path: root/include
2010-03-15Merge branch 'radeon-for-airlied' of ../linux-2.6 into drm-linusDave Airlie
* 'radeon-for-airlied' of ../linux-2.6: drm/radeon/kms: prepare for more reclocking operations drm/radeon/kms: switch to condition waiting for reclocking drm/radeon/r600: add missing license and comments to r600_blit_shaders.c drm/radeon/kms: improve coding style a little drm/radeon/kms: remove dead audio/HDMI code drm/radeon/kms: enable audio engine on DCE32 drm/radeon/kms: add HDMI code for pre-DCE3 R6xx GPUs drm/radeon/kms: clean assigning HDMI blocks to encoders drm/radeon/kms: clean HDMI definitions drm/radeon/kms/rs4xx: make sure crtcs are enabled when setting timing drm/radeon/kms/r1xx: enable hw i2c drm/radeon/kms: fix i2c prescale calc on older radeons drm/radeon/kms: fix for hw i2c drm/radeon/kms: fix pal tv-out support on legacy IGP chips drm/radeon/kms: further spread spectrum fixes drm/radeon/kms: use lcd pll limits when available drm/radeon/kms/atom: spread spectrum fix drm/radeon/kms: catch atombios infinite loop and break out of it drm/radeon: add new RS880 pci id
2010-03-15drm/ttm: use drm calloc large and free largeDave Airlie
Now that the drm core can do this, lets just use it, split the code out so TTM doesn't have to drag all of drmP.h in. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-15drm/radeon: add new RS880 pci idAlex Deucher
This should go to 2.6.33 stable as well. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01vga_switcheroo: fix build on platforms with no ACPIDave Airlie
radeon was always including the atpx code unnecessarily, also core switcheroo was including acpi headers. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01Merge branch 'gpu-switcher' of /ssd/git//linux-2.6 into drm-next-stageDave Airlie
* 'gpu-switcher' of /ssd/git//linux-2.6: vga_switcheroo: initial implementation (v15) fb: for framebuffer handover don't exit the loop early. Conflicts: drivers/gpu/drm/i915/i915_dma.c drivers/gpu/drm/radeon/Makefile drivers/gpu/drm/radeon/radeon.h
2010-03-01vga_switcheroo: initial implementation (v15)Dave Airlie
Many new laptops now come with 2 gpus, one to be used for low power modes and one for gaming/on-ac applications. These GPUs are typically wired to the laptop panel and VGA ports via a multiplexer unit which is controlled via ACPI methods. 4 combinations of systems typically exist - with 2 ACPI methods. Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method ATI/ATI - some ASUS - use ATPX ACPI Method Intel/Nvidia - - use _DSM ACPI method Nvidia/Nvidia - - use _DSM ACPI method. TODO: This patch adds support for the ATPX method and initial bits for the _DSM methods that need to written by someone with access to the hardware. Add a proper non-debugfs interface - need to get some proper testing first. v2: add power up/down support for both devices on W500 puts i915/radeon into D3 and cuts power to radeon. v3: redo probing methods, no DMI list, drm devices call to register with switcheroo, it tries to find an ATPX method on any device and once there is two devices + ATPX it inits the switcher. v4: ATPX msg handling using buffers - should work on more machines v5: rearchitect after more mjg59 discussion - move ATPX handling to radeon driver. v6: add file headers + initial nouveau bits (to be filled out). v7: merge delayed switcher code. v8: avoid suspend/resume of gpu that is off v9: rearchitect - mjg59 is always right. - move all ATPX code to radeon, should allow simpler DSM also proper ATRM handling v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv v11: fix bug in resuming Intel for 2nd time. v12: start fixing up nvidia code blindly. v13: blindly guess at finishing nvidia code v14: remove radeon audio hacks - fix up intel resume more like upstream v15: clean up printks + remove unnecessary igd/dis pointers mount debugfs /sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected + 2 cards. DIS - immediate change to discrete IGD - immediate change to IGD DDIS - delayed change to discrete DIGD - delayed change to IGD ON - turn on not in use OFF - turn off not in use Tested on W500 (Intel/ATI) and T500 (Intel/ATI) Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01Merge branch 'drm-radeon-testing' of /ssd/git/drm-radeon-next into ↵Dave Airlie
drm-next-stage * 'drm-radeon-testing' of /ssd/git/drm-radeon-next: drm/radeon: r100/r200 ums: block ability for userspace app to trash 0 page and beyond drm/ttm: fix function prototype to match implementation drm/radeon: use ALIGN instead of open coding it drm/radeon/kms: initialize set_surface_reg reg for rs600 asic
2010-03-01drm/ttm: fix function prototype to match implementationRandy Dunlap
Fix function prototype to match its actual usage and implementation. drivers/gpu/drm/ttm/ttm_bo_util.c:341:10: error: symbol 'ttm_io_prot' redeclared with different type (originally declared at include/drm/ttm/ttm_bo_driver.h:911) - incompatible argument 1 (different signedness) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Airlie <airlied@linux.ie> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01Merge remote branch 'anholt/drm-intel-next' into drm-next-stageDave Airlie
* anholt/drm-intel-next: (103 commits) drm/i915: Use a dmi quirk to skip a broken SDVO TV output. drm/i915: enable/disable LVDS port at DPMS time drm/i915: check for multiple write domains in pin_and_relocate drm/i915: clean-up i915_gem_flush_gpu_write_domain drm/i915: reuse i915_gpu_idle helper drm/i915: ensure lru ordering of fence_list drm/i915: extract fence stealing code drm/i915: fixup active list locking in object_unbind drm/i915: reuse i915_gem_object_put_fence_reg for fence stealing code drm/i915: Add dependency on the intel agp module drm/i915: More s/IS_IRONLAKE/HAS_PCH_SPLIT for Sandybridge. drm/i915: Correct the Sandybridge chipset info structs. drm/i915: Disable the hangcheck reset on Sandybridge until we add support. drm/i915: Add a new mobile Sandybridge PCI ID. agp/intel: Add a new Sandybridge HB/IG PCI ID combo. drm/i915, agp/intel: Fix stolen memory size on Sandybridge drm/i915: Correct locking in the modesetting failure path, fixing a BUG_ON. drm/i915: Disable the surface tile swizzling on Sandybridge. agp/intel: Use a non-reserved value for the cache field of the PTEs. drm/i915: Fix sandybridge status page setup. ...
2010-03-01Merge remote branch 'nouveau/for-airlied' into drm-next-stageDave Airlie
* nouveau/for-airlied: (25 commits) drm/nouveau: use ALIGN instead of open coding it drm/nouveau: report unknown connector state if lid closed drm/nouveau: support version 0x20 displayport tables drm/nouveau: Fix noaccel/nofbaccel option descriptions. drm/nv50: Implement ctxprog/state generation. drm/nouveau: use dcb connector types throughout the driver drm/nv50: enable hpd on any connector we know the gpio line for drm/nouveau: use dcb connector table for creating drm connectors drm/nouveau: construct a connector table for cards that lack a real one drm/nouveau: check for known dcb connector types drm/nouveau: parse dcb gpio/connector tables after encoders drm/nouveau: reorganise bios header, add dcb connector type enums drm/nouveau: merge nvbios and nouveau_bios_info drm/nouveau: merge parsed_dcb and bios_parsed_dcb into dcb_table drm/nouveau: rename parsed_dcb_gpio to dcb_gpio_table drm/nouveau: allow retrieval of vbios image from debugfs drm/nouveau: fix missing spin_unlock in failure path drm/nouveau: fix i2ctable bounds checking drm/nouveau: fix nouveau_i2c_find bounds checking drm/nouveau: fix pramdac_table range checking ... Conflicts: drivers/gpu/drm/nouveau/nouveau_gem.c
2010-03-01Merge remote branch 'korg/drm-core-next' into drm-next-stageDave Airlie
* korg/drm-core-next: drm/ttm: handle OOM in ttm_tt_swapout drm/radeon/kms/atom: fix shr/shl ops drm/kms: fix spelling of "CLOCK" drm/kms: fix fb_changed = true else statement drivers/gpu/drm/drm_fb_helper.c: don't use private implementation of atoi() drm: switch all GEM/KMS ioctls to unlocked ioctl status. Use drm_gem_object_[handle_]unreference_unlocked where possible drm: introduce drm_gem_object_[handle_]unreference_unlocked
2010-02-26drm/i915: Add initial bits for VGA modesetting bringup on Sandybridge.Eric Anholt
Signed-off-by: Eric Anholt <eric@anholt.net>
2010-02-26Merge remote branch 'korg/drm-radeon-testing' into drm-next-stageDave Airlie
* korg/drm-radeon-testing: (62 commits) drm/radeon/kms: update new pll algo drm/radeon/kms: add support for square microtiles on r3xx-r5xx drm/radeon/kms: force pinning buffer into visible VRAM drm/radeon/kms/evergreen: fix typo in cursor code drm/radeon/kms: implement reading active PCIE lanes on R600+ drm/radeon/kms: for downclocking non-mobility check PERFORMANCE state drm/radeon/kms: simplify storing current and requested PM mode drm/radeon: fixes for r6xx/r7xx gfx init drm/radeon/rv740: fix backend setup drm/radeon/kms: fix R3XX/R4XX memory controller initialization [rfc] drm/radeon/kms: pm debugging check for vbl. drm/radeon: Fix memory allocation failures in the preKMS command stream checking. drm: Add generic multipart buffer. drm/radeon/kms: simplify memory controller setup V2 drm/radeon: Add asic hook for dma copy to r200 cards. drm/radeon/kms: Create asic structure for r300 pcie cards. drm/radeon/kms: remove unused r600_gart_clear_page drm/radeon/kms: remove HDP flushes from fence emit (v2) drm/radeon/kms: add LVDS pll quirk for Dell Studio 15 drm/radeon/kms: simplify picking power state ... Conflicts: drivers/gpu/drm/radeon/atom.c drivers/gpu/drm/radeon/atombios.h drivers/gpu/drm/radeon/atombios_dp.c drivers/gpu/drm/radeon/r600.c drivers/gpu/drm/radeon/r600_audio.c drivers/gpu/drm/radeon/r600_cp.c drivers/gpu/drm/radeon/radeon.h drivers/gpu/drm/radeon/radeon_connectors.c drivers/gpu/drm/radeon/radeon_ring.c drivers/gpu/drm/radeon/rv770.c
2010-02-25drm/nouveau: new gem pushbuf interface, bump to 0.0.16Ben Skeggs
This commit breaks the userspace interface, and requires a new libdrm for nouveau to operate again. The multiple GEM_PUSHBUF ioctls that were present in 0.0.15 for compatibility purposes are now gone, and replaced with the new ioctl which allows for multiple push buffers to be submitted (necessary for hw index buffers in the nv50 3d driver) and relocations to be applied on any buffer. A number of other ioctls (CARD_INIT, GEM_PIN, GEM_UNPIN) that were needed for userspace modesetting have also been removed. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Francisco Jerez <currojerez@riseup.net>
2010-02-25Merge remote branch 'korg/drm-core-next' into drm-next-stageDave Airlie
2010-02-25drm/radeon/kms: add support for square microtiles on r3xx-r5xxMarek Olšák
Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-23Revert "block: improve queue_should_plug() by looking at IO depths"Jens Axboe
This reverts commit fb1e75389bd06fd5987e9cda1b4e0305c782f854. "Benjamin S." <sbenni@gmx.de> reports that the patch in question causes a big drop in sequential throughput for him, dropping from 200MB/sec down to only 70MB/sec. Needs to be investigated more fully, for now lets just revert the offending commit. Conflicts: include/linux/blkdev.h Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-23drm: Add generic multipart buffer.Pauli Nieminen
Allocating multiple pages of memory for data that is coming from user space may fail. To fix memory allocation failures the buffer object should be split to multiple independ pages. drm buffer provides generic interface to copy and process large data arrays from user space. Interface includes allocation and free functions to allocate the buffer object and data storage pages. All access operations are performed relative to a internal pointer which is advanced with drm_buffer_advance function. The buffer can be accessed using drm_buffer_pointer_to_XXX functions if it is known that requested object doesn't split over a page boundary. These functions don't do any error checking to maximize performance. If there is large object which could be split there is special drm_buffer_read_object function. drm_buffer_read_object takes a pointer as argument which is used as temporary store for data if it is split over boundary in the buffer. Signed-off-by: Pauli Nieminen <suokkos@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: CacheFiles: Fix a race in cachefiles_delete_object() vs rename vfs: don't call ima_file_check() unconditionally in nfsd_open() fs: inode - remove 8 bytes of padding on 64bits allowing 1 more objects/slab under slub Switch proc/self to nd_set_link() fix LOOKUP_FOLLOW on automount "symlinks"
2010-02-20ARM: 5951/1: ARM: fix documentation of the PrimeCell busLinus Walleij
This fixes the filepath encoded in <linux/amba/bus.h> and adds some documentation as to what this bus really means. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-19fs: inode - remove 8 bytes of padding on 64bits allowing 1 more objects/slab ↵Richard Kennedy
under slub This removes 8 bytes of padding from struct inode on 64bit builds, and so allows 1 more object/slab in the inode_cache when using slub. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> ---- patch against 2.6.33-rc8 compiled & tested on x86_64 AMDX2 I've been running this patch for over a week with no obvious problems regards Richard Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add KEY_RFKILL Input: i8042 - fix KBC jam during hibernate
2010-02-18Input: add KEY_RFKILLMatthew Garrett
Most laptops have keys that are intended to toggle all device state, not just wifi. These are currently generally mapped to KEY_WLAN. As a result, rfkill will only kill or enable wifi in response to the key press. This confuses users and can make it difficult for them to enable bluetooth and wwan devices. This patch adds a new keycode, KEY_RFKILL. It indicates that the system should toggle the state of all rfkillable devices. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-02-16kfifo: Don't use integer as NULL pointerAnton Vorontsov
This patch fixes following sparse warnings: include/linux/kfifo.h:127:25: warning: Using plain integer as NULL pointer kernel/kfifo.c:83:21: warning: Using plain integer as NULL pointer Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-15Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf top: Fix help text alignment perf: Fix hypervisor sample reporting perf: Make bp_len type to u64 generic across the arch
2010-02-11drm: introduce drm_gem_object_[handle_]unreference_unlockedLuca Barbieri
This patch introduces the drm_gem_object_unreference_unlocked and drm_gem_object_handle_unreference_unlocked functions that do not require holding struct_mutex. drm_gem_object_unreference_unlocked calls the new ->gem_free_object_unlocked entry point if available, and otherwise just takes struct_mutex and just calls ->gem_free_object Signed-off-by: Luca Barbieri <luca@luca-barbieri.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11Merge remote branch 'nouveau/for-airlied' of nouveau-2.6Dave Airlie
* 'nouveau/for-airlied' of /home/airlied/kernel/drm-next: nouveau: fix state detection with switchable graphics drm/nouveau: move dereferences after null checks drm/nv50: make the pgraph irq handler loop like the pre-nv50 version drm/nv50: delete ramfc object after disabling fifo, not before drm/nv50: avoid unloading pgraph context when ctxprog is running drm/nv50: align size of buffer object to the right boundaries. drm/nv50: disregard dac outputs in nv50_sor_dpms() drm/nv50: prevent multiple init tables being parsed at the same time drm/nouveau: make dp auxch xfer len check for reads only drm/nv40: make INIT_COMPUTE_MEM a NOP, just like nv50 drm/nouveau: Add proper vgaarb support. drm/nouveau: Fix fbcon on mixed pre-NV50 + NV50 multicard. drivers/gpu/drm/nouveau/nouveau_grctx.c: correct NULL test drm/nouveau: call ttm_bo_wait with the bo lock held to prevent hang drm/nouveau: Fixup semaphores on pre-nv50 cards. drm/nouveau: Add getparam to get available PGRAPH units. drm/nouveau: Add module options to disable acceleration. drm/nouveau: fix non-vram notifier blocks
2010-02-11drm/vmwgfx: Drop scanout flag compat and add execbuf ioctl parameter ↵Jakob Bornecrantz
members. Bumps major. Even if this bumps the version to 1 it does not mean the driver is out of staging. From what we know this is the last backwards incompatible change to the driver. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-11drm/vmwgfx: Update the user-space interface.Thomas Hellstrom
When time-based throttling is implemented, we need to bump minor. When the old way of detecting scanout is removed, we need to bump major. In the meantime, this change should not break existing user-space. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (29 commits) drivers/net: Correct NULL test MAINTAINERS: networking drivers - Add git net-next tree net/sched: Fix module name in Kconfig cxgb3: fix GRO checksum check dst: call cond_resched() in dst_gc_task() netfilter: nf_conntrack: fix hash resizing with namespaces netfilter: xtables: compat out of scope fix netfilter: nf_conntrack: restrict runtime expect hashsize modifications netfilter: nf_conntrack: per netns nf_conntrack_cachep netfilter: nf_conntrack: fix memory corruption with multiple namespaces Bluetooth: Keep a copy of each HID device's report descriptor pktgen: Fix freezing problem igb: make certain to reassign legacy interrupt vectors after reset irda: add missing BKL in irnet_ppp ioctl irda: unbalanced lock_kernel in irnet_ppp ixgbe: Fix return of invalid txq ixgbe: Fix ixgbe_tx_map error path netxen: protect resource cleanup by rtnl lock netxen: fix tx timeout recovery for NX2031 chip Bluetooth: Enter active mode before establishing a SCO link. ...
2010-02-09drm/nouveau: Add getparam to get available PGRAPH units.Marcin Kościelnicki
On nv50, this will be needed by applications using CUDA to know how much stack/local memory to allocate. Signed-off-by: Marcin Kościelnicki <koriakin@0x04.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-02-09drm/radeon/kms: add initial Evergreen support (Radeon HD 5xxx)Alex Deucher
This adds initial Evergreen KMS support, it doesn't include any acceleration features or interrupt handling yet. Major changes are DCE4 handling for PLLs for the > 2 crtcs. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-09drm/radeon/kms: add support for hardcoded edids in rom (v2)Alex Deucher
Some servers hardcode an edid in rom so that they will work properly with KVMs. This is a port of the relevant code from the ddx. [airlied: reworked to validate edid at boot stage - and remove special quirk, if there is a valid EDID in the BIOS rom we'll just try and use it.] Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-02-08netfilter: nf_conntrack: fix hash resizing with namespacesPatrick McHardy
As noticed by Jon Masters <jonathan@jonmasters.org>, the conntrack hash size is global and not per namespace, but modifiable at runtime through /sys/module/nf_conntrack/hashsize. Changing the hash size will only resize the hash in the current namespace however, so other namespaces will use an invalid hash size. This can cause crashes when enlarging the hashsize, or false negative lookups when shrinking it. Move the hash size into the per-namespace data and only use the global hash size to initialize the per-namespace value when instanciating a new namespace. Additionally restrict hash resizing to init_net for now as other namespaces are not handled currently. Cc: stable@kernel.org Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-08netfilter: nf_conntrack: per netns nf_conntrack_cachepEric Dumazet
nf_conntrack_cachep is currently shared by all netns instances, but because of SLAB_DESTROY_BY_RCU special semantics, this is wrong. If we use a shared slab cache, one object can instantly flight between one hash table (netns ONE) to another one (netns TWO), and concurrent reader (doing a lookup in netns ONE, 'finding' an object of netns TWO) can be fooled without notice, because no RCU grace period has to be observed between object freeing and its reuse. We dont have this problem with UDP/TCP slab caches because TCP/UDP hashtables are global to the machine (and each object has a pointer to its netns). If we use per netns conntrack hash tables, we also *must* use per netns conntrack slab caches, to guarantee an object can not escape from one namespace to another one. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> [Patrick: added unique slab name allocation] Cc: stable@kernel.org Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-02-07ima: rename ima_path_check to ima_file_checkMimi Zohar
ima_path_check actually deals with files! call it ima_file_check instead. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07fix ima breakageMimi Zohar
The "Untangling ima mess, part 2 with counters" patch messed up the counters. Based on conversations with Al Viro, this patch streamlines ima_path_check() by removing the counter maintaince. The counters are now updated independently, from measuring the file, in __dentry_open() and alloc_file() by calling ima_counts_get(). ima_path_check() is called from nfsd and do_filp_open(). It also did not measure all files that should have been measured. Reason: ima_path_check() got bogus value passed as mask. [AV: mea culpa] [AV: add missing nfsd bits] Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-05Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] Call flush_dcache_page after PIO data transfers in libata-sff.c ahci: add Acer G725 to broken suspend list libata: fix ata_id_logical_per_physical_sectors libata-scsi passthru: fix bug which truncated LBA48 return values
2010-02-05percpu: add __percpu for sparseStephen Rothwell
This is to make the annotation of percpu variables during the next merge window less painfull. Extracted from a patch by Rusty Russell. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-04Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Handle futex value corruption gracefully futex: Handle user space corruption gracefully futex_lock_pi() key refcnt fix softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resume
2010-02-04libata: fix ata_id_logical_per_physical_sectorsChristoph Hellwig
The value we get from the low byte of the ATA_ID_SECTOR_SIZE word is not not a plain multiple, but the log of it, so fix the helper to give the correct answer. Without this we'll get an incorrect minimal I/O size in the block limits VPD page for 4k sector drives. Also change the return value of ata_id_logical_per_physical_sectors to u16 for the unlikely case of very large logical sectors. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-02-04perf: Make bp_len type to u64 generic across the archMahesh Salgaonkar
Change 'bp_len' type to __u64 to make it work across archs as the s390 architecture watch point length can be upto 2^64. reference: http://lkml.org/lkml/2010/1/25/212 This is an ABI change that is not backward compatible with the previous hardware breakpoint info layout integrated in this development cycle, a rebuilt of perf tools is necessary for versions based on 2.6.33-rc1 - 2.6.33-rc6 to work with a kernel based on this patch. Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "K. Prasad" <prasad@linux.vnet.ibm.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin <schwidefsky@de.ibm.com> LKML-Reference: <20100130045518.GA20776@in.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits) connector: Delete buggy notification code. be2net: use eq-id to calculate cev-isr reg offset Bluetooth: Use the control channel for raw HID reports Bluetooth: Add DFU driver for Atheros Bluetooth chipset AR3011 Bluetooth: Redo checks in IRQ handler for shared IRQ support Bluetooth: Fix memory leak in L2CAP Bluetooth: Remove double free of SKB pointer in L2CAP cdc_ether: Partially revert "usbnet: Set link down initially ..." be2net: Fix memset() arg ordering. bonding: bond_open error return value ixgbe: if ixgbe_copy_dcb_cfg is going to fail learn about it early ixgbe: set the correct DCB bit for pg tx settings igbvf: fix issue w/ mapped_as_page being left set after unmap drivers/net: ks8851_mll ethernet network driver be2net: Bug fix to support newer generation of BE ASIC starfire: clean up properly if firmware loading fails mac80211: fix NULL pointer dereference when ftrace is enabled netfilter: ctnetlink: fix expectation mask dump ipv6: conntrack: Add member of user to nf_ct_frag6_queue structure ath9k: fix eeprom INI values override for 2GHz-only cards ...
2010-02-02connector: Delete buggy notification code.Evgeniy Polyakov
On Tue, Feb 02, 2010 at 02:57:14PM -0800, Greg KH (gregkh@suse.de) wrote: > > There are at least two ways to fix it: using a big cannon and a small > > one. The former way is to disable notification registration, since it is > > not used by anyone at all. Second way is to check whether calling > > process is root and its destination group is -1 (kind of priveledged > > one) before command is dispatched to workqueue. > > Well if no one is using it, removing it makes the most sense, right? > > No objection from me, care to make up a patch either way for this? Getting it is not used, let's drop support for notifications about (un)registered events from connector. Another option was to check credentials on receiving, but we can always restore it without bugs if needed, but genetlink has a wider code base and none complained, that userspace can not get notification when some other clients were (un)registered. Kudos for Sebastian Krahmer <krahmer@suse.de>, who found a bug in the code. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-01Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: Fix oops after radeon_cs_parser_init() failure. drm/radeon/kms: move radeon KMS on/off switch out of staging. drm/radeon/kms: Bailout of blit if error happen & protect with mutex V3 drm/vmwgfx: Don't send bad flags to the host drm/vmwgfx: Request SVGA version 2 and bail if not found drm/vmwgfx: Correctly detect 3D drm/ttm: remove unnecessary save_flags and ttm_flag_masked in ttm_bo_util.c drm/kms: Remove incorrect comment in struct drm_mode_modeinfo drm/ttm: remove padding from ttm_ref_object on 64bit builds drm/radeon/kms: release agp on error. drm/kms/radeon/agp: Move the check of the aper_size after drm_acp_acquire and drm_agp_info drm/kms/radeon/agp: Fix warning, format ‘%d’ expects type ‘int’, but argument 4 has type ‘size_t’ drm/ttm: Avoid conflicting reserve_memtype during ttm_tt_set_page_caching. drm/kms/radeon: pick digitial encoders smarter. (v3) drm/radeon/kms: use active device to pick connector for encoder drm/radeon/kms: fix incorrect logic in DP vs eDP connector checking.
2010-02-01Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, hw_breakpoint, kgdb: Do not take mutex for kernel debugger x86, hw_breakpoints, kgdb: Fix kgdb to use hw_breakpoint API hw_breakpoints: Release the bp slot if arch_validate_hwbkpt_settings() fails. perf: Ignore perf.data.old perf report: Fix segmentation fault when running with '-g none'
2010-02-01Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: TIF_ABI_PENDING bit removal powerpc/pseries: Fix xics build without CONFIG_SMP powerpc/4xx: Add pcix type 1 transactions powerpc/pci: Add missing call to header fixup powerpc/pci: Add missing hookup to pci_slot powerpc/pci: Add calls to set_pcie_port_type() and set_pcie_hotplug_bridge() powerpc/40x: Update the PowerPC 40x board defconfigs powerpc/44x: Update PowerPC 44x board defconfigs
2010-02-01softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resumeJason Wessel
When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, sched_clock() gets the time from hardware such as the TSC on x86. In this configuration kgdb will report a softlock warning message on resuming or detaching from a debug session. Sequence of events in the problem case: 1) "cpu sched clock" and "hardware time" are at 100 sec prior to a call to kgdb_handle_exception() 2) Debugger waits in kgdb_handle_exception() for 80 sec and on exit the following is called ... touch_softlockup_watchdog() --> __raw_get_cpu_var(touch_timestamp) = 0; 3) "cpu sched clock" = 100s (it was not updated, because the interrupt was disabled in kgdb) but the "hardware time" = 180 sec 4) The first timer interrupt after resuming from kgdb_handle_exception updates the watchdog from the "cpu sched clock" update_process_times() { ... run_local_timers() --> softlockup_tick() --> check (touch_timestamp == 0) (it is "YES" here, we have set "touch_timestamp = 0" at kgdb) --> __touch_softlockup_watchdog() ***(A)--> reset "touch_timestamp" to "get_timestamp()" (Here, the "touch_timestamp" will still be set to 100s.) ... scheduler_tick() ***(B)--> sched_clock_tick() (update "cpu sched clock" to "hardware time" = 180s) ... } 5) The Second timer interrupt handler appears to have a large jump and trips the softlockup warning. update_process_times() { ... run_local_timers() --> softlockup_tick() --> "cpu sched clock" - "touch_timestamp" = 180s-100s > 60s --> printk "soft lockup error messages" ... } note: ***(A) reset "touch_timestamp" to "get_timestamp(this_cpu)" Why is "touch_timestamp" 100 sec, instead of 180 sec? When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, the call trace of get_timestamp() is: get_timestamp(this_cpu) -->cpu_clock(this_cpu) -->sched_clock_cpu(this_cpu) -->__update_sched_clock(sched_clock_data, now) The __update_sched_clock() function uses the GTOD tick value to create a window to normalize the "now" values. So if "now" value is too big for sched_clock_data, it will be ignored. The fix is to invoke sched_clock_tick() to update "cpu sched clock" in order to recover from this state. This is done by introducing the function touch_softlockup_watchdog_sync(). This allows kgdb to request that the sched clock is updated when the watchdog thread runs the first time after a resume from kgdb. [yong.zhang0@gmail.com: Use per cpu instead of an array] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Dongdong Deng <Dongdong.Deng@windriver.com> Cc: kgdb-bugreport@lists.sourceforge.net Cc: peterz@infradead.org LKML-Reference: <1264631124-4837-2-git-send-email-jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-01drm/kms: Remove incorrect comment in struct drm_mode_modeinfoMarcin Kościelnicki
2010-01-30perf, hw_breakpoint, kgdb: Do not take mutex for kernel debuggerJason Wessel
This patch fixes the regression in functionality where the kernel debugger and the perf API do not nicely share hw breakpoint reservations. The kernel debugger cannot use any mutex_lock() calls because it can start the kernel running from an invalid context. A mutex free version of the reservation API needed to get created for the kernel debugger to safely update hw breakpoint reservations. The possibility for a breakpoint reservation to be concurrently processed at the time that kgdb interrupts the system is improbable. Should this corner case occur the end user is warned, and the kernel debugger will prohibit updating the hardware breakpoint reservations. Any time the kernel debugger reserves a hardware breakpoint it will be a system wide reservation. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: kgdb-bugreport@lists.sourceforge.net Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: torvalds@linux-foundation.org LKML-Reference: <1264719883-7285-3-git-send-email-jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
