commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
commit 54a3ac0c9e5b7213daa358ce74d154352657353a upstream.
Usb3.0 device defines function remote wakeup which is only for interface
recipient rather than device recipient. This is different with usb2.0 device's
remote wakeup feature which is defined for device recipient. According usb3.0
spec 9.4.5, the function remote wakeup can be modified by the SetFeature()
requests using the FUNCTION_SUSPEND feature selector. This patch is to use
correct way to disable usb3.0 device's function remote wakeup after suspend
error and resuming.
This should be backported to kernels as old as 3.4, that contain the
commit 623bef9e03a60adc623b09673297ca7a1cdfb367 "USB/xhci: Enable remote
wakeup for USB3 devices."
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82 upstream.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
commit 0ff8754981261a80f4b77db2536dfea92c2d4539 upstream.
This patch adds [dev,lun]_link_magic value assignment + checks within generic
target_fabric_port_link() and target_fabric_mappedlun_link() code to ensure
destination config_item *target_item sent from configfs_symlink() ->
config_item_operations->allow_link() is the underlying se_device->dev_group
and se_lun->lun_group that we expect to symlink.
Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: CAI Qian <caiqian@redhat.com>
This would reset a connection with any OSD that had an outstanding
request that was taking more than N seconds. The idea was that if the
OSD was buggy, the client could compensate by resending the request.
In reality, this only served to hide server bugs, and we haven't
actually seen such a bug in quite a while. Moreover, the userspace
client code never did this.
More importantly, often the request is taking a long time because the
OSD is trying to recover, or overloaded, and killing the connection
and retrying would only make the situation worse by giving the OSD
more work to do.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
(cherry picked from commit 83aff95eb9d60aff5497e9f44a2ae906b86d8e88)
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream.
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
[bhelgaas: changelog]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ]
Implement the RFC 5691 mitigation against Blind
Reset attack using SYN bit.
Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop
incoming packet, instead of resetting the session.
Add a new SNMP counter to count number of challenge acks sent
in response to SYN packets.
(netstat -s | grep TCPSYNChallenge)
Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session
because of a SYN flag.
Cc: Kiran Kumar Kella <kkiran@broadcom.com>
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ]
Reset attack using RST bit.
Idea is to validate incoming RST sequence,
to match RCV.NXT value, instead of previouly accepted
window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND)
If sequence is in window but not an exact match, send
a "challenge ACK", so that the other part can resend an
RST with the appropriate sequence.
Add a new sysctl, tcp_challenge_ack_limit, to limit
number of challenge ACK sent per second.
Add a new SNMP counter to count number of challenge acks sent.
(netstat -s | grep TCPChallengeACK)
[ Upstream commit e337e24d6624e74a558aa69071e112a65f7b5758 ]
If in either of the above functions inet_csk_route_child_sock() or
__inet_inherit_port() fails, the newsk will not be freed:
unreferenced object 0xffff88022e8a92c0 (size 1592):
comm "softirq", pid 0, jiffies 4294946244 (age 726.160s)
hex dump (first 32 bytes):
0a 01 01 01 0a 01 01 02 00 00 00 00 a7 cc 16 00 ................
02 00 03 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff8153d190>] kmemleak_alloc+0x21/0x3e
[<ffffffff810ab3e7>] kmem_cache_alloc+0xb5/0xc5
[<ffffffff8149b65b>] sk_prot_alloc.isra.53+0x2b/0xcd
[<ffffffff8149b784>] sk_clone_lock+0x16/0x21e
[<ffffffff814d711a>] inet_csk_clone_lock+0x10/0x7b
[<ffffffff814ebbc3>] tcp_create_openreq_child+0x21/0x481
[<ffffffff814e8fa5>] tcp_v4_syn_recv_sock+0x3a/0x23b
[<ffffffff814ec5ba>] tcp_check_req+0x29f/0x416
[<ffffffff814e8e10>] tcp_v4_do_rcv+0x161/0x2bc
[<ffffffff814eb917>] tcp_v4_rcv+0x6c9/0x701
[<ffffffff814cea9f>] ip_local_deliver_finish+0x70/0xc4
[<ffffffff814cec20>] ip_local_deliver+0x4e/0x7f
[<ffffffff814ce9f8>] ip_rcv_finish+0x1fc/0x233
[<ffffffff814cee68>] ip_rcv+0x217/0x267
[<ffffffff814a7bbe>] __netif_receive_skb+0x49e/0x553
[<ffffffff814a7cc3>] netif_receive_skb+0x50/0x82
This happens, because sk_clone_lock initializes sk_refcnt to 2, and thus
a single sock_put() is not enough to free the memory. Additionally, things
like xfrm, memcg, cookie_values,... may have been initialized.
We have to free them properly.
This is fixed by forcing a call to tcp_done(), ending up in
inet_csk_destroy_sock, doing the final sock_put(). tcp_done() is necessary,
because it ends up doing all the cleanup on xfrm, memcg, cookie_values,
xfrm,...
Before calling tcp_done, we have to set the socket to SOCK_DEAD, to
force it entering inet_csk_destroy_sock. To avoid the warning in
inet_csk_destroy_sock, inet_num has to be set to 0.
As inet_csk_destroy_sock does a dec on orphan_count, we first have to
increase it.
Calling tcp_done() allows us to remove the calls to
tcp_clear_xmit_timer() and tcp_cleanup_congestion_control().
A similar approach is taken for dccp by calling dccp_done().
This is in the kernel since 093d282321 (tproxy: fix hash locking issue
when using port redirection in __inet_inherit_port()), thus since
version >= 2.6.37.
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
commit dd67d32dbc5de299d70cc9e10c6c1e29ffa56b92 upstream.
A task is considered frozen enough between freezer_do_not_count() and
freezer_count() and freezers use freezer_should_skip() to test this
condition. This supposedly works because freezer_count() always calls
try_to_freezer() after clearing %PF_FREEZER_SKIP.
However, there currently is nothing which guarantees that
freezer_count() sees %true freezing() after clearing %PF_FREEZER_SKIP
when freezing is in progress, and vice-versa. A task can escape the
freezing condition in effect by freezer_count() seeing !freezing() and
freezer_should_skip() seeing %PF_FREEZER_SKIP.
This patch adds smp_mb()'s to freezer_count() and
freezer_should_skip() such that either %true freezing() is visible to
freezer_count() or !PF_FREEZER_SKIP is visible to
freezer_should_skip().
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream.
Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and
(PageHead) is true, for tail pages. If this is indeed the intended
behavior, which I doubt because it breaks cache cleaning on some ARM
systems, then the nomenclature is highly problematic.
This patch makes sure PageHead is only true for head pages and PageTail
is only true for tail pages, and neither is true for non-compound pages.
[ This buglet seems ancient - seems to have been introduced back in Apr
2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new
macros". And the reason nobody noticed is because the PageHead()
tests are almost all about just sanity-checking, and only used on
pages that are actual page heads. The fact that the old code returned
true for tail pages too was thus not really noticeable. - Linus ]
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Will Deacon <Will.Deacon@arm.com>
Cc: Steve Capper <Steve.Capper@arm.com>
Cc: Christoph Lameter <cl@linux.com>
commit b66c5984017533316fd1951770302649baf1aa33 upstream.
If a series of scripts are executed, each triggering module loading via
unprintable bytes in the script header, kernel stack contents can leak
into the command line.
Normally execution of binfmt_script and binfmt_misc happens recursively.
However, when modules are enabled, and unprintable bytes exist in the
bprm->buf, execution will restart after attempting to load matching
binfmt modules. Unfortunately, the logic in binfmt_script and
binfmt_misc does not expect to get restarted. They leave bprm->interp
pointing to their local stack. This means on restart bprm->interp is
left pointing into unused stack memory which can then be copied into the
userspace argv areas.
After additional study, it seems that both recursion and restart remains
the desirable way to handle exec with scripts, misc, and modules. As
such, we need to protect the changes to interp.
This changes the logic to require allocation for any changes to the
bprm->interp. To avoid adding a new kmalloc to every exec, the default
value is left as-is. Only when passing through binfmt_script or
binfmt_misc does an allocation take place.
For a proof of concept, see DoTest.sh from:
http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/
Cc: halfdog <me@halfdog.net>
Cc: P J P <ppandit@redhat.com>
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream.
This fixes a regression in 3.7-rc, which has since gone into stable.
Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount
imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the
refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went
on expecting alloc_page_vma() to drop the refcount it had acquired.
This deserves a rework: but for now fix the leak in shmem_alloc_page().
Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use
the same refcounting there as in shmem_alloc_page(), delete its onstack
mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() -
those were invented to let swapin_readahead() make an unknown number of
calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e,
alloc_pages_vma() has kept refcount in balance, so now no problem.
Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com>
commit 0181bd5dea2ed0696f84591a92da0b6a1f1a2e62 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 261030215d970c62f799e6e508e3c68fc7ec2aa9 upstream.
For some reason the declaration of ceph_con_get() and
ceph_con_put() did not get deleted in this commit:
d59315ca libceph: drop ceph_con_get/put helpers and nref member
Clean that up.
Signed-off-by: Alex Elder <elder@inktank.com>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
(cherry picked from commit d63b77f4c552cc3a20506871046ab0fcbc332609)
If we encounter an invalid (e.g., zeroed) mapping, return an error
and avoid a divide by zero.
(cherry picked from commit 4a8616920860920abaa51193146fe36b38ef09aa)
Rename flags with CON_FLAG prefix, move the definitions into the c file,
and (better) document their meaning.
(cherry picked from commit 8dacc7da69a491c515851e68de6036f21b5663ce)
Use a simple set of 6 enumerated values for the socket states (CON_STATE_*)
and use those instead of the state bits. All of the con->state checks are
now under the protection of the con mutex, so this is safe. It also
simplifies many of the state checks because we can check for anything other
than the expected state instead of various bits for races we can think of.
This appears to hold up well to stress testing both with and without socket
failure injection on the server side.
(cherry picked from commit a2a3258417eb6a1799cf893350771428875a8287)
Add an atomic variable 'stopping' as flag in struct ceph_messenger,
set this flag to 1 in function ceph_destroy_client(), and add the condition code
in function ceph_data_ready() to test the flag value, if true(1), just return.
Signed-off-by: Guanjun He <gjhe@suse.com>
Reviewed-by: Sage Weil <sage@inktank.com>
(cherry picked from commit d50b409fb8698571d8209e5adfe122e287e31290)
Initialize the type field for messages in a msgpool. The caller was doing
this for osd ops, but not for the reply messages.
Reported-by: Alex Elder <elder@inktank.com>
(cherry picked from commit b7a9e5dd40f17a48a72f249b8bbc989b63bae5fd)
The peer name may change on each open attempt, even when the connection is
reused.
(cherry picked from commit e27947c767f5bed15048f4e4dad3e2eb69133697)
There is no state explicitly defined when a ceph connection is fully
operational. So define one.
It's set when the connection sequence completes successfully, and is
cleared when the connection gets closed.
Be a little more careful when examining the old state when a socket
disconnect event is reported.
(cherry picked from commit d59315ca8c0de00df9b363f94a2641a30961ca1c)
These are no longer used. Every ceph_connection instance is embedded in
another structure, and refcounts manipulated via the get/put ops.
(cherry picked from commit 8921d114f5574c6da2cdd00749d185633ecf88f3)
ceph_con_revoke_message() is passed both a message and a ceph
connection. A ceph_msg allocated for incoming messages on a
connection always has a pointer to that connection, so there's no
need to provide the connection when revoking such a message.
Note that the existing logic does not preclude the message supplied
being a null/bogus message pointer. The only user of this interface
is the OSD client, and the only value an osd client passes is a
request's r_reply field. That is always non-null (except briefly in
an error path in ceph_osdc_alloc_request(), and that drops the
only reference so the request won't ever have a reply to revoke).
So we can safely assume the passed-in message is non-null, but add a
BUG_ON() to make it very obvious we are imposing this restriction.
Rename the function ceph_msg_revoke_incoming() to reflect that it is
really an operation on an incoming message.
(cherry picked from commit 6740a845b2543cc46e1902ba21bac743fbadd0dc)
ceph_con_revoke() is passed both a message and a ceph connection.
Now that any message associated with a connection holds a pointer
to that connection, there's no need to provide the connection when
revoking a message.
This has the added benefit of precluding the possibility of the
providing the wrong connection pointer. If the message's connection
pointer is null, it is not being tracked by any connection, so
revoking it is a no-op. This is supported as a convenience for
upper layers, so they can revoke a message that is not actually
"in flight."
Rename the function ceph_msg_revoke() to reflect that it is really
an operation on a message, not a connection.
(cherry picked from commit 38941f8031bf042dba3ced6394ba3a3b16c244ea)
When a ceph message is queued for sending it is placed on a list of
pending messages (ceph_connection->out_queue). When they are
actually sent over the wire, they are moved from that list to
another (ceph_connection->out_sent). When acknowledgement for the
message is received, it is removed from the sent messages list.
During that entire time the message is "in the possession" of a
single ceph connection. Keep track of that connection in the
message. This will be used in the next patch (and is a helpful
bit of information for debugging anyway).
(cherry picked from commit 1bfd89f4e6e1adc6a782d94aa5d4c53be1e404d7)
Move the initialization of a ceph connection's private pointer,
operations vector pointer, and peer name information into
ceph_con_init(). Rearrange the arguments so the connection pointer
is first. Hide the byte-swapping of the peer entity number inside
ceph_con_init()
(cherry picked from commit 67130934fb579fdf0f2f6d745960264378b57dc8)
A monitor client has a pointer to a ceph connection structure in it.
This is the only one of the three ceph client types that do it this
way; the OSD and MDS clients embed the connection into their main
structures. There is always exactly one ceph connection for a
monitor client, so there is no need to allocate it separate from the
monitor client structure.
So switch the ceph_mon_client structure to embed its
ceph_connection structure.
(cherry picked from commit ce2c8903e76e690846a00a0284e4bd9ee954d680)
Start explicitly keeping track of the state of a ceph connection's
socket, separate from the state of the connection itself. Create
placeholder functions to encapsulate the state transitions.
| NEW* | transient initial state
| con_sock_state_init()
v
| CLOSED | initialized, but no socket (and no
---------- TCP connection)
| \ con_sock_state_connecting()
+ con_sock_state_closed() \
| | CLOSING | socket event; \
| ----------- await close \
| + con_sock_state_closing() |
| / \ v
| / -----------------| CONNECTING | socket created, TCP
| | / -------------- connect initiated
| | | con_sock_state_connected()
| | v
| CONNECTED | TCP connection established
Make the socket state an atomic variable, reinforcing that it's a
distinct transtion with no possible "intermediate/both" states.
This is almost certainly overkill at this point, though the
transitions into CONNECTED and CLOSING state do get called via
socket callback (the rest of the transitions occur with the
connection mutex held). We can back out the atomicity later.
Reviewed-by: Sage Weil<sage@inktank.com>
(cherry picked from commit 928443cd9644e7cfd46f687dbeffda2d1a357ff9)
A ceph_connection holds a mixture of connection state (as in "state
machine" state) and connection flags in a single "state" field. To
make the distinction more clear, define a new "flags" field and use
it rather than the "state" field to hold Boolean flag values.
(cherry picked from commit 15d9882c336db2db73ccf9871ae2398e452f694c)
A ceph client has a pointer to a ceph messenger structure in it.
There is always exactly one ceph messenger for a ceph client, so
there is no need to allocate it separate from the ceph client
structure.
Switch the ceph_client structure to embed its ceph_messenger
structure.
Reviewed-by: Yehuda Sadeh <yehuda@inktank.com>
(cherry picked from commit 6384bb8b8e88a9c6bf2ae0d9517c2c0199177c34)
No code sets a bad_proto method in its ceph connection operations
vector, so just get rid of it.
(cherry picked from commit e5e372da9a469dfe3ece40277090a7056c566838)
The ceph connection state "DEAD" is never set and is therefore not
needed. Eliminate it.
(cherry picked from commit 5bdca4e0768d3e0f4efa43d9a2cc8210aeb91ab9)
In ancient times, the messenger could both initiate and accept connections.
An artifact if that was data structures to store/process an incoming
ceph_msg_connect request and send an outgoing ceph_msg_connect_reply.
Sadly, the negotiation code was referencing those structures and ignoring
important information (like the peer's connect_seq) from the correct ones.
Among other things, this fixes tight reconnect loops where the server sends
RETRY_SESSION and we (the client) retries with the same connect_seq as last
time. This bug pretty easily triggered by injecting socket failures on the
MDS and running some fs workload like workunits/direct_io/test_sync_io.
(cherry picked from commit 8f43fb53894079bf0caab6e348ceaffe7adc651a)
Rather than passing a bunch of arguments to be filled in with the
content of the ceph_auth_handshake buffer now returned by the
get_authorizer method, just use the returned information in the
caller, and drop the unnecessary arguments.
(cherry picked from commit a3530df33eb91d787d08c7383a0a9982690e42d0)
Have the get_authorizer auth_client method return a ceph_auth
pointer rather than an integer, pointer-encoding any returned
error value. This is to pave the way for making use of the
returned value in an upcoming patch.
(cherry picked from commit 74f1869f76d043bad12ec03b4d5f04a8c3d1f157)
Make use of the new ceph_auth_handshake structure in order to reduce
the number of arguments passed to the create_authorizor method in
ceph_auth_client_ops. Use a local variable of that type as a
shorthand in the get_authorizer method definitions.
(cherry picked from commit 6c4a19158b96ea1fb8acbe0c1d5493d9dcd2f147)
The definitions for the ceph_mds_session and ceph_osd both contain
five fields related only to "authorizers." Encapsulate those fields
into their own struct type, allowing for better isolation in some
upcoming patches.
Fix the #includes in "linux/ceph/osd_client.h" to lay out their more
complete canonical path.
(cherry picked from commit f671d4cd9b36691ac4ef42cde44c1b7a84e13631)
Fix the node weight lookup for tree buckets by using a correct accessor.
Reflects ceph.git commit d287ade5bcbdca82a3aef145b92924cf1e856733.
(cherry picked from commit 8b12d47b80c7a34dffdd98244d99316db490ec58)
Move various types from int -> __u32 (or similar), and add const as
appropriate.
This reflects changes that have been present in the userland implementation
for some time.
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit a007c4c3e943ecc054a806c259d95420a188754b upstream.
I don't think there's a practical difference for the range of values
these interfaces should see, but it would be safer to be unambiguous.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
commit 9b395bc3be1cebf0144a127c7e67d56dbdac0930 upstream.
A number of places in the mesh code don't check that
the frame data is present and in the skb header when
trying to access. Add those checks and the necessary
pskb_may_pull() calls. This prevents accessing data
that doesn't actually exist.
To do this, export ieee80211_get_mesh_hdrlen() to be
able to use it in mac80211.
commit 95a7d76897c1e7243d4137037c66d15cbf2cce76 upstream.
As Mukesh explained it, the MMUEXT_TLB_FLUSH_ALL allows the
hypervisor to do a TLB flush on all active vCPUs. If instead
we were using the generic one (which ends up being xen_flush_tlb)
we end up making the MMUEXT_TLB_FLUSH_LOCAL hypercall. But
before we make that hypercall the kernel will IPI all of the
vCPUs (even those that were asleep from the hypervisor
perspective). The end result is that we needlessly wake them
up and do a TLB flush when we can just let the hypervisor
do it correctly.
This patch gives around 50% speed improvement when migrating
idle guest's from one host to another.
Oracle-bug: 14630170
Tested-by: Jingjie Jiang <jingjie.jiang@oracle.com>
Suggested-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 785107923a83d8456bbd8564e288a24d84109a46 upstream.
Some new ACPI 5.0 tables reference resources stored in boot services
memory, so keep that memory around until we have ACPI and can extract
data from it.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/baaa6d44bdc4eb0c58e5d1b4ccd2c729f854ac55.1348876882.git.josh@joshtriplett.org
Cc: Matt Fleming <matt@console-pimps.org>
commit 6ede1fd3cb404c0016de6ac529df46d561bd558b upstream.
We will not map partial pages, so need to make sure memblock
allocation will not allocate those bytes out.
Also we will use for_each_mem_pfn_range() to loop to map memory
range to keep them consistent.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/CAE9FiQVZirvaBMFYRfXMmWEcHbKSicQEHz4VAwUv0xFCk51ZNw@mail.gmail.com
Acked-by: Jacob Shin <jacob.shin@amd.com>
commit b6aa22db7857ab7ed042d6c56b800bfc727cfdff upstream.
commit bf7a01bf7987b63b121d572b240c132ec44129c4 upstream.
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It
silently masks off at least one flag that might be set by the driver
(NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly
others.
Really, as long as driver writers exercise a small amount of care with
NAND_* options, this mask is not necessary at all; it was only here to
prevent certain options from accidentally being set by the driver. But the
original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Tested-by: Huang Shijie <shijie8@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
[ Upstream commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e ]
6a32e4f9dd9219261f8856f817e6655114cfec2f made the vlan code skip marking
vlan-tagged frames for not locally configured vlans as PACKET_OTHERHOST if
there was an rx_handler, as the rx_handler could cause the frame to be received
on a different (virtual) vlan-capable interface where that vlan might be
configured.
As rx_handlers do not necessarily return RX_HANDLER_ANOTHER, this could cause
frames for unknown vlans to be delivered to the protocol stack as if they had
been received untagged.
For example, if an ipv6 router advertisement that's tagged for a locally not
configured vlan is received on an interface with macvlan interfaces attached,
macvlan's rx_handler returns RX_HANDLER_PASS after delivering the frame to the
macvlan interfaces, which caused it to be passed to the protocol stack, leading
to ipv6 addresses for the announced prefix being configured even though those
are completely unusable on the underlying interface.
The fix moves marking as PACKET_OTHERHOST after the rx_handler so the
rx_handler, if there is one, sees the frame unchanged, but afterwards,
before the frame is delivered to the protocol stack, it gets marked whether
there is an rx_handler or not.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
