path: root/init/do_mounts_md.c
2009-03-31md: move lots of #include lines out of .h files and into .cNeilBrown
This makes the includes more explicit, and is preparation for moving md_k.h to drivers/md/md.h Remove include/raid/md.h as its only remaining use was to #include other files. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move LEVEL_* definition from md_k.h to md_u.hNeilBrown
.. as they are part of the user-space interface. Also move MdpMinorShift into there so we can remove duplication. Lastly move mdp_major in. It is less obviously part of the user-space interface, but do_mounts_md.c uses it, and it is acting a bit like user-space. Signed-off-by: NeilBrown <neilb@suse.de>
2009-02-21Consolidate driver_probe_done() loops into one placeArjan van de Ven
there's a few places that currently loop over driver_probe_done(), and I'm about to add another one. This patch abstracts it into a helper to reduce duplication. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Acked-by: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06autodetect_raid: add missing __init markingMike Frysinger
The function autodetect_raid is only used by __init functions, and it refers to __initdata, so it needs __init markings. Fixes this error: The function autodetect_raid() references the variable __initdata raid_noautodetect. This is often because autodetect_raid lacks a __initdata annotation or the annotation of raid_noautodetect is wrong. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-01init/do_mounts_md.c: remove duplicated #includeHuang Weiyi
Removed duplicated #include <linux/delay.h> in init/do_mounts_md.c. The same compile error ("error: implicit declaration of function 'msleep'") got fixed twice: - f8b77d39397e1510b1a3bcfd385ebd1a45aae77f ("init/do_mounts_md.c: msleep compile fix") - 73b4a24f5ff09389ba6277c53a266b142f655ed2 ("init/do_mounts_md.c must #include <linux/delay.h>") by people adding the <linux/delay.h> include in two slightly different places. Andrew's quilt scripts happily ignore the fuzz, and will re-apply the patch even though they had conflicts. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30init/do_mounts_md.c: msleep compile fixAlexey Dobriyan
init/do_mounts_md.c:285: error: implicit declaration of function 'msleep' Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16init/do_mounts_md.c must #include <linux/delay.h>Adrian Bunk
This patch fixes the following compile error caused by commit 589f800bb12c5cd6c9167bbf9bf3cb70cd8e422c ("fastboot: make the raid autodetect code wait for all devices to init"): CC init/do_mounts_md.o init/do_mounts_md.c: In function 'autodetect_raid': init/do_mounts_md.c:285: error: implicit declaration of function 'msleep' make[2]: *** [init/do_mounts_md.o] Error 1 Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-12raid: make RAID autodetect default a KConfig optionArjan van de Ven
RAID autodetect has the side effect of requiring synchronisation of all device drivers, which can make the boot several seconds longer (I've measured 7 on one of my laptops).... even for systems that don't have RAID setup for the root filesystem (the only FS where this matters). This patch makes the default for autodetect a config option; either way the user can always override via the kernel command line. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: NeilBrown <neilb@suse.de>
2008-10-12warning: fix init do_mounts_md cIngo Molnar
fix warning: init/do_mounts_md.c: In function ‘md_run_setup’: init/do_mounts_md.c:282: warning: ISO C90 forbids mixed declarations and code also, use the opportunity to put the RAID autodetection code into a separate function - this also solves a checkpatch style warning. No code changed: md5: aa36a35faef371b05f1974ad583bdbbd do_mounts_md.o.before.asm aa36a35faef371b05f1974ad583bdbbd do_mounts_md.o.after.asm Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-12fastboot: make the RAID autostart code print a message just before waitingArjan van de Ven
As requested/suggested by Neil Brown: make the raid code print that it's about to wait for probing to be done as well as give a suggestion on how to disable the probing if the user doesn't use raid. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com
2008-10-12fastboot: make the raid autodetect code wait for all devices to initArjan van de Ven
The raid autodetect code really needs to have all devices probed before it can detect raid arrays; not doing so would give rather messy situations where arrays would get detected as degraded while they shouldn't be etc. This is in preparation of removing the "wait for everything to init" code that makes everyone pay, not just raid users. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-05-24md: proper extern for mdp_majorAdrian Bunk
This patch adds a proper extern for mdp_major in include/linux/raid/md.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28init: fix integer as NULL pointer warningsHarvey Harrison
init/do_mounts_rd.c:215:13: warning: Using plain integer as NULL pointer init/do_mounts_md.c:136:45: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] md: remove MAX_MD_DEVS which is an arbitrary limitNeilBrown
Once upon a time we needed to fixed limit to the number of md devices, probably because we preallocated some array. This need no longer exists, but we still have an arbitrary limit. So remove MAX_MD_DEVS and allow as many devices as we can fit into the 'minor' part of a device number. Also remove some useless noise at init time (which reports MAX_MD_DEVS) and remove MD_THREAD_NAME_MAX which hasn't been used for a while. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove devfs from the init codeGreg Kroah-Hartman
This patch removes the devfs code from the init/ directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-06[PATCH] md: remove personality numbering from mdNeilBrown
md supports multiple different RAID level, each being implemented by a 'personality' (which is often in a separate module). These personalities have fairly artificial 'numbers'. The numbers are use to: 1- provide an index into an array where the various personalities are recorded 2- identify the module (via an alias) which implements are particular personality. Neither of these uses really justify the existence of personality numbers. The array can be replaced by a linked list which is searched (array lookup only happens very rarely). Module identification can be done using an alias based on level rather than 'personality' number. The current 'raid5' modules support two level (4 and 5) but only one personality. This slight awkwardness (which was handled in the mapping from level to personality) can be better handled by allowing raid5 to register 2 personalities. With this change in place, the core md module does not need to have an exhaustive list of all possible personalities, so other personalities can be added independently. This patch also moves the check for chunksize being non-zero into the ->run routines for the personalities that need it, rather than having it in core-md. This has a side effect of allowing 'faulty' and 'linear' not to have a chunk-size set. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
