commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
[bwh: Backported to 3.2:
- Adjust filenames, context
- Drop arc, metag, nios2 and lustre changes
- For sh, patch both 32-bit and 64-bit implementations to use goto bad_area
- For s390, pass int_code and trans_exc_code as arguments to do_no_context()
and do_sigsegv()]
commit cd83ce9e6195aa3ea15ab4db92892802c20df5d0 upstream.
This patch adds a usb quirk to support devices with interupt endpoints
and bInterval values expressed as microframes. The quirk causes the
parse endpoint function to modify the reported bInterval to a standards
conforming value.
There is currently code in the endpoint parser that checks for
bIntervals that are outside of the valid range (1-16 for USB 2+ high
speed and super speed interupt endpoints). In this case, the code assumes
the bInterval is being reported in 1ms frames. As well, the correction
is only applied if the original bInterval value is out of the 1-16 range.
With this quirk applied to the device, the bInterval will be
accurately adjusted from microframes to an exponent.
Signed-off-by: James P Michels III <james.p.michels@gmail.com>
commit 72dd299d5039a336493993dcc63413cf31d0e662 upstream.
Ronny reports: https://bugzilla.kernel.org/show_bug.cgi?id=87101
"Since commit 8a4aeec8d "libata/ahci: accommodate tag ordered
controllers" the access to the harddisk on the first SATA-port is
failing on its first access. The access to the harddisk on the
second port is working normal.
When reverting the above commit, access to both harddisks is working
fine again."
Maintain tag ordered submission as the default, but allow sata_sil24 to
continue with the old behavior.
Cc: Tejun Heo <tj@kernel.org>
Reported-by: Ronny Hegewald <Ronny.Hegewald@online.de>
commit 39ef311204941ddd01ea2950d6220c8ccc710d15 upstream.
device_create_groups lets callers create devices as well as associated
sysfs attributes with a single call. This avoids race conditions seen
if sysfs attributes on new devices are created later.
[fixed up comment block placement and add checks for printk buffer
formats - gregkh]
Cc: Jean Delvare <khali@linux-fr.org>
[bwh: Backported to 3.2: adjust context]
commit f2f37f58b1b933b06d6d84e80a31a1b500fb0db2 upstream.
To make it easier for driver subsystems to work with attribute groups,
create the ATTRIBUTE_GROUPS macro to remove some of the repetitive
typing for the most common use for attribute groups.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
- Adjust filenames
- Drop changes to algorithms and drivers we don't have
- Add aliases to generic C implementations that didn't need them before]
commit 2d6d7f98284648c5ed113fe22a132148950b140f upstream.
Tejun, while reviewing the code, spotted the following race condition
between the dirtying and truncation of a page:
__set_page_dirty_nobuffers() __delete_from_page_cache()
if (TestSetPageDirty(page))
page->mapping = NULL
if (PageDirty())
dec_zone_page_state(page, NR_FILE_DIRTY);
dec_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
if (page->mapping)
account_page_dirtied(page)
__inc_zone_page_state(page, NR_FILE_DIRTY);
__inc_bdi_stat(mapping->backing_dev_info, BDI_RECLAIMABLE);
which results in an imbalance of NR_FILE_DIRTY and BDI_RECLAIMABLE.
Dirtiers usually lock out truncation, either by holding the page lock
directly, or in case of zap_pte_range(), by pinning the mapcount with
the page table lock held. The notable exception to this rule, though,
is do_wp_page(), for which this race exists. However, do_wp_page()
already waits for a locked page to unlock before setting the dirty bit,
in order to prevent a race where clear_page_dirty() misses the page bit
in the presence of dirty ptes. Upgrade that wait to a fully locked
set_page_dirty() to also cover the situation explained above.
Afterwards, the code in set_page_dirty() dealing with a truncation race
is no longer needed. Remove it.
Reported-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
- Adjust context
- Use VM_BUG_ON() rather than VM_BUG_ON_PAGE()]
commit ed6d7c8e578331cad594ee70d60e2e146b5dce7b upstream.
There's only one caller of set_page_dirty_balance() and that will call it
with page_mkwrite == 0.
The page_mkwrite argument was unused since commit b827e496c893 "mm: close
page_mkwrite races".
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 7a3ef208e662f4b63d43a23f61a64a129c525bbc upstream.
Constantly forking task causes unlimited grow of anon_vma chain. Each
next child allocates new level of anon_vmas and links vma to all
previous levels because pages might be inherited from any level.
This patch adds heuristic which decides to reuse existing anon_vma
instead of forking new one. It adds counter anon_vma->degree which
counts linked vmas and directly descending anon_vmas and reuses anon_vma
if counter is lower than two. As a result each anon_vma has either vma
or at least two descending anon_vmas. In such trees half of nodes are
leafs with alive vmas, thus count of anon_vmas is no more than two times
bigger than count of vmas.
This heuristic reuses anon_vmas as few as possible because each reuse
adds false aliasing among vmas and rmap walker ought to scan more ptes
when it searches where page is might be mapped.
Link: http://lkml.kernel.org/r/20120816024610.GA5350@evergreen.ssec.wisc.edu
Fixes: 5beb49305251 ("mm: change anon_vma linking to fix multi-process server scalability issue")
[akpm@linux-foundation.org: fix typo, per Rik]
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Reported-by: Daniel Forrest <dan.forrest@ssec.wisc.edu>
Tested-by: Michal Hocko <mhocko@suse.cz>
Tested-by: Jerome Marchand <jmarchan@redhat.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
Signed-off-by: John Stultz <john.stultz@linaro.org>
[bwh: Backported to 3.2: adjust filename]
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
commit 9bffdca8c64a72ac54c47a552734ab457bc720d4 upstream.
Use dev_to_virtio wrapper in virtio to make code clearly.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
This reverts commit 9f871e883277cc22c6217db806376dce52401a31, which
was commit 1485348d2424e1131ea42efc033cbd9366462b01 upstream.
It can cause connections to stall when a PMTU event occurs. This was
fixed by commit 843925f33fcc ("tcp: Do not apply TSO segment limit to
non-TSO packets") upstream, but that depends on other changes to TSO.
The original issue this fixed was a performance regression for the sfc
driver in extreme cases of TSO (skb with > 100 segments). This is not
really very important and it seems best to revert it rather than try
to fix it up.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: netdev@vger.kernel.org
Cc: linux-net-drivers@solarflare.com
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
- Adjust context
- Handle the CONFIG_GENERIC_HARDIRQS=n case]
commit a5a519b2710be43fce3cf9ce7bd8de8db3f2a9de upstream.
In recent testing I had disabled CONFIG_IP_MULTIPLE_TABLES and as a result
when I ran "cat /proc/net/fib_trie" the main trie was displayed multiple
times. I found that the problem line of code was in the function
fib_trie_seq_next. Specifically the line below caused the indexes to go in
the opposite direction of our traversal:
h = tb->tb_id & (FIB_TABLE_HASHSZ - 1);
This issue was that the RT tables are defined such that RT_TABLE_LOCAL is ID
255, while it is located at TABLE_LOCAL_INDEX of 0, and RT_TABLE_MAIN is 254
with a TABLE_MAIN_INDEX of 1. This means that the above line will return 1
for the local table and 0 for main. The result is that fib_trie_seq_next
will return NULL at the end of the local table, fib_trie_seq_start will
return the start of the main table, and then fib_trie_seq_next will loop on
main forever as h will always return 0.
The fix for this is to reverse the ordering of the two tables. It has the
advantage of making it so that the tables now print in the same order
regardless of if multiple tables are enabled or not. In order to make the
definition consistent with the multiple tables case I simply masked the to
RT_TABLE_XXX values by (FIB_TABLE_HASHSZ - 1). This way the two table
layouts should always stay consistent.
Fixes: 93456b6 ("[IPV4]: Unify access to the routing tables")
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
commit 71cea17ed39fdf1c0634f530ddc6a2c2fc601c2b upstream.
TCP md5 code uses per cpu variables but protects access to them with
a shared spinlock, which is a contention point.
[ tcp_md5sig_pool_lock is locked twice per incoming packet ]
Makes things much simpler, by allocating crypto structures once, first
time a socket needs md5 keys, and not deallocating them as they are
really small.
Next step would be to allow crypto allocations being done in a NUMA
aware way.
- Adjust context
- Conditions for alloc/free are quite different]
commit 5188cd44c55db3e92cd9e77a40b5baa7ed4340f7 upstream.
UFO is now disabled on all drivers that work with virtio net headers,
but userland may try to send UFO/IPv6 packets anyway. Instead of
sending with ID=0, we should select identifiers on their behalf (as we
used to).
Fixes: 916e4cf46d02 ("ipv6: reuse ip6_frag_id from ip6_ufo_append_data")
[bwh: For 3.2, net/ipv6/output_core.c is a completely new file]
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
commit bd14b1b2e29bd6812597f896dde06eaf7c6d2f24 upstream.
It appears some networks play bad games with the two bits reserved for
ECN. This can trigger false congestion notifications and very slow
transferts.
Since RFC 3168 (6.1.1) forbids SYN packets to carry CT bits, we can
disable TCP ECN negociation if it happens we receive mangled CT bits in
the SYN packet.
Cc: Perry Lorier <perryl@google.com>
Cc: Matt Mathis <mattmathis@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Wilmer van der Gaast <wilmer@google.com>
Cc: Ankur Jain <jankur@google.com>
Cc: Tom Herbert <therbert@google.com>
Cc: Dave Täht <dave.taht@bufferbloat.net>
Acked-by: Neal Cardwell <ncardwell@google.com>
Cc: Florian Westphal <fw@strlen.de>
commit 6d50e60cd2edb5a57154db5a6f64eef5aa59b751 upstream.
If an anonymous mapping is not allowed to fault thp memory and then
madvise(MADV_HUGEPAGE) is used after fault, khugepaged will never
collapse this memory into thp memory.
This occurs because the madvise(2) handler for thp, hugepage_madvise(),
clears VM_NOHUGEPAGE on the stack and it isn't stored in vma->vm_flags
until the final action of madvise_behavior(). This causes the
khugepaged_enter_vma_merge() to be a no-op in hugepage_madvise() when
the vma had previously had VM_NOHUGEPAGE set.
Fix this by passing the correct vma flags to the khugepaged mm slot
handler. There's no chance khugepaged can run on this vma until after
madvise_behavior() returns since we hold mm->mmap_sem.
It would be possible to clear VM_NOHUGEPAGE directly from vma->vm_flags
in hugepage_advise(), but I didn't want to introduce special case
behavior into madvise_behavior(). I think it's best to just let it
always set vma->vm_flags itself.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Suleiman Souhlal <suleiman@google.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
[bwh: Backported to 3.2: adjust context, indentation]
commit 8c3e434769b1707fd2d24de5a2eb25fedc634c4a upstream.
0x4c6e is a secondary device id so should not be used
by the driver.
Noticed-by: Mark Kettenis <mark.kettenis@xs4all.nl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
- extract_buf() needs to use this for the 'extract' array as well
- Adjust context]
Part of upstream commit fe8c8a126806 ('crypto: more robust
crypto_memneq'), needed by commit d4c5efdb9777 ('random: add and use
memzero_explicit() for clearing data').
commit 71458cfc782eafe4b27656e078d379a34e472adf upstream.
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
commit b8839b8c55f3fdd60dc36abcda7e0266aff7985c upstream.
The math in both blk_stack_limits() and queue_limit_alignment_offset()
assume that a block device's io_min (aka minimum_io_size) is always a
power-of-2. Fix the math such that it works for non-power-of-2 io_min.
This issue (of alignment_offset != 0) became apparent when testing
dm-thinp with a thinp blocksize that matches a RAID6 stripesize of
1280K. Commit fdfb4c8c1 ("dm thin: set minimum_io_size to pool's data
block size") unlocked the potential for alignment_offset != 0 due to
the dm-thin-pool's io_min possibly being a non-power-of-2.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 90a8020278c1598fafd071736a0846b38510309c upstream.
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
- Adjust context
- truncate_setsize() already has an oldsize variable]
commit ddbe1fca0bcb87ca8c199ea873a456ca8a948567 upstream.
This full-speed USB device generates spurious remote wakeup event
as soon as USB_DEVICE_REMOTE_WAKEUP feature is set. As the result,
Linux can't enter system suspend and S0ix power saving modes once
this keyboard is used.
This patch tries to introduce USB_QUIRK_IGNORE_REMOTE_WAKEUP quirk.
With this quirk set, wakeup capability will be ignored during
device configure.
This patch could be back-ported to kernels as old as 2.6.39.
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream.
When receiving a e.g. semi-good formed connection scan in the
form of ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
Joint work with Vlad Yasevich.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
- Adjust context
- sctp_sf_violation_paramlen() doesn't take a struct net * parameter]
commit e86fea764991e00a03ff1e56409ec9cacdbda4c9 upstream.
Returns the time remaining for an alarm timer, rather than the time at
which it is scheduled to expire. If the timer has already expired or it
is not currently scheduled, the it_value's members are set to zero.
This new behavior matches that of the other posix-timers and the POSIX
specifications.
This is a change in user-visible behavior, and may break existing
applications. Hopefully, few users rely on the old incorrect behavior.
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Sharvil Nanavati <sharvil@google.com>
Signed-off-by: Richard Larocque <rlarocque@google.com>
[jstultz: minor style tweak]
[bwh: Backported to 3.2: Add definition of alarm_expires_remaining() from
commit 6cffe00f7d4e ('alarmtimer: Add functions for timerfd support')]
commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream.
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
commit 3cea4c3071d4e55e9d7356efe9d0ebf92f0c2204 upstream.
Rename front_max field of struct ceph_msg to front_alloc_len to make
its purpose more clear.
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
commit a5fe8e7695dc3f547e955ad2b662e3e72969e506 upstream.
alpha2 is defined as 2-chars array, but is used in multiple
places as string (e.g. with nla_put_string calls), which
might leak kernel data.
Solve it by simply adding an extra char for the NULL
terminator, making such operations safe.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
commit e7b691b085fda913830e5280ae6f724b2a63c824 upstream.
slab_node() could access current->mempolicy from interrupt context.
However there's a race condition during exit where the mempolicy
is first freed and then the pointer zeroed.
Using this from interrupts seems bogus anyways. The interrupt
will interrupt a random process and therefore get a random
mempolicy. Many times, this will be idle's, which noone can change.
Just disable this here and always use local for slab
from interrupts. I also cleaned up the callers of slab_node a bit
which always passed the same argument.
I believe the original mempolicy code did that in fact,
so it's likely a regression.
v2: send version with correct logic
v3: simplify. fix typo.
Reported-by: Arun Sharma <asharma@fb.com>
Cc: penberg@kernel.org
Cc: cl@linux.com
[tdmackey@twitter.com: Rework control flow based on feedback from
cl@linux.com, fix logic, and cleanup current task_struct reference]
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Christoph Lameter <cl@linux.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: David Mackey <tdmackey@twitter.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
[ Upstream commit 04ca6973f7c1a0d8537f2d9906a0cf8e69886d75 ]
In "Counting Packets Sent Between Arbitrary Internet Hosts", Jeffrey and
Jedidiah describe ways exploiting linux IP identifier generation to
infer whether two machines are exchanging packets.
With commit 73f156a6e8c1 ("inetpeer: get rid of ip_id_count"), we
changed IP id generation, but this does not really prevent this
side-channel technique.
This patch adds a random amount of perturbation so that IP identifiers
for a given destination [1] are no longer monotonically increasing after
an idle period.
Note that prandom_u32_max(1) returns 0, so if generator is used at most
once per jiffy, this patch inserts no hole in the ID suite and do not
increase collision probability.
This is jiffies based, so in the worst case (HZ=1000), the id can
rollover after ~65 seconds of idle time, which should be fine.
We also change the hash used in __ip_select_ident() to not only hash
on daddr, but also saddr and protocol, so that ICMP probes can not be
used to infer information for other protocols.
For IPv6, adds saddr into the hash as well, but not nexthdr.
If I ping the patched target, we can see ID are now hard to predict.
21:57:11.008086 IP (...)
A > target: ICMP echo request, seq 1, length 64
21:57:11.010752 IP (... id 2081 ...)
target > A: ICMP echo reply, seq 1, length 64
21:57:12.013133 IP (...)
A > target: ICMP echo request, seq 2, length 64
21:57:12.015737 IP (... id 3039 ...)
target > A: ICMP echo reply, seq 2, length 64
21:57:13.016580 IP (...)
A > target: ICMP echo request, seq 3, length 64
21:57:13.019251 IP (... id 3437 ...)
target > A: ICMP echo reply, seq 3, length 64
[1] TCP sessions uses a per flow ID generator not changed by this patch.
Reported-by: Jeffrey Knockel <jeffk@cs.unm.edu>
Reported-by: Jedidiah R. Crandall <crandall@cs.unm.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
commit 41c3bd2039e0d7b3dc32313141773f20716ec524 upstream.
The NetLabel category (catmap) functions have a problem in that they
assume categories will be set in an increasing manner, e.g. the next
category set will always be larger than the last. Unfortunately, this
is not a valid assumption and could result in problems when attempting
to set categories less than the startbit in the lowest catmap node.
In some cases kernel panics and other nasties can result.
This patch corrects the problem by checking for this and allocating a
new catmap node instance and placing it at the front of the list.
Reported-by: Christian Evans <frodox@zoho.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
[bwh: Backported to 3.2: adjust filename for SMACK]
commit ffbc6f0ead47fa5a1dc9642b0331cb75c20a640e upstream.
Since March 2009 the kernel has treated the state that if no
MS_..ATIME flags are passed then the kernel defaults to relatime.
Defaulting to relatime instead of the existing atime state during a
remount is silly, and causes problems in practice for people who don't
specify any MS_...ATIME flags and to get the default filesystem atime
setting. Those users may encounter a permission error because the
default atime setting does not work.
A default that does not work and causes permission problems is
ridiculous, so preserve the existing value to have a default
atime setting that is always guaranteed to work.
Using the default atime setting in this way is particularly
interesting for applications built to run in restricted userspace
environments without /proc mounted, as the existing atime mount
options of a filesystem can not be read from /proc/mounts.
In practice this fixes user space that uses the default atime
setting on remount that are broken by the permission checks
keeping less privileged users from changing more privileged users
atime settings.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
[bwh: Backported to 3.2: add definition of MNT_ATIME_MASK, as we don't
need the fix that introduced that definition upstream]
commit 1a112d10f03e83fb3a2fdc4c9165865dec8a3ca6 upstream.
1871ee134b73 ("libata: support the ata host which implements a queue
depth less than 32") directly used ata_port->scsi_host->can_queue from
ata_qc_new() to determine the number of tags supported by the host;
unfortunately, SAS controllers doing SATA don't initialize ->scsi_host
leading to the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm
CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62
Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000
RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012
RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa
RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298
RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200
R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000
FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000
CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0
Stack:
ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200
ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68
ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80
Call Trace:
[<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430
[<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas]
[<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300
[<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550
[<ffffffff81317613>] __blk_run_queue+0x33/0x40
[<ffffffff8131781a>] queue_unplugged+0x2a/0x90
[<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210
[<ffffffff8131d274>] blk_finish_plug+0x14/0x50
[<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0
[<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50
[<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50
[<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0
[<ffffffff81219897>] blkdev_read_iter+0x37/0x40
[<ffffffff811e307e>] new_sync_read+0x7e/0xb0
[<ffffffff811e3734>] vfs_read+0x94/0x170
[<ffffffff811e43c6>] SyS_read+0x46/0xb0
[<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0
[<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b
Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00
Fix it by introducing ata_host->n_tags which is initialized to
ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to
scsi_host_template->can_queue in ata_host_register() for !SAS ones.
As SAS hosts are never registered, this will give them the same
ATA_MAX_QUEUE - 1 as before. Note that we can't use
scsi_host->can_queue directly for SAS hosts anyway as they can go
higher than the libata maximum.
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
Reported-by: Peter Hurley <peter@hurleysoftware.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32")
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit a3860c1c5dd1137db23d7786d284939c5761d517 upstream.
ULONG_MAX is often used to check for integer overflow when calculating
allocation size. While ULONG_MAX happens to work on most systems, there
is no guarantee that `size_t' must be the same size as `long'.
This patch introduces SIZE_MAX, the maximum value of `size_t', to improve
portability and readability for allocation size validation.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Acked-by: Alex Elder <elder@dreamhost.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Pekka Enberg <penberg@kernel.org>
commit c2853c8df57f49620d26f317d7d43347c29bfc2e upstream.
There is div64_long() to handle the s64/long division, but no mocro do
u64/ul division. It is necessary in some scenarios, so add this
function.
Signed-off-by: Alex Shi <alex.shi@intel.com>
commit b14bf2d0c0358140041d1c1805a674376964d0e0 upstream.
Some buggy JMicron USB-ATA bridges don't know how to translate the FUA
bit in READs or WRITEs. This patch adds an entry in unusual_devs.h
and a blacklist flag to tell the sd driver not to use FUA.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Michael Büsch <m@bues.ch>
Tested-by: Michael Büsch <m@bues.ch>
Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
- Adjust context
- Use sd_printk() not sd_first_printk()]
This reverts commit caa5344994778a2b4725b2d75c74430f76925e4a, which
was commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream. In 3.2,
the transport header length is not calculated in the forwarding path,
so skb_gso_network_seglen() returns an incorrect result. We also have
problems due to the local_df flag not being set correctly.
commit a353e0ce0fd42d8859260666d1e9b10f2abd4698 upstream.
Many places do
if ((skb_shinfo(skb)->tx_flags & SKBTX_DEV_ZEROCOPY))
skb_copy_ubufs(skb, gfp_mask);
to copy and invoke frag destructors if necessary.
Add an inline helper for this.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream.
The 'sysret' fastpath does not correctly restore even all regular
registers, much less any segment registers or reflags values. That is
very much part of why it's faster than 'iret'.
Normally that isn't a problem, because the normal ptrace() interface
catches the process using the signal handler infrastructure, which
always returns with an iret.
However, some paths can get caught using ptrace_event() instead of the
signal path, and for those we need to make sure that we aren't going to
return to user space using 'sysret'. Otherwise the modifications that
may have been done to the register set by the tracer wouldn't
necessarily take effect.
Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from
arch_ptrace_stop_needed() which is invoked from ptrace_stop().
Reported-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
[ Upstream commit 39c36094d78c39e038c1e499b2364e13bce36f54 ]
I noticed we were sending wrong IPv4 ID in TCP flows when MTU discovery
is disabled.
Note how GSO/TSO packets do not have monotonically incrementing ID.
06:37:41.575531 IP (id 14227, proto: TCP (6), length: 4396)
06:37:41.575534 IP (id 14272, proto: TCP (6), length: 65212)
06:37:41.575544 IP (id 14312, proto: TCP (6), length: 57972)
06:37:41.575678 IP (id 14317, proto: TCP (6), length: 7292)
06:37:41.575683 IP (id 14361, proto: TCP (6), length: 63764)
It appears I introduced this bug in linux-3.1.
inet_getid() must return the old value of peer->ip_id_count,
not the new one.
Lets revert this part, and remove the prevention of
a null identification field in IPv6 Fragment Extension Header,
which is dubious and not even done properly.
Fixes: 87c48fa3b463 ("ipv6: make fragment identifications less predictable")
commit e63ed0d7a98014fdfc2cfeb3f6dada313dcabb59 upstream.
This patch eliminates the reap_ref and replaces it with a proper kref.
On last put of this kref, the target is removed from visibility in
sysfs. The final call to scsi_target_reap() for the device is done from
__scsi_remove_device() and only if the device was made visible. This
ensures that the target disappears as soon as the last device is gone
rather than waiting until final release of the device (which is often
too long).
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 8b975bd3f9089f8ee5d7bbfd798537b992bbc7e7 upstream.
This commit updates the kernel LZO code to the current upsteam version
which features a significant speed improvement - benchmarking the Calgary
and Silesia test corpora typically shows a doubled performance in
both compression and decompression on modern i386/x86_64/powerpc machines.
Signed-off-by: Markus F.X.J. Oberhumer <markus@oberhumer.com>
commit 4af4206be2bd1933cae20c2b6fb2058dbc887f7c upstream.
syscall_regfunc() and syscall_unregfunc() should set/clear
TIF_SYSCALL_TRACEPOINT system-wide, but do_each_thread() can race
with copy_process() and miss the new child which was not added to
the process/thread lists yet.
Change copy_process() to update the child's TIF_SYSCALL_TRACEPOINT
under tasklist.
Link: http://lkml.kernel.org/p/20140413185854.GB20668@redhat.com
Fixes: a871bd33a6c0 "tracing: Add syscall tracepoints"
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
commit 07f4d9d74a04aa7c72c5dae0ef97565f28f17b92 upstream.
The user-control put and get handlers as well as the tlv do not protect against
concurrent access from multiple threads. Since the state of the control is not
updated atomically it is possible that either two write operations or a write
and a read operation race against each other. Both can lead to arbitrary memory
disclosure. This patch introduces a new lock that protects user-controls from
concurrent access. Since applications typically access controls sequentially
than in parallel a single lock per card should be fine.
Acked-by: Jaroslav Kysela <perex@perex.cz>
