[ Upstream commit 6041186a32585fc7a1d0f6cfe2f138b05fdc3c82 ]
When a module option, or core kernel argument, toggles a static-key it
requires jump labels to be initialized early. While x86, PowerPC, and
ARM64 arrange for jump_label_init() to be called before parse_args(),
ARM does not.
Kernel command line: rdinit=/sbin/init page_alloc.shuffle=1 panic=-1 console=ttyAMA0,115200 page_alloc.shuffle=1
WARNING: CPU: 0 PID: 0 at ./include/linux/jump_label.h:303
page_alloc_shuffle+0x12c/0x1ac
static_key_enable(): static key 'page_alloc_shuffle_key+0x0/0x4' used
before call to jump_label_init()
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted
5.1.0-rc4-next-20190410-00003-g3367c36ce744 #1
Hardware name: ARM Integrator/CP (Device Tree)
[<c0011c68>] (unwind_backtrace) from [<c000ec48>] (show_stack+0x10/0x18)
[<c000ec48>] (show_stack) from [<c07e9710>] (dump_stack+0x18/0x24)
[<c07e9710>] (dump_stack) from [<c001bb1c>] (__warn+0xe0/0x108)
[<c001bb1c>] (__warn) from [<c001bb88>] (warn_slowpath_fmt+0x44/0x6c)
[<c001bb88>] (warn_slowpath_fmt) from [<c0b0c4a8>]
(page_alloc_shuffle+0x12c/0x1ac)
[<c0b0c4a8>] (page_alloc_shuffle) from [<c0b0c550>] (shuffle_store+0x28/0x48)
[<c0b0c550>] (shuffle_store) from [<c003e6a0>] (parse_args+0x1f4/0x350)
[<c003e6a0>] (parse_args) from [<c0ac3c00>] (start_kernel+0x1c0/0x488)
Move the fallback call to jump_label_init() to occur before
parse_args().
The redundant calls to jump_label_init() in other archs are left intact
in case they have static key toggling use cases that are even earlier
than option parsing.
Link: http://lkml.kernel.org/r/155544804466.1032396.13418949511615676665.stgit@dwillia2-desk3.amr.corp.intel.com
Reported-by: Guenter Roeck <groeck@google.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Russell King <rmk@armlinux.org.uk>
[ Upstream commit 4d217a5adccf5e806790c37c61cc374a08bd7381 ]
The newly added 'rodata_enabled' global variable is protected by
the wrong #ifdef, leading to a link error when CONFIG_DEBUG_SET_MODULE_RONX
is turned on:
kernel/module.o: In function `disable_ro_nx':
module.c:(.text.unlikely.disable_ro_nx+0x88): undefined reference to `rodata_enabled'
kernel/module.o: In function `module_disable_ro':
module.c:(.text.module_disable_ro+0x8c): undefined reference to `rodata_enabled'
kernel/module.o: In function `module_enable_ro':
module.c:(.text.module_enable_ro+0xb0): undefined reference to `rodata_enabled'
CONFIG_SET_MODULE_RONX does not exist, so use the correct one instead.
Fixes: 39290b389ea2 ("module: extend 'rodata=off' boot cmdline parameter to module mappings")
Signed-off-by: Jessica Yu <jeyu@redhat.com>
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream.
This is purely a preparatory patch for upcoming changes during the 4.19
merge window.
We have a function called "boot_cpu_state_init()" that isn't really
about the bootup cpu state: that is done much earlier by the similarly
named "boot_cpu_init()" (note lack of "state" in name).
This function initializes some hotplug CPU state, and needs to run after
the percpu data has been properly initialized. It even has a comment to
that effect.
Except it _doesn't_ actually run after the percpu data has been properly
initialized. On x86 it happens to do that, but on at least arm and
arm64, the percpu base pointers are initialized by the arch-specific
'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init().
This had some unexpected results, and in particular we have a patch
pending for the merge window that did the obvious cleanup of using
'this_cpu_write()' in the cpu hotplug init code:
- per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE;
+ this_cpu_write(cpuhp_state.state, CPUHP_ONLINE);
which is obviously the right thing to do. Except because of the
ordering issue, it actually failed miserably and unexpectedly on arm64.
So this just fixes the ordering, and changes the name of the function to
be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu
hotplug state, because the core CPU state was supposed to have already
been done earlier.
Marked for stable, since the (not yet merged) patch that will show this
problem is marked for stable.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com>
Suggested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: stable@kernel.org
commit 39290b389ea upstream.
The current "rodata=off" parameter disables read-only kernel mappings
under CONFIG_DEBUG_RODATA:
commit d2aa1acad22f ("mm/init: Add 'rodata=off' boot cmdline parameter
to disable read-only kernel mappings")
This patch is a logical extension to module mappings ie. read-only mappings
at module loading can be disabled even if CONFIG_DEBUG_SET_MODULE_RONX
(mainly for debug use). Please note, however, that it only affects RO/RW
permissions, keeping NX set.
This is the first step to make CONFIG_DEBUG_SET_MODULE_RONX mandatory
(always-on) in the future as CONFIG_DEBUG_RODATA on x86 and arm64.
Suggested-by: and Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Link: http://lkml.kernel.org/r/20161114061505.15238-1-takahiro.akashi@linaro.org
Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport]
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Greg Hackmann <ghackmann@google.com>
Kaiser only needs to map one page of the stack; and
kernel/fork.c did not build on powerpc (no __PAGE_KERNEL).
It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack()
and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's
kaiser_add_mapping() and kaiser_remove_mapping(). And use
linux/kaiser.h in init/main.c to avoid the #ifdefs there.
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Acked-by: Jiri Kosina <jkosina@suse.cz>
[ Upstream commit 08865514805d2de8e7002fa8149c5de3e391f412 ]
Commit 4a9d4b024a31 ("switch fput to task_work_add") implements a
schedule_work() for completing fput(), but did not guarantee calling
__fput() after unpacking initramfs. Because of this, there is a
possibility that during boot a driver can see ETXTBSY when it tries to
load a binary from initramfs as fput() is still pending on that binary.
This patch makes sure that fput() is completed after unpacking initramfs
and removes the call to flush_delayed_fput() in kernel_init() which
happens very late after unpacking initramfs.
Link: http://lkml.kernel.org/r/20170201140540.22051-1-lokeshvutla@ti.com
Reported-by: Murali Karicheri <m-karicheri2@ti.com>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Nishanth Menon <nm@ti.com>
commit f5b98461cb8167ba362ad9f74c41d126b7becea7 upstream.
Now that our crng uses chacha20, we can rely on its speedy
characteristics for replacing MD5, while simultaneously achieving a
higher security guarantee. Before the idea was to use these functions if
you wanted random integers that aren't stupidly insecure but aren't
necessarily secure either, a vague gray zone, that hopefully was "good
enough" for its users. With chacha20, we can strengthen this claim,
since either we're using an rdrand-like instruction, or we're using the
same crng as /dev/urandom. And it's faster than what was before.
We could have chosen to replace this with a SipHash-derived function,
which might be slightly faster, but at the cost of having yet another
RNG construction in the kernel. By moving to chacha20, we have a single
RNG to analyze and verify, and we also already get good performance
improvements on all platforms.
Implementation-wise, rather than use a generic buffer for both
get_random_int/long and memcpy based on the size needs, we use a
specific buffer for 32-bit reads and for 64-bit reads. This way, we're
guaranteed to always have aligned accesses on all platforms. While
slightly more verbose in C, the assembly this generates is a lot
simpler than otherwise.
Finally, on 32-bit platforms where longs and ints are the same size,
we simply alias get_random_int to get_random_long.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Suggested-by: Theodore Ts'o <tytso@mit.edu>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot time as
possible, hoping to capitalize on any possible variation in CPU operation
(due to runtime data differences, hardware differences, SMP ordering,
thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example for
how to manipulate kernel code using the gcc plugin internals.
The need for very-early boot entropy tends to be very architecture or
system design specific, so this plugin is more suited for those sorts
of special cases. The existing kernel RNG already attempts to extract
entropy from reliable runtime variation, but this plugin takes the idea to
a logical extreme by permuting a global variable based on any variation
in code execution (e.g. a different value (and permutation function)
is used to permute the global based on loop count, case statement,
if/then/else branching, etc).
To do this, the plugin starts by inserting a local variable in every
marked function. The plugin then adds logic so that the value of this
variable is modified by randomly chosen operations (add, xor and rol) and
random values (gcc generates separate static values for each location at
compile time and also injects the stack pointer at runtime). The resulting
value depends on the control flow path (e.g., loops and branches taken).
Before the function returns, the plugin mixes this local variable into
the latent_entropy global variable. The value of this global variable
is added to the kernel entropy pool in do_one_initcall() and _do_fork(),
though it does not credit any bytes of entropy to the pool; the contents
of the global are just used to mix the pool.
Additionally, the plugin can pre-initialize arrays with build-time
random contents, so that two different kernel builds running on identical
hardware will not have the same starting values.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message and code comments]
sprint_symbol_no_offset() returns the string "function_name
[module_name]" where [module_name] is not printed for built in kernel
functions. This means that the blacklisting code will fail when
comparing module function names with the extended string.
This patch adds the functionality to block a module's module_init()
function by finding the space in the string and truncating the
comparison to that length.
Link: http://lkml.kernel.org/r/1466124387-20446-1-git-send-email-prarit@redhat.com
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Yang Shi <yang.shi@linaro.org>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
There was only one use of __initdata_refok and __exit_refok
__init_refok was used 46 times against 82 for __ref.
Those definitions are obsolete since commit 312b1485fb50 ("Introduce new
section reference annotations tags: __ref, __refdata, __refconst")
This patch removes the following compatibility definitions and replaces
them treewide.
/* compatibility defines */
#define __init_refok __ref
#define __initdata_refok __refdata
#define __exit_refok __ref
I can also provide separate patches if necessary.
(One patch per tree and check in 1 month or 2 to remove old definitions)
Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Merge misc fixes from Andrew Morton:
"Two weeks worth of fixes here"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (41 commits)
init/main.c: fix initcall_blacklisted on ia64, ppc64 and parisc64
autofs: don't get stuck in a loop if vfs_write() returns an error
mm/page_owner: avoid null pointer dereference
tools/vm/slabinfo: fix spelling mistake: "Ocurrences" -> "Occurrences"
fs/nilfs2: fix potential underflow in call to crc32_le
oom, suspend: fix oom_reaper vs. oom_killer_disable race
ocfs2: disable BUG assertions in reading blocks
mm, compaction: abort free scanner if split fails
mm: prevent KASAN false positives in kmemleak
mm/hugetlb: clear compound_mapcount when freeing gigantic pages
mm/swap.c: flush lru pvecs on compound page arrival
memcg: css_alloc should return an ERR_PTR value on error
memcg: mem_cgroup_migrate() may be called with irq disabled
hugetlb: fix nr_pmds accounting with shared page tables
Revert "mm: disable fault around on emulated access bit architecture"
Revert "mm: make faultaround produce old ptes"
mailmap: add Boris Brezillon's email
mailmap: add Antoine Tenart's email
mm, sl[au]b: add __GFP_ATOMIC to the GFP reclaim mask
mm: mempool: kasan: don't poot mempool objects in quarantine
When I replaced kasprintf("%pf") with a direct call to
sprint_symbol_no_offset I must have broken the initcall blacklisting
feature on the arches where dereference_function_descriptor() is
non-trivial.
Fixes: c8cdd2be213f (init/main.c: simplify initcall_blacklisted())
Link: http://lkml.kernel.org/r/1466027283-4065-1-git-send-email-linux@rasmusvillemoes.dk
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Petr Mladek <pmladek@suse.com>
We've had the thread info allocated together with the thread stack for
most architectures for a long time (since the thread_info was split off
from the task struct), but that is about to change.
But the patches that move the thread info to be off-stack (and a part of
the task struct instead) made it clear how confused the allocator and
freeing functions are.
Because the common case was that we share an allocation with the thread
stack and the thread_info, the two pointers were identical. That
identity then meant that we would have things like
ti = alloc_thread_info_node(tsk, node);
tsk->stack = ti;
which certainly _worked_ (since stack and thread_info have the same
value), but is rather confusing: why are we assigning a thread_info to
the stack? And if we move the thread_info away, the "confusing" code
just gets to be entirely bogus.
So remove all this confusion, and make it clear that we are doing the
stack allocation by renaming and clarifying the function names to be
about the stack. The fact that the thread_info then shares the
allocation is an implementation detail, and not really about the
allocation itself.
This is a pure renaming and type fix: we pass in the same pointer, it's
just that we clarify what the pointer means.
The ia64 code that actually only has one single allocation (for all of
task_struct, thread_info and kernel thread stack) now looks a bit odd,
but since "tsk->stack" is actually not even used there, that oddity
doesn't matter. It would be a separate thing to clean that up, I
intentionally left the ia64 changes as a pure brute-force renaming and
type change.
Acked-by: Andy Lutomirski <luto@amacapital.net>
page_ext_init() checks suitable pages with pfn_to_nid(), but
pfn_to_nid() depends on memmap which will not be setup fully until
page_alloc_init_late() is done. Use early_pfn_to_nid() instead of
pfn_to_nid() so that page extension could be still used early even
though CONFIG_ DEFERRED_STRUCT_PAGE_INIT is enabled and catch early page
allocation call sites.
Suggested by Joonsoo Kim [1], this fix basically undoes the change
introduced by commit b8f1a75d61d840 ("mm: call page_ext_init() after all
struct pages are initialized") and fixes the same problem with a better
approach.
[1] http://lkml.kernel.org/r/CAAmzW4OUmyPwQjvd7QUfc6W1Aic__TyAuH80MLRZNMxKy0-wPQ@mail.gmail.com
Link: http://lkml.kernel.org/r/1464198689-23458-1-git-send-email-yang.shi@linaro.org
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Using kasprintf to get the function name makes us look up the name
twice, along with all the vsnprintf overhead of parsing the format
string etc. It also means there is an allocation failure case to deal
with. Since symbol_string in vsprintf.c would anyway allocate an array
of size KSYM_SYMBOL_LEN on the stack, that might as well be done up
here.
Moreover, since this is a debug feature and the blacklisted_initcalls
list is usually empty, we might as well test that and thus avoid looking
up the symbol name even once in the common case.
Acked-by: Prarit Bhargava <prarit@redhat.com>
printk() takes some locks and could not be used a safe way in NMI
context.
The chance of a deadlock is real especially when printing stacks from
all CPUs. This particular problem has been addressed on x86 by the
commit a9edc8809328 ("x86/nmi: Perform a safe NMI stack trace on all
CPUs").
The patchset brings two big advantages. First, it makes the NMI
backtraces safe on all architectures for free. Second, it makes all NMI
messages almost safe on all architectures (the temporary buffer is
limited. We still should keep the number of messages in NMI context at
minimum).
Note that there already are several messages printed in NMI context:
WARN_ON(in_nmi()), BUG_ON(in_nmi()), anything being printed out from MCE
handlers. These are not easy to avoid.
This patch reuses most of the code and makes it generic. It is useful
for all messages and architectures that support NMI.
The alternative printk_func is set when entering and is reseted when
leaving NMI context. It queues IRQ work to copy the messages into the
main ring buffer in a safe context.
__printk_nmi_flush() copies all available messages and reset the buffer.
Then we could use a simple cmpxchg operations to get synchronized with
writers. There is also used a spinlock to get synchronized with other
flushers.
We do not longer use seq_buf because it depends on external lock. It
would be hard to make all supported operations safe for a lockless use.
It would be confusing and error prone to make only some operations safe.
The code is put into separate printk/nmi.c as suggested by Steven
Rostedt. It needs a per-CPU buffer and is compiled only on
architectures that call nmi_enter(). This is achieved by the new
HAVE_NMI Kconfig flag.
The are MN10300 and Xtensa architectures. We need to clean up NMI
handling there first. Let's do it separately.
The patch is heavily based on the draft from Peter Zijlstra, see
https://lkml.org/lkml/2015/6/10/327
[arnd@arndb.de: printk-nmi: use %zu format string for size_t]
[akpm@linux-foundation.org: min_t->min - all types are size_t here]
Signed-off-by: Petr Mladek <pmladek@suse.com>
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> [arm part]
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Jiri Kosina <jkosina@suse.com>
When DEFERRED_STRUCT_PAGE_INIT is enabled, just a subset of memmap at
boot are initialized, then the rest are initialized in parallel by
starting one-off "pgdatinitX" kernel thread for each node X.
If page_ext_init is called before it, some pages will not have valid
extension, this may lead the below kernel oops when booting up kernel:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8118d982>] free_pcppages_bulk+0x2d2/0x8d0
PGD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 11 PID: 106 Comm: pgdatinit1 Not tainted 4.6.0-rc5-next-20160427 #26
Hardware name: Intel Corporation S5520HC/S5520HC, BIOS S5500.86B.01.10.0025.030220091519 03/02/2009
task: ffff88017c080040 ti: ffff88017c084000 task.ti: ffff88017c084000
RIP: 0010:[<ffffffff8118d982>] [<ffffffff8118d982>] free_pcppages_bulk+0x2d2/0x8d0
RSP: 0000:ffff88017c087c48 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000001
RDX: 0000000000000980 RSI: 0000000000000080 RDI: 0000000000660401
RBP: ffff88017c087cd0 R08: 0000000000000401 R09: 0000000000000009
R10: ffff88017c080040 R11: 000000000000000a R12: 0000000000000400
R13: ffffea0019810000 R14: ffffea0019810040 R15: ffff88066cfe6080
FS: 0000000000000000(0000) GS:ffff88066cd40000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 0000000002406000 CR4: 00000000000006e0
Call Trace:
free_hot_cold_page+0x192/0x1d0
__free_pages+0x5c/0x90
__free_pages_boot_core+0x11a/0x14e
deferred_free_range+0x50/0x62
deferred_init_memmap+0x220/0x3c3
kthread+0xf8/0x110
ret_from_fork+0x22/0x40
Code: 49 89 d4 48 c1 e0 06 49 01 c5 e9 de fe ff ff 4c 89 f7 44 89 4d b8 4c 89 45 c0 44 89 5d c8 48 89 4d d0 e8 62 c7 07 00 48 8b 4d d0 <48> 8b 00 44 8b 5d c8 4c 8b 45 c0 44 8b 4d b8 a8 02 0f 84 05 ff
RIP [<ffffffff8118d982>] free_pcppages_bulk+0x2d2/0x8d0
RSP <ffff88017c087c48>
Move page_ext_init() after page_alloc_init_late() to make sure page extension
is setup for all pages.
Link: http://lkml.kernel.org/r/1463696006-31360-1-git-send-email-yang.shi@linaro.org
Merge first patch-bomb from Andrew Morton:
- some misc things
- ofs2 updates
- about half of MM
- checkpatch updates
- autofs4 update
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
autofs4: fix string.h include in auto_dev-ioctl.h
autofs4: use pr_xxx() macros directly for logging
autofs4: change log print macros to not insert newline
autofs4: make autofs log prints consistent
autofs4: fix some white space errors
autofs4: fix invalid ioctl return in autofs4_root_ioctl_unlocked()
autofs4: fix coding style line length in autofs4_wait()
autofs4: fix coding style problem in autofs4_get_set_timeout()
autofs4: coding style fixes
autofs: show pipe inode in mount options
kallsyms: add support for relative offsets in kallsyms address table
kallsyms: don't overload absolute symbol type for percpu symbols
x86: kallsyms: disable absolute percpu symbols on !SMP
checkpatch: fix another left brace warning
checkpatch: improve UNSPECIFIED_INT test for bare signed/unsigned uses
checkpatch: warn on bare unsigned or signed declarations without int
checkpatch: exclude asm volatile from complex macro check
mm: memcontrol: drop unnecessary lru locking from mem_cgroup_migrate()
mm: migrate: consolidate mem_cgroup_migrate() calls
mm/compaction: speed up pageblock_pfn_to_page() when zone is contiguous
Use list_for_each_entry() instead of list_for_each() to simplify the code.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Pull cpu hotplug updates from Thomas Gleixner:
"This is the first part of the ongoing cpu hotplug rework:
- Initial implementation of the state machine
- Runs all online and prepare down callbacks on the plugged cpu and
not on some random processor
- Replaces busy loop waiting with completions
- Adds tracepoints so the states can be followed"
More detailed commentary on this work from an earlier email:
"What's wrong with the current cpu hotplug infrastructure?
- Asymmetry
The hotplug notifier mechanism is asymmetric versus the bringup and
teardown. This is mostly caused by the notifier mechanism.
- Largely undocumented dependencies
While some notifiers use explicitely defined notifier priorities,
we have quite some notifiers which use numerical priorities to
express dependencies without any documentation why.
- Control processor driven
Most of the bringup/teardown of a cpu is driven by a control
processor. While it is understandable, that preperatory steps,
like idle thread creation, memory allocation for and initialization
of essential facilities needs to be done before a cpu can boot,
there is no reason why everything else must run on a control
processor. Before this patch series, bringup looks like this:
Control CPU Booting CPU
do preparatory steps
kick cpu into life
do low level init
sync with booting cpu sync with control cpu
bring the rest up
- All or nothing approach
There is no way to do partial bringups. That's something which is
really desired because we waste e.g. at boot substantial amount of
time just busy waiting that the cpu comes to life. That's stupid
as we could very well do preparatory steps and the initial IPI for
other cpus and then go back and do the necessary low level
synchronization with the freshly booted cpu.
- Minimal debuggability
Due to the notifier based design, it's impossible to switch between
two stages of the bringup/teardown back and forth in order to test
the correctness. So in many hotplug notifiers the cancel
mechanisms are either not existant or completely untested.
- Notifier [un]registering is tedious
To [un]register notifiers we need to protect against hotplug at
every callsite. There is no mechanism that bringup/teardown
callbacks are issued on the online cpus, so every caller needs to
do it itself. That also includes error rollback.
What's the new design?
The base of the new design is a symmetric state machine, where both
the control processor and the booting/dying cpu execute a well
defined set of states. Each state is symmetric in the end, except
for some well defined exceptions, and the bringup/teardown can be
stopped and reversed at almost all states.
So the bringup of a cpu will look like this in the future:
kick cpu into life
do low level init
bring itself up
The synchronization step does not require the control cpu to wait.
That mechanism can be done asynchronously via a worker or some
other mechanism.
The teardown can be made very similar, so that the dying cpu cleans
up and brings itself down. Cleanups which need to be done after
the cpu is gone, can be scheduled asynchronously as well.
There is a long way to this, as we need to refactor the notion when a
cpu is available. Today we set the cpu online right after it comes
out of the low level bringup, which is not really correct.
The proper mechanism is to set it to available, i.e. cpu local
threads, like softirqd, hotplug thread etc. can be scheduled on that
cpu, and once it finished all booting steps, it's set to online, so
general workloads can be scheduled on it. The reverse happens on
teardown. First thing to do is to forbid scheduling of general
workloads, then teardown all the per cpu resources and finally shut it
off completely.
This patch series implements the basic infrastructure for this at the
core level. This includes the following:
- Basic state machine implementation with well defined states, so
ordering and prioritization can be expressed.
- Interfaces to [un]register state callbacks
This invokes the bringup/teardown callback on all online cpus with
the proper protection in place and [un]installs the callbacks in
the state machine array.
For callbacks which have no particular ordering requirement we have
a dynamic state space, so that drivers don't have to register an
explicit hotplug state.
If a callback fails, the code automatically does a rollback to the
previous state.
- Sysfs interface to drive the state machine to a particular step.
This is only partially functional today. Full functionality and
therefor testability will be achieved once we converted all
existing hotplug notifiers over to the new scheme.
- Run all CPU_ONLINE/DOWN_PREPARE notifiers on the booting/dying
processor:
kick cpu into life
do low level init
wait for boot
bring itself up
Signal completion to control cpu
In a previous step of this work we've done a full tree mechanical
conversion of all hotplug notifiers to the new scheme. The balance
is a net removal of about 4000 lines of code.
This is not included in this series, as we decided to take a
different approach. Instead of mechanically converting everything
over, we will do a proper overhaul of the usage sites one by one so
they nicely fit into the symmetric callback scheme.
I decided to do that after I looked at the ugliness of some of the
converted sites and figured out that their hotplug mechanism is
completely buggered anyway. So there is no point to do a
mechanical conversion first as we need to go through the usage
sites one by one again in order to achieve a full symmetric and
testable behaviour"
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
cpu/hotplug: Document states better
cpu/hotplug: Fix smpboot thread ordering
cpu/hotplug: Remove redundant state check
cpu/hotplug: Plug death reporting race
rcu: Make CPU_DYING_IDLE an explicit call
cpu/hotplug: Make wait for dead cpu completion based
cpu/hotplug: Let upcoming cpu bring itself fully up
arch/hotplug: Call into idle with a proper state
cpu/hotplug: Move online calls to hotplugged cpu
cpu/hotplug: Create hotplug threads
cpu/hotplug: Split out the state walk into functions
cpu/hotplug: Unpark smpboot threads from the state machine
cpu/hotplug: Move scheduler cpu_online notifier to hotplug core
cpu/hotplug: Implement setup/removal interface
cpu/hotplug: Make target state writeable
cpu/hotplug: Add sysfs state interface
cpu/hotplug: Hand in target state to _cpu_up/down
cpu/hotplug: Convert the hotplugged cpu work to a state machine
cpu/hotplug: Convert to a state machine for the control processor
cpu/hotplug: Add tracepoints
Pull read-only kernel memory updates from Ingo Molnar:
"This tree adds two (security related) enhancements to the kernel's
handling of read-only kernel memory:
- extend read-only kernel memory to a new class of formerly writable
kernel data: 'post-init read-only memory' via the __ro_after_init
attribute, and mark the ARM and x86 vDSO as such read-only memory.
This kind of attribute can be used for data that requires a once
per bootup initialization sequence, but is otherwise never modified
after that point.
This feature was based on the work by PaX Team and Brad Spengler.
(by Kees Cook, the ARM vDSO bits by David Brown.)
- make CONFIG_DEBUG_RODATA always enabled on x86 and remove the
Kconfig option. This simplifies the kernel and also signals that
read-only memory is the default model and a first-class citizen.
(Kees Cook)"
* 'mm-readonly-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ARM/vdso: Mark the vDSO code read-only after init
x86/vdso: Mark the vDSO code read-only after init
lkdtm: Verify that '__ro_after_init' works correctly
arch: Introduce post-init read-only memory
x86/mm: Always enable CONFIG_DEBUG_RODATA and remove the Kconfig option
mm/init: Add 'rodata=off' boot cmdline parameter to disable read-only kernel mappings
asm-generic: Consolidate mark_rodata_ro()
Handle the smpboot threads in the state machine.
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20160226182341.295777684@linutronix.de
Move the split out steps into a callback array and let the cpu_up/down
code iterate through the array functions. For now most of the
callbacks are asymmetric to resemble the current hotplug maze.
Link: http://lkml.kernel.org/r/20160226182340.671816690@linutronix.de
mappings
It may be useful to debug writes to the readonly sections of memory,
so provide a cmdline "rodata=off" to allow for this. This can be
expanded in the future to support "log" and "write" modes, but that
will need to be architecture-specific.
This also makes KDB software breakpoints more usable, as read-only
mappings can now be disabled on any kernel.
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Brown <david.brown@linaro.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: PaX Team <pageexec@freemail.hu>
Cc: kernel-hardening@lists.openwall.com
Cc: linux-arch <linux-arch@vger.kernel.org>
Link: http://lkml.kernel.org/r/1455748879-21872-3-git-send-email-keescook@chromium.org
Lockdep is initialized at compile time now. Get rid of lockdep_init().
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mike Krinkin <krinkin.m.u@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: mm-commits@vger.kernel.org
Make obsolete_checksetup() return bool due to this particular function
only using either one or zero as its return value.
No functional change.
Signed-off-by: Yaowei Bai <baiyaowei@cmss.chinamobile.com>
This commit adds the invocation of rcu_end_inkernel_boot() just before
init is invoked. This allows the CONFIG_RCU_EXPEDITE_BOOT Kconfig
option to do something useful and prepares for the upcoming
rcupdate.rcu_normal_after_boot kernel parameter.
We need to launch the usermodehelper kernel threads with the widest
affinity and this is partly why we use khelper. This workqueue has
unbound properties and thus a wide affinity inherited by all its children.
Now khelper also has special properties that we aren't much interested in:
ordered and singlethread. There is really no need about ordering as all
we do is creating kernel threads. This can be done concurrently. And
singlethread is a useless limitation as well.
The workqueue engine already proposes generic unbound workqueues that
don't share these useless properties and handle well parallel jobs.
The only worrysome specific is their affinity to the node of the current
CPU. It's fine for creating the usermodehelper kernel threads but those
inherit this affinity for longer jobs such as requesting modules.
This patch proposes to use these node affine unbound workqueues assuming
that a node is sufficient to handle several parallel usermodehelper
requests.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
Dave Hansen reported the following;
My laptop has been behaving strangely with 4.2-rc2. Once I log
in to my X session, I start getting all kinds of strange errors
from applications and see this in my dmesg:
VFS: file-max limit 8192 reached
The problem is that the file-max is calculated before memory is fully
initialised and miscalculates how much memory the kernel is using. This
patch recalculates file-max after deferred memory initialisation. Note
that using memory hotplug infrastructure would not have avoided this
problem as the value is not recalculated after memory hot-add.
4.1: files_stat.max_files = 6582781
4.2-rc2: files_stat.max_files = 8192
4.2-rc2 patched: files_stat.max_files = 6562467
Small differences with the patch applied and 4.1 but not enough to matter.
Reported-by: Dave Hansen <dave.hansen@intel.com>
Cc: Nicolai Stange <nicstange@gmail.com>
Cc: Alex Ng <alexng@microsoft.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Waiman Long reported that 24TB machines hit OOM during basic setup when
struct page initialisation was deferred. One approach is to initialise
memory on demand but it interferes with page allocator paths. This patch
creates dedicated threads to initialise memory before basic setup. It
then blocks on a rw_semaphore until completion as a wait_queue and counter
is overkill. This may be slower to boot but it's simplier overall and
also gets rid of a section mangling which existed so kswapd could do the
initialisation.
[akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast]
Cc: Waiman Long <waiman.long@hp.com
Cc: Nathan Zimmer <nzimmer@sgi.com>
Cc: Scott Norton <scott.norton@hp.com>
Tested-by: Daniel J Blueman <daniel@numascale.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
Commit 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before
timekeeping_init()" moved the ACPI subsystem initialization,
including the ACPI mode enabling, to an earlier point in the
initialization sequence, to allow the timekeeping subsystem
use ACPI early. Unfortunately, that resulted in boot regressions
on some systems and the early ACPI initialization was moved toward
its original position in the kernel initialization code by commit
c4e1acbb35e4 "ACPI / init: Invoke early ACPI initialization later".
However, that turns out to be insufficient, as boot is still broken
on the Tyan S8812 mainboard.
To fix that issue, split the ACPI early initialization code into
two pieces so the majority of it still located in acpi_early_init()
and the part switching over the platform into the ACPI mode goes into
a new function, acpi_subsystem_init(), executed at the original early
ACPI initialization spot.
That fixes the Tyan S8812 boot problem, but still allows ACPI
tables to be loaded earlier which is useful to the EFI code in
efi_enter_virtual_mode().
Link: https://bugzilla.kernel.org/show_bug.cgi?id=97141
Fixes: 73f7d1ca3263 "ACPI / init: Run acpi_early_init() before timekeeping_init()"
Reported-and-tested-by: Marius Tolzmann <tolzmann@molgen.mpg.de>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Reviewed-by: Lee, Chun-Yi <jlee@suse.com>
This adds an extra argument onto parse_params() to be used
as a way to make the unused callback a bit more useful and
generic by allowing the caller to pass on a data structure
of its choice. An example use case is to allow us to easily
make module parameters for every module which we will do
next.
@ parse @
identifier name, args, params, num, level_min, level_max;
identifier unknown, param, val, doing;
type s16;
extern char *parse_args(const char *name,
char *args,
const struct kernel_param *params,
unsigned num,
s16 level_min,
s16 level_max,
+ void *arg,
int (*unknown)(char *param, char *val,
const char *doing
+ , void *arg
@ parse_mod @
type s16;
char *args,
unsigned num,
s16 level_min,
s16 level_max,
+ void *arg,
const char *doing
+ , void *arg
@ parse_args_found @
expression R, E1, E2, E3, E4, E5, E6;
identifier func;
R =
parse_args(E1, E2, E3, E4, E5, E6,
+ NULL,
func);
R =
+ NULL,
&func);
R =
+ NULL,
NULL);
+ NULL,
func);
+ NULL,
&func);
+ NULL,
NULL);
@ parse_args_unused depends on parse_args_found @
identifier parse_args_found.func;
int func(char *param, char *val, const char *unused
+ , void *arg
@ mod_unused depends on parse_args_found @
expression A1, A2, A3;
- func(A1, A2, A3);
+ func(A1, A2, A3, NULL);
Generated-by: Coccinelle SmPL
Cc: cocci@systeme.lip6.fr
Cc: Felipe Contreras <felipe.contreras@gmail.com>
Cc: Ewan Milne <emilne@redhat.com>
Cc: Jean Delvare <jdelvare@suse.de>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
PAGE_SIZE is not guaranteed to be equal to or less than 8 times the
THREAD_SIZE.
E.g. architecture hexagon may have page size 1M and thread size 4096.
This would lead to a division by zero in the calculation of max_threads.
With this patch the buggy code is moved to a separate function
set_max_threads. The error is not fixed.
After fixing the problem in a separate patch the new function can be
reused to adjust max_threads after adding or removing memory.
Argument mempages of function fork_init() is removed as totalram_pages is
an exported symbol.
The creation of separate patches for refactoring to a new function and for
fixing the logic was suggested by Ingo Molnar.
Merge first patchbomb from Andrew Morton:
- arch/sh updates
- ocfs2 updates
- kernel/watchdog feature
- about half of mm/
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (122 commits)
Documentation: update arch list in the 'memtest' entry
Kconfig: memtest: update number of test patterns up to 17
arm: add support for memtest
arm64: add support for memtest
memtest: use phys_addr_t for physical addresses
mm: move memtest under mm
mm, hugetlb: abort __get_user_pages if current has been oom killed
mm, mempool: do not allow atomic resizing
memcg: print cgroup information when system panics due to panic_on_oom
mm: numa: remove migrate_ratelimited
mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZE
mm: split ET_DYN ASLR from mmap ASLR
s390: redefine randomize_et_dyn for ELF_ET_DYN_BASE
mm: expose arch_mmap_rnd when available
s390: standardize mmap_rnd() usage
powerpc: standardize mmap_rnd() usage
mips: extract logic for mmap_rnd()
arm64: standardize mmap_rnd() usage
x86: standardize mmap_rnd() usage
arm: factor out mmap ASLR into mmap_rnd
Add ioremap_pud_enabled() and ioremap_pmd_enabled(), which return 1 when
I/O mappings with pud/pmd are enabled on the kernel.
ioremap_huge_init() calls arch_ioremap_pud_supported() and
arch_ioremap_pmd_supported() to initialize the capabilities at boot-time.
A new kernel option "nohugeiomap" is also added, so that user can disable
the huge I/O map capabilities when necessary.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Cc: Robert Elliott <Elliott@hp.com>
Pull RCU changes from Ingo Molnar:
"The main changes in this cycle were:
- changes permitting use of call_rcu() and friends very early in
boot, for example, before rcu_init() is invoked.
- add in-kernel API to enable and disable expediting of normal RCU
grace periods.
- improve RCU's handling of (hotplug-) outgoing CPUs.
- NO_HZ_FULL_SYSIDLE fixes.
- tiny-RCU updates to make it more tiny.
- documentation updates.
- miscellaneous fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (58 commits)
cpu: Provide smpboot_thread_init() on !CONFIG_SMP kernels as well
cpu: Defer smpboot kthread unparking until CPU known to scheduler
rcu: Associate quiescent-state reports with grace period
rcu: Yet another fix for preemption and CPU hotplug
rcu: Add diagnostics to grace-period cleanup
rcutorture: Default to grace-period-initialization delays
rcu: Handle outgoing CPUs on exit from idle loop
cpu: Make CPU-offline idle-loop transition point more precise
rcu: Eliminate ->onoff_mutex from rcu_node structure
rcu: Process offlining and onlining only at grace-period start
rcu: Move rcu_report_unblock_qs_rnp() to common code
rcu: Rework preemptible expedited bitmask handling
rcu: Remove event tracing from rcu_cpu_notify(), used by offline CPUs
rcutorture: Enable slow grace-period initializations
rcu: Provide diagnostic option to slow down grace-period initialization
rcu: Detect stalls caused by failure to propagate up rcu_node tree
rcu: Eliminate empty HOTPLUG_CPU ifdef
rcu: Simplify sync_rcu_preempt_exp_init()
rcu: Put all orphan-callback-related code under same comment
rcu: Consolidate offline-CPU callback initialization
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
Currently, smpboot_unpark_threads() is invoked before the incoming CPU
has been added to the scheduler's runqueue structures. This might
potentially cause the unparked kthread to run on the wrong CPU, since the
correct CPU isn't fully set up yet.
That causes a sporadic, hard to debug boot crash triggering on some
systems, reported by Borislav Petkov, and bisected down to:
2a442c9c6453 ("x86: Use common outgoing-CPU-notification code")
This patch places smpboot_unpark_threads() in a CPU hotplug
notifier with priority set so that these kthreads are unparked just after
the CPU has been added to the runqueues.
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
Fix incorrect spelling of situation.
Signed-off-by: Frans Klaver <fransklaver@gmail.com>
Now we call ss->bind() in cgroup_init(), so cgroup_init() will
call cpuset_bind() and then the latter will access top_cpuset's
cpumask, which is NULL, because cpuset_init() is called after
cgroup_init()
The simplest fix is to swap cgroup_init() and cpuset_init().
Cc: Vladimir Davydov <vdavydov@parallels.com>
Fixes: 295458e67284 ("cgroup: call cgroup_subsys->bind on cgroup subsys initialization")
Reported by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Zefan Li <lizefan@huawei.com>
Acked-by: Vladimir Davydov <vdavydov@parallels.com>
CONFIG_INIT_FALLBACK adds config bloat without an obvious use case that
makes it worth keeping around. Delete it.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Chuck Ebbert <cebbert.lkml@gmail.com>
Cc: Frank Rowand <frowand.list@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Rob Landley <rob@landley.net>
Cc: Shuah Khan <shuah.kh@samsung.com>
The UP local API support can be set up from an early initcall. No need
for horrible hackery in the init code.
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Joerg Roedel <joro@8bytes.org>
Link: http://lkml.kernel.org/r/20150115211703.827943883@linutronix.de
Pull vfs pile #2 from Al Viro:
"Next pile (and there'll be one or two more).
The large piece in this one is getting rid of /proc/*/ns/* weirdness;
among other things, it allows to (finally) make nameidata completely
opaque outside of fs/namei.c, making for easier further cleanups in
there"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
coda_venus_readdir(): use file_inode()
fs/namei.c: fold link_path_walk() call into path_init()
path_init(): don't bother with LOOKUP_PARENT in argument
fs/namei.c: new helper (path_cleanup())
path_init(): store the "base" pointer to file in nameidata itself
make default ->i_fop have ->open() fail with ENXIO
make nameidata completely opaque outside of fs/namei.c
kill proc_ns completely
take the targets of /proc/*/ns/* symlinks to separate fs
bury struct proc_ns in fs/proc
copy address of proc_ns_ops into ns_common
new helpers: ns_alloc_inum/ns_free_inum
make proc_ns_operations work with struct ns_common * instead of void *
switch the rest of proc_ns_operations to working with &...->ns
netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns
make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns
common object embedded into various struct ....ns
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"As the merge window is still open, and this code was not as complex as
I thought it might be. I'm pushing this in now.
This will allow Thomas to debug his irq work for 3.20.
This adds two new features:
1) Allow traceopoints to be enabled right after mm_init().
By passing in the trace_event= kernel command line parameter,
tracepoints can be enabled at boot up. For debugging things like
the initialization of interrupts, it is needed to have tracepoints
enabled very early. People have asked about this before and this
has been on my todo list. As it can be helpful for Thomas to debug
his upcoming 3.20 IRQ work, I'm pushing this now. This way he can
add tracepoints into the IRQ set up and have users enable them when
things go wrong.
2) Have the tracepoints printed via printk() (the console) when they
are triggered.
If the irq code locks up or reboots the box, having the tracepoint
output go into the kernel ring buffer is useless for debugging.
But being able to add the tp_printk kernel command line option
along with the trace_event= option will have these tracepoints
printed as they occur, and that can be really useful for debugging
early lock up or reboot problems.
This code is not that intrusive and it passed all my tests. Thomas
tried them out too and it works for his needs.
Link: http://lkml.kernel.org/r/20141214201609.126831471@goodmis.org"
* tag 'trace-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add tp_printk cmdline to have tracepoints go to printk()
tracing: Move enabling tracepoints to just after rcu_init()
Enabling tracepoints at boot up can be very useful. The tracepoint
can be initialized right after RCU has been. There's no need to
wait for the early_initcall() to be called. That's too late for some
things that can use tracepoints for debugging. Move the logic to
enable tracepoints out of the initcalls and into init/main.c to
right after rcu_init().
This also allows trace_printk() to be used early too.
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1412121539300.16494@nanos
Link: http://lkml.kernel.org/r/20141214164104.307127356@goodmis.org
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Thomas Gleixner <tglx@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"In terms of changes, there's general maintenance to the Smack,
SELinux, and integrity code.
The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT,
which allows IMA appraisal to require signatures. Support for reading
keys from rootfs before init is call is also added"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: Remove security_ops extern
security: smack: fix out-of-bounds access in smk_parse_smack()
VFS: refactor vfs_read()
ima: require signature based appraisal
integrity: provide a hook to load keys when rootfs is ready
ima: load x509 certificate from the kernel
integrity: provide a function to load x509 certificate from the kernel
integrity: define a new function integrity_read_file()
Security: smack: replace kzalloc with kmem_cache for inode_smack
Smack: Lock mode for the floor and hat labels
ima: added support for new kernel cmdline parameter ima_template_fmt
ima: allocate field pointers array on demand in template_desc_init_fields()
ima: don't allocate a copy of template_fmt in template_desc_init_fields()
ima: display template format in meas. list if template name length is zero
ima: added error messages to template-related functions
ima: use atomic bit operations to protect policy update interface
ima: ignore empty and with whitespaces policy lines
ima: no need to allocate entry for comment
ima: report policy load status
ima: use path names cache
When we debug something, we'd like to insert some information to every
page. For this purpose, we sometimes modify struct page itself. But,
this has drawbacks. First, it requires re-compile. This makes us
hesitate to use the powerful debug feature so development process is
slowed down. And, second, sometimes it is impossible to rebuild the
kernel due to third party module dependency. At third, system behaviour
would be largely different after re-compile, because it changes size of
struct page greatly and this structure is accessed by every part of
kernel. Keeping this as it is would be better to reproduce errornous
situation.
This feature is intended to overcome above mentioned problems. This
feature allocates memory for extended data per page in certain place
rather than the struct page itself. This memory can be accessed by the
accessor functions provided by this code. During the boot process, it
checks whether allocation of huge chunk of memory is needed or not. If
not, it avoids allocating memory at all. With this advantage, we can
include this feature into the kernel in default and can avoid rebuild and
solve related problems.
Until now, memcg uses this technique. But, now, memcg decides to embed
their variable to struct page itself and it's code to extend struct page
has been removed. I'd like to use this code to develop debug feature, so
this patch resurrect it.
To help these things to work well, this patch introduces two callbacks for
clients. One is the need callback which is mandatory if user wants to
avoid useless memory allocation at boot-time. The other is optional, init
callback, which is used to do proper initialization after memory is
allocated. Detailed explanation about purpose of these functions is in
code comment. Please refer it.
Others are completely same with previous extension code in memcg.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Dave Hansen <dave@sr71.net>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Jungsoo Son <jungsoo.son@lge.com>
