Merge second patch-bomb from Andrew Morton:
- misc fixes
- audit stuff
- fanotify/inotify/dnotify things
- most of the rest of MM. The new cache shrinker code from Glauber and
Dave Chinner probably isn't quite stabilized yet.
- ptrace
- ipc
- partitions
- reboot cleanups
- add LZ4 decompressor, use it for kernel compression
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits)
lib/scatterlist: error handling in __sg_alloc_table()
scsi_debug: fix do_device_access() with wrap around range
crypto: talitos: use sg_pcopy_to_buffer()
lib/scatterlist: introduce sg_pcopy_from_buffer() and sg_pcopy_to_buffer()
lib/scatterlist: factor out sg_miter_get_next_page() from sg_miter_next()
crypto: add lz4 Cryptographic API
lib: add lz4 compressor module
arm: add support for LZ4-compressed kernel
lib: add support for LZ4-compressed kernel
decompressor: add LZ4 decompressor module
lib: add weak clz/ctz functions
reboot: move arch/x86 reboot= handling to generic kernel
reboot: arm: change reboot_mode to use enum reboot_mode
reboot: arm: prepare reboot_mode for moving to generic kernel code
reboot: arm: remove unused restart_mode fields from some arm subarchs
reboot: unicore32: prepare reboot_mode for moving to generic kernel code
reboot: x86: prepare reboot_mode for moving to generic kernel code
reboot: checkpatch.pl the new kernel/reboot.c file
reboot: move shutdown/reboot related functions to kernel/reboot.c
reboot: remove -stable friendly PF_THREAD_BOUND define
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
Pull 9p update from Eric Van Hensbergen:
"Grab bag of little fixes and enhancements:
- optional security enhancements
- fix path coverage in MAINTAINERS
- switch to using most used protocol and transport as default
- clean up buffer dumps in trace code
Held off on RDMA patches as they need to be cleaned up a bit, but will
try to get the cleaned, checked, and pushed by mid-week"
* tag 'for-linus-3.11-merge-window-part-1' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: Add rest of 9p files to MAINTAINERS entry
9p: trace: use %*ph to dump buffer
net/9p: Handle error in zero copy request correctly for 9p2000.u
net/9p: Use virtio transpart as the default transport
net/9p: Make 9P2000.L the default protocol for 9p file system
This adds a way to check ring empty state after enable_cb outside any
locks. Will be used by virtio_net.
Note: there's room for more optimization: caller is likely to have a
memory barrier already, which means we might be able to get rid of a
barrier here. Deferring this optimization until we do some
benchmarking.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph updates from Sage Weil:
"There is some follow-on RBD cleanup after the last window's code drop,
a series from Yan fixing multi-mds behavior in cephfs, and then a
sprinkling of bug fixes all around. Some warnings, sleeping while
atomic, a null dereference, and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (36 commits)
libceph: fix invalid unsigned->signed conversion for timespec encoding
libceph: call r_unsafe_callback when unsafe reply is received
ceph: fix race between cap issue and revoke
ceph: fix cap revoke race
ceph: fix pending vmtruncate race
ceph: avoid accessing invalid memory
libceph: Fix NULL pointer dereference in auth client code
ceph: Reconstruct the func ceph_reserve_caps.
ceph: Free mdsc if alloc mdsc->mdsmap failed.
ceph: remove sb_start/end_write in ceph_aio_write.
ceph: avoid meaningless calling ceph_caps_revoking if sync_mode == WB_SYNC_ALL.
ceph: fix sleeping function called from invalid context.
ceph: move inode to proper flushing list when auth MDS changes
rbd: fix a couple warnings
ceph: clear migrate seq when MDS restarts
ceph: check migrate seq before changing auth cap
ceph: fix race between page writeback and truncate
ceph: reset iov_len when discarding cap release messages
ceph: fix cap release race
libceph: fix truncate size calculation
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs update from Chris Mason:
"These are the usual mixture of bugs, cleanups and performance fixes.
Miao has some really nice tuning of our crc code as well as our
transaction commits.
Josef is peeling off more and more problems related to early enospc,
and has a number of important bug fixes in here too"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (81 commits)
Btrfs: wait ordered range before doing direct io
Btrfs: only do the tree_mod_log_free_eb if this is our last ref
Btrfs: hold the tree mod lock in __tree_mod_log_rewind
Btrfs: make backref walking code handle skinny metadata
Btrfs: fix crash regarding to ulist_add_merge
Btrfs: fix several potential problems in copy_nocow_pages_for_inode
Btrfs: cleanup the code of copy_nocow_pages_for_inode()
Btrfs: fix oops when recovering the file data by scrub function
Btrfs: make the chunk allocator completely tree lockless
Btrfs: cleanup orphaned root orphan item
Btrfs: fix wrong mirror number tuning
Btrfs: cleanup redundant code in btrfs_submit_direct()
Btrfs: remove btrfs_sector_sum structure
Btrfs: check if we can nocow if we don't have data space
Btrfs: stop using try_to_writeback_inodes_sb_nr to flush delalloc
Btrfs: use a percpu to keep track of possibly pinned bytes
Btrfs: check for actual acls rather than just xattrs when caching no acl
Btrfs: move btrfs_truncate_page to btrfs_cont_expand instead of btrfs_truncate
Btrfs: optimize reada_for_balance
Btrfs: optimize read_block_for_search
Suggested by Linus:
Changed time accounting for busy-poll:
- Make it microsecond based.
- Use unsigned longs.
- Revert back to use time_after instead of time_in_range.
Reorder poll/select busy loop conditions:
- Clear busy_flag after one time we can't busy-poll.
- Only init busy_end if we actually are going to busy-poll.
Added one more missing need_resched() test.
Signed-off-by: Eliezer Tamir <eliezer.tamir@linux.intel.com>
__kernel_time_t is a long, which cannot hold a U32_MAX on 32-bit
architectures. Just drop this check as it has limited value.
This fixes a crash like:
[ 957.905812] kernel BUG at /srv/autobuild-ceph/gitbuilder.git/build/include/linux/ceph/decode.h:164!
[ 957.914849] Internal error: Oops - BUG: 0 [#1] SMP ARM
[ 957.919978] Modules linked in: rbd libceph libcrc32c ipmi_devintf ipmi_si ipmi_msghandler nfsd nfs_acl auth_rpcgss nfs fscache lockd sunrpc
[ 957.932547] CPU: 1 Tainted: G W (3.9.0-ceph-19bb6a83-highbank #1)
[ 957.939881] PC is at ceph_osdc_build_request+0x8c/0x4f8 [libceph]
[ 957.945967] LR is at 0xec520904
[ 957.949103] pc : [<bf13e76c>] lr : [<ec520904>] psr: 20000153
[ 957.949103] sp : ec753df8 ip : 00000001 fp : ec53e100
[ 957.960571] r10: ebef25c0 r9 : ec5fa400 r8 : ecbcc000
[ 957.965788] r7 : 00000000 r6 : 00000000 r5 : ffffffff r4 : 00000020
[ 957.972307] r3 : 51cc8143 r2 : ec520900 r1 : ec753e58 r0 : ec520908
[ 957.978827] Flags: nzCv IRQs on FIQs off Mode SVC_32 ISA ARM Segment user
[ 957.986039] Control: 10c5387d Table: 2c59c04a DAC: 00000015
[ 957.991777] Process rbd (pid: 2138, stack limit = 0xec752238)
[ 957.997514] Stack: (0xec753df8 to 0xec754000)
[ 958.001864] 3de0: 00000001 00000001
[ 958.010032] 3e00: 00000001 bf139744 ecbcc000 ec55a0a0 00000024 00000000 ebef25c0 fffffffe
[ 958.018204] 3e20: ffffffff 00000000 00000000 00000001 ec5fa400 ebef25c0 ec53e100 bf166b68
[ 958.026377] 3e40: 00000000 0000220f fffffffe ffffffff ec753e58 bf13ff24 51cc8143 05b25ed2
[ 958.034548] 3e60: 00000001 00000000 00000000 bf1688d4 00000001 00000000 00000000 00000000
[ 958.042720] 3e80: 00000001 00000060 ec5fa400 ed53d200 ed439600 ed439300 00000001 00000060
[ 958.050888] 3ea0: ec5fa400 ed53d200 00000000 bf16a320 00000000 ec53e100 00000040 ec753eb8
[ 958.059059] 3ec0: ec51df00 ed53d7c0 ed53d200 ed53d7c0 00000000 ed53d7c0 ec5fa400 bf16ed70
[ 958.067230] 3ee0: 00000000 00000060 00000002 ed53d200 00000000 bf16acf4 ed53d7c0 ec752000
[ 958.075402] 3f00: ed980e50 e954f5d8 00000000 00000060 ed53d240 ed53d258 ec753f80 c04f44a8
[ 958.083574] 3f20: edb7910c ec664700 01ade920 c02e4c44 00000060 c016b3dc ec51de40 01adfb84
[ 958.091745] 3f40: 00000060 ec752000 ec753f80 ec752000 00000060 c0108444 00000007 ec51de48
[ 958.099914] 3f60: ed0eb8c0 00000000 00000000 ec51de40 01adfb84 00000001 00000060 c0108858
[ 958.108085] 3f80: 00000000 00000000 51cc8143 00000060 01adfb84 00000007 00000004 c000dd68
[ 958.116257] 3fa0: 00000000 c000dbc0 00000060 01adfb84 00000007 01adfb84 00000060 01adfb80
[ 958.124429] 3fc0: 00000060 01adfb84 00000007 00000004 beded1a8 00000000 01adf2f0 01ade920
[ 958.132599] 3fe0: 00000000 beded180 b6811324 b6811334 800f0010 00000007 2e7f5821 2e7f5c21
[ 958.140815] [<bf13e76c>] (ceph_osdc_build_request+0x8c/0x4f8 [libceph]) from [<bf166b68>] (rbd_osd_req_format_write+0x50/0x7c [rbd])
[ 958.152739] [<bf166b68>] (rbd_osd_req_format_write+0x50/0x7c [rbd]) from [<bf1688d4>] (rbd_dev_header_watch_sync+0xe0/0x204 [rbd])
[ 958.164486] [<bf1688d4>] (rbd_dev_header_watch_sync+0xe0/0x204 [rbd]) from [<bf16a320>] (rbd_dev_image_probe+0x23c/0x850 [rbd])
[ 958.175967] [<bf16a320>] (rbd_dev_image_probe+0x23c/0x850 [rbd]) from [<bf16acf4>] (rbd_add+0x3c0/0x918 [rbd])
[ 958.185975] [<bf16acf4>] (rbd_add+0x3c0/0x918 [rbd]) from [<c02e4c44>] (bus_attr_store+0x20/0x2c)
[ 958.194850] [<c02e4c44>] (bus_attr_store+0x20/0x2c) from [<c016b3dc>] (sysfs_write_file+0x168/0x198)
[ 958.203984] [<c016b3dc>] (sysfs_write_file+0x168/0x198) from [<c0108444>] (vfs_write+0x9c/0x170)
[ 958.212768] [<c0108444>] (vfs_write+0x9c/0x170) from [<c0108858>] (sys_write+0x3c/0x70)
[ 958.220768] [<c0108858>] (sys_write+0x3c/0x70) from [<c000dbc0>] (ret_fast_syscall+0x0/0x30)
[ 958.229199] Code: e59d1058 e5913000 e3530000 ba000114 (e7f001f2)
CC: stable@vger.kernel.org # 3.4+
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Pull NFS client updates from Trond Myklebust:
"Feature highlights include:
- Add basic client support for NFSv4.2
- Add basic client support for Labeled NFS (selinux for NFSv4.2)
- Fix the use of credentials in NFSv4.1 stateful operations, and add
support for NFSv4.1 state protection.
Bugfix highlights:
- Fix another NFSv4 open state recovery race
- Fix an NFSv4.1 back channel session regression
- Various rpc_pipefs races
- Fix another issue with NFSv3 auth negotiation
Please note that Labeled NFS does require some additional support from
the security subsystem. The relevant changesets have all been
reviewed and acked by James Morris."
* tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (54 commits)
NFS: Set NFS_CS_MIGRATION for NFSv4 mounts
NFSv4.1 Refactor nfs4_init_session and nfs4_init_channel_attrs
nfs: have NFSv3 try server-specified auth flavors in turn
nfs: have nfs_mount fake up a auth_flavs list when the server didn't provide it
nfs: move server_authlist into nfs_try_mount_request
nfs: refactor "need_mount" code out of nfs_try_mount
SUNRPC: PipeFS MOUNT notification optimization for dying clients
SUNRPC: split client creation routine into setup and registration
SUNRPC: fix races on PipeFS UMOUNT notifications
SUNRPC: fix races on PipeFS MOUNT notifications
NFSv4.1 use pnfs_device maxcount for the objectlayout gdia_maxcount
NFSv4.1 use pnfs_device maxcount for the blocklayout gdia_maxcount
NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesize
NFS: Improve legacy idmapping fallback
NFSv4.1 end back channel session draining
NFS: Apply v4.1 capabilities to v4.2
NFSv4.1: Clean up layout segment comparison helper names
NFSv4.1: layout segment comparison helpers should take 'const' parameters
NFSv4: Move the DNS resolver into the NFSv4 module
rpc_pipefs: only set rpc_dentry_ops if d_op isn't already set
Pull third set of VFS updates from Al Viro:
"Misc stuff all over the place. There will be one more pile in a
couple of days"
This is an "evil merge" that also uses the new d_count helper in
fs/configfs/dir.c, missed by commit 84d08fa888e7 ("helper for reading
->d_count")
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ncpfs: fix error return code in ncp_parse_options()
locks: move file_lock_list to a set of percpu hlist_heads and convert file_lock_lock to an lglock
seq_file: add seq_list_*_percpu helpers
f2fs: fix readdir incorrectness
mode_t whack-a-mole...
lustre: kill the pointless wrapper
helper for reading ->d_count
The only difference between sg_pcopy_{from,to}_buffer() and
sg_copy_{from,to}_buffer() is an additional argument that specifies the
number of bytes to skip the SG list before copying.
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: Douglas Gilbert <dgilbert@interlog.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Horia Geanta <horia.geanta@freescale.com>
Cc: Imre Deak <imre.deak@intel.com>
Acked-by: Tejun Heo <tj@kernel.org>
This patchset is for supporting LZ4 compression and the crypto API using
it.
As shown below, the size of data is a little bit bigger but compressing
speed is faster under the enabled unaligned memory access. We can use
lz4 de/compression through crypto API as well. Also, It will be useful
for another potential user of lz4 compression.
lz4 Compression Benchmark:
Compiler: ARM gcc 4.6.4
ARMv7, 1 GHz based board
Kernel: linux 3.4
Uncompressed data Size: 101 MB
Compressed Size compression Speed
LZO 72.1MB 32.1MB/s, 33.0MB/s(UA)
LZ4 75.1MB 30.4MB/s, 35.9MB/s(UA)
LZ4HC 59.8MB 2.4MB/s, 2.5MB/s(UA)
- UA: Unaligned memory Access support
- Latest patch set for LZO applied
This patch:
Add support for LZ4 compression in the Linux Kernel. LZ4 Compression APIs
for kernel are based on LZ4 implementation by Yann Collet and were changed
for kernel coding style.
LZ4 homepage : http://fastcompression.blogspot.com/p/lz4.html
LZ4 source repository : http://code.google.com/p/lz4/
svn revision : r90
Two APIs are added:
lz4_compress() support basic lz4 compression whereas lz4hc_compress()
support high compression or CPU performance get lower but compression
ratio get higher. Also, we require the pre-allocated working memory with
the defined size and destination buffer must be allocated with the size of
lz4_compressbound.
[akpm@linux-foundation.org: make lz4_compresshcctx() static]
Signed-off-by: Chanho Min <chanho.min@lge.com>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Bob Pearson <rpearson@systemfabricworks.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Herbert Xu <herbert@gondor.hengli.com.au>
Cc: Yann Collet <yann.collet.73@gmail.com>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
Add support for extracting LZ4-compressed kernel images, as well as
LZ4-compressed ramdisk images in the kernel boot process.
Signed-off-by: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: Florian Fainelli <florian@openwrt.org>
Add support for LZ4 decompression in the Linux Kernel. LZ4 Decompression
APIs for kernel are based on LZ4 implementation by Yann Collet.
Benchmark Results(PATCH v3)
Compiler: Linaro ARM gcc 4.6.2
1. ARMv7, 1.5GHz based board
Kernel: linux 3.4
Uncompressed Kernel Size: 14MB
Compressed Size Decompression Speed
LZO 6.7MB 20.1MB/s, 25.2MB/s(UA)
LZ4 7.3MB 29.1MB/s, 45.6MB/s(UA)
2. ARMv7, 1.7GHz based board
Kernel: linux 3.7
LZO 6.0MB 34.1MB/s, 52.2MB/s(UA)
LZ4 6.5MB 86.7MB/s
This patch set is for adding support for LZ4-compressed Kernel. LZ4 is a
very fast lossless compression algorithm and it also features an extremely
fast decoder [1].
But we have five of decompressors already and one question which does
arise, however, is that of where do we stop adding new ones? This issue
had been discussed and came to the conclusion [2].
Russell King said that we should have:
- one decompressor which is the fastest
- one decompressor for the highest compression ratio
- one popular decompressor (eg conventional gzip)
If we have a replacement one for one of these, then it should do exactly
that: replace it.
The benchmark shows that an 8% increase in image size vs a 66% increase
in decompression speed compared to LZO(which has been known as the
fastest decompressor in the Kernel). Therefore the "fast but may not be
small" compression title has clearly been taken by LZ4 [3].
[1] http://code.google.com/p/lz4/
[2] http://thread.gmane.org/gmane.linux.kbuild.devel/9157
[3] http://thread.gmane.org/gmane.linux.kbuild.devel/9347
LZ4 homepage: http://fastcompression.blogspot.com/p/lz4.html
LZ4 source repository: http://code.google.com/p/lz4/
Signed-off-by: Yann Collet <yann.collet.73@gmail.com>
Merge together the unicore32, arm, and x86 reboot= command line
parameter handling.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Prepare for the moving the parsing of reboot= to the generic kernel code
by making reboot_mode into a more generic form.
Cc: Miguel Boton <mboton.lkml@gmail.com>
Get the new file to pass scripts/checkpatch.pl
sem_otime contains the time of the last semaphore operation that
completed successfully. Every operation updates this value, thus access
from multiple cpus can cause thrashing.
Therefore the patch replaces the variable with a per-semaphore variable.
The per-array sem_otime is only calculated when required.
No performance improvement on a single-socket i3 - only important for
larger systems.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Introduce separate queues for operations that do not modify the
semaphore values. Advantages:
- Simpler logic in check_restart().
- Faster update_queue(): Right now, all wait-for-zero operations are
always tested, even if the semaphore value is not 0.
- wait-for-zero gets again priority, as in linux <=3.0.9
This reverts commit bf26c018490c ("Prepare to fix racy accesses on task
breakpoints").
The patch was fine but we can no longer race with SIGKILL after commit
9899d11f6544 ("ptrace: ensure arch_ptrace/ptrace_request can never race
with SIGKILL"), the __TASK_TRACED tracee can't be woken up and
->ptrace_bps[] can't go away.
Now that ptrace_get_breakpoints/ptrace_put_breakpoints have no callers,
we can kill them and remove task->ptrace_bp_refcnt.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Michael Neuling <mikey@neuling.org>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
This patch, originally from Android kernel, adds vfat ioctl command
FAT_IOCTL_GET_VOLUME_ID, with this command we can get the vfat volume ID
using following code:
ioctl(fd, FAT_IOCTL_GET_VOLUME_ID, &volume_ID)
This patch is a modified version of the patch by Mike Lockwood, with
changes from Dmitry Pervushin, who noticed the original patch makes some
volume IDs abiguous with error returns: for example, if volume id is
0xFFFFFDAD, that matches -ENOIOCTLCMD, we get "FFFFFFFF" from the user
space.
So add a parameter to ioctl to get the correct volume ID.
Android uses vfat volume ID to identify different sd card, when a new sd
card is inserted to device, android can scan the media on it and pop up
new contents.
Signed-off-by: Bintian Wang <bintian.wang@linaro.org>
Cc: dmitry pervushin <dpervushin@gmail.com>
Cc: Mike Lockwood <lockwood@android.com>
Cc: Colin Cross <ccross@android.com>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Sean McNeil <sean@mcneil.com>
There is no parameter "sync" in address_space_operations->migratepage().
It should be migrate_mode. And the comment is for MIGRATE_ASYNC.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
These VM_<READfoo> macros aren't used very often and three of them
aren't used at all.
Expand the ones that are used in-place, and remove all the now unused
#define VM_<foo> macros.
VM_READHINTMASK, VM_NormalReadHint and VM_ClearReadHint were added just
before 2.4 and appears have never been used.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue"), there is no bdi forker thread
any more. However, WB_REASON_FORKER_THREAD is still used due to it is
TPs userland visible and we won't be exposing exactly the same
information with just a different name.
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
wb_reason_name is not used any more - remove it.
Reviewed-by: Fengguang Wu <fengguang.wu@intel.com>
It's not used globally and could be static.
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
These functions are nowhere used, so remove them.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
0xc just means MOVABLE + DMA32, which results in zone DMA32.
VM_UNLIST was used to indicate that the vm_struct is not listed in
vmlist.
But after commit 4341fa454796 ("mm, vmalloc: remove list management of
vmlist after initializing vmalloc"), the meaning of this flag changed.
It now means the vm_struct is not fully initialized. So renaming it to
VM_UNINITIALIZED seems more reasonable.
Also change clear_vm_unlist to clear_vm_uninitialized_flag.
audit_names record
The old audit PATH records for mq_open looked like this:
type=PATH msg=audit(1366282323.982:869): item=1 name=(null) inode=6777
dev=00:0c mode=041777 ouid=0 ogid=0 rdev=00:00
obj=system_u:object_r:tmpfs_t:s15:c0.c1023
type=PATH msg=audit(1366282323.982:869): item=0 name="test_mq" inode=26732
dev=00:0c mode=0100700 ouid=0 ogid=0 rdev=00:00
obj=staff_u:object_r:user_tmpfs_t:s15:c0.c1023
...with the audit related changes that went into 3.7, they now look like this:
type=PATH msg=audit(1366282236.776:3606): item=2 name=(null) inode=66655
type=PATH msg=audit(1366282236.776:3606): item=1 name=(null) inode=6926
type=PATH msg=audit(1366282236.776:3606): item=0 name="test_mq"
Both of these look wrong to me. As Steve Grubb pointed out:
"What we need is 1 PATH record that identifies the MQ. The other PATH
records probably should not be there."
Fix it to record the mq root as a parent, and flag it such that it
should be hidden from view when the names are logged, since the root of
the mq filesystem isn't terribly interesting. With this change, we get
a single PATH record that looks more like this:
type=PATH msg=audit(1368021604.836:484): item=0 name="test_mq" inode=16914
dev=00:0c mode=0100644 ouid=0 ogid=0 rdev=00:00
obj=unconfined_u:object_r:user_tmpfs_t:s0
In order to do this, a new audit_inode_parent_hidden() function is
added. If we do it this way, then we avoid having the existing callers
of audit_inode needing to do any sort of flag conversion if auditing is
inactive.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reported-by: Jiri Jaburek <jjaburek@redhat.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
Rename functions in include/net/ll_poll.h to busy wait.
Clarify documentation about expected power use increase.
Rename POLL_LL to POLL_BUSY_LOOP.
Add need_resched() testing to poll/select busy loops.
Note, that in select and poll can_busy_poll is dynamic and is
updated continuously to reflect the existence of supported
sockets with valid queue information.
virtio_ring.h uses mb() and friends, make
it pull in asm/barrier.h itself, not rely
on other headers to do it.
Also known as the "no really, I read the spec" bit.
into for-next
This deals with the sparse warning:
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: warning: incorrect type in argument 2 (different address spaces)
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: expected void *buf
drivers/net/ethernet/mellanox/mlx5/core/health.c:94:54: got struct health_buffer [noderef] <asn:2>*health
Signed-off-by: Roland Dreier <roland@purestorage.com>
The driver is comprised of two kernel modules: mlx5_ib and mlx5_core.
This partitioning resembles what we have for mlx4, except that mlx5_ib
is the pci device driver and not mlx5_core.
mlx5_core is essentially a library that provides general functionality
that is intended to be used by other Mellanox devices that will be
introduced in the future. mlx5_ib has a similar role as any hardware
device under drivers/infiniband/hw.
Signed-off-by: Eli Cohen <eli@mellanox.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Merge in coccinelle fixes from Fengguang Wu <fengguang.wu@intel.com>.
- Roland ]
The function stub for cpufreq_cooling_get_level introduced
in 57df81069 "Thermal: exynos: fix cooling state translation"
is not syntactically correct C and needs to be fixed to avoid
this error:
In file included from drivers/thermal/db8500_thermal.c:20:0:
include/linux/cpu_cooling.h: In function 'cpufreq_cooling_get_level':
include/linux/cpu_cooling.h:57:1:
error: parameter name omitted unsigned long cpufreq_cooling_get_level(unsigned int, unsigned int) ^
include/linux/cpu_cooling.h:57:1: error: parameter name omitted
Acked-by: Eduardo Valentin <eduardo.valentin@ti.com>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Amit Daniel kachhap <amit.daniel@samsung.com>
Cc: stable@vger.kernel.org
Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
The file_lock_list is only used for /proc/locks. The vastly common case
is for locks to be put onto the list and come off again, without ever
being traversed.
Help optimize for this use-case by moving to percpu hlist_head-s. At the
same time, we can make the locking less contentious by moving to an
lglock. When iterating over the lists for /proc/locks, we must take the
global lock and then iterate over each CPU's list in turn.
This change necessitates a new fl_link_cpu field to keep track of which
CPU the entry is on. On x86_64 at least, this field is placed within an
existing hole in the struct to avoid growing the size.
Acked-by: J. Bruce Fields <bfields@fieldses.org>
When we convert the file_lock_list to a set of percpu lists, we'll need
a way to iterate over them in order to output /proc/locks info. Add
some seq_list_*_percpu helpers to handle that.
kmap_atomic allows only one argument now, just remove the unused 'kmtype'.
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Chris Zankel <chris@zankel.net>
RDMA needs to post a buffer for each incoming reply.
Hence it needs to keep count of these and needs to be
aware of whether a flushed request has received a reply
or not.
This patch adds the cancelled() callback to the transport modules.
It is called when RFLUSH has been received and that the corresponding
request will never receive a reply.
Signed-off-by: Simon Derr <simon.derr@bull.net>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
If the privport option is specified, the tcp transport binds local
address to a reserved port before connecting to the 9p server.
In some cases when 9P AUTH cannot be implemented, this is better than
nothing.
Signed-off-by: Jim Garlick <garlick@llnl.gov>
Continue the approach taken by commit d2b57063e4a ("IB/core: Reserve
bits in enum ib_qp_create_flags for low-level driver use") and add
reserved entries to the ib_qp_type and ib_wr_opcode enums. Low-level
drivers can then define macros to use these reserved values, giving
proper names to the macros for readability. Also add a range of
reserved flags to enum ib_send_flags.
The mlx5 IB driver uses the new additions.
The return value wasn't checked by any of the callers. Assuming this is
correct behaviour, we can simplify some code by not bothering to
generate it.
nab: Add srpt_queue_data_in() + srpt_queue_tm_rsp() nops around
srpt_queue_response() void return
Signed-off-by: Joern Engel <joern@logfs.org>
Three have been checked for but were never set. Remove the dead code.
Also renumbers the remaining ones to a) get rid of the holes after the
removal and b) avoid a collision between TMR_FUNCTION_COMPLETE==0 and
the uninitialized case. If we failed to set a code, we should rather
fall into the default case then return success.
This patch adds tracepoints to the target code for commands being
received and being completed, which is quite useful for debugging
interactions with initiators. For example, one can do something like the
following to watch commands that are completing unsuccessfully:
# echo 'scsi_status!=0' > /sys/kernel/debug/tracing/events/target/target_cmd_complete/filter
# echo 1 > /sys/kernel/debug/tracing/events/target/target_cmd_complete/enable
<run command that fails>
# cat /sys/kernel/debug/tracing/trace
iscsi_trx-0-1902 [003] ...1 990185.810385: target_cmd_complete: iqn.1993-08.org.debian:01:e51ede6aacfd <- LUN 001 status CHECK CONDITION (sense len 18 / 70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00) 0x95 data_length 512 CDB 95 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 (TA:SIMPLE C:00)
(v2: Drop undefined COMPARE_AND_WRITE)
This patch addresses a bug where RDMA_CM_EVENT_DISCONNECTED may occur
before the connection shutdown has been completed by rx/tx threads,
that causes isert_free_conn() to wait indefinately on ->conn_wait.
This patch allows isert_disconnect_work code to invoke rdma_disconnect
when isert_disconnect_work() process context is started by client
session reset before isert_free_conn() code has been reached.
It also adds isert_conn->conn_mutex protection for ->state within
isert_disconnect_work(), isert_cq_comp_err() and isert_free_conn()
code, along with isert_check_state() for wait_event usage.
(v2: Add explicit iscsit_cause_connection_reinstatement call
during isert_disconnect_work() to force conn reset)
Cc: stable@vger.kernel.org # 3.10+
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Pull slave-dmaengine updates from Vinod Koul:
"Once you have some time from extended weekend celebrations please
consider pulling the following to get:
- Various fixes and PCI driver for dw_dmac by Andy
- DT binding for imx-dma by Markus & imx-sdma by Shawn
- DT fixes for dmaengine by Lars
- jz4740 dmac driver by Lars
- and various fixes across the drivers"
What "extended weekend celebrations"? I'm in the merge window, who has
time for extended celebrations..
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (40 commits)
DMA: shdma: add DT support
DMA: shdma: shdma_chan_filter() has to be in shdma-base.h
DMA: shdma: (cosmetic) don't re-calculate a pointer
dmaengine: at_hdmac: prepare clk before calling enable
dmaengine/trivial: at_hdmac: add curly brackets to if/else expressions
dmaengine: at_hdmac: remove unsuded atc_cleanup_descriptors()
dmaengine: at_hdmac: add FIFO configuration parameter to DMA DT binding
ARM: at91: dt: add header to define at_hdmac configuration
MIPS: jz4740: Correct clock gate bit for DMA controller
MIPS: jz4740: Remove custom DMA API
MIPS: jz4740: Register jz4740 DMA device
dma: Add a jz4740 dmaengine driver
MIPS: jz4740: Acquire and enable DMA controller clock
dma: mmp_tdma: disable irq when disabling dma channel
dmaengine: PL08x: Avoid collisions with get_signal() macro
dmaengine: dw: select DW_DMAC_BIG_ENDIAN_IO automagically
dma: dw: add PCI part of the driver
dma: dw: split driver to library part and platform code
dma: move dw_dmac driver to an own directory
dw_dmac: don't check resource with devm_ioremap_resource
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull first stage of __cpuinit removal from Paul Gortmaker:
"The two commits here 1) dummy out all the __cpuinit macros so that we
no longer generate such sections, and then 2) remove all the section
processing that we used to do for those sections.
This makes all the __cpuinit and friends no-ops, so that we can remove
the use cases of it at our leisure. Expect stage 2, which does the
tree wide removal sweep at the end of the merge window."
* 'cpuinit-delete' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
modpost: remove all traces of cpuinit/cpuexit sections
init.h: remove __cpuinit sections from the kernel
