path: root/include
2014-06-21Merge tag 'locks-v3.16-2' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking fixes from Jeff Layton: "File locking related bugfixes Nothing too earth-shattering here. A fix for a potential regression due to a patch in pile #1, and the addition of a memory barrier to prevent a race condition between break_deleg and generic_add_lease" * tag 'locks-v3.16-2' of git://git.samba.org/jlayton/linux: locks: set fl_owner for leases back to current->files locks: add missing memory barrier in break_deleg
2014-06-21Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This is larger than usual: the main reason are the ARM symbol lookup speedups that came in late and were hard to resist. There's also a kprobes fix and various tooling fixes, plus the minimal re-enablement of the mmap2 support interface" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits) x86/kprobes: Fix build errors and blacklist context_track_user perf tests: Add test for closing dso objects on EMFILE error perf tests: Add test for caching dso file descriptors perf tests: Allow reuse of test_file function perf tests: Spawn child for each test perf tools: Add dso__data_* interface descriptons perf tools: Allow to close dso fd in case of open failure perf tools: Add file size check and factor dso__data_read_offset perf tools: Cache dso data file descriptor perf tools: Add global count of opened dso objects perf tools: Add global list of opened dso objects perf tools: Add data_fd into dso object perf tools: Separate dso data related variables perf tools: Cache register accesses for unwind processing perf record: Fix to honor user freq/interval properly perf timechart: Reflow documentation perf probe: Improve error messages in --line option perf probe: Improve an error message of perf probe --vars mode perf probe: Show error code and description in verbose mode perf probe: Improve error message for unknown member of data structure ...
2014-06-19Merge tag 'pm+acpi-3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are fixes mostly (ia64 regression related to the ACPI enumeration of devices, cpufreq regressions, fix for I2C controllers included in Intel SoCs, mvebu cpuidle driver fix related to sysfs) plus additional kernel command line arguments from Kees to make it possible to build kernel images with hibernation and the kernel address space randomization included simultaneously, a new ACPI battery driver quirk for a system with a broken BIOS and a couple of ACPI core cleanups. Specifics: - Fix for an ia64 regression introduced during the 3.11 cycle by a commit that modified the hardware initialization ordering and made device discovery fail on some systems. - Fix for a build problem on systems where the cpufreq-cpu0 driver is built-in and the cpu-thermal driver is modular from Arnd Bergmann. - Fix for a recently introduced computational mistake in the intel_pstate driver that leads to excessive rounding errors from Doug Smythies. - Fix for a failure code path in cpufreq_update_policy() that fails to unlock the locks acquired previously from Aaron Plattner. - Fix for the cpuidle mvebu driver to use shorter state names which will prevent the sysfs interface from returning mangled strings. From Gregory Clement. - ACPI LPSS driver fix to make sure that the I2C controllers included in BayTrail SoCs are not held in the reset state while they are being probed from Mika Westerberg. - New kernel command line arguments making it possible to build kernel images with hibernation and kASLR included at the same time and to select which of them will be used via the command line (they are still functionally mutually exclusive, though). From Kees Cook. - ACPI battery driver quirk for Acer Aspire V5-573G that fails to send battery status change notifications timely from Alexander Mezin. - Two ACPI core cleanups from Christoph Jaeger and Fabian Frederick" * tag 'pm+acpi-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpuidle: mvebu: Fix the name of the states cpufreq: unlock when failing cpufreq_update_policy() intel_pstate: Correct rounding in busy calculation ACPI: use kstrto*() instead of simple_strto*() ACPI / processor replace __attribute__((packed)) by __packed ACPI / battery: add quirk for Acer Aspire V5-573G ACPI / battery: use callback for setting up quirks ACPI / LPSS: Take I2C host controllers out of reset x86, kaslr: boot-time selectable with hibernation PM / hibernate: introduce "nohibernate" boot parameter cpufreq: cpufreq-cpu0: fix CPU_THERMAL dependency ACPI / ia64 / sba_iommu: Restore the working initialization ordering
2014-06-19Merge tag 'sound-3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "The significant part here is a few security fixes for ALSA core control API by Lars. Besides that, there are a few fixes for ASoC sigmadsp (again by Lars) for building properly, and small fixes for ASoC rsnd, MMP, PXA and FSL, in addition to a fix for bogus WARNING in i915/HD-audio binding" * tag 'sound-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: control: Make sure that id->index does not overflow ALSA: control: Handle numid overflow ALSA: control: Don't access controls outside of protected regions ALSA: control: Fix replacing user controls ALSA: control: Protect user controls against concurrent access drm/i915, HD-audio: Don't continue probing when nomodeset is given ASoC: fsl: Fix build problem ASoC: rsnd: fixup index of src/dst mod when capture ASoC: fsl_spdif: Fix integer overflow when calculating divisors ASoC: fsl_spdif: Fix incorrect usage of regmap_read() ASoC: dapm: Make sure register value is in sync with DAPM kcontrol state ASoC: sigmadsp: Split regmap and I2C support into separate modules ASoC: MMP audio needs sram support ASoC: pxa: add I2C dependencies as needed
2014-06-19Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A smaller collection of fixes for the block core that would be nice to have in -rc2. This pull request contains: - Fixes for races in the wait/wakeup logic used in blk-mq from Alexander. No issues have been observed, but it is definitely a bit flakey currently. Alternatively, we may drop the cyclic wakeups going forward, but that needs more testing. - Some cleanups from Christoph. - Fix for an oops in null_blk if queue_mode=1 and softirq completions are used. From me. - A fix for a regression caused by the chunk size setting. It inadvertently used max_hw_sectors instead of max_sectors, which is incorrect, and causes hangs on btrfs multi-disk setups (where hw sectors apparently isn't set). From me. - Removal of WQ_POWER_EFFICIENT in the kblockd creation. This was a recent addition as well, but it actually breaks blk-mq which relies on strict scheduling. If the workqueue power_efficient mode is turned on, this breaks blk-mq. From Matias. - null_blk module parameter description fix from Mike" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: bitmap tag: fix races in bt_get() function blk-mq: bitmap tag: fix race on blk_mq_bitmap_tags::wake_cnt blk-mq: bitmap tag: fix races on shared ::wake_index fields block: blk_max_size_offset() should check ->max_sectors null_blk: fix softirq completions for queue_mode == 1 blk-mq: merge blk_mq_drain_queue and __blk_mq_drain_queue blk-mq: properly drain stopped queues block: remove WQ_POWER_EFFICIENT from kblockd null_blk: fix name and description of 'queue_mode' module parameter block: remove elv_abort_queue and blk_abort_flushes
2014-06-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-nextLinus Torvalds
Pull sparc fixes from David Miller: "Sparc sparse fixes from Sam Ravnborg" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (67 commits) sparc64: fix sparse warnings in int_64.c sparc64: fix sparse warning in ftrace.c sparc64: fix sparse warning in kprobes.c sparc64: fix sparse warning in kgdb_64.c sparc64: fix sparse warnings in compat_audit.c sparc64: fix sparse warnings in init_64.c sparc64: fix sparse warnings in aes_glue.c sparc: fix sparse warnings in smp_32.c + smp_64.c sparc64: fix sparse warnings in perf_event.c sparc64: fix sparse warnings in kprobes.c sparc64: fix sparse warning in tsb.c sparc64: clean up compat_sigset_t.seta handling sparc64: fix sparse "Should it be static?" warnings in signal32.c sparc64: fix sparse warnings in sys_sparc32.c sparc64: fix sparse warning in pci.c sparc64: fix sparse warnings in smp_64.c sparc64: fix sparse warning in prom_64.c sparc64: fix sparse warning in btext.c sparc64: fix sparse warnings in sys_sparc_64.c + unaligned_64.c sparc64: fix sparse warning in process_64.c ... Conflicts: arch/sparc/include/asm/pgtable_64.h
2014-06-19Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: x86, kaslr: boot-time selectable with hibernation PM / hibernate: introduce "nohibernate" boot parameter
2014-06-18Merge branch 'topic/core-vuln-fixes' into for-linusTakashi Iwai
2014-06-18ALSA: control: Protect user controls against concurrent accessLars-Peter Clausen
The user-control put and get handlers as well as the tlv do not protect against concurrent access from multiple threads. Since the state of the control is not updated atomically it is possible that either two write operations or a write and a read operation race against each other. Both can lead to arbitrary memory disclosure. This patch introduces a new lock that protects user-controls from concurrent access. Since applications typically access controls sequentially than in parallel a single lock per card should be fine. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-17blk-mq: bitmap tag: fix races on shared ::wake_index fieldsAlexander Gordeev
Fix racy updates of shared blk_mq_bitmap_tags::wake_index and blk_mq_hw_ctx::wake_index fields. Cc: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-06-17block: blk_max_size_offset() should check ->max_sectorsJens Axboe
Commit 762380ad9322 inadvertently changed a check for max_sectors to max_hw_sectors. Revert that part, so we still compare against max_sectors. Signed-off-by: Jens Axboe <axboe@fb.com>
2014-06-17ACPI / processor replace __attribute__((packed)) by __packedFabian Frederick
This patch fixes checkpatch warnings: "WARNING: __packed is preferred over __attribute__((packed))" Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-16PM / hibernate: introduce "nohibernate" boot parameterKees Cook
To support using kernel features that are not compatible with hibernation, this creates the "nohibernate" kernel boot parameter to disable both hibernation and resume. This allows hibernation support to be a boot-time choice instead of only a compile-time choice. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-16Merge remote-tracking branch 'regulator/fix/core' into regulator-linusMark Brown
2014-06-16drm/i915, HD-audio: Don't continue probing when nomodeset is givenTakashi Iwai
When a machine is booted with nomodeset option, i915 driver skips the whole initialization. Meanwhile, HD-audio tries to bind wth i915 just by request_symbol() without knowing that the initialization was skipped, and eventually it hits WARN_ON() in i915_request_power_well() and i915_release_power_well() wrongly but still continues probing, even though it doesn't work at all. In this patch, both functions are changed to return an error in case of uninitialized state instead of WARN_ON(), so that HD-audio driver can give up HDMI controller initialization at the right time. Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: <stable@vger.kernel.org> [3.15] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix checksumming regressions, from Tom Herbert. 2) Undo unintentional permissions changes for SCTP rto_alpha and rto_beta sysfs knobs, from Denial Borkmann. 3) VXLAN, like other IP tunnels, should advertize it's encapsulation size using dev->needed_headroom instead of dev->hard_header_len. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: sctp: fix permissions for rto_alpha and rto_beta knobs vxlan: Checksum fixes net: add skb_pop_rcv_encapsulation udp: call __skb_checksum_complete when doing full checksum net: Fix save software checksum complete net: Fix GSO constants to match NETIF flags udp: ipv4: do not waste time in __udp4_lib_mcast_demux_lookup vxlan: use dev->needed_headroom instead of dev->hard_header_len MAINTAINERS: update cxgb4 maintainer
2014-06-15Merge tag 'clk-for-linus-3.16-part2' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull more clock framework updates from Mike Turquette: "This contains the second half the of the clk changes for 3.16. They are simply fixes and code refactoring for the OMAP clock drivers. The sunxi clock driver changes include splitting out the one mega-driver into several smaller pieces and adding support for the A31 SoC clocks" * tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits) clk: sunxi: document PRCM clock compatible strings clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support clk: sun6i: Protect SDRAM gating bit clk: sun6i: Protect CPU clock clk: sunxi: Rework clock protection code clk: sunxi: Move the GMAC clock to a file of its own clk: sunxi: Move the 24M oscillator to a file of its own clk: sunxi: Remove calls to clk_put clk: sunxi: document new A31 USB clock compatible clk: sunxi: Implement A31 USB clock ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC) CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic) dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock CLK: TI: gate: add composite interface clock to OMAP2 only build ARM: OMAP2: clock: add DT boot support for cpufreq_ck CLK: TI: OMAP2: add clock init support ...
2014-06-15Merge git://git.infradead.org/users/willy/linux-nvmeLinus Torvalds
Pull NVMe update from Matthew Wilcox: "Mostly bugfixes again for the NVMe driver. I'd like to call out the exported tracepoint in the block layer; I believe Keith has cleared this with Jens. We've had a few reports from people who're really pounding on NVMe devices at scale, hence the timeout changes (and new module parameters), hotplug cpu deadlock, tracepoints, and minor performance tweaks" [ Jens hadn't seen that tracepoint thing, but is ok with it - it will end up going away when mq conversion happens ] * git://git.infradead.org/users/willy/linux-nvme: (22 commits) NVMe: Fix START_STOP_UNIT Scsi->NVMe translation. NVMe: Use Log Page constants in SCSI emulation NVMe: Define Log Page constants NVMe: Fix hot cpu notification dead lock NVMe: Rename io_timeout to nvme_io_timeout NVMe: Use last bytes of f/w rev SCSI Inquiry NVMe: Adhere to request queue block accounting enable/disable NVMe: Fix nvme get/put queue semantics NVMe: Delete NVME_GET_FEAT_TEMP_THRESH NVMe: Make admin timeout a module parameter NVMe: Make iod bio timeout a parameter NVMe: Prevent possible NULL pointer dereference NVMe: Fix the buffer size passed in GetLogPage(CDW10.NUMD) NVMe: Update data structures for NVMe 1.2 NVMe: Enable BUILD_BUG_ON checks NVMe: Update namespace and controller identify structures to the 1.1a spec NVMe: Flush with data support NVMe: Configure support for block flush NVMe: Add tracepoints NVMe: Protect against badly formatted CQEs ...
2014-06-15net: add skb_pop_rcv_encapsulationTom Herbert
This function is used by UDP encapsulation protocols in RX when crossing encapsulation boundary. If ip_summed is set to CHECKSUM_UNNECESSARY and encapsulation is not set, change to CHECKSUM_NONE since the checksum has not been validated within the encapsulation. Clears csum_valid by the same rationale. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-15udp: call __skb_checksum_complete when doing full checksumTom Herbert
In __udp_lib_checksum_complete check if checksum is being done over all the data (len is equal to skb->len) and if it is call __skb_checksum_complete instead of __skb_checksum_complete_head. This allows checksum to be saved in checksum complete. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-15net: Fix GSO constants to match NETIF flagsTom Herbert
Joseph Gasparakis reported that VXLAN GSO offload stopped working with i40e device after recent UDP changes. The problem is that the SKB_GSO_* bits are out of sync with the corresponding NETIF flags. This patch fixes that. Also, we add BUILD_BUG_ONs in net_gso_ok for several GSO constants that were missing to avoid the problem in the future. Reported-by: Joseph Gasparakis <joseph.gasparakis@intel.com> Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull more btrfs updates from Chris Mason: "This has a few fixes since our last pull and a new ioctl for doing btree searches from userland. It's very similar to the existing ioctl, but lets us return larger items back down to the app" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: fix error handling in create_pending_snapshot btrfs: fix use of uninit "ret" in end_extent_writepage() btrfs: free ulist in qgroup_shared_accounting() error path Btrfs: fix qgroups sanity test crash or hang btrfs: prevent RCU warning when dereferencing radix tree slot Btrfs: fix unfinished readahead thread for raid5/6 degraded mounting btrfs: new ioctl TREE_SEARCH_V2 btrfs: tree_search, search_ioctl: direct copy to userspace btrfs: new function read_extent_buffer_to_user btrfs: tree_search, copy_to_sk: return needed size on EOVERFLOW btrfs: tree_search, copy_to_sk: return EOVERFLOW for too small buffer btrfs: tree_search, search_ioctl: accept varying buffer btrfs: tree_search: eliminate redundant nr_items check
2014-06-14Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver for Sensirion SHTC1 humidity / temperature sensor - convert ltc4151 and vexpress drivers to use devm functions - drop generic chip detection from lm85 driver - avoid forward declarations in atxp1 driver - fix sign extensions in ina2xx driver * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: vexpress: Use devm helper for hwmon device registration hwmon: (atxp1) Avoid forward declaration hwmon: add support for Sensirion SHTC1 sensor hwmon: (ltc4151) Convert to devm_hwmon_device_register_with_groups hwmon: (lm85) Drop generic detection hwmon: (ina2xx) Cast to s16 on shunt and current regs
2014-06-14Merge branch 'perf/core' into perf/urgent, to pick up the latest fixesIngo Molnar
2014-06-13btrfs: new ioctl TREE_SEARCH_V2Gerhard Heift
This new ioctl call allows the user to supply a buffer of varying size in which a tree search can store its results. This is much more flexible if you want to receive items which are larger than the current fixed buffer of 3992 bytes or if you want to fetch more items at once. Items larger than this buffer are for example some of the type EXTENT_CSUM. Signed-off-by: Gerhard Heift <Gerhard@Heift.Name> Signed-off-by: Chris Mason <clm@fb.com> Acked-by: David Sterba <dsterba@suse.cz>
2014-06-13NVMe: Define Log Page constantsMatthew Wilcox
Taken from the 1.1a version of the spec Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
2014-06-13NVMe: Fix hot cpu notification dead lockKeith Busch
There is a potential dead lock if a cpu event occurs during nvme probe since it registered with hot cpu notification. This fixes the race by having the module register with notification outside of probe rather than have each device register. The actual work is done in a scheduled work queue instead of in the notifier since assigning IO queues has the potential to block if the driver creates additional queues. Signed-off-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
2014-06-13Merge tag 'sound-fix-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Most of changes are small and easy cleanup or fixes: - a few HD-audio Realtek codec fixes and quirks - Intel HDMI audio fixes for Broadwell and Haswell / ValleyView - FireWire sound stack cleanups - a couple of sequencer core fixes - compress ABI fix for 64bit - conversion to modern ktime*() API" * tag 'sound-fix-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (23 commits) ALSA: hda/realtek - Add more entry for enable HP mute led ALSA: hda - Add quirk for external mic on Lifebook U904 ALSA: hda - fix a fixup value for codec alc293 in the pin_quirk table ALSA: intel8x0: Use ktime and ktime_get() ALSA: core: Use ktime_get_ts() ALSA: hda - verify pin:converter connection on unsol event for HSW and VLV ALSA: compress: Cancel the optimization of compiler and fix the size of struct for all platform. ALSA: hda - Add quirk for ABit AA8XE Revert "ALSA: hda - mask buggy stream DMA0 for Broadwell display controller" ALSA: hda - using POS_FIX_LPIB on Broadwell HDMI Audio ALSA: hda/realtek - Add support of ALC667 codec ALSA: hda/realtek - Add more codec rename ALSA: hda/realtek - New vendor ID for ALC233 ALSA: hda - add two new pin tables ALSA: hda/realtek - Add support of ALC891 codec ALSA: seq: Continue broadcasting events to ports if one of them fails ALSA: bebob: Remove unused function prototype ALSA: fireworks: Remove meaningless mutex_destroy() ALSA: fireworks: Remove a constant over width to which it's applied ALSA: fireworks: Improve comments about Fireworks transaction ...
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "This has a mix of bug fixes and cleanups. Alex's patch fixes a rare race in RBD. Ilya's patches fix an ENOENT check when a second rbd image is mapped and a couple memory leaks. Zheng fixes several issues with fragmented directories and multiple MDSs. Josh fixes a spin/sleep issue, and Josh and Guangliang's patches fix setting and unsetting RBD images read-only. Naturally there are several other cleanups mixed in for good measure" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits) rbd: only set disk to read-only once rbd: move calls that may sleep out of spin lock range rbd: add ioctl for rbd ceph: use truncate_pagecache() instead of truncate_inode_pages() ceph: include time stamp in every MDS request rbd: fix ida/idr memory leak rbd: use reference counts for image requests rbd: fix osd_request memory leak in __rbd_dev_header_watch_sync() rbd: make sure we have latest osdmap on 'rbd map' libceph: add ceph_monc_wait_osdmap() libceph: mon_get_version request infrastructure libceph: recognize poolop requests in debugfs ceph: refactor readpage_nounlock() to make the logic clearer mds: check cap ID when handling cap export message ceph: remember subtree root dirfrag's auth MDS ceph: introduce ceph_fill_fragtree() ceph: handle cap import atomically ceph: pre-allocate ceph_cap struct for ceph_add_cap() ceph: update inode fields according to issued caps rbd: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO ...
2014-06-12Merge branch 'topic/omap3isp' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull OMAP3 updates from Mauro Carvalho Chehab: "Some driver improvements on OMAP3. This series depend on some iommu patches already merged" * 'topic/omap3isp' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (26 commits) [media] omap3isp: Rename isp_buffer isp_addr field to dma [media] omap3isp: Move to videobuf2 [media] v4l: vb2: Add a function to discard all DONE buffers [media] omap3isp: Cancel all queued buffers when stopping the video stream [media] omap3isp: Move buffer irqlist to isp_buffer structure [media] omap3isp: Move queue irqlock to isp_video structure [media] omap3isp: Move queue mutex to isp_video structure [media] omap3isp: queue: Don't build scatterlist for kernel buffer [media] omap3isp: Use the ARM DMA IOMMU-aware operations [media] omap3isp: queue: Use sg_alloc_table_from_pages() [media] omap3isp: queue: Map PFNMAP buffers to device [media] omap3isp: queue: Fix the dma_map_sg() return value check [media] omap3isp: queue: Allocate kernel buffers with dma_alloc_coherent [media] omap3isp: queue: Inline the ispmmu_v(un)map functions [media] omap3isp: queue: Merge the prepare and sglist functions [media] omap3isp: queue: Use sg_table structure [media] omap3isp: queue: Move IOMMU handling code to the queue [media] omap3isp: video: Set the buffer bytesused field at completion time [media] omap3isp: ccdc: Use the DMA API for FPC [media] omap3isp: ccdc: Use the DMA API for LSC ...
2014-06-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - Add support for T10 PI pass-through between vhost-scsi + virtio-scsi (MST + Paolo + MKP + nab) - Add support for T10 PI in qla2xxx target mode (Quinn + MKP + hch + nab, merged through scsi.git) - Add support for percpu-ida pre-allocation in qla2xxx target code (Quinn + nab) - A number of iser-target fixes related to hardening the network portal shutdown path (Sagi + Slava) - Fix response length residual handling for a number of control CDBs (Roland + Christophe V.) - Various iscsi RFC conformance fixes in the CHAP authentication path (Tejas and Calsoft folks + nab) - Return TASK_SET_FULL status for tcm_fc(FCoE) DataIn + Response failures (Vasu + Jun + nab) - Fix long-standing ABORT_TASK + session reset hang (nab) - Convert iser-initiator + iser-target to include T10 bytes into EDTL (Sagi + Or + MKP + Mike Christie) - Fix NULL pointer dereference regression related to XCOPY introduced in v3.15 + CC'ed to v3.12.y (nab)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (34 commits) target: Fix NULL pointer dereference for XCOPY in target_put_sess_cmd vhost-scsi: Include prot_bytes into expected data transfer length TARGET/sbc,loopback: Adjust command data length in case pi exists on the wire libiscsi, iser: Adjust data_length to include protection information scsi_cmnd: Introduce scsi_transfer_length helper target: Report correct response length for some commands target/sbc: Check that the LBA and number of blocks are correct in VERIFY target/sbc: Remove sbc_check_valid_sectors() Target/iscsi: Fix sendtargets response pdu for iser transport Target/iser: Fix a wrong dereference in case discovery session is over iser iscsi-target: Fix ABORT_TASK + connection reset iscsi_queue_req memory leak target: Use complete_all for se_cmd->t_transport_stop_comp target: Set CMD_T_ACTIVE bit for Task Management Requests target: cleanup some boolean tests target/spc: Simplify INQUIRY EVPD=0x80 tcm_fc: Generate TASK_SET_FULL status for response failures tcm_fc: Generate TASK_SET_FULL status for DataIN failures iscsi-target: Reject mutual authentication with reflected CHAP_C iscsi-target: Remove no-op from iscsit_tpg_del_portal_group iscsi-target: Fix CHAP_A parameter list handling ...
2014-06-12Merge tag 'trace-3.16-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing cleanups and bugfixes from Steven Rostedt: "One bug fix that goes back to 3.10. Accessing a non existent buffer if "possible cpus" is greater than actual CPUs (including offline CPUs). Namhyung Kim did some reviews of the patches I sent this merge window and found a memory leak and had a few clean ups" * tag 'trace-3.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix check of ftrace_trace_arrays list_empty() check tracing: Fix leak of per cpu max data in instances tracing: Cleanup saved_cmdlines_size changes ring-buffer: Check if buffer exists before polling
2014-06-12Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more scheduler updates from Ingo Molnar: "Second round of scheduler changes: - try-to-wakeup and IPI reduction speedups, from Andy Lutomirski - continued power scheduling cleanups and refactorings, from Nicolas Pitre - misc fixes and enhancements" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/deadline: Delete extraneous extern for to_ratio() sched/idle: Optimize try-to-wake-up IPI sched/idle: Simplify wake_up_idle_cpu() sched/idle: Clear polling before descheduling the idle thread sched, trace: Add a tracepoint for IPI-less remote wakeups cpuidle: Set polling in poll_idle sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...) sched: Rename capacity related flags sched: Final power vs. capacity cleanups sched: Remove remaining dubious usage of "power" sched: Let 'struct sched_group_power' care about CPU capacity sched/fair: Disambiguate existing/remaining "capacity" usage sched/fair: Change "has_capacity" to "has_free_capacity" sched/fair: Remove "power" from 'struct numa_stats' sched: Fix signedness bug in yield_to() sched/fair: Use time_after() in record_wakee() sched/balancing: Reduce the rate of needless idle load balancing sched/fair: Fix unlocked reads of some cfs_b->quota/period
2014-06-12Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second round of perf updates: - wide reaching kprobes sanitization and robustization, with the hope of fixing all 'probe this function crashes the kernel' bugs, by Masami Hiramatsu. - uprobes updates from Oleg Nesterov: tmpfs support, corner case fixes and robustization work. - perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo et al: * Add support to accumulate hist periods (Namhyung Kim) * various fixes, refactorings and enhancements" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits) perf: Differentiate exec() and non-exec() comm events perf: Fix perf_event_comm() vs. exec() assumption uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates perf/documentation: Add description for conditional branch filter perf/x86: Add conditional branch filtering support perf/tool: Add conditional branch filter 'cond' to perf record perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND' uprobes: Teach copy_insn() to support tmpfs uprobes: Shift ->readpage check from __copy_insn() to uprobe_register() perf/x86: Use common PMU interrupt disabled code perf/ARM: Use common PMU interrupt disabled code perf: Disable sampled events if no PMU interrupt perf: Fix use after free in perf_remove_from_context() perf tools: Fix 'make help' message error perf record: Fix poll return value propagation perf tools: Move elide bool into perf_hpp_fmt struct perf tools: Remove elide setup for SORT_MODE__MEMORY mode perf tools: Fix "==" into "=" in ui_browser__warning assignment perf tools: Allow overriding sysfs and proc finding with env var perf tools: Consider header files outside perf directory in tags target ...
2014-06-12Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more locking changes from Ingo Molnar: "This is the second round of locking tree updates for v3.16, offering large system scalability improvements: - optimistic spinning for rwsems, from Davidlohr Bueso. - 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, locking/rwlocks: Enable qrwlocks on x86 locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks locking/mutexes: Documentation update/rewrite locking/rwsem: Fix checkpatch.pl warnings locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK locking/rwsem: Support optimistic spinning
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge tag 'dm-3.16-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper updates from Mike Snitzer: "This pull request is later than I'd have liked because I was waiting for some performance data to help finally justify sending the long-standing dm-crypt cpu scalability improvements upstream. Unfortunately we came up short, so those dm-crypt changes will continue to wait, but it seems we're not far off. . Add dm_accept_partial_bio interface to DM core to allow DM targets to only process a portion of a bio, the remainder being sent in the next bio. This enables the old dm snapshot-origin target to only split write bios on chunk boundaries, read bios are now sent to the origin device unchanged. . Add DM core support for disabling WRITE SAME if the underlying SCSI layer disables it due to command failure. . Reduce lock contention in DM's bio-prison. . A few small cleanups and fixes to dm-thin and dm-era" * tag 'dm-3.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm thin: update discard_granularity to reflect the thin-pool blocksize dm bio prison: implement per bucket locking in the dm_bio_prison hash table dm: remove symbol export for dm_set_device_limits dm: disable WRITE SAME if it fails dm era: check for a non-NULL metadata object before closing it dm thin: return ENOSPC instead of EIO when error_if_no_space enabled dm thin: cleanup noflush_work to use a proper completion dm snapshot: do not split read bios sent to snapshot-origin target dm snapshot: allocate a per-target structure for snapshot-origin target dm: introduce dm_accept_partial_bio dm: change sector_count member in clone_info from sector_t to unsigned
2014-06-12Merge tag 'pci-v3.16-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull more PCI updates from Bjorn Helgaas: "Here are some more things I'd like to see in v3.16-rc1: - DMA alias iterator, part of some work to fix IOMMU issues - MVEBU, Tegra, DesignWare changes that I forgot to include before - Some whitespace code cleanup Details: IOMMU - Add DMA alias iterator (Alex Williamson) - Add DMA alias quirks for ASMedia, ITE, Tundra bridges (Alex Williamson) - Add DMA alias quirks for Marvell, Ricoh devices (Alex Williamson) - Add DMA alias quirk for HighPoint devices (Jérôme Carretero) MSI - Fix leak in free_msi_irqs() (Alexei Starovoitov) Marvell MVEBU - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Avoid setting an undefined window size (Jason Gunthorpe) - Allow several windows with the same target/attribute (Thomas Petazzoni) - Split PCIe BARs into multiple MBus windows when needed (Thomas Petazzoni) - Fix off-by-one in the computed size of the mbus windows (Willy Tarreau) NVIDIA Tegra - Use new OF interrupt mapping when possible (Lucas Stach) Synopsys DesignWare - Remove unnecessary use of 'conf_lock' spinlock (Andrew Murray) - Use new OF interrupt mapping when possible (Lucas Stach) - Split Exynos and i.MX bindings (Lucas Stach) - Fix comment for setting number of lanes (Mohit Kumar) - Fix iATU programming for cfg1, io and mem viewport (Mohit Kumar) Miscellaneous - EXPORT_SYMBOL cleanup (Ryan Desfosses) - Whitespace cleanup (Ryan Desfosses) - Merge multi-line quoted strings (Ryan Desfosses)" * tag 'pci-v3.16-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits) PCI: Add function 1 DMA alias quirk for HighPoint RocketRaid 642L PCI/MSI: Fix memory leak in free_msi_irqs() PCI: Merge multi-line quoted strings PCI: Whitespace cleanup PCI: Move EXPORT_SYMBOL so it immediately follows function/variable PCI: Add bridge DMA alias quirk for ITE bridge PCI: designware: Split Exynos and i.MX bindings PCI: Add bridge DMA alias quirk for ASMedia and Tundra bridges PCI: Add support for PCIe-to-PCI bridge DMA alias quirks PCI: Add function 1 DMA alias quirk for Marvell devices PCI: Add function 0 DMA alias quirk for Ricoh devices PCI: Add support for DMA alias quirks PCI: Convert pci_dev_flags definitions to bit shifts PCI: Add DMA alias iterator PCI: mvebu: Use '%pa' for printing 'phys_addr_t' type PCI: mvebu: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Remove unnecessary use of 'conf_lock' spinlock PCI: designware: Use new OF interrupt mapping when possible PCI: designware: Fix iATU programming for cfg1, io and mem viewport PCI: designware: Fix comment for setting number of lanes ...
2014-06-12Merge tag 'pm+acpi-3.16-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are fixups on top of the previous PM+ACPI pull request, regression fixes (ACPI hotplug, cpufreq ppc-corenet), other bug fixes (ACPI reset, cpufreq), new PM trace points for system suspend profiling and a copyright notice update. Specifics: - I didn't remember correctly that the Hans de Goede's ACPI video patches actually didn't flip the video.use_native_backlight default, although we had discussed that and decided to do that. Since I said we would do that in the previous PM+ACPI pull request, make that change for real now. - ACPI bus check notifications for PCI host bridges don't cause the bus below the host bridge to be checked for changes as they should because of a mistake in the ACPI-based PCI hotplug (ACPIPHP) subsystem that forgets to add hotplug contexts to PCI host bridge ACPI device objects. Create hotplug contexts for PCI host bridges too as appropriate. - Revert recent cpufreq commit related to the big.LITTLE cpufreq driver that breaks arm64 builds. - Fix for a regression in the ppc-corenet cpufreq driver introduced during the 3.15 cycle and causing the driver to use the remainder from do_div instead of the quotient. From Ed Swarthout. - Resets triggered by panic activate a BUG_ON() in vmalloc.c on systems where the ACPI reset register is located in memory address space. Fix from Randy Wright. - Fix for a problem with cpufreq governors that decisions made by them may be suboptimal due to the fact that deferrable timers are used by them for CPU load sampling. From Srivatsa S Bhat. - Fix for a problem with the Tegra cpufreq driver where the CPU frequency is temporarily switched to a "stable" level that is different from both the initial and target frequencies during transitions which causes udelay() to expire earlier than it should sometimes. From Viresh Kumar. - New trace points and rework of some existing trace points for system suspend/resume profiling from Todd Brandt. - Assorted cpufreq fixes and cleanups from Stratos Karafotis and Viresh Kumar. - Copyright notice update for suspend-and-cpuhotplug.txt from Srivatsa S Bhat" * tag 'pm+acpi-3.16-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / hotplug / PCI: Add hotplug contexts to PCI host bridges PM / sleep: trace events for device PM callbacks cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag PM / Documentation: Update copyright in suspend-and-cpuhotplug.txt cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads PM / sleep: trace events for suspend/resume cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies ACPI / video: Change the default for video.use_native_backlight to 1 ACPI: Fix bug when ACPI reset register is implemented in system memory
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED updates from Bryan Wu: "I just found merge window is open and I'm quite busy and almost forget to send out this pull request. Thanks Russell and Alexandre ping me about this. So basically we got some clean up and leds-pwm fixing patches from Russell" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: Remove duplicated OOM message for individual driver drivers/leds: Replace __get_cpu_var use through this_cpu_ptr leds: lp55xx: add DT bindings for LP55231 leds: 88pm860x: Fix missing refcount decrement for parent of_node leds: 88pm860x: Use of_get_child_by_name leds: leds-pwm: add DT support for LEDs wired to supply leds: leds-pwm: implement PWM inversion leds: leds-pwm: convert OF parsing code to use led_pwm_add() leds: leds-pwm: provide a common function to setup a single led-pwm device leds: pca9685: Remove leds-pca9685 driver dell-led: add mic mute led interface
2014-06-12Merge tag 'mfd-for-linus-3.16-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull more MFD updates from Lee Jones: "I missed collecting these patches due to a branch/tag naming ambiguity. Completely my own fault, as I mindlessly named a branch and tag identically. Sorry for the fuss. This pull-request contains some misplaced patches from Tony Lindgren that should have been part of the initial one" * tag 'mfd-for-linus-3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: mfd: twl4030-power: Add a configuration to turn off oscillator during off-idle mfd: twl4030-power: Add support for board specific configuration mfd: twl4030-power: Add recommended idle configuration mfd: twl4030-power: Add generic reset configuration mfd: twl4030-power: Fix some defines for SW_EVENTS mfd: twl4030-power: Fix hang on reboot if sleep configuration was loaded earlier
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12hwmon: add support for Sensirion SHTC1 sensorTomas Pop
Add support for Sensirion SHTC1 and compatible temperature and humidity sensors. Signed-off-by: Tomas Pop <tomas.pop@sensirion.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-12Merge commit '3cf2f34' into sched/core, to fix build errorIngo Molnar
Fix this dependency on the locking tree's smp_mb*() API changes: kernel/sched/idle.c:247:3: error: implicit declaration of function ‘smp_mb__after_atomic’ [-Werror=implicit-function-declaration] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-12Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: PM / sleep: trace events for device PM callbacks PM / sleep: trace events for suspend/resume
2014-06-12Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: cpufreq: cpufreq-cpu0: remove dependency on THERMAL and REGULATOR cpufreq: tegra: update comment for clarity cpufreq: intel_pstate: Remove duplicate CPU ID check cpufreq: Mark CPU0 driver with CPUFREQ_NEED_INITIAL_FREQ_CHECK flag cpufreq: governor: remove copy_prev_load from 'struct cpu_dbs_common_info' cpufreq: governor: Be friendly towards latency-sensitive bursty workloads cpufreq: ppc-corenet-cpu-freq: do_div use quotient Revert "cpufreq: Enable big.LITTLE cpufreq driver on arm64" cpufreq: Tegra: implement intermediate frequency callbacks cpufreq: add support for intermediate (stable) frequencies
2014-06-12ALSA: core: Use ktime_get_ts()Thomas Gleixner
do_posix_clock_monotonic_gettime() is a leftover from the initial posix timer implementation which maps to ktime_get_ts(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-12ALSA: compress: Cancel the optimization of compiler and fix the size of ↵Wang, Xiaoming
struct for all platform. Cancel the optimization of compiler for struct snd_compr_avail which size will be 0x1c in 32bit kernel while 0x20 in 64bit kernel under the optimizer. That will make compaction between 32bit and 64bit. So add packed to fix the size of struct snd_compr_avail to 0x1c for all platform. Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com> Signed-off-by: xiaoming wang <xiaoming.wang@intel.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-06-12Merge commit '9f12600fe425bc28f0ccba034a77783c09c15af4' into for-linusAl Viro
Backmerge of dcache.c changes from mainline. It's that, or complete rebase... Conflicts: fs/splice.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
