Sony IMX135 camera sensor can be found on Ardbeg/Laguna. This patch
introduced sensor driver for imx135 using soc_camera interface.
Bug 1380143
Change-Id: Ifa0becf1ec2d9931ebf9ea3a4e9ea3e1013a9e36
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/337469
(cherry picked from commit 94a04c2c9b614519aab6f718d60bcf1d8032aa8f)
Reviewed-on: http://git-master/r/498935
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Provide sysedp_dynamic_capping with the instantaneous GPU frequency
when notifying it of the GPU load. Modify the gpu/cpu priority
decision logic to choose CPU priority until GPU frequency gets "near"
the CPU-priority-limited-GPU-fmax. Introduce the priority_bias debugfs
parameter to facilitate tuning of "near". priority_bias takes a value
from 0 to 100.
Change-Id: I57df17d50cd8077a512b5932f4a304ca5e6992aa
Signed-off-by: Matt Longnecker <mlongnecker@nvidia.com>
Reviewed-on: http://git-master/r/481720
(cherry picked from commit b2ac745a45e273e849d7b190913ee97092fdebc2)
Reviewed-on: http://git-master/r/498901
Due to a HW bug 1320346 in t12x/t13x, PCIE needs to be unpowergated when XUSB
is to be accessed. Currently PCIE powergating ops need to be invoked from XUSB
driver since powergating module doesn't internally handle this dependency.
This patch implements this dependency within the powergating module so that
xhci-tegra driver can stay chip-agnostic.
Bug 1451279
Bug 1524744
Bug 200027067
Change-Id: I57da2645c9bde1c98b73a906f2ff5e407a3a8380
Reviewed-on: http://git-master/r/424035
(cherry picked from commit ff373b04f297ee653c58a86c6642325037f5d10e)
Signed-off-by: Vidya Sagar <vidyas@nvidia.com>
Reviewed-on: http://git-master/r/498661
Due to HW Bug 1320346, both XUSB and PCIE modules need to control powergating
on PCIE block. Implement reference counter mechanism so that powergating is
done only when neither of these two drivers are active.
Bug 1451279
Bug 1455032
Bug 200027067
Change-Id: I6866ba0fb47433e211360b722abbb1b2c1a05c35
Reviewed-on: http://git-master/r/418060
(cherry picked from commit 70be55b824632252be36f6ee0d495d4c0f4e507c)
Reviewed-on: http://git-master/r/498659
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Add a simple sysfs interface to the generic PWM framework.
/sys/class/pwm/
`-- pwmchipN/ for each PWM chip
|-- export (w/o) ask the kernel to export a PWM channel
|-- npwm (r/o) number of PWM channels in this PWM chip
|-- pwmX/ for each exported PWM channel
| |-- duty_cycle (r/w) duty cycle (in nanoseconds)
| |-- enable (r/w) enable/disable PWM
| |-- period (r/w) period (in nanoseconds)
| `-- polarity (r/w) polarity of PWM (normal/inversed)
`-- unexport (w/o) return a PWM channel to the kernel
Based on work by Lars Poeschel.
Bug 200028381
Change-Id: I0c9c6ad2ca7173e6fc3fbe1d3cd3963cde00539a
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Rob Landley <rob@landley.net>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
(cherry picked from commit 76abbdde2d95a3807d0dc6bf9f84d03d0dbd4f3d)
Reviewed-on: http://git-master/r/455068
(cherry picked from commit b1824bc0325f84ea04dab7d6d4f7c887c80b1982)
Reviewed-on: http://git-master/r/488690
Tested-by: Winnie Hsu <whsu@nvidia.com>
This patch addresses the following issues in the header files in the
cpufreq core:
- Include headers in ascending order, so that we don't add same
many times by mistake.
- <asm/> must be included after <linux/>, so that they override
whatever they need to.
- Remove unnecessary includes.
- Don't include files already included by cpufreq.h or
cpufreq_governor.h.
Bug 1359622
[rjw: Changelog]
Change-Id: I3d69d7243b982cd2e32abfdfb9dd750843a07629
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
(cherry picked from commit 5ff0a268037d344f86df690ccb994d8bc015d2d9)
Reviewed-on: http://git-master/r/482370
Tested-by: Rajkumar Kasirajan <rkasirajan@nvidia.com>
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Since the user space code may works in either 32 or 64 bit mode,
attentions should be taken while passing pointers from user space to
the kernel. In this case, the p_value of struct nvc_param and
power_on/power_off of struct virtual_device received from the user
space should be handled properly.
The solution is to create a set of 32 bit version of structures
nvc_param and virtual_device along with some dedicated 32 bit mode
ioctl commands, then in the ioctl functions, the 32 bit user mode
access will be handled separately.
bug 1518359
Change-Id: I4cbbeeaef446ab962aaa1f92251ce1fd9d5723aa
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/437390
(cherry picked from commit 3fdbc210fc9f33d0f89af079a89bdb1f41e73ecb)
Reviewed-on: http://git-master/r/482230
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
This patch modifies devfreq to account only the time a device is
powered in trans_stat. In addition, this patch also fixes a race
in trans_stat maintenance in cases where the node is readed at
the same time the transition table is being updated by frequency
re-estimation.
Change-Id: I6e4341317b6dda88d69028c9f67785400e5a7a65
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/435174
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
Reviewed-by: Samuel Russell <samuelr@nvidia.com>
Tested-by: Samuel Russell <samuelr@nvidia.com>
Reviewed-by: Ilan Aelion <iaelion@nvidia.com>
* Add time source option (CNTVCT or kernel monotonic clock).
* Do not use arch timer if user does not have direct access to
CNTVCT register.
Bug 1508327
Change-Id: I0efc619146c1256ac57120b8646ecd8e819a1315
Signed-off-by: Igor Nabirushkin <inabirushkin@nvidia.com>
Reviewed-on: http://git-master/r/427620
(cherry picked from commit 5e375e6dbca8211bb2af04bd25d5e5d66371aa4f)
Reviewed-on: http://git-master/r/433507
Reviewed-by: Andrey Trachenko <atrachenko@nvidia.com>
Tested-by: Maxim Morin <mmorin@nvidia.com>
Add API dma_alloc_at_from_contiguous to support allocations at
specific phys address.
Bug 200016405
Change-Id: I425a25af3163c391e6b7d9b8bc3299f3ffc7c7c8
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/431949
Bug 200004233
1. Raising service priority to avoid "service busy" issue while
system fully loading
2. Test_mode function@driver (Change idle escape threshold at runtime)
Usage:
a. Disable: echo 0 > /sys/devices/virtual/misc/touch/test_mode
b. Enable: echo 1 > /sys/devices/virtual/misc/touch/test_mode
c. Set: echo 2 2 100 > /sys/devices/virtual/misc/touch/test_mode
(take touch threshold 100 as example)
d. Check: cat /sys/devices/virtual/misc/touch/test_mode
3. Coding style refine
4. Add mutex_lock/mutex_unlock protection in KRL_CMD_FLUSH_QU command table
Change-Id: Iebfd42c359b510e7102d54c9b8537382c8788242
Signed-off-by: Alex Chen <alchen@nvidia.com>
Reviewed-on: http://git-master/r/432095
Reviewed-by: Jordan Nien <jnien@nvidia.com>
Reviewed-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
This patch permits changing of the current CSC coefficients. It cannot be used
with interlaced mode.
Adds fields to skip window CSC programming if nothing has changed.
Bug 1522546
Change-Id: If8fc6a5d634e4b300ef0de6a5913188fe1f1efb0
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/422885
(cherry picked from commit 4aa22cd32362f0d91ef030bc0942c303714141cf)
Reviewed-on: http://git-master/r/425986
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Tested-by: Michael Frydrych <mfrydrych@nvidia.com>
Defining relaxed version of idle_cpu, which uses
macro cpu_relaxed_read_long, that will be used to
enhance power efficiency.
bug 1440421
Change-Id: I6ba2185632ad0fba766a2548b0ddac743defb1b9
Signed-off-by: Sumit Singh <sumsingh@nvidia.com>
Reviewed-on: http://git-master/r/426484
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
Defining relaxed version of llist_empty as llist_empty_relaxed,
which will be used for power-optimization.
bug 1440421
Change-Id: I1c4c34b381e49775ed08ddd606d9744a7e7e1fba
Reviewed-on: http://git-master/r/426483
Trying to improve the power efficiency in linux/seqlock.h,
using macros cpu_relaxed_read and cpu_read_relax.
Bug 1440421
Change-Id: I8dcc9dc9c72e5a6848c7823768c76f5d38e9f0d1
Reviewed-on: http://git-master/r/398943
(cherry picked from commit ed77ee4d50641b1a5668545c946cda681c06fcd2)
Reviewed-on: http://git-master/r/422258
This reverts commit aa55d35202b5895068bdf8eace842102bf134dab.
Revert the change becasue it breaks the VUS and ID detection. With this change
on some platforms, the VBUS and ID both are detected even only connnect the
VBUS cable. This causes misbehaving of the drivers.
bug 200013069
Change-Id: I8b10c9a7c1b0520c83118245a5e85c61e9777c81
Reviewed-on: http://git-master/r/424815
(cherry picked from commit 992d7b8c03b4787c4fa37a90804008eff4ce48b4)
Reviewed-on: http://git-master/r/427032
- Update memory resize callbacks to return error codes
- error handling on heap resize update failure
Bug 1487804
Bug 1517584
Change-Id: I5ac044677e883fbecf6d04a8c1e83794325703f3
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/423748
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
commit f8c056c12c7b72290c47afadaf8b2f16336b3238
Author: Igor Nabirushkin <inabirushkin@nvidia.com>
Date: Thu Jun 5 11:57:52 2014 +0400
misc: tegra-profiler: mixed backtraces
Unwinding: switch from code with frame pointers to code
with unwind tables.
Bug 1487488
Change-Id: I254a8fd762b5312f854db1fe79635a2b419091f0
Reviewed-on: http://git-master/r/419384
commit a1d7f98fb15d4578cd140fe03a4c748e1db86c57
Date: Thu Jun 5 11:08:55 2014 +0400
misc: tegra-profiler: add sched samples
Tegra Profiler: capture task starting being scheduled on a core.
Add sched in/out samples.
Bug 1520808
Change-Id: I2c62e5c1918bdba0fc997d79d8aeb3b7b63530f0
Reviewed-on: http://git-master/r/419352
commit 6f847fd1257af28fc11b942a2f3b3dfc7eb4579f
Date: Thu Jun 5 09:52:29 2014 +0400
misc: tegra-profiler: use cntvct as time source
Tegra Profiler: use Virtual Count register (CNTVCT) as
time source.
Bug 1508327
Change-Id: If37e2dbe0a256ec28575d7c1b7d601d6bc1090f5
Reviewed-on: http://git-master/r/419305
commit d79e4f5292dae4cccb510be2b47f4ee00baa53d7
Date: Thu Jun 5 09:10:47 2014 +0400
misc: tegra-profiler: get perfmon extension
Add version of the ARMv8 NVIDIA perfmon extension to
device capabilities.
Bug 1520757
Change-Id: I18d10133272a10e3faf5022b4579c7dfea78791e
Reviewed-on: http://git-master/r/419274
commit afedef10f26475b98b7d42ab3bab6f0c2fbb6eae
Date: Mon May 19 16:49:19 2014 +0400
misc: tegra-profiler: fix hang up bug for Norrin
Do not use probe_kernel_address.
Actually, it is not safe on Norrin: this can lead to system crash.
Bug 200005974
Bug 1522252
Change-Id: If8bae9afd7c7e1bbb5beaf430c0c61f552aeb036
Reviewed-on: http://git-master/r/411507
commit 1b4c5247c0ab284dbed25683cbfa5a301da787ff
Date: Fri May 16 12:49:15 2014 +0400
misc: tegra-profiler: add unwind information
Tegra Profiler: add additional unwind information
for each call entry.
Bug 1514626
Change-Id: I2873941a4c903e0e7e909897ead55eb34d80b966
Reviewed-on: http://git-master/r/410770
commit b2f593d9bb00a380d4402f2a8cd9ed8d9646dcbd
Date: Fri May 16 12:05:36 2014 +0400
misc: tegra-profiler: fixed recursive call chains
In some cases, recursive call chains can be broken.
This patch fixes this problem.
Bug 200005395
Change-Id: I7d31ec64b004109c3684cf0d143d9b1d6cd59f9f
Reviewed-on: http://git-master/r/410745
commit 6c9f626340a81daf124d4bbeff2254f63cc084b7
Date: Fri May 16 11:24:50 2014 +0400
misc: tegra-profiler: support too deep stack level
Too deep stack level: handle it properly.
Appropriate unwind reason code has been added.
Unwinding based on frame pointers: add unwind reason codes.
Bug 200005380
Change-Id: I2199df90c746ada6a7f224a8b675638b69dc6da8
Reviewed-on: http://git-master/r/410717
commit ddea2fc86588bdf3ae313a270364052a0beab160
Date: Fri May 16 10:44:06 2014 +0400
misc: tegra-profiler: fix setup bug
* Fix bug that happens when using non-standard profiling frequencies
* Allow root user to use any frequency in range [100 Hz; 100 kHz]
Bug 200005366
Change-Id: I9a07e2c9c1fec6d61f34009d1975ea7f5d0e2592
Reviewed-on: http://git-master/r/410705
commit 5c64bcefc4b3df0ba9612cd67703593d488ab38c
Author: Deepak Nibade <dnibade@nvidia.com>
Date: Mon May 19 15:48:02 2014 +0530
misc: tegra-profiler: fix resource leaks
Fix Coverity issue of resource leaks
Coverity id : 26481
Coverity id : 26483
Bug 1416640
Change-Id: Ib71950f196b5421ccbc21b3ac8d620e790e83366
Reviewed-on: http://git-master/r/411421
commit 2f5d99b96ba18129f6c708e3db9a1e32da24816f
Date: Tue May 6 09:47:02 2014 +0400
tegra-profiler: add access to the exception tables
Tegra Profiler: add access to the exception tables via mmap areas.
Do not read directly from the user space.
Bug 200002243
Change-Id: I442daaecb11fd4416b3e485722efdf34234e0241
Reviewed-on: http://git-master/r/405671
commit 218d8cc8a573da49145c7104258fb290c83205b9
Date: Thu Apr 17 13:02:07 2014 +0400
misc: tegra-profiler: unwinding: use RCU locking
Unwinding: use RCU locking instead of spinlocks to protect
map of regions.
Bug 1502205
Change-Id: If1089b74b1f317eeaae5059de40d7a3365ae4061
Reviewed-on: http://git-master/r/397599
Change-Id: I1ac2a5a290f723cab40463932c0a814a670cf9e7
Reviewed-on: http://git-master/r/424787
Tested-by: Daniel Horowitz <dhorowitz@nvidia.com>
This reverts commit 96ec201230966872c1c4b3b2197c6e457f0236e0.
Signed-off-by: Seema Khowala <seemaj@nvidia.com>
Change-Id: Ie7127c66af2fa20ede0d512dc0d1d08499d2a8be
Reviewed-on: http://git-master/r/423316
Reviewed-by: Chao Xu <cxu@nvidia.com>
Update Documentation for device tree update for
optional oc_pg_ctrl_masking feature
Bug 1518725
Bug 1419425
Change-Id: I309533849d48d61aefebd8f477e79b79ed4127fb
Reviewed-on: http://git-master/r/423185
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Based on DT or pdata for the board used, add support
to mask oc_pg_ctrl and oc_pg_ctrl2 signal
Bug 1518725
Bug 1419425
Change-Id: Ie69c1de37b9f428e23268dad009dfff36cb1463d
Reviewed-on: http://git-master/r/423036
Defining relaxed version of hrtimer_callback_running(),
which will be used to improve power efficiency through
the use of macro cpu_relaxed_read_long.
Bug 1440421
Change-Id: Ie42d7ae9628a817d52f4636781e11b607327c2c5
Reviewed-on: http://git-master/r/398789
(cherry picked from commit 0d9f5fc1d39d7d1809519b5d11bf7ac72287b7c6)
Reviewed-on: http://git-master/r/422255
Using cpu_relaxed_read_long and defining relaxed
version of some macros, and functions so that it
can be used to improve power efficiency.
bug 1440421
Change-Id: If857ff7110cffadc6f13289a6395d253a8e3e232
Reviewed-on: http://git-master/r/380859
(cherry picked from commit a66b23c6971403594cc6a82923c8df3b8472de90)
Reviewed-on: http://git-master/r/422251
Removing cpu_relaxed_read and cpu_relaxed_read_long macros from
processor.h, as these macros are defined in asm-generic/relaxed.h.
Bug 1440421
Change-Id: I5d1ba25755e1c9d33b080dfe01ba838289f306af
Reviewed-on: http://git-master/r/400093
(cherry picked from commit 57eb21e2d4cad3ce1f85283cfffd0eff85a6d17d)
Reviewed-on: http://git-master/r/422209
Defined a new header file relaxed.h, which contains basic
macros which will be used for improving power efficiency for
arm64.
bug 1440421
Change-Id: I5ae7503afdfbaa951827bbf466d8ddccf444f558
Reviewed-on: http://git-master/r/398315
(cherry picked from commit dd434aeb1afea1d9ebce1099fb6ecfa7c6c762c6)
Reviewed-on: http://git-master/r/422203
Defining relaxed version of atomic read as cpu_relaxed_read_atomic
which will be used for improving power efficiency for arm64.
bug 1440421
Change-Id: I6ac26653ec3d62f74d8c21f250dcdaf9dfb75b9b
Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com>
(cherry picked from commit 7360c3df73afa07361eecab730903e0697d3408f)
Reviewed-on: http://git-master/r/415628
Bug 1516918
Change-Id: I5615b0657d255d9134415d92d372771baa4271e1
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/420818
Reviewed-by: Josh Kuo <joshk@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Add below two new APIs for gk20a :
1) gk20a_do_idle()
this API will force GPU to idle and railgate
2) gk20a_do_unidle()
this API will unblock all the tasks blocked by do_idle()
Bug 1487804
Change-Id: Ic5e7f2d19fb8d35f43666d0e309dde3022349d92
Reviewed-on: http://git-master/r/412061
(cherry picked from commit 932879a81499b8a7bd4eac1b985141fde8b39a0b)
Reviewed-on: http://git-master/r/421696
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Ensure that newly allocated pages, which are faulted in
in FOLL_DURABLE mode comes from non-movalbe pageblocks,
to workaround migration failures with CMA
bug 1517584
Change-Id: I76d2185cc7e77992db585a71efaa06a5c0105a76
Reviewed-on: http://git-master/r/421677
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
__get_user_pages() is already exported function,
so get_user_pages() can be easily inlined to the
caller functions.
bug 1517584
Change-Id: If700fa3c6ead133299fa99a702887584b76e5ffb
Reviewed-on: http://git-master/r/421676
introduce migrate_replace_page for migrating
page to the given target
bug 1517584
Change-Id: I5f1d3bcb19ca7d9c9cf7234e8d3472a42c4f40af
Reviewed-on: http://git-master/r/421675
Use pre-allocated DMA buffers for ADMA descriptor and Bounce buffer
instead of dynamic DMA mapping.
This improves SDHCI driver performance by reducing dynamic DMA mapping
overhead.
Bug 1486735
Change-Id: Ic9c646437be047d33304339eccc48a825f0a8bcc
Reviewed-on: http://git-master/r/380885
Cherry-picked from commit 7ffcc4cf1a1cec42610c1b55c30b3ec28547a11e
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Signed-off-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Change-Id: If850a534ba9fbfd169b4fbefd35ca5922b1d1254
Reviewed-on: http://git-master/r/416955
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: R Raj Kumar <rrajk@nvidia.com>
(cherry picked from commit 9e58888afe4e66e83eece0a8332c8e7440bd1bcf)
Reviewed-on: http://git-master/r/419444
into promotion_build
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
This reverts commit 6c8f204fe29c074287147c7fcc3dfdbd61d038df.
Change-Id: Ic688774004109ac2a8e977eb38fe934bbfac586f
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/420121
Reviewed-by: Seema Khowala <seemaj@nvidia.com>
Tested-by: Seema Khowala <seemaj@nvidia.com>
Register to otg extcon dev for y-cable notification.
Bug 200004368
Bug 1456628
Change-Id: Ie63e29b90885ef713b96d30d05fedbbb89d3cd30
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/416656
(cherry picked from commit 350fe59088ec3016cff15b1627ca26dcaa659919)
Reviewed-on: http://git-master/r/418864
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Add support for disabling pull down of the LDOs. this is configurable
from platforms.
bug 1494740
Change-Id: I8c3e02f36b3045fa25a8c881a10c686ab9c63967
Reviewed-on: http://git-master/r/418246
(cherry picked from commit 0894c40230017f0fbb0f463a0c5027738b1d2b1f)
Reviewed-on: http://git-master/r/419339
Tested-by: Venkat Reddy Talla <vreddytalla@nvidia.com>
Add support on core driver of regulator to disable parent once the
regulator enable. This is needed for some specific purpose to handle
overcurrent on parent rail due to enabling the rail.
bug 1494740
Change-Id: I95084243975ca5298abbaa23a31007413bdca7a9
Reviewed-on: http://git-master/r/418143
(cherry picked from commit a65d4377c02067d8b6105c7fcd1931e20d9e8995)
Reviewed-on: http://git-master/r/419335
while_each_thread() and next_thread() should die, almost every lockless
usage is wrong.
1. Unless g == current, the lockless while_each_thread() is not safe.
while_each_thread(g, t) can loop forever if g exits, next_thread()
can't reach the unhashed thread in this case. Note that this can
happen even if g is the group leader, it can exec.
2. Even if while_each_thread() itself was correct, people often use
it wrongly.
It was never safe to just take rcu_read_lock() and loop unless
you verify that pid_alive(g) == T, even the first next_thread()
can point to the already freed/reused memory.
This patch adds signal_struct->thread_head and task->thread_node to
create the normal rcu-safe list with the stable head. The new
for_each_thread(g, t) helper is always safe under rcu_read_lock() as
long as this task_struct can't go away.
Note: of course it is ugly to have both task_struct->thread_node and the
old task_struct->thread_group, we will kill it later, after we change
the users of while_each_thread() to use for_each_thread().
Perhaps we can kill it even before we convert all users, we can
reimplement next_thread(t) using the new thread_head/thread_node. But
we can't do this right now because this will lead to subtle behavioural
changes. For example, do/while_each_thread() always sees at least one
task, while for_each_thread() can do nothing if the whole thread group
has died. Or thread_group_empty(), currently its semantics is not clear
unless thread_group_leader(p) and we need to audit the callers before we
can change it.
So this patch adds the new interface which has to coexist with the old
one for some time, hopefully the next changes will be more or less
straightforward and the old one will go away soon.
Bug 200004307
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
(cherry picked from commit 0c740d0afc3bff0a097ad03a1c8df92757516f5c)
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Change-Id: Id689cb1383ceba2561b66188d88258619b68f5c6
Reviewed-on: http://git-master/r/419041
Change-Id: I7cc66c88afbfcca6b93e714c778c892dea14ac8f
Reviewed-on: http://git-master/r/417896
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Bug 1498826
Bug 1501967
Bug 200008806
Change-Id: Ic9179766890ebbd42bb064cd66e17a4ac959d7c4
Reviewed-on: http://git-master/r/416356
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Make ACA detection platform dependent. Also unset
the mutually explosive property.
Bug 200004368
Change-Id: I2bdd1008dc96debb29542cef0f6b7d4b801c6cd4
Reviewed-on: http://git-master/r/415127
(cherry picked from commit aa55d35202b5895068bdf8eace842102bf134dab)
Reviewed-on: http://git-master/r/417467
Maxim 14675 charger support at the PHY layer
Bug 1321188
Bug 1456402
(cherry picked from commit 2ab5c72ab40adfdc34d5334a4c2c4648ccdac42e)
Change-Id: I31d672e82f9f3a4ccf5a8db75df8f7e12f30a63b
Reviewed-on: http://git-master/r/400490
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/417035
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
- Once shutdown has been called against pmic, i2c bus
is shutdown, so pmic cannot enable or disable
regulators
- As such, once shutdown has been called, reject
regulator enable/disable calls
Bug 1510778
Change-Id: I6eb26d4846ed5c51f882761568c1f9152a0ebb24
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/411684
Ensure system time is read from rtc i.e. PMIC RTC
in case of tegra after system resume.
- Change is applicable to all PMIC RTC drivers.
bug 1510843
Reviewed-on: http://git-master/r/413365/
Reviewed-on: http://git-master/r/414163/
Reviewed-on: http://git-master/r/414169/
Reviewed-on: http://git-master/r/414200/
Reviewed-on: http://git-master/r/414201/
Change-Id: I8194f9f4be581216d662e6a6e0d7e98a9495159c
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/414203
Bug 1454698
Change-Id: Ice7c62791df51c3f9883b3b525b3587f0111b2ca
Signed-off-by: Pablo Ceballos <pceballos@nvidia.com>
Reviewed-on: http://git-master/r/402792
(cherry picked from commit 28d8a3d738d97b1c50a0d0f67a38a2a94dcee59f)
Reviewed-on: http://git-master/r/405959
Add T132 touch support for TN8
Bug 200004659
Change-Id: Id6c36db22e9376dd0ce8055c3aeaa25e56c9c0fe
Reviewed-on: http://git-master/r/410383
Change-Id: Id9b7ea216b8c93e291cc95d7522ba21d15701eeb
Reviewed-on: http://git-master/r/397838
Signed-off-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-on: http://git-master/r/402485
