[ Upstream commit 28e6b67f0b292f557468c139085303b15f1a678f ]
Since commit 55334a5db5cd ("net_sched: act: refuse to remove bound action
outside"), we end up with a wrong reference count for a tc action.
Test case 1:
FOO="1,6 0 0 4294967295,"
BAR="1,6 0 0 4294967294,"
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 \
action bpf bytecode "$FOO"
tc actions show action bpf
action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe
index 1 ref 1 bind 1
tc actions replace action bpf bytecode "$BAR" index 1
action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe
index 1 ref 2 bind 1
tc actions replace action bpf bytecode "$FOO" index 1
index 1 ref 3 bind 1
Test case 2:
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action ok
tc actions show action gact
action order 0: gact action pass
random type none pass val 0
tc actions add action drop index 1
RTNETLINK answers: File exists [...]
What happens is that in tcf_hash_check(), we check tcf_common for a given
index and increase tcfc_refcnt and conditionally tcfc_bindcnt when we've
found an existing action. Now there are the following cases:
1) We do a late binding of an action. In that case, we leave the
tcfc_refcnt/tcfc_bindcnt increased and are done with the ->init()
handler. This is correctly handeled.
2) We replace the given action, or we try to add one without replacing
and find out that the action at a specific index already exists
(thus, we go out with error in that case).
In case of 2), we have to undo the reference count increase from
tcf_hash_check() in the tcf_hash_check() function. Currently, we fail to
do so because of the 'tcfc_bindcnt > 0' check which bails out early with
an -EPERM error.
Now, while commit 55334a5db5cd prevents 'tc actions del action ...' on an
already classifier-bound action to drop the reference count (which could
then become negative, wrap around etc), this restriction only accounts for
invocations outside a specific action's ->init() handler.
One possible solution would be to add a flag thus we possibly trigger
the -EPERM ony in situations where it is indeed relevant.
After the patch, above test cases have correct reference count again.
Fixes: 55334a5db5cd ("net_sched: act: refuse to remove bound action outside")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit 03645a11a570d52e70631838cb786eb4253eb463 ]
ip6_datagram_connect() is doing a lot of socket changes without
socket being locked.
This looks wrong, at least for udp_lib_rehash() which could corrupt
lists because of concurrent udp_sk(sk)->udp_portaddr_hash accesses.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 841df7df196237ea63233f0f9eaa41db53afd70f upstream.
Commit 6f6a6fda2945 "jbd2: fix ocfs2 corrupt when updating journal
superblock fails" changed jbd2_cleanup_journal_tail() to return EIO
when the journal is aborted. That makes logic in
jbd2_log_do_checkpoint() bail out which is fine, except that
jbd2_journal_destroy() expects jbd2_log_do_checkpoint() to always make
a progress in cleaning the journal. Without it jbd2_journal_destroy()
just loops in an infinite loop.
Fix jbd2_journal_destroy() to cleanup journal checkpoint lists of
jbd2_log_do_checkpoint() fails with error.
Reported-by: Eryu Guan <guaneryu@gmail.com>
Tested-by: Eryu Guan <guaneryu@gmail.com>
Fixes: 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a
Signed-off-by: Jan Kara <jack@suse.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 11cec15bf3fb498206ef63b1fa26c27689e02d0e upstream.
The number of TLB lines was increased from 16 on Tegra30 to 32 on
Tegra114 and later. Parameterize the value so that the initial default
can be set accordingly.
On Tegra30, initializing the value to 32 would effectively disable the
TLB and hence cause massive latencies for memory accesses translated
through the SMMU. This is especially noticeable for isochronuous clients
such as display, whose FIFOs would continuously underrun.
Fixes: 891846516317 ("memory: Add NVIDIA Tegra memory controller support")
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit 0fdea1e8a2853f79d39b8555cc9de16a7e0ab26f upstream.
Commit 718ba5b87343, moved the responsibility for unlocking the socket to
xs_tcp_setup_socket, meaning that the socket will be unlocked before we
know that it has finished trying to connect. The following patch is based on
an initial patch by Russell King to ensure that we delay clearing the
XPRT_CONNECTING flag until we either know that we failed to initiate
a connection attempt, or the connection attempt itself failed.
Fixes: 718ba5b87343 ("SUNRPC: Add helpers to prevent socket create from racing")
Reported-by: Russell King <linux@arm.linux.org.uk>
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
Tested-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 051ac3848a94f21cfdec899cc9c65ce7f9f116fa upstream.
`perf stat -e sunrpc:svc_xprt_do_enqueue true` results in
Warning: unknown op '->'
Warning: [sunrpc:svc_xprt_do_enqueue] unknown op '->'
Similar warning for svc_handle_xprt as well.
Actually TP_printk() should never dereference an address saved in the ring
buffer that points somewhere in the kernel. There's no guarantee that that
object still exists (with the exception of static strings).
Therefore change all the arguments for TP_printk(), so that it references
values existing in the ring buffer only.
While doing that, also fix another possible bug when argument xprt could be
NULL and TP_fast_assign() tries to access it's elements.
Signed-off-by: Pratyush Anand <panand@redhat.com>
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Fixes: 83a712e0afef "sunrpc: add some tracepoints around ..."
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 2f064f3485cd29633ad1b3cfb00cc519509a3d72 upstream.
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
commit 5d0ddfebb93069061880fc57ee4ba7246bd1e1ee upstream.
Nick Meier reported a regression with HyperV that "
After rebooting the VM, the following messages are logged in syslog
when trying to load the tulip driver:
tulip: Linux Tulip drivers version 1.1.15 (Feb 27, 2007)
tulip: 0000:00:0a.0: PCI INT A: failed to register GSI
tulip: Cannot enable tulip board #0, aborting
tulip: probe of 0000:00:0a.0 failed with error -16
Errors occur in 3.19.0 kernel
Works in 3.17 kernel.
According to the ACPI dump file posted by Nick at
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1440072
The ACPI MADT table includes an interrupt source overridden entry for
ACPI SCI:
[236h 0566 1] Subtable Type : 02 <Interrupt Source Override>
[237h 0567 1] Length : 0A
[238h 0568 1] Bus : 00
[239h 0569 1] Source : 09
[23Ah 0570 4] Interrupt : 00000009
[23Eh 0574 2] Flags (decoded below) : 000D
Polarity : 1
Trigger Mode : 3
And in DSDT table, we have _PRT method to define PCI interrupts, which
eventually goes to:
Name (PRSA, ResourceTemplate ()
IRQ (Level, ActiveLow, Shared, )
{3,4,5,7,9,10,11,12,14,15}
Name (PRSB, ResourceTemplate ()
Name (PRSC, ResourceTemplate ()
Name (PRSD, ResourceTemplate ()
According to the MADT and DSDT tables, IRQ 9 may be used for:
1) ACPI SCI in level, high mode
2) PCI legacy IRQ in level, low mode
So there's a conflict in polarity setting for IRQ 9.
Prior to commit cd68f6bd53cf ("x86, irq, acpi: Get rid of special
handling of GSI for ACPI SCI"), ACPI SCI is handled specially and
there's no check for conflicts between ACPI SCI and PCI legagy IRQ.
And it seems that the HyperV hypervisor doesn't make use of the
polarity configuration in IOAPIC entry, so it just works.
Commit cd68f6bd53cf gets rid of the specially handling of ACPI SCI,
and then the pin attribute checking code discloses the conflicts
between ACPI SCI and PCI legacy IRQ on HyperV virtual machine,
and rejects the request to assign IRQ9 to PCI devices.
So penalize legacy IRQ used by ACPI SCI and mark it unusable if ACPI
SCI attributes conflict with PCI IRQ attributes.
Please refer to following links for more information:
https://bugzilla.kernel.org/show_bug.cgi?id=101301
Fixes: cd68f6bd53cf ("x86, irq, acpi: Get rid of special handling of GSI for ACPI SCI")
Reported-and-tested-by: Nick Meier <nmeier@microsoft.com>
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
commit 932c435caba8a2ce473a91753bad0173269ef334 upstream.
Add a dev_flags bit, PCI_DEV_FLAGS_VPD_REF_F0, to access VPD through
function 0 to provide VPD access on other functions. This is for hardware
devices that provide copies of the same VPD capability registers in
multiple functions. Because the kernel expects that each function has its
own registers, both the locking and the state tracking are affected by VPD
accesses to different functions.
On such devices for example, if a VPD write is performed on function 0,
*any* later attempt to read VPD from any other function of that device will
hang. This has to do with how the kernel tracks the expected value of the
F bit per function.
Concurrent accesses to different functions of the same device can not only
hang but also corrupt both read and write VPD data.
When hangs occur, typically the error message:
vpd r/w failed. This is likely a firmware bug on this device.
will be seen.
Never set this bit on function 0 or there will be an infinite recursion.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
commit c689a923c867eac40ed3826c1d9328edea8b6bc7 upstream.
Add inverse unit conversion macro to convert from standard IIO units to
units that might be used by some devices.
Those are useful in combination with scale factors that are specified as
IIO_VAL_FRACTIONAL. Typically the denominator for those specifications will
contain the maximum raw value the sensor will generate and the numerator
the value it maps to in a specific unit. Sometimes datasheets specify those
in different units than the standard IIO units (e.g. degree/s instead of
rad/s) and so we need to do a unit conversion.
From a mathematical point of view it does not make a difference whether we
apply the unit conversion to the numerator or the inverse unit conversion
to the denominator since (x / y) / z = x / (y * z). But as the denominator
is typically a larger value and we are rounding both the numerator and
denominator to integer values using the later method gives us a better
precision (E.g. the relative error is smaller if we round 8000.3 to 8000
rather than rounding 8.3 to 8).
This is where in inverse unit conversion macros will be used.
Marked for stable as used by some upcoming fixes.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit b7560de198222994374c1340a389f12d5efb244a upstream.
This helper is required for irq chips which do not implement a
irq_set_type callback and need to call down the irq domain hierarchy
for the actual trigger type change.
This helper is required to fix further wreckage caused by the
conversion of TI OMAP to hierarchical irq domains and therefor tagged
for stable.
[ tglx: Massaged changelog ]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: <linux@arm.linux.org.uk>
Cc: <nsekhar@ti.com>
Cc: <jason@lakedaemon.net>
Cc: <balbi@ti.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: <tony@atomide.com>
Cc: <marc.zyngier@arm.com>
Cc: stable@vger.kernel.org # 4.1
Link: http://lkml.kernel.org/r/1439554830-19502-3-git-send-email-grygorii.strashko@ti.com
commit 74a80d67b8316eb3fbeb73dafc060a5a0a708587 upstream.
This reverts commit 42b966fbf35da9c87f08d98f9b8978edf9e717cf.
As implemented, ACS-4 sense reporting for ATA devices bypasses error
diagnosis and handling in libata degrading EH behavior significantly.
Revert the related changes for now.
Cc: Hannes Reinecke <hare@suse.de>
commit 84ded2f8e7dda336fc2fb3570726ceb3b3b3590f upstream.
This reverts commit fe7173c206de63fc28475ee6ae42ff95c05692de.
ATA_ID_COMMAND_SET_3/4 constants are not reverted as they're used by
later changes.
commit fe16d4f202c59a560533a223bc6375739ee30944 upstream.
This reverts commit a1524f226a02aa6edebd90ae0752e97cfd78b159.
commit e037239e5e7b61007763984aa35a8329596d8c88 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5f867db63473f32cce1b868e281ebd42a41f8fad upstream.
Commit 66507c7bc8895f0da6b ("mtd: nand: Add support to use nand_base
poi databuf as bounce buffer") added a flag NAND_USE_BOUNCE_BUFFER
using the same bit value as the existing NAND_BUSWIDTH_AUTO.
Cc: Kamal Dasu <kdasu.kdev@gmail.com>
Fixes: 66507c7bc8895f0da6b ("mtd: nand: Add support to use nand_base
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit c9ddbac9c89110f77cb0fa07e634aaf1194899aa upstream.
09a2c73ddfc7 ("PCI: Remove unused PCI_MSIX_FLAGS_BIRMASK definition")
removed PCI_MSIX_FLAGS_BIRMASK from an exported header because it was
unused in the kernel. But that breaks user programs that were using it
(QEMU in particular).
Restore the PCI_MSIX_FLAGS_BIRMASK definition.
[bhelgaas: changelog]
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit e54198657b65625085834847ab6271087323ffea upstream.
This patch fixes a regression introduced with the following commit
in v4.0-rc1 code, where a iscsit_start_kthreads() failure triggers
a NULL pointer dereference OOPs:
commit 88dcd2dab5c23b1c9cfc396246d8f476c872f0ca
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Thu Feb 26 22:19:15 2015 -0800
iscsi-target: Convert iscsi_thread_set usage to kthread.h
To address this bug, move iscsit_start_kthreads() immediately
preceeding the transmit of last login response, before signaling
a successful transition into full-feature-phase within existing
iscsi_target_do_tx_login_io() logic.
This ensures that no target-side resource allocation failures can
occur after the final login response has been successfully sent.
Also, it adds a iscsi_conn->rx_login_comp to allow the RX thread
to sleep to prevent other socket related failures until the final
iscsi_post_login_handler() call is able to complete.
Cc: Sagi Grimberg <sagig@mellanox.com>
commit 4c62360d7562a20c996836d163259c87d9378120 upstream.
The memory error record structure includes as its first field a
bitmask of which subsequent fields are valid. The allows new fields
to be added to the structure while keeping compatibility with older
software that parses these records. This mechanism was used between
versions 2.2 and 2.3 to add four new fields, growing the size of the
structure from 73 bytes to 80. But Linux just added all the new
fields so this test:
if (gdata->error_data_length >= sizeof(*mem_err))
cper_print_mem(newpfx, mem_err);
else
goto err_section_too_small;
now make Linux complain about old format records being too short.
Add a definition for the old format of the structure and use that
for the minimum size check. Pass the actual size to cper_print_mem()
so it can sanity check the validation_bits field to ensure that if
a BIOS using the old format sets bits as if it were new, we won't
access fields beyond the end of the structure.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit e3eea1404f5ff7a2ceb7b5e7ba412a6fd94f2935 upstream.
Commit 4104d326b670 ("ftrace: Remove global function list and call function
directly") simplified the ftrace code by removing the global_ops list with a
new design. But this cleanup also broke the filtering of PIDs that are added
to the set_ftrace_pid file.
Add back the proper hooks to have pid filtering working once again.
Reported-by: Matt Fleming <matt@console-pimps.org>
Reported-by: Richard Weinberger <richard.weinberger@gmail.com>
Tested-by: Matt Fleming <matt@console-pimps.org>
commit d3b58c47d330de8c29898fe9746f7530408f8a59 upstream.
Commit 514ac99c64b "can: fix multiple delivery of a single CAN frame for
overlapping CAN filters" requires the skb->tstamp to be set to check for
identical CAN skbs.
Without timestamping to be required by user space applications this timestamp
was not generated which lead to commit 36c01245eb8 "can: fix loss of CAN frames
in raw_rcv" - which forces the timestamp to be set in all CAN related skbuffs
by introducing several __net_timestamp() calls.
This forces e.g. out of tree drivers which are not using alloc_can{,fd}_skb()
to add __net_timestamp() after skbuff creation to prevent the frame loss fixed
in mainline Linux.
This patch removes the timestamp dependency and uses an atomic counter to
create an unique identifier together with the skbuff pointer.
Btw: the new skbcnt element introduced in struct can_skb_priv has to be
initialized with zero in out-of-tree drivers which are not using
alloc_can{,fd}_skb() too.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 764ad8ba8cd4c6f836fca9378f8c5121aece0842 upstream.
The current buffer is much too small if you have a relatively long
hostname. Bring it up to the size of the one that SETCLIENTID has.
Reported-by: Michael Skralivetsky <michael.skralivetsky@primarydata.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
commit 496e7ce2a46562938edcb74f65b26068ee8895f6 upstream.
If GPIOLIB=n:
drivers/leds/leds-gpio.c: In function ‘gpio_leds_create’:
drivers/leds/leds-gpio.c:187: error: implicit declaration of function ‘devm_get_gpiod_from_child’
drivers/leds/leds-gpio.c:187: warning: assignment makes pointer from integer without a cast
Add dummies for fwnode_get_named_gpiod() and devm_get_gpiod_from_child()
for the !GPIOLIB case to fix this.
Fixes: 40b7318319281b1b ("gpio: Support for unified device properties interface")
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
commit c8fff7bc5bba6bd59cad40441c189c4efe7190f6 upstream.
Node 0 might be offline as well as any other numa node,
in this case kernel cannot handle memory allocation and crashes.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 0c3f061c195c ("of: implement of_node_to_nid as a weak function")
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit b86a50c3b5414eafdbee7f34af4a201a4a7817c2 upstream.
Cleanup commit 73679e508201 ("compiler-intel.h: Remove duplicate
definition") removed the double definition of __memory_barrier()
intrinsics.
However, in doing so, it also removed the preceding #undef barrier by
accident, meaning, the actual barrier() macro from compiler-gcc.h with
inline asm is still in place as __GNUC__ is provided.
Subsequently, barrier() can never be defined as __memory_barrier() from
compiler.h since it already has a definition in place and if we trust
the comment in compiler-intel.h, ecc doesn't support gcc specific asm
statements.
I don't have an ecc at hand (unsure if that's still used in the field?)
and only found this by accident during code review, a revert of that
cleanup would be simplest option.
Fixes: 73679e508201 ("compiler-intel.h: Remove duplicate definition")
Reviewed-by: Pranith Kumar <bobby.prani@gmail.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: mancha security <mancha1@zoho.com>
commit 0ea61381788a37d864f9841b0fe97d40f7058f3b upstream.
ACPICA commit 4da56eeae0749dfe8491285c1e1fad48f6efafd8
The following commit temporarily disables correct 64-bit FADT addresses
favor during the period the root cause of the bug is not fixed:
Commit: 85dbd5801f62b66e2aa7826aaefcaebead44c8a6
ACPICA: Tables: Restore old behavor to favor 32-bit FADT addresses.
With enough protections, this patch re-enables 64-bit FADT addresses by
default. If regressions are reported against such change, this patch should
be bisected and reverted.
Note that 64-bit FACS favor and 64-bit firmware waking vector favor are
excluded by this commit in order not to break OSPMs. Lv Zheng.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=74021
Link: https://github.com/acpica/acpica/commit/4da56eea
Reported-and-tested-by: Oswald Buddenhagen <ossi@kde.org>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
commit c04be18448355441a0c424362df65b6422e27bda upstream.
ACPICA commit 90f5332a15e9d9ba83831ca700b2b9f708274658
This patch adds a new FACS initialization flag for acpi_tb_initialize().
acpi_enable_subsystem() might be invoked several times in OS bootup process,
and we don't want FACS initialization to be invoked twice. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/90f5332a
commit c04e1fb4396d27f18296db0f914760fa7fe8223a upstream.
ACPICA commit f7b86f35416e3d1f71c3d816ff5075ddd33ed486
The following commit is reported to have broken s2ram on some platforms:
Commit: 0249ed2444d65d65fc3f3f64f398f1ad0b7e54cd
ACPICA: Add option to favor 32-bit FADT addresses.
The platform reports 2 FACS tables (which is not allowed by ACPI
specification) and the new 32-bit address favor rule forces OSPMs to use
the FACS table reported via FADT's X_FIRMWARE_CTRL field.
The root cause of the reported bug might be one of the followings:
1. BIOS may favor the 64-bit firmware waking vector address when the
version of the FACS is greater than 0 and Linux currently only supports
resuming from the real mode, so the 64-bit firmware waking vector has
never been set and might be invalid to BIOS while the commit enables
higher version FACS.
2. BIOS may favor the FACS reported via the "FIRMWARE_CTRL" field in the
FADT while the commit doesn't set the firmware waking vector address of
the FACS reported by "FIRMWARE_CTRL", it only sets the firware waking
vector address of the FACS reported by "X_FIRMWARE_CTRL".
This patch excludes the cases that can trigger the bugs caused by the root
cause 2.
There is no handshaking mechanism can be used by OSPM to tell BIOS which
FACS is currently used. Thus the FACS reported by "FIRMWARE_CTRL" may still
be used by BIOS and the 0 value of the 32-bit firmware waking vector might
trigger such failure.
This patch tries to favor 32bit FACS address in another way where both the
FACS reported by "FIRMWARE_CTRL" and the FACS reported by "X_FIRMWARE_CTRL"
are loaded so that further commit can set firmware waking vector in the
both tables to ensure we can exclude the cases that trigger the bugs caused
by the root cause 2. The exclusion is split into 2 commits as this commit
is also useful for dumping more ACPI tables, it won't get reverted when
such exclusion is no longer necessary. Lv Zheng.
Link: https://github.com/acpica/acpica/commit/f7b86f35
commit 0294112ee3135fbd15eaa70015af8283642dd970 upstream.
This effectively reverts the following three commits:
7bc10388ccdd ACPI / resources: free memory on error in add_region_before()
0f1b414d1907 ACPI / PNP: Avoid conflicting resource reservations
b9a5e5e18fbf ACPI / init: Fix the ordering of acpi_reserve_resources()
(commit b9a5e5e18fbf introduced regressions some of which, but not
all, were addressed by commit 0f1b414d1907 and commit 7bc10388ccdd
was a fixup on top of the latter) and causes ACPI fixed hardware
resources to be reserved at the fs_initcall_sync stage of system
initialization.
The story is as follows. First, a boot regression was reported due
to an apparent resource reservation ordering change after a commit
that shouldn't lead to such changes. Investigation led to the
conclusion that the problem happened because acpi_reserve_resources()
was executed at the device_initcall() stage of system initialization
which wasn't strictly ordered with respect to driver initialization
(and with respect to the initialization of the pcieport driver in
particular), so a random change causing the device initcalls to be
run in a different order might break things.
The response to that was to attempt to run acpi_reserve_resources()
as soon as we knew that ACPI would be in use (commit b9a5e5e18fbf).
However, that turned out to be too early, because it caused resource
reservations made by the PNP system driver to fail on at least one
system and that failure was addressed by commit 0f1b414d1907.
That fix still turned out to be insufficient, though, because
calling acpi_reserve_resources() before the fs_initcall stage of
system initialization caused a boot regression to happen on the
eCAFE EC-800-H20G/S netbook. That meant that we only could call
acpi_reserve_resources() at the fs_initcall initialization stage
or later, but then we might just as well call it after the PNP
initalization in which case commit 0f1b414d1907 wouldn't be
necessary any more.
For this reason, the changes made by commit 0f1b414d1907 are reverted
(along with a memory leak fixup on top of that commit), the changes
made by commit b9a5e5e18fbf that went too far are reverted too and
acpi_reserve_resources() is changed into fs_initcall_sync, which
will cause it to be executed after the PNP subsystem initialization
(which is an fs_initcall) and before device initcalls (including
the pcieport driver initialization) which should avoid the initial
issue.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=100581
Link: http://marc.info/?t=143092384600002&r=1&w=2
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99831
Link: http://marc.info/?t=143389402600001&r=1&w=2
Fixes: b9a5e5e18fbf "ACPI / init: Fix the ordering of acpi_reserve_resources()"
Reported-by: Roland Dreier <roland@purestorage.com>
commit 648a9bc5308d952f2c80772301b339f73026f013 upstream.
Since the hardware sometimes mysteriously totally flummoxes the 64bit
read of a 64bit register when read using a single instruction, split the
read into two instructions. Since the read here is of automatically
incrementing timestamp counters, we also have to be very careful in
order to make sure that it does not increment between the two
instructions.
However, since userspace tried to workaround this issue and so enshrined
this ABI for a broken hardware read and in the process neglected that
the read only fails in some environments, we have to introduce a new
uABI flag for userspace to request the 2x32 bit accurate read of the
timestamp.
v2: Fix alignment check and include details of the workaround for
userspace.
Reported-by: Karol Herbst <freedesktop@karolherbst.de>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=91317
Testcase: igt/gem_reg_read
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Michał Winiarski <michal.winiarski@intel.com>
Tested-by: Michał Winiarski <michal.winiarski@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 60f207a5b6d8f23c2e8388b415e8d5c7311cc79d upstream.
for_each_*_in_state validate array index after
access to array elements, thus perform out of bounds read.
Fix this by validating index in the first place and read
array element iff validation was successful.
Fixes: df63b9994eaf ("drm/atomic: Add for_each_{connector,crtc,plane}_in_state helper macros")
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
commit 6b8eeca65b18ae77e175cc2b6571731f0ee413bf upstream.
I've only seen this once, and I failed to capture the
lockdep backtrace, but I did some investigations.
If we are calling into the MST layer from EDID probing,
we have the mode_config mutex held, if during that EDID
probing, the MST hub goes away, then we can get a deadlock
where the connector destruction function in the driver
tries to retake the mode config mutex.
This offloads connector destruction to a workqueue,
and avoid the subsequenct lock ordering issue.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
limit
commit af34d637637eabaf49406eb35c948cd51ba262a6 upstream.
Since no longer limiting max_sectors to BLK_DEF_MAX_SECTORS (commit 34b48db66e08),
data corruption may occur on ST380013AS drive configured on 82801JI (ICH10 Family)
SATA controller. This patch will allow the driver to limit max_sectors as before
# cat /sys/block/sdb/queue/max_sectors_kb
512
I was able to double the max_sectors_kb value up to 16384 on linux-4.2.0-rc2
before seeing corruption, but seems safer to use previous limit. Without this
patch max_sectors_kb will be 32767.
tj: Minor comment update.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: David Milburn <dmilburn@redhat.com>
Fixes: 34b48db66e08 ("block: remove artifical max_hw_sectors cap")
commit 71d126fd28de2d4d9b7b2088dbccd7ca62fad6e0 upstream.
Some devices lose data on TRIM whether queued or not. This patch adds
a horkage to disable TRIM.
tj: Collapsed unnecessary if() nesting.
Signed-off-by: Arne Fitzenreiter <arne_f@ipfire.org>
commit 5d3abf8ff67f49271a42c0f7fa4f20f9e046bf0e upstream.
Some devices advertise support for the READ/WRITE LOG DMA EXT commands
but fail when we try to issue them. This can lead to queued TRIM being
unintentionally disabled since the relevant feature flag is located in a
general purpose log page.
Fall back to unqueued READ LOG EXT if the DMA variant fails while
reading a log page.
Reviewed-by: Hannes Reinecke <hare@suse.de>
commit 6f6a6fda294506dfe0e3e0a253bb2d2923f28f0a upstream.
If updating journal superblock fails after journal data has been
flushed, the error is omitted and this will mislead the caller as a
normal case. In ocfs2, the checkpoint will be treated successfully
and the other node can get the lock to update. Since the sb_start is
still pointing to the old log block, it will rewrite the journal data
during journal recovery by the other node. Thus the new updates will
be overwritten and ocfs2 corrupts. So in above case we have to return
the error, and ocfs2_commit_cache will take care of the error and
prevent the other node to do update first. And only after recovering
journal it can do the new updates.
The issue discussion mail can be found at:
https://oss.oracle.com/pipermail/ocfs2-devel/2015-June/010856.html
http://comments.gmane.org/gmane.comp.file-systems.ext4/48841
[ Fixed bug in patch which allowed a non-negative error return from
jbd2_cleanup_journal_tail() to leak out of jbd2_fjournal_flush(); this
was causing xfstests ext4/306 to fail. -- Ted ]
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Tested-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
commit bd7ade3cd9b0850264306f5c2b79024a417b6396 upstream.
sb_getblk() is used during ext4 (and possibly other FSes) writeback
paths. Sometimes such path require allocating memory and guaranteeing
that such allocation won't block. Currently, however, there is no way
to provide user flags for sb_getblk which could lead to deadlocks.
This patch implements a sb_getblk_gfp with the only difference it can
accept user-provided GFP flags.
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
commit 1e25aa9641e8f3fa39cd5e46b4afcafd7f12a44b upstream.
By default all the sensors are runtime suspended state (lowest power
state). During Linux suspend process, all the run time suspended
devices are resumed and then suspended. This caused all sensors to
power up and introduced delay in suspend time, when we introduced
runtime PM for HID sensors. The opposite process happens during resume
process.
To fix this, we do powerup process of the sensors only when the request
is issued from user (raw or tiggerred). In this way when runtime,
resume calls for powerup it will simply return as this will not match
user requested state.
Note this is a regression fix as the increase in suspend / resume
times can be substantial (report of 8 seconds on Len's laptop!)
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Tested-by: Len Brown <len.brown@intel.com>
commit 3a9ad0b4fdcd57f775d3615004c8c64c021a9e7d upstream.
David Ahern reported that d63e2e1f3df9 ("sparc/PCI: Clip bridge windows
to fit in upstream windows") fails to boot on sparc/T5-8:
pci 0000:06:00.0: reg 0x184: can't handle BAR above 4GB (bus address 0x110204000)
The problem is that sparc64 assumed that dma_addr_t only needed to hold DMA
addresses, i.e., bus addresses returned via the DMA API (dma_map_single(),
etc.), while the PCI core assumed dma_addr_t could hold *any* bus address,
including raw BAR values. On sparc64, all DMA addresses fit in 32 bits, so
dma_addr_t is a 32-bit type. However, BAR values can be 64 bits wide, so
they don't fit in a dma_addr_t. d63e2e1f3df9 added new checking that
tripped over this mismatch.
Add pci_bus_addr_t, which is wide enough to hold any PCI bus address,
including both raw BAR values and DMA addresses. This will be 64 bits
on 64-bit platforms and on platforms with a 64-bit dma_addr_t. Then
dma_addr_t only needs to be wide enough to hold addresses from the DMA API.
[bhelgaas: changelog, bugzilla, Kconfig to ensure pci_bus_addr_t is at
least as wide as dma_addr_t, documentation]
Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows")
Fixes: 23b13bc76f35 ("PCI: Fail safely if we can't handle BARs larger than 4GB")
Link: http://lkml.kernel.org/r/CAE9FiQU1gJY1LYrxs+ma5LCTEEe4xmtjRG0aXJ9K_Tsu+m9Wuw@mail.gmail.com
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96231
Reported-by: David Ahern <david.ahern@oracle.com>
Tested-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
commit 0824965140fff1bf640a987dc790d1594a8e0699 upstream.
Refine the mechanism introduced by commit f244d8b623da ("ACPIPHP / radeon /
nouveau: Fix VGA switcheroo problem related to hotplug") to propagate the
ignore_hotplug setting of the device to its parent bridge in case hotplug
notifications related to the graphics adapter switching are given for the
bridge rather than for the device itself (they need to be ignored in both
cases).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=61891
Link: https://bugs.freedesktop.org/show_bug.cgi?id=88927
Fixes: b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device")
Reported-and-tested-by: tiagdtd-lava <tiagdtd-lava@yahoo.de>
commit 8a8c35fadfaf55629a37ef1a8ead1b8fb32581d2 upstream.
Beginning at commit d52d3997f843 ("ipv6: Create percpu rt6_info"), the
following INFO splat is logged:
[ INFO: suspicious RCU usage. ]
4.1.0-rc7-next-20150612 #1 Not tainted
kernel/sched/core.c:7318 Illegal context switch in RCU-bh read-side critical section!
rcu_scheduler_active = 1, debug_locks = 0
3 locks held by systemd/1:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff815f0c8f>] rtnetlink_rcv+0x1f/0x40
#1: (rcu_read_lock_bh){......}, at: [<ffffffff816a34e2>] ipv6_add_addr+0x62/0x540
#2: (addrconf_hash_lock){+...+.}, at: [<ffffffff816a3604>] ipv6_add_addr+0x184/0x540
stack backtrace:
CPU: 0 PID: 1 Comm: systemd Not tainted 4.1.0-rc7-next-20150612 #1
Hardware name: TOSHIBA TECRA A50-A/TECRA A50-A, BIOS Version 4.20 04/17/2014
Call Trace:
dump_stack+0x4c/0x6e
lockdep_rcu_suspicious+0xe7/0x120
___might_sleep+0x1d5/0x1f0
__might_sleep+0x4d/0x90
kmem_cache_alloc+0x47/0x250
create_object+0x39/0x2e0
kmemleak_alloc_percpu+0x61/0xe0
pcpu_alloc+0x370/0x630
Additional backtrace lines are truncated. In addition, the above splat
is followed by several "BUG: sleeping function called from invalid
context at mm/slub.c:1268" outputs. As suggested by Martin KaFai Lau,
these are the clue to the fix. Routine kmemleak_alloc_percpu() always
uses GFP_KERNEL for its allocations, whereas it should follow the gfp
from its callers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tejun Heo <tj@kernel.org>
commit 7f1a57fdd6cb6e7be2ed31878a34655df38e1861 upstream.
Don't call the power_supply_changed() from power_supply_register() when
parent is still probing because it may lead to accessing parent too
early.
In bq27x00_battery this caused NULL pointer exception because uevent of
power_supply_changed called back the the get_property() method provided
by the driver. The get_property() method accessed pointer which should
be returned by power_supply_register().
Starting from bq27x00_battery_probe():
di->bat = power_supply_register()
kobject_uevent()
power_supply_uevent()
power_supply_show_property()
power_supply_get_property()
bq27x00_battery_get_property()
dereference of di->bat which is NULL here
The dereference of di->bat (value returned by power_supply_register())
is the currently visible problem. However calling back the methods
provided by driver before ending the probe may lead to accessing other
driver-related data which is not yet initialized.
The call to power_supply_changed() is postponed till probing ends -
mutex of parent device is released.
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 297d716f6260 ("power_supply: Change ownership from driver to core")
Tested-By: Dr. H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
commit 0f1b414d190724617eb1cdd615592fa8cd9d0b50 upstream.
Commit b9a5e5e18fbf "ACPI / init: Fix the ordering of
acpi_reserve_resources()" overlooked the fact that the memory
and/or I/O regions reserved by acpi_reserve_resources() may
conflict with those reserved by the PNP "system" driver.
If that conflict actually takes place, it causes the reservations
made by the "system" driver to fail while before commit b9a5e5e18fbf
all reservations made by it and by acpi_reserve_resources() would be
successful. In turn, that allows the resources that haven't been
reserved by the "system" driver to be used by others (e.g. PCI) which
sometimes leads to functional problems (up to and including boot
failures).
To fix that issue, introduce a common resource reservation routine,
acpi_reserve_region(), to be used by both acpi_reserve_resources()
and the "system" driver, that will track all resources reserved by
it and avoid making conflicting requests.
commit b064a8fa77dfead647564c46ac8fc5b13bd1ab73 upstream.
Commit 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before
timekeeping_init()" moved the ACPI subsystem initialization,
including the ACPI mode enabling, to an earlier point in the
initialization sequence, to allow the timekeeping subsystem
use ACPI early. Unfortunately, that resulted in boot regressions
on some systems and the early ACPI initialization was moved toward
its original position in the kernel initialization code by commit
c4e1acbb35e4 "ACPI / init: Invoke early ACPI initialization later".
However, that turns out to be insufficient, as boot is still broken
on the Tyan S8812 mainboard.
To fix that issue, split the ACPI early initialization code into
two pieces so the majority of it still located in acpi_early_init()
and the part switching over the platform into the ACPI mode goes into
a new function, acpi_subsystem_init(), executed at the original early
ACPI initialization spot.
That fixes the Tyan S8812 boot problem, but still allows ACPI
tables to be loaded earlier which is useful to the EFI code in
efi_enter_virtual_mode().
Link: https://bugzilla.kernel.org/show_bug.cgi?id=97141
Fixes: 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before timekeeping_init()"
Reported-and-tested-by: Marius Tolzmann <tolzmann@molgen.mpg.de>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Lee, Chun-Yi <jlee@suse.com>
commit 1b852bceb0d111e510d1a15826ecc4a19358d512 upstream.
Fresh mounts of proc and sysfs are a very special case that works very
much like a bind mount. Unfortunately the current structure can not
preserve the MNT_LOCK... mount flags. Therefore refactor the logic
into a form that can be modified to preserve those lock bits.
Add a new filesystem flag FS_USERNS_VISIBLE that requires some mount
of the filesystem be fully visible in the current mount namespace,
before the filesystem may be mounted.
Move the logic for calling fs_fully_visible from proc and sysfs into
fs/namespace.c where it has greater access to mount namespace state.
commit 87d2846fcf88113fae2341da1ca9a71f0d916f2c upstream.
Add two functions sysfs_create_mount_point and
sysfs_remove_mount_point that hang a permanently empty directory off
of a kobject or remove a permanently emptpy directory hanging from a
kobject. Export these new functions so modular filesystems can use
them.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit ea015218f2f7ace2dad9cedd21ed95bdba2886d7 upstream.
Add a new function kernfs_create_empty_dir that can be used to create
directory that can not be modified.
Update the code to use make_empty_dir_inode when reporting a
permanently empty directory to the vfs.
Update the code to not allow adding to permanently empty directories.
commit f9bd6733d3f11e24f3949becf277507d422ee1eb upstream.
Add a magic sysctl table sysctl_mount_point that when used to
create a directory forces that directory to be permanently empty.
Update the code to use make_empty_dir_inode when accessing permanently
empty directories.
Update /proc/sys/fs/binfmt_misc to be a permanently empty directory.
commit fbabfd0f4ee2e8847bf56edf481249ad1bb8c44d upstream.
To ensure it is safe to mount proc and sysfs I need to check if
filesystems that are mounted on top of them are mounted on truly empty
directories. Given that some directories can gain entries over time,
knowing that a directory is empty right now is insufficient.
Therefore add supporting infrastructure for permantently empty
directories that proc and sysfs can use when they create mount points
for filesystems and fs_fully_visible can use to test for permanently
empty directories to ensure that nothing will be gained by mounting a
fresh copy of proc or sysfs.
