path: root/init/init_task.c
2012-05-05init_task: Create generic init_task instanceThomas Gleixner
All archs define init_task in the same way (except ia64, but there is no particular reason why ia64 cannot use the common version). Create a generic instance so all archs can be converted over. The config switch is temporary and will be removed when all archs are converted over. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Link: http://lkml.kernel.org/r/20120503085034.092585287@linutronix.de
