1) The TSB lookup was not using the correct hash mask.
2) It was not aligned on a boundary equal to it's size,
which is required by the sun4v Hypervisor.
wasn't having it's return value checked, and that bug will be fixed up
as well in a subsequent changeset.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Noticed by Matvejchikov Ilya.
This combines two upstream commits to fix an OOPS with
AF_UNIX and SELINUX.
Basically, sk->sk_socket can become NULL because we access
a peer socket without any locking, so it can be shut down and
released in another thread.
Commit: d410b81b4eef2e4409f9c38ef201253fbbcc7d94
[AF_UNIX]: Make socket locking much less confusing.
The unix_state_*() locking macros imply that there is some
rwlock kind of thing going on, but the implementation is
actually a spinlock which makes the code more confusing than
it needs to be.
So use plain unix_state_lock and unix_state_unlock.
Commit: 19fec3e807a487415e77113cb9dbdaa2da739836
[AF_UNIX]: Fix datagram connect race causing an OOPS.
Based upon an excellent bug report and initial patch by
Frederik Deweerdt.
The UNIX datagram connect code blindly dereferences other->sk_socket
via the call down to the security_unix_may_send() function.
Without locking 'other' that pointer can go NULL via unix_release_sock()
which does sock_orphan() which also marks the socket SOCK_DEAD.
So we have to lock both 'sk' and 'other' yet avoid all kinds of
potential deadlocks (connect to self is OK for datagram sockets and it
is possible for two datagram sockets to perform a simultaneous connect
to each other). So what we do is have a "double lock" function similar
to how we handle this situation in other areas of the kernel. We take
the lock of the socket pointer with the smallest address first in
order to avoid ABBA style deadlocks.
Once we have them both locked, we check to see if SOCK_DEAD is set
for 'other' and if so, drop everything and retry the lookup.
Strip __cpuinit[data] from Node <-> PXM routines and supporting data
structures. Also make pxm_to_node_map and node_to_pxm_map local to the
numa acpi module.
This fixes a bug triggered by the following conditions:
- boot on a machine with a SLIT table defined
- kernel is configured w/ CONFIG_HOTPLUG_CPU=n
- cat /sys/devices/system/node/node*/distance
This will cause an oops by calling into a freed memory section.
In particular, on x86_64, __node_distance calls node_to_pxm().
Signed-off-by: Aaron Durbin <adurbin@google.com>
Cc: Len Brown <lenb@kernel.org>
On systems with huge amount of physical memory, VFS cache and memory memmap
may eat all available system memory under 4G, then the system may fail to
allocate swiotlb bounce buffer.
There was a fix for this issue in arch/x86_64/mm/numa.c, but that fix dose
not cover sparsemem model.
This patch add fix to sparsemem model by first try to allocate memmap above
4G.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Andi Kleen <ak@suse.de>
Cc: <stable@kernel.org>
[chrisw: trivial backport]
This patch updates the Intel ICH9M LPC Controller DID's, due to a
specification change.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
Cc: Greg KH <greg@kroah.com>
The Via VT3351 APIC does not play well with MSI and unleashes a flood
of APIC errors when MSI is used to deliver interrupts. The problem
was recently exposed when the atl1 network device driver, which enables
MSI by default, stimulated APIC errors on an Asus M2V mainboard, which
employs the Via VT3351.
See http://bugzilla.kernel.org/show_bug.cgi?id=8472 for additional
details on this bug.
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
It is a known fact that freezeable multithreaded workqueues doesn't like
CPU_DEAD. We keep them only for the incoming CPU-hotplug rework.
Sadly, we can't just kill create_freezeable_workqueue() right now, make
them singlethread.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Gautham R Shenoy <ego@in.ibm.com>
It is possible that real data or metadata follows the bitmap
without full page alignment.
So limit the last write to be only the required number of bytes,
rounded up to the hard sector size of the device.
Signed-off-by: Neil Brown <neilb@suse.de>
Some devices have more than 15 which was the previous
setting.
We need to make sure that the clocksources are resumed, when timekeeping is
resumed. The current resume logic does not guarantee this.
Add a resume function pointer to the clocksource struct, so clocksource
drivers which need to reinitialize the clocksource can provide a resume
function.
Add a resume function, which calls the maybe available clocksource resume
functions and resets the watchdog function, so a stable TSC can be used
accross suspend/resume.
Cc: john stultz <johnstul@us.ibm.com>
CONFIG_NETPOLL_TRAP causes the TX queue controls to be completely bypassed in
the netpoll's "trapped" mode which easily causes overflows in the drivers with
short TX queues (most notably, in 8139too with its 4-deep queue). So, make
this option more sensible by making it only bypass the TX softirq wakeup.
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Acked-by: Tom Rini <trini@kernel.crashing.org>
Acked-by: Matt Mackall <mpm@selenic.com>
packets through NAT
While porting some changes of the 2.6.21-rc7 pptp/proto_gre conntrack
and nat modules to a 2.4.32 kernel I noticed that the gre_key function
returns a wrong pointer to the GRE key of a version 0 packet thus
corrupting the packet payload.
The intended behaviour for GREv0 packets is to act like
nf_conntrack_proto_generic/nf_nat_proto_unknown so I have ripped the
offending functions (not used anymore) and modified the
nf_nat_proto_gre modules to not touch version 0 (non PPTP) packets.
Signed-off-by: Jorge Boncompte <jorge@dti2.net>
PCI devices were being programmed with an incorrect base address value.
This patch moves I/O space into a 16-bit addressable region and corrects
the i/o offset.
Much thanks to Martin Michlmayr for tracking this issue and testing
debug patches.
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.
[IPV6]: Disallow RH0 by default.
[XFRM]: beet: fix pseudo header length value
[TCP]: Congestion control initialization.
A security issue is emerging. Disallow Routing Header Type 0 by default
as we have been doing for IPv4.
Note: We allow RH2 by default because it is harmless.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
We broke the the alignment of members of taskstats to the 8 byte boundary
with the CSA patches. In the current kernel, the taskstats structure is
not suitable for use by 32 bit applications in a 64 bit kernel.
On x86_64
Offsets of taskstats' members (64 bit kernel, 64 bit application)
@taskstats'offsetof[@taskstats'indices] = (
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
24, # cpu_delay_total
32, # blkio_count
40, # blkio_delay_total
48, # swapin_count
56, # swapin_delay_total
64, # cpu_run_real_total
72, # cpu_run_virtual_total
80, # ac_comm
112, # ac_sched
113, # ac_pad
116, # ac_uid
120, # ac_gid
124, # ac_pid
128, # ac_ppid
132, # ac_btime
136, # ac_etime
144, # ac_utime
152, # ac_stime
160, # ac_minflt
168, # ac_majflt
176, # coremem
184, # virtmem
192, # hiwater_rss
200, # hiwater_vm
208, # read_char
216, # write_char
224, # read_syscalls
232, # write_syscalls
240, # read_bytes
248, # write_bytes
256, # cancelled_write_bytes
Offsets of taskstats' members (64 bit kernel, 32 bit application)
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
12, # cpu_count
20, # cpu_delay_total
28, # blkio_count
36, # blkio_delay_total
44, # swapin_count
52, # swapin_delay_total
60, # cpu_run_real_total
68, # cpu_run_virtual_total
76, # ac_comm
108, # ac_sched
109, # ac_pad
112, # ac_uid
116, # ac_gid
120, # ac_pid
124, # ac_ppid
128, # ac_btime
132, # ac_etime
140, # ac_utime
148, # ac_stime
156, # ac_minflt
164, # ac_majflt
172, # coremem
180, # virtmem
188, # hiwater_rss
196, # hiwater_vm
204, # read_char
212, # write_char
220, # read_syscalls
228, # write_syscalls
236, # read_bytes
244, # write_bytes
252, # cancelled_write_bytes
This is one way to solve the problem without re-arranging structure members
is to pack the structure. The patch adds an __attribute__((aligned(8))) to
the taskstats structure members so that 32 bit applications using taskstats
can work with a 64 bit kernel.
Using __attribute__((packed)) would break the 64 bit alignment of members.
The fix was tested on x86_64. After the fix, we got
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
232, # read_syscalls
240, # write_syscalls
248, # read_bytes
256, # write_bytes
264, # cancelled_write_bytes
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
248, # read_bytes
256, # write_bytes
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Jay Lan <jlan@engr.sgi.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix wrong checksum for split TCP packets on 64-bit MIPS
[MIPS] Fix BUG(), BUG_ON() handling
[MIPS] Retry {save,restore}_fp_context if failed in atomic context.
[MIPS] Disallow CpU exception in kernel again.
[MIPS] Add missing silicon revisions for BCM112x
Get rid of the inlined #ifdefs.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
I've traced down an off-by-one TCP checksum calculation error under
1) The TCP code needs to split a full-sized packet due to a reduced
MSS (typically due to the addition of TCP options mid-stream like
SACK).
_AND_
2) The checksum of the 2nd fragment is larger than the checksum of the
original packet. After subtraction this results in a checksum for
the 1st fragment with bits 16..31 set to 1. (this is ok)
_AND_
3) The checksum of the 1st fragment's TCP header plus the previously
32bit checksum of the 1st fragment DOES NOT cause a 32bit overflow
when added together. This results in a checksum of the TCP header
plus TCP data that still has the upper 16 bits as 1's.
_THEN_
4) The TCP+data checksum is added to the checksum of the pseudo IP
header with csum_tcpudp_nofold() incorrectly (the bug).
The problem is the checksum of the TCP+data is passed to
csum_tcpudp_nofold() as an 32bit unsigned value, however the assembly
code acts on it as if it is a 64bit unsigned value.
This causes an incorrect 32->64bit extension if the sum has bit 31
set. The resulting checksum is off by one.
This problems is data and TCP header dependent due to #2 and #3
above so it doesn't occur on every TCP packet split.
Signed-off-by: Dave Johnson <djohnson+linux-mips@sw.starentnetworks.com>
With commit 63dc68a8cf60cb110b147dab1704d990808b39e2, kernel can not
handle BUG() and BUG_ON() properly since get_user() returns false for
kernel code. Use __get_user() to skip unnecessary access_ok(). This
patch also make BRK_BUG code encoded in the TNE instruction.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The save_fp_context()/restore_fp_context() might sleep on accessing
user stack and therefore might lose FPU ownership in middle of them.
If these function failed due to "in_atomic" test in do_page_fault,
touch the sigcontext area in non-atomic context and retry these
save/restore operation.
This is a replacement of a (broken) fix which was titled "Allow CpU
exception in kernel partially".
The commit 4d40bff7110e9e1a97ff8c01bdd6350e9867cc10 ("Allow CpU
exception in kernel partially") was broken. The commit was to fix
theoretical problem but broke usual case. Revert it for now.
Recent versions of the BCM112X processors aren't recognized by Linux
(preventing Linux from booting on those processors). This patch adds
support for those that are missing.
Signed-off-by: Mark Mason <mason@broadcom.com>
[BRIDGE]: Unaligned access when comparing ethernet addresses
[SCTP]: Unmap v4mapped addresses during SCTP_BINDX_REM_ADDR operation.
[SCTP]: Fix assertion (!atomic_read(&sk->sk_rmem_alloc)) failed message
[NET]: Set a separate lockdep class for neighbour table's proxy_queue
[NET]: Fix UDP checksum issue in net poll mode.
[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.
[NET]: Get rid of alloc_skb_from_cache
Provide an dummy implementation of devm_ioport_map() and
devm_ioport_unmap() to allow drivers (eg, pata_platform) to build for
platforms where CONFIG_NO_IOPORT is selected.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Override compiler .arch directive for generic kernel build.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Signed-off-by: Richard Henderson <rth@twiddle.net>
Files:
arch/alpha/kernel/core_mcpcia.c
arch/alpha/kernel/sys_rawhide.c
include/asm-alpha/core_mcpcia.h
Determine correct hose configuration; RAWHIDE family can have
2 or 4 hoses, so make sure non-existent hoses are ignored.
arch/alpha/kernel/err_titan.c
Supply a needed #include <asm/irq_regs.h>
arch/alpha/kernel/module.c
Add some useful output to the relocation overflow messages.
arch/alpha/kernel/sys_noritake.c
Supply necessary noritake_end_irq() to correct interrupt handling.
This fixes a problem first noted by hangs during boot probing with
a DE500-BA TULIP NIC present.
arch/alpha/kernel/sys_sio.c
Correct saving of original PIRQ register (PCI IRQ routing);
change default PIRQ setting to leave PCI IRQs 9 and 14 free to
be used for sound (Multia) and IDE (any), respectively.
include/asm-alpha/io.h
Supply the "isa_virt_to_bus" routine.
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
Cc: Richard Henderson <rth@twiddle.net>
Make kernel-doc comments match macro names.
Correct parameter names in a few places.
Remove '#' from beginning of kernel-doc comment macro names.
Remove extra (erroneous) blank lines in kernel-doc.
Warning(plist.h:100): Cannot understand * #PLIST_HEAD_INIT - static struct plist_head initializer on line 100 - I thought it was a doc line
Warning(plist.h:112): Cannot understand * #PLIST_NODE_INIT - static struct plist_node initializer on line 112 - I thought it was a doc line
Warning(plist.h:103): No description found for parameter '_lock'
Warning(plist.h:129): No description found for parameter 'lock'
Warning(plist.h:158): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'n'
Warning(plist.h:179): No description found for parameter 'mem'
This still leaves one warning & one error that need attention:
Error(plist.h:219): cannot understand prototype: '('
Warning(plist.h): no structured comments found
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Daniel Walker <dwalker@mvista.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Trivial change to pass vmsplice arguments through the compat layer on
pp64.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Acked-by: Paul Mackerras <paulus@samba.org>
Otherwise the following calltrace will lead to a wrong
lockdep warning:
neigh_proxy_process()
`- lock(neigh_table->proxy_queue.lock);
arp_redo /* via tbl->proxy_redo */
arp_process
neigh_event_ns
neigh_update
skb_queue_purge
`- lock(neighbor->arp_queue.lock);
This is not a deadlock actually, as neighbor table's proxy_queue
and the neighbor's arp_queue are different queues.
Lockdep thinks there is a deadlock as both queues are initialized
with skb_queue_head_init() and thus have a common class.
Since this was added originally for Xen, and Xen has recently (~2.6.18)
stopped using this function, we can safely get rid of it. Good timing
too since this function has started to bit rot.
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the
memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must
ensure that the PG_writeback flag is cleared.
Also ensure that we actually own the PG_writeback flag whenever we
schedule a new writeback by making nfs_set_page_writeback() return the
value of test_set_page_writeback().
The PG_writeback page flag ends up replacing the functionality of the
PG_FLUSHING nfs_page flag, so we rip that out too.
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: add "optical" to sysfs "media" attribute
ide: ugly messages trying to open CD drive with no media present
ide: correctly prevent IDE timer expiry function to run if request was already handled
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] SGI Altix : fix pcibr_dmamap_ate32() bug
[IA64] Fix CPU freq displayed in /proc/cpuinfo
[IA64] Fix wrong assumption about irq and vector in msi_ia64.c
[IA64] BTE error timer fix
already handled
It is possible for the timer expiry function to run even though the
request has already been handled: ide_timer_expiry() only checks that
the handler is not NULL, but it is possible that we have handled a
request (thus clearing the handler) and then started a new request
(thus starting the timer again, and setting a handler).
A simple way to exhibit this is to set the DMA timeout to 1 jiffy and
run dd: The kernel will panic after a few minutes because
ide_timer_expiry() tries to add a timer when it's already active.
To fix this, we simply add a request generation count that gets
incremented at every interrupt, and check in ide_timer_expiry() that
we have not already handled a new interrupt before running the expiry
function.
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Since lazy MMU batching mode still allows interrupts to enter, it is
possible for interrupt handlers to try to use kmap_atomic, which fails when
lazy mode is active, since the PTE update to highmem will be delayed. The
best workaround is to issue an explicit flush in kmap_atomic_functions
case; this is the only way nested PTE updates can happen in the interrupt
handler.
Thanks to Jeremy Fitzhardinge for noting the bug and suggestions on a fix.
This patch gets reverted again when we start 2.6.22 and the bug gets fixed
differently.
Signed-off-by: Zachary Amsden <zach@vmware.com>
Cc: Andi Kleen <ak@muc.de>
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
On a SGI Altix TIOCP based PCI bus we need to include the ATE_PIO attribute
bit if we're mapping a 32bit MSI address.
Signed-off-by: Mike Habeck <habeck@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Just a one-byter for an ia64 thinko/typo - already fixed for i386 and x86_64.
Acked-by: Tony Luck <tony.luck@intel.com>
Revert all this. It can cause device-mapper to receive a different major from
earlier kernels and it turns out that the Amanda backup program (via GNU tar,
apparently) checks major numbers on files when performing incremental backups.
Which is a bit broken of Amanda (or tar), but this feature isn't important
enough to justify the churn.
A device can be removed from an md array via e.g.
echo remove > /sys/block/md3/md/dev-sde/state
This will try to remove the 'dev-sde' subtree which will deadlock
since
commit e7b0d26a86943370c04d6833c6edba2a72a6e240
With this patch we run the kobject_del via schedule_work so as to
avoid the deadlock.
Cc: Alan Stern <stern@rowland.harvard.edu>
patch 4/4:
Limit ATAPI DMA to R/W commands only for TORiSAN DRD-N216 DVD-ROM drives
(http://bugzilla.kernel.org/show_bug.cgi?id=6710)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
patch 3/4:
The TORiSAN drive locks up when max sector == 256.
Limit max sector to 128 for the TORiSAN DRD-N216 drives.
patch 1/4:
Reorder HSM_ST_FIRST, such that the task state transition is easier decoded with human eyes.
Add unsigned to unused bit field in a.out.h to make sparse happy.
[ I took care of the sparc64 side as well -DaveM ]
Signed-off-by: Robert Reif <reif@earthlink.net>
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6:
[PATCH] x86: Don't probe for DDC on VBE1.2
[PATCH] x86-64: Increase NMI watchdog probing timeout
[PATCH] x86-64: Let oprofile reserve MSR on all CPUs
[PATCH] x86-64: Disable local APIC timer use on AMD systems with C1E
Fix the regression resulting from the recent change of suspend code
ordering that causes systems based on Intel x86 CPUs using the microcode
driver to hang during the resume.
The problem occurs since the microcode driver uses request_firmware() in
its CPU hotplug notifier, which is called after tasks has been frozen and
hangs. It can be fixed by telling the microcode driver to use the
microcode stored in memory during the resume instead of trying to load it
from disk.
Adrian Bunk <bunk@stusta.de>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Maxim <maximlevitsky@gmail.com>
built-in drivers had broken sysfs links that caused bootup hangs for
certain driver unregistry sequences.
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Greg KH <greg@kroah.com>
Currently we have a confused udelay implementation.
* __const_udelay does not accept usecs but xloops in i386 and x86_64
* our implementation requires usecs as arg
* it gets a xloops count when called by asm/arch/delay.h
Bugs related to this (extremely long shutdown times) where reported by some
x86_64 users, especially using Device Mapper.
To hit this bug, a compile-time constant time parameter must be passed -
that's why UML seems to work most times. Fix this with a simple udelay
implementation.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Acked-by: Jeff Dike <jdike@addtoit.com>
