path: root/include
2011-08-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: remove unused "ddr" parameter in struct mmc_ios mmc: dw_mmc: Fix DDR mode support. mmc: core: use defined R1_STATE_PRG macro for card status mmc: sdhci: use f_max instead of host->clock for timeouts mmc: sdhci: move timeout_clk calculation farther down mmc: sdhci: check host->clock before using it as a denominator mmc: Revert "mmc: sdhci: Fix SDHCI_QUIRK_TIMEOUT_USES_SDCLK" mmc: tmio: eliminate unused variable 'mmc' warning mmc: esdhc-imx: fix card interrupt loss on freescale eSDHC mmc: sdhci-s3c: Fix build for header change mmc: dw_mmc: Fix mask in IDMAC_SET_BUFFER1_SIZE macro mmc: cb710: fix possible pci_dev leak in cb710_pci_configure() mmc: core: Detect eMMC v4.5 ext_csd entries mmc: mmc_test: avoid stalled file in debugfs mmc: sdhci-s3c: add BROKEN_ADMA_ZEROLEN_DESC quirk mmc: sdhci: pxav3: controller needs 32 bit ADMA addressing mmc: sdhci: fix retuning timer wrongly deleted in sdhci_tasklet_finish
2011-08-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Fix compile warning in wm8750.c ASoC: omap: Update e-mail address of Jarkko Nikula ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: Terminate WM8750 SPI device ID table ASoC: Add missing break in WM8994 probe ALSA: snd-usb-caiaq: Correct offset fields of outbound iso_frame_desc ALSA: azt3328 - adjust error handling code to include debugging code ALSA: hda - Add CONFIG_SND_HDA_POWER_SAVE to stac_vrefout_set() ALSA: usb-audio - Add quirk for BOSS Micro BR-80 ASoC: Fix typo in wm8750 spi_ids ASoC: Fix warning in Speyside WM8962 ASoC: Fix SPI driver binding for WM8987 ASoC: Fix binding of WM8750 on Jive ASoC: WM8903: Free IRQ on device removal ASoC: Tegra: wm8903 machine driver: Allow re-insertion of module ASoC: Tegra: tegra_pcm_deallocate_dma_buffer: Don't OOPS
2011-08-13mmc: remove unused "ddr" parameter in struct mmc_iosJaehoon Chung
"mmc: dw_mmc: Fix DDR mode support" removed the last user. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-08-12Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: dt: add empty of_get_property for non-dt
2011-08-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) e1000e: increase driver version number e1000e: alternate MAC address update e1000e: do not disable receiver on 82574/82583 e1000e: alternate MAC address does not work on device id 0x1060 PCnet: Fix section mismatch bnx2x: disable dcb on 578xx since not supported yet bnx2x: properly clean indirect addresses bnx2x: prevent race between undi_unload and load flows bnx2x: fix select_queue when FCoE is disabled bnx2x: init FCOE FP only once ipv4: some rt_iif -> rt_route_iif conversions net/bridge/netfilter/ebtables.c: use available error handling code net/netlabel/netlabel_kapi.c: add missing cleanup code net/irda: sh_sir: tidyup compile warning net/irda: sh_sir: add missing header net/irda: sh_irda: add missing header slcan: ldisc generated skbs are received in softirq context scm: Capture the full credentials of the scm sender tcp: initialize variable ecn_ok in syncookies path drivers/net/wireless/wl1251: add missing kfree ...
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-09dt: add empty of_get_property for non-dtStephen Warren
The patch adds empty function of_get_property for non-dt build, so that drivers migrating to dt can save some '#ifdef CONFIG_OF'. This also fixes the current Tegra compile problem in linux-next. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: pss - don't use the deprecated function check_region ALSA: timer - Add NULL-check for invalid slave timer ALSA: timer - Fix Oops at closing slave timer ASoC: Acknowledge WM8996 interrupts before acting on them ASoC: Rename WM8915 to WM8996 ALSA: Fix dependency of CONFIG_SND_TEA575X ALSA: asihpi - use kzalloc() ALSA: snd-usb-caiaq: Fix keymap for RigKontrol3 ALSA: snd-usb: Fix uninitialized variable usage ALSA: hda - Fix a complile warning in patch_via.c ALSA: hdspm - Fix uninitialized compile warnings ALSA: usb-audio - add quirk for Keith McMillen StringPort ALSA: snd-usb: operate on given mixer interface only ALSA: snd-usb: avoid dividing by zero on invalid input ALSA: snd-usb: Accept UAC2 FORMAT_TYPE descriptors with bLength > 6 sound: oss/pas2: Remove CLOCK_TICK_RATE dependency from PAS16 driver ALSA: hda - Use auto-parser for ASUS UX50, Eee PC P901, S101 and P1005 ALSA: hda - Fix digital-mic mono recording on ASUS Eee PC ASoC: sgtl5000: fix cache handling ASoC: Disable wm_hubs periodic DC servo update
2011-08-08mm: Fix fixup_user_fault() for MMU=nPeter Zijlstra
In commit 2efaca927f5c ("mm/futex: fix futex writes on archs with SW tracking of dirty & young") we forgot about MMU=n. This patch fixes that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/1311761831.24752.413.camel@twins Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08cred: use 'const' in get_current_{user,groups}Linus Torvalds
Avoid annoying warnings from these functions ("discards qualifiers") because they assign 'current_cred()' to a non-const pointer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08CRED: Restore const to current_cred()David Howells
Commit 3295514841c2 ("fix rcu annotations noise in cred.h") accidentally dropped the const of current->cred inside current_cred() by the insertion of a cast to deal with an RCU annotation loss warning from sparce. Use an appropriate RCU wrapper instead so as not to lose the const. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-07ipv4: route non-local sources for raw socketJulian Anastasov
The raw sockets can provide source address for routing but their privileges are not considered. We can provide non-local source address, make sure the FLOWI_FLAG_ANYSRC flag is set if socket has privileges for this, i.e. based on hdrincl (IP_HDRINCL) and transparent flags. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-07net: Make userland include of netlink.h more sane.David S. Miller
Currently userland will barf when including linux/netlink.h unless it precisely includes sys/socket.h first. The issue is where the definition of "sa_family_t" comes from. We've been back and forth on how to fix this issue in the past, see: http://thread.gmane.org/gmane.linux.debian.devel.bugs.general/622621 http://thread.gmane.org/gmane.linux.network/143380 Ben Hutchings suggested we take a hint from how we handle the sockaddr_storage type. First we define a "__kernel_sa_family_t" to linux/socket.h that is always defined. Then if __KERNEL__ is defined, we also define "sa_family_t" as equal to "__kernel_sa_family_t". Then in places like linux/netlink.h we use __kernel_sa_family_t in user visible datastructures. Reported-by: Michel Machado <michel@digirati.com.br> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-08ASoC: Rename WM8915 to WM8996Mark Brown
For marketing reasons the part will be called WM8996. In order to avoid user confusion rename the driver to reflect this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-07fix rcu annotations noise in cred.hAl Viro
task->cred is declared as __rcu, and access to other tasks' ->cred is, indeed, protected. Access to current->cred does not need rcu_dereference() at all, since only the task itself can change its ->cred. sparse, of course, has no way of knowing that... Add force-cast in current_cred(), make current_fsuid() et.al. use it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: ore: Make ore its own module exofs: Rename raid engine from exofs/ios.c => ore exofs: ios: Move to a per inode components & device-table exofs: Move exofs specific osd operations out of ios.c exofs: Add offset/length to exofs_get_io_state exofs: Fix truncate for the raid-groups case exofs: Small cleanup of exofs_fill_super exofs: BUG: Avoid sbi realloc exofs: Remove pnfs-osd private definitions nfs_xdr: Move nfs4_string definition out of #ifdef CONFIG_NFS_V4
2011-08-06vfs: optimize inode cache access patternsLinus Torvalds
The inode structure layout is largely random, and some of the vfs paths really do care. The path lookup in particular is already quite D$ intensive, and profiles show that accessing the 'inode->i_op->xyz' fields is quite costly. We already optimized the dcache to not unnecessarily load the d_op structure for members that are often NULL using the DCACHE_OP_xyz bits in dentry->d_flags, and this does something very similar for the inode ops that are used during pathname lookup. It also re-orders the fields so that the fields accessed by 'stat' are together at the beginning of the inode structure, and roughly in the order accessed. The effect of this seems to be in the 1-2% range for an empty kernel "make -j" run (which is fairly kernel-intensive, mostly in filename lookup), so it's visible. The numbers are fairly noisy, though, and likely depend a lot on exact microarchitecture. So there's more tuning to be done. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06vfs: renumber DCACHE_xyz flags, remove some stale onesLinus Torvalds
Gcc tends to generate better code with small integers, including the DCACHE_xyz flag tests - so move the common ones to be first in the list. Also just remove the unused DCACHE_INOTIFY_PARENT_WATCHED and DCACHE_AUTOFS_PENDING values, their users no longer exists in the source tree. And add a "unlikely()" to the DCACHE_OP_COMPARE test, since we want the common case to be a nice straight-line fall-through. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Compute protocol sequence numbers and fragment IDs using MD5. crypto: Move md5_transform to lib/md5.c
2011-08-06exofs: Rename raid engine from exofs/ios.c => oreBoaz Harrosh
ORE stands for "Objects Raid Engine" This patch is a mechanical rename of everything that was in ios.c and its API declaration to an ore.c and an osd_ore.h header. The ore engine will later be used by the pnfs objects layout driver. * File ios.c => ore.c * Declaration of types and API are moved from exofs.h to a new osd_ore.h * All used types are prefixed by ore_ from their exofs_ name. * Shift includes from exofs.h to osd_ore.h so osd_ore.h is independent, include it from exofs.h. Other than a pure rename there are no other changes. Next patch will move the ore into it's own module and will export the API to be used by exofs and later the layout driver Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-08-06net: Compute protocol sequence numbers and fragment IDs using MD5.David S. Miller
Computers have become a lot faster since we compromised on the partial MD4 hash which we use currently for performance reasons. MD5 is a much safer choice, and is inline with both RFC1948 and other ISS generators (OpenBSD, Solaris, etc.) Furthermore, only having 24-bits of the sequence number be truly unpredictable is a very serious limitation. So the periodic regeneration and 8-bit counter have been removed. We compute and use a full 32-bit sequence number. For ipv6, DCCP was found to use a 32-bit truncated initial sequence number (it needs 43-bits) and that is fixed here as well. Reported-by: Dan Kaminsky <dan@doxpara.com> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-06crypto: Move md5_transform to lib/md5.cDavid S. Miller
We are going to use this for TCP/IP sequence number and fragment ID generation. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (38 commits) acer-wmi: support Lenovo ideapad S205 wifi switch acerhdf.c: spaces in aliased changed to * platform-drivers-x86: ideapad-laptop: add missing ideapad_input_exit in ideapad_acpi_add error path x86 driver: fix typo in TDP override enabling Platform: fix samsung-laptop DMI identification for N150/N210/220/N230 dell-wmi: Add keys for Dell XPS L502X platform-drivers-x86: samsung-q10: make dmi_check_callback return 1 Platform: Samsung Q10 backlight driver platform-drivers-x86: intel_scu_ipc: convert to DEFINE_PCI_DEVICE_TABLE platform-drivers-x86: intel_rar_register: convert to DEFINE_PCI_DEVICE_TABLE platform-drivers-x86: intel_menlow: add missing return AE_OK for intel_menlow_register_sensor() platform-drivers-x86: intel_mid_thermal: fix memory leak platform-drivers-x86: msi-wmi: add missing sparse_keymap_free in msi_wmi_init error path Samsung Laptop platform driver: support N510 asus-wmi: add uwb rfkill support asus-wmi: add gps rfkill support asus-wmi: add CWAP support and clarify the meaning of WAPF bits asus-wmi: return proper value in store_cpufv() asus-wmi: check for temp1 presence asus-wmi: add thermal sensor ...
2011-08-06lib/sha1: use the git implementation of SHA-1Mandeep Singh Baines
For ChromiumOS, we use SHA-1 to verify the integrity of the root filesystem. The speed of the kernel sha-1 implementation has a major impact on our boot performance. To improve boot performance, we investigated using the heavily optimized sha-1 implementation used in git. With the git sha-1 implementation, we see a 11.7% improvement in boot time. 10 reboots, remove slowest/fastest. Before: Mean: 6.58 seconds Stdev: 0.14 After (with git sha-1, this patch): Mean: 5.89 seconds Stdev: 0.07 The other cool thing about the git SHA-1 implementation is that it only needs 64 bytes of stack for the workspace while the original kernel implementation needed 320 bytes. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ramsay Jones <ramsay@ramsay1.demon.co.uk> Cc: Nicolas Pitre <nico@cam.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David S. Miller <davem@davemloft.net> Cc: linux-crypto@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-05Add KEY_MICMUTE and enable it on Lenovo X220Andy Lutomirski
I suspect that this works on T410. Signed-off-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-08-05Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (55 commits) Revert "drm/i915: Try enabling RC6 by default (again)" drm/radeon: Extended DDC Probing for ECS A740GM-M DVI-D Connector drm/radeon: Log Subsystem Vendor and Device Information drm/radeon: Extended DDC Probing for Connectors with Improperly Wired DDC Lines (here: Asus M2A-VM HDMI) drm: Separate EDID Header Check from EDID Block Check drm: Add NULL check about irq functions drm: Fix irq install error handling drm/radeon: fix potential NULL dereference in drivers/gpu/drm/radeon/atom.c drm/radeon: clean reg header files drm/debugfs: Initialise empty variable drm/radeon/kms: add thermal chip quirk for asus 9600xt drm/radeon: off by one in check_reg() functions drm/radeon/kms: fix version comment due to merge timing drm/i915: allow cache sharing policy control drm/i915/hdmi: HDMI source product description infoframe support drm/i915/hdmi: split infoframe setting from infoframe type code drm: track CEA version number if present drm/i915: Try enabling RC6 by default (again) Revert "drm/i915/dp: Zero the DPCD data before connection probe" drm/i915/dp: wait for previous AUX channel activity to clear ...
2011-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits) ipv6: check for IPv4 mapped addresses when connecting IPv6 sockets mlx4: decreasing ref count when removing mac net: Fix security_socket_sendmsg() bypass problem. net: Cap number of elements for sendmmsg net: sendmmsg should only return an error if no messages were sent ixgbe: fix PHY link setup for 82599 ixgbe: fix __ixgbe_notify_dca() bail out code igb: fix WOL on second port of i350 device e1000e: minor re-order of #include files e1000e: remove unnecessary check for NULL pointer intel drivers: repair missing flush operations macb: restore wrap bit when performing underrun cleanup cdc_ncm: fix endianness problem. irda: use PCI_VENDOR_ID_* mlx4: Fixing Ethernet unicast packet steering net: fix NULL dereferences in check_peer_redir() bnx2x: Clear MDIO access warning during first driver load bnx2x: Fix BCM578xx MAC test bnx2x: Fix BCM54618se invalid link indication bnx2x: Fix BCM84833 link ...
2011-08-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: RCUify freeing acls, let check_acl() go ahead in RCU mode if acl is cached get rid of boilerplate switches in posix_acl.h fix block device fallout from ->fsync() changes
2011-08-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dmaengine: use DEFINE_IDR for static initialization ioat: fix xor_idx_to_desc Avoid section type conflict in dma/ioat/dma_v3.c ioat: Adding PCI IDs for IOAT devices on SandyBridge platforms
2011-08-04nfs_xdr: Move nfs4_string definition out of #ifdef CONFIG_NFS_V4Boaz Harrosh
exofs file system wants to use pnfs_osd_xdr.h file instead of redefining pnfs-objects types in it's private "pnfs.h" headr. Before we do the switch we must make sure pnfs_osd_xdr.h is compilable also under NFS versions smaller than 4.1. Since now it is needed regardless of version, by the exofs code. nfs4_string is not the only nfs4 type out in the global scope. Ack-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-08-04Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: Revert "dt: add of_alias_scan and of_alias_get_id" dt: remove of_alias_get_id() reference
2011-08-04drm: Separate EDID Header Check from EDID Block CheckThomas Reim
Provides function drm_edid_header_is_valid() for EDID header check and replaces EDID header check part of function drm_edid_block_valid() by a call of drm_edid_header_is_valid(). This is a prerequisite to extend DDC probing, e. g. in function radeon_ddc_probe() for Radeon devices, by a central EDID header check. Tested for kernel 2.6.35, 2.6.38 and 3.0 Cc: <stable@kernel.org> Signed-off-by: Thomas Reim <reimth@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Acked-by: Stephen Michaels <Stephen.Micheals@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-08-04Merge branch 'drm-intel-next' of ↵Dave Airlie
ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 into drm-fixes * 'drm-intel-next' of ssh://master.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: (42 commits) drm/i915: allow cache sharing policy control drm/i915/hdmi: HDMI source product description infoframe support drm/i915/hdmi: split infoframe setting from infoframe type code drm: track CEA version number if present drm/i915: Try enabling RC6 by default (again) Revert "drm/i915/dp: Zero the DPCD data before connection probe" drm/i915/dp: wait for previous AUX channel activity to clear drm/i915: don't use uninitialized EDID bpc values when picking pipe bpp drm/i915/pch: Save/restore PCH_PORT_HOTPLUG across suspend drm/i915: apply phase pointer override on SNB+ too drm/i915: Add quirk to disable SSC on Sony Vaio Y2 drm/i915: provide more error output when mode sets fail drm/i915: add GPU max frequency control file i915: add Dell OptiPlex FX170 to intel_no_lvds drm/i915: Ignore GPU wedged errors while pinning scanout buffers drm/i915/hdmi: send AVI info frames on ILK+ as well drm/i915: fix CB tuning check for ILK+ drm/i915: Flush other plane register writes drm/i915: flush plane control changes on ILK+ as well drm/i915: apply timing generator bug workaround on CPT and PPT ...
2011-08-04Revert "dt: add of_alias_scan and of_alias_get_id"Grant Likely
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb. of_alias_* still needs work to be generalized for 'promtree' dt platforms, and to no implicitly create entries for available ids. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-03Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle: stop depending on pm_idle x86 idle: move mwait_idle_with_hints() to where it is used cpuidle: replace xen access to x86 pm_idle and default_idle cpuidle: create bootparam "cpuidle.off=1" mrst_pmu: driver for Intel Moorestown Power Management Unit
2011-08-03Merge branch 'apei-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'apei-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI, APEI, EINJ Param support is disabled by default APEI GHES: 32-bit buildfix ACPI: APEI build fix ACPI, APEI, GHES: Add hardware memory error recovery support HWPoison: add memory_failure_queue() ACPI, APEI, GHES, Error records content based throttle ACPI, APEI, GHES, printk support for recoverable error via NMI lib, Make gen_pool memory allocator lockless lib, Add lock-less NULL terminated single list Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHG ACPI, APEI, Add WHEA _OSC support ACPI, APEI, Add APEI bit support in generic _OSC call ACPI, APEI, GHES, Support disable GHES at boot time ACPI, APEI, GHES, Prevent GHES to be built as module ACPI, APEI, Use apei_exec_run_optional in APEI EINJ and ERST ACPI, APEI, Add apei_exec_run_optional ACPI, APEI, GHES, Do not ratelimit fatal error printk before panic ACPI, APEI, ERST, Fix erst-dbg long record reading issue ACPI, APEI, ERST, Prevent erst_dbg from loading if ERST is disabled
2011-08-03Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: dt: add of_alias_scan and of_alias_get_id
2011-08-03drm: track CEA version number if presentJesse Barnes
Drivers need to know the CEA version number in addition to other display info (like whether the display is an HDMI sink) before enabling certain features. So track the CEA version number in the display info structure. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-08-03tmpfs radix_tree: locate_item to speed up swapoffHugh Dickins
We have already acknowledged that swapoff of a tmpfs file is slower than it was before conversion to the generic radix_tree: a little slower there will be acceptable, if the hotter paths are faster. But it was a shock to find swapoff of a 500MB file 20 times slower on my laptop, taking 10 minutes; and at that rate it significantly slows down my testing. Now, most of that turned out to be overhead from PROVE_LOCKING and PROVE_RCU: without those it was only 4 times slower than before; and more realistic tests on other machines don't fare as badly. I've tried a number of things to improve it, including tagging the swap entries, then doing lookup by tag: I'd expected that to halve the time, but in practice it's erratic, and often counter-productive. The only change I've so far found to make a consistent improvement, is to short-circuit the way we go back and forth, gang lookup packing entries into the array supplied, then shmem scanning that array for the target entry. Scanning in place doubles the speed, so it's now only twice as slow as before (or three times slower when the PROVEs are on). So, add radix_tree_locate_item() as an expedient, once-off, single-caller hack to do the lookup directly in place. #ifdef it on CONFIG_SHMEM and CONFIG_SWAP, as much to document its limited applicability as save space in other configurations. And, sadly, #include sched.h for cond_resched(). Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: use kmemdup for short symlinksHugh Dickins
But we've not yet removed the old swp_entry_t i_direct[16] from shmem_inode_info. That's because it was still being shared with the inline symlink. Remove it now (saving 64 or 128 bytes from shmem inode size), and use kmemdup() for short symlinks, say, those up to 128 bytes. I wonder why mpol_free_shared_policy() is done in shmem_destroy_inode() rather than shmem_evict_inode(), where we usually do such freeing? I guess it doesn't matter, and I'm not into NUMA mpol testing right now. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: convert mem_cgroup shmem to radix-swapHugh Dickins
Remove mem_cgroup_shmem_charge_fallback(): it was only required when we had to move swappage to filecache with GFP_NOWAIT. Remove the GFP_NOWAIT special case from mem_cgroup_cache_charge(), by moving its call out from shmem_add_to_page_cache() to two of thats three callers. But leave it doing mem_cgroup_uncharge_cache_page() on error: although asymmetrical, it's easier for all 3 callers to handle. These two changes would also be appropriate if anyone were to start using shmem_read_mapping_page_gfp() with GFP_NOWAIT. Remove mem_cgroup_get_shmem_target(): mc_handle_file_pte() can test radix_tree_exceptional_entry() to get what it needs for itself. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: miscellaneous trivial cleanupsHugh Dickins
While it's at its least, make a number of boring nitpicky cleanups to shmem.c, mostly for consistency of variable naming. Things like "swap" instead of "entry", "pgoff_t index" instead of "unsigned long idx". And since everything else here is prefixed "shmem_", better change init_tmpfs() to shmem_init(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: demolish old swap vector supportHugh Dickins
The maximum size of a shmem/tmpfs file has been limited by the maximum size of its triple-indirect swap vector. With 4kB page size, maximum filesize was just over 2TB on a 32-bit kernel, but sadly one eighth of that on a 64-bit kernel. (With 8kB page size, maximum filesize was just over 4TB on a 64-bit kernel, but 16TB on a 32-bit kernel, MAX_LFS_FILESIZE being then more restrictive than swap vector layout.) It's a shame that tmpfs should be more restrictive than ramfs, and this limitation has now been noticed. Add another level to the swap vector? No, it became obscure and hard to maintain, once I complicated it to make use of highmem pages nine years ago: better choose another way. Surely, if 2.4 had had the radix tree pagecache introduced in 2.5, then tmpfs would never have invented its own peculiar radix tree: we would have fitted swap entries into the common radix tree instead, in much the same way as we fit swap entries into page tables. And why should each file have a separate radix tree for its pages and for its swap entries? The swap entries are required precisely where and when the pages are not. We want to put them together in a single radix tree: which can then avoid much of the locking which was needed to prevent them from being exchanged underneath us. This also avoids the waste of memory devoted to swap vectors, first in the shmem_inode itself, then at least two more pages once a file grew beyond 16 data pages (pages accounted by df and du, but not by memcg). Allocated upfront, to avoid allocation when under swapping pressure, but pure waste when CONFIG_SWAP is not set - I have never spattered around the ifdefs to prevent that, preferring this move to sharing the common radix tree instead. There are three downsides to sharing the radix tree. One, that it binds tmpfs more tightly to the rest of mm, either requiring knowledge of swap entries in radix tree there, or duplication of its code here in shmem.c. I believe that the simplications and memory savings (and probable higher performance, not yet measured) justify that. Two, that on HIGHMEM systems with SWAP enabled, it's the lowmem radix nodes that cannot be freed under memory pressure - whereas before it was the less precious highmem swap vector pages that could not be freed. I'm hoping that 64-bit has now been accessible for long enough, that the highmem argument has grown much less persuasive. Three, that swapoff is slower than it used to be on tmpfs files, since it's using a simple generic mechanism not tailored to it: I find this noticeable, and shall want to improve, but maybe nobody else will notice. So... now remove most of the old swap vector code from shmem.c. But, for the moment, keep the simple i_direct vector of 16 pages, with simple accessors shmem_put_swap() and shmem_get_swap(), as a toy implementation to help mark where swap needs to be handled in subsequent patches. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03mm: let swap use exceptional entriesHugh Dickins
If swap entries are to be stored along with struct page pointers in a radix tree, they need to be distinguished as exceptional entries. Most of the handling of swap entries in radix tree will be contained in shmem.c, but a few functions in filemap.c's common code need to check for their appearance: find_get_page(), find_lock_page(), find_get_pages() and find_get_pages_contig(). So as not to slow their fast paths, tuck those checks inside the existing checks for unlikely radix_tree_deref_slot(); except for find_lock_page(), where it is an added test. And make it a BUG in find_get_pages_tag(), which is not applied to tmpfs files. A part of the reason for eliminating shmem_readpage() earlier, was to minimize the places where common code would need to allow for swap entries. The swp_entry_t known to swapfile.c must be massaged into a slightly different form when stored in the radix tree, just as it gets massaged into a pte_t when stored in page tables. In an i386 kernel this limits its information (type and page offset) to 30 bits: given 32 "types" of swapfile and 4kB pagesize, that's a maximum swapfile size of 128GB. Which is less than the 512GB we previously allowed with X86_PAE (where the swap entry can occupy the entire upper 32 bits of a pte_t), but not a new limitation on 32-bit without PAE; and there's not a new limitation on 64-bit (where swap filesize is already limited to 16TB by a 32-bit page offset). Thirty areas of 128GB is probably still enough swap for a 64GB 32-bit machine. Provide swp_to_radix_entry() and radix_to_swp_entry() conversions, and enforce filesize limit in read_swap_header(), just as for ptes. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03radix_tree: exceptional entries and indicesHugh Dickins
A patchset to extend tmpfs to MAX_LFS_FILESIZE by abandoning its peculiar swap vector, instead keeping a file's swap entries in the same radix tree as its struct page pointers: thus saving memory, and simplifying its code and locking. This patch: The radix_tree is used by several subsystems for different purposes. A major use is to store the struct page pointers of a file's pagecache for memory management. But what if mm wanted to store something other than page pointers there too? The low bit of a radix_tree entry is already used to denote an indirect pointer, for internal use, and the unlikely radix_tree_deref_retry() case. Define the next bit as denoting an exceptional entry, and supply inline functions radix_tree_exception() to return non-0 in either unlikely case, and radix_tree_exceptional_entry() to return non-0 in the second case. If a subsystem already uses radix_tree with that bit set, no problem: it does not affect internal workings at all, but is defined for the convenience of those storing well-aligned pointers in the radix_tree. The radix_tree_gang_lookups have an implicit assumption that the caller can deduce the offset of each entry returned e.g. by the page->index of a struct page. But that may not be feasible for some kinds of item to be stored there. radix_tree_gang_lookup_slot() allow for an optional indices argument, output array in which to return those offsets. The same could be added to other radix_tree_gang_lookups, but for now keep it to the only one for which we need it. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03drivers/video/backlight/aat2870_bl.c: fix setting max_currentAxel Lin
- Current implementation tests wrong value for setting aat2870_bl->max_current. - In the current implementation, we cannot differentiate between 2 cases: a) if pdata->max_current is not set , or b) pdata->max_current is set to AAT2870_CURRENT_0_45 (which is also 0). Fix it by setting AAT2870_CURRENT_0_45 to be 1 and adjust the equation in aat2870_brightness() accordingly. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Samuel Ortiz <sameo@linux.intel.com> Tested-by: Jin Park <jinyoungp@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03mm: page_alloc: increase __GFP_BITS_SHIFT to include __GFP_OTHER_NODEJohannes Weiner
__GFP_OTHER_NODE is used for NUMA allocations on behalf of other nodes. It's supposed to be passed through from the page allocator to zone_statistics(), but it never gets there as gfp_allowed_mask is not wide enough and masks out the flag early in the allocation path. The result is an accounting glitch where successful NUMA allocations by-agent are not properly attributed as local. Increase __GFP_BITS_SHIFT so that it includes __GFP_OTHER_NODE. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03ida: simplified functions for id allocationRusty Russell
The current hyper-optimized functions are overkill if you simply want to allocate an id for a device. Create versions which use an internal lock. In followup patches, numerous drivers are converted to use this interface. Thanks to Tejun for feedback. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03fault-injection: add ability to export fault_attr in arbitrary directoryAkinobu Mita
init_fault_attr_dentries() is used to export fault_attr via debugfs. But it can only export it in debugfs root directory. Per Forlin is working on mmc_fail_request which adds support to inject data errors after a completed host transfer in MMC subsystem. The fault_attr for mmc_fail_request should be defined per mmc host and export it in debugfs directory per mmc host like /sys/kernel/debug/mmc0/mmc_fail_request. init_fault_attr_dentries() doesn't help for mmc_fail_request. So this introduces fault_create_debugfs_attr() which is able to create a directory in the arbitrary directory and replace init_fault_attr_dentries(). [akpm@linux-foundation.org: extraneous semicolon, per Randy] Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Tested-by: Per Forlin <per.forlin@linaro.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
