Pull drm fixes from Dave Airlie:
"Intel: edid fixes, power consumption fix, s/r fix, haswell fix
Radeon: BIOS loading fixes for UEFI and Thunderbolt machines, better
MSAA validation, lockup timeout fixes, modesetting fixes
One udl dpms fix, one vmwgfx fix, a couple of trivial core changes.
There is an export added to ACPI as part of the radeon bios fixes.
I've also included the fbcon flashing cursor vs deinit race fix, that
seems the simplest place to start"
Trivial conflict in drivers/video/console/fbcon.c due to me having
already applied the fbcon flashing cursor vs deinit race fix, and Dave
had added a comment in there too.
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (22 commits)
fbcon: fix race condition between console lock and cursor timer (v1.1)
drm: Add missing static storage class specifiers in drm_proc.c file
drm/udl: dpms off the crtc when disabled.
drm: Remove two unused fields from struct drm_display_mode
drm: stop vmgfx driver explosion
drm/radeon/ss: use num_crtc rather than hardcoded 6
Revert "drm/radeon: fix bo creation retry path"
drm/i915: use hsw rps tuning values everywhere on gen6+
drm/radeon: split ATRM support out from the ATPX handler (v3)
drm/radeon: convert radeon vfct code to use acpi_get_table_with_size
ACPI: export symbol acpi_get_table_with_size
drm/radeon: implement ACPI VFCT vbios fetch (v3)
drm/radeon/kms: extend the Fujitsu D3003-S2 board connector quirk to cover later silicon stepping
drm/radeon: fix checking of MSAA renderbuffers on r600-r700
drm/radeon: allow CMASK and FMASK in the CS checker on r600-r700
drm/radeon: init lockup timeout on ring init
drm/radeon: avoid turning off spread spectrum for used pll
drm/i915: fall back to bit-banging if GMBUS fails in CRT EDID reads
drm/i915: extract connector update from intel_ddc_get_modes() for reuse
drm/i915: fix hsw uncached pte
Pull SCSI target fixes from Nicholas Bellinger:
"The executive summary includes:
- Post-merge review comments for tcm_vhost (MST + nab)
- Avoid debugging overhead when not debugging for tcm-fc(FCoE) (MDR)
- Fix NULL pointer dereference bug on alloc_page failulre (Yi Zou)
- Fix REPORT_LUNs regression bug with pSCSI export (AlexE + nab)
- Fix regression bug with handling of zero-length data CDBs (nab)
- Fix vhost_scsi_target structure alignment (MST)
Thanks again to everyone who contributed a bugfix patch, gave review
feedback on tcm_vhost code, and/or reported a bug during their own
testing over the last weeks.
There is one other outstanding bug reported by Roland recently related
to SCSI transfer length overflow handling, for which the current
proposed bugfix has been left in queue pending further testing with
other non iscsi-target based fabric drivers.
As the patch is verified with loopback (local SGL memory from SCSI
LLD) + tcm_qla2xxx (TCM allocated SGL memory mapped to PCI HW) fabric
ports, it will be included into the next 3.6-rc-fixes PULL request."
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: Remove unused se_cmd.cmd_spdtl
tcm_fc: rcu_deref outside rcu lock/unlock section
tcm_vhost: Fix vhost_scsi_target structure alignment
target: Fix regression bug with handling of zero-length data CDBs
target/pscsi: Fix bug with REPORT_LUNs handling for SCSI passthrough
tcm_vhost: Change vhost_scsi_target->vhost_wwpn to char *
target: fix NULL pointer dereference bug alloc_page() fails to get memory
tcm_fc: Avoid debug overhead when not debugging
tcm_vhost: Post-merge review changes requested by MST
tcm_vhost: Fix incorrect IS_ERR() usage in vhost_scsi_map_iov_to_sgl
Pull NFS client bugfixes from Trond Myklebust:
- NFSv3 mounts need to fail if the FSINFO rpc call fails
- Ensure that the NFS commit cache gets torn down when we unload the
NFS module.
- Fix memory scribble issues when interrupting a LAYOUTGET rpc call
- Fix NFSv4 legacy idmapper regressions
- Fix issues with the NFSv4 getacl command
- Fix a regression when using the legacy "mount -t nfs4"
* tag 'nfs-for-3.6-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv3: Ensure that do_proc_get_root() reports errors correctly
NFSv4: Ensure that nfs4_alloc_client cleans up on error.
NFS: return -ENOKEY when the upcall fails to map the name
NFS: Clear key construction data if the idmap upcall fails
NFSv4: Don't use private xdr_stream fields in decode_getacl
NFSv4: Fix the acl cache size calculation
NFSv4: Fix pointer arithmetic in decode_getacl
NFS: Alias the nfs module to nfs4
NFS: Fix a regression when loading the NFS v4 module
NFSv4.1: Remove a bogus BUG_ON() in nfs4_layoutreturn_done
pnfs-obj: Better IO pattern in case of unaligned offset
NFS41: add pg_layout_private to nfs_pageio_descriptor
pnfs: nfs4_proc_layoutget returns void
pnfs: defer release of pages in layoutget
nfs: tear down caches in nfs_init_writepagecache when allocation fails
Pull assorted fixes - mostly vfs - from Al Viro:
"Assorted fixes, with an unexpected detour into vfio refcounting logics
(fell out when digging in an analog of eventpoll race in there)."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
task_work: add a scheduling point in task_work_run()
fs: fix fs/namei.c kernel-doc warnings
eventpoll: use-after-possible-free in epoll_create1()
vfio: grab vfio_device reference *before* exposing the sucker via fd_install()
vfio: get rid of vfio_device_put()/vfio_group_get_device* races
vfio: get rid of open-coding kref_put_mutex
introduce kref_put_mutex()
vfio: don't dereference after kfree...
mqueue: lift mnt_want_write() outside ->i_mutex, clean up a bit
equivalent of
mutex_lock(mutex);
if (!kref_put(kref, release))
mutex_unlock(mutex);
Merge fixes from Andrew Morton.
Random drivers and some VM fixes.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (17 commits)
mm: compaction: Abort async compaction if locks are contended or taking too long
mm: have order > 0 compaction start near a pageblock with free pages
rapidio/tsi721: fix unused variable compiler warning
rapidio/tsi721: fix inbound doorbell interrupt handling
drivers/rtc/rtc-rs5c348.c: fix hour decoding in 12-hour mode
mm: correct page->pfmemalloc to fix deactivate_slab regression
drivers/rtc/rtc-pcf2123.c: initialize dynamic sysfs attributes
mm/compaction.c: fix deferring compaction mistake
drivers/misc/sgi-xp/xpc_uv.c: SGI XPC fails to load when cpu 0 is out of IRQ resources
string: do not export memweight() to userspace
hugetlb: update hugetlbpage.txt
checkpatch: add control statement test to SINGLE_STATEMENT_DO_WHILE_MACRO
mm: hugetlbfs: correctly populate shared pmd
cciss: fix incorrect scsi status reporting
Documentation: update mount option in filesystem/vfat.txt
mm: change nr_ptes BUG_ON to WARN_ON
cs5535-clockevt: typo, it's MFGPT, not MFPGT
Pull networking update from David Miller:
"A couple weeks of bug fixing in there. The largest chunk is all the
broken crap Amerigo Wang found in the netpoll layer."
1) netpoll and it's users has several serious bugs:
a) uses GFP_KERNEL with locks held
b) interfaces requiring interrupts disabled are called with them
enabled
c) and vice versa
d) VLAN tag demuxing, as per all other RX packet input paths, is not
applied
All from Amerigo Wang.
2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for
good, from Neal Cardwell.
3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials
when the user doesn't specify one explicitly during sendmsg().
Instead we attach an empty (zero) SCM credential block which is
definitely not what we want. Fix from Eric Dumazet.
4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix
from Ben Hutchings.
5) inet_csk_route_child_sock() checks wrong inet options pointer, fix
from Christoph Paasch.
6) When AF_PACKET is used for transmit, packet loopback doesn't behave
properly when a socket fanout is enabled, from Eric Leblond.
7) On bluetooth l2cap channel create failure, we leak the socket, from
Jaganath Kanakkassery.
8) Fix all the netprio file handling bugs found by Al Viro, from John
Fastabend.
9) Several error return and NULL deref bug fixes in networking drivers
from Julia Lawall.
10) A large smattering of struct padding et al. kernel memory leaks to
userspace found of Mathias Krause.
11) Conntrack expections in netfilter can access an uninitialized timer,
fix from Pablo Neira Ayuso.
12) Several netfilter SIP tracker bug fixes from Patrick McHardy.
13) IPSEC ipv6 routes are not initialized correctly all the time,
resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy.
14) Bridging does rcu_dereference() outside of RCU protected area, from
Stephen Hemminger.
15) Fix routing cache removal performance regression when looking up
output routes that have a local destination. From Zheng Yan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
af_netlink: force credentials passing [CVE-2012-3520]
ipv4: fix ip header ident selection in __ip_make_skb()
ipv4: Use newinet->inet_opt in inet_csk_route_child_sock()
tcp: fix possible socket refcount problem
net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child()
net/core/dev.c: fix kernel-doc warning
netconsole: remove a redundant netconsole_target_put()
net: ipv6: fix oops in inet_putpeer()
net/stmmac: fix issue of clk_get for Loongson1B.
caif: Do not dereference NULL in chnl_recv_cb()
af_packet: don't emit packet on orig fanout group
drivers/net/irda: fix error return code
drivers/net/wan/dscc4.c: fix error return code
drivers/net/wimax/i2400m/fw.c: fix error return code
smsc75xx: add missing entry to MAINTAINERS
net: qmi_wwan: new devices: UML290 and K5006-Z
net: sh_eth: Add eth support for R8A7779 device
netdev/phy: skip disabled mdio-mux nodes
dt: introduce for_each_available_child_of_node, of_get_next_available_child
net: netprio: fix cgrp create and write priomap race
Jim Schutt reported a problem that pointed at compaction contending
heavily on locks. The workload is straight-forward and in his own words;
The systems in question have 24 SAS drives spread across 3 HBAs,
running 24 Ceph OSD instances, one per drive. FWIW these servers
are dual-socket Intel 5675 Xeons w/48 GB memory. I've got ~160
Ceph Linux clients doing dd simultaneously to a Ceph file system
backed by 12 of these servers.
Early in the test everything looks fine
procs -------------------memory------------------ ---swap-- -----io---- --system-- -----cpu-------
r b swpd free buff cache si so bi bo in cs us sy id wa st
31 15 0 287216 576 38606628 0 0 2 1158 2 14 1 3 95 0 0
27 15 0 225288 576 38583384 0 0 18 2222016 203357 134876 11 56 17 15 0
28 17 0 219256 576 38544736 0 0 11 2305932 203141 146296 11 49 23 17 0
6 18 0 215596 576 38552872 0 0 7 2363207 215264 166502 12 45 22 20 0
22 18 0 226984 576 38596404 0 0 3 2445741 223114 179527 12 43 23 22 0
and then it goes to pot
163 8 0 464308 576 36791368 0 0 11 22210 866 536 3 13 79 4 0
207 14 0 917752 576 36181928 0 0 712 1345376 134598 47367 7 90 1 2 0
123 12 0 685516 576 36296148 0 0 429 1386615 158494 60077 8 84 5 3 0
123 12 0 598572 576 36333728 0 0 1107 1233281 147542 62351 7 84 5 4 0
622 7 0 660768 576 36118264 0 0 557 1345548 151394 59353 7 85 4 3 0
223 11 0 283960 576 36463868 0 0 46 1107160 121846 33006 6 93 1 1 0
Note that system CPU usage is very high blocks being written out has
dropped by 42%. He analysed this with perf and found
perf record -g -a sleep 10
perf report --sort symbol --call-graph fractal,5
34.63% [k] _raw_spin_lock_irqsave
|--97.30%-- isolate_freepages
| compaction_alloc
| unmap_and_move
| migrate_pages
| compact_zone
| compact_zone_order
| try_to_compact_pages
| __alloc_pages_direct_compact
| __alloc_pages_slowpath
| __alloc_pages_nodemask
| alloc_pages_vma
| do_huge_pmd_anonymous_page
| handle_mm_fault
| do_page_fault
| page_fault
| |--87.39%-- skb_copy_datagram_iovec
| | tcp_recvmsg
| | inet_recvmsg
| | sock_recvmsg
| | sys_recvfrom
| | system_call
| | __recv
| | --100.00%-- (nil)
| --12.61%-- memcpy
--2.70%-- [...]
There was other data but primarily it is all showing that compaction is
contended heavily on the zone->lock and zone->lru_lock.
commit [b2eef8c0: mm: compaction: minimise the time IRQs are disabled
while isolating pages for migration] noted that it was possible for
migration to hold the lru_lock for an excessive amount of time. Very
broadly speaking this patch expands the concept.
This patch introduces compact_checklock_irqsave() to check if a lock
is contended or the process needs to be scheduled. If either condition
is true then async compaction is aborted and the caller is informed.
The page allocator will fail a THP allocation if compaction failed due
to contention. This patch also introduces compact_trylock_irqsave()
which will acquire the lock only if it is not contended and the process
does not need to schedule.
Reported-by: Jim Schutt <jaschut@sandia.gov>
Tested-by: Jim Schutt <jaschut@sandia.gov>
Fix the following warning:
usr/include/linux/string.h:8: userspace cannot reference function or variable defined in the kernel
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Akinobu Mita <akinobu.mita@gmail.com>
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Pablo Neira Ayuso discovered that avahi and
potentially NetworkManager accept spoofed Netlink messages because of a
kernel bug. The kernel passes all-zero SCM_CREDENTIALS ancillary data
to the receiver if the sender did not provide such data, instead of not
including any such data at all or including the correct data from the
peer (as it is the case with AF_UNIX).
This bug was introduced in commit 16e572626961
(af_unix: dont send SCM_CREDENTIALS by default)
This patch forces passing credentials for netlink, as
before the regression.
Another fix would be to not add SCM_CREDENTIALS in
netlink messages if not provided by the sender, but it
might break some programs.
With help from Florian Weimer & Petr Matousek
This issue is designated as CVE-2012-3520
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
This was originally for helping fabrics to determine overflow/underflow
status, and has been superceeded by SCF_OVERFLOW_BIT + SCF_UNDERFLOW_BIT.
Signed-off-by: Roland Dreier <roland@purestorage.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
- Fixed Nomadik errorpath
- Fixed documentation spelling errors
- Forward-declare struct device in a header file
- Remove some extraneous code lines when getting pinctrl states
- Correct the i.MX51 configure register number
- Fix the Nomadik keypad function group list
* tag 'pinctrl-fixes-v3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
pinctrl/nomadik: add kp_b_2 keyboard function group list
pinctrl: imx51: fix .conf_reg of MX51_PAD_SD2_CMD__CSPI_MOSI
trivial: pinctrl core: remove extraneous code lines
pinctrl: header: trivial: declare struct device
Documentation/pinctrl.txt: Fix some misspelled macros
pinctrl/nomadik: fix null in irqdomain errorpath
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"This update became slightly bigger than usual for rc3, but most of the
commits are small and trivial. A large chunk is found for HD-audio
ca0132 codec, which is mostly a clean up of the specific code, to make
SPDIF working properly, and also in the new ASoC Arizona driver.
One important fix is for usb-audio Oops fix since 3.5. We still see
some EHCI related bandwidth problem, but usb-audio should be more
stabilized now.
Other than that, a Kconfig fix is spread over files, and various
HD-audio and ASoC fixes as usual, in addition to Julia's error path
fixes."
* tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (42 commits)
ALSA: snd-als100: fix suspend/resume
ALSA: hda - Fix leftover codec->power_transition
ALSA: hda - don't create dysfunctional mixer controls for ca0132
ALSA: sound/ppc/snd_ps3.c: fix error return code
ALSA: sound/pci/rme9652/hdspm.c: fix error return code
ALSA: sound/pci/sis7019.c: fix error return code
ALSA: sound/pci/ctxfi/ctatc.c: fix error return code
ALSA: sound/atmel/ac97c.c: fix error return code
ALSA: sound/atmel/abdac.c: fix error return code
ALSA: fix pcm.h kernel-doc warning and notation
sound: oss/sb_audio: prevent divide by zero bug
ASoC: wm9712: Fix inverted capture volume
ASoC: wm9712: Fix microphone source selection
ASoC: wm5102: Remove DRC2
ALSA: hda - Don't send invalid volume knob command on IDT 92hd75bxx
ALSA: usb-audio: Fix scheduling-while-atomic bug in PCM capture stream
ALSA: lx6464es: Add a missing error check
ALSA: hda - Fix 'Beep Playback Switch' with no underlying mute switch
ASoC: jack: Always notify full jack status
ASoC: wm5110: Add missing input PGA routes
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Additional updates for 3.6
A batch more bugfixes, all driver-specific and fairly small and
unremarkable in a global context. The biggest batch are for the newly
added Arizona drivers.
Pull x86 fixes from Ingo Molnar.
A x32 socket ABI fix with a -stable backport tag among other fixes.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x32: Use compat shims for {g,s}etsockopt
Revert "x86-64/efi: Use EFI to deal with platform wall clock"
x86, apic: fix broken legacy interrupts in the logical apic mode
x86, build: Globally set -fno-pic
x86, avx: don't use avx instructions with "noxsave" boot param
Pull a mutex fix from Ingo Molnar.
Fix the fastpath_lock failure contention flag for xchg-based mutexes.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mutex: Place lock in contended state after fastpath_lock failure
Commit 97bab73f (inet: Hide route peer accesses behind helpers.) introduced
a bug in xfrm6_policy_destroy(). The xfrm_dst's _rt6i_peer member is not
initialized, causing a false positive result from inetpeer_ptr_is_peer(),
which in turn causes a NULL pointer dereference in inet_putpeer().
Pid: 314, comm: kworker/0:1 Not tainted 3.6.0-rc1+ #17 To Be Filled By O.E.M. To Be Filled By O.E.M./P4S800D-X
EIP: 0060:[<c03abf93>] EFLAGS: 00010246 CPU: 0
EIP is at inet_putpeer+0xe/0x16
EAX: 00000000 EBX: f3481700 ECX: 00000000 EDX: 000dd641
ESI: f3481700 EDI: c05e949c EBP: f551def4 ESP: f551def4
DS: 007b ES: 007b FS: 0000 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 00000070 CR3: 3243d000 CR4: 00000750
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
f551df04 c0423de1 00000000 f3481700 f551df18 c038d5f7 f254b9f8 f551df28
f34f85d8 f551df20 c03ef48d f551df3c c0396870 f30697e8 f24e1738 c05e98f4
f5509540 c05cd2b4 f551df7c c0142d2b c043feb5 f5509540 00000000 c05cd2e8
[<c0423de1>] xfrm6_dst_destroy+0x42/0xdb
[<c038d5f7>] dst_destroy+0x1d/0xa4
[<c03ef48d>] xfrm_bundle_flo_delete+0x2b/0x36
[<c0396870>] flow_cache_gc_task+0x85/0x9f
[<c0142d2b>] process_one_work+0x122/0x441
[<c043feb5>] ? apic_timer_interrupt+0x31/0x38
[<c03967eb>] ? flow_cache_new_hashrnd+0x2b/0x2b
[<c0143e2d>] worker_thread+0x113/0x3cc
Fix by adding a init_dst() callback to struct xfrm_policy_afinfo to
properly initialize the dst's peer pointer.
Pable Neira Ayuso says:
The following five patches contain fixes for 3.6-rc, they are:
* Two fixes for message parsing in the SIP conntrack helper, from
Patrick McHardy.
* One fix for the SIP helper introduced in the user-space cthelper
infrastructure, from Patrick McHardy.
* fix missing appropriate locking while modifying one conntrack entry
from the nfqueue integration code, from myself.
* fix possible access to uninitiliazed timer in the nf_conntrack
expectation infrastructure, from myself.
If a packet is emitted on one socket in one group of fanout sockets,
it is transmitted again. It is thus read again on one of the sockets
of the fanout group. This result in a loop for software which
generate packets when receiving one.
This retransmission is not the intended behavior: a fanout group
must behave like a single socket. The packet should not be
transmitted on a socket if it originates from a socket belonging
to the same fanout group.
This patch fixes the issue by changing the transmission check to
take fanout group info account.
Reported-by: Aleksandr Kotov <a1k@mail.ru>
Signed-off-by: Eric Leblond <eric@regit.org>
Macro for_each_child_of_node() makes it easy to iterate over all of the
children for a given device tree node, including those nodes that are
marked as unavailable (i.e. status = "disabled").
Introduce for_each_available_child_of_node(), which is like
for_each_child_of_node(), but it automatically skips unavailable nodes.
This also requires the introduction of helper function
of_get_next_available_child(), which returns the next available child
node.
Fix kernel-doc warning in <sound/pcm.h> and add function name to make
the kernel-doc notation complete.
Warning(include/sound/pcm.h:1081): No description found for parameter 'substream'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging fixes from Greg Kroah-Hartman:
"Here are some staging driver fixes (and iio driver fixes, they get
lumped in with the staging stuff due to dependancies) for your 3.6-rc3
tree.
Nothing major, just a bunch of fixes that people have reported.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'staging-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (26 commits)
iio: lm3533-als: Fix build warnings
staging:iio:ad7780: Mark channels as unsigned
staging:iio:ad7192: Report offset and scale for temperature channel
staging:iio:ad7192: Report channel offset
staging:iio:ad7192: Mark channels as unsigned
staging:iio:ad7192: Fix setting ACX
staging:iio:ad7192: Add missing break in switch statement
staging:iio:ad7793: Fix internal reference value
staging:iio:ad7793: Follow new IIO naming spec
staging:iio:ad7793: Fix temperature scale and offset
staging:iio:ad7793: Report channel offset
staging:iio:ad7793: Mark channels as unsigned
staging:iio:ad7793: Add missing break in switch statement
iio/adjd_s311: Fix potential memory leak in adjd_s311_update_scan_mode()
iio: frequency: ADF4350: Fix potential reference div factor overflow.
iio: staging: ad7298_ring: Fix maybe-uninitialized warning
staging: comedi: usbduxfast: Declare MODULE_FIRMWARE usage
staging: comedi: usbdux: Declare MODULE_FIRMWARE usage
staging: comedi: usbduxsigma: Declare MODULE_FIRMWARE usage
staging: csr: add INET dependancy
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bug fixes from Ted Ts'o:
"The following are all bug fixes and regressions. The most notable are
the ones which cause problems for ext4 on RAID --- a performance
problem when mounting very large filesystems, and a kernel OOPS when
doing an rm -rf on large directory hierarchies on fast devices."
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: fix kernel BUG on large-scale rm -rf commands
ext4: fix long mount times on very big file systems
ext4: don't call ext4_error while block group is locked
ext4: avoid kmemcheck complaint from reading uninitialized memory
ext4: make sure the journal sb is written in ext4_clear_journal_err()
As struct device is used as a function argument, it should at
least be declared (device.h is not included).
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
With small channel spacing values and high reference frequencies it is
possible to exceed the range of the 10-bit counter.
Workaround by checking the range and widening some constrains.
We don't use the REG1_PHASE value in this case the datasheet recommends to set
it to 1 if not used.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Pull VFIO fix from Alex Williamson:
"Just a trivial patch to include vfio.h in the installed headers so we
can complete userspace integration into QEMU."
* tag 'vfio-for-v3.6-rc1' of git://github.com/awilliam/linux-vfio:
vfio: Include vfio.h in installed headers
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse updates from Miklos Szeredi.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: verify all ioctl retry iov elements
fuse: add missing INIT flag descriptions
fuse: add missing INIT flags
fuse: update attributes on aio_read
fuse: invalidate inode mapping if mtime changes
fuse: add FUSE_AUTO_INVAL_DATA init flag
llc_station_init() creates and processes an event skb with no effect
other than to change the state from DOWN to UP. Allocation failure is
reported, but then ignored by its caller, llc2_init(). Remove this
possibility by simply initialising the state as UP.
These functions are just boolean, let them return
bool instead of int.
Signed-off-by: Cong Wang <amwang@redhat.com>
Although this doesn't matter actually, because netpoll_tx_running()
doesn't use the parameter, the code will be more readable.
For team_dev_queue_xmit() we have to move it down to avoid
compile errors.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
This patch fixes several problems in the call path of
netpoll_send_skb_on_dev():
1. Disable IRQ's before calling netpoll_send_skb_on_dev().
2. All the callees of netpoll_send_skb_on_dev() should use
rcu_dereference_bh() to dereference ->npinfo.
3. Rename arp_reply() to netpoll_arp_reply(), the former is too generic.
The logic of the code is same, just call netpoll_rx_on().
In __netpoll_rx(), it dereferences ->npinfo without rcu_dereference_bh(),
this patch fixes it by using the 'npinfo' passed from netpoll_rx()
where it is already dereferenced with rcu_dereference_bh().
Like the previous patch, slave_disable_netpoll() and __netpoll_cleanup()
may be called with read_lock() held too, so we should make them
non-block, by moving the cleanup and kfree() to call_rcu_bh() callbacks.
slave_enable_netpoll() and __netpoll_setup() may be called
with read_lock() held, so should use GFP_ATOMIC to allocate
memory. Eric suggested to pass gfp flags to __netpoll_setup().
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This reverts commit bacef661acdb634170a8faddbc1cf28e8f8b9eee.
This commit has been found to cause serious regressions on a number of
ASUS machines at the least. We probably need to provide a 1:1 map in
addition to the EFI virtual memory map in order for this to work.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reported-and-bisected-by: Jérôme Carretero <cJ-ko@zougloub.eu>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: Matthew Garrett <mjg@redhat.com>
Link: http://lkml.kernel.org/r/20120805172903.5f8bb24c@zougloub.eu
"Radeon and intel fixes mostly, one fix to the mgag200 driver to not
hang on certain server variants."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (32 commits)
drm/radeon: fix typo in function header comment
drm/radeon/kms: implement timestamp userspace query (v2)
drm/radeon/kms: add MSAA texture support for r600-evergreen
drm/radeon/kms: reorder code in r600_check_texture_resource
drm/radeon: fence virtual address and free it once idle v4
drm/radeon: fix some missing parens in asic macros
drm/radeon: add some new SI pci ids
drm/radeon: fix ordering in pll picking on dce4+
drm/radeon: do not reenable crtc after moving vram start address
drm/radeon: fix bank tiling parameters on cayman
drm/radeon: fix bank tiling parameters on evergreen
drm/radeon: fix bank tiling parameters on SI
drm/radeon: properly handle crtc powergating
drm/radeon: properly handle SS overrides on TN (v2)
drm/radeon/dce4+: set a more reasonable cursor watermark
drm/radeon: fix handling for ddc type 5 on combios
drm/mgag200: fix G200ER pll picking algorithm
drm/edid: Fix potential memory leak in edid_load()
drm/udl: Use ERR_CAST inlined function instead of ERR_PTR(PTR_ERR(.. [1]
drm/radeon/kms: allow "invalid" DB formats as a means to disable DB
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: <stable@vger.kernel.org>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
Returns a snapshot of the GPU clock counter. Needed
for certain OpenGL extensions.
v2: agd5f
- address Jerome's comments
- add function documentation
Signed-off-by: Marek Olšák <maraeo@gmail.com>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org
Pull networking changes from David Miller:
"Most importantly this should cure the ipv4-mapped ipv6 socket TCP
crashes some people were seeing, otherwise:
1) Fix e1000e autonegotiation handling regression, from Tushar Dave.
2) Fix TX data corruption race on e1000e down, also from Tushar Dave.
3) Fix bfin_sir IRDA driver build, from Sonic Zhang.
4) AF_PACKET mmap() tests a flag in the TX ring shared between
userspace and the kernel for an internal consistency check. It
really shouldn't do this to validate the kernel's own behavior
because the user can corrupt it to be any value at all. From
Daniel Borkmann.
5) Fix TCP metrics leak on netns dismantle, from Eric Dumazet.
6) Orphan the anonymous TCP socket from the SKB in
ip_send_unicast_reply() so that the rest of the stack needn't see
it. Otherwise we get selinux problems of all sorts, from Eric
Dumazet.
This is the best way to fix this since the socket is just a place
holder for sending packets in a context where we have no real
socket at all.
7) Fix TUN detach crashes, from Stanislav Kinsbursky.
8) dev_set_alias() leaks memory on krealloc() failure, from Alexey
Khoroshilov.
9) FIB trie must use call_rcu() not call_rcu_bh(), because this code
is not universally invoked from software interrupts. From Eric
Dumazet.
10) PPTP looks up ipv4 routes with the wrong network namespace, fix
from Gao Feng."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (33 commits)
bnx2x: Fix compiler warnings
af_packet: remove BUG statement in tpacket_destruct_skb
macvtap: rcu_dereference outside read-lock section
codel: refine one condition to avoid a nul rec_inv_sqrt
ixgbe: add missing braces
ipv4: fix ip_send_skb()
net: tcp: ipv6_mapped needs sk_rx_dst_set method
ipv4: tcp: unicast_sock should not land outside of TCP stack
bnx2x: Fix recovery flow cleanup during probe
bnx2x: fix unload previous driver flow when flr-capable
tun: don't zeroize sock->file on detach
igb: Fix register defines for all non-82575 hardware
e1000e: fix panic while dumping packets on Tx hang with IOMMU
igb: fix panic while dumping packets on Tx hang with IOMMU
tcp: must free metrics at net dismantle
net/stmmac: mark probe function as __devinit
lpc_eth: remove obsolete ifdefs
net/core: Fix potential memory leak in dev_set_alias()
cdc-phonet: Don't leak in usbpn_open
batman-adv: Fix mem leak in the batadv_tt_local_event() function
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull a security subsystem fix from James Morris
"This fixes an issue in the Yama LSM"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
Yama: higher restrictions should block PTRACE_TRACEME
Pull power management fixes from Rafael J. Wysocki:
- Fix for two recent regressions in the generic PM domains framework.
- Revert of a commit that introduced a resume regression and is
conceptually incorrect in my opinion.
- Fix for a return value in pcc-cpufreq.c from Julia Lawall.
- RTC wakeup signaling fix from Neil Brown.
- Suppression of compiler warnings for CONFIG_PM_SLEEP unset in ACPI,
platform/x86 and TPM drivers.
* tag 'pm-for-3.6-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
tpm_tis / PM: Fix unused function warning for CONFIG_PM_SLEEP
platform / x86 / PM: Fix unused function warnings for CONFIG_PM_SLEEP
ACPI / PM: Fix unused function warnings for CONFIG_PM_SLEEP
Revert "NMI watchdog: fix for lockup detector breakage on resume"
PM: Make dev_pm_get_subsys_data() always return 0 on success
drivers/cpufreq/pcc-cpufreq.c: fix error return code
RTC: Avoid races between RTC alarm wakeup and suspend.
Pull arm-soc bug fixes from Arnd Bergmann:
"These are a bunch of bug fixes that came in after the merge window and
one update for the MAINTAINERS file.
The largest part of the fixes are patches that address bugs found by
building all the ARM defconfig files. There are a lot more warnings
that we have patches for, but the others are either still under
discussion or are harmless and do not cause actual problems besides
making the build slightly noisy."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (30 commits)
ARM: davinci: remove broken ntosd2_init_i2c
ARM: s3c24xx: enable CONFIG_BUG for tct_hammer
omap-rng: fix use of SIMPLE_DEV_PM_OPS
spi/s3c64xx: improve error handling
mtd/omap2: fix dmaengine_slave_config error handling
gpio: em: do not discard em_gio_irq_domain_cleanup
ARM: exynos: exynos_pm_add_dev_to_genpd may be unused
ARM: imx: gpmi-nand depends on mxs-dma
ARM: integrator: include <linux/export.h>
ARM: s3c24xx: use new PWM driver
ARM: sa1100: include linux/io.h in hackkit leds code
Input: eeti_ts: pass gpio value instead of IRQ
ARM: pxa: remove irq_to_gpio from ezx-pcap driver
ARM: tegra: more regulator fixes for Harmony
usb/ohci-omap: remove unused variable
mfd/asic3: fix asic3_mfd_probe return value
ARM: kirkwood: fix typo in Makefile.boot
i.MX27: Fix emma-prp and csi clocks.
ARM: integrator: use clk_prepare_enable() for timer
MAINTAINERS: update entry for Linus Walleij
One condition before codel_Newton_step() was not good if
we never left the dropping state for a flow. As a result
rec_inv_sqrt was 0, instead of the ~0 initial value.
codel control law was then set to a very aggressive mode, dropping
many packets before reaching 'target' and recovering from this problem.
To keep codel_vars_init() as efficient as possible, refine
the condition to make sure rec_inv_sqrt initial value is correct
Many thanks to Anton Mich for discovering the issue and suggesting
a fix.
Reported-by: Anton Mich <lp2s1h@gmail.com>
ip_send_skb() can send orphaned skb, so we must pass the net pointer to
avoid possible NULL dereference in error path.
Bug added by commit 3a7c384ffd57 (ipv4: tcp: unicast_sock should not
land outside of TCP stack)
The higher ptrace restriction levels should be blocking even
PTRACE_TRACEME requests. The comments in the LSM documentation are
misleading about when the checks happen (the parent does not go through
security_ptrace_access_check() on a PTRACE_TRACEME call).
Cc: stable@vger.kernel.org # 3.5.x and later
Signed-off-by: James Morris <james.l.morris@oracle.com>
Within SIP messages IPv6 addresses are enclosed in square brackets in most
cases, with the exception of the "received=" header parameter. Currently
the helper fails to parse enclosed addresses.
This patch:
- changes the SIP address parsing function to enforce square brackets
when required, and accept them when not required but present, as
recommended by RFC 5118.
- adds a new SDP address parsing function that never accepts square
brackets since SDP doesn't use them.
With these changes, the SIP helper correctly parses all test messages
from RFC 5118 (Session Initiation Protocol (SIP) Torture Test Messages
for Internet Protocol Version 6 (IPv6)).
commit 5d299f3d3c8a2fb (net: ipv6: fix TCP early demux) added a
regression for ipv6_mapped case.
[ 67.422369] SELinux: initialized (dev autofs, type autofs), uses
genfs_contexts
[ 67.449678] SELinux: initialized (dev autofs, type autofs), uses
genfs_contexts
[ 92.631060] BUG: unable to handle kernel NULL pointer dereference at
(null)
[ 92.631435] IP: [< (null)>] (null)
[ 92.631645] PGD 0
[ 92.631846] Oops: 0010 [#1] SMP
[ 92.632095] Modules linked in: autofs4 sunrpc ipv6 dm_mirror
dm_region_hash dm_log dm_multipath dm_mod video sbs sbshc battery ac lp
parport sg snd_hda_intel snd_hda_codec snd_seq_oss snd_seq_midi_event
snd_seq snd_seq_device pcspkr snd_pcm_oss snd_mixer_oss snd_pcm
snd_timer serio_raw button floppy snd i2c_i801 i2c_core soundcore
snd_page_alloc shpchp ide_cd_mod cdrom microcode ehci_hcd ohci_hcd
uhci_hcd
[ 92.634294] CPU 0
[ 92.634294] Pid: 4469, comm: sendmail Not tainted 3.6.0-rc1 #3
[ 92.634294] RIP: 0010:[<0000000000000000>] [< (null)>]
(null)
[ 92.634294] RSP: 0018:ffff880245fc7cb0 EFLAGS: 00010282
[ 92.634294] RAX: ffffffffa01985f0 RBX: ffff88024827ad00 RCX:
0000000000000000
[ 92.634294] RDX: 0000000000000218 RSI: ffff880254735380 RDI:
ffff88024827ad00
[ 92.634294] RBP: ffff880245fc7cc8 R08: 0000000000000001 R09:
0000000000000000
[ 92.634294] R10: 0000000000000000 R11: ffff880245fc7bf8 R12:
ffff880254735380
[ 92.634294] R13: ffff880254735380 R14: 0000000000000000 R15:
7fffffffffff0218
[ 92.634294] FS: 00007f4516ccd6f0(0000) GS:ffff880256600000(0000)
knlGS:0000000000000000
[ 92.634294] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 92.634294] CR2: 0000000000000000 CR3: 0000000245ed1000 CR4:
00000000000007f0
[ 92.634294] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 92.634294] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7:
0000000000000400
[ 92.634294] Process sendmail (pid: 4469, threadinfo ffff880245fc6000,
task ffff880254b8cac0)
[ 92.634294] Stack:
[ 92.634294] ffffffff813837a7 ffff88024827ad00 ffff880254b6b0e8
ffff880245fc7d68
[ 92.634294] ffffffff81385083 00000000001d2680 ffff8802547353a8
ffff880245fc7d18
[ 92.634294] ffffffff8105903a ffff88024827ad60 0000000000000002
00000000000000ff
[ 92.634294] Call Trace:
[ 92.634294] [<ffffffff813837a7>] ? tcp_finish_connect+0x2c/0xfa
[ 92.634294] [<ffffffff81385083>] tcp_rcv_state_process+0x2b6/0x9c6
[ 92.634294] [<ffffffff8105903a>] ? sched_clock_cpu+0xc3/0xd1
[ 92.634294] [<ffffffff81059073>] ? local_clock+0x2b/0x3c
[ 92.634294] [<ffffffff8138caf3>] tcp_v4_do_rcv+0x63a/0x670
[ 92.634294] [<ffffffff8133278e>] release_sock+0x128/0x1bd
[ 92.634294] [<ffffffff8139f060>] __inet_stream_connect+0x1b1/0x352
[ 92.634294] [<ffffffff813325f5>] ? lock_sock_nested+0x74/0x7f
[ 92.634294] [<ffffffff8104b333>] ? wake_up_bit+0x25/0x25
[ 92.634294] [<ffffffff8139f223>] ? inet_stream_connect+0x22/0x4b
[ 92.634294] [<ffffffff8139f234>] inet_stream_connect+0x33/0x4b
[ 92.634294] [<ffffffff8132e8cf>] sys_connect+0x78/0x9e
[ 92.634294] [<ffffffff813fd407>] ? sysret_check+0x1b/0x56
[ 92.634294] [<ffffffff81088503>] ? __audit_syscall_entry+0x195/0x1c8
[ 92.634294] [<ffffffff811cc26e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 92.634294] [<ffffffff813fd3e2>] system_call_fastpath+0x16/0x1b
[ 92.634294] Code: Bad RIP value.
[ 92.634294] RIP [< (null)>] (null)
[ 92.634294] RSP <ffff880245fc7cb0>
[ 92.648982] ---[ end trace 24e2bed94314c8d9 ]---
[ 92.649146] Kernel panic - not syncing: Fatal exception in interrupt
Fix this using inet_sk_rx_dst_set(), and export this function in case
IPv6 is modular.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
