path: root/include
2006-08-06S390: fix futex_atomic_cmpxchg_inatomicMartin Schwidefsky
[S390] fix futex_atomic_cmpxchg_inatomic futex_atomic_cmpxchg_inatomic has the same bug as the other atomic futex operations: the operation needs to be done in the user address space, not the kernel address space. Add the missing sacf 256 & sacf 0. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06ext3: avoid triggering ext3_error on bad NFS file handleNeil Brown
The inode number out of an NFS file handle gets passed eventually to ext3_get_inode_block() without any checking. If ext3_get_inode_block() allows it to trigger an error, then bad filehandles can have unpleasant effect - ext3_error() will usually cause a forced read-only remount, or a panic if `errors=panic' was used. So remove the call to ext3_error there and put a matching check in ext3/namei.c where inode numbers are read off storage. [akpm@osdl.org: fix off-by-one error] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Eric Sandeen <esandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06Sparc64 quad-float emulation fixDavid Miller
[SPARC64]: Fix quad-float multiply emulation. Something is wrong with the 3-multiply (vs. 4-multiply) optimized version of _FP_MUL_MEAT_2_*(), so just use the slower version which actually computes correct values. Noticed by Rene Rebe Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06Update frag_list in pskb_trimHerbert Xu
[NET]: Update frag_list in pskb_trim When pskb_trim has to defer to ___pksb_trim to trim the frag_list part of the packet, the frag_list is not updated to reflect the trimming. This will usually work fine until you hit something that uses the packet length or tail from the frag_list. Examples include esp_output and ip_fragment. Another problem caused by this is that you can end up with a linear packet with a frag_list attached. It is possible to get away with this if we audit everything to make sure that they always consult skb->len before going down onto frag_list. In fact we can do the samething for the paged part as well to avoid copying the data area of the skb. For now though, let's do the conservative fix and update frag_list. Many thanks to Marco Berizzi for helping me to track down this bug. This 4-year old bug took 3 months to track down. Marco was very patient indeed :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-24Suppress irq handler mismatch messages in ALSA ISA driversTakashi Iwai
Suppress 'irq handler mismatch' messages at auto-probing of irqs in ALSA ISA drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-29[PATCH] libata: minor patch for ATA_DFLAG_PIOTejun Heo
Problem: - With 2.6.17 libata, some PIO-only devices are given DMA commands. Changes: - Do not clear the ATA_DFLAG_PIO flag in ata_dev_configure(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] x86: compile fix for asm-i386/alternatives.hKirill Smelkov
compile fix: <asm-i386/alternative.h> needs <asm/types.h> for 'u8' -- just look at struct alt_instr. My module includes <asm/bitops.h> as the first header, and as of 2.6.17 this leads to compilation errors. Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] SCTP: Reject sctp packets with broadcast addresses.Vlad Yasevich
Make SCTP handle broadcast properly Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-29[PATCH] PFKEYV2: Fix inconsistent typing in struct sadb_x_kmprivate.Tushar Gohad
Fixes inconsistent use of "uint32_t" vs. "u_int32_t". Fix pfkeyv2 userspace builds. Signed-off-by: Tushar Gohad <tgohad@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-17[PATCH] powerpc: enable CPU_FTR_CI_LARGE_PAGE for cellArnd Bergmann
Reflect the fact that the Cell Broadband Engine supports 64k pages by adding the bit to the CPU features. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] Fix Integrator and Versatile interrupt initialisation [ARM] 3546/1: PATCH: subtle lost interrupts bug on i.MX [ARM] 3547/1: PXA-OHCI: Allow platforms to specify a power budget [ARM] Fix Neponset IRQ handling
2006-06-11[PATCH] PCI: fix pciehp compile issue when CONFIG_ACPI is not enabledakpm@osdl.org
Fix build error when CONFIG_ACPI not defined Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-10[PATCH] I2O: Bugfixes to get I2O working againMarkus Lidel
From: Markus Lidel <Markus.Lidel@shadowconnect.com> - Fixed locking of struct i2o_exec_wait in Executive-OSM - Removed LCT Notify in i2o_exec_probe() which caused freeing memory and accessing freed memory during first enumeration of I2O devices - Added missing locking in i2o_exec_lct_notify() - removed put_device() of I2O controller in i2o_iop_remove() which caused the controller structure get freed to early - Fixed size of mempool in i2o_iop_alloc() - Fixed access to freed memory in i2o_msg_get() See http://bugzilla.kernel.org/show_bug.cgi?id=6561 Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-08[PATCH] s390: fix in-user atomic futex operation.Martin Schwidefsky
From: Martin Schwidefsky <schwidefsky@de.ibm.com> __futex_atomic_op needs to do an atomic operation in the user address space, not the kernel address space. Add the missing sacf 256/sacf 0 to switch to the secondary mode before doing the compare-and-swap. In addition add another fixup for catch specification exceptions if the compare-and-swap address is not aligned. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-08[PATCH] elevator switching raceJens Axboe
There's a race between shutting down one io scheduler and firing up the next, in which a new io could enter and cause the io scheduler to be invoked with bad or NULL data. To fix this, we need to maintain the queue lock for a bit longer. Unfortunately we cannot do that, since the elevator init requires to be run without the lock held. This isn't easily fixable, without also changing the mempool API. So split the initialization into two parts, and alloc-init operation and an attach operation. Then we can preallocate the io scheduler and related structures, and run the attach inside the lock after we detach the old one. This patch has survived 30 minutes of 1 second io scheduler switching with a very busy io load. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-08[PATCH] Fix mempolicy.h build errorRalf Baechle
From: Ralf Baechle <ralf@linux-mips.org> <linux/mempolicy.h> uses struct mm_struct and relies on a definition or declaration somehow magically being dragged in which may result in a build: [...] CC mm/mempolicy.o In file included from mm/mempolicy.c:69: include/linux/mempolicy.h:150: warning: ‘struct mm_struct’ declared inside parameter list include/linux/mempolicy.h:150: warning: its scope is only this definition or declaration, which is probably not what you want include/linux/mempolicy.h:175: warning: ‘struct mm_struct’ declared inside parameter list mm/mempolicy.c:622: error: conflicting types for ‘do_migrate_pages’ include/linux/mempolicy.h:175: error: previous declaration of ‘do_migrate_pages’ was here mm/mempolicy.c:1661: error: conflicting types for ‘mpol_rebind_mm’ include/linux/mempolicy.h:150: error: previous declaration of ‘mpol_rebind_mm’ was here make[1]: *** [mm/mempolicy.o] Error 1 make: *** [mm] Error 2 [ralf@denk linux-ip35]$ Including <linux/sched.h> is a step into direction of include hell so fixed by adding a forward declaration of struct mm_struct instead. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-08[ARM] 3547/1: PXA-OHCI: Allow platforms to specify a power budgetRichard Purdie
Patch from Richard Purdie Add a power budget variable to the PXA OHCI platform data and add a default value for the spitz platform(s) which prevents known failures with certain USB devices. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-05Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-serial: [SERIAL] typo: buad -> baud
2006-06-06[MIPS] Fix sparsemem support.Chad Reese
Move memory_present() in arch/mips/kernel/setup.c. When using sparsemem extreme, this function does an allocate for bootmem. This would always fail since init_bootmem hasn't been called yet. Move memory_present after free_bootmem. This only marks actual memory ranges as present instead of the entire address space. Signed-off-by: Chad Reese <creese@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix 64-bit build for RM7000.Ralf Baechle
RM7000 has 40-bit virtual / 36-bit physical address space. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix non-linear memory mapping on MIPSSergei Shtylyov
Fix the non-linear memory mapping done via remap_file_pages() -- it didn't work on any MIPS CPU because the page offset clashing with _PAGE_FILE and some other page protection bits which should have been left zeros for this kind of pages. Signed-off-by: Konstantin Baydarov <kbaidarov@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix swap entry for MIPS32 36-bit physical addressSergei Shtylyov
With 64-bit physical address enabled, 'swapon' was causing kernel oops on Alchemy CPUs (MIPS32) because of the swap entry type field corrupting the _PAGE_FILE bit in 'pte_low' field. So, switch to storing the swap entry in 'pte_high' field using all its bits except _PAGE_GLOBAL and _PAGE_VALID which gives 25 bits for the swap entry offset. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix mprotect() syscall for MIPS32 w/36-bit physical address supportSergei Shtylyov
Fix mprotect() syscall for MIPS32 CPUs with 36-bit physical address support: pte_modify() macro didn't clear the hardware page protection bits before modifying... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix declaration of smp_prepare_cpus() platform hook.Ralf Baechle
A while ago prom_prepare_cpus was replaced by plat_prepare_cpus but the declaration has stayed unchanged. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix instable BogoMIPS on multi-issue processors.Ralf Baechle
Increase alignment of BogoMIPS loop to 8 bytes. Having the delay loop overlap cache line boundaries may cause instable delays. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Remove duplicate declaration of cpu_online_map.Ralf Baechle
2006-06-05[PATCH] uml: more __user annotationsAl Viro
From: Al Viro <viro@zeniv.linux.org.uk> uml __user annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] uml: add asm/irqflags.hJeff Dike
From: Jeff Dike <jdike@addtoit.com> Add an empty asm/irqflags.h, which seems to satisfy the lock validator enough that UML builds. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] m48t86: ia64 build fixAndrew Morton
From: Andrew Morton <akpm@osdl.org> drivers/rtc/rtc-m48t86.c: In function `m48t86_rtc_read_time': drivers/rtc/rtc-m48t86.c:51: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:55: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:56: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:57: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:58: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:60: error: structure has no member named `ia64_mv' readb() and writeb() are macros on ia64. Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] alpha: SMP IRQ routing fixIvan Kokshaysky
From: Ivan Kokshaysky <ink@jurassic.park.msu.ru> After removal of fixup_cpu_present_map() function Alpha ended up with an empty cpu_present_map, so secondary CPUs on SMP systems are not being started. Worse, on some platforms we route interrupts to secondary CPUs using cpu_possible_map which is still populated properly. As a result, these interrupts go nowhere so the machines like DP264 aren't able to boot even with a primary CPU. Fixed basically by s/cpu_present_mask/cpu_present_map/. Thanks to Ernst Herzberg for reporting the bug and testing the fix. Cc: Ernst Herzberg <list-lkml@net4u.de> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] Sparsemem build fixRalf Baechle
From: Ralf Baechle <ralf@linux-mips.org> <linux/mmzone.h> uses PAGE_SIZE, PAGE_SHIFT from <asm/page.h> without including that header itself. For some sparsemem configurations this may result in build errors like: CC init/initramfs.o In file included from include/linux/gfp.h:4, from include/linux/slab.h:15, from include/linux/percpu.h:4, from include/linux/rcupdate.h:41, from include/linux/dcache.h:10, from include/linux/fs.h:226, from init/initramfs.c:2: include/linux/mmzone.h:498:22: warning: "PAGE_SHIFT" is not defined In file included from include/linux/gfp.h:4, from include/linux/slab.h:15, from include/linux/percpu.h:4, from include/linux/rcupdate.h:41, from include/linux/dcache.h:10, from include/linux/fs.h:226, from init/initramfs.c:2: include/linux/mmzone.h:526: error: `PAGE_SIZE' undeclared here (not in a function) include/linux/mmzone.h: In function `__pfn_to_section': include/linux/mmzone.h:573: error: `PAGE_SHIFT' undeclared (first use in this function) include/linux/mmzone.h:573: error: (Each undeclared identifier is reported only once include/linux/mmzone.h:573: error: for each function it appears in.) include/linux/mmzone.h: In function `pfn_valid': include/linux/mmzone.h:578: error: `PAGE_SHIFT' undeclared (first use in this function) make[1]: *** [init/initramfs.o] Error 1 make: *** [init] Error 2 Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Seems-reasonable-to: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] s390: cio non-unique path group idsPeter Oberparleiter
From: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> The path grouping can fail due to non-unique pathgroup-IDs. The source for the CPU-ID part of the ID was incorrectly specified on 64 bit systems. Additionally, the length of the ID was too large due to incorrect data packing declaration. Fix CPU-ID lowcore address and add missing packing declaration. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[SERIAL] typo: buad -> baudHorst Schirmeier
Replacing mistyped "buad" with "baud" where applicable. Signed-off-by: Horst Schirmeier <horst@schirmeier.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-02Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3540/1: ixp23xx: deal with gap in interrupt bitmasks [ARM] 3539/1: ixp23xx: fix __arch_ixp23xx_is_coherent() for A1 stepping
2006-06-02Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Fix D-cache corruption in mremap [SPARC64]: Make smp_processor_id() functional before start_kernel()
2006-06-02[ARM] 3539/1: ixp23xx: fix __arch_ixp23xx_is_coherent() for A1 steppingLennert Buytenhek
Patch from Lennert Buytenhek The current __ixp23xx_arch_is_coherent() check assumes that the lower byte of IXP23XX_PRODUCT_ID is identical to the lower byte of processor_id, but this is not the case, and because of this we were incorrectly enabling coherency on A1 stepping CPUs. Stepping A1 of the ixp2350, which has a PRODUCT_ID of 0x401, has '02' in the lower byte of processor_id, while A2, with a PRODUCT_ID of 0x402, has '04' in the lower byte of processor_id. So, to check for >= A2, we really need to check the lower byte of processor_id against >= 4. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-01[SPARC64]: Fix D-cache corruption in mremapDavid S. Miller
If we move a mapping from one virtual address to another, and this changes the virtual color of the mapping to those pages, we can see corrupt data due to D-cache aliasing. Check for and deal with this by overriding the move_pte() macro. Set things up so that other platforms can cleanly override the move_pte() macro too. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-31Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Treat R14000 like R10000. [MIPS] Remove EXPERIMENTAL from PAGE_SIZE_16KB [MIPS] Update/Fix instruction definitions [MIPS] DSP and MDMX share the same config flag bit. [MIPS] Fix deadlock on MP with cache aliases. [MIPS] Use generic STABS_DEBUG macro. [MIPS] Create consistency in "system type" selection. [MIPS] Use generic DWARF_DEBUG [MIPS] Fix kgdb exception handler from user mode. [MIPS] Update struct sigcontext member names [MIPS] Update/fix futex assembly [MIPS] Remove support for sysmips(2) SETNAME and MIPS_RDNVRAM operations. [MIPS] Fix detection and handling of the 74K processor. [MIPS] Add missing 34K processor IDs [MIPS] Fix marking buddy of pte global for MIPS32 w/36-bit physical address [MIPS] AU1xxx mips_timer_interrupt() fixes [MIPS] Fix typo
2006-06-01[MIPS] Treat R14000 like R10000.Kumba
Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Update/Fix instruction definitionsThiemo Seufer
A small bugfix for up to now unused instruction definitions, and a somewhat larger update to cover MIPS32R2 instructions. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] DSP and MDMX share the same config flag bit.Thiemo Seufer
Clarify comment. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Update struct sigcontext member namesDaniel Jacobowitz
Rename the 64-bit sc_hi and sc_lo arrays to use the same names as the 32-bit struct sigcontext (sc_mdhi, sc_hi1, et cetera). Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Update/fix futex assemblyRalf Baechle
o Implement futex_atomic_op_inuser() operation o Don't use the R10000-ll/sc bug workaround version for every processor. branch likely is deprecated and some historic ll/sc processors don't implement it. In any case it's slow. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Fix detection and handling of the 74K processor.Chris Dearman
Nothing exciting; Linux just didn't know it yet so this is most adding a value to a case statement. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Fix marking buddy of pte global for MIPS32 w/36-bit physical addressSergei Shtylyov
In case of CONFIG_64BIT_PHYS_ADDR, set_pte() and pte_clear() functions only set _PAGE_GLOBAL bit in the pte_low field of the buddy PTEs, forgetting to propagate ito to pte_high. Thus, the both pages might not really be made global for the CPU (since it AND's the G-bit of the odd / even PTEs together to decide whether they're global or not). Thus, if only a single page is allocated via vmalloc() or ioremap(), it's not really global for CPU (and it must be, since this is kernel mapping), and thus its ASID is compared against the current process' one -- so, we'll get into trouble sooner or later... Also, pte_none() will fail on global pages because _PAGE_GLOBAL bit is set in both pte_low and pte_high, and pte_val() will return u64 value consisting of those fields concateneted. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-05-31[PATCH] ARM: Fix XScale PMD settingDeepak Saxena
The ARM Architecture Reference Manual lists bit 4 of the PMD as "implementation defined" and it must be set to zero on Intel XScale CPUs or the cache does not behave properly. Found by Mike Rapoport while debugging a flash issue on the PXA255: http://marc.10east.com/?l=linux-arm-kernel&m=114845287600782&w=1 Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] net/compat.h build fixAndrew Morton
From: Andrew Morton <akpm@osdl.org> Move the forward decl outside the ifdef, since we use it in both legs. Should fix the spacr64 build error reported in http://bugzilla.kernel.org/show_bug.cgi?id=6625 Acked-by: "David S. Miller" <davem@davemloft.net> Cc: Cedric Pellerin <cedric@bidouillesoft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] revert "swsusp add check for suspension of X controlled devices"Andrew Morton
From: Andrew Morton <akpm@osdl.org> Revert commit ff4da2e262d2509fe1bacff70dd00934be569c66. It broke APM suspend, probably because APM doesn't switch back to a VT when suspending. Tracked down by Matt Mackall <mpm@selenic.com> Rafael sayeth: "It only fixed the theoretical issue that a quick-handed user could switch to X after processes have been frozen and before the devices are suspended. With the current userland suspend tools it shouldn't be necessary." Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Fix stack/mmap randomization for compat tasksAndi Kleen
ia32_setup_arg_pages would ignore the passed in random stack top and use its own static value. Now it uses the 8bit of randomness native i386 would use too. This indirectly fixes mmap randomization for 32bit processes too, which depends on the stack randomization. Should also give slightly better virtual cache colouring and possibly better performance with HyperThreading. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] VIA PT880 Ultra support. [AGPGART] Fix Nforce3 suspend on amd64. [AGPGART] Enable SIS AGP driver on x86-64 for EM64T systems
