[ Upstream commit 4dcb31d4649df36297296b819437709f5407059c ]
Andrei Vagin reported a KASAN: slab-out-of-bounds error in
skb_update_prio()
Since SYNACK might be attached to a request socket, we need to
get back to the listener socket.
Since this listener is manipulated without locks, add const
qualifiers to sock_cgroup_prioidx() so that the const can also
be used in skb_update_prio()
Also add the const qualifier to sock_cgroup_classid() for consistency.
Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener")
Reported-by: Andrei Vagin <avagin@virtuozzo.com>
[ Upstream commit 35d889d10b649fda66121891ec05eca88150059d ]
When we exceed current packets limit and we have more than one
segment in the list returned by skb_gso_segment(), netem drops
only the first one, skipping the rest, hence kmemleak reports:
unreferenced object 0xffff880b5d23b600 (size 1024):
comm "softirq", pid 0, jiffies 4384527763 (age 2770.629s)
hex dump (first 32 bytes):
00 80 23 5d 0b 88 ff ff 00 00 00 00 00 00 00 00 ..#]............
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<00000000d8a19b9d>] __alloc_skb+0xc9/0x520
[<000000001709b32f>] skb_segment+0x8c8/0x3710
[<00000000c7b9bb88>] tcp_gso_segment+0x331/0x1830
[<00000000c921cba1>] inet_gso_segment+0x476/0x1370
[<000000008b762dd4>] skb_mac_gso_segment+0x1f9/0x510
[<000000002182660a>] __skb_gso_segment+0x1dd/0x620
[<00000000412651b9>] netem_enqueue+0x1536/0x2590 [sch_netem]
[<0000000005d3b2a9>] __dev_queue_xmit+0x1167/0x2120
[<00000000fc5f7327>] ip_finish_output2+0x998/0xf00
[<00000000d309e9d3>] ip_output+0x1aa/0x2c0
[<000000007ecbd3a4>] tcp_transmit_skb+0x18db/0x3670
[<0000000042d2a45f>] tcp_write_xmit+0x4d4/0x58c0
[<0000000056a44199>] tcp_tasklet_func+0x3d9/0x540
[<0000000013d06d02>] tasklet_action+0x1ca/0x250
[<00000000fcde0b8b>] __do_softirq+0x1b4/0x5a3
[<00000000e7ed027c>] irq_exit+0x1e2/0x210
Fix it by adding the rest of the segments, if any, to skb 'to_free'
list. Add new __qdisc_drop_all() and qdisc_drop_all() functions
because they can be useful in the future if we need to drop segmented
GSO packets in other places.
Fixes: 6071bd1aa13e ("netem: Segment GSO packets on enqueue")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit d3dcf8eb615537526bd42ff27a081d46d337816e ]
When inserting duplicate objects (those with the same key),
current rhlist implementation messes up the chain pointers by
updating the bucket pointer instead of prev next pointer to the
newly inserted node. This causes missing elements on removal and
travesal.
Fix that by properly updating pprev pointer to point to
the correct rhash_head next pointer.
Issue: 1241076
Change-Id: I86b2c140bcb4aeb10b70a72a267ff590bb2b17e7
Fixes: ca26893f05e8 ('rhashtable: Add rhlist interface')
Signed-off-by: Paul Blakey <paulb@mellanox.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 6b00c35138b404be98b85f4a703be594cbed501c upstream.
Due to missing information in Hardware manual, current
implementation doesn't read ECCSTAT0 and ECCSTAT1 registers
for IFC 2.0.
Add support to read ECCSTAT0 and ECCSTAT1 registers during
ecccheck for IFC 2.0.
Fixes: 656441478ed5 ("mtd: nand: ifc: Fix location of eccstat registers for IFC V1.0")
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream.
On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may
create pud/pmd mappings. A kernel panic was observed on arm64 systems
with Cortex-A75 in the following steps as described by Hanjun Guo.
1. ioremap a 4K size, valid page table will build,
2. iounmap it, pte0 will set to 0;
3. ioremap the same address with 2M size, pgd/pmd is unchanged,
then set the a new value for pmd;
4. pte0 is leaked;
5. CPU may meet exception because the old pmd is still in TLB,
which will lead to kernel panic.
This panic is not reproducible on x86. INVLPG, called from iounmap,
purges all levels of entries associated with purged address on x86. x86
still has memory leak.
The patch changes the ioremap path to free unmapped page table(s) since
doing so in the unmap path has the following issues:
- The iounmap() path is shared with vunmap(). Since vmap() only
supports pte mappings, making vunmap() to free a pte page is an
overhead for regular vmap users as they do not need a pte page freed
up.
- Checking if all entries in a pte page are cleared in the unmap path
is racy, and serializing this check is expensive.
- The unmap path calls free_vmap_area_noflush() to do lazy TLB purges.
Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB
purge.
Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which
clear a given pud/pmd entry and free up a page for the lower level
entries.
This patch implements their stub functions on x86 and arm64, which work
as workaround.
[akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub]
Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com
Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings")
Reported-by: Lei Li <lious.lilei@hisilicon.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Wang Xuefeng <wxf.wang@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Chintan Pandya <cpandya@codeaurora.org>
Cc: <stable@vger.kernel.org>
commit a6618f4aedb2b60932d766bd82ae7ce866e842aa upstream.
Currently, the offsets in the UAC2 processing unit descriptor are
calculated incorrectly. It causes an issue when connecting the device which
provides such a feature:
[84126.724420] usb 1-1.3.1: invalid Processing Unit descriptor (id 18)
After this patch is applied, the UAC2 processing unit inits w/o this error.
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
Signed-off-by: Kirill Marinushkin <k.marinushkin@gmail.com>
commit c2b37f76485f073f020e60b5954b6dc4e55f693c upstream.
This patch validates user provided input to prevent integer overflow due
to integer manipulation in the mlx5_ib_create_srq function.
Cc: syzkaller <syzkaller@googlegroups.com>
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Signed-off-by: Boris Pismenny <borisp@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 8b8642af15ed14b9a7a34d3401afbcc274533e13 ]
Since commit 5093bb965a163 ("powerpc/QE: switch to the cpm_muram
implementation"), muram area is not part of immrbar mapping anymore
so immrbar_virt_to_phys() is not usable anymore.
Fixes: 5093bb965a163 ("powerpc/QE: switch to the cpm_muram implementation")
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Acked-by: Li Yang <pku.leo@gmail.com>
Signed-off-by: Scott Wood <oss@buserror.net>
[ Upstream commit bb1e23e66e6237ff7a1824b37366540a89149c33 ]
ACPICA commit 637b88de24a78c20478728d9d66632b06fcaa5bf
If the IORT template is compiled and then iort.aml binary disassembled to
iort.dsl, SMMUv1 node lists incorrect offset for SMMU_Nsg_cfg_irpt Interrupt:
[0ECh 0236 8] SMMU_Nsg_irpt Interrupt : 0000000000000000
[0ECh 0236 8] SMMU_Nsg_cfg_irpt Interrupt : 0000000000000000
This is because iasl hasn't implemented SMMU GSI decoding yet.
This patch fixes this issue by preparing structures for decoding IORT SMMU
GSI. ACPICA BZ 1340, reported by Alexei Fedorov, fixed by Lv Zheng.
Link: https://github.com/acpica/acpica/commit/637b88de
Link: https://bugs.acpica.org/show_bug.cgi?id=1340
Reported-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
[ Upstream commit d340266e19ddb70dbd608f9deedcfb35fdb9d419 ]
struct timespec is not y2038 safe on 32 bit machines.
The posix clocks apis use struct timespec directly and through struct
itimerspec.
Replace the posix clock interfaces to use struct timespec64 and struct
itimerspec64 instead. Also fix up their implementations accordingly.
Note that the clock_getres() interface has also been changed to use
timespec64 even though this particular interface is not affected by the
y2038 problem. This helps verification for internal kernel code for y2038
readiness by getting rid of time_t/ timeval/ timespec.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: arnd@arndb.de
Cc: y2038@lists.linaro.org
Cc: netdev@vger.kernel.org
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: john.stultz@linaro.org
Link: http://lkml.kernel.org/r/1490555058-4603-3-git-send-email-deepa.kernel@gmail.com
commit 95dd77580ccd66a0da96e6d4696945b8cea39431 upstream.
On nfsv2 and nfsv3 the nfs server can export subsets of the same
filesystem and report the same filesystem identifier, so that the nfs
client can know they are the same filesystem. The subsets can be from
disjoint directory trees. The nfsv2 and nfsv3 filesystems provides no
way to find the common root of all directory trees exported form the
server with the same filesystem identifier.
The practical result is that in struct super s_root for nfs s_root is
not necessarily the root of the filesystem. The nfs mount code sets
s_root to the root of the first subset of the nfs filesystem that the
kernel mounts.
This effects the dcache invalidation code in generic_shutdown_super
currently called shrunk_dcache_for_umount and that code for years
has gone through an additional list of dentries that might be dentry
trees that need to be freed to accomodate nfs.
When I wrote path_connected I did not realize nfs was so special, and
it's hueristic for avoiding calling is_subdir can fail.
The practical case where this fails is when there is a move of a
directory from the subtree exposed by one nfs mount to the subtree
exposed by another nfs mount. This move can happen either locally or
remotely. With the remote case requiring that the move directory be cached
before the move and that after the move someone walks the path
to where the move directory now exists and in so doing causes the
already cached directory to be moved in the dcache through the magic
of d_splice_alias.
If someone whose working directory is in the move directory or a
subdirectory and now starts calling .. from the initial mount of nfs
(where s_root == mnt_root), then path_connected as a heuristic will
not bother with the is_subdir check. As s_root really is not the root
of the nfs filesystem this heuristic is wrong, and the path may
actually not be connected and path_connected can fail.
The is_subdir function might be cheap enough that we can call it
unconditionally. Verifying that will take some benchmarking and
the result may not be the same on all kernels this fix needs
to be backported to. So I am avoiding that for now.
Filesystems with snapshots such as nilfs and btrfs do something
similar. But as the directory tree of the snapshots are disjoint
from one another and from the main directory tree rename won't move
things between them and this problem will not occur.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Fixes: 397d425dc26d ("vfs: Test for and handle paths that are unreachable from their mnt_root")
[ Upstream commit 0c08aaf873174c95e674cf21ffcd041c589d2e5b ]
ISL9305_MAX_REGULATOR is the last index used to access the init_data[]
array, so we need to add one to this last index to obtain the necessary
array size.
This fixes the following smatch error:
drivers/regulator/isl9305.c:160 isl9305_i2c_probe() error: buffer overflow 'pdata->init_data' 3 <= 3
Fixes: dec38b5ce6a9edb4 ("regulator: isl9305: Add Intersil ISL9305/H driver")
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Cc: Mark Brown <broonie@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit fd086045559d90cd7854818b4c60a7119eda6231 ]
Commit 26988efe11b1 ("regulator: core: Allow to get voltage count and
list from parent") introduces the propagation of the parent voltage
count and list for regulators that don't provide this information
themselves. The goal is to support simple switch regulators, however as
a side effect normal continuous regulators can leak details of their
supplies and provide consumers with inconsistent information.
Limit the propagation of the voltage count and list to switch
regulators.
Fixes: 26988efe11b1 ("regulator: core: Allow to get voltage count and
list from parent")
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
commit 1764f8081f1524bf629e0744b277db751281ff56 upstream.
Add the missing module clock for the second channel of the display unit.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit 591a3d7c09fa08baff48ad86c2347dbd28a52753 ]
0day testing by Fengguang Wu triggered this crash while running Trinity:
kernel BUG at include/linux/pagemap.h:151!
CPU: 0 PID: 458 Comm: trinity-c0 Not tainted 4.11.0-rc2-00251-g2947ba0 #1
Call Trace:
__get_user_pages_fast()
get_futex_key()
futex_requeue()
do_futex()
SyS_futex()
do_syscall_64()
entry_SYSCALL64_slow_path()
It' VM_BUG_ON() due to false-negative in_atomic(). We call
page_cache_get_speculative() with disabled local interrupts.
It should be atomic enough.
So let's check for disabled interrupts in the VM_BUG_ON() condition
too, to resolve this.
( This got triggered by the conversion of the x86 GUP code to the
generic GUP code. )
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: LKP <lkp@01.org>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20170324114709.pcytvyb3d6ajux33@black.fi.intel.com
[ Upstream commit c48367427a39ea0b85c7cf018fe4256627abfd9e ]
Because sysctl_tcp_adv_win_scale could be changed any time, so there
is one race in tcp_win_from_space.
For example,
1.sysctl_tcp_adv_win_scale<=0 (sysctl_tcp_adv_win_scale is negative now)
2.space>>(-sysctl_tcp_adv_win_scale) (sysctl_tcp_adv_win_scale is postive now)
As a result, tcp_win_from_space returns 0. It is unexpected.
Certainly if the compiler put the sysctl_tcp_adv_win_scale into one
register firstly, then use the register directly, it would be ok.
But we could not depend on the compiler behavior.
Signed-off-by: Gao Feng <fgao@ikuai8.com>
[ Upstream commit 6f051e4a685b768f3704c7c069aa1edee3010622 ]
[resend due to me forgetting to cc: linux-api the first time around I
posted these back on Feb 23]
From: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
When userspace tries to use these defines, it complains that it needs to
be an unsigned 1 that is shifted, so libc implementations have to create
their own version. Fix this by defining it properly so that libcs can
just use the kernel uapi header.
Reported-by: Elliott Hughes <enh@google.com>
commit cb88a0588717ba6c756cb5972d75766b273a6817 upstream.
Corsair Strafe RGB keyboard does not respond to usb control messages
sometimes and hence generates timeouts.
Commit de3af5bf259d ("usb: quirks: add delay init quirk for Corsair
Strafe RGB keyboard") tried to fix those timeouts by adding
USB_QUIRK_DELAY_INIT.
Unfortunately, even with this quirk timeouts of usb_control_msg()
can still be seen, but with a lower frequency (approx. 1 out of 15):
[ 29.103520] usb 1-8: string descriptor 0 read error: -110
[ 34.363097] usb 1-8: can't set config #1, error -110
Adding further delays to different locations where usb control
messages are issued just moves the timeouts to other locations,
e.g.:
[ 35.400533] usbhid 1-8:1.0: can't add hid device: -110
[ 35.401014] usbhid: probe of 1-8:1.0 failed with error -110
The only way to reliably avoid those issues is having a pause after
each usb control message. In approx. 200 boot cycles no more timeouts
were seen.
Addionaly, keep USB_QUIRK_DELAY_INIT as it turned out to be necessary
to have the delay in hub_port_connect() after hub_port_init().
The overall boot time seems not to be influenced by these additional
delays, even on fast machines and lightweight distributions.
Fixes: de3af5bf259d ("usb: quirks: add delay init quirk for Corsair Strafe RGB keyboard")
Signed-off-by: Danilo Krummrich <danilokrummrich@dk-develop.de>
commit ae0ac0ed6fcf5af3be0f63eb935f483f44a402d2 upstream.
instead of allocating each xt_counter individually, allocate 4k chunks
and then use these for counter allocation requests.
This should speed up rule evaluation by increasing data locality,
also speeds up ruleset loading because we reduce calls to the percpu
allocator.
As Eric points out we can't use PAGE_SIZE, page_allocator would fail on
arches with 64k page size.
Suggested-by: Eric Dumazet <edumazet@google.com>
commit f28e15bacedd444608e25421c72eb2cf4527c9ca upstream.
Keeps some noise away from a followup patch.
commit 4d31eef5176df06f218201bc9c0ce40babb41660 upstream.
On SMP we overload the packet counter (unsigned long) to contain
percpu offset. Hide this from callers and pass xt_counters address
instead.
Preparation patch to allocate the percpu counters in page-sized batch
chunks.
commit 87358710c1fb4f1bf96bbe2349975ff9953fc9b2 upstream.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: arjan.van.de.ven@intel.com
Cc: bp@alien8.de
Cc: dave.hansen@intel.com
Cc: jmattson@google.com
Cc: karahmed@amazon.de
Cc: kvm@vger.kernel.org
Cc: pbonzini@redhat.com
Cc: rkrcmar@redhat.com
Link: http://lkml.kernel.org/r/1519037457-7643-5-git-send-email-dwmw@amazon.co.uk
commit eb6174f6d1be16b19cfa43dac296bfed003ce1a6 upstream.
The nospec.h header expects the per-architecture header file
<asm/barrier.h> to optionally define array_index_mask_nospec(). Include
that dependency to prevent inadvertent fallback to the default
array_index_mask_nospec() implementation.
The default implementation may not provide a full mitigation
on architectures that perform data value speculation.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/151881605404.17395.1341935530792574707.stgit@dwillia2-desk3.amr.corp.intel.com
commit 1d91c1d2c80cb70e2e553845e278b87a960c04da upstream.
There are multiple problems with the dynamic sanity checking in
array_index_nospec_mask_check():
* It causes unnecessary overhead in the 32-bit case since integer sized
@index values will no longer cause the check to be compiled away like
in the 64-bit case.
* In the 32-bit case it may trigger with user controllable input when
the expectation is that should only trigger during development of new
kernel enabling.
* The macro reuses the input parameter in multiple locations which is
broken if someone passes an expression like 'index++' to
array_index_nospec().
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/151881604278.17395.6605847763178076520.stgit@dwillia2-desk3.amr.corp.intel.com
commit 25c058ccaf2ebbc3e250ec1e199e161f91fe27d4 upstream.
Introduce a helper to determine if the current task is an output poll
worker.
This allows us to fix a long-standing deadlock in several DRM drivers
wherein the ->runtime_suspend callback waits for the output poll worker
to finish and the worker in turn calls a ->detect callback which waits
for runtime suspend to finish. The ->detect callback is invoked from
multiple call sites and waiting for runtime suspend to finish is the
correct thing to do except if it's executing in the context of the
worker.
v2: Expand kerneldoc to specifically mention deadlock between
output poll worker and autosuspend worker as use case. (Lyude)
Cc: Dave Airlie <airlied@redhat.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Lyude Paul <lyude@redhat.com>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Link: https://patchwork.freedesktop.org/patch/msgid/3549ce32e7f1467102e70d3e9cbf70c46bfe108e.1518593424.git.lukas@wunner.de
commit 27d4ee03078aba88c5e07dcc4917e8d01d046f38 upstream.
Introduce a helper to retrieve the current task's work struct if it is
a workqueue worker.
wherein the ->runtime_suspend callback waits for a specific worker to
finish and that worker in turn calls a function which waits for runtime
suspend to finish. That function is invoked from multiple call sites
and waiting for runtime suspend to finish is the correct thing to do
except if it's executing in the context of the worker.
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: https://patchwork.freedesktop.org/patch/msgid/2d8f603074131eb87e588d2b803a71765bd3a2fd.1518338788.git.lukas@wunner.de
[ Upstream commit 15f35d49c93f4fa9875235e7bf3e3783d2dd7a1b ]
Since UDP-Lite is always using checksum, the following path is
triggered when calculating pseudo header for it:
udp4_csum_init() or udp6_csum_init()
skb_checksum_init_zero_check()
__skb_checksum_validate_complete()
The problem can appear if skb->len is less than CHECKSUM_BREAK. In
this particular case __skb_checksum_validate_complete() also invokes
__skb_checksum_complete(skb). If UDP-Lite is using partial checksum
that covers only part of a packet, the function will return bad
checksum and the packet will be dropped.
It can be fixed if we skip skb_checksum_init_zero_check() and only
set the required pseudo header checksum for UDP-Lite with partial
checksum before udp4_csum_init()/udp6_csum_init() functions return.
Fixes: ed70fcfcee95 ("net: Call skb_checksum_init in IPv4")
Fixes: e4f45b7f40bd ("net: Call skb_checksum_init in IPv6")
commit b98c6a160a057d5686a8c54c79cc6c8c94a7d0c8 upstream.
The last expression in a statement expression need not be a bare
variable, quoting gcc docs
The last thing in the compound statement should be an expression
followed by a semicolon; the value of this subexpression serves as the
value of the entire construct.
and we already use that in e.g. the min/max macros which end with a
ternary expression.
This way, we can allow index to have const-qualified type, which will in
some cases avoid the need for introducing a local copy of index of
non-const qualified type. That, in turn, can prevent readers not
familiar with the internals of array_index_nospec from wondering about
the seemingly redundant extra variable, and I think that's worthwhile
considering how confusing the whole _nospec business is.
The expression _i&_mask has type unsigned long (since that is the type
of _mask, and the BUILD_BUG_ONs guarantee that _i will get promoted to
that), so in order not to change the type of the whole expression, add
a cast back to typeof(_i).
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/151881604837.17395.10812767547837568328.stgit@dwillia2-desk3.amr.corp.intel.com
commit 230f5a8969d8345fc9bbe3683f068246cf1be4b8 upstream.
Gerd reports that ->i_mode may contain other bits besides S_IFCHR. Use
S_ISCHR() instead. Otherwise, get_user_pages_longterm() may fail on
device-dax instances when those are meant to be explicitly allowed.
Fixes: 2bb6d2837083 ("mm: introduce get_user_pages_longterm")
Reported-by: Gerd Rausch <gerd.rausch@oracle.com>
Acked-by: Jane Chu <jane.chu@oracle.com>
Reported-by: Haozhong Zhang <haozhong.zhang@intel.com>
[ Upstream commit c0bace798436bca0fdc221ff61143f1376a9c3de ]
libc-compat.h aims to prevent symbol collisions between uapi and libc
headers for each supported libc. This requires continuous coordination
between them.
The goal of this commit is to improve the situation for libcs (such as
musl) which are not yet supported and/or do not wish to be explicitly
supported, while not affecting supported libcs. More precisely, with
this commit, unsupported libcs can request the suppression of any
specific uapi definition by defining the correspondings _UAPI_DEF_*
macro as 0. This can fix symbol collisions for them, as long as the
libc headers are included before the uapi headers. Inclusion in the
other order is outside the scope of this commit.
All infrastructure in order to enable this fallback for unsupported
libcs is already in place, except that libc-compat.h unconditionally
defines all _UAPI_DEF_* macros to 1 for all unsupported libcs so that
any previous definitions are ignored. In order to fix this, this commit
merely makes these definitions conditional.
This commit together with the musl libc commit
http://git.musl-libc.org/cgit/musl/commit/?id=04983f2272382af92eb8f8838964ff944fbb8258
fixes for example the following compiler errors when <linux/in6.h> is
included after musl's <netinet/in.h>:
./linux/in6.h:32:8: error: redefinition of 'struct in6_addr'
./linux/in6.h:49:8: error: redefinition of 'struct sockaddr_in6'
./linux/in6.h:59:8: error: redefinition of 'struct ipv6_mreq'
The comments referencing glibc are still correct, but this file is not
only used for glibc any more.
Signed-off-by: Felix Janda <felix.janda@posteo.de>
Reviewed-by: Hauke Mehrtens <hauke@hauke-m.de>
commit 41fce90f26333c4fa82e8e43b9ace86c4e8a0120 upstream.
The following namespace configuration attempt:
# ndctl create-namespace -e namespace0.0 -m devdax -a 1G -f
libndctl: ndctl_dax_enable: dax0.1: failed to enable
Error: namespace0.0: failed to enable
failed to reconfigure namespace: No such device or address
...fails when the backing memory range is not physically aligned to 1G:
# cat /proc/iomem | grep Persistent
210000000-30fffffff : Persistent Memory (legacy)
In the above example the 4G persistent memory range starts and ends on a
256MB boundary.
We handle this case correctly when needing to handle cases that violate
section alignment (128MB) collisions against "System RAM", and we simply
need to extend that padding/truncation for the 1GB alignment use case.
Fixes: 315c562536c4 ("libnvdimm, pfn: add 'align' attribute...")
Reported-and-tested-by: Jane Chu <jane.chu@oracle.com>
commit 2bb6d2837083de722bfdc369cb0d76ce188dd9b4 upstream.
Patch series "introduce get_user_pages_longterm()", v2.
Here is a new get_user_pages api for cases where a driver intends to
keep an elevated page count indefinitely. This is distinct from usages
like iov_iter_get_pages where the elevated page counts are transient.
The iov_iter_get_pages cases immediately turn around and submit the
pages to a device driver which will put_page when the i/o operation
completes (under kernel control).
In the longterm case userspace is responsible for dropping the page
reference at some undefined point in the future. This is untenable for
filesystem-dax case where the filesystem is in control of the lifetime
of the block / page and needs reasonable limits on how long it can wait
for pages in a mapping to become idle.
Fixing filesystems to actually wait for dax pages to be idle before
blocks from a truncate/hole-punch operation are repurposed is saved for
a later patch series.
Also, allowing longterm registration of dax mappings is a future patch
series that introduces a "map with lease" semantic where the kernel can
revoke a lease and force userspace to drop its page references.
I have also tagged these for -stable to purposely break cases that might
assume that longterm memory registrations for filesystem-dax mappings
were supported by the kernel. The behavior regression this policy
change implies is one of the reasons we maintain the "dax enabled.
Warning: EXPERIMENTAL, use at your own risk" notification when mounting
a filesystem in dax mode.
It is worth noting the device-dax interface does not suffer the same
constraints since it does not support file space management operations
like hole-punch.
This patch (of 4):
Until there is a solution to the dma-to-dax vs truncate problem it is
not safe to allow long standing memory registrations against
filesytem-dax vmas. Device-dax vmas do not have this problem and are
explicitly allowed.
This is temporary until a "memory registration with layout-lease"
mechanism can be implemented for the affected sub-systems (RDMA and
V4L2).
[akpm@linux-foundation.org: use kcalloc()]
Link: http://lkml.kernel.org/r/151068939435.7446.13560129395419350737.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: 3565fce3a659 ("mm, x86: get_user_pages() for dax mappings")
Suggested-by: Christoph Hellwig <hch@lst.de>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Seung-Woo Kim <sw0312.kim@samsung.com>
commit de5bbdd01cf9ee3cd4586b5a970d3ea015c6d7e3 upstream.
pci_host_common_probe() is defined when CONFIG_PCI_HOST_COMMON=y;
therefore the function declaration should match that.
drivers/pci/host/pcie-tango.c:300:9: error:
implicit declaration of function 'pci_host_common_probe'
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 975b820b6836b6b6c42fb84cd2e772e2b41bca67 ]
In some cases the clock parent would be set NULL when doing re-parent,
it will cause a NULL pointer accessing if clk_set trace event is
enabled.
This patch sets the parent as "none" if the input parameter is NULL.
Fixes: dfc202ead312 (clk: Add tracepoints for hardware operations)
Signed-off-by: Cai Li <cai.li@spreadtrum.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit 8afa10cbe281b10371fee5a87ab266e48d71a7f9 ]
Check the qmin & qmax values doesn't overflow for the given Wlog value.
Check that qmin <= qmax.
Fixes: a783474591f2 ("[PKT_SCHED]: Generic RED layer")
Signed-off-by: Nogah Frankel <nogahf@mellanox.com>
[ Upstream commit 5c472203421ab4f928aa1ae9e1dbcfdd80324148 ]
Do not allow delta value to be zero since it is used as a divisor.
Fixes: 8af2a218de38 ("sch_red: Adaptative RED AQM")
commit 9fa68f620041be04720d0cbfb1bd3ddfc6310b24 upstream.
Currently, almost none of the keyed hash algorithms check whether a key
has been set before proceeding. Some algorithms are okay with this and
will effectively just use a key of all 0's or some other bogus default.
However, others will severely break, as demonstrated using
"hmac(sha3-512-generic)", the unkeyed use of which causes a kernel crash
via a (potentially exploitable) stack buffer overflow.
A while ago, this problem was solved for AF_ALG by pairing each hash
transform with a 'has_key' bool. However, there are still other places
in the kernel where userspace can specify an arbitrary hash algorithm by
name, and the kernel uses it as unkeyed hash without checking whether it
is really unkeyed. Examples of this include:
- KEYCTL_DH_COMPUTE, via the KDF extension
- dm-verity
- dm-crypt, via the ESSIV support
- dm-integrity, via the "internal hash" mode with no key given
- drbd (Distributed Replicated Block Device)
This bug is especially bad for KEYCTL_DH_COMPUTE as that requires no
privileges to call.
Fix the bug for all users by adding a flag CRYPTO_TFM_NEED_KEY to the
->crt_flags of each hash transform that indicates whether the transform
still needs to be keyed or not. Then, make the hash init, import, and
digest functions return -ENOKEY if the key is still needed.
The new flag also replaces the 'has_key' bool which algif_hash was
previously using, thereby simplifying the algif_hash implementation.
Reported-by: syzbot <syzkaller@googlegroups.com>
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream.
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
commit f35157417215ec138c920320c746fdb3e04ef1d5 upstream.
Provide a function, kmemdup_nul(), that will create a NUL-terminated string
from an unterminated character array where the length is known in advance.
This is better than kstrndup() in situations where we already know the
string length as the strnlen() in kstrndup() is superfluous.
commit 6e6e41c3112276288ccaf80c70916779b84bb276 upstream.
To avoid slab to warn about exceeded size, fail early if queue
occupies more than KMALLOC_MAX_SIZE.
Reported-by: syzbot+e4d4f9ddd4295539735d@syzkaller.appspotmail.com
Fixes: 2e0ab8ca83c12 ("ptr_ring: array based FIFO for pointers")
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
commit ecca8f88da5c4260cc2bccfefd2a24976704c366 upstream.
Now in sctp_setsockopt_maxseg user_frag or frag_point can be set with
val >= 8 and val <= SCTP_MAX_CHUNK_LEN. But both checks are incorrect.
val >= 8 means frag_point can even be less than SCTP_DEFAULT_MINSEGMENT.
Then in sctp_datamsg_from_user(), when it's value is greater than cookie
echo len and trying to bundle with cookie echo chunk, the first_len will
overflow.
The worse case is when it's value is equal as cookie echo len, first_len
becomes 0, it will go into a dead loop for fragment later on. In Hangbin
syzkaller testing env, oom was even triggered due to consecutive memory
allocation in that loop.
Besides, SCTP_MAX_CHUNK_LEN is the max size of the whole chunk, it should
deduct the data header for frag_point or user_frag check.
This patch does a proper check with SCTP_DEFAULT_MINSEGMENT subtracting
the sctphdr and datahdr, SCTP_MAX_CHUNK_LEN subtracting datahdr when
setting frag_point via sockopt. It also improves sctp_setsockopt_maxseg
codes.
Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
I ran into a 4.9 build warning in randconfig testing, starting with the
KAISER patches:
arch/x86/kernel/ldt.c: In function 'alloc_ldt_struct':
arch/x86/include/asm/pgtable_types.h:208:24: error: large integer implicitly truncated to unsigned type [-Werror=overflow]
#define __PAGE_KERNEL (__PAGE_KERNEL_EXEC | _PAGE_NX)
arch/x86/kernel/ldt.c:81:6: note: in expansion of macro '__PAGE_KERNEL'
__PAGE_KERNEL);
I originally ran into this last year when the patches were part of linux-next,
and tried to work around it by using the proper 'pteval_t' types consistently,
but that caused additional problems.
This takes a much simpler approach, and makes the argument type of the dummy
helper always 64-bit, which is wide enough for any page table layout and
won't hurt since this call is just an empty stub anyway.
Fixes: 8f0baadf2bea ("kaiser: merged update")
commit 8fa80c503b484ddc1abbd10c7cb2ab81f3824a50 upstream.
For architectures providing their own implementation of
array_index_mask_nospec() in asm/barrier.h, attempting to use WARN_ONCE() to
complain about out-of-range parameters using WARN_ON() results in a mess
of mutually-dependent include files.
Rather than unpick the dependencies, simply have the core code in nospec.h
perform the checking for us.
Cc: Dan Williams <dan.j.williams@intel.com>
Link: http://lkml.kernel.org/r/1517840166-15399-1-git-send-email-will.deacon@arm.com
commit df5d45aa08f848b79caf395211b222790534ccc7 upstream.
Create a new function attribute __optimize, which allows to specify an
optimization level on a per-function basis.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit f69120ce6c024aa634a8fc25787205e42f0ccbe6 upstream.
Sphinx emits various (26) warnings when building make target 'htmldocs'.
Currently struct definitions contain duplicate documentation, some as
kernel-docs and some as standard c89 comments. We can reduce
duplication while cleaning up the kernel docs.
Move all kernel-docs to right above each struct member. Use the set of
all existing comments (kernel-doc and c89). Add documentation for
missing struct members and function arguments.
Signed-off-by: Tobin C. Harding <me@tobin.cc>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit 9e343e87d2c4c707ef8fae2844864d4dde3a2d13 upstream.
The map_word_() functions, dating back to linux-2.6.8, try to perform
bitwise operations on a 'map_word' structure. This may have worked
with compilers that were current then (gcc-3.4 or earlier), but end
up being rather inefficient on any version I could try now (gcc-4.4 or
higher). Specifically we hit a problem analyzed in gcc PR81715 where we
fail to reuse the stack space for local variables.
This can be seen immediately in the stack consumption for
cfi_staa_erase_varsize() and other functions that (with CONFIG_KASAN)
can be up to 2200 bytes. Changing the inline functions into macros brings
this down to 1280 bytes. Without KASAN, the same problem exists, but
the stack consumption is lower to start with, my patch shrinks it from
920 to 496 bytes on with arm-linux-gnueabi-gcc-5.4, and saves around
1KB in .text size for cfi_cmdset_0020.c, as it avoids copying map_word
structures for each call to one of these helpers.
With the latest gcc-8 snapshot, the problem is fixed in upstream gcc,
but nobody uses that yet, so we should still work around it in mainline
kernels and probably backport the workaround to stable kernels as well.
We had a couple of other functions that suffered from the same gcc bug,
and all of those had a simpler workaround involving dummy variables
in the inline function. Unfortunately that did not work here, the
macro hack was the best I could come up with.
It would also be helpful to have someone to a little performance testing
on the patch, to see how much it helps in terms of CPU utilitzation.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
(cherry picked from commit 66f793099a636862a71c59d4a6ba91387b155e0c)
There's no point in building init code with retpolines, since it runs before
any potentially hostile userspace does. And before the retpoline is actually
ALTERNATIVEd into place, for much of it.
Cc: peterz@infradead.org
Cc: bp@alien8.de
Link: https://lkml.kernel.org/r/1517484441-1420-2-git-send-email-dwmw@amazon.co.uk
(cherry picked from commit 56c30ba7b348b90484969054d561f711ba196507)
'fd' is a user controlled value that is used as a data dependency to
read from the 'fdt->fd' array. In order to avoid potential leaks of
kernel memory values, block speculative execution of the instruction
stream that could issue reads based on an invalid 'file *' returned from
__fcheck_files.
Co-developed-by: Elena Reshetova <elena.reshetova@intel.com>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727418500.33451.17392199002892248656.stgit@dwillia2-desk3.amr.corp.intel.com
