path: root/include
2014-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "A couple of fixes, both -stable fodder. The O_SYNC bug is fairly old..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fix a kmap leak in virtio_console fix O_SYNC|O_APPEND syncing the wrong range on write()
2014-02-09fix O_SYNC|O_APPEND syncing the wrong range on write()Al Viro
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support) when sync_page_range() had been introduced; generic_file_write{,v}() correctly synced pos_after_write - written .. pos_after_write - 1 but generic_file_aio_write() synced pos_before_write .. pos_before_write + written - 1 instead. Which is not the same thing with O_APPEND, obviously. A couple of years later correct variant had been killed off when everything switched to use of generic_file_aio_write(). All users of generic_file_aio_write() are affected, and the same bug has been copied into other instances of ->aio_write(). The fix is trivial; the only subtle point is that generic_write_sync() ought to be inlined to avoid calculations useless for the majority of calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-02-08Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "Quite a varied little collection of fixes. Most of them are relatively small or isolated; the biggest one is Mel Gorman's fixes for TLB range flushing. A couple of AMD-related fixes (including not crashing when given an invalid microcode image) and fix a crash when compiled with gcov" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Unify valid container checks x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y x86/efi: Allow mapping BGRT on x86-32 x86: Fix the initialization of physnode_map x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable() x86/intel/mid: Fix X86_INTEL_MID dependencies arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge x86: mm: change tlb_flushall_shift for IvyBridge x86/mm: Eliminate redundant page table walk during TLB range flushing x86/mm: Clean up inconsistencies when flushing TLB ranges mm, x86: Account for TLB flushes only when debugging x86/AMD/NB: Fix amd_set_subcaches() parameter type x86/quirks: Add workaround for AMD F16h Erratum792 x86, doc, kconfig: Fix dud URL for Microcode data
2014-02-07Merge tag 'efi-urgent' into x86/urgentH. Peter Anvin
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit). Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-06swap: add a simple detector for inappropriate swapin readaheadShaohua Li
This is a patch to improve swap readahead algorithm. It's from Hugh and I slightly changed it. Hugh's original changelog: swapin readahead does a blind readahead, whether or not the swapin is sequential. This may be ok on harddisk, because large reads have relatively small costs, and if the readahead pages are unneeded they can be reclaimed easily - though, what if their allocation forced reclaim of useful pages? But on SSD devices large reads are more expensive than small ones: if the readahead pages are unneeded, reading them in caused significant overhead. This patch adds very simplistic random read detection. Stealing the PageReadahead technique from Konstantin Khlebnikov's patch, avoiding the vma/anon_vma sophistications of Shaohua Li's patch, swapin_nr_pages() simply looks at readahead's current success rate, and narrows or widens its readahead window accordingly. There is little science to its heuristic: it's about as stupid as can be whilst remaining effective. The table below shows elapsed times (in centiseconds) when running a single repetitive swapping load across a 1000MB mapping in 900MB ram with 1GB swap (the harddisk tests had taken painfully too long when I used mem=500M, but SSD shows similar results for that). Vanilla is the 3.6-rc7 kernel on which I started; Shaohua denotes his Sep 3 patch in mmotm and linux-next; HughOld denotes my Oct 1 patch which Shaohua showed to be defective; HughNew this Nov 14 patch, with page_cluster as usual at default of 3 (8-page reads); HughPC4 this same patch with page_cluster 4 (16-page reads); HughPC0 with page_cluster 0 (1-page reads: no readahead). HDD for swapping to harddisk, SSD for swapping to VertexII SSD. Seq for sequential access to the mapping, cycling five times around; Rand for the same number of random touches. Anon for a MAP_PRIVATE anon mapping; Shmem for a MAP_SHARED anon mapping, equivalent to tmpfs. One weakness of Shaohua's vma/anon_vma approach was that it did not optimize Shmem: seen below. Konstantin's approach was perhaps mistuned, 50% slower on Seq: did not compete and is not shown below. HDD Vanilla Shaohua HughOld HughNew HughPC4 HughPC0 Seq Anon 73921 76210 75611 76904 78191 121542 Seq Shmem 73601 73176 73855 72947 74543 118322 Rand Anon 895392 831243 871569 845197 846496 841680 Rand Shmem 1058375 1053486 827935 764955 764376 756489 SSD Vanilla Shaohua HughOld HughNew HughPC4 HughPC0 Seq Anon 24634 24198 24673 25107 21614 70018 Seq Shmem 24959 24932 25052 25703 22030 69678 Rand Anon 43014 26146 28075 25989 26935 25901 Rand Shmem 45349 45215 28249 24268 24138 24332 These tests are, of course, two extremes of a very simple case: under heavier mixed loads I've not yet observed any consistent improvement or degradation, and wider testing would be welcome. Shaohua Li: Test shows Vanilla is slightly better in sequential workload than Hugh's patch. I observed with Hugh's patch sometimes the readahead size is shrinked too fast (from 8 to 1 immediately) in sequential workload if there is no hit. And in such case, continuing doing readahead is good actually. I don't prepare a sophisticated algorithm for the sequential workload because so far we can't guarantee sequential accessed pages are swap out sequentially. So I slightly change Hugh's heuristic - don't shrink readahead size too fast. Here is my test result (unit second, 3 runs average): Vanilla Hugh New Seq 356 370 360 Random 4525 2447 2444 Attached graph is the swapin/swapout throughput I collected with 'vmstat 2'. The first part is running a random workload (till around 1200 of the x-axis) and the second part is running a sequential workload. swapin and swapout throughput are almost identical in steady state in both workloads. These are expected behavior. while in Vanilla, swapin is much bigger than swapout especially in random workload (because wrong readahead). Original patches by: Shaohua Li and Konstantin Khlebnikov. [fengguang.wu@intel.com: swapin_nr_pages() can be static] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-05Merge tag 'stable/for-linus-3.14-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from Konrad Rzeszutek Wilk: "Bug-fixes: - Revert "xen/grant-table: Avoid m2p_override during mapping" as it broke Xen ARM build. - Fix CR4 not being set on AP processors in Xen PVH mode" * tag 'stable/for-linus-3.14-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: set CR4 flags for APs Revert "xen/grant-table: Avoid m2p_override during mapping"
2014-02-05Merge git://git.infradead.org/users/willy/linux-nvmeLinus Torvalds
Pull NVMe driver update from Matthew Wilcox: "Looks like I missed the merge window ... but these are almost all bugfixes anyway (the ones that aren't have been baking for months)" * git://git.infradead.org/users/willy/linux-nvme: NVMe: Namespace use after free on surprise removal NVMe: Correct uses of INIT_WORK NVMe: Include device and queue numbers in interrupt name NVMe: Add a pci_driver shutdown method NVMe: Disable admin queue on init failure NVMe: Dynamically allocate partition numbers NVMe: Async IO queue deletion NVMe: Surprise removal handling NVMe: Abort timed out commands NVMe: Schedule reset for failed controllers NVMe: Device resume error handling NVMe: Cache dev->pci_dev in a local pointer NVMe: Fix lockdep warnings NVMe: compat SG_IO ioctl NVMe: remove deprecated IRQF_DISABLED NVMe: Avoid shift operation when writing cq head doorbell
2014-02-05execve: use 'struct filename *' for executable name passingLinus Torvalds
This changes 'do_execve()' to get the executable name as a 'struct filename', and to free it when it is done. This is what the normal users want, and it simplifies and streamlines their error handling. The controlled lifetime of the executable name also fixes a use-after-free problem with the trace_sched_process_exec tracepoint: the lifetime of the passed-in string for kernel users was not at all obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize the pathname allocation lifetime with the execve() having finished, which in turn meant that the trace point that happened after mm_release() of the old process VM ended up using already free'd memory. To solve the kernel string lifetime issue, this simply introduces "getname_kernel()" that works like the normal user-space getname() function, except with the source coming from kernel memory. As Oleg points out, this also means that we could drop the tcomm[] array from 'struct linux_binprm', since the pathname lifetime now covers setup_new_exec(). That would be a separate cleanup. Reported-by: Igor Zhbanov <i.zhbanov@samsung.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-04Merge tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix NFSv3 acl regressions - Fix NFSv4 memory corruption due to slot table abuse in nfs4_proc_open_confirm - nfs4_destroy_session must call rpc_destroy_waitqueue" * tag 'nfs-for-3.14-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: fs: get_acl() must be allowed to return EOPNOTSUPP NFSv3: Fix return value of nfs3_proc_setacls NFSv3: Remove unused function nfs3_proc_set_default_acl NFSv4.1: nfs4_destroy_session must call rpc_destroy_waitqueue NFSv4: Fix memory corruption in nfs4_proc_open_confirm nfs: fix setting of ACLs on file creation.
2014-02-03Revert "xen/grant-table: Avoid m2p_override during mapping"Konrad Rzeszutek Wilk
This reverts commit 08ece5bb2312b4510b161a6ef6682f37f4eac8a1. As it breaks ARM builds and needs more attention on the ARM side. Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-02Merge branch 'slab/next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull SLAB changes from Pekka Enberg: "Random bug fixes that have accumulated in my inbox over the past few months" * 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: mm: Fix warning on make htmldocs caused by slab.c mm: slub: work around unneeded lockdep warning mm: sl[uo]b: fix misleading comments slub: Fix possible format string bug. slub: use lockdep_assert_held slub: Fix calculation of cpu slabs slab.h: remove duplicate kmalloc declaration and fix kernel-doc warnings
2014-02-01NFSv4: Fix memory corruption in nfs4_proc_open_confirmTrond Myklebust
nfs41_wake_and_assign_slot() relies on the task->tk_msg.rpc_argp and task->tk_msg.rpc_resp always pointing to the session sequence arguments. nfs4_proc_open_confirm tries to pull a fast one by reusing the open sequence structure, thus causing corruption of the NFSv4 slot table. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Several obvious fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Fix mountpoint reference leakage in linkat hfsplus: use xattr handlers for removexattr Typo in compat_sys_lseek() declaration fs/super.c: sync ro remount after blocking writers vfs: unexport the getname() symbol
2014-01-31Merge tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights: - Fix several races in nfs_revalidate_mapping - NFSv4.1 slot leakage in the pNFS files driver - Stable fix for a slot leak in nfs40_sequence_done - Don't reject NFSv4 servers that support ACLs with only ALLOW aces" * tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: initialize the ACL support bits to zero. NFSv4.1: Cleanup NFSv4.1: Clean up nfs41_sequence_done NFSv4: Fix a slot leak in nfs40_sequence_done NFSv4.1 free slot before resending I/O to MDS nfs: add memory barriers around NFS_INO_INVALID_DATA and NFS_INO_INVALIDATING NFS: Fix races in nfs_revalidate_mapping sunrpc: turn warn_gssd() log message into a dprintk() NFS: fix the handling of NFS_INO_INVALID_DATA flag in nfs_revalidate_mapping nfs: handle servers that support only ALLOW ACE type.
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-31Typo in compat_sys_lseek() declarationStephan Springl
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-31Merge tag 'pm+acpi-3.14-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes and cleanups from Rafael Wysocki: - ACPI device hotplug fix preventing ACPI drivers from binding to device objects that acpi_bus_trim() has been called for and the devices represented by them may not be operational. - Recent cpufreq changes related to the "boost" (turbo) feature broke the acpi-cpufreq error code path causing a NULL pointer dereference to occur on some systems. Fix from Konrad Rzeszutek Wilk. - The log level of a CPU initialization error message added recently needs to be reduced, because the particular BIOS issue indicated by it turns out to be widespread and doesn't really matter for the majority of systems having it. From Jiang Liu. - The regulator API needs to be told to stay away from things on systems with ACPI BIOSes or it may conflict with the BIOS' own handling of voltage regulators. Fix from Mark Brown that works around a 3.13 regression in lm90 on PCs occuring if the regulator API is enabled. - Prevent the Exynos4 devfreq driver from being built on multiplatform, because it depends on things that aren't available during such builds. From Sachin Kamat. - Upstream ACPICA doesn't use the bool type as defined in the kernel, so modify the kernel's ACPICA code to follow the upstream in that respect (only one variable definition is affected) to reduce divergences between the two. From Lv Zheng. - Make the ACPI device PM code use ACPI_COMPANION() instead of its own routine doing the same thing (and invokng ACPI_COMPANION() in the process). - Modify some routines in the ACPI processor driver to follow the common convention and return negative integers on errors. From Hanjun Guo. * tag 'pm+acpi-3.14-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / scan: Clear match_driver flag in acpi_bus_trim() ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API acpi-cpufreq: De-register CPU notifier and free struct msr on error. ACPICA: Remove bool usage from ACPICA. PM / devfreq: Disable Exynos4 driver build on multiplatform ACPI / PM: Use ACPI_COMPANION() to get ACPI companions of devices ACPI / scan: reduce log level of "ACPI: \_PR_.CPU4: failed to get CPU APIC ID" ACPI / processor: Return specific error value when mapping lapic id
2014-01-31Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer/dynticks updates from Ingo Molnar: "This tree contains misc dynticks updates: a fix and three cleanups" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/nohz: Fix overflow error in scheduler_tick_max_deferment() nohz_full: fix code style issue of tick_nohz_full_stop_tick nohz: Get timekeeping max deferment outside jiffies_lock tick: Rename tick_check_idle() to tick_irq_enter()
2014-01-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core debug changes from Ingo Molnar: "This contains mostly kernel debugging related updates: - make hung_task detection more configurable to distros - add final bits for x86 UV NMI debugging, with related KGDB changes - update the mailing-list of MAINTAINERS entries I'm involved with" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hung_task: Display every hung task warning sysctl: Add neg_one as a standard constraint x86/uv/nmi, kgdb/kdb: Fix UV NMI handler when KDB not configured x86/uv/nmi: Fix Sparse warnings kgdb/kdb: Fix no KDB config problem MAINTAINERS: Restore "L: linux-kernel@vger.kernel.org" entries
2014-01-31Merge tag 'stable/for-linus-3.14-rc0-late-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "Bug-fixes for the new features that were added during this cycle. There are also two fixes for long-standing issues for which we have a solution: grant-table operations extra work that was not needed causing performance issues and the self balloon code was too aggressive causing OOMs. Details: - Xen ARM couldn't use the new FIFO events - Xen ARM couldn't use the SWIOTLB if compiled as 32-bit with 64-bit PCIe devices. - Grant table were doing needless M2P operations. - Ratchet down the self-balloon code so it won't OOM. - Fix misplaced kfree in Xen PVH error code paths" * tag 'stable/for-linus-3.14-rc0-late-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: Fix misplaced kfree from xlated_setup_gnttab_pages drivers: xen: deaggressive selfballoon driver xen/grant-table: Avoid m2p_override during mapping xen/gnttab: Use phys_addr_t to describe the grant frame base address xen: swiotlb: handle sizeof(dma_addr_t) != sizeof(phys_addr_t) arm/xen: Initialize event channels earlier
2014-01-31xen/grant-table: Avoid m2p_override during mappingZoltan Kiss
The grant mapping API does m2p_override unnecessarily: only gntdev needs it, for blkback and future netback patches it just cause a lock contention, as those pages never go to userspace. Therefore this series does the following: - the original functions were renamed to __gnttab_[un]map_refs, with a new parameter m2p_override - based on m2p_override either they follow the original behaviour, or just set the private flag and call set_phys_to_machine - gnttab_[un]map_refs are now a wrapper to call __gnttab_[un]map_refs with m2p_override false - a new function gnttab_[un]map_refs_userspace provides the old behaviour It also removes a stray space from page.h and change ret to 0 if XENFEAT_auto_translated_physmap, as that is the only possible return value there. v2: - move the storing of the old mfn in page->index to gnttab_map_refs - move the function header update to a separate patch v3: - a new approach to retain old behaviour where it needed - squash the patches into one v4: - move out the common bits from m2p* functions, and pass pfn/mfn as parameter - clear page->private before doing anything with the page, so m2p_find_override won't race with this v5: - change return value handling in __gnttab_[un]map_refs - remove a stray space in page.h - add detail why ret = 0 now at some places v6: - don't pass pfn to m2p* functions, just get it locally Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Suggested-by: David Vrabel <david.vrabel@citrix.com> Acked-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-31mm: sl[uo]b: fix misleading commentsDave Hansen
On x86, SLUB creates and handles <=8192-byte allocations internally. It passes larger ones up to the allocator. Saying "up to order 2" is, at best, ambiguous. Is that order-1? Or (order-2 bytes)? Make it more clear. SLOB commits a similar sin. It *handles* page-size requests, but the comment says that it passes up "all page size and larger requests". SLOB also swaps around the order of the very-similarly-named KMALLOC_SHIFT_HIGH and KMALLOC_SHIFT_MAX #defines. Make it consistent with the order of the other two allocators. Cc: Matt Mackall <mpm@selenic.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2014-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs updates from Chris Mason: "This is a pretty big pull, and most of these changes have been floating in btrfs-next for a long time. Filipe's properties work is a cool building block for inheriting attributes like compression down on a per inode basis. Jeff Mahoney kicked in code to export filesystem info into sysfs. Otherwise, lots of performance improvements, cleanups and bug fixes. Looks like there are still a few other small pending incrementals, but I wanted to get the bulk of this in first" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (149 commits) Btrfs: fix spin_unlock in check_ref_cleanup Btrfs: setup inode location during btrfs_init_inode_locked Btrfs: don't use ram_bytes for uncompressed inline items Btrfs: fix btrfs_search_slot_for_read backwards iteration Btrfs: do not export ulist functions Btrfs: rework ulist with list+rb_tree Btrfs: fix memory leaks on walking backrefs failure Btrfs: fix send file hole detection leading to data corruption Btrfs: add a reschedule point in btrfs_find_all_roots() Btrfs: make send's file extent item search more efficient Btrfs: fix to catch all errors when resolving indirect ref Btrfs: fix protection between walking backrefs and root deletion btrfs: fix warning while merging two adjacent extents Btrfs: fix infinite path build loops in incremental send btrfs: undo sysfs when open_ctree() fails Btrfs: fix snprintf usage by send's gen_unique_name btrfs: fix defrag 32-bit integer overflow btrfs: sysfs: list the NO_HOLES feature btrfs: sysfs: don't show reserved incompat feature btrfs: call permission checks earlier in ioctls and return EPERM ...
2014-01-30Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "A few hotfixes and various leftovers which were awaiting other merges. Mainly movement of zram into mm/" * emailed patches fron Andrew Morton <akpm@linux-foundation.org>: (25 commits) memcg: fix mutex not unlocked on memcg_create_kmem_cache fail path Documentation/filesystems/vfs.txt: update file_operations documentation mm, oom: base root bonus on current usage mm: don't lose the SOFT_DIRTY flag on mprotect mm/slub.c: fix page->_count corruption (again) mm/mempolicy.c: fix mempolicy printing in numa_maps zram: remove zram->lock in read path and change it with mutex zram: remove workqueue for freeing removed pending slot zram: introduce zram->tb_lock zram: use atomic operation for stat zram: remove unnecessary free zram: delay pending free request in read path zram: fix race between reset and flushing pending work zsmalloc: add maintainers zram: add zram maintainers zsmalloc: add copyright zram: add copyright zram: remove old private project comment zram: promote zram from staging zsmalloc: move it under mm ...
2014-01-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The most notable new addition inside this pull request is the support for MIPS's latest and greatest core called "inter/proAptiv". The patch series describes this core as follows. "The interAptiv is a power-efficient multi-core microprocessor for use in system-on-chip (SoC) applications. The interAptiv combines a multi-threading pipeline with a coherence manager to deliver improved computational throughput and power efficiency. The interAptiv can contain one to four MIPS32R3 interAptiv cores, system level coherence manager with L2 cache, optional coherent I/O port, and optional floating point unit." The platform specific patches touch all 3 Broadcom families. It adds support for the new Broadcom/Netlogix XLP9xx Soc, building a common BCM63XX SMP kernel for all BCM63XX SoCs regardless of core type/count and full gpio button/led descriptions for BCM47xx. The rest of the series are cleanups and bug fixes that are MIPS generic and consist largely of changes that Imgtec/MIPS had published in their linux-mti-3.10.git stable tree. Random other cleanups and patches preparing code to be merged in 3.15" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) mips: select ARCH_MIGHT_HAVE_PC_SERIO mips: delete non-required instances of include <linux/init.h> MIPS: KVM: remove shadow_tlb code MIPS: KVM: use common EHINV aware UNIQUE_ENTRYHI mips/ide: flush dcache also if icache does not snoop dcache MIPS: BCM47XX: fix position of cpu_wait disabling MIPS: BCM63XX: select correct MIPS_L1_CACHE_SHIFT value MIPS: update MIPS_L1_CACHE_SHIFT based on MIPS_L1_CACHE_SHIFT_<N> MIPS: introduce MIPS_L1_CACHE_SHIFT_<N> MIPS: ZBOOT: gather string functions into string.c arch/mips/pci: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource bcma: gpio: don't cast u32 to unsigned long ssb: gpio: add own IRQ domain MIPS: BCM47XX: fix sparse warnings in board.c MIPS: BCM47XX: add board detection for Linksys WRT54GS V1 MIPS: BCM47XX: fix detection for some boards MIPS: BCM47XX: Enable buttons support on SSB MIPS: BCM47XX: Convert WNDR4500 to new syntax MIPS: BCM47XX: Use "timer" trigger for status LEDs ...
2014-01-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull more powerpc bits from Ben Herrenschmidt: "Here are a few more powerpc bits for this merge window. The bulk is made of two pull requests from Scott and Anatolij that I had missed previously (they arrived while I was away). Since both their branches are in -next independently, and the content has been around for a little while, they can still go in. The rest is mostly bug and regression fixes, a small series of cleanups to our pseries cpuidle code (including moving it to the right place), and one new cpuidle bakend for the powernv platform. I also wired up the new sched_attr syscalls" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (37 commits) powerpc: Wire up sched_setattr and sched_getattr syscalls powerpc/hugetlb: Replace __get_cpu_var with get_cpu_var powerpc: Make sure "cache" directory is removed when offlining cpu powerpc/mm: Fix mmap errno when MAP_FIXED is set and mapping exceeds the allowed address space powerpc/powernv/cpuidle: Back-end cpuidle driver for powernv platform. powerpc/pseries/cpuidle: smt-snooze-delay cleanup. powerpc/pseries/cpuidle: Remove MAX_IDLE_STATE macro. powerpc/pseries/cpuidle: Make cpuidle-pseries backend driver a non-module. powerpc/pseries/cpuidle: Use cpuidle_register() for initialisation. powerpc/pseries/cpuidle: Move processor_idle.c to drivers/cpuidle. powerpc: Fix 32-bit frames for signals delivered when transactional powerpc/iommu: Fix initialisation of DART iommu table powerpc/numa: Fix decimal permissions powerpc/mm: Fix compile error of pgtable-ppc64.h powerpc: Fix hw breakpoints on !HAVE_HW_BREAKPOINT configurations clk: corenet: Adds the clock binding powerpc/booke64: Guard e6500 tlb handler with CONFIG_PPC_FSL_BOOK3E powerpc/512x: dts: add MPC5125 clock specs powerpc/512x: clk: support MPC5121/5123/5125 SoC variants powerpc/512x: clk: enforce even SDHC divider values ...
2014-01-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - fix make -s detection with make-4.0 - fix for scripts/setlocalversion when the kernel repository is a submodule - do not hardcode ';' in macros that expand to assembler code, as some architectures' assemblers use a different character for newline - Fix passing --gdwarf-2 to the assembler * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: frv: Remove redundant debugging info flag mn10300: Remove redundant debugging info flag kbuild: Fix debugging info generation for .S files arch: use ASM_NL instead of ';' for assembler new line character in the macro kbuild: Fix silent builds with make-4 Fix detectition of kernel git repository in setlocalversion script [take #2]
2014-01-30zsmalloc: add copyrightMinchan Kim
Add my copyright to the zsmalloc source code which I maintain. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30zsmalloc: move it under mmMinchan Kim
This patch moves zsmalloc under mm directory. Before that, description will explain why we have needed custom allocator. Zsmalloc is a new slab-based memory allocator for storing compressed pages. It is designed for low fragmentation and high allocation success rate on large object, but <= PAGE_SIZE allocations. zsmalloc differs from the kernel slab allocator in two primary ways to achieve these design goals. zsmalloc never requires high order page allocations to back slabs, or "size classes" in zsmalloc terms. Instead it allows multiple single-order pages to be stitched together into a "zspage" which backs the slab. This allows for higher allocation success rate under memory pressure. Also, zsmalloc allows objects to span page boundaries within the zspage. This allows for lower fragmentation than could be had with the kernel slab allocator for objects between PAGE_SIZE/2 and PAGE_SIZE. With the kernel slab allocator, if a page compresses to 60% of it original size, the memory savings gained through compression is lost in fragmentation because another object of the same size can't be stored in the leftover space. This ability to span pages results in zsmalloc allocations not being directly addressable by the user. The user is given an non-dereferencable handle in response to an allocation request. That handle must be mapped, using zs_map_object(), which returns a pointer to the mapped region that can be used. The mapping is necessary since the object data may reside in two different noncontigious pages. The zsmalloc fulfills the allocation needs for zram perfectly [sjenning@linux.vnet.ibm.com: borrow Seth's quote] Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Nitin Gupta <ngupta@vflare.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Hugh Dickins <hughd@google.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pekka Enberg <penberg@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30kernel: use lockless list for smp_call_function_singleChristoph Hellwig
Make smp_call_function_single and friends more efficient by using a lockless list. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30memblock, bootmem: restore goal for alloc_lowYinghai Lu
Now we have memblock_virt_alloc_low to replace original bootmem api in swiotlb. But we should not use BOOTMEM_LOW_LIMIT for arch that does not support CONFIG_NOBOOTMEM, as old api take 0. | #define alloc_bootmem_low(x) \ | __alloc_bootmem_low(x, SMP_CACHE_BYTES, 0) |#define alloc_bootmem_low_pages_nopanic(x) \ | __alloc_bootmem_low_nopanic(x, PAGE_SIZE, 0) and we have #define BOOTMEM_LOW_LIMIT __pa(MAX_DMA_ADDRESS) for CONFIG_NOBOOTMEM. Restore goal to 0 to fix ia64 crash, that Tony found. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Reported-by: Tony Luck <tony.luck@gmail.com> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30Merge branch 'for-3.14/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO driver changes from Jens Axboe: - bcache update from Kent Overstreet. - two bcache fixes from Nicholas Swenson. - cciss pci init error fix from Andrew. - underflow fix in the parallel IDE pg_write code from Dan Carpenter. I'm sure the 1 (or 0) users of that are now happy. - two PCI related fixes for sx8 from Jingoo Han. - floppy init fix for first block read from Jiri Kosina. - pktcdvd error return miss fix from Julia Lawall. - removal of IRQF_SHARED from the SEGA Dreamcast CD-ROM code from Michael Opdenacker. - comment typo fix for the loop driver from Olaf Hering. - potential oops fix for null_blk from Raghavendra K T. - two fixes from Sam Bradshaw (Micron) for the mtip32xx driver, fixing an OOM problem and a problem with handling security locked conditions * 'for-3.14/drivers' of git://git.kernel.dk/linux-block: (47 commits) mg_disk: Spelling s/finised/finished/ null_blk: Null pointer deference problem in alloc_page_buffers mtip32xx: Correctly handle security locked condition mtip32xx: Make SGL container per-command to eliminate high order dma allocation drivers/block/loop.c: fix comment typo in loop_config_discard drivers/block/cciss.c:cciss_init_one(): use proper errnos drivers/block/paride/pg.c: underflow bug in pg_write() drivers/block/sx8.c: remove unnecessary pci_set_drvdata() drivers/block/sx8.c: use module_pci_driver() floppy: bail out in open() if drive is not responding to block0 read bcache: Fix auxiliary search trees for key size > cacheline size bcache: Don't return -EINTR when insert finished bcache: Improve bucket_prio() calculation bcache: Add bch_bkey_equal_header() bcache: update bch_bkey_try_merge bcache: Move insert_fixup() to btree_keys_ops bcache: Convert sorting to btree_keys bcache: Convert debug code to btree_keys bcache: Convert btree_iter to struct btree_keys bcache: Refactor bset_tree sysfs stats ...
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-30Merge branch 'for-3.14' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: - Handle some loose ends from the vfs read delegation support. (For example nfsd can stop breaking leases on its own in a fewer places where it can now depend on the vfs to.) - Make life a little easier for NFSv4-only configurations (thanks to Kinglong Mee). - Fix some gss-proxy problems (thanks Jeff Layton). - miscellaneous bug fixes and cleanup * 'for-3.14' of git://linux-nfs.org/~bfields/linux: (38 commits) nfsd: consider CLAIM_FH when handing out delegation nfsd4: fix delegation-unlink/rename race nfsd4: delay setting current_fh in open nfsd4: minor nfs4_setlease cleanup gss_krb5: use lcm from kernel lib nfsd4: decrease nfsd4_encode_fattr stack usage nfsd: fix encode_entryplus_baggage stack usage nfsd4: simplify xdr encoding of nfsv4 names nfsd4: encode_rdattr_error cleanup nfsd4: nfsd4_encode_fattr cleanup minor svcauth_gss.c cleanup nfsd4: better VERIFY comment nfsd4: break only delegations when appropriate NFSD: Fix a memory leak in nfsd4_create_session sunrpc: get rid of use_gssp_lock sunrpc: fix potential race between setting use_gss_proxy and the upcall rpc_clnt sunrpc: don't wait for write before allowing reads from use-gss-proxy file nfsd: get rid of unused function definition Define op_iattr for nfsd4_open instead using macro NFSD: fix compile warning without CONFIG_NFSD_V3 ...
2014-01-30xen/gnttab: Use phys_addr_t to describe the grant frame base addressJulien Grall
On ARM, address size can be 32 bits or 64 bits (if CONFIG_ARCH_PHYS_ADDR_T_64BIT is enabled). We can't assume that the grant frame base address will always fits in an unsigned long. Use phys_addr_t instead of unsigned long as argument for gnttab_setup_auto_xlat_frames. Signed-off-by: Julien Grall <julien.grall@linaro.org> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-01-30target: Fix percpu_ref_put race in transport_lun_remove_cmdNicholas Bellinger
This patch fixes a percpu_ref_put race for se_lun->lun_ref in transport_lun_remove_cmd() where ->lun_ref could end up being put more than once per command via different target completion and fabric release contexts. It adds a cmpxchg() for se_cmd->lun_ref_active to ensure that percpu_ref_put() is only ever called once per se_cmd. This bug was manifesting itself as a LUN shutdown regression bug in >= v3.13 code, where percpu_ref_kill() would end up hanging indefinately due to the incorrect percpu_ref count. (Change se_cmd->lun_ref_active from bool -> int to force at least a 4-byte cmpxchg with MIPS ll/sc ins. - Fengguang) Reported-by: Tommy Apel <tommyapeldk@gmail.com> Cc: Tommy Apel <tommyapeldk@gmail.com> Cc: <stable@vger.kernel.org> #3.13+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-01-29Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Been a bit busy, first week of kids school, and waiting on other trees to go in before I could send this, so its a bit later than I'd normally like. Highlights: - core: timestamp fixes, lots of misc cleanups - new drivers: bochs virtual vga - vmwgfx: major overhaul for their nextgen virt gpu. - i915: runtime D3 on HSW, watermark fixes, power well work, fbc fixes, bdw is no longer prelim. - nouveau: gk110/208 acceleration, more pm groundwork, old overlay support - radeon: dpm rework and clockgating for CIK, pci config reset, big endian fixes - tegra: panel support and DSI support, build as module, prime. - armada, omap, gma500, rcar, exynos, mgag200, cirrus, ast: fixes - msm: hdmi support for mdp5" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (595 commits) drm/nouveau: resume display if any later suspend bits fail drm/nouveau: fix lock unbalance in nouveau_crtc_page_flip drm/nouveau: implement hooks for needed for drm vblank timestamping support drm/nouveau/disp: add a method to fetch info needed by drm vblank timestamping drm/nv50: fill in crtc mode struct members from crtc_mode_fixup drm/radeon/dce8: workaround for atom BlankCrtc table drm/radeon/DCE4+: clear bios scratch dpms bit (v2) drm/radeon: set si_notify_smc_display_change properly drm/radeon: fix DAC interrupt handling on DCE5+ drm/radeon: clean up active vram sizing drm/radeon: skip async dma init on r6xx drm/radeon/runpm: don't runtime suspend non-PX cards drm/radeon: add ring to fence trace functions drm/radeon: add missing trace point drm/radeon: fix VMID use tracking drm: ast,cirrus,mgag200: use drm_can_sleep drm/gma500: Lock struct_mutex around cursor updates drm/i915: Fix the offset issue for the stolen GEM objects DRM: armada: fix missing DRM_KMS_FB_HELPER select drm/i915: Decouple GPU error reporting from ring initialisation ...
2014-01-29Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dma updates from Vinod Koul: - new driver for BCM2835 used in R-pi - new driver for MOXA ART - dma_get_any_slave_channel API for DT based systems - minor fixes and updates spread acrooss driver [ The fsl-ssi dual fifo mode support addition clashed badly with the other changes to fsl-ssi that came in through the sound merge. I did a very rough cut at fixing up the conflict, but Nicolin Chen (author of both sides) will need to verify and check things ] * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (36 commits) dmaengine: mmp_pdma: fix mismerge dma: pl08x: Export pl08x_filter_id acpi-dma: align documentation with kernel-doc format dma: fix vchan_cookie_complete() debug print DMA: dmatest: extend the "device" module parameter to 32 characters drivers/dma: fix error return code dma: omap: Set debug level to debugging messages dmaengine: fix kernel-doc style typos for few comments dma: tegra: add support for Tegra148/124 dma: dw: use %pad instead of casting dma_addr_t dma: dw: join split up messages dma: dw: fix style of multiline comment dmaengine: k3dma: fix sparse warnings dma: pl330: Use dma_get_slave_channel() in the of xlate callback dma: pl330: Differentiate between submitted and issued descriptors dmaengine: sirf: Add device_slave_caps interface DMA: Freescale: change BWC from 256 bytes to 1024 bytes dmaengine: Add MOXA ART DMA engine driver dmaengine: Add DMA_PRIVATE to BCM2835 driver dma: imx-sdma: Assign a default script number for ROM firmware cases ...
2014-01-29Merge tag 'iommu-updates-v3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU Updates from Joerg Roedel: "A few patches have been queued up for this merge window: - improvements for the ARM-SMMU driver (IOMMU_EXEC support, IOMMU group support) - updates and fixes for the shmobile IOMMU driver - various fixes to generic IOMMU code and the Intel IOMMU driver - some cleanups in IOMMU drivers (dev_is_pci() usage)" * tag 'iommu-updates-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (36 commits) iommu/vt-d: Fix signedness bug in alloc_irte() iommu/vt-d: free all resources if failed to initialize DMARs iommu/vt-d, trivial: clean sparse warnings iommu/vt-d: fix wrong return value of dmar_table_init() iommu/vt-d: release invalidation queue when destroying IOMMU unit iommu/vt-d: fix access after free issue in function free_dmar_iommu() iommu/vt-d: keep shared resources when failed to initialize iommu devices iommu/vt-d: fix invalid memory access when freeing DMAR irq iommu/vt-d, trivial: simplify code with existing macros iommu/vt-d, trivial: use defined macro instead of hardcoding iommu/vt-d: mark internal functions as static iommu/vt-d, trivial: clean up unused code iommu/vt-d, trivial: check suitable flag in function detect_intel_iommu() iommu/vt-d, trivial: print correct domain id of static identity domain iommu/vt-d, trivial: refine support of 64bit guest address iommu/vt-d: fix resource leakage on error recovery path in iommu_init_domains() iommu/vt-d: fix a race window in allocating domain ID for virtual machines iommu/vt-d: fix PCI device reference leakage on error recovery path drm/msm: Fix link error with !MSM_IOMMU iommu/vt-d: use dedicated bitmap to track remapping entry allocation status ...
2014-01-29Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull more i2c updates from Wolfram Sang: "Mostly bugfixes, small but wanted cleanups, and Paul's init.h removal applied" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: rcar: fix NACK error code i2c: update i2c_algorithm documentation i2c: rcar: use devm_clk_get to ensure clock is properly ref-counted i2c: rcar: do not print error if device nacks transfer i2c: rely on driver core when sanitizing devices i2c: delete non-required instances of include <linux/init.h> i2c: acorn: is tristate and should use module.h i2c: piix4: Standardize log messages i2c: piix4: Use different message for AMD Auxiliary SMBus Controller i2c: piix4: Add support for AMD ML and CZ SMBus changes
2014-01-29Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon updates from Jean Delvare: "This include it87 driver improvements, and a tree-wide change of my e-mail address" * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: Update Jean Delvare's e-mail address hwmon: (it87) Print proper names for the IT8771E and IT8772E hwmon: (it87) Add support for the ITE IT8603E
2014-01-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more x32 uabi type fixes from Peter Anvin: "Despite the branch name, **most of these changes are to generic code**. They change types so that they make an increasing amount of the exported uapi kernel headers usable for libc. The ARM64 people are also interested in these changes for their ILP32 ABI" * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: uapi: Use __kernel_long_t in struct mq_attr uapi: Use __kernel_ulong_t in shmid64_ds/shminfo64/shm_info x86, uapi, x32: Use __kernel_ulong_t in x86 struct semid64_ds uapi: Use __kernel_ulong_t in struct msqid64_ds uapi: Use __kernel_long_t in struct msgbuf uapi, asm-generic: Use __kernel_ulong_t in uapi struct ipc64_perm uapi: Use __kernel_long_t/__kernel_ulong_t in <linux/resource.h> uapi: Use __kernel_long_t in struct timex
2014-01-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several fixups, of note: 1) Fix unlock of not held spinlock in RXRPC code, from Alexey Khoroshilov. 2) Call pci_disable_device() from the correct shutdown path in bnx2x driver, from Yuval Mintz. 3) Fix qeth build on s390 for some configurations, from Eugene Crosser. 4) Cure locking bugs in bond_loadbalance_arp_mon(), from Ding Tianhong. 5) Must do netif_napi_add() before registering netdevice in sky2 driver, from Stanislaw Gruszka. 6) Fix lost bug fix during merge due to code movement in ieee802154, noticed and fixed by the eagle eyed Stephen Rothwell. 7) Get rid of resource leak in xen-netfront driver, from Annie Li. 8) Bounds checks in qlcnic driver are off by one, from Manish Chopra. 9) TPROXY can leak sockets when TCP early demux is enabled, fix from Holger Eitzenberger" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) qeth: fix build of s390 allmodconfig bonding: fix locking in bond_loadbalance_arp_mon() tun: add device name(iff) field to proc fdinfo entry DT: net: davinci_emac: "ti, davinci-no-bd-ram" property is actually optional DT: net: davinci_emac: "ti, davinci-rmii-en" property is actually optional bnx2x: Fix generic option settings net: Fix warning on make htmldocs caused by skbuff.c llc: remove noisy WARN from llc_mac_hdr_init qlcnic: Fix loopback test failure qlcnic: Fix tx timeout. qlcnic: Fix initialization of vlan list. qlcnic: Correct off-by-one errors in bounds checks net: Document promote_secondaries net: gre: use icmp_hdr() to get inner ip header i40e: Add missing braces to i40e_dcb_need_reconfig() xen-netfront: fix resource leak in netfront net: 6lowpan: fixup for code movement hyperv: Add support for physically discontinuous receive buffer sky2: initialize napi before registering device net: Fix memory leak if TPROXY used with TCP early demux ...
2014-01-29Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge random fixes from Andrew Morton: "Random fixes. I have one batch remaining for -rc1, mainly zram changes which await a merge of Jens's trees" * emailed patches fron Andrew Morton akpm@linux-foundation.org>: MAINTAINERS: ADI Linux development mailing lists: change to the new server Documentation: fix multiple typo occurences s/KenelVersion/KernelVersion/ dma-debug: fix overlap detection memblock: add limit checking to memblock_virt_alloc mm/readahead.c: fix do_readahead() for no readpage(s) mm/slub.c: do not VM_BUG_ON_PAGE() for temporary on-stack pages slab: fix wrong retval on kmem_cache_create_memcg error path s390/compat: change parameter types from unsigned long to compat_ulong_t fs/compat: fix lookup_dcookie() parameter handling fs/compat: fix parameter handling for compat readv/writev syscalls mm/mempolicy.c: convert to pr_foo() mm: numa: initialise numa balancing after jump label initialisation mm/page-writeback.c: do not count anon pages as dirtyable memory mm/page-writeback.c: fix dirty_balance_reserve subtraction from dirtyable memory mm: document improved handling of swappiness==0 lib/genalloc.c: add check gen_pool_dma_alloc() if dma pointer is not NULL
2014-01-29fs/compat: fix lookup_dcookie() parameter handlingHeiko Carstens
Commit d5dc77bfeeab ("consolidate compat lookup_dcookie()") coverted all architectures to the new compat_sys_lookup_dcookie() syscall. The "len" paramater of the new compat syscall must have the type compat_size_t in order to enforce zero extension for architectures where the ABI requires that the caller of a function performed zero and/or sign extension to 64 bit of all parameters. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <stable@vger.kernel.org> [v3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29fs/compat: fix parameter handling for compat readv/writev syscallsHeiko Carstens
We got a report that the pwritev syscall does not work correctly in compat mode on s390. It turned out that with commit 72ec35163f9f ("switch compat readv/writev variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a couple of syscall parameters because the some parameter types haven't been converted from unsigned long to compat_ulong_t. This is needed for architectures where the ABI requires that the caller of a function performed zero and/or sign extension to 64 bit of all parameters. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <stable@vger.kernel.org> [v3.10+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29mm/page-writeback.c: do not count anon pages as dirtyable memoryJohannes Weiner
The VM is currently heavily tuned to avoid swapping. Whether that is good or bad is a separate discussion, but as long as the VM won't swap to make room for dirty cache, we can not consider anonymous pages when calculating the amount of dirtyable memory, the baseline to which dirty_background_ratio and dirty_ratio are applied. A simple workload that occupies a significant size (40+%, depending on memory layout, storage speeds etc.) of memory with anon/tmpfs pages and uses the remainder for a streaming writer demonstrates this problem. In that case, the actual cache pages are a small fraction of what is considered dirtyable overall, which results in an relatively large portion of the cache pages to be dirtied. As kswapd starts rotating these, random tasks enter direct reclaim and stall on IO. Only consider free pages and file pages dirtyable. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: Tejun Heo <tj@kernel.org> Tested-by: Tejun Heo <tj@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2014-01-29fsnotify: Do not return merged event from fsnotify_add_notify_event()Jan Kara
The event returned from fsnotify_add_notify_event() cannot ever be used safely as the event may be freed by the time the function returns (after dropping notification_mutex). So change the prototype to just return whether the event was added or merged into some existing event. Reported-and-tested-by: Jiri Kosina <jkosina@suse.cz> Reported-and-tested-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Jan Kara <jack@suse.cz>
