Extend the clock control for FlexCAN with the second gate which
enable the clocks in the Clock Divider (CCM_CSCDR2) register too.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds missing 26 MHz oscillator circuit clock gate support.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Use clock defines in order to make devicetrees more human readable.
i.MX1 camera driver has been removed by the commit 90b055898e.
This patch removes remaining support files for this camera.
This patch adds devicetree support CCM module for i.MX21 CPUs.
Instead of using enum for clock ID, let's switch imx6qdl clock driver to
use macro. In this case, device tree can reuse these macros to improve
readability.
The platform_data header usb-ehci-mxc.h has a lot of stuff used by only
IMX platform code. They shouldn't be really in this header but a IMX
platform local header. Create ehci.h and move these stuff into it.
imx_udc driver was removed from the kernel of about 10 months ago.
This patch removes a registration helper for this driver and
orphaned driver header.
This patch adds devicetree support CCM module for i.MX1 (MC9328MX1) CPUs.
Pull SCSI target fixes from Nicholas Bellinger:
"Mostly minor fixes this time around. The highlights include:
- iscsi-target CHAP authentication fixes to enforce explicit key
values (Tejas Vaykole + rahul.rane)
- fix a long-standing OOPs in target-core when a alua configfs
attribute is accessed after port symlink has been removed.
(Sebastian Herbszt)
- fix a v3.10.y iscsi-target regression causing the login reject
status class/detail to be ignored (Christoph Vu-Brugier)
- fix a v3.10.y iscsi-target regression to avoid rejecting an
existing ITT during Data-Out when data-direction is wrong (Santosh
Kulkarni + Arshad Hussain)
- fix a iscsi-target related shutdown deadlock on UP kernels (Mikulas
Patocka)
- fix a v3.16-rc1 build issue with vhost-scsi + !CONFIG_NET (MST)"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target: fix iscsit_del_np deadlock on unload
iovec: move memcpy_from/toiovecend to lib/iovec.c
iscsi-target: Avoid rejecting incorrect ITT for Data-Out
tcm_loop: Fix memory leak in tcm_loop_submission_work error path
iscsi-target: Explicily clear login response PDU in exception path
target: Fix left-over se_lun->lun_sep pointer OOPs
iscsi-target; Enforce 1024 byte maximum for CHAP_C key value
iscsi-target: Convert chap_server_compute_md5 to use kstrtoul
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here includes a few patchset for fixing mostly HD-audio issues in
addition to a patch assuring the compress API bytes alignment and a
fix for the die-hard existing race condition at USB-audio
disconnection. The volume looks big in Realtek HD-audio code, but
it's just a translation of the fixup tables, and the actual changes
are rather trivial"
* tag 'sound-3.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - restore BCLK M/N values when resuming HSW/BDW display controller
ALSA: usb-audio: Fix races at disconnection and PCM closing
ALSA: hda - Adjust speaker HPF and add LED support for HP Spectre 13
ALSA: hda - Make the pin quirk tables use the SND_HDA_PIN_QUIRK macro
ALSA: hda - Make a SND_HDA_PIN_QUIRK macro
ALSA: hda - Add pin quirk for Dell XPS 15
ALSA: hda - hdmi: call overridden init on resume
ALSA: hda - Fix usage of "model" module parameter
ALSA: compress: fix the struct alignment to 4 bytes
Pull drm fixes from Dave Airlie:
"Exynos, i915 and msm fixes and one core fix.
exynos:
hdmi power off and mixer issues
msm:
iommu, build fixes,
i915:
regression races and warning fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (22 commits)
drm/i915: vlv_prepare_pll is only needed in case of non DSI interfaces
drm: fix NULL pointer access by wrong ioctl
drm/exynos: enable vsync interrupt while waiting for vblank
drm/exynos: soft reset mixer before reconfigure after power-on
drm/exynos: allow multiple layer updates per vsync for mixer
drm/i915: Hold the table lock whilst walking the file's idr and counting the objects in debugfs
drm/i915: BDW: Adding Reserved PCI IDs.
drm/i915: Only mark the ctx as initialised after a SET_CONTEXT operation
drm/exynos: stop mixer before gating clocks during poweroff
drm/exynos: set power state variable after enabling clocks and power
drm/exynos: disable unused windows on apply
drm/exynos: Fix de-registration ordering
drm/exynos: change zero to NULL for sparse
drm/exynos: dpi: Fix NULL pointer dereference with legacy bindings
drm/exynos: hdmi: fix power order issue
drm/i915: default to having backlight if VBT not available
drm/i915: cache hw power well enabled state
drm/msm: fix IOMMU cleanup for -EPROBE_DEFER
drm/msm: use PAGE_ALIGNED instead of IS_ALIGNED(PAGE_SIZE)
drm/msm/hdmi: set hdp clock rate before prepare_enable
ERROR: "memcpy_fromiovecend" [drivers/vhost/vhost_scsi.ko] undefined!
commit 9f977ef7b671f6169eca78bf40f230fe84b7c7e5
vhost-scsi: Include prot_bytes into expected data transfer length
in target-pending makes drivers/vhost/scsi.c call memcpy_fromiovecend().
This function is not available when CONFIG_NET is not enabled.
socket.h already includes uio.h, so no callers need updating.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Pull block fixes from Jens Axboe:
"A small collection of fixes/changes for the current series. This
contains:
- Removal of dead code from Gu Zheng.
- Revert of two bad fixes that went in earlier in this round, marking
things as __init that were not purely used from init.
- A fix for blk_mq_start_hw_queue() using the __blk_mq_run_hw_queue(),
which could place us wrongly. Make it use the non __ variant,
which handles cases where we are called from the wrong CPU set.
From me.
- A fix for drbd, which allocates discard requests without room for
the SCSI payload. From Lars Ellenberg.
- A fix for user-after-free in the blkcg code from Tejun.
- Addition of limiting gaps in SG lists, if the hardware needs it.
This is the last pre-req patch for blk-mq to enable the full NVMe
conversion. Could wait until 3.17, but it's simple enough so would
be nice to have everything we need for the NVMe port in the 3.17
release. From me"
* 'for-linus' of git://git.kernel.dk/linux-block:
drbd: fix NULL pointer deref in blk_add_request_payload
blk-mq: blk_mq_start_hw_queue() should use blk_mq_run_hw_queue()
block: add support for limiting gaps in SG lists
bio: remove unused macro bip_vec_idx()
Revert "block: add __init to elv_register"
Revert "block: add __init to blkcg_policy_register"
blkcg: fix use-after-free in __blkg_release_rcu() by making blkcg_gq refcnt an atomic_t
floppy: format block0 read error message properly
blkdev_read_iter() wants to cap the iov_iter by the amount of data
remaining to the end of device. That's what iov_iter_truncate() is for
(trim iter->count if it's above the given limit). So far, so good, but
the argument of iov_iter_truncate() is size_t, so on 32bit boxen (in
case of a large device) we end up with that upper limit truncated down
to 32 bits *before* comparing it with iter->count.
Easily fixed by making iov_iter_truncate() take 64bit argument - it does
the right thing after such change (we only reach the assignment in there
when the current value of iter->count is greater than the limit, i.e.
for anything that would get truncated we don't reach the assignment at
all) and that argument is not the new value of iter->count - it's an
upper limit for such.
The overhead of passing u64 is not an issue - the thing is inlined, so
callers passing size_t won't pay any penalty.
Reported-and-tested-by: Theodore Tso <tytso@mit.edu>
Tested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Tested-by: Bruno Wolff III <bruno@wolff.to>
Pull networking fixes from David Miller:
1) Fix crash in ipvs tot_stats estimator, from Julian Anastasov.
2) Fix OOPS in nf_nat on netns removal, from Florian Westphal.
3) Really really really fix locking issues in slip and slcan tty write
wakeups, from Tyler Hall.
4) Fix checksum offloading in fec driver, from Fugang Duan.
5) Off by one in BPF instruction limit test, from Kees Cook.
6) Need to clear all TSO capability flags when doing software TSO in
tg3 driver, from Prashant Sreedharan.
7) Fix memory leak in vlan_reorder_header() error path, from Li
RongQing.
8) Fix various bugs in xen-netfront and xen-netback multiqueue support,
from David Vrabel and Wei Liu.
9) Fix deadlock in cxgb4 driver, from Li RongQing.
10) Prevent double free of no-cache DST entries, from Eric Dumazet.
11) Bad csum_start handling in skb_segment() leads to crashes when
forwarding, from Tom Herbert.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits)
net: fix setting csum_start in skb_segment()
ipv4: fix dst race in sk_dst_get()
net: filter: Use kcalloc/kmalloc_array to allocate arrays
trivial: net: filter: Change kerneldoc parameter order
trivial: net: filter: Fix typo in comment
net: allwinner: emac: Add missing free_irq
cxgb4: use dev_port to identify ports
xen-netback: bookkeep number of active queues in our own module
tg3: Change nvram command timeout value to 50ms
cxgb4: Not need to hold the adap_rcu_lock lock when read adap_rcu_list
be2net: fix qnq mode detection on VFs
of: mdio: fixup of_phy_register_fixed_link parsing of new bindings
at86rf230: fix irq setup
net: phy: at803x: fix coccinelle warnings
net/mlx4_core: Fix the error flow when probing with invalid VF configuration
tulip: Poll link status more frequently for Comet chips
net: huawei_cdc_ncm: increase command buffer size
drivers: net: cpsw: fix dual EMAC stall when connected to same switch
xen-netfront: recreate queues correctly when reconnecting
xen-netfront: fix oops when disconnected from backend
When IP route cache had been removed in linux-3.6, we broke assumption
that dst entries were all freed after rcu grace period. DST_NOCACHE
dst were supposed to be freed from dst_release(). But it appears
we want to keep such dst around, either in UDP sockets or tunnels.
In sk_dst_get() we need to make sure dst refcount is not 0
before incrementing it, or else we might end up freeing a dst
twice.
DST_NOCACHE set on a dst does not mean this dst can not be attached
to a socket or a tunnel.
Then, before actual freeing, we need to observe a rcu grace period
to make sure all other cpus can catch the fact the dst is no longer
usable.
Reported-by: Dormando <dormando@rydia.net>
Pull ARM SoC fixes from Arnd Bergmann:
"A new set of bug fixes for 3.16, containing patches for seven
platforms:
at91:
- drivers/misc fix for Kconfig PWM symbol
- correction of several values in DT after conversion to CCF
- fix at91sam9261/at91sam9261ek mistake in slow crystal vs. slow RC osc
imx:
- Use GPIO for card CD/WP on imx51-babbage and eukrea-mbimxsd51,
because controller base CD/WP is not working in esdhc driver due to
runtime PM support
- A couple of random ventana gw5xxx board fixes
- Add IMX_IPUV3_CORE back to defconfig, which gets lost when moving
IPUv3 driver out of staging tree
- Fix enet/fec clock selection on imx6sl
- Fix display node on imx53-m53evk board
- A couple of Cubox-i updates from Russell, which were omitted from
the merge window due to dependency
integrator:
- fix an OF-related regression against 3.15
mvebu:
- mvebu (v7)
- Fix broken SoC ID detection
- Select ARM_CPU_SUSPEND for v7
- Remove armada38x compatible string (no users yet)
- Enable Dove SoC in mvebu_v7_defconfig
- kirkwood
- Fix phy-connection-type on GuruPlug board
qcom:
- enable gsbi driver in defconfig
- fix section mismatch warning in serial driver
samsung:
- use WFI macro in platform_do_lowpower because exynos cpuhotplug
includes a hardcoded WFI instruction and it causes compile error
in Thumb-2 mode.
- fix GIC reg sizes for exynos4 SoCs
- remove reset timer counter value during boot and resume for mct
to fix a big jump in printk timestamps
- fix pm code to check cortex-A9 for another exynos SoCs
- don't rely on firmware's secondary_cpu_start for mcpm
sti:
- Ethernet clocks were wrongly defined for STiH415/416 platforms
- STiH416 B2020 revision E DTS file name contained uppercase, change to
lowercase"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (33 commits)
ARM: at91/dt: sam9261: remove slow RC osc
ARM: at91/dt: define sam9261ek slow crystal frequency
ARM: at91/dt: sam9261: correctly define mainck
ARM: at91/dt: sam9n12: correct PLLA ICPLL and OUT values
ARM: at91/dt: sam9x5: correct PLLA ICPLL and OUT values
misc: atmel_pwm: fix Kconfig symbols
ARM: integrator: fix OF-related regression
ARM: mvebu: Fix the improper use of the compatible string armada38x using a wildcard
ARM: dts: kirkwood: fix phy-connection-type for Guruplug
ARM: EXYNOS: Don't rely on firmware's secondary_cpu_start for mcpm
ARM: dts: imx51-eukrea-mbimxsd51-baseboard: unbreak esdhc.
ARM: dts: imx51-babbage: Fix esdhc setup
ARM: dts: mx5: Move the display out of soc {} node
ARM: dts: mx5: Fix IPU port node placement
ARM: mvebu: select ARM_CPU_SUSPEND for Marvell EBU v7 platforms
ARM: mvebu: Fix broken SoC ID detection
ARM: imx_v6_v7_defconfig: Enable CONFIG_IMX_IPUV3_CORE
ARM: multi_v7_defconfig: Add QCOM GSBI driver
ARM: stih41x: Rename stih416-b2020-revE.dts to stih416-b2020e.dts
tty: serial: msm: Fix section mismatch warning
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing cleanups and fixes from Steven Rostedt:
"This includes three patches from Oleg Nesterov. The first is a fix to
a race condition that happens between enabling/disabling syscall
tracepoints and new process creations (the check to go into the ptrace
path for a process can be set when it shouldn't, or not set when it
should). Not a major bug but one that should be fixed and even
applied to stable.
The other two patches are cleanup/fixes that are not that critical,
but for an -rc1 release would be nice to have. They both deal with
syscall tracepoints.
It also includes a patch to introduce a new macro for the
TRACE_EVENT() format called __field_struct(). Originally, __field()
was used to record any variable into a trace event, but with the
addition of setting the "is signed" attribute, the check causes
anything but a primitive variable to fail to compile. That is,
structs and unions can't be used as they once were. When the "is
signed" check was introduce there were only primitive variables being
recorded. But that will change soon and it was reported that
__field() causes build failures.
To solve the __field() issue, __field_struct() is introduced to allow
trace_events to be able to record complex types too"
* tag 'trace-fixes-v3.16-rc1-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add __field_struct macro for TRACE_EVENT()
tracing: syscall_regfunc() should not skip kernel threads
tracing: Change syscall_*regfunc() to check PF_KTHREAD and use for_each_process_thread()
tracing: Fix syscall_*regfunc() vs copy_process() race
Another restriction inherited for NVMe - those devices don't support
SG lists that have "gaps" in them. Gaps refers to cases where the
previous SG entry doesn't end on a page boundary. For NVMe, all SG
entries must start at offset 0 (except the first) and end on a page
boundary (except the last).
Signed-off-by: Jens Axboe <axboe@fb.com>
Macro bip_vec_idx() was used by bio integrity originally, but no longer
used now. So remove it.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
These PCI IDs are reserved on BSpec and can be used at any time in the future.
So let's add this now in order to avoid issues that we already faced on previous
platforms, like finding out about new ids when user reported accelaration weren't
enabled.
Cc: stable@vger.kernel.org
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
A 'softlockup' is defined as a bug that causes the kernel to loop in
kernel mode for more than a predefined period to time, without giving
other tasks a chance to run.
Currently, upon detection of this condition by the per-cpu watchdog
task, debug information (including a stack trace) is sent to the system
log.
On some occasions, we have observed that the "victim" rather than the
actual "culprit" (i.e. the owner/holder of the contended resource) is
reported to the user. Often this information has proven to be
insufficient to assist debugging efforts.
To avoid loss of useful debug information, for architectures which
support NMI, this patch makes it possible to improve soft lockup
reporting. This is accomplished by issuing an NMI to each cpu to obtain
a stack trace.
If NMI is not supported we just revert back to the old method. A sysctl
and boot-time parameter is available to toggle this feature.
[dzickus@redhat.com: add CONFIG_SMP in certain areas]
[akpm@linux-foundation.org: additional CONFIG_SMP=n optimisations]
[mq@suse.cz: fix warning]
Signed-off-by: Aaron Tomlin <atomlin@redhat.com>
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Mateusz Guzik <mguzik@redhat.com>
Signed-off-by: Jan Moskyto Matejka <mq@suse.cz>
Sometimes it is preferred not to use the trigger_all_cpu_backtrace()
routine when one wants to avoid capturing a back trace for current. For
instance if one was previously captured recently.
This patch provides a new routine namely
trigger_allbutself_cpu_backtrace() which offers the flexibility to issue
an NMI to every cpu but current and capture a back trace accordingly.
Patch x86 and sparc to support new routine.
[dzickus@redhat.com: add stub in #else clause]
[dzickus@redhat.com: don't print message in single processor case, wrap with get/put_cpu based on Oleg's suggestion]
[sfr@canb.auug.org.au: undo C99ism]
To allow filtering of huge pages, makedumpfile must be able to identify
them in the dump. This can be done by checking the appropriate page
flag, so communicate its value to makedumpfile through the VMCOREINFO
interface.
There's only one small catch. Depending on how many page flags are
available on a given architecture, this bit can be called PG_head or
PG_compound.
I sent a similar patch back in 2012, but Eric Biederman did not like
using an #ifdef. So, this time I'm adding a common symbol
(PG_head_mask) instead.
See https://lkml.org/lkml/2012/11/28/91 for the previous version.
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: Alexey Kardashevskiy <aik@ozlabs.ru>
Cc: Sasha Levin <sasha.levin@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes
Pull "i.MX fixes for 3.16" from Shawn Guo:
runtime PM support
* tag 'imx-fixes-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux:
ARM: dts: hummingboard/cubox-i: move usb otg configuration to platform level
ARM: dts: cubox-i: add support for PWM-driven front panel LED
ARM: dts: imx6: ventana: correct gw52xx sgtl5000 clock source
ARM: dts: imx6qdl-gw5xxx: Fix Linear Technology vendor prefix
ARM: dts: imx6: ventana: fix include typo
ARM: dts: imx6sl: correct the fec ipg clock source
ARM: imx6sl: add missing enet clock for imx6sl
In 64bit systems the compiler can default align to 8bytes causing mis-match with
32bit usermode. Avoid this is future by ensuring all the structures shared with
usermode are packed and aligned to 4 bytes irrespective of arch used
[coding style fixes by tiwai]
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
This reverts commit b5097e956a4d2919ee248d6481e4204c5568ed5c.
The original commit is buggy, we do use the registration functions
at runtime, for instance when loading IO schedulers through sysfs.
Reported-by: Damien Wyart <damien.wyart@gmail.com>
Pull file locking fixes from Jeff Layton:
"File locking related bugfixes
Nothing too earth-shattering here. A fix for a potential regression
due to a patch in pile #1, and the addition of a memory barrier to
prevent a race condition between break_deleg and generic_add_lease"
* tag 'locks-v3.16-2' of git://git.samba.org/jlayton/linux:
locks: set fl_owner for leases back to current->files
locks: add missing memory barrier in break_deleg
Add a notify callback to inform phy drivers when the core is about to
do its link adjustment. No change for drivers that do not implement
this callback.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Pull perf fixes from Ingo Molnar:
"This is larger than usual: the main reason are the ARM symbol lookup
speedups that came in late and were hard to resist.
There's also a kprobes fix and various tooling fixes, plus the minimal
re-enablement of the mmap2 support interface"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits)
x86/kprobes: Fix build errors and blacklist context_track_user
perf tests: Add test for closing dso objects on EMFILE error
perf tests: Add test for caching dso file descriptors
perf tests: Allow reuse of test_file function
perf tests: Spawn child for each test
perf tools: Add dso__data_* interface descriptons
perf tools: Allow to close dso fd in case of open failure
perf tools: Add file size check and factor dso__data_read_offset
perf tools: Cache dso data file descriptor
perf tools: Add global count of opened dso objects
perf tools: Add global list of opened dso objects
perf tools: Add data_fd into dso object
perf tools: Separate dso data related variables
perf tools: Cache register accesses for unwind processing
perf record: Fix to honor user freq/interval properly
perf timechart: Reflow documentation
perf probe: Improve error messages in --line option
perf probe: Improve an error message of perf probe --vars mode
perf probe: Show error code and description in verbose mode
perf probe: Improve error message for unknown member of data structure
Currently the __field() macro in TRACE_EVENT is only good for primitive
values, such as integers and pointers, but it fails on complex data types
such as structures or unions. This is because the __field() macro
determines if the variable is signed or not with the test of:
(((type)(-1)) < (type)1)
Unfortunately, that fails when type is a structure.
Since trace events should support structures as fields a new macro
is created for such a case called __field_struct() which acts exactly
the same as __field() does but it does not do the signed type check
and just uses a constant false for that answer.
Cc: Tony Luck <tony.luck@gmail.com>
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Cc: stable@vger.kernel.org # 2.6.33
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Pull ACPI and power management fixes from Rafael Wysocki:
"These are fixes mostly (ia64 regression related to the ACPI
enumeration of devices, cpufreq regressions, fix for I2C controllers
included in Intel SoCs, mvebu cpuidle driver fix related to sysfs)
plus additional kernel command line arguments from Kees to make it
possible to build kernel images with hibernation and the kernel
address space randomization included simultaneously, a new ACPI
battery driver quirk for a system with a broken BIOS and a couple of
ACPI core cleanups.
Specifics:
- Fix for an ia64 regression introduced during the 3.11 cycle by a
commit that modified the hardware initialization ordering and made
device discovery fail on some systems.
- Fix for a build problem on systems where the cpufreq-cpu0 driver is
built-in and the cpu-thermal driver is modular from Arnd Bergmann.
- Fix for a recently introduced computational mistake in the
intel_pstate driver that leads to excessive rounding errors from
Doug Smythies.
- Fix for a failure code path in cpufreq_update_policy() that fails
to unlock the locks acquired previously from Aaron Plattner.
- Fix for the cpuidle mvebu driver to use shorter state names which
will prevent the sysfs interface from returning mangled strings.
From Gregory Clement.
- ACPI LPSS driver fix to make sure that the I2C controllers included
in BayTrail SoCs are not held in the reset state while they are
being probed from Mika Westerberg.
- New kernel command line arguments making it possible to build
kernel images with hibernation and kASLR included at the same time
and to select which of them will be used via the command line (they
are still functionally mutually exclusive, though). From Kees
Cook.
- ACPI battery driver quirk for Acer Aspire V5-573G that fails to
send battery status change notifications timely from Alexander
Mezin.
- Two ACPI core cleanups from Christoph Jaeger and Fabian Frederick"
* tag 'pm+acpi-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpuidle: mvebu: Fix the name of the states
cpufreq: unlock when failing cpufreq_update_policy()
intel_pstate: Correct rounding in busy calculation
ACPI: use kstrto*() instead of simple_strto*()
ACPI / processor replace __attribute__((packed)) by __packed
ACPI / battery: add quirk for Acer Aspire V5-573G
ACPI / battery: use callback for setting up quirks
ACPI / LPSS: Take I2C host controllers out of reset
x86, kaslr: boot-time selectable with hibernation
PM / hibernate: introduce "nohibernate" boot parameter
cpufreq: cpufreq-cpu0: fix CPU_THERMAL dependency
ACPI / ia64 / sba_iommu: Restore the working initialization ordering
"The significant part here is a few security fixes for ALSA core
control API by Lars. Besides that, there are a few fixes for ASoC
sigmadsp (again by Lars) for building properly, and small fixes for
ASoC rsnd, MMP, PXA and FSL, in addition to a fix for bogus WARNING in
i915/HD-audio binding"
* tag 'sound-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: control: Make sure that id->index does not overflow
ALSA: control: Handle numid overflow
ALSA: control: Don't access controls outside of protected regions
ALSA: control: Fix replacing user controls
ALSA: control: Protect user controls against concurrent access
drm/i915, HD-audio: Don't continue probing when nomodeset is given
ASoC: fsl: Fix build problem
ASoC: rsnd: fixup index of src/dst mod when capture
ASoC: fsl_spdif: Fix integer overflow when calculating divisors
ASoC: fsl_spdif: Fix incorrect usage of regmap_read()
ASoC: dapm: Make sure register value is in sync with DAPM kcontrol state
ASoC: sigmadsp: Split regmap and I2C support into separate modules
ASoC: MMP audio needs sram support
ASoC: pxa: add I2C dependencies as needed
"A smaller collection of fixes for the block core that would be nice to
have in -rc2. This pull request contains:
- Fixes for races in the wait/wakeup logic used in blk-mq from
Alexander. No issues have been observed, but it is definitely a
bit flakey currently. Alternatively, we may drop the cyclic
wakeups going forward, but that needs more testing.
- Some cleanups from Christoph.
- Fix for an oops in null_blk if queue_mode=1 and softirq completions
are used. From me.
- A fix for a regression caused by the chunk size setting. It
inadvertently used max_hw_sectors instead of max_sectors, which is
incorrect, and causes hangs on btrfs multi-disk setups (where hw
sectors apparently isn't set). From me.
- Removal of WQ_POWER_EFFICIENT in the kblockd creation. This was a
recent addition as well, but it actually breaks blk-mq which relies
on strict scheduling. If the workqueue power_efficient mode is
turned on, this breaks blk-mq. From Matias.
- null_blk module parameter description fix from Mike"
blk-mq: bitmap tag: fix races in bt_get() function
blk-mq: bitmap tag: fix race on blk_mq_bitmap_tags::wake_cnt
blk-mq: bitmap tag: fix races on shared ::wake_index fields
block: blk_max_size_offset() should check ->max_sectors
null_blk: fix softirq completions for queue_mode == 1
blk-mq: merge blk_mq_drain_queue and __blk_mq_drain_queue
blk-mq: properly drain stopped queues
block: remove WQ_POWER_EFFICIENT from kblockd
null_blk: fix name and description of 'queue_mode' module parameter
block: remove elv_abort_queue and blk_abort_flushes
Pull sparc fixes from David Miller:
"Sparc sparse fixes from Sam Ravnborg"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (67 commits)
sparc64: fix sparse warnings in int_64.c
sparc64: fix sparse warning in ftrace.c
sparc64: fix sparse warning in kprobes.c
sparc64: fix sparse warning in kgdb_64.c
sparc64: fix sparse warnings in compat_audit.c
sparc64: fix sparse warnings in init_64.c
sparc64: fix sparse warnings in aes_glue.c
sparc: fix sparse warnings in smp_32.c + smp_64.c
sparc64: fix sparse warnings in perf_event.c
sparc64: fix sparse warnings in kprobes.c
sparc64: fix sparse warning in tsb.c
sparc64: clean up compat_sigset_t.seta handling
sparc64: fix sparse "Should it be static?" warnings in signal32.c
sparc64: fix sparse warnings in sys_sparc32.c
sparc64: fix sparse warning in pci.c
sparc64: fix sparse warnings in smp_64.c
sparc64: fix sparse warning in prom_64.c
sparc64: fix sparse warning in btext.c
sparc64: fix sparse warnings in sys_sparc_64.c + unaligned_64.c
sparc64: fix sparse warning in process_64.c
arch/sparc/include/asm/pgtable_64.h
* pm-sleep:
The user-control put and get handlers as well as the tlv do not protect against
concurrent access from multiple threads. Since the state of the control is not
updated atomically it is possible that either two write operations or a write
and a read operation race against each other. Both can lead to arbitrary memory
disclosure. This patch introduces a new lock that protects user-controls from
concurrent access. Since applications typically access controls sequentially
than in parallel a single lock per card should be fine.
Acked-by: Jaroslav Kysela <perex@perex.cz>
Cc: <stable@vger.kernel.org>
Fix racy updates of shared blk_mq_bitmap_tags::wake_index
and blk_mq_hw_ctx::wake_index fields.
Cc: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Commit 762380ad9322 inadvertently changed a check for max_sectors
to max_hw_sectors. Revert that part, so we still compare against
max_sectors.
This patch fixes two problems: -
1) The device tree isn't currently providing sti-ethclk which is
required by the dwmac glue code to correctly configure the ethernet
PHY clock speed.
This means depending on what the bootloader/jtag has
configured this clock to, and what switch/hub the board is plugged
into you most likely will NOT successfully negotiate a ethernet link.
2) The stmmaceth clock was associated with the wrong clock. It was
referencing the PHY clock rather than the interconnect clock which
clocks the IP.
This patch also brings us closer to not having to boot the upstream
kernel with the clk_ignore_unused parameter.
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
There's a enet clock gate missing in clock tree, thus add it.
Signed-off-by: Fugang Duan <B38611@freescale.com>
This patch fixes checkpatch warnings:
"WARNING: __packed is preferred over __attribute__((packed))"
Signed-off-by: Fabian Frederick <fabf@skynet.be>
To support using kernel features that are not compatible with hibernation,
this creates the "nohibernate" kernel boot parameter to disable both
hibernation and resume. This allows hibernation support to be a boot-time
choice instead of only a compile-time choice.
Acked-by: Pavel Machek <pavel@ucw.cz>
Since 4fefee5 ("netfilter: nf_tables: allow to delete several objects
from a batch"), every new rule bumps the chain use counter. However,
this is limited to 16 bits, which means that it will overrun after
2^16 rules.
Use a u32 chain counter and check for overflows (just like we do for
table objects).
When a machine is booted with nomodeset option, i915 driver skips the
whole initialization. Meanwhile, HD-audio tries to bind wth i915 just
by request_symbol() without knowing that the initialization was
skipped, and eventually it hits WARN_ON() in i915_request_power_well()
and i915_release_power_well() wrongly but still continues probing,
even though it doesn't work at all.
In this patch, both functions are changed to return an error in case
of uninitialized state instead of WARN_ON(), so that HD-audio driver
can give up HDMI controller initialization at the right time.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: <stable@vger.kernel.org> [3.15]
1) Fix checksumming regressions, from Tom Herbert.
2) Undo unintentional permissions changes for SCTP rto_alpha and
rto_beta sysfs knobs, from Denial Borkmann.
3) VXLAN, like other IP tunnels, should advertize it's encapsulation
size using dev->needed_headroom instead of dev->hard_header_len.
From Cong Wang.
net: sctp: fix permissions for rto_alpha and rto_beta knobs
vxlan: Checksum fixes
net: add skb_pop_rcv_encapsulation
udp: call __skb_checksum_complete when doing full checksum
net: Fix save software checksum complete
net: Fix GSO constants to match NETIF flags
udp: ipv4: do not waste time in __udp4_lib_mcast_demux_lookup
vxlan: use dev->needed_headroom instead of dev->hard_header_len
MAINTAINERS: update cxgb4 maintainer
