux-kernel@lebenslange-mailadresse.de>
[ Upstream commit 3697649ff29e0f647565eed04b27a7779c646a22 ]
When we're dealing with clones and the area is not writeable, try
harder and get a copy via pskb_expand_head(). Replace also other
occurences in tc actions with the new skb_try_make_writable().
Reported-by: Ashhad Sheikh <ashhadsheikh394@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit ceb56070359b7329b5678b5d95a376fcb24767be ]
Commit dead9f29ddcc ("perf: Fix race in BPF program unregister") moved
destruction of BPF program from free_event_rcu() callback to __free_event(),
which is problematic if used with tail calls: if prog A is attached as
trace event directly, but at the same time present in a tail call map used
by another trace event program elsewhere, then we need to delay destruction
via RCU grace period since it can still be in use by the program doing the
tail call (the prog first needs to be dropped from the tail call map, then
trace event with prog A attached destroyed, so we get immediate destruction).
Fixes: dead9f29ddcc ("perf: Fix race in BPF program unregister")
[ Upstream commit 9a0fee2b552b1235fb1706ae1fc664ae74573be8 ]
Diag intends to broadcast tcp_sk and udp_sk socket destruction.
Testing sk->sk_protocol for IPPROTO_TCP/IPPROTO_UDP alone is not
sufficient for this. Raw sockets can have the same type.
Add a test for sk->sk_type.
Fixes: eb4cb008529c ("sock_diag: define destruction multicast groups")
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit daddef76c3deaaa7922f9d7b18edbf0a061215c3 ]
The implementation of net_dbg_ratelimited in the CONFIG_DYNAMIC_DEBUG
case was added with 2c94b5373 ("net: Implement net_dbg_ratelimited() for
CONFIG_DYNAMIC_DEBUG case"). The implementation strategy was to take the
usual definition of the dynamic_pr_debug macro, but alter it by adding a
call to "net_ratelimit()" in the if statement. This is, in fact, the
correct approach.
However, while doing this, the author of the commit forgot to surround
fmt by pr_fmt, resulting in unprefixed log messages appearing in the
console. So, this commit adds back the pr_fmt(fmt) invocation, making
net_dbg_ratelimited properly consistent across DEBUG, no DEBUG, and
DYNAMIC_DEBUG cases, and bringing parity with the behavior of
dynamic_pr_debug as well.
Fixes: 2c94b5373 ("net: Implement net_dbg_ratelimited() for CONFIG_DYNAMIC_DEBUG case")
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: Tim Bingham <tbingham@akamai.com>
commit d7591f0c41ce3e67600a982bab6989ef0f07b3ce upstream.
The three variants use same copy&pasted code, condense this into a
helper and use that.
Make sure info.name is 0-terminated.
commit 0188346f21e6546498c2a0f84888797ad4063fc5 upstream.
Always returned 0.
commit ce683e5f9d045e5d67d1312a42b359cb2ab2a13c upstream.
We're currently asserting that targetoff + targetsize <= nextoff.
Extend it to also check that targetoff is >= sizeof(xt_entry).
Since this is generic code, add an argument pointing to the start of the
match/target, we can then derive the base structure size from the delta.
We also need the e->elems pointer in a followup change to validate matches.
commit fc1221b3a163d1386d1052184202d5dc50d302d1 upstream.
32bit rulesets have different layout and alignment requirements, so once
more integrity checks get added to xt_check_entry_offsets it will reject
well-formed 32bit rulesets.
commit 7d35812c3214afa5b37a675113555259cfd67b98 upstream.
Currently arp/ip and ip6tables each implement a short helper to check that
the target offset is large enough to hold one xt_entry_target struct and
that t->u.target_size fits within the current rule.
Unfortunately these checks are not sufficient.
To avoid adding new tests to all of ip/ip6/arptables move the current
checks into a helper, then extend this helper in followup patches.
commit dd5f1b049dc139876801db3cdd0f20d21fd428cc upstream.
The INTID mask is wrong, and is made a signed value, which has
nteresting effects in the KVM emulation. Let's sanitize it.
