commit 24cf72518c79cdcda486ed26074ff8151291cf65 upstream.
On NUMA machines, the administrator can configure zone_reclaim_mode that
is a more targetted form of direct reclaim. On machines with large NUMA
distances for example, a zone_reclaim_mode defaults to 1 meaning that
clean unmapped pages will be reclaimed if the zone watermarks are not
being met.
There is a heuristic that determines if the scan is worthwhile but it is
possible that the heuristic will fail and the CPU gets tied up scanning
uselessly. Detecting the situation requires some guesswork and
experimentation so this patch adds a counter "zreclaim_failed" to
/proc/vmstat. If during high CPU utilisation this counter is increasing
rapidly, then the resolution to the problem may be to set
/proc/sys/vm/zone_reclaim_mode to 0.
[akpm@linux-foundation.org: name things consistently]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
commit f9c99bb8b3a1ec81af68d484a551307326c2e933 upstream
This patch splits up the shutdown method of usb_serial_driver into a
disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 2ac6bf4ddc87c3b6b609f8fa82f6ebbffeac12f4 upstream.
The ConnectX Programmer's Reference Manual states that the "SO" bit
must be set when posting Fast Register and Local Invalidate send work
requests. When this bit is set, the work request will be executed
only after all previous work requests on the send queue have been
executed. (If the bit is not set, Fast Register and Local Invalidate
WQEs may begin execution too early, which violates the defined
semantics for these operations)
This fixes the issue with NFS/RDMA reported in
<http://lists.openfabrics.org/pipermail/general/2009-April/059253.html>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit 70beaed22cbe12979e55d99b370e147e2e168562 upstream.
Define ASYNCB_* flags which are bit numbers of the ASYNC_* flags.
This is useful for {test,set,clear}_bit.
Also convert each ASYNC_% to be (1 << ASYNCB_%) and define masks
with the macros, not constants.
Tested with:
#include "PATH_TO_KERNEL/include/linux/serial.h"
static struct {
unsigned int new, old;
} as[] = {
{ ASYNC_HUP_NOTIFY, 0x0001 },
{ ASYNC_FOURPORT, 0x0002 },
{ ASYNC_BOOT_ONLYMCA, 0x00400000 },
{ ASYNC_INTERNAL_FLAGS, 0xFFC00000 }
for (a = 0; a < ARRAY_SIZE(as); a++)
if (as[a].old != as[a].new)
printf("%.8x != %.8x\n", as[a].old, as[a].new);
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
[ Upstream commit 14ebaf81e13ce66bff275380b246796fd16cbfa1 ]
If socket destuction gets delayed to a timer, we try to
lock_sock() from that timer which won't work.
Use bh_lock_sock() in that case.
Tested-by: Ingo Molnar <mingo@elte.hu>
commit 84261923d3dddb766736023bead6fa07b7e218d5 upstream.
make_all_cpus_request contains a race condition which can
trigger false request completed status, as follows:
CPU0 CPU1
if (test_and_set_bit(req,&vcpu->requests))
.... if (test_and_set_bit(req,&vcpu->requests))
.. return
proceed to smp_call_function_many(wait=1)
Use a spinlock to serialize concurrent CPUs.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 3b0fde0fac19c180317eb0601b3504083f4b9bf5 upstream.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13484
Peer reported:
| The bug is introduced from kernel 2.6.27, if E820 table reserve the memory
| above 4G in 32bit OS(BIOS-e820: 00000000fff80000 - 0000000120000000
| (reserved)), system will report Int 6 error and hang up. The bug is caused by
| the following code in drivers/firmware/memmap.c, the resource_size_t is 32bit
| variable in 32bit OS, the BUG_ON() will be invoked to result in the Int 6
| error. I try the latest 32bit Ubuntu and Fedora distributions, all hit this
| bug.
|static int firmware_map_add_entry(resource_size_t start, resource_size_t end,
| const char *type,
| struct firmware_map_entry *entry)
and it only happen with CONFIG_PHYS_ADDR_T_64BIT is not set.
it turns out we need to pass u64 instead of resource_size_t for that.
[akpm@linux-foundation.org: add comment]
Reported-and-tested-by: Peer Chen <pchen@nvidia.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
So can get cpumask_var with cpumask_clear
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5543/1: arm: serial amba: add missing declaration in serial.h
[ARM] pxa: fix pxa27x_udc default pullup GPIO
[ARM] pxa/imote2: fix UCAM sensor board ADC model number
mx[23]: don't put clock lookups in __initdata
fix oops when using console=ttymxcN with N > 0
[ARM] ARMv7 errata: only apply fixes when running on applicable CPU
[ARM] 5534/1: kmalloc must return a cache line aligned buffer
This header is sometimes included in the uncompress stage to get
register values, but no <linux/amba/bus.h> can be included there.
So declare "struct amba_device" here before using it in a prototype.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
The "trace || CLONE_PTRACE" check in tracehook_report_clone() is not right,
- If the untraced task does clone(CLONE_PTRACE) the new child is not traced,
we must not queue SIGSTOP.
- If we forked the traced task, but the tracer exits and untraces both the
forking task and the new child (after copy_process() drops tasklist_lock),
we should not queue SIGSTOP too.
Change the code to check task_ptrace() != 0 instead. This is still racy, but
the race is harmless.
We can race with another tracer attaching to this child, or the tracer can
exit and detach in parallel. But giwen that we didn't do wake_up_new_task()
yet, the child must have the pending SIGSTOP anyway.
Acked-by: Roland McGrath <roland@redhat.com>
drm_helper_connector_dpms.
Making the drm_crtc.c code recognize the DPMS property and invoke the
connector->dpms function doesn't remove any capability from the driver while
reducing code duplication.
That just highlighted the problem with the existing DPMS functions which
could turn off the connector, but failed to turn off any relevant crtcs. The
new drm_helper_connector_dpms function manages all of that, using the
drm_helper-specific crtc and encoder dpms functions, automatically computing
the appropriate DPMS level for each object in the system.
This fixes the current troubles in the i915 driver which left PLLs, pipes
and planes running while in DPMS_OFF mode or even while they were unused.
Signed-off-by: Keith Packard <keithp@keithp.com>
Ideally we should have a directory of drivers and a link to the 'active'
driver. For now just show the first device which is effectively the existing
semantics without a warning.
This is an update on the original buggy patch that I then forgot to
resubmit. Confusingly it was proposed by Red Hat, written by Etched Pixels
fixed and submitted by Intel ...
Resolves-Bug: http://bugzilla.kernel.org/show_bug.cgi?id=9749
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
3c509: Add missing EISA IDs
MAINTAINERS: take maintainership of the cpmac Ethernet driver
net/firmare: Ignore .cis files
ath1e: add new device id for asus hardware
mlx4_en: Fix a kernel panic when waking tx queue
rtl8187: add USB ID for Linksys WUSB54GC-EU v2 USB wifi dongle
at76c50x-usb: avoid mutex deadlock in at76_dwork_hw_scan
mac8390: fix build with NET_POLL_CONTROLLER
cxgb3: link fault fixes
cxgb3: fix dma mapping regression
netfilter: nfnetlink_log: fix wrong skbuff size calculation
netfilter: xt_hashlimit does a wrong SEQ_SKIP
bfin_mac: fix build error due to net_device_ops convert
atlx: move modinfo data from atlx.h to atl1.c
gianfar: fix babbling rx error event bug
cls_cgroup: read classid atomically in classifier
netfilter: nf_ct_dccp: add missing DCCP protocol changes in event cache
netfilter: nf_ct_tcp: fix accepting invalid RST segments
* git://git.kernel.org/pub/scm/linux/kernel/git/jaswinder/headers-check-2.6:
headers_check fix: linux/net_dropmon.h
headers_check fix: linux/auto_fs.h
fix the following 'make headers_check' warnings:
usr/include/linux/net_dropmon.h:7: found __[us]{8,16,32,64} type without #include <linux/types.h>
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
usr/include/linux/auto_fs.h:17: include of <linux/types.h> is preferred over <asm/types.h>
'redhat-bugzilla-500311', 'pci-bind-oops', 'misc-2.6.30' and 'i7300_idle' into release
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: libps2 - better handle bad scheduler decisions
Input: usb1400_ts - fix access to "device data" in resume function
Input: multitouch - augment event semantics documentation
Input: multitouch - add tracking ID to the protocol
mapping->tree_lock can be acquired from interrupt context. Then,
following dead lock can occur.
Assume "A" as a page.
CPU0:
lock_page_cgroup(A)
interrupted
-> take mapping->tree_lock.
CPU1:
-> lock_page_cgroup(A)
This patch tries to fix above deadlock by moving memcg's hook to out of
mapping->tree_lock. charge/uncharge of pagecache/swapcache is protected
by page lock, not tree_lock.
After this patch, lock_page_cgroup() is not called under mapping->tree_lock.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
linux/cred.h can't be included as first header (alphabetical order)
because it uses __init which is enough to break compilation on some archs.
Acked-by: James Morris <jmorris@namei.org>
Testing the i7300_idle driver on i5000-series hardware required
an edit to i7300_idle.h to "#define SUPPORT_I5000 1" and a re-build
of both i7300_idle and ioat_dma.
Replace that build-time scheme with a load-time module parameter:
"7300_idle.forceload=1" to make it easier to test the driver
on hardware that while not officially validated, works fine
and is much more commonly available.
By default (no modparam) the driver will continue to load
only on the i7300.
Note that ioat_dma runs a copy of i7300_idle's probe routine
to know to reserve an IOAT channel for i7300_idle.
This change makes ioat_dma do that always on the i5000,
just like it does on the i7300.
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Andrew Henroid <andrew.d.henroid@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Add support for VGA load detection (pre-945).
drm/i915: Use an I2C algo to do the flip to SDVO DDC bus.
drm/i915: Determine type before initialising connector
drm/i915: Return SDVO LVDS VBT mode if no EDID modes are detected.
drm/i915: Fetch SDVO LVDS mode lines from VBT, then reserve them
i915: support 8xx desktop cursors
drm/i915: allocate large pointer arrays with vmalloc
Robert L Mathews discovered that some clients send evil TCP RST segments,
which are accepted by netfilter conntrack but discarded by the
destination. Thus the conntrack entry is destroyed but the destination
retransmits data until timeout.
The same technique, i.e. sending properly crafted RST segments, can easily
be used to bypass connlimit/connbytes based restrictions (the sample
script written by Robert can be found in the netfilter mailing list
archives).
The patch below adds a new flag and new field to struct ip_ct_tcp_state so
that checking RST segments can be made more strict and thus TCP conntrack
can catch the invalid ones: the RST segment is accepted only if its
sequence number higher than or equal to the highest ack we seen from the
other direction. (The last_ack field cannot be reused because it is used
to catch resent packets.)
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] mpt2sas: fix driver version inconsistency
[SCSI] 3w-xxxx: scsi_dma_unmap fix
[SCSI] 3w-9xxx: scsi_dma_unmap fix
[SCSI] ses: fix problems caused by empty SES provided name
[SCSI] fc-transport: Close state transition-window during rport deletion.
[SCSI] initialize max_target_blocked in scsi_alloc_target
[SCSI] fnic: Add new Cisco PCI-Express FCoE HBA
There are a few multi-touch devices that support finger tracking
well in hardware, Stantum being the prime example. By exposing the
tracking ID in the MT protocol, evdev bandwidth and cpu usage in
user space can be reduced.
This patch adds the ABS_MT_TRACKING_ID to the MT protocol.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Tested-by: Stéphane Chatty <chatty@enac.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
via82cxxx: Add VIA VX855 PCI Device ID
ide: report timeouts in ide_busy_sleep()
ide: improve failed opcode reporting
ide: fix printk() levels in ide_dump_ata[pi]_error()
ide: fix OOPS during ide-cd error recovery
ide: fix 40-wire cable detection for TSST SH-S202* ATAPI devices (v2)
This patch adds the PCI Device ID 0xc409 to the PCI ID table of via82cxxx.c,
as well as the 0x8409 south bridge ID.
This is required to make the IDE driver work on the VX855/VX875 integrated
chipset.
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
Cc: Joseph Chan <JosephChan@via.com.tw>
Cc: Bruce Chang <BruceChang@via.com.tw>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* change 'hwif' argument to 'drive'
* report an error on timeout
* master.kernel.org:/home/rmk/linux-2.6-arm: (25 commits)
[ARM] 5519/1: amba probe: pass "struct amba_id *" instead of void *
[ARM] 5517/1: integrator: don't put clock lookups in __initdata
[ARM] 5518/1: versatile: don't put clock lookups in __initdata
[ARM] mach-l7200: fix spelling of SYS_CLOCK_OFF
[ARM] Double check memmap is actually valid with a memmap has unexpected holes V2
[ARM] realview: fix broadcast tick support
[ARM] realview: remove useless smp_cross_call_done()
[ARM] smp: fix cpumask usage in ARM SMP code
[ARM] 5513/1: Eurotech VIPER SBC: fix compilation error
[ARM] 5509/1: ep93xx: clkdev enable UARTS
ARM: OMAP2/3: Change omapfb to use clkdev for dispc and rfbi, v2
ARM: OMAP3: Fix HW SAVEANDRESTORE shift define
ARM: OMAP3: Fix number of GPIO lines for 34xx
[ARM] S3C: Do not set clk->owner field if unset
[ARM] S3C2410: mach-bast.c registering i2c data too early
[ARM] S3C24XX: Fix unused code warning in arch/arm/plat-s3c24xx/dma.c
[ARM] S3C64XX: fix GPIO debug
[ARM] S3C64XX: GPIO include cleanup
[ARM] nwfpe: fix 'floatx80_is_nan' sparse warning
[ARM] nwfpe: Add decleration for ExtendedCPDO
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
For awhile now, many of the GEM code paths have allocated page or
object arrays with the slab allocator. This is nice and fast, but
won't work well if memory is fragmented, since the slab allocator works
with physically contiguous memory (i.e. order > 2 allocations are
likely to fail fairly early after booting and doing some work).
This patch works around the issue by falling back to vmalloc for
>PAGE_SIZE allocations. This is ugly, but much less work than chaining
a bunch of pages together by hand (suprisingly there's not a bunch of
generic kernel helpers for this yet afaik). vmalloc space is somewhat
precious on 32 bit kernels, but our allocations shouldn't be big enough
to cause problems, though they're routinely more than a page.
Note that this patch doesn't address the unchecked
alloc-based-on-ioctl-args in GEM; that needs to be fixed in a separate
patch.
Also, I've deliberately ignored the DRM's "area" junk. I don't think
anyone actually uses it anymore and I'm hoping it gets ripped out soon.
[Updated: removed size arg to new free function. We could unify the
free functions as well once the DRM mem tracking is ripped out.]
fd.o bug #20152 (part 1/3)
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eric Anholt <eric@anholt.net>
`local_add_unless(x, y, z)' will be expanded to `(&(x)->y, (y), (x))', but
`&(x)->y' should be `&(x)->a'
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
holes V2
pfn_valid() is meant to be able to tell if a given PFN has valid memmap
associated with it or not. In FLATMEM, it is expected that holes always
have valid memmap as long as there is valid PFNs either side of the hole.
In SPARSEMEM, it is assumed that a valid section has a memmap for the
entire section.
However, ARM and maybe other embedded architectures in the future free
memmap backing holes to save memory on the assumption the memmap is never
used. The page_zone linkages are then broken even though pfn_valid()
returns true. A walker of the full memmap must then do this additional
check to ensure the memmap they are looking at is sane by making sure the
zone and PFN linkages are still valid. This is expensive, but walkers of
the full memmap are extremely rare.
This was caught before for FLATMEM and hacked around but it hits again for
SPARSEMEM because the page_zone linkages can look ok where the PFN linkages
are totally screwed. This looks like a hatchet job but the reality is that
any clean solution would end up consumning all the memory saved by punching
these unexpected holes in the memmap. For example, we tried marking the
memmap within the section invalid but the section size exceeds the size of
the hole in most cases so pfn_valid() starts returning false where valid
memmap exists. Shrinking the size of the section would increase memory
consumption offsetting the gains.
This patch identifies when an architecture is punching unexpected holes
in the memmap that the memory model cannot automatically detect and sets
ARCH_HAS_HOLES_MEMORYMODEL. At the moment, this is restricted to EP93xx
which is the model sub-architecture this has been reported on but may expand
later. When set, walkers of the full memmap must call memmap_valid_within()
for each PFN and passing in what it expects the page and zone to be for
that PFN. If it finds the linkages to be broken, it assumes the memmap is
invalid for that PFN.
This adds CONFIG_REISERFS_FS_XATTR protection from reiserfs_permission.
This is needed to avoid warnings during file deletions and chowns with
xattrs disabled.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
* 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Add new GET_PIPE_FROM_CRTC_ID ioctl.
drm/i915: Set HDMI hot plug interrupt enable for only the output in question.
drm/i915: Include 965GME pci ID in IS_I965GM(dev) to match UMS.
drm/i915: Use the GM45 VGA hotplug workaround on G45 as well.
drm/i915: ignore LVDS on intel graphics systems that lie about having it
drm/i915: sanity check IER at wait_request time
drm/i915: workaround IGD i2c bus issue in kernel side (v2)
drm/i915: Don't allow binding objects into the last page of the aperture.
drm/i915: save/restore fence registers across suspend/resume
drm/i915: x86 always has writeq. Add I915_READ64 for symmetry.
This patch provides new heuristics for parsing both the form factor and
media rotation rate ATA IDENFITY words.
The reported ATA version must be 7 or greater and the device must return
values defined as valid in the standard. Only then are the
characteristics reported to SCSI via the VPD B1 page.
This seems like a reasonable compromise to me considering that we have
been shipping several kernel releases that key off the rotation rate bit
without any version checking whatsoever. With no complaints so far.
> After an rport's state has transitioned to FC_PORTSTATE_BLOCKED,
> but, prior to making the upcall to 'block' the scsi-target
> associated with an rport, queued commands can recycle and
> ultimately run out of retries causing failures to propagate to
> upper-level drivers. Close this transition-window by returning
> the non-'retries' modifying DID_IMM_RETRY status for submitted
> I/Os.
The same can happen for iscsi when transitioning from logged in
to failed and blocking the sdevs.
This patch converts iscsi and fc's transitions back to use DID_IMM_RETRY
instead of DID_TRANSPORT_DISRUPTED which has a limited number of retries
that we do not want to use for handling this race.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
[Addition of iscsi and fc port online devloss case conversion by Mike Christie]
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "mm: add /proc controls for pdflush threads"
viocd: needs to depend on BLOCK
block: fix the bio_vec array index out-of-bounds test
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af.
Work is progressing to switch away from pdflush as the process backing
for flushing out dirty data. So it seems pointless to add more knobs
to control pdflush threads. The original author of the patch did not
have any specific use cases for adding the knobs, so we can easily
revert this before 2.6.30 to avoid having to maintain this API
forever.
This allows userlevel code to discover the pipe number corresponding
to a given CRTC ID. This is necessary for doing pipe-specific
operations such as waiting for vblank on a given CRTC. Failure to use
the right pipe mapping can result in GPU hangs, or at least failure
to actually sync to vblank.
Signed-off-by: Carl Worth <cworth@cworth.org>
[anholt: Style touchups from review]
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dma: fix ipu_idmac.c to not discard the last queued buffer
ioatdma: fix "ioatdma frees DMA memory with wrong function"
ipu_idmac: Use disable_irq_nosync() from within irq handlers.
dmatest: fix max channels handling
as reported by Alexander Beregalov <a.beregalov@gmail.com>
ioatdma 0000:00:08.0: DMA-API: device driver frees DMA memory with
wrong function [device address=0x000000007f76f800] [size=2000 bytes]
[map
ped as single] [unmapped as page]
The ioatdma driver was unmapping all regions
(either allocated as page or single) using unmap_page.
This patch lets dma driver recognize if unmap_single or unmap_page should be used.
It introduces two new dma control flags:
DMA_COMPL_SRC_UNMAP_SINGLE and DMA_COMPL_DEST_UNMAP_SINGLE.
They should be set to indicate dma driver to do dma-unmapping as single
(first one for the source, tha latter for the destination).
If respective flag is not set, the driver assumes dma-unmapping as page.
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Tested-by: Alexander Beregalov <a.beregalov@gmail.com>
In order to build the generic syscall table, we need a declaration for
every system call. sys_pipe2 was added without a proper declaration, so
add this to syscalls.h now.
Cc: Ulrich Drepper <drepper@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
Revert driver core: move platform_data into platform_device
Revert driver core: fix passing platform_data
Remove old PRINTK_DEBUG config item
Doc/sysfs-rules: Swap the order of the words so the sentence makes more sense
Driver core: platform: fix kernel-doc warnings
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (22 commits)
Fix the race between capifs remount and node creation
Fix races around the access to ->s_options
switch ufs directories to ufs_sync_file()
Switch open_exec() and sys_uselib() to do_open_filp()
Make open_exec() and sys_uselib() use may_open(), instead of duplicating its parts
Reduce path_lookup() abuses
Make checkpatch.pl shut up on fs/inode.c
NULL noise in fs/super.c:kill_bdev_super()
romfs: cleanup romfs_fs.h
ROMFS: romfs_dev_read() error ignored
fs: dcache fix LRU ordering
ocfs2: Use nd_set_link().
Fix deadlock in ipathfs ->get_sb()
Fix a leak in failure exit in 9p ->get_sb()
Convert obvious places to deactivate_locked_super()
New helper: deactivate_locked_super()
reiserfs: remove privroot hiding in lookup
reiserfs: dont associate security.* with xattr files
reiserfs: fixup xattr_root caching
Always lookup priv_root on reiserfs mount and keep it
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix line-in on Mac Mini Core2 Duo
ALSA: Release v1.0.20
sound: via82xx: fix DXS volume range
sound: serial-u16550: fix buffer overflow
ASoC: Fix errors in WM8990
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits)
bonding: fix panic if initialization fails
IXP4xx: complete Ethernet netdev setup before calling register_netdev().
IXP4xx: use "ENODEV" instead of "ENOSYS" in module initialization.
ipvs: Fix IPv4 FWMARK virtual services
ipv4: Make INET_LRO a bool instead of tristate.
net: remove stale reference to fastroute from Kconfig help text
net: update skb_recycle_check() for hardware timestamping changes
bnx2: Fix panic in bnx2_poll_work().
net-sched: fix bfifo default limit
igb: resolve panic on shutdown when SR-IOV is enabled
wimax: oops: wimax_dev_add() is the only one that can initialize the state
wimax: fix oops if netlink fails to add attribute
Bluetooth: Move dev_set_name() to a context that can sleep
netfilter: ctnetlink: fix wrong message type in user updates
netfilter: xt_cluster: fix use of cluster match with 32 nodes
netfilter: ip6t_ipv6header: fix match on packets ending with NEXTHDR_NONE
netfilter: add missing linux/types.h include to xt_LED.h
mac80211: pid, fix memory corruption
mac80211: minstrel, fix memory corruption
cfg80211: fix comment on regulatory hint processing
* topic/misc:
