commit 669c55e9f99b90e46eaa0f98a67ec53d46dc969a upstream
Dave reported that his large SPARC machines spend lots of time in
hweight64(), try and optimize some of those needless cpumask_weight()
invocations (esp. with the large offstack cpumasks these are very
expensive indeed).
Reported-by: David Miller <davem@davemloft.net>
LKML-Reference: <new-submission>
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 50b926e439620c469565e8be0f28be78f5fca1ce upstream
SD_PREFER_SIBLING is set at the CPU domain level if power saving isn't
enabled, leading to many cache misses on large machines as we traverse
looking for an idle shared cache to wake to. Change the enabler of
select_idle_sibling() to SD_SHARE_PKG_RESOURCES, and enable same at the
sibling domain level.
Reported-by: Lin Ming <ming.m.lin@intel.com>
LKML-Reference: <1262612696.15495.15.camel@marge.simson.net>
commit 0017d735092844118bef006696a750a0e4ef6ebd upstream
Oleg noticed a few races with the TASK_WAKING usage on fork.
- since TASK_WAKING is basically a spinlock, it should be IRQ safe
- since we set TASK_WAKING (*) without holding rq->lock it could
be there still is a rq->lock holder, thereby not actually
providing full serialization.
(*) in fact we clear PF_STARTING, which in effect enables TASK_WAKING.
Cure the second issue by not setting TASK_WAKING in sched_fork(), but
only temporarily in wake_up_new_task() while calling select_task_rq().
Cure the first by holding rq->lock around the select_task_rq() call,
this will disable IRQs, this however requires that we push down the
rq->lock release into select_task_rq_fair()'s cgroup stuff.
Because select_task_rq_fair() still needs to drop the rq->lock we
cannot fully get rid of TASK_WAKING.
Reported-by: Oleg Nesterov <oleg@redhat.com>
commit 9084bb8246ea935b98320554229e2f371f7f52fa upstream
Introduce cpuset_cpus_allowed_fallback() helper to fix the cpuset problems
with select_fallback_rq(). It can be called from any context and can't use
any cpuset locks including task_lock(). It is called when the task doesn't
have online cpus in ->cpus_allowed but ttwu/etc must be able to find a
suitable cpu.
I am not proud of this patch. Everything which needs such a fat comment
can't be good even if correct. But I'd prefer to not change the locking
rules in the code I hardly understand, and in any case I believe this
simple change make the code much more correct compared to deadlocks we
currently have.
LKML-Reference: <20100315091027.GA9155@redhat.com>
commit 6a1bdc1b577ebcb65f6603c57f8347309bc4ab13 upstream
_cpu_down() changes the current task's affinity and then recovers it at
the end. The problems are well known: we can't restore old_allowed if it
was bound to the now-dead-cpu, and we can race with the userspace which
can change cpu-affinity during unplug.
_cpu_down() should not play with current->cpus_allowed at all. Instead,
take_cpu_down() can migrate the caller of _cpu_down() after __cpu_disable()
removes the dying cpu from cpu_online_mask.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
LKML-Reference: <20100315091023.GA9148@redhat.com>
cpuset_lock/cpuset_cpus_allowed_locked code
commit 897f0b3c3ff40b443c84e271bef19bd6ae885195 upstream
This patch just states the fact the cpusets/cpuhotplug interaction is
broken and removes the deadlockable code which only pretends to work.
- cpuset_lock() doesn't really work. It is needed for
cpuset_cpus_allowed_locked() but we can't take this lock in
try_to_wake_up()->select_fallback_rq() path.
- cpuset_lock() is deadlockable. Suppose that a task T bound to CPU takes
callback_mutex. If cpu_down(CPU) happens before T drops callback_mutex
stop_machine() preempts T, then migration_call(CPU_DEAD) tries to take
cpuset_lock() and hangs forever because CPU is already dead and thus
T can't be scheduled.
- cpuset_cpus_allowed_locked() is deadlockable too. It takes task_lock()
which is not irq-safe, but try_to_wake_up() can be called from irq.
Kill them, and change select_fallback_rq() to use cpu_possible_mask, like
we currently do without CONFIG_CPUSETS.
Also, with or without this patch, with or without CONFIG_CPUSETS, the
callers of select_fallback_rq() can race with each other or with
set_cpus_allowed() pathes.
The subsequent patches try to to fix these problems.
LKML-Reference: <20100315091003.GA9123@redhat.com>
commit ea87bb7853168434f4a82426dd1ea8421f9e604d upstream
The ability of enqueueing a task to the head of a SCHED_FIFO priority
list is required to fix some violations of POSIX scheduling policy.
Extend the related functions with a "head" argument.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Carsten Emde <cbe@osadl.org>
Tested-by: Mathias Weber <mathias.weber.mw1@roche.com>
LKML-Reference: <20100120171629.734886007@linutronix.de>
commit 88ec22d3edb72b261f8628226cd543589a6d5e1b upstream
In order to remove the cfs_rq dependency from set_task_cpu() we
need to ensure the task is cfs_rq invariant for all callsites.
The simple approach is to substract cfs_rq->min_vruntime from
se->vruntime on dequeue, and add cfs_rq->min_vruntime on
enqueue.
However, this has the downside of breaking FAIR_SLEEPERS since
we loose the old vruntime as we only maintain the relative
position.
To solve this, we observe that we only migrate runnable tasks,
we do this using deactivate_task(.sleep=0) and
activate_task(.wakeup=0), therefore we can restrain the
min_vruntime invariance to that state.
The only other case is wakeup balancing, since we want to
maintain the old vruntime we cannot make it relative on dequeue,
but since we don't migrate inactive tasks, we can do so right
before we activate it again.
This is where we need the new pre-wakeup hook, we need to call
this while still holding the old rq->lock. We could fold it into
->select_task_rq(), but since that has multiple callsites and
would obfuscate the locking requirements, that seems like a
fudge.
This leaves the fork() case, simply make sure that ->task_fork()
leaves the ->vruntime in a relative state.
This covers all cases where set_task_cpu() gets called, and
ensures it sees a relative vruntime.
LKML-Reference: <20091216170518.191697025@chello.nl>
commit efbbd05a595343a413964ad85a2ad359b7b7efbd upstream
As will be apparent in the next patch, we need a pre wakeup hook
for sched_fair task migration, hence rename the post wakeup hook
and one pre wakeup.
LKML-Reference: <20091216170518.114746117@chello.nl>
commit b9889ed1ddeca5a3f3569c8de7354e9e97d803ae upstream
This build warning:
kernel/sched.c: In function 'set_task_cpu':
kernel/sched.c:2070: warning: unused variable 'old_rq'
Made me realize that the forced2_migrations stat looks pretty
pointless (and a misnomer) - remove it.
commit cd29fe6f2637cc2ccbda5ac65f5332d6bf5fa3c6 upstream
Currently we try to do task placement in wake_up_new_task() after we do
the load-balance pass in sched_fork(). This yields complicated semantics
in that we have to deal with tasks on different RQs and the
set_task_cpu() calls in copy_process() and sched_fork()
Rename ->task_new() to ->task_fork() and call it from sched_fork()
before the balancing, this gives the policy a clear point to place the
task.
commit 9824a2b728b63e7ff586b9fd9293c819be79f0f3 upstream
cpu_nr_migrations() is not used, remove it.
Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
LKML-Reference: <4AF12A66.6020609@ct.jp.nec.com>
commit dba091b9e3522b9d32fc9975e48d3b69633b45f0 upstream
sched_rr_get_param calls
task->sched_class->get_rr_interval(task) without protection
against a concurrent sched_setscheduler() call which modifies
task->sched_class.
Serialize the access with task_rq_lock(task) and hand the rq
pointer into get_rr_interval() as it's needed at least in the
sched_fair implementation.
LKML-Reference: <alpine.LFD.2.00.0912090930120.3089@localhost.localdomain>
commit c41d68a513c71e35a14f66d71782d27a79a81ea6 upstream.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
commit e2f3d75fc0e4a0d03c61872bad39ffa2e74a04ff upstream.
For some mysterious reason, certain hardware reacts badly to usual EH
actions while the system is going for suspend. As the devices won't
be needed until the system is resumed, ask EH to skip usual autopsy
and recovery and proceed directly to suspend.
Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com>
commit 30da55242818a8ca08583188ebcbaccd283ad4d9 upstream.
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove
unsafe and unnecessary hardware access" changed read_msi_msg_desc() to
return the last MSI message written instead of reading it from the
device, since it may be called while the device is in a reduced
power state.
However, the pSeries platform code really does need to read messages
from the device, since they are initially written by firmware.
Therefore:
- Restore the previous behaviour of read_msi_msg_desc()
- Add new functions get_cached_msi_msg{,_desc}() which return the
- Use the new functions where appropriate
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 297c5eee372478fc32fec5fe8eed711eedb13f3d upstream.
It's a really simple list, and several of the users want to go backwards
in it to find the previous vma. So rather than have to look up the
previous entry with 'find_vma_prev()' or something similar, just make it
doubly linked instead.
Tested-by: Ian Campbell <ijc@hellion.org.uk>
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream.
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 6cb4aff0a77cc0e6bae9475d62205319e3ebbf3f upstream.
Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes
during inode creation") contains a bug that will cause it to oops when
mounting a file system that didn't previously contain extended attributes
on a system using security.* xattrs.
The issue is that while creating the privroot during mount
reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which
dereferences the xattr root. The xattr root doesn't exist, so we get an
oops.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 upstream.
This is a real fix for problem of utime/stime values decreasing
described in the thread:
http://lkml.org/lkml/2009/11/3/522
Now cputime is accounted in the following way:
- {u,s}time in task_struct are increased every time when the thread
is interrupted by a tick (timer interrupt).
- When a thread exits, its {u,s}time are added to signal->{u,s}time,
after adjusted by task_times().
- When all threads in a thread_group exits, accumulated {u,s}time
(and also c{u,s}time) in signal struct are added to c{u,s}time
in signal struct of the group's parent.
So {u,s}time in task struct are "raw" tick count, while
{u,s}time and c{u,s}time in signal struct are "adjusted" values.
And accounted values are used by:
- task_times(), to get cputime of a thread:
This function returns adjusted values that originates from raw
{u,s}time and scaled by sum_exec_runtime that accounted by CFS.
- thread_group_cputime(), to get cputime of a thread group:
This function returns sum of all {u,s}time of living threads in
the group, plus {u,s}time in the signal struct that is sum of
adjusted cputimes of all exited threads belonged to the group.
The problem is the return value of thread_group_cputime(),
because it is mixed sum of "raw" value and "adjusted" value:
group's {u,s}time = foreach(thread){{u,s}time} + exited({u,s}time)
This misbehavior can break {u,s}time monotonicity.
Assume that if there is a thread that have raw values greater
than adjusted values (e.g. interrupted by 1000Hz ticks 50 times
but only runs 45ms) and if it exits, cputime will decrease (e.g.
-5ms).
To fix this, we could do:
group's {u,s}time = foreach(t){task_times(t)} + exited({u,s}time)
But task_times() contains hard divisions, so applying it for
every thread should be avoided.
This patch fixes the above problem in the following way:
- Modify thread's exit (= __exit_signal()) not to use task_times().
It means {u,s}time in signal struct accumulates raw values instead
of adjusted values. As the result it makes thread_group_cputime()
to return pure sum of "raw" values.
- Introduce a new function thread_group_times(*task, *utime, *stime)
that converts "raw" values of thread_group_cputime() to "adjusted"
values, in same calculation procedure as task_times().
- Modify group's exit (= wait_task_zombie()) to use this introduced
thread_group_times(). It make c{u,s}time in signal struct to
have adjusted values like before this patch.
- Replace some thread_group_cputime() by thread_group_times().
This replacements are only applied where conveys the "adjusted"
cputime to users, and where already uses task_times() near by it.
(i.e. sys_times(), getrusage(), and /proc/<PID>/stat.)
This patch have a positive side effect:
- Before this patch, if a group contains many short-life threads
(e.g. runs 0.9ms and not interrupted by ticks), the group's
cputime could be invisible since thread's cputime was accumulated
after adjusted: imagine adjustment function as adj(ticks, runtime),
{adj(0, 0.9) + adj(0, 0.9) + ....} = {0 + 0 + ....} = 0.
After this patch it will not happen because the adjustment is
applied after accumulated.
v2:
- remove if()s, put new variables into signal_struct.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Spencer Candland <spencer@bluehost.com>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <4B162517.8040909@jp.fujitsu.com>
commit 0696b711e4be45fa104c12329f617beb29c03f78 upstream.
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier
to struct timekeeper" the clock multiplier of vsyscall is updated with
the unmodified clock multiplier of the clock source and not with the
NTP adjusted multiplier of the timekeeper.
This causes user space observerable time warps:
new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf
Add a new argument "mult" to update_vsyscall() and hand in the
timekeeping internal NTP adjusted multiplier.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com>
LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com>
Signed-off-by: Kurt Garloff <garloff@suse.de>
commit 3c5d92a0cfb5103c0d5ab74d4ae6373d3af38148 upstream.
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
Acked-by: John Jolly <jjolly@suse.de>
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 38117d1495e587fbb10d6e55733139a27893cef5 upstream.
commit 06c4648d46d1b757d6b9591a86810be79818b60c upstream.
Currently such notifications are only generated when the device comes up or the
address changes. However one use case for these notifications is to enable
faster network recovery after a virtual machine migration (by causing switches
to relearn their MAC tables). A migration appears to the network stack as a
temporary loss of carrier and therefore does not trigger either of the current
conditions. Rather than adding carrier up as a trigger (which can cause issues
when interfaces a flapping) simply add an interface which the driver can use
to explicitly trigger the notification.
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
BIO_RW_* bits
commit aca27ba9618276dd2f777bcd5a1419589ccf1ca8 upstream.
Commit a82afdf (block: use the same failfast bits for bio and request)
moved BIO_RW_* bits around such that they match up with REQ_* bits.
Unfortunately, fs.h hard coded RW_MASK, RWA_MASK, READ, WRITE, READA
and SWRITE as 0, 1, 2 and 3, and expected them to match with BIO_RW_*
bits. READ/WRITE didn't change but BIO_RW_AHEAD was moved to bit 4
instead of bit 1, breaking RWA_MASK, READA and SWRITE.
This patch updates RWA_MASK, READA and SWRITE such that they match the
BIO_RW_* bits again. A follow up patch will update the definitions to
directly use BIO_RW_* bits so that this kind of breakage won't happen
again.
Neil also spotted missing RWA_MASK conversion.
Stable: The offending commit a82afdf was released with v2.6.32, so
this patch should be applied to all kernels since then but it must
_NOT_ be applied to kernels earlier than that.
Reported-and-bisected-by: Vladislav Bolkhovitin <vst@vlnb.net>
Root-caused-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit ea2db495f92ad2cf3301623e60cb95b4062bc484 upstream.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit d53cdbb94a52a920d5420ed64d986c3523a56743 upstream.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
Cc: Michael Buesch <mb@bu3sch.de>
Turns out this isn't the best way to resolve this issue. The
individual patches will be applied instead.
commit dd336c554d8926c3348a2d5f2a5ef5597f6d1a06 upstream.
fix memory leak introduced by the patch 6e03a201bbe:
firmware: speed up request_firmware()
1. vfree won't release pages there were allocated explicitly and mapped
using vmap. The memory has to be vunmap-ed and the pages needs
to be freed explicitly
2. page array is moved into the 'struct
firmware' so that we can free it from release_firmware()
and not only in fw_dev_release()
The fix doesn't break the firmware load speed.
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Ming Lei <tom.leiming@gmail.com>
Singed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit 8a64c0f6b7ec7f758c4ef445e49f479e27fa2236 upstream.
When operating in 1-bit mode, SDAT1 is used as dedicated interrupt line.
However, the 8686 will only drive this line when the ECSI bit is set in
the CCCR_IF register.
Thanks to Alagu Sankar for pointing me in the right direction.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alagu Sankar <alagusankar@embwise.com>
Cc: Volker Ernst <volker.ernst@txtr.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Holger Schurig <hs4233@mail.mn-solutions.de>
Cc: Bing Zhao <bzhao@marvell.com>
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-mmc@vger.kernel.org
Acked-by: Dan Williams <dcbw@redhat.com>
commit b6dacf63e9fb2e7a1369843d6cef332f76fca6a3 upstream.
The ACPI spec tells us that the firmware will reenable SCI_EN on resume.
Reality disagrees in some cases. The ACPI spec tells us that the only way
to set SCI_EN is via an SMM call.
https://bugzilla.kernel.org/show_bug.cgi?id=13745 shows us that doing so
may break machines. Tracing the ACPI calls made by Windows shows that it
unconditionally sets SCI_EN on resume with a direct register write, and
therefore the overwhelming probability is that everything is fine with
this behaviour.
Tested-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Len Brown <len.brown@intel.com>
Cc: Kamal Mostafa <kamal@canonical.com>
commit 718be4aaf3613cf7c2d097f925abc3d3553c0605 upstream.
It turns out that there is a bit in the _CST for Intel FFH C3
that tells the OS if we should be checking BM_STS or not.
Linux has been unconditionally checking BM_STS.
If the chip-set is configured to enable BM_STS,
it can retard or completely prevent entry into
deep C-states -- as illustrated by turbostat:
http://userweb.kernel.org/~lenb/acpi/utils/pmtools/turbostat/
ref: Intel Processor Vendor-Specific ACPI Interface Specification
table 4 "_CST FFH GAS Field Encoding"
Bit 1: Set to 1 if OSPM should use Bus Master avoidance for this C-state
https://bugzilla.kernel.org/show_bug.cgi?id=15886
commit cc3e1bea5d87635c519da657303690f5538bb4eb upstream (as of v2.6.33-rc3)
This is a bit complicated because we are trying to optimize when we
send barriers to the fs data disk. We could just throw in an extra
barrier to the data disk whenever we send a barrier to the journal
disk, but that's not always strictly necessary.
We only need to send a barrier during a commit when there are data
blocks which are must be written out due to an inode written in
ordered mode, or if fsync() depends on the commit to force data blocks
to disk. Finally, before we drop transactions from the beginning of
the journal during a checkpoint operation, we need to guarantee that
any blocks that were flushed out to the data disk are firmly on the
rust platter before we drop the transaction from the journal.
Thanks to Oleg Drokin for pointing out this flaw in ext3/ext4.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit bf988435bd5b53529f4408a8efb1f433f6ddfda9 upstream.
struct ethtool_rxnfc was originally defined in 2.6.27 for the
ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data
fields. It was then extended in 2.6.30 to support various additional
commands. These commands should have been defined to use a new
structure, but it is too late to change that now.
Since user-space may still be using the old structure definition
for the ETHTOOL_{G,S}RXFH commands, and since they do not need the
additional fields, only copy the originally defined fields to and
from user-space.
commit 1cb561f83793191cf86a2db3948d28f5f42df9ff upstream.
This fixes the problem introduced in commit
8404080568613d93ad7cf0a16dfb68 which broke mesh peer link establishment.
changes:
v2 Added missing break (Johannes)
v3 Broke original patch into two (Johannes)
Signed-off-by: Javier Cardona <javier@cozybit.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit b26c949755c06ec79e55a75817210083bd78fc9a upstream.
When I added the flags I must have been using a 25 line terminal and missed the following flags.
The collided with flag has one user in staging despite being in-tree for 5 years.
I'm happy to push this via my drm tree unless someone really wants to do it.
commit f8324e20f8289dffc646d64366332e05eaacab25 upstream.
The kernel's math-emu code contains a macro _FP_FROM_INT() which is
used to convert an integer to a raw normalized floating-point value.
It does this basically in three steps:
1. Compute the exponent from the number of leading zero bits.
2. Downshift large fractions to put the MSB in the right position
for normalized fractions.
3. Upshift small fractions to put the MSB in the right position.
There is an boundary error in step 2, causing a fraction with its
MSB exactly one bit above the normalized MSB position to not be
downshifted. This results in a non-normalized raw float, which when
packed becomes a massively inaccurate representation for that input.
The impact of this depends on a number of arch-specific factors,
but it is known to have broken emulation of FXTOD instructions
on UltraSPARC III, which was originally reported as GCC bug 44631
<http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44631>.
Any arch which uses math-emu to emulate conversions from integers to
same-size floats may be affected.
The fix is simple: the exponent comparison used to determine if the
fraction should be downshifted must be "<=" not "<".
I'm sending a kernel module to test this as a reply to this message.
There are also SPARC user-space test cases in the GCC bug entry.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
For some Netbook computers with Broadcom BCM4312 wireless interfaces,
the SPROM has been moved to a new location. When the ssb driver tries to
read the old location, the systems hangs when trying to read a
non-existent location. Such freezes are particularly bad as they do not
log the failure.
This patch is modified from commit
da1fdb02d9200ff28b6f3a380d21930335fe5429 with some pieces from other
mainline changes so that it can be applied to stable 2.6.34.Y.
Per document, for feature control MSR:
Bit 1 enables VMXON in SMX operation. If the bit is clear, execution
of VMXON in SMX operation causes a general-protection exception.
Bit 2 enables VMXON outside SMX operation. If the bit is clear, execution
of VMXON outside SMX operation causes a general-protection exception.
This patch is to enable this kind of check with SMX for VMXON in KVM.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
(cherry picked from commit cafd66595d92591e4bd25c3904e004fc6f897e2d)
commit db1f05bb85d7966b9176e293f3ceead1cb8b5d79 upstream.
Add a new UMOUNT_NOFOLLOW flag to umount(2). This is needed to prevent
symlink attacks in unprivileged unmounts (fuse, samba, ncpfs).
Additionally, return -EINVAL if an unknown flag is used (and specify
an explicitly unused flag: UMOUNT_UNUSED). This makes it possible for
the caller to determine if a flag is supported or not.
CC: Eugene Teo <eugene@redhat.com>
CC: Michael Kerrisk <mtk.manpages@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
(CVE-2010-1173) (v4)
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 upstream.
Ok, version 4
Change Notes:
1) Minor cleanups, from Vlads notes
Summary:
Hey-
Recently, it was reported to me that the kernel could oops in the
following way:
<5> kernel BUG at net/core/skbuff.c:91!
<5> invalid operand: 0000 [#1]
<5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter
ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U)
vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5
ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss
snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore
pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi
mptbase sd_mod scsi_mod
<5> CPU: 0
<5> EIP: 0060:[<c02bff27>] Not tainted VLI
<5> EFLAGS: 00010216 (2.6.9-89.0.25.EL)
<5> EIP is at skb_over_panic+0x1f/0x2d
<5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44
<5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40
<5> ds: 007b es: 007b ss: 0068
<5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0)
<5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180
e0c2947d
<5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004
df653490
<5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e
00000004
<5> Call Trace:
<5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp]
<5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp]
<5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp]
<5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp]
<5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp]
<5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp]
<5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp]
<5> [<c01555a4>] cache_grow+0x140/0x233
<5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp]
<5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp]
<5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp]
<5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter]
<5> [<c02d005e>] nf_iterate+0x40/0x81
<5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151
<5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151
<5> [<c02d0362>] nf_hook_slow+0x83/0xb5
<5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9
<5> [<c02e103e>] ip_rcv+0x334/0x3b4
<5> [<c02c66fd>] netif_receive_skb+0x320/0x35b
<5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd]
<5> [<c02c67a4>] process_backlog+0x6c/0xd9
<5> [<c02c690f>] net_rx_action+0xfe/0x1f8
<5> [<c012a7b1>] __do_softirq+0x35/0x79
<5> [<c0107efb>] handle_IRQ_event+0x0/0x4f
<5> [<c01094de>] do_softirq+0x46/0x4d
Its an skb_over_panic BUG halt that results from processing an init chunk in
which too many of its variable length parameters are in some way malformed.
The problem is in sctp_process_unk_param:
if (NULL == *errp)
*errp = sctp_make_op_error_space(asoc, chunk,
ntohs(chunk->chunk_hdr->length));
if (*errp) {
sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM,
WORD_ROUND(ntohs(param.p->length)));
sctp_addto_chunk(*errp,
WORD_ROUND(ntohs(param.p->length)),
param.v);
When we allocate an error chunk, we assume that the worst case scenario requires
that we have chunk_hdr->length data allocated, which would be correct nominally,
given that we call sctp_addto_chunk for the violating parameter. Unfortunately,
we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error
chunk, so the worst case situation in which all parameters are in violation
requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data.
The result of this error is that a deliberately malformed packet sent to a
listening host can cause a remote DOS, described in CVE-2010-1173:
http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173
I've tested the below fix and confirmed that it fixes the issue. We move to a
strategy whereby we allocate a fixed size error chunk and ignore errors we don't
have space to report. Tested by me successfully
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit 7d683a09990ff095a91b6e724ecee0ff8733274a upstream.
It's used to superblock ->s_magic, which is unsigned long.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Reviewed-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 4daedcfe8c6851aa01cc1997220f2577f4039c13 upstream.
JMB362 is a new variant of jmicron controller which is similar to
JMB360 but has two SATA ports instead of one. As there is no PATA
port, single function AHCI mode can be used as in JMB360. Add pci
quirk for JMB362.
Reported-by: Aries Lee <arieslee@jmicron.com>
commit e9d6c157385e4efa61cb8293e425c9d8beba70d3 upstream.
Shaohua Li reported parallel file copy on tmpfs can lead to OOM killer.
This is regression of caused by commit 9ff473b9a7 ("vmscan: evict
streaming IO first"). Wow, It is 2 years old patch!
Currently, tmpfs file cache is inserted active list at first. This means
that the insertion doesn't only increase numbers of pages in anon LRU, but
it also reduces anon scanning ratio. Therefore, vmscan will get totally
confused. It scans almost only file LRU even though the system has plenty
unused tmpfs pages.
Historically, lru_cache_add_active_anon() was used for two reasons.
1) Intend to priotize shmem page rather than regular file cache.
2) Intend to avoid reclaim priority inversion of used once pages.
But we've lost both motivation because (1) Now we have separate anon and
file LRU list. then, to insert active list doesn't help such priotize.
(2) In past, one pte access bit will cause page activation. then to
insert inactive list with pte access bit mean higher priority than to
insert active list. Its priority inversion may lead to uninteded lru
chun. but it was already solved by commit 645747462 (vmscan: detect
mapped file pages used only once). (Thanks Hannes, you are great!)
Thus, now we can use lru_cache_add_anon() instead.
Reported-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 34441427aab4bdb3069a4ffcda69a99357abcb2e upstream.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
commit f33d7e2d2d113a63772bbc993cdec3b5327f0ef1 upstream.
dma_sync_single_range_for_cpu() and dma_sync_single_range_for_device() use
a wrong address with a partial synchronization.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This reverts commit d150a2b96558a7349cbf3a72a279c37bc67d50fb.
Thanks to Jiri Benc for finding the problem that this patch is
not correct for the 2.6.32-stable series.
Cc: Jiri Kosina <jkosina@suse.cz>
commit 86c38a31aa7f2dd6e74a262710bf8ebf7455acc5 upstream.
GCC 4.5 introduces behavior that forces the alignment of structures to
use the largest possible value. The default value is 32 bytes, so if
some structures are defined with a 4-byte alignment and others aren't
declared with an alignment constraint at all - it will align at 32-bytes.
For things like the ftrace events, this results in a non-standard array.
When initializing the ftrace subsystem, we traverse the _ftrace_events
section and call the initialization callback for each event. When the
structures are misaligned, we could be treating another part of the
structure (or the zeroed out space between them) as a function pointer.
This patch forces the alignment for all the ftrace_event_call structures
to 4 bytes.
Without this patch, the kernel fails to boot very early when built with
gcc 4.5.
It's trivial to check the alignment of the members of the array, so it
might be worthwhile to add something to the build system to do that
automatically. Unfortunately, that only covers this case. I've asked one
of the gcc developers about adding a warning when this condition is seen.
Cc: stable@kernel.org
LKML-Reference: <4B85770B.6010901@suse.com>
Cc: Andreas Radke <a.radke@arcor.de>
