[ Upstream commit e2861fa71641c6414831d628a1f4f793b6562580 ]
When EVM attempts to appraise a file signed with a crypto algorithm the
kernel doesn't have support for, it will cause the kernel to trigger a
module load. If the EVM policy includes appraisal of kernel modules this
will in turn call back into EVM - since EVM is holding a lock until the
crypto initialisation is complete, this triggers a deadlock. Add a
CRYPTO_NOLOAD flag and skip module loading if it's set, and add that flag
in the EVM case in order to fail gracefully with an error message
instead of deadlocking.
Signed-off-by: Matthew Garrett <mjg59@google.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
[ Upstream commit 76d5581c870454be5f1f1a106c57985902e7ea20 ]
When the mlx5 health mechanism detects a problem while the driver
is in the middle of init_one or remove_one, the driver needs to prevent
the health mechanism from scheduling future work; if future work
is scheduled, there is a problem with use-after-free: the system WQ
tries to run the work item (which has been freed) at the scheduled
future time.
Prevent this by disabling work item scheduling in the health mechanism
when the driver is in the middle of init_one() or remove_one().
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reviewed-by: Feras Daoud <ferasda@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
commit 7a9cdebdcc17e426fb5287e4a82db1dfe86339b2 upstream.
Jann Horn points out that the vmacache_flush_all() function is not only
potentially expensive, it's buggy too. It also happens to be entirely
unnecessary, because the sequence number overflow case can be avoided by
simply making the sequence number be 64-bit. That doesn't even grow the
data structures in question, because the other adjacent fields are
already 64-bit.
So simplify the whole thing by just making the sequence number overflow
case go away entirely, which gets rid of all the complications and makes
the code faster too. Win-win.
[ Oleg Nesterov points out that the VMACACHE_FULL_FLUSHES statistics
also just goes away entirely with this ]
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Will Deacon <will.deacon@arm.com>
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Cc: stable@kernel.org
[ Upstream commit d89d41556141a527030a15233135ba622ba3350d ]
Android's header sanitization tool chokes on static inline functions having a
trailing semicolon, leading to an incorrectly parsed header file. While the
tool should obviously be fixed, also fix the header files for the two affected
functions: ethtool_get_flow_spec_ring() and ethtool_get_flow_spec_ring_vf().
Fixes: 8cf6f497de40 ("ethtool: Add helper routines to pass vf to rx_flow_spec")
Reporetd-by: Blair Prescott <blair.prescott@broadcom.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 9fd0e09a4e86499639653243edfcb417a05c5c46 ]
This card identifies itself as:
Ethernet controller [0200]: NCube Device [10ff:8168] (rev 06)
Subsystem: TP-LINK Technologies Co., Ltd. Device [7470:3468]
Adding a new entry to rtl8169_pci_tbl makes the card work.
Link: http://launchpad.net/bugs/1788730
Signed-off-by: Anthony Wong <anthony.wong@ubuntu.com>
commit bb24153a3f13dd0dbc1f8055ad97fe346d598f66 upstream.
The default delay 5 jiffies is too much when the kernel is compiled with
HZ=100 - it results in jumpy cursor in Xwindow.
In order to find out the optimal delay, I benchmarked the driver on
1280x720x30fps video. I found out that with HZ=1000, 10ms is acceptable,
but with HZ=250 or HZ=300, we need 4ms, so that the video is played
without any frame skips.
This patch changes the delay to this value.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 1c48db44924298ad0cb5a6386b88017539be8822 upstream.
PFSID should be used in the invalidation descriptor for flushing
device IOTLBs on SRIOV VFs.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: "Ashok Raj" <ashok.raj@intel.com>
Cc: "Lu Baolu" <baolu.lu@linux.intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 0f725561e168485eff7277d683405c05b192f537 upstream.
When SRIOV VF device IOTLB is invalidated, we need to provide
the PF source ID such that IOMMU hardware can gauge the depth
of invalidation queue which is shared among VFs. This is needed
when device invalidation throttle (DIT) capability is supported.
This patch adds bit definitions for checking and tracking PFSID.
commit 817aef260037f33ee0f44c17fe341323d3aebd6d upstream.
Replace the use of a magic number that indicates that verify_*_signature()
should use the secondary keyring with a symbol.
Signed-off-by: Yannik Sembritzki <yannik@sembritzki.me>
Cc: keyrings@vger.kernel.org
Cc: linux-security-module@vger.kernel.org
commit 0f90be132cbf1537d87a6a8b9e80867adac892f6 upstream.
After a live data migration event at the NFS server, the client may send
I/O requests to the wrong server, causing a live hang due to repeated
recovery events. On the wire, this will appear as an I/O request failing
with NFS4ERR_BADSESSION, followed by successful CREATE_SESSION, repeatedly.
NFS4ERR_BADSSESSION is returned because the session ID being used was
issued by the other server and is not valid at the old server.
The failure is caused by async worker threads having cached the transport
(xprt) in the rpc_task structure. After the migration recovery completes,
the task is redispatched and the task resends the request to the wrong
server based on the old value still present in tk_xprt.
The solution is to recompute the tk_xprt field of the rpc_task structure
so that the request goes to the correct server.
Signed-off-by: Bill Baker <bill.baker@oracle.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Helen Chao <helen.chao@oracle.com>
Fixes: fb43d17210ba ("SUNRPC: Use the multipath iterator to assign a ...")
Cc: stable@vger.kernel.org # v4.9+
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 7506dc7989933235e6fc23f3d0516bdbf0f7d1a8 upstream.
Add PCI-specific dev_printk() wrappers and use them to simplify the code
slightly. No functional change intended.
Signed-off-by: Frederick Lawler <fred@fredlawl.com>
[bhelgaas: squash into one patch]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[only take the pci.h portion of this patch, to make backporting stuff
easier over time - gregkh]
commit 2afc9166f79b8f6da5f347f48515215ceee4ae37 upstream.
Introduce these two functions and export them such that the next patch
can add calls to these functions from the SCSI core.
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: <stable@vger.kernel.org>
commit a5fb9fb023a1435f2b42bccd7f547560f3a21dc3 upstream.
When testing the R-Car PCIe driver on the Condor board, if the PCIe PHY
driver was left disabled, the kernel crashed with this BUG:
kernel BUG at lib/ioremap.c:72!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 39 Comm: kworker/0:1 Not tainted 4.17.0-dirty #1092
Hardware name: Renesas Condor board based on r8a77980 (DT)
Workqueue: events deferred_probe_work_func
pstate: 80000005 (Nzcv daif -PAN -UAO)
pc : ioremap_page_range+0x370/0x3c8
lr : ioremap_page_range+0x40/0x3c8
sp : ffff000008da39e0
x29: ffff000008da39e0 x28: 00e8000000000f07
x27: ffff7dfffee00000 x26: 0140000000000000
x25: ffff7dfffef00000 x24: 00000000000fe100
x23: ffff80007b906000 x22: ffff000008ab8000
x21: ffff000008bb1d58 x20: ffff7dfffef00000
x19: ffff800009c30fb8 x18: 0000000000000001
x17: 00000000000152d0 x16: 00000000014012d0
x15: 0000000000000000 x14: 0720072007200720
x13: 0720072007200720 x12: 0720072007200720
x11: 0720072007300730 x10: 00000000000000ae
x9 : 0000000000000000 x8 : ffff7dffff000000
x7 : 0000000000000000 x6 : 0000000000000100
x5 : 0000000000000000 x4 : 000000007b906000
x3 : ffff80007c61a880 x2 : ffff7dfffeefffff
x1 : 0000000040000000 x0 : 00e80000fe100f07
Process kworker/0:1 (pid: 39, stack limit = 0x (ptrval))
Call trace:
pci_remap_iospace+0x7c/0xac
pci_parse_request_of_pci_ranges+0x13c/0x190
rcar_pcie_probe+0x4c/0xb04
platform_drv_probe+0x50/0xbc
driver_probe_device+0x21c/0x308
__device_attach_driver+0x98/0xc8
bus_for_each_drv+0x54/0x94
__device_attach+0xc4/0x12c
device_initial_probe+0x10/0x18
bus_probe_device+0x90/0x98
deferred_probe_work_func+0xb0/0x150
process_one_work+0x12c/0x29c
worker_thread+0x200/0x3fc
kthread+0x108/0x134
ret_from_fork+0x10/0x18
Code: f9004ba2 54000080 aa0003fb 17ffff48 (d4210000)
It turned out that pci_remap_iospace() wasn't undone when the driver's
probe failed, and since devm_phy_optional_get() returned -EPROBE_DEFER,
the probe was retried, finally causing the BUG due to trying to remap
already remapped pages.
Introduce the devm_pci_remap_iospace() managed API and replace the
pci_remap_iospace() call with it to fix the bug.
Fixes: dbf9826d5797 ("PCI: generic: Convert to DT resource parsing API")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[lorenzo.pieralisi@arm.com: split commit/updated the commit log]
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[ Upstream commit c133459765fae249ba482f62e12f987aec4376f0 ]
CC [M] drivers/net/ethernet/freescale/fman/fman.o
In file included from ../drivers/net/ethernet/freescale/fman/fman.c:35:
../include/linux/fsl/guts.h: In function 'guts_set_dmacr':
../include/linux/fsl/guts.h:165:2: error: implicit declaration of function 'clrsetbits_be32' [-Werror=implicit-function-declaration]
clrsetbits_be32(&guts->dmacr, 3 << shift, device << shift);
Cc: Madalin Bucur <madalin.bucur@nxp.com>
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
[ Upstream commit a69258f7aa2623e0930212f09c586fd06674ad79 ]
After fixing the way DCTCP tracking delayed ACKs, the delayed-ACK
related callbacks are no longer needed
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Lawrence Brakmo <brakmo@fb.com>
[ Upstream commit 38230a3e0e0933bbcf5df6fa469ba0667f667568 ]
the control action in the common member of struct tcf_tunnel_key must be a
valid value, as it can contain the chain index when 'goto chain' is used.
Ensure that the control action can be read as x->tcfa_action, when x is a
pointer to struct tc_action and x->ops->type is TCA_ACT_TUNNEL_KEY, to
prevent the following command:
# tc filter add dev $h2 ingress protocol ip pref 1 handle 101 flower \
> $tcflags dst_mac $h2mac action tunnel_key unset goto chain 1
from causing a NULL dereference when a matching packet is received:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
PGD 80000001097ac067 P4D 80000001097ac067 PUD 103b0a067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 0 PID: 3491 Comm: mausezahn Tainted: G E 4.18.0-rc2.auguri+ #421
Hardware name: Hewlett-Packard HP Z220 CMT Workstation/1790, BIOS K51 v01.58 02/07/2013
RIP: 0010:tcf_action_exec+0xb8/0x100
Code: 00 00 00 20 74 1d 83 f8 03 75 09 49 83 c4 08 4d 39 ec 75 bc 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3 49 8b 97 a8 00 00 00 <48> 8b 12 48 89 55 00 48 83 c4 10 5b 5d 41 5c 41 5d 41 5e 41 5f c3
RSP: 0018:ffff95145ea03c40 EFLAGS: 00010246
RAX: 0000000020000001 RBX: ffff9514499e5800 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000002 RDI: 0000000000000000
RBP: ffff95145ea03e60 R08: 0000000000000000 R09: ffff95145ea03c9c
R10: ffff95145ea03c78 R11: 0000000000000008 R12: ffff951456a69800
R13: ffff951456a69808 R14: 0000000000000001 R15: ffff95144965ee40
FS: 00007fd67ee11740(0000) GS:ffff95145ea00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000001038a2006 CR4: 00000000001606f0
Call Trace:
<IRQ>
fl_classify+0x1ad/0x1c0 [cls_flower]
? __update_load_avg_se.isra.47+0x1ca/0x1d0
? update_load_avg+0x665/0x690
? kmem_cache_alloc+0x38/0x1c0
tcf_classify+0x89/0x140
__netif_receive_skb_core+0x5ea/0xb70
? enqueue_entity+0xd0/0x270
? process_backlog+0x97/0x150
net_rx_action+0x14b/0x3e0
__do_softirq+0xde/0x2b4
do_softirq_own_stack+0x2a/0x40
</IRQ>
do_softirq.part.18+0x49/0x50
__local_bh_enable_ip+0x49/0x50
__dev_queue_xmit+0x4ab/0x8a0
? wait_woken+0x80/0x80
? packet_sendmsg+0x38f/0x810
? __dev_queue_xmit+0x8a0/0x8a0
sock_sendmsg+0x36/0x40
__sys_sendto+0x10e/0x140
? do_vfs_ioctl+0xa4/0x630
? syscall_trace_enter+0x1df/0x2e0
? __audit_syscall_exit+0x22a/0x290
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x5b/0x180
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7fd67e18dc93
Code: 48 8b 0d 18 83 20 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 59 c7 20 00 00 75 13 49 89 ca b8 2c 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 34 c3 48 83 ec 08 e8 2b f7 ff ff 48 89 04 24
RSP: 002b:00007ffe0189b748 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000020ca010 RCX: 00007fd67e18dc93
RDX: 0000000000000062 RSI: 00000000020ca322 RDI: 0000000000000003
RBP: 00007ffe0189b780 R08: 00007ffe0189b760 R09: 0000000000000014
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000062
R13: 00000000020ca322 R14: 00007ffe0189b760 R15: 0000000000000003
Modules linked in: act_tunnel_key act_gact cls_flower sch_ingress vrf veth act_csum(E) xt_CHECKSUM iptable_mangle ipt_MASQUERADE iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 tun bridge stp llc ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter intel_rapl snd_hda_codec_hdmi x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_realtek coretemp snd_hda_codec_generic kvm_intel kvm irqbypass snd_hda_intel crct10dif_pclmul crc32_pclmul hp_wmi ghash_clmulni_intel pcbc snd_hda_codec aesni_intel sparse_keymap rfkill snd_hda_core snd_hwdep snd_seq crypto_simd iTCO_wdt gpio_ich iTCO_vendor_support wmi_bmof cryptd mei_wdt glue_helper snd_seq_device snd_pcm pcspkr snd_timer snd i2c_i801 lpc_ich sg soundcore wmi mei_me
mei ie31200_edac nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod sr_mod cdrom i915 video i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci crc32c_intel libahci serio_raw sfc libata mtd drm ixgbe mdio i2c_core e1000e dca
---[ end trace 1ab8b5b5d4639dfc ]---
Kernel panic - not syncing: Fatal exception in interrupt
Kernel Offset: 0x11400000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Fixes: d0f6dd8a914f ("net/sched: Introduce act_tunnel_key")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
[ Upstream commit a9ba23d48dbc6ffd08426bb10f05720e0b9f5c14 ]
At present the ipv6_renew_options_kern() function ends up calling into
access_ok() which is problematic if done from inside an interrupt as
access_ok() calls WARN_ON_IN_IRQ() on some (all?) architectures
(x86-64 is affected). Example warning/backtrace is shown below:
WARNING: CPU: 1 PID: 3144 at lib/usercopy.c:11 _copy_from_user+0x85/0x90
Call Trace:
<IRQ>
ipv6_renew_option+0xb2/0xf0
ipv6_renew_options+0x26a/0x340
ipv6_renew_options_kern+0x2c/0x40
calipso_req_setattr+0x72/0xe0
netlbl_req_setattr+0x126/0x1b0
selinux_netlbl_inet_conn_request+0x80/0x100
selinux_inet_conn_request+0x6d/0xb0
security_inet_conn_request+0x32/0x50
tcp_conn_request+0x35f/0xe00
? __lock_acquire+0x250/0x16c0
? selinux_socket_sock_rcv_skb+0x1ae/0x210
? tcp_rcv_state_process+0x289/0x106b
? tcp_v6_do_rcv+0x1a7/0x3c0
tcp_v6_rcv+0xc82/0xcf0
ip6_input_finish+0x10d/0x690
ip6_input+0x45/0x1e0
? ip6_rcv_finish+0x1d0/0x1d0
ipv6_rcv+0x32b/0x880
? ip6_make_skb+0x1e0/0x1e0
__netif_receive_skb_core+0x6f2/0xdf0
? process_backlog+0x85/0x250
? process_backlog+0xec/0x250
net_rx_action+0x153/0x480
__do_softirq+0xd9/0x4f7
</IRQ>
While not present in the backtrace, ipv6_renew_option() ends up calling
access_ok() via the following chain:
access_ok()
_copy_from_user()
copy_from_user()
ipv6_renew_option()
The fix presented in this patch is to perform the userspace copy
earlier in the call chain such that it is only called when the option
data is actually coming from userspace; that place is
do_ipv6_setsockopt(). Not only does this solve the problem seen in
the backtrace above, it also allows us to simplify the code quite a
bit by removing ipv6_renew_options_kern() completely. We also take
this opportunity to cleanup ipv6_renew_options()/ipv6_renew_option()
a small amount as well.
This patch is heavily based on a rough patch by Al Viro. I've taken
his original patch, converted a kmemdup() call in do_ipv6_setsockopt()
to a memdup_user() call, made better use of the e_inval jump target in
the same function, and cleaned up the use ipv6_renew_option() by
ipv6_renew_options().
CC: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 9ce7bc036ae4cfe3393232c86e9e1fea2153c237 ]
It is a waste of memory to use a full "struct netns_sysctl_ipv6"
while only one pointer is really used, considering netns_sysctl_ipv6
keeps growing.
Also, since "struct netns_frags" has cache line alignment,
it is better to move the frags_hdr pointer outside, otherwise
we spend a full cache line for this pointer.
This saves 192 bytes of memory per netns.
Fixes: c038a767cd69 ("ipv6: add a new namespace for nf_conntrack_reasm")
[ Upstream commit 455f05ecd2b219e9a216050796d30c830d9bc393 ]
syzbot reported that we reinitialize an active delayed
work in vsock_stream_connect():
ODEBUG: init active (active state 0) object type: timer_list hint:
delayed_work_timer_fn+0x0/0x90 kernel/workqueue.c:1414
WARNING: CPU: 1 PID: 11518 at lib/debugobjects.c:329
debug_print_object+0x16a/0x210 lib/debugobjects.c:326
The pattern is apparently wrong, we should only initialize
the dealyed work once and could repeatly schedule it. So we
have to move out the initializations to allocation side.
And to avoid confusion, we can split the shared dwork
into two, instead of re-using the same one.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reported-by: <syzbot+8a9b1bd330476a4f3db6@syzkaller.appspotmail.com>
Cc: Andy king <acking@vmware.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit 0dcb82254d65f72333aa50ad626d1e9665ad093b ]
llc_sap_put() decreases the refcnt before deleting sap
from the global list. Therefore, there is a chance
llc_sap_find() could find a sap with zero refcnt
in this global list.
Close this race condition by checking if refcnt is zero
or not in llc_sap_find(), if it is zero then it is being
removed so we can just treat it as gone.
Reported-by: <syzbot+278893f3f7803871f7ce@syzkaller.appspotmail.com>
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Michal Hocko <mhocko@suse.com>
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
commit bb29648102335586e9a66289a1d98a0cb392b6e5 upstream.
syzbot reported a crash in vmac_final() when multiple threads
concurrently use the same "vmac(aes)" transform through AF_ALG. The bug
is pretty fundamental: the VMAC template doesn't separate per-request
state from per-tfm (per-key) state like the other hash algorithms do,
but rather stores it all in the tfm context. That's wrong.
Also, vmac_final() incorrectly zeroes most of the state including the
derived keys and cached pseudorandom pad. Therefore, only the first
VMAC invocation with a given key calculates the correct digest.
Fix these bugs by splitting the per-tfm state from the per-request state
and using the proper init/update/final sequencing for requests.
Reproducer for the crash:
#include <linux/if_alg.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int fd;
struct sockaddr_alg addr = {
.salg_type = "hash",
.salg_name = "vmac(aes)",
char buf[256] = { 0 };
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buf, 16);
fork();
fd = accept(fd, NULL, NULL);
for (;;)
write(fd, buf, 256);
The immediate cause of the crash is that vmac_ctx_t.partial_size exceeds
VMAC_NHBYTES, causing vmac_final() to memset() a negative length.
Reported-by: syzbot+264bca3a6e8d645550d3@syzkaller.appspotmail.com
Fixes: f1939f7c5645 ("crypto: vmac - New hash algorithm for intel_txt support")
Cc: <stable@vger.kernel.org> # v2.6.32+
commit 6c26fcd2abfe0a56bbd95271fce02df2896cfd24 upstream.
pfn_modify_allowed() and arch_has_pfn_modify_check() are outside of the
!__ASSEMBLY__ section in include/asm-generic/pgtable.h, which confuses
assembler on archs that don't have __HAVE_ARCH_PFN_MODIFY_ALLOWED (e.g.
ia64) and breaks build:
include/asm-generic/pgtable.h: Assembler messages:
include/asm-generic/pgtable.h:538: Error: Unknown opcode `static inline bool pfn_modify_allowed(unsigned long pfn,pgprot_t prot)'
include/asm-generic/pgtable.h:540: Error: Unknown opcode `return true'
include/asm-generic/pgtable.h:543: Error: Unknown opcode `static inline bool arch_has_pfn_modify_check(void)'
include/asm-generic/pgtable.h:545: Error: Unknown opcode `return false'
arch/ia64/kernel/entry.S:69: Error: `mov' does not fit into bundle
Move those two static inlines into the !__ASSEMBLY__ section so that they
don't confuse the asm build pass.
Fixes: 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
[groeck: Context changes]
commit bc2d8d262cba5736332cbc866acb11b1c5748aa9 upstream
Josh reported that the late SMT evaluation in cpu_smt_state_init() sets
cpu_smt_control to CPU_SMT_NOT_SUPPORTED in case that 'nosmt' was supplied
on the kernel command line as it cannot differentiate between SMT disabled
by BIOS and SMT soft disable via 'nosmt'. That wreckages the state and
makes the sysfs interface unusable.
Rework this so that during bringup of the non boot CPUs the availability of
SMT is determined in cpu_smt_allowed(). If a newly booted CPU is not a
'primary' thread then set the local cpu_smt_available marker and evaluate
this explicitely right after the initial SMP bringup has finished.
SMT evaulation on x86 is a trainwreck as the firmware has all the
information _before_ booting the kernel, but there is no interface to query
it.
Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS")
Reported-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit 801e459a6f3a63af9d447e6249088c76ae16efc4 upstream
Provide a new KVM capability that allows bits within MSRs to be recognized
as features. Two new ioctls are added to the /dev/kvm ioctl routine to
retrieve the list of these MSRs and then retrieve their values. A kvm_x86_ops
callback is used to determine support for the listed MSR-based features.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
[Tweaked documentation. - Radim]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit fee0aede6f4739c87179eca76136f83210953b86 upstream
The CPU_SMT_NOT_SUPPORTED state is set (if the processor does not support
SMT) when the sysfs SMT control file is initialized.
That was fine so far as this was only required to make the output of the
control file correct and to prevent writes in that case.
With the upcoming l1tf command line parameter, this needs to be set up
before the L1TF mitigation selection and command line parsing happens.
Tested-by: Jiri Kosina <jkosina@suse.cz>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/20180713142323.121795971@linutronix.de
commit 8e1b706b6e819bed215c0db16345568864660393 upstream
The L1TF mitigation will gain a commend line parameter which allows to set
a combination of hypervisor mitigation and SMT control.
Expose cpu_smt_disable() so the command line parser can tweak SMT settings.
[ tglx: Split out of larger patch and made it preserve an already existing
force off state ]
Link: https://lkml.kernel.org/r/20180713142323.039715135@linutronix.de
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream
Provide a command line and a sysfs knob to control SMT.
The command line options are:
'nosmt': Enumerate secondary threads, but do not online them
'nosmt=force': Ignore secondary threads completely during enumeration
via MP table and ACPI/MADT.
The sysfs control file has the following states (read/write):
'on': SMT is enabled. Secondary threads can be freely onlined
'off': SMT is disabled. Secondary threads, even if enumerated
cannot be onlined
'forceoff': SMT is permanentely disabled. Writes to the control
file are rejected.
'notsupported': SMT is not supported by the CPU
The command line option 'nosmt' sets the sysfs control to 'off'. This
can be changed to 'on' to reenable SMT during runtime.
The command line option 'nosmt=force' sets the sysfs control to
'forceoff'. This cannot be changed during runtime.
When SMT is 'on' and the control file is changed to 'off' then all online
secondary threads are offlined and attempts to online a secondary thread
later on are rejected.
When SMT is 'off' and the control file is changed to 'on' then secondary
threads can be onlined again. The 'off' -> 'on' transition does not
automatically online the secondary threads.
When the control file is set to 'forceoff', the behaviour is the same as
setting it to 'off', but the operation is irreversible and later writes to
the control file are rejected.
When the control status is 'notsupported' then writes to the control file
are rejected.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit 377eeaa8e11fe815b1d07c81c4a0e2843a8c15eb upstream
For the L1TF workaround its necessary to limit the swap file size to below
MAX_PA/2, so that the higher bits of the swap offset inverted never point
to valid memory.
Add a mechanism for the architecture to override the swap file size check
in swapfile.c and add a x86 specific max swapfile check function that
enforces that limit.
The check is only enabled if the CPU is vulnerable to L1TF.
In VMs with 42bit MAX_PA the typical limit is 2TB now, on a native system
with 46bit PA it is 32TB. The limit is only per individual swap file, so
it's always possible to exceed these limits with multiple swap files or
partitions.
Acked-by: Dave Hansen <dave.hansen@intel.com>
commit 42e4089c7890725fcd329999252dc489b72f2921 upstream
For L1TF PROT_NONE mappings are protected by inverting the PFN in the page
table entry. This sets the high bits in the CPU's address space, thus
making sure to point to not point an unmapped entry to valid cached memory.
Some server system BIOSes put the MMIO mappings high up in the physical
address space. If such an high mapping was mapped to unprivileged users
they could attack low memory by setting such a mapping to PROT_NONE. This
could happen through a special device driver which is not access
protected. Normal /dev/mem is of course access protected.
To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings.
Valid page mappings are allowed because the system is then unsafe anyways.
It's not expected that users commonly use PROT_NONE on MMIO. But to
minimize any impact this is only enforced if the mapping actually refers to
a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip
the check for root.
For mmaps this is straight forward and can be handled in vm_insert_pfn and
in remap_pfn_range().
For mprotect it's a bit trickier. At the point where the actual PTEs are
accessed a lot of state has been changed and it would be difficult to undo
on an error. Since this is a uncommon case use a separate early page talk
walk pass for MMIO PROT_NONE mappings that checks for this condition
early. For non MMIO and non PROT_NONE there are no changes.
[dwmw2: Backport to 4.9]
commit 17dbca119312b4e8173d4e25ff64262119fcef38 upstream
L1TF core kernel workarounds are cheap and normally always enabled, However
they still should be reported in sysfs if the system is vulnerable or
mitigated. Add the necessary CPU feature/bug bits.
- Extend the existing checks for Meltdowns to determine if the system is
vulnerable. All CPUs which are not vulnerable to Meltdown are also not
vulnerable to L1TF
- Check for 32bit non PAE and emit a warning as there is no practical way
for mitigation due to the limited physical address bits
- If the system has more than MAX_PA/2 physical memory the invert page
workarounds don't protect the system against the L1TF attack anymore,
because an inverted physical address will also point to valid
memory. Print a warning in this case and report that the system is
vulnerable.
Add a function which returns the PFN limit for the L1TF mitigation, which
will be used in follow up patches for sanity and range checks.
[ tglx: Renamed the CPU feature bit to L1TF_PTEINV ]
[ dwmw2: Backport to 4.9 (cpufeatures.h, E820) ]
commit 08bb558ac11ab944e0539e78619d7b4c356278bd upstream.
Make the MR writability flags check, which is performed in umem.c,
a static inline function in file ib_verbs.h
This allows the function to be used by low-level infiniband drivers.
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 2fd1d2c4ceb2248a727696962cf3370dc9f5a0a4 upstream.
Andrei Vagin writes:
FYI: This bug has been reproduced on 4.11.7
> BUG: Dentry ffff895a3dd01240{i=4e7c09a,n=lo} still in use (1) [unmount of proc proc]
> ------------[ cut here ]------------
> WARNING: CPU: 1 PID: 13588 at fs/dcache.c:1445 umount_check+0x6e/0x80
> CPU: 1 PID: 13588 Comm: kworker/1:1 Not tainted 4.11.7-200.fc25.x86_64 #1
> Hardware name: CompuLab sbc-flt1/fitlet, BIOS SBCFLT_0.08.04 06/27/2015
> Workqueue: events proc_cleanup_work
> Call Trace:
> dump_stack+0x63/0x86
> __warn+0xcb/0xf0
> warn_slowpath_null+0x1d/0x20
> d_walk+0xc6/0x270
> ? dentry_free+0x80/0x80
> do_one_tree+0x26/0x40
> shrink_dcache_for_umount+0x2d/0x90
> generic_shutdown_super+0x1f/0xf0
> kill_anon_super+0x12/0x20
> proc_kill_sb+0x40/0x50
> deactivate_locked_super+0x43/0x70
> deactivate_super+0x5a/0x60
> cleanup_mnt+0x3f/0x90
> mntput_no_expire+0x13b/0x190
> kern_unmount+0x3e/0x50
> pid_ns_release_proc+0x15/0x20
> proc_cleanup_work+0x15/0x20
> process_one_work+0x197/0x450
> worker_thread+0x4e/0x4a0
> kthread+0x109/0x140
> ? process_one_work+0x450/0x450
> ? kthread_park+0x90/0x90
> ret_from_fork+0x2c/0x40
> ---[ end trace e1c109611e5d0b41 ]---
> VFS: Busy inodes after unmount of proc. Self-destruct in 5 seconds. Have a nice day...
> BUG: unable to handle kernel NULL pointer dereference at (null)
> IP: _raw_spin_lock+0xc/0x30
> PGD 0
Fix this by taking a reference to the super block in proc_sys_prune_dcache.
The superblock reference is the core of the fix however the sysctl_inodes
list is converted to a hlist so that hlist_del_init_rcu may be used. This
allows proc_sys_prune_dache to remove inodes the sysctl_inodes list, while
not causing problems for proc_sys_evict_inode when if it later choses to
remove the inode from the sysctl_inodes list. Removing inodes from the
sysctl_inodes list allows proc_sys_prune_dcache to have a progress
guarantee, while still being able to drop all locks. The fact that
head->unregistering is set in start_unregistering ensures that no more
inodes will be added to the the sysctl_inodes list.
Previously the code did a dance where it delayed calling iput until the
next entry in the list was being considered to ensure the inode remained on
the sysctl_inodes list until the next entry was walked to. The structure
of the loop in this patch does not need that so is much easier to
understand and maintain.
Reported-by: Andrei Vagin <avagin@gmail.com>
Tested-by: Andrei Vagin <avagin@openvz.org>
Fixes: ace0c791e6c3 ("proc/sysctl: Don't grab i_lock under sysctl_lock.")
Fixes: d6cffbbe9a7e ("proc/sysctl: prune stale dentries during unregistering")
commit d6cffbbe9a7e51eb705182965a189457c17ba8a3 upstream.
Currently unregistering sysctl table does not prune its dentries.
Stale dentries could slowdown sysctl operations significantly.
For example, command:
# for i in {1..100000} ; do unshare -n -- sysctl -a &> /dev/null ; done
creates a millions of stale denties around sysctls of loopback interface:
# sysctl fs.dentry-state
fs.dentry-state = 25812579 24724135 45 0 0 0
All of them have matching names thus lookup have to scan though whole
hash chain and call d_compare (proc_sys_compare) which checks them
under system-wide spinlock (sysctl_lock).
# time sysctl -a > /dev/null
real 1m12.806s
user 0m0.016s
sys 1m12.400s
Currently only memory reclaimer could remove this garbage.
But without significant memory pressure this never happens.
This patch collects sysctl inodes into list on sysctl table header and
prunes all their dentries once that table unregisters.
Konstantin Khlebnikov <khlebnikov@yandex-team.ru> writes:
> On 10.02.2017 10:47, Al Viro wrote:
>> how about >> the matching stats *after* that patch?
> dcache size doesn't grow endlessly, so stats are fine
> fs.dentry-state = 92712 58376 45 0 0 0
> # time sysctl -a &>/dev/null
> real 0m0.013s
> user 0m0.004s
> sys 0m0.008s
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream.
This is purely a preparatory patch for upcoming changes during the 4.19
merge window.
We have a function called "boot_cpu_state_init()" that isn't really
about the bootup cpu state: that is done much earlier by the similarly
named "boot_cpu_init()" (note lack of "state" in name).
This function initializes some hotplug CPU state, and needs to run after
the percpu data has been properly initialized. It even has a comment to
that effect.
Except it _doesn't_ actually run after the percpu data has been properly
initialized. On x86 it happens to do that, but on at least arm and
arm64, the percpu base pointers are initialized by the arch-specific
'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init().
This had some unexpected results, and in particular we have a patch
pending for the merge window that did the obvious cleanup of using
'this_cpu_write()' in the cpu hotplug init code:
- per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE;
+ this_cpu_write(cpuhp_state.state, CPUHP_ONLINE);
which is obviously the right thing to do. Except because of the
ordering issue, it actually failed miserably and unexpectedly on arm64.
So this just fixes the ordering, and changes the name of the function to
be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu
hotplug state, because the core CPU state was supposed to have already
been done earlier.
Marked for stable, since the (not yet merged) patch that will show this
problem is marked for stable.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
commit 12c8f25a016dff69ee284aa3338bebfd2cfcba33 upstream.
KASAN uses the __no_sanitize_address macro to disable instrumentation of
particular functions. Right now it's defined only for GCC build, which
causes false positives when clang is used.
This patch adds a definition for clang.
Note, that clang's revision 329612 or higher is required.
[andreyknvl@google.com: remove redundant #ifdef CONFIG_KASAN check]
Link: http://lkml.kernel.org/r/c79aa31a2a2790f6131ed607c58b0dd45dd62a6c.1523967959.git.andreyknvl@google.com
Link: http://lkml.kernel.org/r/4ad725cc903f8534f8c8a60f0daade5e3d674f8d.1523554166.git.andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Paul Lawrence <paullawrence@google.com>
Cc: Sandipan Das <sandipan@linux.vnet.ibm.com>
Cc: Sodagudi Prasad <psodagud@codeaurora.org>
commit e01e80634ecdde1dd113ac43b3adad21b47f3957 upstream.
One of the classes of kernel stack content leaks[1] is exposing the
contents of prior heap or stack contents when a new process stack is
allocated. Normally, those stacks are not zeroed, and the old contents
remain in place. In the face of stack content exposure flaws, those
contents can leak to userspace.
Fixing this will make the kernel no longer vulnerable to these flaws, as
the stack will be wiped each time a stack is assigned to a new process.
There's not a meaningful change in runtime performance; it almost looks
like it provides a benefit.
Performing back-to-back kernel builds before:
Run times: 157.86 157.09 158.90 160.94 160.80
Mean: 159.12
Std Dev: 1.54
and after:
Run times: 159.31 157.34 156.71 158.15 160.81
Mean: 158.46
Std Dev: 1.46
Instead of making this a build or runtime config, Andy Lutomirski
recommended this just be enabled by default.
[1] A noisy search for many kinds of stack content leaks can be seen here:
https://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=linux+kernel+stack+leak
I did some more with perf and cycle counts on running 100,000 execs of
/bin/true.
before:
Cycles: 218858861551 218853036130 214727610969 227656844122 224980542841
Mean: 221015379122.60
Std Dev: 4662486552.47
after:
Cycles: 213868945060 213119275204 211820169456 224426673259 225489986348
Mean: 217745009865.40
Std Dev: 5935559279.99
It continues to look like it's faster, though the deviation is rather
wide, but I'm not sure what I could do that would be less noisy. I'm
open to ideas!
Link: http://lkml.kernel.org/r/20180221021659.GA37073@beast
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Cc: Mel Gorman <mgorman@techsingularity.net>
[ Srivatsa: Backported to 4.9.y ]
Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu>
Reviewed-by: Srinidhi Rao <srinidhir@vmware.com>
commit ca182551857cc2c1e6a2b7f1e72090a137a15008 upstream.
Kmemleak considers any pointers on task stacks as references. This
patch clears newly allocated and reused vmap stacks.
Link: http://lkml.kernel.org/r/150728990124.744199.8403409836394318684.stgit@buzz
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 73c8d8945505acdcbae137c2e00a1232e0be709f upstream.
Maintain the tracing on/off setting of the ring_buffer when switching
to the trace buffer snapshot.
Taking a snapshot is done by swapping the backup ring buffer
(max_tr_buffer). But since the tracing on/off setting is defined
by the ring buffer, when swapping it, the tracing on/off setting
can also be changed. This causes a strange result like below:
/sys/kernel/debug/tracing # cat tracing_on
1
/sys/kernel/debug/tracing # echo 0 > tracing_on
0
/sys/kernel/debug/tracing # echo 1 > snapshot
1
0
We don't touch tracing_on, but snapshot changes tracing_on
setting each time. This is an anomaly, because user doesn't know
that each "ring_buffer" stores its own tracing-enable state and
the snapshot is done by swapping ring buffers.
Link: http://lkml.kernel.org/r/153149929558.11274.11730609978254724394.stgit@devbox
Cc: Shuah Khan <shuah@kernel.org>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Hiraku Toyooka <hiraku.toyooka@cybertrust.co.jp>
Fixes: debdd57f5145 ("tracing: Make a snapshot feature available from userspace")
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
[ Updated commit log and comment in the code ]
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 9a9c9b51e54618861420093ae6e9b50a961914c5 ]
We want to add finer control of the number of ACK packets sent after
ECN events.
This patch is not changing current behavior, it only enables following
change.
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit 4f212e40468650e220c1770876c7f25b8e0c1ff5 ]
To comply with eDP1.4a this bit should be set when enabling PSR2.
Signed-off-by: José Roberto de Souza <jose.souza@intel.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180328223046.16125-1-jose.souza@intel.com
[ Upstream commit c1c734cb1f54b062f7e67ffc9656d82f5b412b9c ]
As part of bringup I ended up wanting to call an earlycon driver by a
name that was exactly 16-bytes big, specifically "qcom_geni_serial".
Unfortunately, when I tried this I found that things compiled just
fine. They just didn't work.
Specifically the compiler felt perfectly justified in initting the
".name" field of "struct earlycon_id" with the full 16-bytes and just
skipping the '\0'. Needless to say, that behavior didn't seem ideal,
but I guess someone must have allowed it for a reason.
One way to fix this is to shorten the name field to 15 bytes and then
add an extra byte after that nobody touches. This should always be
initted to 0 and we're golden.
There are, of course, other ways to fix this too. We could audit all
the users of the "name" field and make them stop at both null
termination or at 16 bytes. We could also just make the name field
much bigger so that we're not likely to run into this. ...but both
seem like we'll just hit the bug again.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
[ Upstream commit 1c74d5c0de0c2cc29fef97a19251da2ad6f579bd ]
Currently we are enabling handling of interrupts specific to Tegra124+
which happen to overlap with previous generations. Let's specify
interrupts mask per SoC generation for consistency and in a preparation
of squashing of Tegra20 driver into the common one that will enable
handling of GART faults which may be undesirable by newer generations.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 9c4a121e82634aa000a702c98cd6f05b27d6e186 ]
Add support for the BCM43364 chipset via an SDIO interface, as used in
e.g. the Murata 1FX module.
The BCM43364 uses the same firmware as the BCM43430 (which is already
included), the only difference is the omission of Bluetooth.
However, the SDIO_ID for the BCM43364 is 02D0:A9A4, giving it a MODALIAS
of sdio:c00v02D0dA9A4, which doesn't get recognised and hence doesn't
load the brcmfmac module. Adding the 'A9A4' ID in the appropriate place
triggers the brcmfmac driver to load, and then correctly use the
firmware file 'brcmfmac43430-sdio.bin'.
Signed-off-by: Sean Lanigan <sean@lano.id.au>
Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 8a22a3e1e768c309b718f99bd86f9f25a453e0dc ]
Inclusion of include/dma-iommu.h when CONFIG_IOMMU_DMA is not selected
results in the following splat:
In file included from drivers/irqchip/irq-gic-v3-mbi.c:20:0:
./include/linux/dma-iommu.h:95:69: error: unknown type name ‘dma_addr_t’
static inline int iommu_get_msi_cookie(struct iommu_domain *domain, dma_addr_t base)
./include/linux/dma-iommu.h:108:74: warning: ‘struct list_head’ declared inside parameter list will not be visible outside of this definition or declaration
static inline void iommu_dma_get_resv_regions(struct device *dev, struct list_head *list)
scripts/Makefile.build:312: recipe for target 'drivers/irqchip/irq-gic-v3-mbi.o' failed
Fix it by including linux/types.h.
Cc: Rob Herring <robh@kernel.org>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Cc: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lkml.kernel.org/r/20180508121438.11301-5-marc.zyngier@arm.com
[ Upstream commit bd975e691486ba52790ba23cc9b4fecab7bc0d31 ]
When listing sets with timeout support, there's a probability that
just timing out entries with "0" timeout value is listed/saved.
However when restoring the saved list, the zero timeout value means
permanent elelements.
The new behaviour is that timing out entries are listed with "timeout 1"
instead of zero.
Fixes netfilter bugzilla #1258.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 3756f6401c302617c5e091081ca4d26ab604bec5 upstream.
gcc-8 warns about using strncpy() with the source size as the limit:
fs/exec.c:1223:32: error: argument to 'sizeof' in 'strncpy' call is the same expression as the source; did you mean to use the size of the destination? [-Werror=sizeof-pointer-memaccess]
This is indeed slightly suspicious, as it protects us from source
arguments without NUL-termination, but does not guarantee that the
destination is terminated.
This keeps the strncpy() to ensure we have properly padded target
buffer, but ensures that we use the correct length, by passing the
actual length of the destination buffer as well as adding a build-time
check to ensure it is exactly TASK_COMM_LEN.
There are only 23 callsites which I all reviewed to ensure this is
currently the case. We could get away with doing only the check or
passing the right length, but it doesn't hurt to do both.
Link: http://lkml.kernel.org/r/20171205151724.1764896-1-arnd@arndb.de
Suggested-by: Kees Cook <keescook@chromium.org>
Cc: Serge Hallyn <serge@hallyn.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Aleksa Sarai <asarai@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Frederic Weisbecker <frederic@kernel.org>
[ Upstream commit 72cd43ba64fc172a443410ce01645895850844c8 ]
Juha-Matti Tilli reported that malicious peers could inject tiny
packets in out_of_order_queue, forcing very expensive calls
to tcp_collapse_ofo_queue() and tcp_prune_ofo_queue() for
every incoming packet. out_of_order_queue rb-tree can contain
thousands of nodes, iterating over all of them is not nice.
Before linux-4.9, we would have pruned all packets in ofo_queue
in one go, every XXXX packets. XXXX depends on sk_rcvbuf and skbs
truesize, but is about 7000 packets with tcp_rmem[2] default of 6 MB.
Since we plan to increase tcp_rmem[2] in the future to cope with
modern BDP, can not revert to the old behavior, without great pain.
Strategy taken in this patch is to purge ~12.5 % of the queue capacity.
Fixes: 36a6503fedda ("tcp: refine tcp_prune_ofo_queue() to not drop all packets")
Reported-by: Juha-Matti Tilli <juha-matti.tilli@iki.fi>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit a0496ef2c23b3b180902dd185d0d63ccbc624cf8 ]
Per DCTCP RFC8257 (Section 3.2) the ACK reflecting the CE status change
has to be sent immediately so the sender can respond quickly:
""" When receiving packets, the CE codepoint MUST be processed as follows:
1. If the CE codepoint is set and DCTCP.CE is false, set DCTCP.CE to
true and send an immediate ACK.
2. If the CE codepoint is not set and DCTCP.CE is true, set DCTCP.CE
to false and send an immediate ACK.
Previously DCTCP implementation may continue to delay the ACK. This
patch fixes that to implement the RFC by forcing an immediate ACK.
Tested with this packetdrill script provided by Larry Brakmo
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
0.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
0.000 setsockopt(3, SOL_TCP, TCP_CONGESTION, "dctcp", 5) = 0
0.000 bind(3, ..., ...) = 0
0.000 listen(3, 1) = 0
0.100 < [ect0] SEW 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
0.100 > SE. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 8>
0.110 < [ect0] . 1:1(0) ack 1 win 257
0.200 accept(3, ..., ...) = 4
+0 setsockopt(4, SOL_SOCKET, SO_DEBUG, [1], 4) = 0
0.200 < [ect0] . 1:1001(1000) ack 1 win 257
0.200 > [ect01] . 1:1(0) ack 1001
0.200 write(4, ..., 1) = 1
0.200 > [ect01] P. 1:2(1) ack 1001
0.200 < [ect0] . 1001:2001(1000) ack 2 win 257
+0.005 < [ce] . 2001:3001(1000) ack 2 win 257
+0.000 > [ect01] . 2:2(0) ack 2001
// Previously the ACK below would be delayed by 40ms
+0.000 > [ect01] E. 2:2(0) ack 3001
+0.500 < F. 9501:9501(0) ack 4 win 257
[ Upstream commit 27cde44a259c380a3c09066fc4b42de7dde9b1ad ]
Currently when a DCTCP receiver delays an ACK and receive a
data packet with a different CE mark from the previous one's, it
sends two immediate ACKs acking previous and latest sequences
respectly (for ECN accounting).
Previously sending the first ACK may mark off the delayed ACK timer
(tcp_event_ack_sent). This may subsequently prevent sending the
second ACK to acknowledge the latest sequence (tcp_ack_snd_check).
The culprit is that tcp_send_ack() assumes it always acknowleges
the latest sequence, which is not true for the first special ACK.
The fix is to not make the assumption in tcp_send_ack and check the
actual ack sequence before cancelling the delayed ACK. Further it's
safer to pass the ack sequence number as a local variable into
tcp_send_ack routine, instead of intercepting tp->rcv_nxt to avoid
future bugs like this.
Reported-by: Neal Cardwell <ncardwell@google.com>
