[ Upstream commit 55d5b7dd6451b58489ce384282ca5a4a289eb8d5 ]
There is only one function in init/initramfs.c that is in the .text
section, and it is marked __weak. When building with clang-12 and the
integrated assembler, this leads to a bug with recordmcount:
./scripts/recordmcount "init/initramfs.o"
Cannot find symbol for section 2: .text.
init/initramfs.o: failed
I'm not quite sure what exactly goes wrong, but I notice that this
function is only ever called from an __init function, and normally
inlined. Marking it __init as well is clearly correct and it leads to
recordmcount no longer complaining.
Link: https://lkml.kernel.org/r/20201204165742.3815221-1-arnd@kernel.org
Cc: Nathan Chancellor <natechancellor@gmail.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Barret Rhoden <brho@google.com>
commit e99332e7b4cda6e60f5b5916cf9943a79dbef902 upstream.
It seems that for whatever reason, gcc-10 ends up not inlining a couple
of functions that used to be inlined before. Even if they only have one
single callsite - it looks like gcc may have decided that the code was
unlikely, and not worth inlining.
The code generation difference is harmless, but caused a few new section
mismatch errors, since the (now no longer inlined) function wasn't in
the __init section, but called other init functions:
Section mismatch in reference from the function kexec_free_initrd() to the function .init.text:free_initrd_mem()
Section mismatch in reference from the function tpm2_calc_event_log_size() to the function .init.text:early_memremap()
Section mismatch in reference from the function tpm2_calc_event_log_size() to the function .init.text:early_memunmap()
So add the appropriate __init annotation to make modpost not complain.
In both cases there were trivially just a single callsite from another
__init function.
With gcc-4.6.3:
WARNING: vmlinux.o(.text.unlikely+0x140): Section mismatch in reference from the function populate_initrd_image() to the variable .init.ramfs.info:__initramfs_size
The function populate_initrd_image() references
the variable __init __initramfs_size.
This is often because populate_initrd_image lacks a __init
annotation or the annotation of __initramfs_size is wrong.
WARNING: vmlinux.o(.text.unlikely+0x14c): Section mismatch in reference from the function populate_initrd_image() to the function .init.text:unpack_to_rootfs()
the function __init unpack_to_rootfs().
annotation or the annotation of unpack_to_rootfs is wrong.
WARNING: vmlinux.o(.text.unlikely+0x198): Section mismatch in reference from the function populate_initrd_image() to the function .init.text:xwrite()
the function __init xwrite().
annotation or the annotation of xwrite is wrong.
Indeed, if the compiler decides not to inline populate_initrd_image(), a
warning is generated.
Fix this by adding the missing __init annotations.
Link: http://lkml.kernel.org/r/20190617074340.12779-1-geert@linux-m68k.org
Fixes: 7c184ecd262fe64f ("initramfs: factor out a helper to populate the initrd image")
Since commit 54c7a8916a88 ("initramfs: free initrd memory if opening
/initrd.image fails"), the kernel has unconditionally attempted to free
the initrd even if it doesn't exist.
In the non-existent case this causes a boot-time splat if
CONFIG_DEBUG_VIRTUAL is enabled due to a call to virt_to_phys() with a
NULL address.
Instead we should check that the initrd actually exists and only attempt
to free it if it does.
Link: http://lkml.kernel.org/r/20190516143125.48948-1-steven.price@arm.com
Fixes: 54c7a8916a88 ("initramfs: free initrd memory if opening /initrd.image fails")
Signed-off-by: Steven Price <steven.price@arm.com>
Reported-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Various architectures including x86 poison the freed initrd memory. Do
the same in the generic free_initrd_mem implementation and switch a few
more architectures that are identical to the generic code over to it now.
Link: http://lkml.kernel.org/r/20190213174621.29297-9-hch@lst.de
Acked-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Catalin Marinas <catalin.marinas@arm.com> [arm64]
Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Cc: Steven Price <steven.price@arm.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Russell King <linux@armlinux.org.uk>
For most architectures free_initrd_mem just expands to the same
free_reserved_area call. Provide that as a generic implementation marked
__weak.
Link: http://lkml.kernel.org/r/20190213174621.29297-8-hch@lst.de
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
No need to handle the freeing disable in arch code when we already have a
core hook (and a different name for the option) for it.
Link: http://lkml.kernel.org/r/20190213174621.29297-7-hch@lst.de
Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64]
The code for kernels that support ramdisks or not is mostly the same.
Unify it by using an IS_ENABLED for the info message, and moving the error
message into a stub for populate_initrd_image.
[cai@lca.pw: fix a compilation error]
Link: http://lkml.kernel.org/r/20190328014806.36375-1-cai@lca.pw
Link: http://lkml.kernel.org/r/20190213174621.29297-6-hch@lst.de
Signed-off-by: Qian Cai <cai@lca.pw>
This will allow for cleaner code sharing in the caller.
Link: http://lkml.kernel.org/r/20190213174621.29297-5-hch@lst.de
Factor the kexec logic into a separate helper, and then inline the rest of
free_initrd into the only caller.
Link: http://lkml.kernel.org/r/20190213174621.29297-4-hch@lst.de
Patch series "initramfs tidyups".
I've spent some time chasing down behavior in initramfs and found
plenty of opportunity to improve the code. A first stab on that is
contained in this series.
This patch (of 7):
We free the initrd memory for all successful or error cases except for the
case where opening /initrd.image fails, which looks like an oversight.
Steven said:
: This also changes the behaviour when CONFIG_INITRAMFS_FORCE is enabled
: - specifically it means that the initrd is freed (previously it was
: ignored and never freed). But that seems like reasonable behaviour and
: the previous behaviour looks like another oversight.
Link: http://lkml.kernel.org/r/20190213174621.29297-3-hch@lst.de
Reviewed-by: Steven Price <steven.price@arm.com>
Use distinct error messages when archive decompression failed.
Link: http://lkml.kernel.org/r/20190212075635.7373-1-david.engraf@sysgo.com
Signed-off-by: David Engraf <david.engraf@sysgo.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Tested-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
Revert ff1522bb7d9845 ("initramfs: cleanup incomplete rootfs").
Andy reports
: This breaks my setup where I have U-boot provided more size of initramfs
: than needed. This allows a bit of flexibility to increase or decrease
: initramfs compressed image without taking care of bootloader. The proper
: solution is to do this if we sure that we didn't get enough memory,
: otherwise I can't consider the error fatal to clean up rootfs.
Fixes: ff1522bb7d9845 ("initramfs: cleanup incomplete rootfs")
Reported-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: David Engraf <david.engraf@sysgo.com>
Unpacking an external initrd may fail e.g. not enough memory. This
leads to an incomplete rootfs because some files might be extracted
already. Fixed by cleaning the rootfs so the kernel is not using an
incomplete rootfs.
Link: http://lkml.kernel.org/r/20181030151805.5519-1-david.engraf@sysgo.com
Pull in v4.20-rc5, solving a conflict we'll otherwise get in aio.c and
also getting the merge fix that went into mainline that users are
hitting testing for-4.21/block and/or for-next.
* tag 'v4.20-rc5': (664 commits)
Linux 4.20-rc5
PCI: Fix incorrect value returned from pcie_get_speed_cap()
MAINTAINERS: Update linux-mips mailing list address
ocfs2: fix potential use after free
mm/khugepaged: fix the xas_create_range() error path
mm/khugepaged: collapse_shmem() do not crash on Compound
mm/khugepaged: collapse_shmem() without freezing new_page
mm/khugepaged: minor reorderings in collapse_shmem()
mm/khugepaged: collapse_shmem() remember to clear holes
mm/khugepaged: fix crashes due to misaccounted holes
mm/khugepaged: collapse_shmem() stop if punched or truncated
mm/huge_memory: fix lockdep complaint on 32-bit i_size_read()
mm/huge_memory: splitting set mapping+index before unfreeze
mm/huge_memory: rename freeze_page() to unmap_page()
initramfs: clean old path before creating a hardlink
kernel/kcov.c: mark funcs in __sanitizer_cov_trace_pc() as notrace
psi: make disabling/enabling easier for vendor kernels
proc: fixup map_files test on arm
debugobjects: avoid recursive calls with kmemleak
userfaultfd: shmem: UFFDIO_COPY: set the page dirty if VM_WRITE is not set
sys_link() can fail due to the new path already existing. This case
ofen occurs when we use a concated initrd, for example:
1) prepare a basic rootfs, it contains a regular files rc.local
lizhijian@:~/yocto-tiny-i386-2016-04-22$ cat etc/rc.local
#!/bin/sh
echo "Running /etc/rc.local..."
yocto-tiny-i386-2016-04-22$ find . | sed 's,^\./,,' | cpio -o -H newc | gzip -n -9 >../rootfs.cgz
2) create a extra initrd which also includes a etc/rc.local
lizhijian@:~/lkp-x86_64/etc$ echo "append initrd" >rc.local
lizhijian@:~/lkp/lkp-x86_64/etc$ cat rc.local
append initrd
lizhijian@:~/lkp/lkp-x86_64/etc$ ln rc.local rc.local.hardlink
append initrd
lizhijian@:~/lkp/lkp-x86_64/etc$ stat rc.local rc.local.hardlink
File: 'rc.local'
Size: 14 Blocks: 8 IO Block: 4096 regular file
Device: 801h/2049d Inode: 11296086 Links: 2
Access: (0664/-rw-rw-r--) Uid: ( 1002/lizhijian) Gid: ( 1002/lizhijian)
Access: 2018-11-15 16:08:28.654464815 +0800
Modify: 2018-11-15 16:07:57.514903210 +0800
Change: 2018-11-15 16:08:24.180228872 +0800
Birth: -
File: 'rc.local.hardlink'
Birth: -
lizhijian@:~/lkp/lkp-x86_64$ find . | sed 's,^\./,,' | cpio -o -H newc | gzip -n -9 >../rc-local.cgz
lizhijian@:~/lkp/lkp-x86_64$ gzip -dc ../rc-local.cgz | cpio -t
etc
etc/rc.local.hardlink <<< it will be extracted first at this initrd
etc/rc.local
3) concate 2 initrds and boot
lizhijian@:~/lkp$ cat rootfs.cgz rc-local.cgz >concate-initrd.cgz
lizhijian@:~/lkp$ qemu-system-x86_64 -nographic -enable-kvm -cpu host -smp 1 -m 1024 -kernel ~/lkp/linux/arch/x86/boot/bzImage -append "console=ttyS0 earlyprint=ttyS0 ignore_loglevel" -initrd ./concate-initr.cgz -serial stdio -nodefaults
In this case, sys_link(2) will fail and return -EEXIST, so we can only get
the rc.local at rootfs.cgz instead of rc-local.cgz
[akpm@linux-foundation.org: move code to avoid forward declaration]
Link: http://lkml.kernel.org/r/1542352368-13299-1-git-send-email-lizhijian@cn.fujitsu.com
Signed-off-by: Li Zhijian <lizhijian@cn.fujitsu.com>
Cc: Philip Li <philip.li@intel.com>
Cc: Li Zhijian <zhijianx.li@intel.com>
This removes a bunch of core and elevator related code. On the core
front, we remove anything related to queue running, draining,
initialization, plugging, and congestions. We also kill anything
related to request allocation, merging, retrieval, and completion.
Remove any checking for single queue IO schedulers, as they no
longer exist. This means we can also delete a bunch of code related
to request issue, adding, completion, etc - and all the SQ related
ops and helpers.
Also kill the load_default_modules(), as all that did was provide
for a way to load the default single queue elevator.
Tested-by: Ming Lei <ming.lei@redhat.com>
Reviewed-by: Omar Sandoval <osandov@fb.com>
Sparse checking used to be disabled on init/do_mounts.c and a few related
files because "Many of the syscalls used in this file expect some of the
arguments to be __user pointers not __kernel pointers".
However since 28128c61e ("kconfig.h: Include compiler types to avoid
missed struct attributes") the checks are, in fact, not disabled anymore
because of the more early include of "linux/compiler_types.h"
So remove the now ineffective #undefery that was done to disable these
warnings, as well as the associated comment.
Link: http://lkml.kernel.org/r/20180617115355.53799-1-luc.vanoostenryck@gmail.com
Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com>
Using this helper allows us to avoid the in-kernel calls to the
sys_getdents64() syscall. The ksys_ prefix denotes that this function
is meant as a drop-in replacement for the syscall. In particular, it
uses the same calling convention as sys_getdents64().
This patch is part of a series which removes in-kernel calls to syscalls.
On this basis, the syscall entry path can be streamlined. For details, see
http://lkml.kernel.org/r/20180325162527.GA17492@light.dominikbrodowski.net
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Using this wrapper allows us to avoid the in-kernel calls to the
sys_open() syscall. The ksys_ prefix denotes that this function is meant
as a drop-in replacement for the syscall. In particular, it uses the
same calling convention as sys_open().
Using the ksys_close() wrapper allows us to get rid of in-kernel calls
to the sys_close() syscall. The ksys_ prefix denotes that this function
uses the same calling convention as sys_close(), with one subtle
difference:
The few places which checked the return value did not care about the return
value re-writing in sys_close(), so simply use a wrapper around
__close_fd().
Using the ksys_ftruncate() wrapper allows us to get rid of in-kernel
calls to the sys_ftruncate() syscall. The ksys_ prefix denotes that this
function is meant as a drop-in replacement for the syscall. In
particular, it uses the same calling convention as sys_ftruncate().
Using the fs-interal do_fchownat() wrapper allows us to get rid of
fs-internal calls to the sys_fchownat() syscall.
Introducing the ksys_fchown() helper and the ksys_{,}chown() wrappers
allows us to avoid the in-kernel calls to the sys_{,l,f}chown() syscalls.
The ksys_ prefix denotes that these functions are meant as a drop-in
replacement for the syscalls. In particular, they use the same calling
convention as sys_{,l,f}chown().
remove in-kernel calls to syscall
Using the fs-internal do_fchmodat() helper allows us to get rid of
fs-internal calls to the sys_fchmodat() syscall.
Introducing the ksys_fchmod() helper and the ksys_chmod() wrapper allows
us to avoid the in-kernel calls to the sys_fchmod() and sys_chmod()
syscalls. The ksys_ prefix denotes that these functions are meant as a
drop-in replacement for the syscalls. In particular, they use the same
calling convention as sys_fchmod() and sys_chmod().
to syscall
Using the fs-internal do_linkat() helper allows us to get rid of
fs-internal calls to the sys_linkat() syscall.
Introducing the ksys_link() wrapper allows us to avoid the in-kernel
calls to sys_link() syscall. The ksys_ prefix denotes that this function
is meant as a drop-in replacement for the syscall. In particular, it uses
the same calling convention as sys_link().
In the near future, the only fs-external user of ksys_link() should be
converted to use vfs_link() instead.
to syscall
Using the fs-internal do_mknodat() helper allows us to get rid of
fs-internal calls to the sys_mknodat() syscall.
Introducing the ksys_mknod() wrapper allows us to avoid the in-kernel
calls to sys_mknod() syscall. The ksys_ prefix denotes that this function
the same calling convention as sys_mknod().
calls to syscall
Using the fs-internal do_symlinkat() helper allows us to get rid of
fs-internal calls to the sys_symlinkat() syscall.
Introducing the ksys_symlink() wrapper allows us to avoid the in-kernel
calls to the sys_symlink() syscall. The ksys_ prefix denotes that this
function is meant as a drop-in replacement for the syscall. In particular,
it uses the same calling convention as sys_symlink().
to syscall
Using the fs-internal do_mkdirat() helper allows us to get rid of
fs-internal calls to the sys_mkdirat() syscall.
Introducing the ksys_mkdir() wrapper allows us to avoid the in-kernel calls
to the sys_mkdir() syscall. The ksys_ prefix denotes that this function is
meant as a drop-in replacement for the syscall. In particular, it uses the
same calling convention as sys_mkdir().
sys_rmdir() syscall. The ksys_ prefix denotes that this function is meant
as a drop-in replacement for the syscall. In particular, it uses the same
calling convention as sys_rmdir().
sys_unlink() syscall. The ksys_ prefix denotes that this function is meant
calling convention as sys_unlink().
In the near future, all callers of ksys_unlink() should be converted to
call do_unlinkat() directly or, at least, to operate on regular kernel
pointers.
Using this helper allows us to avoid the in-kernel calls to the sys_write()
syscall. The ksys_ prefix denotes that this function is meant as a drop-in
replacement for the syscall. In particular, it uses the same calling
convention as sys_write().
In the near future, the do_mounts / initramfs callers of ksys_write()
should be converted to use filp_open() and vfs_write() instead.
Cc: linux-s390@vger.kernel.org
The cpio format uses a 32-bit number to encode file timestamps, which
breaks initramfs support in 2038. This reinterprets the timestamp as
unsigned, to give us another 68 years and avoids breaking until 2106.
Link: http://lkml.kernel.org/r/20171019095536.801199-1-arnd@arndb.de
Cc: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Stafford Horne <shorne@gmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
struct timespec is not y2038 safe on 32 bit machines.
Replace timespec with y2038 safe struct timespec64.
Note that the patch only changes the internals without
modifying the syscall interfaces. This will be part
of a separate series.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
sys_newlstat is a system call implementation that is meant for user
space, and that copies kernel-internal data structure to the user
format, which is not needed for in-kernel users.
Further, as we rearrange the system call implementation so we can extend
it with 64-bit time_t, the prototype for sys_newlstat changes.
This changes the initramfs code to use vfs_lstat directly, to get it out
of the way of the time_t changes, and make it slightly more efficient in
the process. Along the same lines we also replace sys_stat and
sys_stat64 with vfs_stat.
Link: http://lkml.kernel.org/r/20170314214932.4052842-1-arnd@arndb.de
Many "embedded" architectures provide CMDLINE_FORCE to allow the kernel
to override the command line provided by an inflexible bootloader.
However there is currrently no way for the kernel to override the
initramfs image provided by the bootloader meaning there are still ways
for bootloaders to make things difficult for us.
Fix this by introducing INITRAMFS_FORCE which can prevent the kernel
from loading the bootloader supplied image.
We use CMDLINE_FORCE (and its friend CMDLINE_EXTEND) to imply that the
system has an inflexible bootloader. This allow us to avoid presenting
this config option to users of systems where inflexible bootloaders
aren't usually a problem.
Link: http://lkml.kernel.org/r/20170217121940.30126-1-daniel.thompson@linaro.org
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Commit 17a9be317475 ("initramfs: Always do fput() and load modules after
rootfs populate") introduced an error for the
CONFIG_BLK_DEV_RAM=y
case, because even though the code looks fine, the compiler really wants
a statement after a label, or you'll get complaints:
init/initramfs.c: In function 'populate_rootfs':
init/initramfs.c:644:2: error: label at end of compound statement
That commit moved the subsequent statements to outside the compound
statement, leaving the label without any associated statements.
Reported-by: Jörg Otte <jrg.otte@gmail.com>
Fixes: 17a9be317475 ("initramfs: Always do fput() and load modules after rootfs populate")
Cc: stable@vger.kernel.org # if 17a9be317475 gets backported
In OpenRISC we do not have a bootloader passed initrd, but the built in
initramfs does contain the /init and other binaries, including modules.
The previous commit 08865514805d2 ("initramfs: finish fput() before
accessing any binary from initramfs") made a change to only call fput()
if the bootloader initrd was available, this caused intermittent crashes
for OpenRISC.
This patch changes the fput() to happen unconditionally if any rootfs is
loaded. Also, I added some comments to make it a bit more clear why we
call unpack_to_rootfs() multiple times.
Fixes: 08865514805d2 ("initramfs: finish fput() before accessing any binary from initramfs")
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Stafford Horne <shorne@gmail.com>
Commit 4a9d4b024a31 ("switch fput to task_work_add") implements a
schedule_work() for completing fput(), but did not guarantee calling
__fput() after unpacking initramfs. Because of this, there is a
possibility that during boot a driver can see ETXTBSY when it tries to
load a binary from initramfs as fput() is still pending on that binary.
This patch makes sure that fput() is completed after unpacking initramfs
and removes the call to flush_delayed_fput() in kernel_init() which
happens very late after unpacking initramfs.
Link: http://lkml.kernel.org/r/20170201140540.22051-1-lokeshvutla@ti.com
Reported-by: Murali Karicheri <m-karicheri2@ti.com>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Nishanth Menon <nm@ti.com>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Resolve shadow warnings that are produced in W=2 builds by renaming a
global with a too-generic name and renaming a formal parameter.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
On a system with low memory extracting the initramfs may fail. If this
happens the user gets "Failed to execute /init" instead of an initramfs
error.
Check return value of sys_write and call error() when the write was
incomplete or failed.
Now with 64bit bzImage and kexec tools, we support ramdisk that size is
bigger than 2g, as we could put it above 4G.
Found compressed initramfs image could not be decompressed properly. It
turns out that image length is int during decompress detection, and it
will become < 0 when length is more than 2G. Furthermore, during
decompressing len as int is used for inbuf count, that has problem too.
Change len to long, that should be ok as on 32 bit platform long is
32bits.
Tested with following compressed initramfs image as root with kexec.
gzip, bzip2, xz, lzma, lzop, lz4.
run time for populate_rootfs():
size name Nehalem-EX Westmere-EX Ivybridge-EX
9034400256 root_img : 26s 24s 30s
3561095057 root_img.lz4 : 28s 27s 27s
3459554629 root_img.lzo : 29s 29s 28s
3219399480 root_img.gz : 64s 62s 49s
2251594592 root_img.xz : 262s 260s 183s
2226366598 root_img.lzma: 386s 376s 277s
2901482513 root_img.bz2 : 635s 599s
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Rashika Kheria <rashika.kheria@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: P J P <ppandit@redhat.com>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: "Daniel M. Weeks" <dan@danweeks.net>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jan Beulich <JBeulich@suse.com>
When initrd (compressed or not) is used, kernel report data corrupted with
/dev/ram0.
The root cause:
During initramfs checking, if it is initrd, it will be transferred to
/initrd.image with sys_write.
sys_write only support 2G-4K write, so if the initrd ram is more than
that, /initrd.image will not complete at all.
Add local xwrite to loop calling sys_write to workaround the problem.
Also need to use xwrite in write_buffer() to handle:
image is uncompressed cpio and there is one big file (>2G) in it.
unpack_to_rootfs ===> write_buffer ===> actions[]/do_copy
At the same time, we don't need to worry about sys_read/sys_write in
do_mounts_rd.c::crd_load. As decompressor will have fill/flush and local
buffer that is smaller than 2G.
Test with uncompressed initrd, and compressed ones with gz, bz2, lzma,xz,
lzop.
Acked-by: H. Peter Anvin <hpa@zytor.com>
This can greatly aid in narrowing down the real source of initramfs
problems such as failures related to the compression of the in-kernel
initramfs when an external initramfs is in use as well. Existing errors
are ambiguous as to which initramfs is a problem and why.
[akpm@linux-foundation.org: use pr_debug()]
Signed-off-by: Daniel M. Weeks <dan@danweeks.net>
Use constant format string in case message changes.
This patch adds default module loading and uses it to load the default
block elevator. During boot, it's called right after initramfs or
initrd is made available and right before control is passed to
userland. This ensures that as long as the modules are available in
the usual places in initramfs, initrd or the root filesystem, the
default modules are loaded as soon as possible.
This will replace the on-demand elevator module loading from elevator
init path.
v2: Fixed build breakage when !CONFIG_BLOCK. Reported by kbuild test
robot.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Alex Riesen <raa.lkml@gmail.com>
Cc: Fengguang We <fengguang.wu@intel.com>
The init/mount.o source files produce a number of sparse warnings of the
type:
warning: incorrect type in argument 1 (different address spaces)
expected char [noderef] <asn:1>*dev_name
got char *name
This is due to the syscalls expecting some of the arguments to be user
pointers but they are being passed as kernel pointers. This is harmless
but adds a lot of noise to a sparse build.
To limit the noise just disable the sparse checking in the relevant source
files, but still display a warning so that the user knows this has been
done.
Since the sparse checking has been disabled we can also remove the __user
__force casts that are scattered thru the source.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
initramfs: Fix build break on symbol-prefixed archs
initramfs: fix initramfs size calculation
initramfs: generalize initramfs_data.xxx.S variants
scripts/kallsyms: Enable error messages while hush up unnecessary warnings
scripts/setlocalversion: update comment
kbuild: Use a single clean rule for kernel and external modules
kbuild: Do not run make clean in $(srctree)
scripts/mod/modpost.c: fix commentary accordingly to last changes
kbuild: Really don't clean bounds.h and asm-offsets.h
