path: root/init/Kconfig
2009-08-04perf_counter: Set the CONFIG_PERF_COUNTERS default to y if CONFIG_PROFILING=yIngo Molnar
If user has already enabled profiling support in the kernel (for oprofile, old-style profiling of ftrace) then offer up perfcounters with a y default in interactive kconfig sessions. Still keep it off by default otherwise. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02tracing, perf_counter: Add help text to CONFIG_EVENT_PROFILEPeter Zijlstra
Explain what tracepoint profiling sources are about. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Jeff Garzik <jeff@garzik.org> LKML-Reference: <1248856508.6987.3041.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-13perf_counter: Fix the tracepoint channel to perfcountersChris Wilson
Fix a missed rename in EVENT_PROFILE support so that it gets built and allows tracepoint tracing from the 'perf' tool. Fix a typo in the (never before built & enabled) portion in perf_counter.c as well, and update that code to the attr.config changes as well. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Ben Gamari <bgamari.foss@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1246869094-21237-1-git-send-email-chris@chris-wilson.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-18kernel: constructor supportPeter Oberparleiter
Call constructors (gcc-generated initcall-like functions) during kernel start and module load. Constructors are e.g. used for gcov data initialization. Disable constructor support for usermode Linux to prevent conflicts with host glibc. Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15driver core: set default SYSFS_DEPRECATED=nKay Sievers
All recent distros depend on the non-deprecated sysfs layout, so change the default value of the option to reflect that. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (53 commits) .gitignore: ignore *.lzma files kbuild: add generic --set-str option to scripts/config kbuild: simplify argument loop in scripts/config kbuild: handle non-existing options in scripts/config kallsyms: generalize text region handling kallsyms: support kernel symbols in Blackfin on-chip memory documentation: make version fix kbuild: fix a compile warning gitignore: Add GNU GLOBAL files to top .gitignore kbuild: fix delay in setlocalversion on readonly source README: fix misleading pointer to the defconf directory vmlinux.lds.h update kernel-doc: cleanup perl script Improve vmlinux.lds.h support for arch specific linker scripts kbuild: fix headers_exports with boolean expression kbuild/headers_check: refine extern check kbuild: fix "Argument list too long" error for "make headers_check", ignore *.patch files Remove bashisms from scripts menu: fix embedded menu presentation ...
2009-06-12perf_counter: Start documenting HAVE_PERF_COUNTERS requirementsMike Frysinger
Help out arch porters who want to support perf counters by listing some basic requirements. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1244827063-24046-1-git-send-email-vapier@gentoo.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: fsnotify: allow groups to set freeing_mark to null inotify/dnotify: should_send_event shouldn't match on FS_EVENT_ON_CHILD dnotify: do not bother to lock entry->lock when reading mask dnotify: do not use ?true:false when assigning to a bool fsnotify: move events should indicate the event was on a child inotify: reimplement inotify using fsnotify fsnotify: handle filesystem unmounts with fsnotify marks fsnotify: fsnotify marks on inodes pin them in core fsnotify: allow groups to add private data to events fsnotify: add correlations between events fsnotify: include pathnames with entries when possible fsnotify: generic notification queue and waitq dnotify: reimplement dnotify using fsnotify fsnotify: parent event notification fsnotify: add marks to inodes so groups can interpret how to handle those inodes fsnotify: unified filesystem notification backend
2009-06-11inotify: reimplement inotify using fsnotifyEric Paris
Reimplement inotify_user using fsnotify. This should be feature for feature exactly the same as the original inotify_user. This does not make any changes to the in kernel inotify feature used by audit. Those patches (and the eventual removal of in kernel inotify) will come after the new inotify_user proves to be working correctly. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-11perf_counter: Turn off by defaultIngo Molnar
Perfcounters were enabled by default to help testing - but now that we are submitting it upstream, make it default-disabled. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-09menu: fix embedded menu presentationRandy Dunlap
The STRIP_ASM_SYMS kconfig symbol mucks up the embedded menu because STRIP_ASM_SYMS is in the middle of the embedded menu items but it does not depend on EMBEDDED. Move it to beyond the end of the embedded menu so that the menu is presented correctly. Or if STRIP_ASM_SYMS should depend on EMBEDDED, that can also be fixed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14Merge branch 'core/urgent' into core/rcuIngo Molnar
Merge reason: new patches to be queued up depend on: ef631b0: rcu: Make hierarchical RCU less IPI-happy Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-11kbuild: make it possible for the linker to discard local symbols from vmlinuxDavid Howells
Make it possible for the linker to discard local symbols from vmlinux as they cause vmlinux to balloon when CONFIG_KALLSYMS=y and they cause dump_stack() and get_wchan() to produce useless information under some circumstances. With this we add a config option (CONFIG_STRIP_ASM_SYMS) that will cause the build to supply -X to the linker to tell it to strip temporary local symbols. This doesn't seem to cause gdb any problems. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-08Merge commit 'v2.6.30-rc1' into perfcounters/coreIngo Molnar
Conflicts: arch/powerpc/include/asm/systbl.h arch/powerpc/include/asm/unistd.h include/linux/init_task.h Merge reason: the conflicts are non-trivial: PowerPC placement of sys_perf_counter_open has to be mixed with the new preadv/pwrite syscalls. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07namespaces: mqueue namespace: adapt sysctlSerge E. Hallyn
Largely inspired from ipc/ipc_sysctl.c. This patch isolates the mqueue sysctl stuff in its own file. [akpm@linux-foundation.org: build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: need the upstream facility added by: 7f1e2ca: hrtimer: fix rq->lock inversion (again) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Make CONFIG_SLOW_WORK an automatic rather than manual config optionDavid Howells
Make CONFIG_SLOW_WORK an automatic rather than manual config option so that people configuring their kernels don't have to make the choice. It can be selected automatically by those things that require it (such as FS-Cache). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06perf_counter: hook up the tracepoint eventsPeter Zijlstra
Impact: new perfcounters feature Enable usage of tracepoints as perf counter events. tracepoint event ids can be found in /debug/tracing/event/*/*/id and (for now) are represented as -65536+id in the type field. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Orig-LKML-Reference: <20090319194233.744044174@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-03RCU: make treercu be defaultPaul E. McKenney
Impact: switch default config from CLASSIC_RCU to TREE_RCU Given that I have not gotten any complaints or bug reports on treercu recently, this patch makes it be the default. There are a number of other defconfig files that explicitly call out CLASSIC_RCU, but which have comment headers saying not to edit them. Probably holdovers from one of the flavors of "make config", but... Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: akpm@linux-foundation.org Cc: dipankar@in.ibm.com Cc: niv@us.ibm.com Cc: manfred@colorfullife.com Cc: peterz@infradead.org LKML-Reference: <20090403040625.GA9473@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03Create a dynamically sized pool of threads for doing very slow work itemsDavid Howells
Create a dynamically sized pool of threads for doing very slow work items, such as invoking mkdir() or rmdir() - things that may take a long time and may sleep, holding mutexes/semaphores and hogging a thread, and are thus unsuitable for workqueues. The number of threads is always at least a settable minimum, but more are started when there's more work to do, up to a limit. Because of the nature of the load, it's not suitable for a 1-thread-per-CPU type pool. A system with one CPU may well want several threads. This is used by FS-Cache to do slow caching operations in the background, such as looking up, creating or deleting cache objects. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-02cpusets: allow cpusets to be configured/built on non-SMP systemsPaul Menage
Allow cpusets to be configured/built on non-SMP systems Currently it's impossible to build cpusets under UML on x86-64, since cpusets depends on SMP and x86-64 UML doesn't support SMP. There's code in cpusets that doesn't depend on SMP. This patch surrounds the minimum amount of cpusets code with #ifdef CONFIG_SMP in order to allow cpusets to build/run on UP systems (for testing purposes under UML). Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul Menage <menage@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memcg: remove redundant message at swaponKAMEZAWA Hiroyuki
It's pointed out that swap_cgroup's message at swapon() is nonsense. Because * It can be calculated very easily if all necessary information is written in Kconfig. * It's not necessary to annoying people at every swapon(). In other view, now, memory usage per swp_entry is reduced to 2bytes from 8bytes(64bit) and I think it's reasonably small. Reported-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-03-30trivial: fix where cgroup documentation is not correctly referred toThadeu Lima de Souza Cascardo
cgroup documentation was moved to Documentation/cgroups/. There are some places that still refer to Documentation/controllers/, Documentation/cgroups.txt and Documentation/cpusets.txt. Fix those. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13Merge branches 'sched/clock', 'sched/urgent' and 'linus' into sched/coreIngo Molnar
2009-03-13Merge branch 'core/locking' into tracing/ftraceIngo Molnar
2009-03-10menu: fix embedded menu snafuRandy Dunlap
The COMPAT_BRK kconfig symbol does not depend on EMBEDDED, but it is in the midst of the EMBEDDED menu symbols, so it mucks up the EMBEDDED menu. Fix by moving it to just after all of the EMBEDDED menu symbols. Also, ANON_INODES has a similar problem, so move it to just above the EMBEDDED menu items since it is used in the EMBEDDED menu. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-06Merge branch 'x86/core' into tracing/texteditIngo Molnar
Conflicts: arch/x86/Kconfig block/blktrace.c kernel/irq/handle.c Semantic conflict: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04Merge branches 'x86/apic', 'x86/cpu', 'x86/fixmap', 'x86/mm', 'x86/sched', ↵Ingo Molnar
'x86/setup-lzma', 'x86/signal' and 'x86/urgent' into x86/core
2009-03-02Revert "menu: fix embedded menu snafu"Linus Torvalds
This reverts commit 155b25bcc28631a5b5230191aa3f56c40dfffa3f, which was totally wrong - the "embedded" options still exists (very much so) even on non-embedded platforms. It's just that we don't bother with actually asking about them when we're not embedded, we just take their default values (which is usually 'y' - the options add features that may not be worth it in a constrained environment). Noticed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-02menu: fix embedded menu snafuRandy Dunlap
The COMPAT_BRK kconfig symbol does not depend on EMBEDDED, but it is in the midst of the EMBEDDED menu symbols, so it mucks up the EMBEDDED menu. Fix by moving it to just after all of the EMBEDDED menu symbols. Also, surround all of the EMBEDDED symbols with "if EMBEDDED"/"endif" so that this EMBEDDED block is clearer. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-20tracing/markers: make markers select tracepointsFrederic Weisbecker
Sometimes it happens that KConfig dependencies are not handled like in the following scenario: - config A bool - config B bool depends on A - config C bool select B If one selects C, then it will select B without checking its dependency to A, if A hasn't been selected elsewhere, it will result in a build failure. This is what happens on the following build error: kernel/built-in.o: In function `marker_update_probe_range': (.text+0x52f64): undefined reference to `tracepoint_probe_register_noupdate' kernel/built-in.o: In function `marker_update_probe_range': (.text+0x52f74): undefined reference to `tracepoint_probe_unregister_noupdate' kernel/built-in.o: In function `marker_update_probe_range': (.text+0x52fb9): undefined reference to `tracepoint_probe_unregister_noupdate' kernel/built-in.o: In function `marker_update_probes': marker.c:(.text+0x530ba): undefined reference to `tracepoint_probe_update_all' CONFIG_KVM_TRACE will select CONFIG_MARKER, but the latter depends on CONFIG_TRACEPOINTS which will not be selected. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-11Merge commit 'v2.6.29-rc4' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/setup_percpu.c arch/x86/mm/fault.c drivers/acpi/processor_idle.c kernel/irq/handle.c
2009-02-08Merge branches 'sched/rt' and 'sched/urgent' into sched/coreIngo Molnar
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix kbuild.txt typos kbuild: print usage with no arguments in scripts/config Revert "kbuild: strip generated symbols from *.ko"
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (92 commits) gianfar: Revive VLAN support vlan: Export symbols as non GPL symbols. bnx2x: tx_has_work should not wait for FW netxen: reduce memory footprint netxen: fix vlan tso/checksum offload net: Fix linux/if_frad.h's suitability for userspace. net: Move config NET_NS to from net/Kconfig to init/Kconfig isdn: Fix missing ifdef in isdn_ppp networking: document "nc" in addition to "netcat" in netconsole.txt e1000e: workaround hw errata af_key: initialize xfrm encap_oa virtio_net: Fix MAX_PACKET_LEN to support 802.1Q VLANs lcs: fix compilation for !CONFIG_IP_MULTICAST rtl8187: Add termination packet to prevent stall iwlwifi: fix rs_get_rate WARN_ON() p54usb: fix packet loss with first generation devices sctp: Fix another socket race during accept/peeloff sctp: Properly timestamp outgoing data chunks for rtx purposes sctp: Correctly start rtx timer on new packet transmissions. sctp: Fix crc32c calculations on big-endian arhes. ...
2009-01-26net: Move config NET_NS to from net/Kconfig to init/KconfigMatt Helsley
Make NET_NS available underneath the generic Namespaces config option since all of the other namespace options are there. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22Merge branch 'core/debugobjects' into core/urgentThomas Gleixner
2009-01-21Merge commit 'v2.6.29-rc2' into perfcounters/coreIngo Molnar
Conflicts: include/linux/syscalls.h
2009-01-16sched: make plist a library facilityPeter Zijlstra
Ingo Molnar wrote: > here's a new build failure with tip/sched/rt: > > LD .tmp_vmlinux1 > kernel/built-in.o: In function `set_curr_task_rt': > sched.c:(.text+0x3675): undefined reference to `plist_del' > kernel/built-in.o: In function `pick_next_task_rt': > sched.c:(.text+0x37ce): undefined reference to `plist_del' > kernel/built-in.o: In function `enqueue_pushable_task': > sched.c:(.text+0x381c): undefined reference to `plist_del' Eliminate the plist library kconfig and make it available unconditionally. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-15cgroups: consolidate cgroup documentsLi Zefan
Move Documentation/cpusets.txt and Documentation/controllers/* to Documentation/cgroups/ Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15cgroups: clean up KconfigLi Zefan
- move CONFIG_PROC_PID_CPUSET into cgroup menu - move MM_OWNER to the bottom for better menu indent - fix typos - use tabs not spaces Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
