For at91 boards, there are different IPs for adc. Different IPs has different
STARTUP & PRESCAL mask in ADC_MR.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Add a resource managed devm_iio_trigger_alloc()/devm_iio_triger_free()
to automatically clean up triggers allocated by IIO drivers, thus
leading to simplified IIO drivers code.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Signed-off-by: Kyunmin Park <kyungmin.park@samsung.com>
This patch replace some magic numbers. I believe it makes
the driver more readable.
The magic number 0x26 is the XO system embedded controller
(EC) command 'DCON power enable/disable'.
Number 0x41, and 0x42 are special memory controller settings
register. The 0x41 initialize bit sequence 0x101 means:
enable memory power down function and special SDRAM clock
delay for synchronize SDRAM output and clock signal.
The 0x42 initialize squence 0x101 is wrong. According to
the specification Bit 8 is reserved, thus not in use.
I removed it.
Signed-off-by: Jens Frederich <jfrederich@gmail.com>
We want the staging fixes in here as well.
Pull NFS client bugfixes from Trond Myklebust:
- Stable patch for lockd to fix Oopses due to inappropriate calls to
utsname()->nodename
- Stable patches for sunrpc to fix Oopses on shutdown when using
AF_LOCAL sockets with rpcbind
- Fix memory leak and error checking issues in nfs4_proc_lookup_mountpoint
- Fix a regression with the sync mount option failing to work for nfs4
mounts
- Fix a writeback performance issue when doing cache invalidation
- Remove an incorrect call to nfs_setsecurity in nfs_fhget
* tag 'nfs-for-3.11-4' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv4: Fix up nfs4_proc_lookup_mountpoint
NFS: Remove unnecessary call to nfs_setsecurity in nfs_fhget()
NFSv4: Fix the sync mount option for nfs4 mounts
NFS: Fix writeback performance issue on cache invalidation
SUNRPC: If the rpcbind channel is disconnected, fail the call to unregister
SUNRPC: Don't auto-disconnect from the local rpcbind socket
LOCKD: Don't call utsname()->nodename from nlmclnt_setlockargs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver fixes from Greg KH:
"Here are 3 small fixes for staging/IIO drivers for 3.11-rc5. Nothing
huge, two IIO driver fixes, and a zcache fix. All of these have been
in linux-next for a while"
* tag 'staging-3.11-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: zcache: fix "zcache=" kernel parameter
iio: ti_am335x_adc: Fix wrong samples received on 1st read
iio:trigger: Fix use_count race condition
Pull ACPI and power management fixes from Rafael Wysocki:
- ACPI-based memory hotplug stopped working after a recent change,
because it's not possible to associate sufficiently many "physical"
devices with one ACPI device object due to an artificial limit. Fix
from Rafael J Wysocki removes that limit and makes memory hotplug
work again.
- A change made in 3.9 uncovered a bug in the ACPI processor driver
preventing NUMA nodes from being put offline due to an ordering
issue. Fix from Yasuaki Ishimatsu changes the ordering to make
things work again.
- One of the recent ACPI video commits (that hasn't been reverted so
far) uncovered a bug in the code handling quirky BIOSes that caused
some Asus machines to boot with backlight completely off which made
it quite difficult to use them afterward. Fix from Felipe Contreras
improves the quirk to cover this particular case correctly.
- A cpufreq user space interface change made in 3.10 inadvertently
renamed the ignore_nice_load sysfs attribute to ignore_nice which
resulted in some confusion. Fix from Viresh Kumar changes the name
back to ignore_nice_load.
- An initialization ordering change made in 3.9 broke cpufreq on
loongson2 boards. Fix from Aaro Koskinen restores the correct
initialization ordering there.
- Fix breakage resulting from a mistake made in 3.9 and causing the
detection of some graphics adapters (that were detected correctly
before) to fail. There are two objects representing the same PCIe
port in the affected systems' ACPI tables and both appear as
"enabled" and we are expected to guess which one to use. We used to
choose the right one before by pure luck, but when we tried to
address another similar corner case, the luck went away. This time
we try to make our guessing a bit more educated which is reported to
work on those systems.
- The /proc/acpi/wakeup interface code is missing some locking which
may lead to breakage if that file is written or read during hotplug
of wakeup devices. That should be rare but still possible, so it's
better to start using the appropriate locking there.
* tag 'pm+acpi-3.11-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: Try harder to resolve _ADR collisions for bridges
cpufreq: rename ignore_nice as ignore_nice_load
cpufreq: loongson2: fix regression related to clock management
ACPI / processor: move try_offline_node() after acpi_unmap_lsapic()
ACPI: Drop physical_node_id_bitmap from struct acpi_device
ACPI / PM: Walk physical_node_list under physical_node_lock
ACPI / video: improve quirk check in acpi_video_bqc_quirk()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Some driver fixes (em28xx, coda, usbtv, s5p, hdpvr and ml86v7667) and
a fix for media DocBook"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] em28xx: fix assignment of the eeprom data
[media] hdpvr: fix iteration over uninitialized lists in hdpvr_probe()
[media] usbtv: fix dependency
[media] usbtv: Throw corrupted frames away
[media] usbtv: Fix deinterlacing
[media] v4l2: added missing mutex.h include to v4l2-ctrls.h
[media] DocBook: upgrade media_api DocBook version to 4.2
[media] ml86v7667: fix compile warning: 'ret' set but not used
[media] s5p-g2d: Fix registration failure
[media] media: coda: Fix DT driver data pointer for i.MX27
[media] s5p-mfc: Fix input/output format reporting
Ensure that user_namespace->parent chain can't grow too much.
Currently we use the hardroded 32 as limit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fixes from Mark Brown:
"Two things here, one is a fix for a nasty issue where we were failing
to sync the last register in a block when using raw writes and the
other fixes a missing header for the !REGMAP stubs so that we don't
rely on implicit includes in that case"
* tag 'regmap-v3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: Add missing header for !CONFIG_REGMAP stubs
regmap: cache: Make sure to sync the last register in a block
If rpcbind causes our connection to the AF_LOCAL socket to close after
we've registered a service, then we want to be careful about reconnecting
since the mount namespace may have changed.
By simply refusing to reconnect the AF_LOCAL socket in the case of
unregister, we avoid the need to somehow save the mount namespace. While
this may lead to some services not unregistering properly, it should
be safe.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Nix <nix@esperi.org.uk>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: stable@vger.kernel.org # 3.9.x
In theory, under a given ACPI namespace node there should be only
one child device object with _ADR whose value matches a given bus
address exactly. In practice, however, there are systems in which
multiple child device objects under a given parent have _ADR matching
exactly the same address. In those cases we use _STA to determine
which of the multiple matching devices is enabled, since some systems
are known to indicate which ACPI device object to associate with the
given physical (usually PCI) device this way.
Unfortunately, as it turns out, there are systems in which many
device objects under the same parent have _ADR matching exactly the
same bus address and none of them has _STA, in which case they all
should be regarded as enabled according to the spec. Still, if
those device objects are supposed to represent bridges (e.g. this
is the case for device objects corresponding to PCIe ports), we can
try harder and skip the ones that have no child device objects in the
ACPI namespace. With luck, we can avoid using device objects that we
are not expected to use this way.
Although this only works for bridges whose children also have ACPI
namespace representation, it is sufficient to address graphics
adapter detection issues on some systems, so rework the code finding
a matching device ACPI handle for a given bus address to implement
this idea.
Introduce a new function, acpi_find_child(), taking three arguments:
the ACPI handle of the device's parent, a bus address suitable for
the device's bus type and a bool indicating if the device is a
bridge and make it work as outlined above. Reimplement the function
currently used for this purpose, acpi_get_child(), as a call to
acpi_find_child() with the last argument set to 'false' and make
the PCI subsystem use acpi_find_child() with the bridge information
passed as the last argument to it. [Lan Tianyu notices that it is
not sufficient to use pci_is_bridge() for that, because the device's
subordinate pointer hasn't been set yet at this point, so use
hdr_type instead.]
This change fixes a regression introduced inadvertently by commit
33f767d (ACPI: Rework acpi_get_child() to be more efficient) which
overlooked the fact that for acpi_walk_namespace() "post-order" means
"after all children have been visited" rather than "on the way back",
so for device objects without children and for namespace walks of
depth 1, as in the acpi_get_child() case, the "post-order" callbacks
ordering is actually the same as the ordering of "pre-order" ones.
Since that commit changed the namespace walk in acpi_get_child() to
terminate after finding the first matching object instead of going
through all of them and returning the last one, it effectively
changed the result returned by that function in some rare cases and
that led to problems (the switch from a "pre-order" to a "post-order"
callback was supposed to prevent that from happening, but it was
ineffective).
As it turns out, the systems where the change made by commit
33f767d actually matters are those where there are multiple ACPI
device objects representing the same PCIe port (which effectively
is a bridge). Moreover, only one of them, and the one we are
expected to use, has child device objects in the ACPI namespace,
so the regression can be addressed as described above.
References: https://bugzilla.kernel.org/show_bug.cgi?id=60561
Reported-by: Peter Wu <lekensteyn@gmail.com>
Tested-by: Vladimir Lalov <mail@vlalov.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fixes from Steven Rostedt:
"Oleg Nesterov has been working hard in closing all the holes that can
lead to race conditions between deleting an event and accessing an
event debugfs file. This included a fix to the debugfs system (acked
by Greg Kroah-Hartman). We think that all the holes have been patched
and hopefully we don't find more. I haven't marked all of them for
stable because I need to examine them more to figure out how far back
some of the changes need to go.
Along the way, some other fixes have been made. Alexander Z Lam fixed
some logic where the wrong buffer was being modifed.
Andrew Vagin found a possible corruption for machines that actually
allocate cpumask, as a reference to one was being zeroed out by
mistake.
Dhaval Giani found a bad prototype when tracing is not configured.
And I not only had some changes to help Oleg, but also finally fixed a
long standing bug that Dave Jones and others have been hitting, where
a module unload and reload can cause the function tracing accounting
to get screwed up"
* tag 'trace-fixes-3.11-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Fix reset of time stamps during trace_clock changes
tracing: Make TRACE_ITER_STOP_ON_FREE stop the correct buffer
tracing: Fix trace_dump_stack() proto when CONFIG_TRACING is not set
tracing: Fix fields of struct trace_iterator that are zeroed by mistake
tracing/uprobes: Fail to unregister if probe event files are in use
tracing/kprobes: Fail to unregister if probe event files are in use
tracing: Add comment to describe special break case in probe_remove_event_call()
tracing: trace_remove_event_call() should fail if call/file is in use
debugfs: debugfs_remove_recursive() must not rely on list_empty(d_subdirs)
ftrace: Check module functions being traced on reload
ftrace: Consolidate some duplicate code for updating ftrace ops
tracing: Change remove_event_file_dir() to clear "d_subdirs"->i_private
tracing: Introduce remove_event_file_dir()
tracing: Change f_start() to take event_mutex and verify i_private != NULL
tracing: Change event_filter_read/write to verify i_private != NULL
tracing: Change event_enable/disable_read() to verify i_private != NULL
tracing: Turn event/id->i_private into call->event.type
regmap.h requires linux/err.h if CONFIG_REGMAP is not defined. Without it I get
error.
CC drivers/media/platform/exynos4-is/fimc-reg.o
In file included from drivers/media/platform/exynos4-is/fimc-reg.c:14:0:
include/linux/regmap.h: In function ‘regmap_write’:
include/linux/regmap.h:525:10: error: ‘EINVAL’ undeclared (first use in this function)
include/linux/regmap.h:525:10: note: each undeclared identifier is reported only once for each function it appears in
Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Cc: stable@kernel.org
The physical_node_id_bitmap in struct acpi_device is only used for
looking up the first currently unused dependent phyiscal node ID
by acpi_bind_one(). It is not really necessary, however, because
acpi_bind_one() walks the entire physical_node_list of the given
device object for sanity checking anyway and if that list is always
sorted by node_id, it is straightforward to find the first gap
between the currently used node IDs and use that number as the ID
of the new list node.
This also removes the artificial limit of the maximum number of
dependent physical devices per ACPI device object, which now depends
only on the capacity of unsigend int. As a result, it fixes a
regression introduced by commit e2ff394 (ACPI / memhotplug: Bind
removable memory blocks to ACPI device nodes) that caused
acpi_memory_enable_device() to fail when the number of 128 MB blocks
within one removable memory module was greater than 32.
Reported-and-tested-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Second round of IIO fixes for the 3.11 cycle.
1) Fix a long term race in the IIO trigger handling.
This only effects cases where a single trigger is in use
by multiple devices.
2) ti_am335x fix an issue with incorrect data due to reading before
the sequencer is finished.
Pull networking fixes from David Miller:
1) Don't ignore user initiated wireless regulatory settings on cards
with custom regulatory domains, from Arik Nemtsov.
2) Fix length check of bluetooth information responses, from Jaganath
Kanakkassery.
3) Fix misuse of PTR_ERR in btusb, from Adam Lee.
4) Handle rfkill properly while iwlwifi devices are offline, from
Emmanuel Grumbach.
5) Fix r815x devices DMA'ing to stack buffers, from Hayes Wang.
6) Kernel info leak in ATM packet scheduler, from Dan Carpenter.
7) 8139cp doesn't check for DMA mapping errors, from Neil Horman.
8) Fix bridge multicast code to not snoop when no querier exists,
otherwise mutlicast traffic is lost. From Linus Lüssing.
9) Avoid soft lockups in fib6_run_gc(), from Michal Kubecek.
10) Fix races in automatic address asignment on ipv6, which can result
in incorrect lifetime assignments. From Jiri Benc.
11) Cure build bustage when CONFIG_NET_LL_RX_POLL is not set and rename
it CONFIG_NET_RX_BUSY_POLL to eliminate the last reference to the
original naming of this feature. From Cong Wang.
12) Fix crash in TIPC when server socket creation fails, from Ying Xue.
13) macvlan_changelink() silently succeeds when it shouldn't, from
Michael S Tsirkin.
14) HTB packet scheduler can crash due to sign extension, fix from
Stephen Hemminger.
15) With the cable unplugged, r8169 prints out a message every 10
seconds, make it netif_dbg() instead of netif_warn(). From Peter
Wu.
16) Fix memory leak in rtm_to_ifaddr(), from Daniel Borkmann.
17) sis900 gets spurious TX queue timeouts due to mismanagement of link
carrier state, from Denis Kirjanov.
18) Validate somaxconn sysctl to make sure it fits inside of a u16.
From Roman Gushchin.
19) Fix MAC address filtering on qlcnic, from Shahed Shaikh.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits)
qlcnic: Fix for flash update failure on 83xx adapter
qlcnic: Fix link speed and duplex display for 83xx adapter
qlcnic: Fix link speed display for 82xx adapter
qlcnic: Fix external loopback test.
qlcnic: Removed adapter series name from warning messages.
qlcnic: Free up memory in error path.
qlcnic: Fix ingress MAC learning
qlcnic: Fix MAC address filter issue on 82xx adapter
net: ethernet: davinci_emac: drop IRQF_DISABLED
netlabel: use domain based selectors when address based selectors are not available
net: check net.core.somaxconn sysctl values
sis900: Fix the tx queue timeout issue
net: rtm_to_ifaddr: free ifa if ifa_cacheinfo processing fails
r8169: remove "PHY reset until link up" log spam
net: ethernet: cpsw: drop IRQF_DISABLED
htb: fix sign extension bug
macvlan: handle set_promiscuity failures
macvlan: better mode validation
tipc: fix oops when creating server socket fails
net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLL
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com>
Add a resource managed devm_iio_device_alloc()/devm_iio_device_free()
to automatically clean up any allocations made by IIO drivers,
thus leading to simplified IIO drivers code.
In addition, this will allow IIO drivers to use other devm_*() API
(like devm_request_irq) and don't care about the race between
iio_device_free() and the release of resources by Device core
during driver removing.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com>
Tested-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
There are no users of this macro left and we have come to the conclusion that it
is not a good idea to expose the raw chip reset to userspace so the macro is
very unlikely to be used in new drivers.
This patch add support to redirect the DRDY interrupt on INT1 or INT2
on accelerometer and pressure sensors.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
When CONFIG_TRACING is not enabled, the stub prototype for trace_dump_stack()
is incorrect. It has (void) when it should be (int).
Link: http://lkml.kernel.org/r/CAPhKKr_H=ukFnBL4WgDOVT5ay2xeF-Ho+CA0DWZX0E2JW-=vSQ@mail.gmail.com
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Cc: stable@vger.kernel.org # 2.6.30
Signed-off-by: Andrew Vagin <avagin@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma fixes from Roland Dreier:
- Fixes for the newly merged mlx5 hardware driver
- Stack info leak fixes from Dan Carpenter
- Fixes for pkey table handling with SR-IOV
- A few other small things
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IPoIB: Fix pkey change flow for virtualization environments
IPoIB: Make sure child devices use valid/proper pkeys
IB/core: Create QP1 using the pkey index which contains the default pkey
mlx5_core: Variable may be used uninitialized
mlx5_core: Implement new initialization sequence
mlx5_core: Fix use after free in mlx5_cmd_comp_handler()
IB/mlx5: Fix stack info leak in mlx5_ib_alloc_ucontext()
IB/mlx5: Fix error return code in init_one()
IB/mlx4: Use default pkey when creating tunnel QPs
RDMA/cma: Only call cma_save_ib_info() for CM REQs
RDMA/cma: Fix accessing invalid private data for UD
RDMA/cma: Fix gcc warning
Revert "RDMA/nes: Fix compilation error when nes_debug is enabled"
IB/qib: Add err_decode() call for ring dump
RDMA/cxgb3: Fix stack info leak in iwch_create_cq()
RDMA/nes: Fix info leaks in nes_create_qp() and nes_create_cq()
RDMA/ocrdma: Fix several stack info leaks
RDMA/cxgb4: Fix stack info leak in c4iw_create_qp()
RDMA/ocrdma: Remove unused include
- Revert two cpuidle commits added during the 3.8 development cycle
that turn out to have introduced a significant performance regression
as requested by Jeremy Eder.
- The recent patches that made the freezer less heavy-weight introduced
a regression causing user-space-driven hibernation using the ioctl()
interface to block indefinitely when the hibernate process executes
try_to_freeze(). Fix from Colin Cross addresses this by adding a
process flag to mark the hibernate/suspend process to inform the
freezer that that process should be ignored.
- One of the recent cpufreq reverts uncovered a problem in the core
causing the cpufreq driver module refcount to become negative after a
system suspend-resume cycle. Fix from Rafael J Wysocki.
- The evaluation of the ACPI battery _BIX method has never worked
correctly, because the commit that added support for it forgot to
take the "Revision" field in the return package into account. As a
result, the reading of battery info doesn't work at all on some
systems, which is addressed by a fix from Lan Tianyu.
* tag 'pm+acpi-3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
freezer: set PF_SUSPEND_TASK flag on tasks that call freeze_processes
ACPI / battery: Fix parsing _BIX return value
cpufreq: Fix cpufreq driver module refcount balance after suspend/resume
Revert "cpuidle: Quickly notice prediction failure for repeat mode"
Revert "cpuidle: Quickly notice prediction failure in general case"
Eliezer renames several *ll_poll to *busy_poll, but forgets
CONFIG_NET_LL_RX_POLL, so in case of confusion, rename it too.
Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
When CONFIG_NET_LL_RX_POLL is not set, I got:
net/socket.c: In function ‘sock_poll’:
net/socket.c:1165:4: error: implicit declaration of function ‘sk_busy_loop’ [-Werror=implicit-function-declaration]
Fix this by adding a nop when !CONFIG_NET_LL_RX_POLL.
On a high-traffic router with many processors and many IPv6 dst
entries, soft lockup in fib6_run_gc() can occur when number of
entries reaches gc_thresh.
This happens because fib6_run_gc() uses fib6_gc_lock to allow
only one thread to run the garbage collector but ip6_dst_gc()
doesn't update net->ipv6.ip6_rt_last_gc until fib6_run_gc()
returns. On a system with many entries, this can take some time
so that in the meantime, other threads pass the tests in
ip6_dst_gc() (ip6_rt_last_gc is still not updated) and wait for
the lock. They then have to run the garbage collector one after
another which blocks them for quite long.
Resolve this by replacing special value ~0UL of expire parameter
to fib6_run_gc() by explicit "force" parameter to choose between
spin_lock_bh() and spin_trylock_bh() and call fib6_run_gc() with
force=false if gc_thresh is reached but not max_size.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
Pull drm fixes from Dave Airlie:
"Radeon, nouveau, exynos, intel, mgag200..
Not all strictly regressions but there was probably only one patch I'd
have really left out and it didn't seem worth respinning exynos to
avoid it, the line change count is quite low.
radeon: regressions + more dynamic powermanagement fixes, since DPM
is a new feature, and off by default I'd prefer to keep merging
fixes since it has a large userbase already and I'd like to keep
them on mainline
nouveau: is mostly regression fixes
i915: is a regression fix since Daniel is on holidays I've merged it.
mgag200: I've picked a bunch of targetted fixes from a big bunch of
distro patches,
exynos: build fixes mostly, one regression fix
I expect things will slow right down now, I may send on the intel
early quirk from Jesse separatly, since I think the x86 maintainers
acked it"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (37 commits)
drm/i915: fix missed hunk after GT access breakage
drm/radeon/dpm: re-enable cac control on SI
drm/radeon/dpm: fix calculations in si_calculate_leakage_for_v_and_t_formula
drm: fix 64 bit drm fixed point helpers
drm/radeon/atom: initialize more atom interpretor elements to 0
drm/nouveau: fix semaphore dmabuf obj
drm/nouveau/vm: make vm refcount into a kref
drm/nv31/mpeg: don't recognize nv3x cards as having nv44 graph class
drm/nv40/mpeg: write magic value to channel object to make it work
drm/nouveau: fix size check for cards without vm
drm/nv50-/disp: remove dcb_outp_match call, and related variables
drm/nva3-/disp: fix hda eld writing, needs to be padded
drm/nv31/mpeg: fix mpeg engine initialization
drm/nv50/mc: include vp in the fb error reporting mask
drm/nouveau: fix null pointer dereference in poll_changed
drm/nv50/gpio: post-nv92 cards have 32 interrupt lines
drm/nvc0/fb: take lock in nvc0_ram_put()
drm/nouveau/core: xtensa firmware size needs to be 0x40000 no matter what
drm/mgag200: Fix LUT programming for 16bpp
drm/mgag200: Fix framebuffer pitch calculation
Merge more patches from Andrew Morton:
"A bunch of fixes.
Plus Joe's printk move and rework. It's not a -rc3 thing but now
would be a nice time to offload it, while things are quiet. I've been
sitting on it all for a couple of weeks, no issues"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
vmpressure: make sure there are no events queued after memcg is offlined
vmpressure: do not check for pending work to prevent from new work
vmpressure: change vmpressure::sr_lock to spinlock
printk: rename struct log to struct printk_log
printk: use pointer for console_cmdline indexing
printk: move braille console support into separate braille.[ch] files
printk: add console_cmdline.h
printk: move to separate directory for easier modification
drivers/rtc/rtc-twl.c: fix: rtcX/wakealarm attribute isn't created
mm: zbud: fix condition check on allocation size
thp, mm: avoid PageUnevictable on active/inactive lru lists
mm/swap.c: clear PageActive before adding pages onto unevictable list
arch/x86/platform/ce4100/ce4100.c: include reboot.h
mm: sched: numa: fix NUMA balancing when !SCHED_DEBUG
rapidio: fix use after free in rio_unregister_scan()
.gitignore: ignore *.lz4 files
MAINTAINERS: dynamic debug: Jason's not there...
dmi_scan: add comments on dmi_present() and the loop in dmi_scan_machine()
ocfs2/refcounttree: add the missing NULL check of the return value of find_or_create_page()
mm: mempolicy: fix mbind_range() && vma_adjust() interaction
vmpressure is called synchronously from reclaim where the target_memcg
is guaranteed to be alive but the eventfd is signaled from the work
queue context. This means that memcg (along with vmpressure structure
which is embedded into it) might go away while the work item is pending
which would result in use-after-release bug.
We have two possible ways how to fix this. Either vmpressure pins memcg
before it schedules vmpr->work and unpin it in vmpressure_work_fn or
explicitely flush the work item from the css_offline context (as
suggested by Tejun).
This patch implements the later one and it introduces vmpressure_cleanup
which flushes the vmpressure work queue item item. It hooks into
mem_cgroup_css_offline after the memcg itself is cleaned up.
Reported-by: Tejun Heo <tj@kernel.org>
Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
Cc: Li Zefan <lizefan@huawei.com>
Acked-by: Tejun Heo <tj@kernel.org>
There is nothing that can sleep inside critical sections protected by
this lock and those sections are really small so there doesn't make much
sense to use mutex for them. Change the log to a spinlock
Reviewed-by: Tejun Heo <tj@kernel.org>
Introduce enbale_hca and disable_hca commands to signify when the
driver starts or ceases to operate on the device.
In addition the driver will use boot and init pages count; boot pages
is required to allow firmware to complete boot commands and the other
to complete init hca. Command interface revision is bumped to 4 to
enforce using supported firmware.
This patch breaks compatibility with old versions of firmware (< 4);
however, the first GA firmware we will publish will support version 4
so this should not be a problem.
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
1) Fix association failures not triggering a connect-failure event in
cfg80211, from Johannes Berg.
2) Eliminate a potential NULL deref with older iptables tools when
configuring xt_socket rules, from Eric Dumazet.
3) Missing RTNL locking in wireless regulatory code, from Johannes
Berg.
4) Fix OOPS caused by firmware loading races in ath9k_htc, from Alexey
Khoroshilov.
5) Fix usb URB leak in usb_8dev CAN driver, also from Alexey
Khoroshilov.
6) VXLAN namespace teardown fails to unregister devices, from Stephen
Hemminger.
7) Fix multicast settings getting dropped by firmware in qlcnic driver,
from Sucheta Chakraborty.
8) Add sysctl range enforcement for tcp_syn_retries, from Michal Tesar.
9) Fix a nasty bug in bridging where an active timer would get
reinitialized with a setup_timer() call. From Eric Dumazet.
10) Fix use after free in new mlx5 driver, from Dan Carpenter.
11) Fix freed pointer reference in ipv6 multicast routing on namespace
cleanup, from Hannes Frederic Sowa.
12) Some usbnet drivers report TSO and SG in their feature set, but the
usbnet layer doesn't really support them. From Eric Dumazet.
13) Fix crash on EEH errors in tg3 driver, from Gavin Shan.
14) Drop cb_lock when requesting modules in genetlink, from Stanislaw
Gruszka.
15) Kernel stack leaks in cbq scheduler and af_key pfkey messages, from
Dan Carpenter.
16) FEC driver erroneously signals NETDEV_TX_BUSY on transmit leading to
endless loops, from Uwe Kleine-König.
17) Fix hangs from loading mvneta driver, from Arnaud Patard.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (84 commits)
mlx5: fix error return code in mlx5_alloc_uuars()
mvneta: Try to fix mvneta when compiled as module
mvneta: Fix hang when loading the mvneta driver
atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring
genetlink: fix usage of NLM_F_EXCL or NLM_F_REPLACE
af_key: more info leaks in pfkey messages
net/fec: Don't let ndo_start_xmit return NETDEV_TX_BUSY without link
net_sched: Fix stack info leak in cbq_dump_wrr().
igb: fix vlan filtering in promisc mode when not in VT mode
ixgbe: Fix Tx Hang issue with lldpad on 82598EB
genetlink: release cb_lock before requesting additional module
net: fec: workaround stop tx during errata ERR006358
qlcnic: Fix diagnostic interrupt test for 83xx adapters.
qlcnic: Fix setting Guest VLAN
qlcnic: Fix operation type and command type.
qlcnic: Fix initialization of work function.
Revert "atl1c: Fix misuse of netdev_alloc_skb in refilling rx ring"
net/tg3: Fix warning from pci_disable_device()
net/tg3: Fix kernel crash
Change trace_remove_event_call(call) to return the error if this
call is active. This is what the callers assume but can't verify
outside of the tracing locks. Both trace_kprobe.c/trace_uprobe.c
need the additional changes, unregister_trace_probe() should abort
if trace_remove_event_call() fails.
The caller is going to free this call/file so we must ensure that
nobody can use them after trace_remove_event_call() succeeds.
debugfs should be fine after the previous changes and event_remove()
does TRACE_REG_UNREGISTER, but still there are 2 reasons why we need
the additional checks:
- There could be a perf_event(s) attached to this tp_event, so the
patch checks ->perf_refcount.
- TRACE_REG_UNREGISTER can be suppressed by FTRACE_EVENT_FL_SOFT_MODE,
so we simply check FTRACE_EVENT_FL_ENABLED protected by event_mutex.
Link: http://lkml.kernel.org/r/20130729175033.GB26284@redhat.com
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Loading a firmware into a target is typically called firmware
download, not firmware upload. So we rename the netlink API to
NFC_CMD_FW_DOWNLOAD in order to avoid any terminology confusion from
userspace.
Alex writes:
- more fixes for SI dpm
- fix DP on some rv6xx boards
* 'drm-fixes-3.11' of git://people.freedesktop.org/~agd5f/linux:
Sign bit wasn't handled properly and a small typo.
Thanks to Christian for helping me sort this out.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Calling freeze_processes sets a global flag that will cause any
process that calls try_to_freeze to enter the refrigerator. It
skips sending a signal to the current task, but if the current
task ever hits try_to_freeze, all threads will be frozen and the
system will deadlock.
Set a new flag, PF_SUSPEND_TASK, on the task that calls
freeze_processes. The flag notifies the freezer that the thread
is involved in suspend and should not be frozen. Also add a
WARN_ON in thaw_processes if the caller does not have the
PF_SUSPEND_TASK flag set to catch if a different task calls
thaw_processes than the one that called freeze_processes, leaving
a task with PF_SUSPEND_TASK permanently set on it.
Threads that spawn off a task with PF_SUSPEND_TASK set (which
swsusp does) will also have PF_SUSPEND_TASK set, preventing them
from freezing while they are helping with suspend, but they need
to be dead by the time suspend is triggered, otherwise they may
run when userspace is expected to be frozen. Add a WARN_ON in
thaw_processes if more than one thread has the PF_SUSPEND_TASK
flag set.
Reported-and-tested-by: Michael Leun <lkml20130126@newton.leun.net>
Signed-off-by: Colin Cross <ccross@android.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394
Pull firewire regression fix from Stefan Richter:
"This fixes corrupted video capture, seen with IIDC/DCAM video and
certain buffer settings. (Regression since v3.4 inclusive.)"
* tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394:
firewire: fix libdc1394/FlyCap2 iso event regression
Revert commit 69a37bea (cpuidle: Quickly notice prediction failure for
repeat mode), because it has been identified as the source of a
significant performance regression in v3.8 and later as explained by
Jeremy Eder:
We believe we've identified a particular commit to the cpuidle code
that seems to be impacting performance of variety of workloads.
The simplest way to reproduce is using netperf TCP_RR test, so
we're using that, on a pair of Sandy Bridge based servers. We also
have data from a large database setup where performance is also
measurably/positively impacted, though that test data isn't easily
share-able.
Included below are test results from 3 test kernels:
kernel reverts
1) vanilla upstream (no reverts)
2) perfteam2 reverts e11538d1f03914eb92af5a1a378375c05ae8520c
3) test reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
In summary, netperf TCP_RR numbers improve by approximately 4%
after reverting 69a37beabf1f0a6705c08e879bdd5d82ff6486c4. When
69a37beabf1f0a6705c08e879bdd5d82ff6486c4 is included, C0 residency
never seems to get above 40%. Taking that patch out gets C0 near
100% quite often, and performance increases.
The below data are histograms representing the %c0 residency @
1-second sample rates (using turbostat), while under netperf test.
- If you look at the first 4 histograms, you can see %c0 residency
almost entirely in the 30,40% bin.
- The last pair, which reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4,
shows %c0 in the 80,90,100% bins.
Below each kernel name are netperf TCP_RR trans/s numbers for the
particular kernel that can be disclosed publicly, comparing the 3
test kernels. We ran a 4th test with the vanilla kernel where
we've also set /dev/cpu_dma_latency=0 to show overall impact
boosting single-threaded TCP_RR performance over 11% above
baseline.
3.10-rc2 vanilla RX + c0 lock (/dev/cpu_dma_latency=0):
TCP_RR trans/s 54323.78
3.10-rc2 vanilla RX (no reverts)
TCP_RR trans/s 48192.47
Receiver %c0
0.0000 - 10.0000 [ 1]: *
10.0000 - 20.0000 [ 0]:
20.0000 - 30.0000 [ 0]:
30.0000 - 40.0000 [ 59]:
40.0000 - 50.0000 [ 1]: *
50.0000 - 60.0000 [ 0]:
60.0000 - 70.0000 [ 0]:
70.0000 - 80.0000 [ 0]:
80.0000 - 90.0000 [ 0]:
90.0000 - 100.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 11]: ***********
40.0000 - 50.0000 [ 49]:
3.10-rc2 perfteam2 RX (reverts commit
e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 49698.69
Receiver %c0
10.0000 - 20.0000 [ 1]: *
40.0000 - 50.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 2]: **
40.0000 - 50.0000 [ 58]:
3.10-rc2 test RX (reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
and e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 47766.95
Receiver %c0
30.0000 - 40.0000 [ 27]: ***************************
40.0000 - 50.0000 [ 2]: **
60.0000 - 70.0000 [ 2]: **
90.0000 - 100.0000 [ 28]: ****************************
Sender:
50.0000 - 60.0000 [ 1]: *
70.0000 - 80.0000 [ 3]: ***
80.0000 - 90.0000 [ 7]: *******
90.0000 - 100.0000 [ 38]: **************************************
These results demonstrate gaining back the tendency of the CPU to
stay in more responsive, performant C-states (and thus yield
measurably better performance), by reverting commit
Requested-by: Jeremy Eder <jeder@redhat.com>
Tested-by: Len Brown <len.brown@intel.com>
Cc: 3.8+ <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
- Driver fixes for AM33xx, SIRF and PFC pin controllers
- Fix a compile warning from the pinctrl single-register driver
- Fix a little nasty memory leak
* tag 'pinctrl-for-v3.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl: fix a memleak when freeing maps
pinctrl: pinctrl-single: fix compile warning when no CONFIG_PM
pinctrl: sh-pfc: fix SDHI0 VccQ regulator on sh73a0 with DT
arm/dts: sirf: fix the pingroup name mismatch between drivers and dts
pinctrl: sirf: add usp0_uart_nostreamctrl pin group for usp-uart without flowctrl
pinctrl: sirf: fix the pin number and mux bit for usp0
pinctrl: am33xx dt binding: correct include path
Commit 18d627113b83 (firewire: prevent dropping of completed iso packet
header data) was intended to be an obvious bug fix, but libdc1394 and
FlyCap2 depend on the old behaviour by ignoring all returned information
and thus not noticing that not all packets have been received yet. The
result was that the video frame buffers would be saved before they
contained the correct data.
Reintroduce the old behaviour for old clients.
Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com>
Tested-by: Josep Bosch <jep250@gmail.com>
Cc: <stable@vger.kernel.org> # 3.4+
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
"These are just two fixes, a revert of the would-be backlight fix that
didn't work and an intel_pstate fix for two problems related to
maximum P-state selection.
Specifics:
- Revert of the ACPI video commit that I hoped would help fix
backlight problems related to Windows 8 compatibility on some
systems. Unfortunately, it turned out to cause problems to happen
too.
- Fix for two problems in intel_pstate, a possible failure to respond
to a load change on a quiet system and a possible failure to select
the highest available P-state on some systems. From Dirk
Brandewie"
* tag 'pm+acpi-3.11-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
Revert "ACPI / video / i915: No ACPI backlight if firmware expects Windows 8"
cpufreq / intel_pstate: Change to scale off of max P-state
Pull ARM SoC fixes from Olof Johansson:
"This is a largeish batch of fixes, mostly because I missed -rc2 due to
travel/vacation. So in number these are a bit more than ideal unless
you amortize them over two -rcs.
Quick breakdown:
- Defconfig updates
- Making multi_v7_defconfig useful on more hardware to encourage
single-image usage
- Davinci and nomadik updates due to new code merged this merge
window
- Fixes for UART on Samsung platforms, both PM and clock-related
- A handful of warning fixes from defconfig builds, including for
max8925 backlight and pxamci (both with appropriate acks)
- Exynos5440 fixes for LPAE configuration, PM
- ...plus a bunch of other smaller changes all over the place
I expect to switch to regressions-or-severe-bugs-only fixes from here
on out"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits)
mfd: max8925: fix dt code for backlight
ARM: omap5: Only select errata 798181 if SMP
ARM: EXYNOS: Update CONFIG_ARCH_NR_GPIO for Exynos
ARM: EXYNOS: Fix low level debug support
ARM: SAMSUNG: Save/restore only selected uart's registers
ARM: SAMSUNG: Add SAMSUNG_PM config option to select pm
ARM: S3C24XX: Add missing clkdev entries for s3c2440 UART
ARM: multi_v7_defconfig: Select USB chipidea driver
ARM: pxa: propagate errors from regulator_enable() to pxamci
ARM: zynq: fix compilation warning
ARM: keystone: fix compilation warning
ARM: highbank: Only touch common coherency control register fields
ARM: footbridge: fix overlapping PCI mappings
dmaengine: shdma: fix a build failure on platforms with no DMA support
ARM: STi: Set correct ARM ERRATAs.
ARM: dts: STi: Fix pinconf setup for STiH416 serial2
ARM: nomadik: configure for NO_HZ and HRTIMERS
ARM: nomadik: update defconfig base
ARM: nomadik: Update MMC defconfigs
ARM: davinci: defconfig: enable EDMA driver
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of USB fixes for 3.11-rc3.
Lots of little things, nothing major. A number of new device ids,
build fixes for DMA, and a bunch of other minor things. All of these
have been in the linux-next tree"
* tag 'usb-3.11-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (40 commits)
usb: Clear both buffers when clearing a control transfer TT buffer.
usb/gadget: free opts struct on error recovery
USB: mos7840: fix memory leak in open
usb: serial: option.c: remove ONDA MT825UP product ID fromdriver
usb: serial: option: add Olivetti Olicard 200
usb: serial: option: blacklist ONDA MT689DC QMI interface
xhci: fix null pointer dereference on ring_doorbell_for_active_rings
usb: host: xhci: Enable XHCI_SPURIOUS_SUCCESS for all controllers with xhci 1.0
usb: fix build warning in pci-quirks.h when CONFIG_PCI is not enabled
usb: xhci: Mark two functions __maybe_unused
xhci: Avoid NULL pointer deref when host dies.
usb: serial: option: Add ONYX 3G device support
USB: ti_usb_3410_5052: fix dynamic-id matching
usb: option: add TP-LINK MA260
USB: option: add D-Link DWM-152/C1 and DWM-156/C1
USB: EHCI: Fix resume signalling on remote wakeup
USB: cp210x: add MMB and PI ZigBee USB Device Support
usb: cp210x support SEL C662 Vendor/Device
USB: option: append Petatel NP10T device to GSM modems list
USB: misc: Add Manhattan Hi-Speed USB DVI Converter to sisusbvga
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Assorted libata updates.
The most critical one is a fix for ahci oops during boot. Also, a new
smallish platform ahci driver is added and sata_inic162x is marked
clearly as experimental (it whines during boot too) as data corruption
seems rather common on the device and it's unlikely to get any love in
the foreseeable future. If the whining doesn't draw any attention, I
think we'd probably be better of making the driver depend on BROKEN in
a couple releases"
This is v2 of this pull request with fixed dependencies for ahci_imx.
* 'for-3.11-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci_imx: depend on CONFIG_MFD_SYSCON
ahci_imx: add ahci sata support on imx platforms
ARM: imx6q: update the sata bits definitions of gpr13
ahci: fix Null pointer dereference in achi_host_active()
libata: make it clear that sata_inic162x is experimental
libata: replace strict_strtol() with kstrtol()
ata: Fix DVD not dectected at some platform with Wellsburg PCH
This patch fixes following error:
include/media/v4l2-ctrls.h:193:15: error: field ‘_lock’ has incomplete type
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_lock’:
include/media/v4l2-ctrls.h:570:2: error: implicit declaration of
function ‘mutex_lock’ [-Werror=implicit-function-declaration]
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_unlock’:
include/media/v4l2-ctrls.h:579:2: error: implicit declaration of
function ‘mutex_unlock’ [-Werror=implicit-function-declaration]
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
