path: root/include
2018-02-22x86: fix build warnign with 32-bit PAEArnd Bergmann
I ran into a 4.9 build warning in randconfig testing, starting with the KAISER patches: arch/x86/kernel/ldt.c: In function 'alloc_ldt_struct': arch/x86/include/asm/pgtable_types.h:208:24: error: large integer implicitly truncated to unsigned type [-Werror=overflow] #define __PAGE_KERNEL (__PAGE_KERNEL_EXEC | _PAGE_NX) ^ arch/x86/kernel/ldt.c:81:6: note: in expansion of macro '__PAGE_KERNEL' __PAGE_KERNEL); ^~~~~~~~~~~~~ I originally ran into this last year when the patches were part of linux-next, and tried to work around it by using the proper 'pteval_t' types consistently, but that caused additional problems. This takes a much simpler approach, and makes the argument type of the dummy helper always 64-bit, which is wide enough for any page table layout and won't hurt since this call is just an empty stub anyway. Fixes: 8f0baadf2bea ("kaiser: merged update") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22nospec: Move array_index_nospec() parameter checking into separate macroWill Deacon
commit 8fa80c503b484ddc1abbd10c7cb2ab81f3824a50 upstream. For architectures providing their own implementation of array_index_mask_nospec() in asm/barrier.h, attempting to use WARN_ONCE() to complain about out-of-range parameters using WARN_ON() results in a mess of mutually-dependent include files. Rather than unpick the dependencies, simply have the core code in nospec.h perform the checking for us. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1517840166-15399-1-git-send-email-will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22compiler-gcc.h: Introduce __optimize function attributeGeert Uytterhoeven
commit df5d45aa08f848b79caf395211b222790534ccc7 upstream. Create a new function attribute __optimize, which allows to specify an optimization level on a per-function basis. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22jbd2: fix sphinx kernel-doc build warningsTobin C. Harding
commit f69120ce6c024aa634a8fc25787205e42f0ccbe6 upstream. Sphinx emits various (26) warnings when building make target 'htmldocs'. Currently struct definitions contain duplicate documentation, some as kernel-docs and some as standard c89 comments. We can reduce duplication while cleaning up the kernel docs. Move all kernel-docs to right above each struct member. Use the set of all existing comments (kernel-doc and c89). Add documentation for missing struct members and function arguments. Signed-off-by: Tobin C. Harding <me@tobin.cc> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: poly1305 - remove ->setkey() methodEric Biggers
commit a16e772e664b9a261424107784804cffc8894977 upstream. Since Poly1305 requires a nonce per invocation, the Linux kernel implementations of Poly1305 don't use the crypto API's keying mechanism and instead expect the key and nonce as the first 32 bytes of the data. But ->setkey() is still defined as a stub returning an error code. This prevents Poly1305 from being used through AF_ALG and will also break it completely once we start enforcing that all crypto API users (not just AF_ALG) call ->setkey() if present. Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17crypto: hash - introduce crypto_hash_alg_has_setkey()Eric Biggers
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream. Templates that use an shash spawn can use crypto_shash_alg_has_setkey() to determine whether the underlying algorithm requires a key or not. But there was no corresponding function for ahash spawns. Add it. Note that the new function actually has to support both shash and ahash algorithms, since the ahash API can be used with either. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17mtd: cfi: convert inline functions to macrosArnd Bergmann
commit 9e343e87d2c4c707ef8fae2844864d4dde3a2d13 upstream. The map_word_() functions, dating back to linux-2.6.8, try to perform bitwise operations on a 'map_word' structure. This may have worked with compilers that were current then (gcc-3.4 or earlier), but end up being rather inefficient on any version I could try now (gcc-4.4 or higher). Specifically we hit a problem analyzed in gcc PR81715 where we fail to reuse the stack space for local variables. This can be seen immediately in the stack consumption for cfi_staa_erase_varsize() and other functions that (with CONFIG_KASAN) can be up to 2200 bytes. Changing the inline functions into macros brings this down to 1280 bytes. Without KASAN, the same problem exists, but the stack consumption is lower to start with, my patch shrinks it from 920 to 496 bytes on with arm-linux-gnueabi-gcc-5.4, and saves around 1KB in .text size for cfi_cmdset_0020.c, as it avoids copying map_word structures for each call to one of these helpers. With the latest gcc-8 snapshot, the problem is fixed in upstream gcc, but nobody uses that yet, so we should still work around it in mainline kernels and probably backport the workaround to stable kernels as well. We had a couple of other functions that suffered from the same gcc bug, and all of those had a simpler workaround involving dummy variables in the inline function. Unfortunately that did not work here, the macro hack was the best I could come up with. It would also be helpful to have someone to a little performance testing on the patch, to see how much it helps in terms of CPU utilitzation. Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13x86/retpoline: Avoid retpolines for built-in __init functionsDavid Woodhouse
(cherry picked from commit 66f793099a636862a71c59d4a6ba91387b155e0c) There's no point in building init code with retpolines, since it runs before any potentially hostile userspace does. And before the retpoline is actually ALTERNATIVEd into place, for much of it. Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: karahmed@amazon.de Cc: peterz@infradead.org Cc: bp@alien8.de Link: https://lkml.kernel.org/r/1517484441-1420-2-git-send-email-dwmw@amazon.co.uk Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13vfs, fdtable: Prevent bounds-check bypass via speculative executionDan Williams
(cherry picked from commit 56c30ba7b348b90484969054d561f711ba196507) 'fd' is a user controlled value that is used as a data dependency to read from the 'fdt->fd' array. In order to avoid potential leaks of kernel memory values, block speculative execution of the instruction stream that could issue reads based on an invalid 'file *' returned from __fcheck_files. Co-developed-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: kernel-hardening@lists.openwall.com Cc: gregkh@linuxfoundation.org Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: torvalds@linux-foundation.org Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727418500.33451.17392199002892248656.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13array_index_nospec: Sanitize speculative array de-referencesDan Williams
(cherry picked from commit f3804203306e098dae9ca51540fcd5eb700d7f40) array_index_nospec() is proposed as a generic mechanism to mitigate against Spectre-variant-1 attacks, i.e. an attack that bypasses boundary checks via speculative execution. The array_index_nospec() implementation is expected to be safe for current generation CPUs across multiple architectures (ARM, x86). Based on an original implementation by Linus Torvalds, tweaked to remove speculative flows by Alexei Starovoitov, and tweaked again by Linus to introduce an x86 assembly implementation for the mask generation. Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org> Co-developed-by: Alexei Starovoitov <ast@kernel.org> Suggested-by: Cyril Novikov <cnovikov@lynx.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: kernel-hardening@lists.openwall.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Russell King <linux@armlinux.org.uk> Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727414229.33451.18411580953862676575.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13module/retpoline: Warn about missing retpoline in moduleAndi Kleen
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8) There's a risk that a kernel which has full retpoline mitigations becomes vulnerable when a module gets loaded that hasn't been compiled with the right compiler or the right option. To enable detection of that mismatch at module load time, add a module info string "retpoline" at build time when the module was compiled with retpoline support. This only covers compiled C source, but assembler source or prebuilt object files are not checked. If a retpoline enabled kernel detects a non retpoline protected module at load time, print a warning and report it in the sysfs vulnerability file. [ tglx: Massaged changelog ] Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: gregkh@linuxfoundation.org Cc: torvalds@linux-foundation.org Cc: jeyu@kernel.org Cc: arjan@linux.intel.com Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03tty: fix data race between tty_init_dev and flush of bufGaurav Kohli
commit b027e2298bd588d6fa36ed2eda97447fb3eac078 upstream. There can be a race, if receive_buf call comes before tty initialization completes in n_tty_open and tty->disc_data may be NULL. CPU0 CPU1 ---- ---- 000|n_tty_receive_buf_common() n_tty_open() -001|n_tty_receive_buf2() tty_ldisc_open.isra.3() -002|tty_ldisc_receive_buf(inline) tty_ldisc_setup() Using ldisc semaphore lock in tty_init_dev till disc_data initializes completely. Signed-off-by: Gaurav Kohli <gkohli@codeaurora.org> Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03net/mlx5: Define interface bits for fencing UMR wqeMax Gurtovoy
commit 1410a90ae449061b7e1ae19d275148f36948801b upstream. HW can implement UMR wqe re-transmission in various ways. Thus, add HCA cap to distinguish the needed fence for UMR to make sure that the wqe wouldn't fail on mkey checks. Signed-off-by: Max Gurtovoy <maxg@mellanox.com> Acked-by: Leon Romanovsky <leon@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com> Cc: Marta Rybczynska <mrybczyn@kalray.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31bpf: avoid false sharing of map refcount with max_entriesDaniel Borkmann
[ upstream commit be95a845cc4402272994ce290e3ad928aff06cb9 ] In addition to commit b2157399cc98 ("bpf: prevent out-of-bounds speculation") also change the layout of struct bpf_map such that false sharing of fast-path members like max_entries is avoided when the maps reference counter is altered. Therefore enforce them to be placed into separate cachelines. pahole dump after change: struct bpf_map { const struct bpf_map_ops * ops; /* 0 8 */ struct bpf_map * inner_map_meta; /* 8 8 */ void * security; /* 16 8 */ enum bpf_map_type map_type; /* 24 4 */ u32 key_size; /* 28 4 */ u32 value_size; /* 32 4 */ u32 max_entries; /* 36 4 */ u32 map_flags; /* 40 4 */ u32 pages; /* 44 4 */ u32 id; /* 48 4 */ int numa_node; /* 52 4 */ bool unpriv_array; /* 56 1 */ /* XXX 7 bytes hole, try to pack */ /* --- cacheline 1 boundary (64 bytes) --- */ struct user_struct * user; /* 64 8 */ atomic_t refcnt; /* 72 4 */ atomic_t usercnt; /* 76 4 */ struct work_struct work; /* 80 32 */ char name[16]; /* 112 16 */ /* --- cacheline 2 boundary (128 bytes) --- */ /* size: 128, cachelines: 2, members: 17 */ /* sum members: 121, holes: 1, sum holes: 7 */ }; Now all entries in the first cacheline are read only throughout the life time of the map, set up once during map creation. Overall struct size and number of cachelines doesn't change from the reordering. struct bpf_map is usually first member and embedded in map structs in specific map implementations, so also avoid those members to sit at the end where it could potentially share the cacheline with first map values e.g. in the array since remote CPUs could trigger map updates just as well for those (easily dirtying members like max_entries intentionally as well) while having subsequent values in cache. Quoting from Google's Project Zero blog [1]: Additionally, at least on the Intel machine on which this was tested, bouncing modified cache lines between cores is slow, apparently because the MESI protocol is used for cache coherence [8]. Changing the reference counter of an eBPF array on one physical CPU core causes the cache line containing the reference counter to be bounced over to that CPU core, making reads of the reference counter on all other CPU cores slow until the changed reference counter has been written back to memory. Because the length and the reference counter of an eBPF array are stored in the same cache line, this also means that changing the reference counter on one physical CPU core causes reads of the eBPF array's length to be slow on other physical CPU cores (intentional false sharing). While this doesn't 'control' the out-of-bounds speculation through masking the index as in commit b2157399cc98, triggering a manipulation of the map's reference counter is really trivial, so lets not allow to easily affect max_entries from it. Splitting to separate cachelines also generally makes sense from a performance perspective anyway in that fast-path won't have a cache miss if the map gets pinned, reused in other progs, etc out of control path, thus also avoids unintentional false sharing. [1] https://googleprojectzero.blogspot.ch/2018/01/reading-privileged-memory-with-side.html Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31ipv4: Make neigh lookup keys for loopback/point-to-point devices be INADDR_ANYJim Westfall
[ Upstream commit cd9ff4de0107c65d69d02253bb25d6db93c3dbc1 ] Map all lookup neigh keys to INADDR_ANY for loopback/point-to-point devices to avoid making an entry for every remote ip the device needs to talk to. This used the be the old behavior but became broken in a263b3093641f (ipv4: Make neigh lookups directly in output packet path) and later removed in 0bb4087cbec0 (ipv4: Fix neigh lookup keying over loopback/point-to-point devices) because it was broken. Signed-off-by: Jim Westfall <jwestfall@surrealistic.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31net: tcp: close sock if net namespace is exitingDan Streetman
[ Upstream commit 4ee806d51176ba7b8ff1efd81f271d7252e03a1d ] When a tcp socket is closed, if it detects that its net namespace is exiting, close immediately and do not wait for FIN sequence. For normal sockets, a reference is taken to their net namespace, so it will never exit while the socket is open. However, kernel sockets do not take a reference to their net namespace, so it may begin exiting while the kernel socket is still open. In this case if the kernel socket is a tcp socket, it will stay open trying to complete its close sequence. The sock's dst(s) hold a reference to their interface, which are all transferred to the namespace's loopback interface when the real interfaces are taken down. When the namespace tries to take down its loopback interface, it hangs waiting for all references to the loopback interface to release, which results in messages like: unregister_netdevice: waiting for lo to become free. Usage count = 1 These messages continue until the socket finally times out and closes. Since the net namespace cleanup holds the net_mutex while calling its registered pernet callbacks, any new net namespace initialization is blocked until the current net namespace finishes exiting. After this change, the tcp socket notices the exiting net namespace, and closes immediately, releasing its dst(s) and their reference to the loopback interface, which lets the net namespace continue exiting. Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1711407 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=97811 Signed-off-by: Dan Streetman <ddstreet@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31ipv6: Fix getsockopt() for sockets with default IPV6_AUTOFLOWLABELBen Hutchings
[ Upstream commit e9191ffb65d8e159680ce0ad2224e1acbde6985c ] Commit 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl setting") removed the initialisation of ipv6_pinfo::autoflowlabel and added a second flag to indicate whether this field or the net namespace default should be used. The getsockopt() handling for this case was not updated, so it currently returns 0 for all sockets for which IPV6_AUTOFLOWLABEL is not explicitly enabled. Fix it to return the effective value, whether that has been set at the socket or net namespace level. Fixes: 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl ...") Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31eventpoll.h: add missing epoll event masksGreg KH
commit 7e040726850a106587485c21bdacc0bfc8a0cbed upstream. [resend due to me forgetting to cc: linux-api the first time around I posted these back on Feb 23] From: Greg Kroah-Hartman <gregkh@linuxfoundation.org> For some reason these values are not in the uapi header file, so any libc has to define it themselves. To prevent them from needing to do this, just have the kernel provide the correct values. Reported-by: Elliott Hughes <enh@google.com> Signed-off-by: Greg Hackmann <ghackmann@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31mm: fix 100% CPU kswapd busyloop on unreclaimable nodesJohannes Weiner
commit c73322d098e4b6f5f0f0fa1330bf57e218775539 upstream. Patch series "mm: kswapd spinning on unreclaimable nodes - fixes and cleanups". Jia reported a scenario in which the kswapd of a node indefinitely spins at 100% CPU usage. We have seen similar cases at Facebook. The kernel's current method of judging its ability to reclaim a node (or whether to back off and sleep) is based on the amount of scanned pages in proportion to the amount of reclaimable pages. In Jia's and our scenarios, there are no reclaimable pages in the node, however, and the condition for backing off is never met. Kswapd busyloops in an attempt to restore the watermarks while having nothing to work with. This series reworks the definition of an unreclaimable node based not on scanning but on whether kswapd is able to actually reclaim pages in MAX_RECLAIM_RETRIES (16) consecutive runs. This is the same criteria the page allocator uses for giving up on direct reclaim and invoking the OOM killer. If it cannot free any pages, kswapd will go to sleep and leave further attempts to direct reclaim invocations, which will either make progress and re-enable kswapd, or invoke the OOM killer. Patch #1 fixes the immediate problem Jia reported, the remainder are smaller fixlets, cleanups, and overall phasing out of the old method. Patch #6 is the odd one out. It's a nice cleanup to get_scan_count(), and directly related to #5, but in itself not relevant to the series. If the whole series is too ambitious for 4.11, I would consider the first three patches fixes, the rest cleanups. This patch (of 9): Jia He reports a problem with kswapd spinning at 100% CPU when requesting more hugepages than memory available in the system: $ echo 4000 >/proc/sys/vm/nr_hugepages top - 13:42:59 up 3:37, 1 user, load average: 1.09, 1.03, 1.01 Tasks: 1 total, 1 running, 0 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 12.5 sy, 0.0 ni, 85.5 id, 2.0 wa, 0.0 hi, 0.0 si, 0.0 st KiB Mem: 31371520 total, 30915136 used, 456384 free, 320 buffers KiB Swap: 6284224 total, 115712 used, 6168512 free. 48192 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 76 root 20 0 0 0 0 R 100.0 0.000 217:17.29 kswapd3 At that time, there are no reclaimable pages left in the node, but as kswapd fails to restore the high watermarks it refuses to go to sleep. Kswapd needs to back away from nodes that fail to balance. Up until commit 1d82de618ddd ("mm, vmscan: make kswapd reclaim in terms of nodes") kswapd had such a mechanism. It considered zones whose theoretically reclaimable pages it had reclaimed six times over as unreclaimable and backed away from them. This guard was erroneously removed as the patch changed the definition of a balanced node. However, simply restoring this code wouldn't help in the case reported here: there *are* no reclaimable pages that could be scanned until the threshold is met. Kswapd would stay awake anyway. Introduce a new and much simpler way of backing off. If kswapd runs through MAX_RECLAIM_RETRIES (16) cycles without reclaiming a single page, make it back off from the node. This is the same number of shots direct reclaim takes before declaring OOM. Kswapd will go to sleep on that node until a direct reclaimer manages to reclaim some pages, thus proving the node reclaimable again. [hannes@cmpxchg.org: check kswapd failure against the cumulative nr_reclaimed count] Link: http://lkml.kernel.org/r/20170306162410.GB2090@cmpxchg.org [shakeelb@google.com: fix condition for throttle_direct_reclaim] Link: http://lkml.kernel.org/r/20170314183228.20152-1-shakeelb@google.com Link: http://lkml.kernel.org/r/20170228214007.5621-2-hannes@cmpxchg.org Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Shakeel Butt <shakeelb@google.com> Reported-by: Jia He <hejianet@gmail.com> Tested-by: Jia He <hejianet@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31Revert "module: Add retpoline tag to VERMAGIC"Greg Kroah-Hartman
commit 5132ede0fe8092b043dae09a7cc32b8ae7272baa upstream. This reverts commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12. Turns out distros do not want to make retpoline as part of their "ABI", so this patch should not have been merged. Sorry Andi, this was my fault, I suggested it when your original patch was the "correct" way of doing this instead. Reported-by: Jiri Kosina <jikos@kernel.org> Fixes: 6cfb521ac0d5 ("module: Add retpoline tag to VERMAGIC") Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: rusty@rustcorp.com.au Cc: arjan.van.de.ven@intel.com Cc: jeyu@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31drivers: base: cacheinfo: fix x86 with CONFIG_OF enabledSudeep Holla
commit fac51482577d5e05bbb0efa8d602a3c2111098bf upstream. With CONFIG_OF enabled on x86, we get the following error on boot: " Failed to find cpu0 device node Unable to detect cache hierarchy from DT for CPU 0 " and the cacheinfo fails to get populated in the corresponding sysfs entries. This is because cache_setup_of_node looks for of_node for setting up the shared cpu_map without checking that it's already populated in the architecture specific callback. In order to indicate that the shared cpu_map is already populated, this patch introduces a boolean `cpu_map_populated` in struct cpu_cacheinfo that can be used by the generic code to skip cache_shared_cpu_map_setup. This patch also sets that boolean for x86. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23module: Add retpoline tag to VERMAGICAndi Kleen
commit 6cfb521ac0d5b97470883ff9b7facae264b7ab12 upstream. Add a marker for retpoline to the module VERMAGIC. This catches the case when a non RETPOLINE compiled module gets loaded into a retpoline kernel, making it insecure. It doesn't handle the case when retpoline has been runtime disabled. Even in this case the match of the retcompile status will be enforced. This implies that even with retpoline run time disabled all modules loaded need to be recompiled. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: David Woodhouse <dwmw@amazon.co.uk> Cc: rusty@rustcorp.com.au Cc: arjan.van.de.ven@intel.com Cc: jeyu@kernel.org Cc: torvalds@linux-foundation.org Link: https://lkml.kernel.org/r/20180116205228.4890-1-andi@firstfloor.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23scsi: sg: disable SET_FORCE_LOW_DMAHannes Reinecke
commit 745dfa0d8ec26b24f3304459ff6e9eacc5c8351b upstream. The ioctl SET_FORCE_LOW_DMA has never worked since the initial git check-in, and the respective setting is nowadays handled correctly. So disable it entirely. Signed-off-by: Hannes Reinecke <hare@suse.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Tested-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17objtool, modules: Discard objtool annotation sections for modulesJosh Poimboeuf
commit e390f9a9689a42f477a6073e2e7df530a4c1b740 upstream. The '__unreachable' and '__func_stack_frame_non_standard' sections are only used at compile time. They're discarded for vmlinux but they should also be discarded for modules. Since this is a recurring pattern, prefix the section names with ".discard.". It's a nice convention and vmlinux.lds.h already discards such sections. Also remove the 'a' (allocatable) flag from the __unreachable section since it doesn't make sense for a discarded section. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jessica Yu <jeyu@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends") Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble Signed-off-by: Ingo Molnar <mingo@kernel.org> [dwmw2: Remove the unreachable part in backporting since it's not here yet] Signed-off-by: David Woodhouse <dwmw@amazon.co.ku> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sysfs/cpu: Add vulnerability folderThomas Gleixner
commit 87590ce6e373d1a5401f6539f0c59ef92dd924a9 upstream. As the meltdown/spectre problem affects several CPU architectures, it makes sense to have common way to express whether a system is affected by a particular vulnerability or not. If affected the way to express the mitigation should be common as well. Create /sys/devices/system/cpu/vulnerabilities folder and files for meltdown, spectre_v1 and spectre_v2. Allow architectures to override the show function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: David Woodhouse <dwmw@amazon.co.uk> Link: https://lkml.kernel.org/r/20180107214913.096657732@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17bpf: prevent out-of-bounds speculationAlexei Starovoitov
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream. Under speculation, CPUs may mis-predict branches in bounds checks. Thus, memory accesses under a bounds check may be speculated even if the bounds check fails, providing a primitive for building a side channel. To avoid leaking kernel data round up array-based maps and mask the index after bounds check, so speculated load with out of bounds index will load either valid value from the array or zero from the padded area. Unconditionally mask index for all array types even when max_entries are not rounded to power of 2 for root user. When map is created by unpriv user generate a sequence of bpf insns that includes AND operation to make sure that JITed code includes the same 'index & index_mask' operation. If prog_array map is created by unpriv user replace bpf_tail_call(ctx, map, index); with if (index >= max_entries) { index &= map->index_mask; bpf_tail_call(ctx, map, index); } (along with roundup to power 2) to prevent out-of-bounds speculation. There is secondary redundant 'if (index >= max_entries)' in the interpreter and in all JITs, but they can be optimized later if necessary. Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array) cannot be used by unpriv, so no changes there. That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on all architectures with and without JIT. v2->v3: Daniel noticed that attack potentially can be crafted via syscall commands without loading the program, so add masking to those paths as well. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: John Fastabend <john.fastabend@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Cc: Jiri Slaby <jslaby@suse.cz> [ Backported to 4.9 - gregkh ] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17target: Avoid early CMD_T_PRE_EXECUTE failures during ABORT_TASKNicholas Bellinger
commit 1c21a48055a67ceb693e9c2587824a8de60a217c upstream. This patch fixes bug where early se_cmd exceptions that occur before backend execution can result in use-after-free if/when a subsequent ABORT_TASK occurs for the same tag. Since an early se_cmd exception will have had se_cmd added to se_session->sess_cmd_list via target_get_sess_cmd(), it will not have CMD_T_COMPLETE set by the usual target_complete_cmd() backend completion path. This causes a subsequent ABORT_TASK + __target_check_io_state() to signal ABORT_TASK should proceed. As core_tmr_abort_task() executes, it will bring the outstanding se_cmd->cmd_kref count down to zero releasing se_cmd, after se_cmd has already been queued with error status into fabric driver response path code. To address this bug, introduce a CMD_T_PRE_EXECUTE bit that is set at target_get_sess_cmd() time, and cleared immediately before backend driver dispatch in target_execute_cmd() once CMD_T_ACTIVE is set. Then, check CMD_T_PRE_EXECUTE within __target_check_io_state() to determine when an early exception has occured, and avoid aborting this se_cmd since it will have already been queued into fabric driver response path code. Reported-by: Donald White <dew@datera.io> Cc: Donald White <dew@datera.io> Cc: Mike Christie <mchristi@redhat.com> Cc: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17net: stmmac: enable EEE in MII, GMII or RGMII onlyJerome Brunet
[ Upstream commit 879626e3a52630316d817cbda7cec9a5446d1d82 ] Note in the databook - Section 4.4 - EEE : " The EEE feature is not supported when the MAC is configured to use the TBI, RTBI, SMII, RMII or SGMII single PHY interface. Even if the MAC supports multiple PHY interfaces, you should activate the EEE mode only when the MAC is operating with GMII, MII, or RGMII interface." Applying this restriction solves a stability issue observed on Amlogic gxl platforms operating with RMII interface and the internal PHY. Fixes: 83bf79b6bb64 ("stmmac: disable at run-time the EEE if not supported") Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Tested-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17sh_eth: fix SH7757 GEther initializationSergei Shtylyov
[ Upstream commit 5133550296d43236439494aa955bfb765a89f615 ] Renesas SH7757 has 2 Fast and 2 Gigabit Ether controllers, while the 'sh_eth' driver can only reset and initialize TSU of the first controller pair. Shimoda-san tried to solve that adding the 'needs_init' member to the 'struct sh_eth_plat_data', however the platform code still never sets this flag. I think that we can infer this information from the 'devno' variable (set to 'platform_device::id') and reset/init the Ether controller pair only for an even 'devno'; therefore 'sh_eth_plat_data::needs_init' can be removed... Fixes: 150647fb2c31 ("net: sh_eth: change the condition of initialization") Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17KVM: Fix stack-out-of-bounds read in write_mmioWanpeng Li
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream. Reported by syzkaller: BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm] Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298 CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18 Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016 Call Trace: dump_stack+0xab/0xe1 print_address_description+0x6b/0x290 kasan_report+0x28a/0x370 write_mmio+0x11e/0x270 [kvm] emulator_read_write_onepage+0x311/0x600 [kvm] emulator_read_write+0xef/0x240 [kvm] emulator_fix_hypercall+0x105/0x150 [kvm] em_hypercall+0x2b/0x80 [kvm] x86_emulate_insn+0x2b1/0x1640 [kvm] x86_emulate_instruction+0x39a/0xb90 [kvm] handle_exception+0x1b4/0x4d0 [kvm_intel] vcpu_enter_guest+0x15a0/0x2640 [kvm] kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm] kvm_vcpu_ioctl+0x479/0x880 [kvm] do_vfs_ioctl+0x142/0x9a0 SyS_ioctl+0x74/0x80 entry_SYSCALL_64_fastpath+0x23/0x9a The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall) to the guest memory, however, write_mmio tracepoint always prints 8 bytes through *(u64 *)val since kvm splits the mmio access into 8 bytes. This leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes it by just accessing the bytes which we operate on. Before patch: syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f After patch: syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f Reported-by: Dmitry Vyukov <dvyukov@google.com> Reviewed-by: Darren Kenny <darren.kenny@oracle.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17mac80211: Add RX flag to indicate ICV strippedDavid Spinadel
commit cef0acd4d7d4811d2d19cd0195031bf0dfe41249 upstream. Add a flag that indicates that the WEP ICV was stripped from an RX packet, allowing the device to not transfer that if it's already checked. Signed-off-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10kernel: make groups_sort calling a responsibility group_info allocatorsThiago Rafael Becker
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream. In testing, we found that nfsd threads may call set_groups in parallel for the same entry cached in auth.unix.gid, racing in the call of groups_sort, corrupting the groups for that entry and leading to permission denials for the client. This patch: - Make groups_sort globally visible. - Move the call to groups_sort to the modifiers of group_info - Remove the call to groups_sort from set_groups Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: NeilBrown <neilb@suse.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10fscache: Fix the default for fscache_maybe_release_page()David Howells
commit 98801506552593c9b8ac11021b0cdad12cab4f6b upstream. Fix the default for fscache_maybe_release_page() for when the cookie isn't valid or the page isn't cached. It mustn't return false as that indicates the page cannot yet be freed. The problem with the default is that if, say, there's no cache, but a network filesystem's pages are using up almost all the available memory, a system can OOM because the filesystem ->releasepage() op will not allow them to be released as fscache_maybe_release_page() incorrectly prevents it. This can be tested by writing a sequence of 512MiB files to an AFS mount. It does not affect NFS or CIFS because both of those wrap the call in a check of PG_fscache and it shouldn't bother Ceph as that only has PG_private set whilst writeback is in progress. This might be an issue for 9P, however. Note that the pages aren't entirely stuck. Removing a file or unmounting will clear things because that uses ->invalidatepage() instead. Fixes: 201a15428bd5 ("FS-Cache: Handle pages pending storage that get evicted under OOM conditions") Reported-by: Marc Dionne <marc.dionne@auristor.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Marc Dionne <marc.dionne@auristor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: vmstat show NR_KAISERTABLE as nr_overheadHugh Dickins
The kaiser update made an interesting choice, never to free any shadow page tables. Contention on global spinlock was worrying, particularly with it held across page table scans when freeing. Something had to be done: I was going to add refcounting; but simply never to free them is an appealing choice, minimizing contention without complicating the code (the more a page table is found already, the less the spinlock is used). But leaking pages in this way is also a worry: can we get away with it? At the very least, we need a count to show how bad it actually gets: in principle, one might end up wasting about 1/256 of memory that way (1/512 for when direct-mapped pages have to be user-mapped, plus 1/512 for when they are user-mapped from the vmalloc area on another occasion (but we don't have vmalloc'ed stacks, so only large ldts are vmalloc'ed). Add per-cpu stat NR_KAISERTABLE: including 256 at startup for the shared pgd entries, and 1 for each intermediate page table added thereafter for user-mapping - but leave out the 1 per mm, for its shadow pgd, because that distracts from the monotonic increase. Shown in /proc/vmstat as nr_overhead (0 if kaiser not enabled). In practice, it doesn't look so bad so far: more like 1/12000 after nine hours of gtests below; and movable pageblock segregation should tend to cluster the kaiser tables into a subset of the address space (if not, they will be bad for compaction too). But production may tell a different story: keep an eye on this number, and bring back lighter freeing if it gets out of control (maybe a shrinker). ["nr_overhead" should of course say "nr_kaisertable", if it needs to stay; but for the moment we are being coy, preferring that when Joe Blow notices a new line in his /proc/vmstat, he does not get too curious about what this "kaiser" stuff might be.] Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: cleanups while trying for gold linkHugh Dickins
While trying to get our gold link to work, four cleanups: matched the gdt_page declaration to its definition; in fiddling unsuccessfully with PERCPU_INPUT(), lined up backslashes; lined up the backslashes according to convention in percpu-defs.h; deleted the unused irq_stack_pointer addition to irq_stack_union. Sad to report that aligning backslashes does not appear to help gold align to 8192: but while these did not help, they are worth keeping. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: stack map PAGE_SIZE at THREAD_SIZE-PAGE_SIZEHugh Dickins
Kaiser only needs to map one page of the stack; and kernel/fork.c did not build on powerpc (no __PAGE_KERNEL). It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack() and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's kaiser_add_mapping() and kaiser_remove_mapping(). And use linux/kaiser.h in init/main.c to avoid the #ifdefs there. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: merged updateDave Hansen
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging). Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KAISER: Kernel Address IsolationRichard Fellner
This patch introduces our implementation of KAISER (Kernel Address Isolation to have Side-channels Efficiently Removed), a kernel isolation technique to close hardware side channels on kernel address information. More information about the patch can be found on: https://github.com/IAIK/KAISER From: Richard Fellner <richard.fellner@student.tugraz.at> From: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode Date: Thu, 4 May 2017 14:26:50 +0200 Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2 Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5 To: <linux-kernel@vger.kernel.org> To: <kernel-hardening@lists.openwall.com> Cc: <clementine.maurice@iaik.tugraz.at> Cc: <moritz.lipp@iaik.tugraz.at> Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Cc: Richard Fellner <richard.fellner@student.tugraz.at> Cc: Ingo Molnar <mingo@kernel.org> Cc: <kirill.shutemov@linux.intel.com> Cc: <anders.fogh@gdata-adan.de> After several recent works [1,2,3] KASLR on x86_64 was basically considered dead by many researchers. We have been working on an efficient but effective fix for this problem and found that not mapping the kernel space when running in user mode is the solution to this problem [4] (the corresponding paper [5] will be presented at ESSoS17). With this RFC patch we allow anybody to configure their kernel with the flag CONFIG_KAISER to add our defense mechanism. If there are any questions we would love to answer them. We also appreciate any comments! Cheers, Daniel (+ the KAISER team from Graz University of Technology) [1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf [2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf [3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf [4] https://github.com/IAIK/KAISER [5] https://gruss.cc/files/kaiser.pdf [patch based also on https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch] Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at> Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at> Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at> Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02mm/vmstat: Make NR_TLB_REMOTE_FLUSH_RECEIVED available even on UPAndy Lutomirski
commit 5dd0b16cdaff9b94da06074d5888b03235c0bf17 upstream. This fixes CONFIG_SMP=n, CONFIG_DEBUG_TLBFLUSH=y without introducing further #ifdef soup. Caught by a Kbuild bot randconfig build. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: ce4a4e565f52 ("x86/mm: Remove the UP asm/tlbflush.h code, always use the (formerly) SMP code") Link: http://lkml.kernel.org/r/76da9a3cc4415996f2ad2c905b93414add322021.1496673616.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02timers: Reinitialize per cpu bases on hotplugThomas Gleixner
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream. The timer wheel bases are not (re)initialized on CPU hotplug. That leaves them with a potentially stale clk and next_expiry valuem, which can cause trouble then the CPU is plugged. Add a prepare callback which forwards the clock, sets next_expiry to far in the future and reset the control flags to a known state. Set base->must_forward_clk so the first timer which is queued will try to forward the clock to current jiffies. Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel") Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Sebastian Siewior <bigeasy@linutronix.de> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02net/mlx5: Fix rate limit packet pacing naming and structEran Ben Elisha
[ Upstream commit 37e92a9d4fe38dc3e7308913575983a6a088c8d4 ] In mlx5_ifc, struct size was not complete, and thus driver was sending garbage after the last defined field. Fixed it by adding reserved field to complete the struct size. In addition, rename all set_rate_limit to set_pp_rate_limit to be compliant with the Firmware <-> Driver definition. Fixes: 7486216b3a0b ("{net,IB}/mlx5: mlx5_ifc updates") Fixes: 1466cc5b23d1 ("net/mlx5: Rate limit tables support") Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02tcp: invalidate rate samples during SACK renegingYousuk Seung
[ Upstream commit d4761754b4fb2ef8d9a1e9d121c4bec84e1fe292 ] Mark tcp_sock during a SACK reneging event and invalidate rate samples while marked. Such rate samples may overestimate bw by including packets that were SACKed before reneging. < ack 6001 win 10000 sack 7001:38001 < ack 7001 win 0 sack 8001:38001 // Reneg detected > seq 7001:8001 // RTO, SACK cleared. < ack 38001 win 10000 In above example the rate sample taken after the last ack will count 7001-38001 as delivered while the actual delivery rate likely could be much lower i.e. 7001-8001. This patch adds a new field tcp_sock.sack_reneg and marks it when we declare SACK reneging and entering TCP_CA_Loss, and unmarks it after the last rate sample was taken before moving back to TCP_CA_Open. This patch also invalidates rate samples taken while tcp_sock.is_sack_reneg is set. Fixes: b9f64820fb22 ("tcp: track data delivery rate for a TCP connection") Signed-off-by: Yousuk Seung <ysseung@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Soheil Hassas Yeganeh <soheil@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Priyaranjan Jha <priyarjha@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ptr_ring: add barriersMichael S. Tsirkin
[ Upstream commit a8ceb5dbfde1092b466936bca0ff3be127ecf38e ] Users of ptr_ring expect that it's safe to give the data structure a pointer and have it be available to consumers, but that actually requires an smb_wmb or a stronger barrier. In absence of such barriers and on architectures that reorder writes, consumer might read an un=initialized value from an skb pointer stored in the skb array. This was observed causing crashes. To fix, add memory barriers. The barrier we use is a wmb, the assumption being that producers do not need to read the value so we do not need to order these reads. Reported-by: George Cherian <george.cherian@cavium.com> Suggested-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02net: reevalulate autoflowlabel setting after sysctl settingShaohua Li
[ Upstream commit 513674b5a2c9c7a67501506419da5c3c77ac6f08 ] sysctl.ip6.auto_flowlabels is default 1. In our hosts, we set it to 2. If sockopt doesn't set autoflowlabel, outcome packets from the hosts are supposed to not include flowlabel. This is true for normal packet, but not for reset packet. The reason is ipv6_pinfo.autoflowlabel is set in sock creation. Later if we change sysctl.ip6.auto_flowlabels, the ipv6_pinfo.autoflowlabel isn't changed, so the sock will keep the old behavior in terms of auto flowlabel. Reset packet is suffering from this problem, because reset packet is sent from a special control socket, which is created at boot time. Since sysctl.ipv6.auto_flowlabels is 1 by default, the control socket will always have its ipv6_pinfo.autoflowlabel set, even after user set sysctl.ipv6.auto_flowlabels to 1, so reset packset will always have flowlabel. Normal sock created before sysctl setting suffers from the same issue. We can't even turn off autoflowlabel unless we kill all socks in the hosts. To fix this, if IPV6_AUTOFLOWLABEL sockopt is used, we use the autoflowlabel setting from user, otherwise we always call ip6_default_np_autolabel() which has the new settings of sysctl. Note, this changes behavior a little bit. Before commit 42240901f7c4 (ipv6: Implement different admin modes for automatic flow labels), the autoflowlabel behavior of a sock isn't sticky, eg, if sysctl changes, existing connection will change autoflowlabel behavior. After that commit, autoflowlabel behavior is sticky in the whole life of the sock. With this patch, the behavior isn't sticky again. Cc: Martin KaFai Lau <kafai@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tom Herbert <tom@quantonium.net> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02ipv4: igmp: guard against silly MTU valuesEric Dumazet
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ] IPv4 stack reacts to changes to small MTU, by disabling itself under RTNL. But there is a window where threads not using RTNL can see a wrong device mtu. This can lead to surprises, in igmp code where it is assumed the mtu is suitable. Fix this by reading device mtu once and checking IPv4 minimal MTU. This patch adds missing IPV4_MIN_MTU define, to not abuse ETH_MIN_MTU anymore. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-29crypto: mcryptd - protect the per-CPU queue with a lockSebastian Andrzej Siewior
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream. mcryptd_enqueue_request() grabs the per-CPU queue struct and protects access to it with disabled preemption. Then it schedules a worker on the same CPU. The worker in mcryptd_queue_worker() guards access to the same per-CPU variable with disabled preemption. If we take CPU-hotplug into account then it is possible that between queue_work_on() and the actual invocation of the worker the CPU goes down and the worker will be scheduled on _another_ CPU. And here the preempt_disable() protection does not work anymore. The easiest thing is to add a spin_lock() to guard access to the list. Another detail: mcryptd_queue_worker() is not processing more than MCRYPTD_BATCH invocation in a row. If there are still items left, then it will invoke queue_work() to proceed with more later. *I* would suggest to simply drop that check because it does not use a system workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if preemption is required then the scheduler should do it. However if queue_work() is used then the work item is marked as CPU unbound. That means it will try to run on the local CPU but it may run on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y. Again, the preempt_disable() won't work here but lock which was introduced will help. In order to keep work-item on the local CPU (and avoid RR) I changed it to queue_work_on(). Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25bpf: fix branch pruning logicDaniel Borkmann
From: Alexei Starovoitov <ast@fb.com> [ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ] when the verifier detects that register contains a runtime constant and it's compared with another constant it will prune exploration of the branch that is guaranteed not to be taken at runtime. This is all correct, but malicious program may be constructed in such a way that it always has a constant comparison and the other branch is never taken under any conditions. In this case such path through the program will not be explored by the verifier. It won't be taken at run-time either, but since all instructions are JITed the malicious program may cause JITs to complain about using reserved fields, etc. To fix the issue we have to track the instructions explored by the verifier and sanitize instructions that are dead at run time with NOPs. We cannot reject such dead code, since llvm generates it for valid C code, since it doesn't do as much data flow analysis as the verifier does. Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)") Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25vhost-vsock: add pkt cancel capabilityPeng Tao
[ Upstream commit 16320f363ae128d9b9c70e60f00f2a572f57c23d ] To allow canceling all packets of a connection. Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com> Reviewed-by: Jorgen Hansen <jhansen@vmware.com> Signed-off-by: Peng Tao <bergwolf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25vsock: track pkt owner vsockPeng Tao
[ Upstream commit 36d277bac8080202684e67162ebb157f16631581 ] So that we can cancel a queued pkt later if necessary. Signed-off-by: Peng Tao <bergwolf@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
